path: root/Documentation/scsi/hptiop.txt
2009-10-02[SCSI] hptiop: Add RR44xx adapter supportHighPoint Linux Team
Most code changes were made to support RR44xx adapters. - add more PCI device ID. - using PCI BAR[2] to access RR44xx IOP. - using PCI BAR[0] to check and clear RR44xx IRQ. Signed-off-by: HighPoint Linux Team <linux@highpoint-tech.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2008-01-11[SCSI] hptiop: add more adapter models and other fixesHighPoint Linux Team
Most code changes were made to support adapters based on Marvell IOP, plus some other fixes. - add more PCI device IDs - support for adapters based on Marvell IOP - fix a result code translation error on big-endian systems - fix resource releasing bug when scsi_host_alloc() fail in hptiop_probe() - update scsi_cmnd.resid when finishing a request - correct some coding style issues [akpm@linux-foundation.org: type fixes] Signed-off-by: HighPoint Linux Team <linux@highpoint-tech.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2006-06-10[SCSI] hptiop: HighPoint RocketRAID 3xxx controller driverHighPoint Linux Team
HighPoint RocketRAID 3220/3320 series 8 channel PCI-X SATA RAID Host Adapters. Fixes from original submission: Merge Andrew Morton's patches: - Provide locking for global list - Fix debug printks - uninline function with multiple callsites - coding style fixups - remove unneeded casts of void* - kfree(NULL) is legal - Don't "succeed" if register_chrdev() failed - otherwise we'll later unregister a not-registered chrdev. - Don't return from hptiop_do_ioctl() with the spinlock held. - uninline __hpt_do_ioctl() Update for Arjan van de Ven's comments: - put all asm/ includes after the linux/ ones - replace mdelay with msleep - add pci posting flush - do not set pci command reqister in map_pci_bar - do not try merging sg elements in hptiop_buildsgl() - remove unused outstandingcommands member from hba structure - remove unimplemented hptiop_abort() handler - remove typedef u32 hpt_id_t Other updates: - fix endianess Signed-off-by: HighPoint Linux Team <linux@highpoint-tech.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
