path: root/Documentation/sync_file.txt
2017-05-24sync_file.txt: standardize document formatMauro Carvalho Chehab
Each text file under Documentation follows a different format. Some doesn't even have titles! Change its representation to follow the adopted standard, using ReST markups for it to be parseable by Sphinx: - Use markup for document title and authorship; - Mark literal blocks; - Use a numbered list for references. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.com> Link: http://patchwork.freedesktop.org/patch/msgid/e781f61e582e7c7eb5de456608043aff9fe2b2b5.1495157082.git.mchehab@s-opensource.com
2017-03-17Documentation: sync_file.txt: Fix typosTamara Diaconita
Fix spelling mistakes in sync_file.txt to make documentation clear. Signed-off-by: Tamara Diaconita <diaconita.tamara@gmail.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-10-25dma-buf: Rename struct fence to dma_fenceChris Wilson
I plan to usurp the short name of struct fence for a core kernel struct, and so I need to rename the specialised fence/timeline for DMA operations to make room. A consensus was reached in https://lists.freedesktop.org/archives/dri-devel/2016-July/113083.html that making clear this fence applies to DMA operations was a good thing. Since then the patch has grown a bit as usage increases, so hopefully it remains a good thing! (v2...: rebase, rerun spatch) v3: Compile on msm, spotted a manual fixup that I broke. v4: Try again for msm, sorry Daniel coccinelle script: @@ @@ - struct fence + struct dma_fence @@ @@ - struct fence_ops + struct dma_fence_ops @@ @@ - struct fence_cb + struct dma_fence_cb @@ @@ - struct fence_array + struct dma_fence_array @@ @@ - enum fence_flag_bits + enum dma_fence_flag_bits @@ @@ ( - fence_init + dma_fence_init | - fence_release + dma_fence_release | - fence_free + dma_fence_free | - fence_get + dma_fence_get | - fence_get_rcu + dma_fence_get_rcu | - fence_put + dma_fence_put | - fence_signal + dma_fence_signal | - fence_signal_locked + dma_fence_signal_locked | - fence_default_wait + dma_fence_default_wait | - fence_add_callback + dma_fence_add_callback | - fence_remove_callback + dma_fence_remove_callback | - fence_enable_sw_signaling + dma_fence_enable_sw_signaling | - fence_is_signaled_locked + dma_fence_is_signaled_locked | - fence_is_signaled + dma_fence_is_signaled | - fence_is_later + dma_fence_is_later | - fence_later + dma_fence_later | - fence_wait_timeout + dma_fence_wait_timeout | - fence_wait_any_timeout + dma_fence_wait_any_timeout | - fence_wait + dma_fence_wait | - fence_context_alloc + dma_fence_context_alloc | - fence_array_create + dma_fence_array_create | - to_fence_array + to_dma_fence_array | - fence_is_array + dma_fence_is_array | - trace_fence_emit + trace_dma_fence_emit | - FENCE_TRACE + DMA_FENCE_TRACE | - FENCE_WARN + DMA_FENCE_WARN | - FENCE_ERR + DMA_FENCE_ERR ) ( ... ) Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Acked-by: Sumit Semwal <sumit.semwal@linaro.org> Acked-by: Christian König <christian.koenig@amd.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/20161025120045.28839-1-chris@chris-wilson.co.uk
2016-08-11Documentation: add doc for sync_file_get_fence()Gustavo Padovan
Document the new function added to sync_file.c v2: Adapt to fence_array v3: Take in Chris Wilson suggestions Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Acked-by: Christian König <christian.koenig@amd.com> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
2016-06-03Documentation: Fix some grammar mistakes in sync_file.txtJavier Martinez Canillas
There are two sentences in the Sync File documentation where the english is a little off. This patch is an attempt to fix these. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Reviewed-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-04-29Documentation: add Sync File docGustavo Padovan
Add sync_file documentation on dma-buf-sync_file.txt Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
