path: root/Documentation/scsi
2006-10-04Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (54 commits) [SCSI] Initial Commit of qla4xxx [SCSI] raid class: handle component-add errors [SCSI] SCSI megaraid_sas: handle thrown errors [SCSI] SCSI aic94xx: handle sysfs errors [SCSI] SCSI st: fix error handling in module init, sysfs [SCSI] SCSI sd: fix module init/exit error handling [SCSI] SCSI osst: add error handling to module init, sysfs [SCSI] scsi: remove hosts.h [SCSI] scsi: Scsi_Cmnd convertion in aic7xxx_old.c [SCSI] megaraid_sas: sets ioctl timeout and updates version,changelog [SCSI] megaraid_sas: adds tasklet for cmd completion [SCSI] megaraid_sas: prints pending cmds before setting hw_crit_error [SCSI] megaraid_sas: function pointer for disable interrupt [SCSI] megaraid_sas: frame count optimization [SCSI] megaraid_sas: FW transition and q size changes [SCSI] qla2xxx: Update version number to 8.01.07-k2. [SCSI] qla2xxx: Stall mid-layer error handlers while rport is blocked. [SCSI] qla2xxx: Add MODULE_FIRMWARE tags. [SCSI] qla2xxx: Add support for host port state FC transport attribute. [SCSI] qla2xxx: Add support for fabric name FC transport attribute. ...
2006-10-04[SCSI] megaraid_sas: sets ioctl timeout and updates version,changelogSumant Patro
This patch sets timeout of max 180 seconds for ioctl completion. It also updates the Changelog and hikes the version to 3.05. Signed-off-by: Sumant Patro <Sumant.Patro@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-03Documentation: remove duplicated wordsPaolo Ornati
Remove many duplicated words under Documentation/ and do other small cleanups. Examples: "and and" --> "and" "in in" --> "in" "the the" --> "the" "the the" --> "to the" ... Signed-off-by: Paolo Ornati <ornati@fastwebnet.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'S'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letter 'S'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Alan Cox <alan@redhat.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'Q'-'R'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'Q'-'R'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix "can not" in Documentation and KconfigMatt LaPlante
Randy brought it to my attention that in proper english "can not" should always be written "cannot". I donot see any reason to argue, even if I mightnot understand why this rule exists. This patch fixes "can not" in several Documentation files as well as three Kconfigs. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'N'-'P'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'N'-'P'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'H'-'M'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'H'-'M'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'F'-'G'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'F'-'G'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'D'-'E'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'D'-'E'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'B'-'C'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'B'-'C'. There are also a few grammar fixes thrown in for Randy. ;) Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix some typos in Documentation/: 'A'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letter 'A'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03remove mentionings of devfs in documentationAdrian Bunk
Now that devfs is removed, there's no longer any need to document how to do this or that with devfs. This patch includes some improvements by Joe Perches. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-23[SCSI] aacraid: README updateMark Haverkamp
Received from Mark Salyzyn: This patch to the driver's documentation adds a few new product entries, sorts the entries on OEM lines first for easy searching, followed by product id order to make it easier to compare against the open source pci list. The driver has 'family match' so is somewhat future proof, no code changes are required to recognize the new products. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-08-29[SCSI] aic94xx: new driverJames Bottomley
This is the end point of the separate aic94xx driver based on the original driver and transport class from Luben Tuikov <ltuikov@yahoo.com> The log of the separate development is: Alexis Bruemmer: o aic94xx: fix hotplug/unplug for expanderless systems o aic94xx: disable split completion timer/setting by default o aic94xx: wide port off expander support o aic94xx: remove various inline functions o aic94xx: use bitops o aic94xx: remove queue comment o aic94xx: remove sas_common.c o aic94xx: sas remove depot's o aic94xx: use available list_for_each_entry_safe_reverse() o aic94xx: sas header file merge James Bottomley: o aic94xx: fix TF_TMF_NO_CTX processing o aic94xx: convert to request_firmware interface o aic94xx: fix hotplug/unplug o aic94xx: add link error counts to the expander phys o aic94xx: add transport class phy reset capability o aic94xx: remove local_attached flag o Remove README o Fixup Makefile variable for libsas rename o Rename sas->libsas o aic94xx: correct return code for sas_discover_event o aic94xx: use parent backlink port o aic94xx: remove channel abstraction o aic94xx: fix routing algorithms o aic94xx: add backlink port o aic94xx: fix cascaded expander properties o aic94xx: fix sleep under lock o aic94xx: fix panic on module removal in complex topology o aic94xx: make use of the new sas_port o rename sas_port to asd_sas_port o Fix for eh_strategy_handler move o aic94xx: move entirely over to correct transport class formulation o remove last vestages of sas_rphy_alloc() o update for eh_timed_out move o Preliminary expander support for aic94xx o sas: