path: root/Documentation/sysctl/fs.txt
2012-08-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull second vfs pile from Al Viro: "The stuff in there: fsfreeze deadlock fixes by Jan (essentially, the deadlock reproduced by xfstests 068), symlink and hardlink restriction patches, plus assorted cleanups and fixes. Note that another fsfreeze deadlock (emergency thaw one) is *not* dealt with - the series by Fernando conflicts a lot with Jan's, breaks userland ABI (FIFREEZE semantics gets changed) and trades the deadlock for massive vfsmount leak; this is going to be handled next cycle. There probably will be another pull request, but that stuff won't be in it." Fix up trivial conflicts due to unrelated changes next to each other in drivers/{staging/gdm72xx/usb_boot.c, usb/gadget/storage_common.c} * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (54 commits) delousing target_core_file a bit Documentation: Correct s_umount state for freeze_fs/unfreeze_fs fs: Remove old freezing mechanism ext2: Implement freezing btrfs: Convert to new freezing mechanism nilfs2: Convert to new freezing mechanism ntfs: Convert to new freezing mechanism fuse: Convert to new freezing mechanism gfs2: Convert to new freezing mechanism ocfs2: Convert to new freezing mechanism xfs: Convert to new freezing code ext4: Convert to new freezing mechanism fs: Protect write paths by sb_start_write - sb_end_write fs: Skip atime update on frozen filesystem fs: Add freezing handling to mnt_want_write() / mnt_drop_write() fs: Improve filesystem freezing handling switch the protection of percpu_counter list to spinlock nfsd: Push mnt_want_write() outside of i_mutex btrfs: Push mnt_want_write() outside of i_mutex fat: Push mnt_want_write() outside of i_mutex ...
2012-07-30fs: make dumpable=2 require fully qualified pathKees Cook
When the suid_dumpable sysctl is set to "2", and there is no core dump pipe defined in the core_pattern sysctl, a local user can cause core files to be written to root-writable directories, potentially with user-controlled content. This means an admin can unknowningly reintroduce a variation of CVE-2006-2451, allowing local users to gain root privileges. $ cat /proc/sys/fs/suid_dumpable 2 $ cat /proc/sys/kernel/core_pattern core $ ulimit -c unlimited $ cd / $ ls -l core ls: cannot access core: No such file or directory $ touch core touch: cannot touch `core': Permission denied $ OHAI="evil-string-here" ping localhost >/dev/null 2>&1 & $ pid=$! $ sleep 1 $ kill -SEGV $pid $ ls -l core -rw------- 1 root kees 458752 Jun 21 11:35 core $ sudo strings core | grep evil OHAI=evil-string-here While cron has been fixed to abort reading a file when there is any parse error, there are still other sensitive directories that will read any file present and skip unparsable lines. Instead of introducing a suid_dumpable=3 mode and breaking all users of mode 2, this only disables the unsafe portion of mode 2 (writing to disk via relative path). Most users of mode 2 (e.g. Chrome OS) already use a core dump pipe handler, so this change will not break them. For the situations where a pipe handler is not defined but mode 2 is still active, crash dumps will only be written to fully qualified paths. If a relative path is defined (e.g. the default "core" pattern), dump attempts will trigger a printk yelling about the lack of a fully qualified path. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Alan Cox <alan@linux.intel.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Doug Ledford <dledford@redhat.com> Cc: Serge Hallyn <serge.hallyn@canonical.com> Cc: James Morris <james.l.morris@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-29fs: add link restrictionsKees Cook
This adds symlink and hardlink restrictions to the Linux VFS. Symlinks: A long-standing class of security issues is the symlink-based time-of-check-time-of-use race, most commonly seen in world-writable directories like /tmp. The common method of exploitation of this flaw is to cross privilege boundaries when following a given symlink (i.e. a root process follows a symlink belonging to another user). For a likely incomplete list of hundreds of examples across the years, please see: http://cve.mitre.org/cgi-bin/cvekey.cgi?keyword=/tmp The solution is to permit symlinks to only be followed when outside a sticky world-writable directory, or when the uid of the symlink and follower match, or when the directory owner matches the symlink's owner. Some pointers to the history of earlier discussion that I could find: 1996 Aug, Zygo Blaxell http://marc.info/?l=bugtraq&m=87602167419830&w=2 1996 Oct, Andrew Tridgell http://lkml.indiana.edu/hypermail/linux/kernel/9610.2/0086.html 1997 Dec, Albert D Cahalan http://lkml.org/lkml/1997/12/16/4 2005 Feb, Lorenzo Hernández García-Hierro http://lkml.indiana.edu/hypermail/linux/kernel/0502.0/1896.html 2010 May, Kees Cook https://lkml.org/lkml/2010/5/30/144 Past objections and rebuttals could be summarized as: - Violates POSIX. - POSIX didn't consider this situation and it's not useful to follow a broken specification at the cost of security. - Might break unknown applications that use this feature. - Applications that break because of the change are easy to spot and fix. Applications that are vulnerable to symlink ToCToU by not having the change aren't. Additionally, no applications have yet been found that rely on this behavior. - Applications should just use mkstemp() or O_CREATE|O_EXCL. - True, but applications are not perfect, and new software is written all the time that makes these mistakes; blocking this flaw at the kernel is a single solution to the entire class of vulnerability. - This should live in the core VFS. - This should live in an LSM. (https://lkml.org/lkml/2010/5/31/135) - This should live in an LSM. - This should live in the core VFS. (https://lkml.org/lkml/2010/8/2/188) Hardlinks: On systems that have user-writable directories on the same partition as system files, a long-standing class of security issues is the hardlink-based time-of-check-time-of-use race, most commonly seen in world-writable directories like /tmp. The common method of exploitation of this flaw is to cross privilege boundaries when