path: root/Documentation/scsi
2011-07-27[SCSI] megaraid_sas Version to 5.40-rc1 and Changelog updateadam radford
Signed-off-by: Adam Radford <aradford@gmail.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-06-13doc: fix wrong arch/i386 referencesWanlong Gao
Change all "arch/i386" to "arch/x86" in Documentaion/, since the directory has changed. Also update the files which have changed their filename in the meantime accordingly. Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com> [jkosina@suse.cz: reword changelog] Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-24[SCSI] megaraid_sas: Version and Changelog updateadam radford
Signed-off-by: Adam Radford <aradford@gmail.com> Signed-off-by: James Bottomley <jbottomley@parallels.com>
2011-05-01[SCSI] qla2xxx: Update License file.Madhuranath Iyengar
Signed-off-by: Madhuranath Iyengar <Madhu.Iyengar@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-04-04Documentation: fix minor typos/spellingSylvestre Ledru
Fix some minor typos: * informations => information * there own => their own * these => this Signed-off-by: Sylvestre Ledru <sylvestre.ledru@scilab.org> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-14[SCSI] hpsa: export resettable host attributeStephen M. Cameron
This attribute, requested by Redhat, allows kexec-tools to know whether the controller can honor the reset_devices kernel parameter and actually reset the controller. For kdump to work properly it is necessary that the reset_devices parameter be honored. This attribute enables kexec-tools to warn the user if they attempt to designate a non-resettable controller as the dump device. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-28[SCSI] megaraid_sas: Version and Changelog updateadam radford
Signed-off-by: Adam Radford <aradford@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-18[SCSI] hpsa: Add transport_mode host attribute in /sysStephen M. Cameron
2011-01-24[SCSI] scsi_mid_low_api.txt recommend resid usageDouglas Gilbert
As discussed in a thread on this list titled: "RFC: short reads on block devices" this patch adds recommendations for LLDs to set resid when there might be uncertainty about how much data has been returned by a device. This patch inline and attached] is against scsi-misc-2.6.git Signed-off-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-24[SCSI] hpsa: allow driver to put controller in either simple or performant modeStephen M. Cameron
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2010-12-22[SCSI] megaraid_sas: Documentation updateadam radford
The following patch updates the Documentation/scsi/ChangeLog.megaraid_sas file. Signed-off-by: Adam Radford <aradford@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-22Merge branch 'master' into for-nextJiri Kosina
Conflicts: MAINTAINERS arch/arm/mach-omap2/pm24xx.c drivers/scsi/bfa/bfa_fcpim.c Needed to update to apply fixes for which the old branch was too outdated.
2010-12-21[SCSI] fix up documentation for change in ->queuecommand to lockless callingJames Bottomley
The current doc still says we call it with the host lock held, which is going to cause confusion. Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-26[SCSI] megaraid_sas: Version and documentation updateYang, Bo
Signed-off-by Bo Yang <bo.yang@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-10-08[SCSI] st: add MTWEOFI to write filemarks without flushing drive bufferKai Makisara
This patch adds a new MTIOCTOP operation MTWEOFI that writes filemarks with immediate bit set. This means that the drive does not flush its buffer and the next file can be started immediately. This speeds up writing in applications that have to write multiple small files. Signed-off-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-08-14Documentation: move SCSI parameters to their own text fileRandy Dunlap
Move SCSI parameters from kernel-parameters.txt to their own text file. This continues a trend of moving non-core parameters out of kernel-parameters.txt. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-27[SCSI] hpsa: expose controller firmware revision via /sys.Stephen M. Cameron
2010-07-27[SCSI] hpsa: Add hpsa.txt to Documentation/scsiStephen M. Cameron
2010-07-12fix comnment/printk typos concerning "empty"Uwe Kleine-König
2010-04-23Documentation/: it's -> its where appropriateFrancis Galiegue
Fix obvious cases of "it's" being used when "its" was meant. Signed-off-by: Francis Galiegue <fgaliegue@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-17[SCSI] megaraid_sas: version and documentation updateYang, Bo
Signed-off-by Bo Yang<bo.yang@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-10-29[SCSI] megaraid_sas: Update version number and documentationYang, Bo
2009-10-02[SCSI] hptiop: Add RR44xx adapter supportHighPoint Linux Team
Most code changes were made to support RR44xx adapters. - add more PCI device ID. - using PCI BAR[2] to access RR44xx IOP. - using PCI BAR[0] to check and clear RR44xx IRQ. Signed-off-by: HighPoint Linux Team <linux@highpoint-tech.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-09-21trivial: fix typos "man[ae]g?ment" -> "management"Uwe Kleine-Koenig
Signed-off-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-21trivial: fix typo "to to" in multiple filesAnand Gadiyar
Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: [SCSI] aic79xx: make driver respect nvram for IU and QAS settings [SCSI] don't attach ULD to Dell Universal Xport [SCSI] lpfc 8.3.3 : Update driver version to 8.3.3 [SCSI] lpfc 8.3.3 : Add support for Target Reset handler entrypoint [SCSI] lpfc 8.3.3 : Fix a couple of spin_lock and memory issues and a crash [SCSI] lpfc 8.3.3 : FC/FCOE discovery fixes [SCSI] lpfc 8.3.3 : Fix various SLI-3 vs SLI-4 differences [SCSI] qla2xxx: Resolve a performance issue in interrupt [SCSI] cnic, bnx2i: Fix build failure when CONFIG_PCI is not set. [SCSI] nsp_cs: time_out reaches -1 [SCSI] qla2xxx: fix printk format warnings [SCSI] ncr53c8xx: div reaches -1 [SCSI] compat: don't perform unneeded copy in sg_io code [SCSI] zfcp: Update FC pass-through support [SCSI] zfcp: Add FC pass-through support [SCSI] FC Pass Thru support
2009-06-12[SCSI] FC Pass Thru supportJames Smart
Attached is the ELS/CT pass-thru patch for the FC Transport. The patch creates a generic framework that lays on top of bsg and the SGIO v4 ioctl in order to pass transaction requests to LLDD's. The interface supports the following operations: On an fc_host basis: Request login to the specified N_Port_ID, creating an fc_rport. Request logout of the specified N_Port_ID, deleting an fc_rport Send ELS request to specified N_Port_ID w/o requiring a login, and wait for ELS response. Send CT request to specified N_Port_ID and wait for CT response. Login is required, but LLDD is allowed to manage login and decide whether it stays in place after the request is satisfied. Vendor-Unique request. Allows a LLDD-specific request to be passed to the LLDD, and the passing of a response back to the application. On an fc_rport basis: Send ELS request to nport and wait for ELS response. Send CT request to nport and wait for CT response. The patch also exports several headers from include/scsi such that they can be available to user-space applications: include/scsi/scsi.h include/scsi/scsi_netlink.h include/scsi/scsi_netlink_fc.h include/scsi/scsi_bsg_fc.h For further information, refer to the last RFC: http://marc.info/?l=linux-scsi&m=123436574018579&w=2 Note: Documentation is still spotty and will be added later. [bharrosh@panasas.com: update for new block API] Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-12trivial: Miscellaneous documentation typo fixesMatt LaPlante
Fix various typos in documentation txts. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-04-03[SCSI] aacraid driver updateLeubner, Achim
changes: - set aac_cache=2 as default value to avoid performance problem (Novell bugzilla #469922) - Dell/PERC controller boot problem fixed (RedHat bugzilla #457552) - WWN flag added to fix SLES10 SP1/SP2 drive detection problems - 64-bit support changes - DECLARE_PCI_DEVICE_TABLE macro added - controller type changes Signed-off-by: Achim Leubner <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] osd: Documentation for OSD libraryBoaz Harrosh
Add osd.txt to Documentation/scsi/ Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Reviewed-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-02-21[SCSI] cxgb3i: Fix spelling errors in documentationKaren Xie
Signed-off-by: Karen Xie <kxie@chelsio.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-08fix similar typos to successfullColy Li
When I review ocfs2 code, find there are 2 typos to "successfull". After doing grep "successfull " in kernel tree, 22 typos found totally -- great minds always think alike :) This patch fixes all the similar typos. Thanks for Randy's ack and comments. Signed-off-by: Coly Li <coyli@suse.de> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jeremy Kerr <jk@ozlabs.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06trivial: Fix misspelling of "firmware" in docs for ncr53c8xx/sym53c8xxNick Andrew
Fix misspelling of "firmware" in docs for ncr53c8xx/sym53c8xx It's spelled "firmware". Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-06trivial: fix then -> than typos in comments and documentationFrederik Schwarzer
- (better, more, bigger ...) then -> (...) than Signed-off-by: Frederik Schwarzer <schwarzerf@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-12-30[SCSI] cxgb3i: Add cxgb3i iSCSI driver.Karen Xie
This patch implements the cxgb3i iscsi connection acceleration for the open-iscsi initiator. The cxgb3i driver offers the iscsi PDU based offload: - digest insertion and verification - payload direct-placement into host memory buffer. Signed-off-by: Karen Xie <kxie@chelsio.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-30Rationalise Randy's address a bitAlan Cox
Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Remove Andrew Morton's old email accountsFrancois Cami
People can use the real name an an index into MAINTAINERS to find the current email address. Signed-off-by: Francois Cami <francois.cami@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-03[SCSI] fc_transport: Add an API to allow an LLD to create vportsAndrew Vasquez
There's already a fc_vport_termintate() call exported by the transport. This patch adds a symmetric call to the API to allow an NPIV-capable LLD to instantiate vports sans user intervention. Additional comments/updates: Re: scsi_fc_transport.txt Add a function prototype for fc_vport_terminate similar to what's done for fc_vport_create Re: fc_vport_create I recommend we pass the channel number in fc_vport_create rather than fixing it at zero. Also, ids->vport_type should be set to FC_PORTTYPE_NPIV prior to calling fc_vport_create. The comment is also meaningless. Added-by and Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-08-16[SCSI] megaraid_sas: version and Documentation UpdateYang, Bo
Signed-off-by: Bo Yang <bo.yang@lsi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-26Documentation cleanup: trivial misspelling, punctuation, and grammar ↵Matt LaPlante
corrections. Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
