path: root/Documentation/sound
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (250 commits) ALSA: hda: Storage class should be before const qualifier ASoC: tpa6130a2: Remove CPVSS and HPVdd supplies ASoC: tpa6130a2: Define output pins with SND_SOC_DAPM_OUTPUT ASoC: sdp4430 - add sdp4430 pcm ops to DAI. ASoC: TWL6040: Enable earphone path in codec ASoC: SDP4430: Add support for Earphone speaker ASoC: SDP4430: Add sdp4430 machine driver ASoC: tlv320dac33: Avoid powering off while in BIAS_OFF ASoC: tlv320dac33: Use dev_dbg in dac33_hard_power function ALSA: sound/pci/asihpi: Use kzalloc ALSA: hdmi - dont fail on extra nodes ALSA: intelhdmi - add id for the CougarPoint chipset ALSA: intelhdmi - user friendly codec name ALSA: intelhdmi - add dependency on SND_DYNAMIC_MINORS ALSA: asihpi: incorrect range check ALSA: asihpi: testing the wrong variable ALSA: es1688: add pedantic range checks ARM: McBSP: Add support for omap4 in McBSP driver ARM: McBSP: Fix request for irq in OMAP4 OMAP: McBSP: Add 32-bit mode support ...
2010-05-20Merge branch 'topic/hda' into for-linusTakashi Iwai
2010-05-10ALSA: Merge es1688 and es968 driversKrzysztof Helt
The ESS ES968 chip is nothing more then a PnP companion for a non-PnP audio chip. It was paired with non-PnP ESS' chips: ES688 and ES1688. The ESS' audio chips are handled by the es1688 driver in native mode. The PnP cards are handled by the ES968 driver in SB compatible mode. Move the ES968 chip handling to the es1688 driver so the driver can handle both PnP and non-PnP cards. The es968 is removed. Also, a new PnP id is added for the card I acquired (the change was tested on this card). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-23Documentation/: it's -> its where appropriateFrancis Galiegue
Fix obvious cases of "it's" being used when "its" was meant. Signed-off-by: Francis Galiegue <fgaliegue@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-04-22ALSA: Add support of AudioScience ASI boardsEliot Blennerhassett
Added the support of AudioScience ASI boards. The driver has been tested for years on alsa-driver external tree, now finally got merged to the kernel. Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-07Merge branch 'fix/hda' into topic/hdaTakashi Iwai
2010-04-01ALSA: hda - Update document about MSI and interruptsTakashi Iwai
2010-03-26ALSA: hda-intel - remove model=hwio from documentationJaroslav Kysela
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-03-26ALSA: hda-intel - remove model=hwio , use probe_only=3 insteadJaroslav Kysela
The probe_only module parameter skips the codec initialization, too. Remove the model=hwio code and use second bit in probe_only to skip the HDA codec reset procedure. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-03-26ALSA: hda-intel - add special 'hwio' model to bypass initializationJaroslav Kysela
Using the 'model=hwio' option, the driver bypasses any codec initialization and the reset procedure for codecs is also bypassed. This mode is usefull to enable direct access using hwdep interface (using hdaverb or hda-analyzer tools) and retain codec setup from BIOS. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-03-08Merge branch 'topic/misc' into for-linusTakashi Iwai
2010-03-01ALSA: ua101: add Edirol UA-1000 supportClemens Ladisch
Add support for the Edirol UA-1000 to the UA-101 driver. Both devices behave the same, so we just have to shuffle around some interface numbers and name strings. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-03-01Merge branch 'topic/hda' into for-linusTakashi Iwai
2010-02-23ALSA: hda - Add missing description in HD-Audio-Models.txtTakashi Iwai
2010-02-22ALSA: hda - Add Macmini 3,1 supportLuke Yelavich
BugLink: https://bugs.edge.launchpad.net/ubuntu/+source/linux/+bug/343989 Add a model quirk for the NVIDIA based Macmini hardware, aka Macmini 3,1. The pinout is almost identical to the mb5 quirk, except for no microphone and the line-in mixer controls being on a different index. Everything works in 2ch mode, but as I am not sure what needs to be changed for 6ch mode, or whether the Mac Mini's chip supports 6ch mode, I have simply duplicated the code from the mb5 quirk for the mac mini chmode management. The new model parameter for this quirk is "macmini3". Signed-off-by: Luke Yelavich <luke.yelavich@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-16Merge branch 'topic/misc' of ↵Jaroslav Kysela
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 into devel