following a given hardlink (i.e. a root process follows a hardlink created by another user). Additionally, an issue exists where users can "pin" a potentially vulnerable setuid/setgid file so that an administrator will not actually upgrade a system fully. The solution is to permit hardlinks to only be created when the user is already the existing file's owner, or if they already have read/write access to the existing file. Many Linux users are surprised when they learn they can link to files they have no access to, so this change appears to follow the doctrine of "least surprise". Additionally, this change does not violate POSIX, which states "the implementation may require that the calling process has permission to access the existing file"[1]. This change is known to break some implementations of the "at" daemon, though the version used by Fedora and Ubuntu has been fixed[2] for a while. Otherwise, the change has been undisruptive while in use in Ubuntu for the last 1.5 years. [1] http://pubs.opengroup.org/onlinepubs/9699919799/functions/linkat.html [2] http://anonscm.debian.org/gitweb/?p=collab-maint/at.git;a=commitdiff;h=f4114656c3a6c6f6070e315ffdf940a49eda3279 This patch is based on the patches in Openwall and grsecurity, along with suggestions from Al Viro. I have added a sysctl to enable the protected behavior, and documentation. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-31mqueue: separate mqueue default value from maximum valueKOSAKI Motohiro
Commit b231cca4381e ("message queues: increase range limits") changed mqueue default value when attr parameter is specified NULL from hard coded value to fs.mqueue.{msg,msgsize}_max sysctl value. This made large side effect. When user need to use two mqueue applications 1) using !NULL attr parameter and it require big message size and 2) using NULL attr parameter and only need small size message, app (1) require to raise fs.mqueue.msgsize_max and app (2) consume large memory size even though it doesn't need. Doug Ledford propsed to switch back it to static hard coded value. However it also has a compatibility problem. Some applications might started depend on the default value is tunable. The solution is to separate default value from maximum value. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Doug Ledford <dledford@redhat.com> Acked-by: Doug Ledford <dledford@redhat.com> Acked-by: Joe Korty <joe.korty@ccur.com> Cc: Amerigo Wang <amwang@redhat.com> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-23Documentation: update epoll sysctl textLucian Adrian Grijincu
max_user_instances was removed in this commit: commit 9df04e1f25effde823a600e755b51475d438f56b Author: Davide Libenzi <davidel@xmailserver.org> Date: Thu Jan 29 14:25:26 2009 -0800 epoll: drop max_user_instances and rely only on max_user_watches but the documentation entry was not removed. Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Lucian Adrian Grijincu <lucian.grijincu@gmail.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-16Documentation: file handles are now freedFederica Teodori
Since file handles are freed, a little amendment to the documentation Signed-off-by: Federica Teodori <federica.teodori@googlemail.com> Acked-by: Rik van Riel<riel@redhat.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24Documentation: update stale definition of file-nr in fs.txtXiaotian Feng
In "documentation: update Documentation/filesystem/proc.txt and Documentation/sysctls" (commit 760df93ec) we merged /proc/sys/fs documentation in Documentation/sysctl/fs.txt and Documentation/filesystem/proc.txt, but stale file-nr definition remained. This patch adds back the right fs-nr definition for 2.6 kernel. Signed-off-by: Xiaotian Feng<dfeng@redhat.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02documentation: update Documentation/filesystem/proc.txt and ↵Shen Feng
Documentation/sysctls Now /proc/sys is described in many places and much information is redundant. This patch updates the proc.txt and move the /proc/sys desciption out to the files in Documentation/sysctls. Details are: merge - 2.1 /proc/sys/fs - File system data - 2.11 /proc/sys/fs/mqueue - POSIX message queues filesystem - 2.17 /proc/sys/fs/epoll - Configuration options for the epoll interface with Documentation/sysctls/fs.txt. remove - 2.2 /proc/sys/fs/binfmt_misc - Miscellaneous binary formats since it's not better then the Documentation/binfmt_misc.txt. merge - 2.3 /proc/sys/kernel - general kernel parameters with Documentation/sysctls/kernel.txt remove - 2.5 /proc/sys/dev - Device specific parameters since it's obsolete the sysfs is used now. remove - 2.6 /proc/sys/sunrpc - Remote procedure calls since it's not better then the Documentation/sysctls/sunrpc.txt move - 2.7 /proc/sys/net - Networking stuff - 2.9 Appletalk - 2.10 IPX to newly created Documentation/sysctls/net.txt. remove - 2.8 /proc/sys/net/ipv4 - IPV4 settings since it's not better then the Documentation/networking/ip-sysctl.txt. add - Chapter 3 Per-Process Parameters to descibe /proc/<pid>/xxx parameters. Signed-off-by: Shen Feng <shen@cn.fujitsu.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06get rid of NR_OPEN and introduce a sysctl_nr_openEric Dumazet
NR_OPEN (historically set to 1024*1024) actually forbids processes to open more than 1024*1024 handles. Unfortunatly some production servers hit the not so 'ridiculously high value' of 1024*1024 file descriptors per process. Changing NR_OPEN is not considered safe because of vmalloc space potential exhaust. This patch introduces a new sysctl (/proc/sys/fs/nr_open) wich defaults to 1024*1024, so that admins can decide to change this limit if their workload needs it. [akpm@linux-foundation.org: export it for sparc64] Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-30Fix typos in /Documentation : MiscMatt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some misc words. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-08-27[PATCH] Fix docs for fs.suid_dumpableAlexey Dobriyan
Sergey Vlasov noticed that there is not kernel.suid_dumpable, but fs.suid_dumpable. How KERN_SETUID_DUMPABLE ended up in fs_table[]? Hell knows... Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
