path: root/Documentation/scsi/scsi_eh.txt
2018-05-29block: remove BLK_EH_HANDLEDChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-05-29block: rename BLK_EH_NOT_HANDLED to BLK_EH_DONEChristoph Hellwig
The BLK_EH_NOT_HANDLED implies nothing happen, but very often that is not what is happening - instead the driver already completed the command. Fix the symbolic name to reflect that a little better. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2017-04-06scsi: make asynchronous aborts mandatoryHannes Reinecke
There hasn't been any reports for HBAs where asynchronous abort would not work, so we should make it mandatory and remove the fallback. Signed-off-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-04-06scsi: make eh_eflags persistentHannes Reinecke
If a failed command is retried and fails again we need to enter SCSI EH, otherwise we will never be able to recover the command. To detect this situation we must not clear scmd->eh_eflags when EH finishes but rather make it persistent throughout the lifetime of the command. Signed-off-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Benjamin Block <bblock@linux.vnet.ibm.com> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-06-08scsi: fix race between simultaneous decrements of ->host_failedWei Fang
sas_ata_strategy_handler() adds the works of the ata error handler to system_unbound_wq. This workqueue asynchronously runs work items, so the ata error handler will be performed concurrently on different CPUs. In this case, ->host_failed will be decreased simultaneously in scsi_eh_finish_cmd() on different CPUs, and become abnormal. It will lead to permanently inequality between ->host_failed and ->host_busy, and scsi error handler thread won't start running. IO errors after that won't be handled. Since all scmds must have been handled in the strategy handler, just remove the decrement in scsi_eh_finish_cmd() and zero ->host_busy after the strategy handler to fix this race. Fixes: 50824d6c5657 ("[SCSI] libsas: async ata-eh") Cc: stable@vger.kernel.org Signed-off-by: Wei Fang <fangwei1@huawei.com> Reviewed-by: James Bottomley <jejb@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2014-10-29scsi: Fix "choir" and "beeing" malapropsFinn Thain
Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-12-19[SCSI] Update documentationHannes Reinecke
The documentation has gone out-of-sync, so update it to the current status. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2006-11-30Fix typos in /Documentation : MiscMatt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some misc words. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'H'-'M'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'H'-'M'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'D'-'E'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'D'-'E'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-04-10[PATCH] move ->eh_strategy_handler to the transport classChristoph Hellwig
Overriding the whole EH code is a per-transport, not per-host thing. Move ->eh_strategy_handler to the transport class, same as ->eh_timed_out. Downside is that scsi_host_alloc can't check for the total lack of EH anymore, but the transition period from old EH where we needed it is long gone already. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2005-11-06[SCSI] Documentation: typo in scsi/scsi_eh.txtStefan Richter
undefined symbol in Documentation/scsi/scsi_eh.txt Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-10[SCSI] scsi: Error handler description documentTejun Heo
This patch adds Documentation/scsi/scs_eh.txt. I've chosen plain text over DocBook as most other scsi docs are in plain text and it's more accessible. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
