path: root/Documentation/rtc.txt
2016-03-14rtc: implement a sysfs interface for clock offsetJoshua Clayton
clock offset may be set and read in decimal parts per billion attribute is /sys/class/rtc/rtcN/offset The attribute is only visible for rtcs that have set_offset implemented. Signed-off-by: Joshua Clayton <stillcompiling@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-03-24Documentation, split up rtc.txt into documentation and test filePrarit Bhargava
This patch splits rtc.txt into two separate files, one for the documentation itself, and the other for the rtctest.c file. The rtctest file is moved into the kernel tools/testing/selftests/timers directory. This will make automated testing easier. Note that the only difference in the rtc.txt file is that the location of the rtctest.c file has changed. Signed-off-by: Prarit Bhargava <prarit@redhat.com> Acked-by: Jonathan Corbet <corbet@lwn.net> Acked-by: John Stultz <john.stultz@linaro.org> Cc: corbet@lwn.net Cc: rtc-linux@googlegroups.com Cc: linux-doc@vger.kernel.org Cc: a.zummo@towertech.it Cc: prarit@redhat.com Cc: john.stultz@linaro.org Cc: shuahkh@osg.samsung.com Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2013-07-03rtc: add ability to push out an existing wakealarm using sysfsBernie Thompson
This adds the ability for the rtc sysfs code to handle += characters at the beginning of a wakealarm setting string. This will allow the user to attempt to push out an existing wakealarm by a provided amount. In the case that the += characters are provided but the alarm is not active -EINVAL is returned. his is useful, at least for my purposes in suspend/resume testing. The basic test goes something like: 1. Set a wake alarm from userspace 5 seconds in the future 2. Start the suspend process (echo mem > /sys/power/state) 3. After ~2.5 seconds if userspace is still running (using another thread to check this), move the wake alarm 5 more seconds If the "move" involves an unset of the wakealarm then there's a period of time where the system is midway through suspending but has no wake alarm. It will get stuck. We'd rather not remove the "move" since the idea is to avoid a cancelled suspend when the alarm fires _during_ suspend. It is difficult for the test to tell the difference between a suspend that was cancelled because the alarm fired too early and a suspend that was Signed-off-by: Bernie Thompson <bhthompson@chromium.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Doug Anderson <dianders@chromium.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06rtc-proc: permit the /proc/driver/rtc device to use other devicesKim, Milo
To get time information via /proc/driver/rtc, only the first device (rtc0) is used. If the rtcN (eg. rtc1 or rtc2) is used for the system clock, there is no way to get information of rtcN via /proc/driver/rtc. With this patch, the time data can be retrieved from the system clock RTC. If the RTC_HCTOSYS_DEVICE is not defined, then rtc0 is used by default. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-09RTC: Fix up rtc.txt documentation to reflect changes to generic rtc layerJohn Stultz
Now that the genric RTC layer handles much of the RTC functionality, the rtc.txt documentation needs to be updated to remove outdated information. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2009-09-23rtc: add boot_timesource sysfs attributeMatthew Garrett
CONFIG_RTC_HCTOSYS allows the kernel to read the system time from the RTC at boot and resume, avoiding the need for userspace to do so. Unfortunately userspace currently has no way to know whether this configuration option is enabled and thus cannot sensibly choose whether to run hwclock itself or not. Add a hctosys sysfs attribute which indicates whether a given RTC set the system clock. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23rtc: document the sysfs interfaceMatthew Garrett
The sysfs interface to the RTC class drivers is currently undocumented. Add some basic documentation defining the semantics of the fields. Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23rtc: update documentation wrt RTC_PIE/irq_set_stateMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc: cleanup example codeMike Frysinger
No functional changes here, just tighten up style/whitespace. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc: update documentation wrt irq_set_freqMike Frysinger
Document the proper use of the irq_set_freq function. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14rtc: tweak driver documentation for rtc periodicMike Frysinger
The max_user_freq member is not really meant for RTC drivers to modify, so update the rtc documentation so drivers writers know what is expected of them when handling periodic events. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17rtc: make example code jump to done instead of return when ioctl not supportedHans-Christian Egtvedt
Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: remove "RTC_ALM_SET mode" bugsDavid Brownell
This fixes a common glitch in how RTC drivers handle two "set alarm" modes, by getting rid of the surprising/hidden one that was rarely implemented correctly (and which could expose nonportable hardware-specific behavior). The glitch comes from the /dev/rtcX logic implementing the legacy RTC_ALM_SET (limited to 24 hours, needing RTC_AIE_ON) ioctl on top of the RTC driver call providing access to the newer RTC_WKALM_SET (without those limitations) by initializing the day/month/year fields to be invalid ... that second mode. Now, since few RTC drivers check those fields, and most hardware misbehaves when faced with invalid date fields, many RTC drivers will set bogus alarm times on those RTC_ALM_SET code paths. (Several in-tree drivers have that issue, and I also noticed it with code reviews on several new RTC drivers.) This patch ensures that RTC drivers never see such invalid alarm fields, by moving some logic out of rtc-omap into the RTC_ALM_SET code and adding an explicit check (which will prevent the issue on other code paths). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Scott Wood <scottwood@freescale.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] some rtc documentation updatesMike Frysinger
Fix typo when describing RTC_WKALM. Add some helpful pointers to people developing their own RTC driver. Change a bunch of the error messages in the test program to be a bit more helpful. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-25[PATCH] Documentation/rtc.txt updates (for rtc class)David Brownell
This updates the RTC documentation to summarize the two APIs now available: the old PC/AT one, and the new RTC class drivers. It also updates the included "rtctest.c" file to better meet Linux style guidelines, and to work with the new RTC drivers. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] rtc: small documentation updateJean Delvare
Rtc driver documentation update * Mention the max-user-freq control file. * Add missing header in example code. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
