path: root/Documentation/sysctl/00-INDEX
2009-04-02documentation: update Documentation/filesystem/proc.txt and ↵Shen Feng
Documentation/sysctls Now /proc/sys is described in many places and much information is redundant. This patch updates the proc.txt and move the /proc/sys desciption out to the files in Documentation/sysctls. Details are: merge - 2.1 /proc/sys/fs - File system data - 2.11 /proc/sys/fs/mqueue - POSIX message queues filesystem - 2.17 /proc/sys/fs/epoll - Configuration options for the epoll interface with Documentation/sysctls/fs.txt. remove - 2.2 /proc/sys/fs/binfmt_misc - Miscellaneous binary formats since it's not better then the Documentation/binfmt_misc.txt. merge - 2.3 /proc/sys/kernel - general kernel parameters with Documentation/sysctls/kernel.txt remove - 2.5 /proc/sys/dev - Device specific parameters since it's obsolete the sysfs is used now. remove - 2.6 /proc/sys/sunrpc - Remote procedure calls since it's not better then the Documentation/sysctls/sunrpc.txt move - 2.7 /proc/sys/net - Networking stuff - 2.9 Appletalk - 2.10 IPX to newly created Documentation/sysctls/net.txt. remove - 2.8 /proc/sys/net/ipv4 - IPV4 settings since it's not better then the Documentation/networking/ip-sysctl.txt. add - Chapter 3 Per-Process Parameters to descibe /proc/<pid>/xxx parameters. Signed-off-by: Shen Feng <shen@cn.fujitsu.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Add a 00-INDEX file to Documentation/sysctl/Jesper Juhl
Add a 00-INDEX file to Documentation/sysctl/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: Rob Landley <rob@landley.net> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
