Document the Smack bringup features. Update the proper location for
mounting smackfs from /smack to /sys/fs/smackfs. Fix some spelling errors.
Suggest the use of the load2 interface instead of the load interface.
Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
git://git.kernel.org/pub/scm/linux/kernel/git/sergeh/linux-security
Pull security layer updates from Serge Hallyn:
"This is a merge of James Morris' security-next tree from 3.14 to
yesterday's master, plus four patches from Paul Moore which are in
linux-next, plus one patch from Mimi"
* 'serge-next-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sergeh/linux-security:
ima: audit log files opened with O_DIRECT flag
selinux: conditionally reschedule in hashtab_insert while loading selinux policy
selinux: conditionally reschedule in mls_convert_context while loading selinux policy
selinux: reject setexeccon() on MNT_NOSUID applications with -EACCES
selinux: Report permissive mode in avc: denied messages.
Warning in scanf string typing
Smack: Label cgroup files for systemd
Smack: Verify read access on file open - v3
security: Convert use of typedef ctl_table to struct ctl_table
Smack: bidirectional UDS connect check
Smack: Correctly remove SMACK64TRANSMUTE attribute
SMACK: Fix handling value==NULL in post setxattr
bugfix patch for SMACK
Smack: adds smackfs/ptrace interface
Smack: unify all ptrace accesses in the smack
Smack: fix the subject/object order in smack_ptrace_traceme()
Minor improvement of 'smack_sb_kern_mount'
smack: fix key permission verification
KEYS: Move the flags representing required permission to linux/key.h
This allows to limit ptrace beyond the regular smack access rules.
It adds a smackfs/ptrace interface that allows smack to be configured
to require equal smack labels for PTRACE_MODE_ATTACH access.
See the changes in Documentation/security/Smack.txt below for details.
Signed-off-by: Lukasz Pawelczyk <l.pawelczyk@partner.samsung.com>
Signed-off-by: Rafal Krypa <r.krypa@samsung.com>
Fix double words "the the" in various files
within Documentations.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Rule modifications are enabled via /smack/change-rule. Format is as follows:
"Subject Object rwaxt rwaxt"
First two strings are subject and object labels up to 255 characters.
Third string contains permissions to enable.
Fourth string contains permissions to disable.
All unmentioned permissions will be left unchanged.
If no rule previously existed, it will be created.
Targeted for git://git.gitorious.org/smack-next/kernel.git
The userland git repository has been moved to a new place.
Signed-off-by: Daniel Wagner <daniel.wagner@bmw-carit.de>
Cc: Casey Schaufler <casey@schaufler-ca.com>
Cc: Rob Landley <rob@landley.net>
Cc: linux-security-module@vger.kernel.org
Cc: lkml@vger.kernel.org
Add /smack/revoke-subject special file. Writing a SMACK label to this file will
set the access to '-' for all access rules with that subject label.
V4 updated to current linux-security#next
Targeted for git://gitorious.org/smack-next/kernel.git
Modern application runtime environments like to use
naming schemes that are structured and generated without
human intervention. Even though the Smack limit of 23
characters for a label name is perfectly rational for
human use there have been complaints that the limit is
a problem in environments where names are composed from
a set or sources, including vendor, author, distribution
channel and application name. Names like
softwarehouse-pgwodehouse-coolappstore-mellowmuskrats
are becoming harder to avoid. This patch introduces long
label support in Smack. Labels are now limited to 255
characters instead of the old 23.
The primary reason for limiting the labels to 23 characters
was so they could be directly contained in CIPSO category sets.
This is still done were possible, but for labels that are too
large a mapping is required. This is perfectly safe for communication
that stays "on the box" and doesn't require much coordination
between boxes beyond what would have been required to keep label
names consistent.
The bulk of this patch is in smackfs, adding and updating
administrative interfaces. Because existing APIs can't be
changed new ones that do much the same things as old ones
have been introduced.
The Smack specific CIPSO data representation has been removed
and replaced with the data format used by netlabel. The CIPSO
header is now computed when a label is imported rather than
on use. This results in improved IP performance. The smack
label is now allocated separately from the containing structure,
allowing for larger strings.
Four new /smack interfaces have been introduced as four
of the old interfaces strictly required labels be specified
in fixed length arrays.
The access interface is supplemented with the check interface:
access "Subject Object rwxat"
access2 "Subject Object rwaxt"
The load interface is supplemented with the rules interface:
load "Subject Object rwxat"
load2 "Subject Object rwaxt"
The load-self interface is supplemented with the self-rules interface:
load-self "Subject Object rwxat"
load-self2 "Subject Object rwaxt"
The cipso interface is supplemented with the wire interface:
cipso "Subject lvl cnt c1 c2 ..."
cipso2 "Subject lvl cnt c1 c2 ..."
The old interfaces are maintained for compatibility.
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
move LSM-, credentials-, and keys-related files from Documentation/
to Documentation/security/,
add Documentation/security/00-INDEX, and
update all occurrences of Documentation/<moved_file>
to Documentation/security/<moved_file>.