remove event thread o minor warning cleanups o remove last vestiges of id mapping arrays o Further updates o Convert aic94xx over entirely to the transport class end device and o update aic94xx/sas to use the new sas transport class end device o [PATCH] aic94xx: attaching to the sas transport class o Add missing completion removal from prior patch o [PATCH] aic94xx: attaching to the sas transport class o Build fixes from akpm Jeff Garzik: o [scsi aic94xx] Remove ->owner from PCI info table Luben Tuikov: o initial aic94xx driver Mike Anderson: o aic94xx: fix panic on module insertion o aic94xx: stub out SATA_DEV case o aic94xx: compile warning cleanups o aic94xx: sas_alloc_task o aic94xx: ref count update o aic94xx nexus loss time value o [PATCH] aic94xx: driver assertion in non-x86 BIOS env Randy Dunlap: o libsas: externs not needed Robert Tarte: o aic94xx: sequence patch - fixes SATA support Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-08-27Merge ../linux-2.6James Bottomley
2006-07-28[SCSI] arcmsr: initial driver, version 1.20.00.13Erich Chen
arcmsr is a driver for the Areca Raid controller, a host based RAID subsystem that speaks SCSI at the firmware level. This patch is quite a clean up over the initial submission with contributions from: Randy Dunlap <rdunlap@xenotime.net> Christoph Hellwig <hch@lst.de> Matthew Wilcox <matthew@wil.cx> Adrian Bunk <bunk@stusta.de> Signed-off-by: Erich Chen <erich@areca.com.tw> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-28[SCSI] megaraid_{mm,mbox}: a fix on "kernel unaligned access address" issueJu, Seokmann
There was an issue in the data structure defined by megaraid driver casuing "kernel unaligned access.." messages to be displayed during IOCTL on IA64 platform. The issue has been reported/fixed by Sakurai Hiroomi [sakurai_hiro@soft.fujitsu.com]. Signed-Off By: Seokmann Ju <seokmann.ju@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-28[SCSI] megaraid_{mm,mbox}: a fix on INQUIRY with EVPDJu, Seokmann
With this patch, driver will protect data corruption created by INQUIRY with EVPD request to megaraid controllers. As specified in the changelog, megaraid F/W already has fixed the issue and being under process of release. Meanwhile, driver will protect the system with this patch. Signed-Off By: Seokmann Ju <seokmann.ju@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-28[SCSI] megaraid_{mm,mbox}: 64-bit DMA capability checkerJu, Seokmann
This patch contains - a fix for 64-bit DMA capability check in megaraid_{mm,mbox} driver. - includes changes (going back to 32-bit DMA mask if 64-bit DMA mask failes) suggested by James with previous patch. - addition of SATA 150-4/6 as commented by Vasily Averin. With patch, the driver access PCIconfiguration space with dedicated offset to read a signature. If the signature read, it means that the controller has capability to handle 64-bit DMA. Without this patch, the driver used to blindly claim 64-bit DMA capability. The issue has been reported by Vasily Averin [vvs@sw.ru]. Thank you Vasily for the reporting. Signed-Off By: Seokmann Ju <seokmann.ju@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-03Merge ../scsi-misc-2.6James Bottomley
Conflicts: drivers/scsi/nsp32.c drivers/scsi/pcmcia/nsp_cs.c Removal of randomness flag conflicts with SA_ -> IRQF_ global replacement. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-02[PATCH] irq-flags: documentation: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28Merge ../linux-2.6/James Bottomley
Conflicts: drivers/scsi/aacraid/comminit.c Fixed up by removing the now renamed CONFIG_IOMMU option from aacraid Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-26remove the bouncing email address of David CampbellAdrian Bunk
This patch removes a bouncing email address from the kernel sources. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-26[SCSI] megaraid_sas: zcr with fixSumant Patro
The patch adds support for a ZCR controller (Device ID : 0x413). It also has a critical bug fix : Disable controller interrupt before firing INIT cmd to FW. Interrupt is enabled after required initialization is over. This is done to ensure that driver is ready to handle interrupts when it is generated by the controller. Signed-off-by: Sumant Patro <Sumant.Patro@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-19[SCSI] aacraid: Update supported product informationMark Haverkamp
Received From Mark Salyzyn Some of the cards product names changed. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-10Merge ../linux-2.6James Bottomley
2006-06-10[SCSI] scsi: remove Documentation/scsi/cpqfc.txtArthur Othieno
cpqfc driver flushed out with: [SCSI] remove broken driver cpqfc (commit ca61f10ab2b874b889e89d14ea09fae2dcccdca6) but somehow Documentation/scsi/cpqfc.txt managed to survive the blast. Signed-off-by: Arthur Othieno <apgo@patchbomb.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-10[SCSI] hptiop: HighPoint RocketRAID 3xxx controller driverHighPoint Linux Team
HighPoint RocketRAID 3220/3320 series 8 channel PCI-X SATA RAID Host Adapters. Fixes from original submission: Merge Andrew Morton's patches: - Provide locking for global list - Fix debug printks - uninline function with multiple callsites - coding style fixups - remove unneeded casts of void* - kfree(NULL) is legal - Don't "succeed" if register_chrdev() failed - otherwise we'll later unregister a not-registered chrdev. - Don't return from hptiop_do_ioctl() with the spinlock held. - uninline __hpt_do_ioctl() Update for Arjan van de Ven's comments: - put all asm/ includes after the linux/ ones - replace mdelay with msleep - add pci posting flush - do not set pci command reqister in map_pci_bar - do not try merging sg elements in hptiop_buildsgl() - remove unused outstandingcommands member from hba structure - remove unimplemented hptiop_abort() handler - remove typedef u32 hpt_id_t Other updates: - fix endianess Signed-off-by: HighPoint Linux Team <linux@highpoint-tech.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-06[SCSI] megaraid_sas: switch fw_outstanding to an atomic_tSumant Patro