2010-02-16Merge branch 'fixes' into develJaroslav Kysela
2010-02-13ALSA: hda - Add support for Lenovo IdeaPad U150Greg Alexander
Add patch for the Conexant 5066 HDA codec to support the Lenovo IdeaPad U150 Signed-off-by: Greg Alexander <greigs@galexander.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-28ALSA: hda - Allow override more fields via patch loaderTakashi Iwai
Allow the override of vendor-id, subsystem-id, revision-id and chip name via patch loading. Updated the document, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-24ALSA: hda - Add support for Toshiba Satellite M300Takashi Iwai
Added the support for Toshiba Satellite M300 with Conexant 5051 codec. Since the laptop has no port C connection and the pin reports always the jack sense true, we need to ignore port-C unsol event. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-23ALSA: hda - Minor fixes for Compaq Presario F700 quirkTakashi Iwai
Minor fixes for HP Compaq Presario F700 quirks with Cxt5051 codec: - changed the capture mixer elements to the standard name. - fixed the quirk name string without a space - sorted the quirk list - updated the documentation Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-18Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-01-18sound: virtuoso: add Xonar DS supportClemens Ladisch
Add experimental support for the Asus Xonar DS. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-14ALSA: ctxfi - Add subsystem optionTakashi Iwai
Added a new option "subsystem" to override the PCI SSID for identifying the card type. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-26ALSA: Fix a typo in Procfile.txtMasanari Iida
Fix a typo in Documentation/sound/alsa/Procfile.txt Signed-off-by Masanari Iida <standby24x7@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-25ALSA: jazz16: refine dma and irq selectionKrzysztof Helt
Narrow the dma and irq selection after the DOS driver. Add ALSA configuration description as well. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-25Merge branch 'fix/misc' into topic/miscTakashi Iwai
2009-12-22ALSA: hda - Add support for the new 27 inch IMacsRafael Avila de Espindola
With the attached patch I am able to use the sound on a new IMac 27. What works: *) Internal speakers *) Internal microphone *) Headphone I don't have an external mic or a SPDIF device to test the rest. Signed-off-by: Rafael Avila de Espindola <rafael.espindola@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-14sound: add Edirol UA-101 supportClemens Ladisch
Add experimental support for the Edirol UA-101 audio/MIDI interface. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-09Merge branch 'topic/hda' into for-linusTakashi Iwai
2009-12-09ALSA: document: Add direct git link to grub hda-analyzerAlexey Fisher
Just to save some time, add direct git link to grub hda-analyzer Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-08ALSA: hda - iMac 9,1 sound patch.Justin P. Mattock
This is an updated patch for the Apple iMac 9,1 model to add sound. Original patch posted here: http://article.gmane.org/gmane.linux.alsa.devel/61361/match= I have been using this patch for a while now and have to say it works vary well, except for a few minor things: With the iMac 24-inch 3.06GHz Intel Core 2 Duo everything seems to be working as it should, although I have not looked into the microphone (never really use one, nor have any apps to test, my guess is it doesn't work, or I never figured out how to get it to work). With the iMac 24-inch 2.66GHz Intel Core 2 Duo everything is the same as with the above machine except I'm hearing a light scratchy/distortion noise come out of the speakers when using headphones(above machine does not do this). Other than that the sound level is great(especially with good Dj headphones). Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Tested-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-04Merge branch 'topic/hda' into for-linusTakashi Iwai
2009-12-01Merge branch 'topic/beep-rename' into topic/core-changeTakashi Iwai
2009-11-18ALSA: hda - Fix mute-LED sync on HP laptops with IDT92HD83xxx codecsTakashi Iwai
The mute-LED isn't synchronized with the actual mute state on some HP laptops with IDT 92HD83xxx codecs. A similar hack using check_power_status callback is added for this codec, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-16ALSA: hda - Add description of beep_mode in ALSA-Configuration.txtTakashi Iwai
2009-11-05ALSA: rename "PC Speaker" controls to "Speaker"Jaroslav Kysela
