path: root/Documentation/security
2012-04-25keys: update the documentation with info about "logon" keysJeff Layton
Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com>
2012-03-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates for 3.4 from James Morris: "The main addition here is the new Yama security module from Kees Cook, which was discussed at the Linux Security Summit last year. Its purpose is to collect miscellaneous DAC security enhancements in one place. This also marks a departure in policy for LSM modules, which were previously limited to being standalone access control systems. Chromium OS is using Yama, and I believe there are plans for Ubuntu, at least. This patchset also includes maintenance updates for AppArmor, TOMOYO and others." Fix trivial conflict in <net/sock.h> due to the jumo_label->static_key rename. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (38 commits) AppArmor: Fix location of const qualifier on generated string tables TOMOYO: Return error if fails to delete a domain AppArmor: add const qualifiers to string arrays AppArmor: Add ability to load extended policy TOMOYO: Return appropriate value to poll(). AppArmor: Move path failure information into aa_get_name and rename AppArmor: Update dfa matching routines. AppArmor: Minor cleanup of d_namespace_path to consolidate error handling AppArmor: Retrieve the dentry_path for error reporting when path lookup fails AppArmor: Add const qualifiers to generated string tables AppArmor: Fix oops in policy unpack auditing AppArmor: Fix error returned when a path lookup is disconnected KEYS: testing wrong bit for KEY_FLAG_REVOKED TOMOYO: Fix mount flags checking order. security: fix ima kconfig warning AppArmor: Fix the error case for chroot relative path name lookup AppArmor: fix mapping of META_READ to audit and quiet flags AppArmor: Fix underflow in xindex calculation AppArmor: Fix dropping of allowed operations that are force audited AppArmor: Add mising end of structure test to caps unpacking ...
2012-03-07Documentation: Fix multiple typo in DocumentationMasanari Iida
Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-02-16Yama: add PR_SET_PTRACER_ANYKees Cook
For a process to entirely disable Yama ptrace restrictions, it can use the special PR_SET_PTRACER_ANY pid to indicate that any otherwise allowed process may ptrace it. This is stronger than calling PR_SET_PTRACER with pid "1" because it includes processes in external pid namespaces. This is currently needed by the Chrome renderer, since its crash handler (Breakpad) runs external to the renderer's pid namespace. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: James Morris <jmorris@namei.org>
2012-02-10security: Yama LSMKees Cook
This adds the Yama Linux Security Module to collect DAC security improvements (specifically just ptrace restrictions for now) that have existed in various forms over the years and have been carried outside the mainline kernel by other Linux distributions like Openwall and grsecurity. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2012-01-19KEYS: Allow special keyrings to be clearedDavid Howells
The kernel contains some special internal keyrings, for instance the DNS resolver keyring : 2a93faf1 I----- 1 perm 1f030000 0 0 keyring .dns_resolver: empty It would occasionally be useful to allow the contents of such keyrings to be flushed by root (cache invalidation). Allow a flag to be set on a keyring to mark that someone possessing the sysadmin capability can clear the keyring, even without normal write access to the keyring. Set this flag on the special keyrings created by the DNS resolver, the NFS identity mapper and the CIFS identity mapper. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-11-16Merge branch 'master'; commit 'v3.2-rc2' into nextJames Morris
2011-11-16Documentation: clarify the purpose of LSMsKees Cook
Clarify the purpose of the LSM interface with some brief examples and pointers to additional documentation. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: James Morris <jmorris@namei.org>
2011-09-27doc: fix broken referencesPaul Bolle
There are numerous broken references to Documentation files (in other Documentation files, in comments, etc.). These broken references are caused by typo's in the references, and by renames or removals of the Documentation files. Some broken references are simply odd. Fix these broken references, sometimes by dropping the irrelevant text they were part of. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-30encrypted-keys: move ecryptfs documentation to proper locationMimi Zohar
Move keys-ecryptfs.txt to Documentation/security. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-06-27encrypted-keys: add ecryptfs format supportRoberto Sassu
The 'encrypted' key type defines its own payload format which contains a symmetric key randomly generated that cannot be used directly to mount an eCryptfs filesystem, because it expects an authentication token structure. This patch introduces the new format 'ecryptfs' that allows to store an authentication token structure inside the encrypted key payload containing a randomly generated symmetric key, as the same for the format 'default'. More details about the usage of encrypted keys with the eCryptfs filesystem can be found in the file 'Documentation/keys-ecryptfs.txt'. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Acked-by: Gianluca Ramunno <ramunno@polito.it> Acked-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2011-06-27encrypted-keys: add key format supportRoberto Sassu
This patch introduces a new parameter, called 'format', that defines the format of data stored by encrypted keys. The 'default' format identifies encrypted keys containing only the symmetric key, while other formats can be defined to support additional information. The 'format' parameter is written in the datablob produced by commands 'keyctl print' or 'keyctl pipe' and is integrity protected by the HMAC. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Acked-by: Gianluca Ramunno <ramunno@polito.it> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2011-05-19Create Documentation/security/,Randy Dunlap
move LSM-, credentials-, and keys-related files from Documentation/ to Documentation/security/, add Documentation/security/00-INDEX, and update all occurrences of Documentation/<moved_file> to Documentation/security/<moved_file>.
