path: root/Documentation/security/keys-trusted-encrypted.txt
2011-06-27encrypted-keys: add ecryptfs format supportRoberto Sassu
The 'encrypted' key type defines its own payload format which contains a symmetric key randomly generated that cannot be used directly to mount an eCryptfs filesystem, because it expects an authentication token structure. This patch introduces the new format 'ecryptfs' that allows to store an authentication token structure inside the encrypted key payload containing a randomly generated symmetric key, as the same for the format 'default'. More details about the usage of encrypted keys with the eCryptfs filesystem can be found in the file 'Documentation/keys-ecryptfs.txt'. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Acked-by: Gianluca Ramunno <ramunno@polito.it> Acked-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2011-06-27encrypted-keys: add key format supportRoberto Sassu
This patch introduces a new parameter, called 'format', that defines the format of data stored by encrypted keys. The 'default' format identifies encrypted keys containing only the symmetric key, while other formats can be defined to support additional information. The 'format' parameter is written in the datablob produced by commands 'keyctl print' or 'keyctl pipe' and is integrity protected by the HMAC. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Acked-by: Gianluca Ramunno <ramunno@polito.it> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2011-05-19Create Documentation/security/,Randy Dunlap
move LSM-, credentials-, and keys-related files from Documentation/ to Documentation/security/, add Documentation/security/00-INDEX, and update all occurrences of Documentation/<moved_file> to Documentation/security/<moved_file>.