To unify control names, rename "PC Speaker" to "Speaker" for PPC ALSA drivers. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-05ALSA: rename "PC Speaker" and "PC Beep" controls to "Beep"Jaroslav Kysela
To avoid confusion in control names for the standard analog PC Beep generator using a small Internal PC Speaker, rename all related "PC Speaker" and "PC Beep" controls to "Beep" only. This name is more universal and can be also used on more platforms without confusion. Introduce also "Internal Speaker" in ControlNames.txt for systems with full-featured build-in internal speaker. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-02ALSA: dummy - Fix descriptions of pcm_substreams parameterTakashi Iwai
Now up to 128 substreams are supported. Reported-by: Adrian Bridgett <adrian@smop.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-01ALSA: snd-pcsp: add nopcm modeStas Sergeev
Currently, if the high-res timers are unavailable, snd-pcsp does not initialize. People who choose it over pcspkr, loose their console beeps in that case and get annoyed. With this patch, the console beeps remain regardless of the high-res timers. Additionally, the "nopcm" modparam is added to forcibly disable the PCM capabilities of the driver. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-01Merge branch 'fix/misc' into topic/miscTakashi Iwai
2009-10-13Merge branch 'fix/hda' into for-linusTakashi Iwai
2009-10-13ALSA: hda - Fix mute sound with STAC9227/9228 codecsTakashi Iwai
On FSC laptops, the sound gets muted gradually when the volume is chnaged. This is due to the wrong volume-knob widget setup. The delta bit (bit 7) shouldn't be set for these devices. This patch adds a new quirk to set the value 0x7f to the widget 0x24 instead of 0xff. Reference: Novell bnc#546006 http://bugzilla.novell.com/show_bug.cgi?id=546006 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-10-05ALSA: sscape: force AD1848 codec mode on old SoundscapeKrzysztof Helt
Old Soundscape cards (pre PnP) work only with AD1848 codecs. If the CS4231 codec is installed it must be used in AD1848 compatible mode. Also, add gameport support and remove an unused mpu field. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-10-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of ssh://master.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (21 commits) ALSA: usb - Use strlcat() correctly ALSA: Fix invalid __exit in sound/mips/*.c ALSA: hda - Fix / improve ALC66x parser ALSA: ctxfi: Swapped SURROUND-SIDE mute sound: Make keywest_driver static ALSA: intel8x0 - Mute External Amplifier by default for Sony VAIO VGN-B1VP ALSA: hda - Fix digita/analog mic auto-switching with IDT codecs ASoC: fix kconfig order of Blackfin drivers ALSA: hda - Added quirk to enable sound on Toshiba NB200 ASoC: Fix dependency of CONFIG_SND_PXA2XX_SOC_IMOTE2 ALSA: Don't assume i2c device probing always succeeds ALSA: intel8x0 - Mute External Amplifier by default for Sony VAIO VGN-T350P ALSA: echoaudio - Re-enable the line-out control for the Mia card ALSA: hda - Resurrect input-source mixer of ALC268 model=acer ALSA: hda - Analog Devices AD1984A add HP Touchsmart model ALSA: hda - Add HP Pavilion dv4t-1300 to MSI whitelist ALSA: hda - CD-audio sound for hda-intel conexant benq laptop ASoC: DaVinci: Correct McASP FIFO initialization ASoC: Davinci: Fix race with cpu_dai->dma_data ASoC: DaVinci: Fix divide by zero error during 1st execution ...
2009-10-03Merge branch 'fix/hda' into for-linusTakashi Iwai
2009-10-01ALSA: sscape: convert to firmware loader frameworkKrzysztof Helt
The conversion solves the problem that firmware size was set to 64KB while non PnP cards have 128KB firmware files. An additional firmware initialization code has been moved from the OSS driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-29ALSA: hda - Analog Devices AD1984A add HP Touchsmart modelMiguel de Barros
Reference: ALSA bug #0004614 https://bugtrack.alsa-project.org/alsa-bug/view.php?id=4614 port-A (0x11) - front hp-out port-D (0x12) - rear line out port-E (0x1c) - front mic-in port-F (0x16) - Internal speakers digital-mic (0x17) - Internal mic init verbs, mixers, jack sensing and PCI_QUIRK to support this hardware Signed-off-by: Miguel de Barros <miguel.de.barros@bluewin.ch> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-21trivial: fix typos "man[ae]g?ment" -> "management"Uwe Kleine-Koenig
Signed-off-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