This patch( originally submitted by Christoph Hellwig) removes instance_lock and changes fw_outstanding variable data type to atomic_t. Signed-off-by: Sumant Patro <Sumant.Patro@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-27[SCSI] megaraid_{mm,mbox}: fix a bug in reset handlerJu, Seokmann
When abort failed, the driver gets reset handleer called. In the reset handler, driver calls 'scsi_done()' callback for same SCSI command packet (struct scsi_cmnd) multiple times if there are multiple SCSI command packet in the pend_list. More over, if there are entry in the pend_lsit with IOCTL packet associated, the driver returns it to wrong free_list so that, in turn, the driver could end up with 'NULL pointer dereference..' during I/O command building with incorrect resource. Also, the patch contains several minor/cosmetic changes besides this. Signed-off-by: Seokmann Ju <seokmann.ju@lsil.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-10[PATCH] move ->eh_strategy_handler to the transport classChristoph Hellwig
Overriding the whole EH code is a per-transport, not per-host thing. Move ->eh_strategy_handler to the transport class, same as ->eh_timed_out. Downside is that scsi_host_alloc can't check for the total lack of EH anymore, but the transition period from old EH where we needed it is long gone already. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-02-04[SCSI] megaraid_sas: support for 1078 type controller addedSumant Patro
This patch adds support for 1078 type controller (device id : 0x60). Signed-off-by: Sumant Patro <Sumant.Patro@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-04[SCSI] megaraid_sas: register 16 byte CDB capabilityJoshua Giles
This patch properly registers the 16 byte command length capability of the megaraid_sas controlled hardware with the scsi midlayer. All megaraid_sas hardware supports 16 byte CDB's. Signed-off-by: Joshua Giles <joshua_giles@dell.com> Signed-off-by: Sumant Patro <Sumant.Patro@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-31[SCSI] aic7xxx: update documentationHannes Reinecke
This patch updates the documentation for aic7xxx and aic79xx with fixes from the adaptec driver. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-29[SCSI] megaraid_sas: new template defined to represent each type of controllersSumant Patro
This patch defines a new template to represent each type of controllers (identified by the processor used). The template has members that is set with appropriate values during driver initialisation. This change is done to support new controllers with minimal change to existing code. In future, for a new controller support, a template will be declared and its members initialised appropriately. Signed-off-by: Sumant Patro <Sumant.Patro@lsil.com> Rejections fixed and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-29[SCSI] megaraid_sas: cleanup queue command pathSumant Patro
This patch (originally submitted by Christoph Hellwig) removes code duplication in megasas_build_cmd. It also defines MEGASAS_IOC_FIRMWARE32 to allow 64 bit compiled applications to work. Signed-off-by: Sumant Patro <Sumant.Patro@lsil.com> Rejections fixed and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-12[SCSI] aacraid: README updateMark Haverkamp
Received From Mark Salyzyn. Move the README from the driver directory to the Documentation directory. Updated the documentation, added descriptions for cards that were missing. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
2006-01-03update the email address of Randy DunlapAdrian Bunk
This patch removes all references to the bouncing address rddunlap@osdl.org and one dead web page from the kernel. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Randy Dunlap <rdunlap@xenotime.net>
2005-12-13[SCSI] Mention scsi_scan_host() in scsi_mid_low_api.txtMatthew Wilcox
Update to mention scsi_scan_host() Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-13[SCSI] megaraid_{mbox,mm} : remove PCI Id overlaping between megaraid_legacy ↵Ju, Seokmann
and megaraid_{mbox,mm} Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-22[PATCH] kernel Doc/ URL correctionsRandy Dunlap
Correct lots of URLs in Documentation/ Also a few minor whitespace cleanups and typo/spello fixes. Sadly there are still a lot of bad URLs remaining. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[SCSI] remove Scsi_Device typedefChristoph Hellwig
2005-11-09[SCSI] remove Scsi_Host_Template typedefChristoph Hellwig
2005-11-06[SCSI] remove the obsolete SCSI qlogicisp driverAdrian Bunk
The SCSI qlogicisp driver is both marked BROKEN and superseded by the qla1280 driver. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-06[SCSI] Documentation: typo in scsi/scsi_eh.txtStefan Richter
undefined symbol in Documentation/scsi/scsi_eh.txt Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[SCSI] qla2xxx: Update license.Andrew Vasquez
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-12Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-for-linus-2.6 Linus Torvalds
2005-09-10[SCSI] scsi: Error handler description documentTejun Heo
This patch adds Documentation/scsi/scs_eh.txt. I've chosen plain text over DocBook as most other scsi docs are in plain text and it's more accessible. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
