path: root/Documentation/sysctl
2009-06-16vmscan: properly account for the number of page cache pages zone_reclaim() ↵Mel Gorman
can reclaim A bug was brought to my attention against a distro kernel but it affects mainline and I believe problems like this have been reported in various guises on the mailing lists although I don't have specific examples at the moment. The reported problem was that malloc() stalled for a long time (minutes in some cases) if a large tmpfs mount was occupying a large percentage of memory overall. The pages did not get cleaned or reclaimed by zone_reclaim() because the zone_reclaim_mode was unsuitable, but the lists are uselessly scanned frequencly making the CPU spin at near 100%. This patchset intends to address that bug and bring the behaviour of zone_reclaim() more in line with expectations which were noticed during investigation. It is based on top of mmotm and takes advantage of Kosaki's work with respect to zone_reclaim(). Patch 1 fixes the heuristics that zone_reclaim() uses to determine if the scan should go ahead. The broken heuristic is what was causing the malloc() stall as it uselessly scanned the LRU constantly. Currently, zone_reclaim is assuming zone_reclaim_mode is 1 and historically it could not deal with tmpfs pages at all. This fixes up the heuristic so that an unnecessary scan is more likely to be correctly avoided. Patch 2 notes that zone_reclaim() returning a failure automatically means the zone is marked full. This is not always true. It could have failed because the GFP mask or zone_reclaim_mode were unsuitable. Patch 3 introduces a counter zreclaim_failed that will increment each time the zone_reclaim scan-avoidance heuristics fail. If that counter is rapidly increasing, then zone_reclaim_mode should be set to 0 as a temporarily resolution and a bug reported because the scan-avoidance heuristic is still broken. This patch: On NUMA machines, the administrator can configure zone_reclaim_mode that is a more targetted form of direct reclaim. On machines with large NUMA distances for example, a zone_reclaim_mode defaults to 1 meaning that clean unmapped pages will be reclaimed if the zone watermarks are not being met. There is a heuristic that determines if the scan is worthwhile but the problem is that the heuristic is not being properly applied and is basically assuming zone_reclaim_mode is 1 if it is enabled. The lack of proper detection can manfiest as high CPU usage as the LRU list is scanned uselessly. Historically, once enabled it was depending on NR_FILE_PAGES which may include swapcache pages that the reclaim_mode cannot deal with. Patch vmscan-change-the-number-of-the-unmapped-files-in-zone-reclaim.patch by Kosaki Motohiro noted that zone_page_state(zone, NR_FILE_PAGES) included pages that were not file-backed such as swapcache and made a calculation based on the inactive, active and mapped files. This is far superior when zone_reclaim==1 but if RECLAIM_SWAP is set, then NR_FILE_PAGES is a reasonable starting figure. This patch alters how zone_reclaim() works out how many pages it might be able to reclaim given the current reclaim_mode. If RECLAIM_SWAP is set in the reclaim_mode it will either consider NR_FILE_PAGES as potential candidates or else use NR_{IN}ACTIVE}_PAGES-NR_FILE_MAPPED to discount swapcache and other non-file-backed pages. If RECLAIM_WRITE is not set, then NR_FILE_DIRTY number of pages are not candidates. If RECLAIM_SWAP is not set, then NR_FILE_MAPPED are not. [kosaki.motohiro@jp.fujitsu.com: Estimate unmapped pages minus tmpfs pages] [fengguang.wu@intel.com: Fix underflow problem in Kosaki's estimate] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16page allocator: use allocation flags as an index to the zone watermarkMel Gorman
ALLOC_WMARK_MIN, ALLOC_WMARK_LOW and ALLOC_WMARK_HIGH determin whether pages_min, pages_low or pages_high is used as the zone watermark when allocating the pages. Two branches in the allocator hotpath determine which watermark to use. This patch uses the flags as an array index into a watermark array that is indexed with WMARK_* defines accessed via helpers. All call sites that use zone->pages_* are updated to use the helpers for accessing the values and the array offsets for setting. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-12trivial: Miscellaneous documentation typo fixesMatt LaPlante
Fix various typos in documentation txts. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-05-22Merge branch 'master' into nextJames Morris
Conflicts: fs/exec.c Removed IMA changes (the IMA checks are now performed via may_open()). Signed-off-by: James Morris <jmorris@namei.org>
2009-05-15Revert "mm: add /proc controls for pdflush threads"Jens Axboe
This reverts commit fafd688e4c0c34da0f3de909881117d374e4c7af. Work is progressing to switch away from pdflush as the process backing for flushing out dirty data. So it seems pointless to add more knobs to control pdflush threads. The original author of the patch did not have any specific use cases for adding the knobs, so we can easily revert this before 2.6.30 to avoid having to maintain this API forever. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-08Merge branch 'master' into nextJames Morris
2009-05-02mm: prevent divide error for small values of vm_dirty_bytesAndrea Righi
Avoid setting less than two pages for vm_dirty_bytes: this is necessary to avoid potential division by 0 (like the following) in get_dirty_limits(). [ 49.951610] divide error: 0000 [#1] PREEMPT SMP [ 49.952195] last sysfs file: /sys/devices/pci0000:00/0000:00:01.1/host0/target0:0:0/0:0:0:0/block/sda/uevent [ 49.952195] CPU 1 [ 49.952195] Modules linked in: pcspkr [ 49.952195] Pid: 3064, comm: dd Not tainted 2.6.30-rc3 #1 [ 49.952195] RIP: 0010:[<ffffffff802d39a9>] [<ffffffff802d39a9>] get_dirty_limits+0xe9/0x2c0 [ 49.952195] RSP: 0018:ffff88001de03a98 EFLAGS: 00010202 [ 49.952195] RAX: 00000000000000c0 RBX: ffff88001de03b80 RCX: 28f5c28f5c28f5c3 [ 49.952195] RDX: 0000000000000000 RSI: 00000000000000c0 RDI: 0000000000000000 [ 49.952195] RBP: ffff88001de03ae8 R08: 0000000000000000 R09: 0000000000000000 [ 49.952195] R10: ffff88001ddda9a0 R11: 0000000000000001 R12: 0000000000000001 [ 49.952195] R13: ffff88001fbc8218 R14: ffff88001de03b70 R15: ffff88001de03b78 [ 49.952195] FS: 00007fe9a435b6f0(0000) GS:ffff8800025d9000(0000) knlGS:0000000000000000 [ 49.952195] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 49.952195] CR2: 00007fe9a39ab000 CR3: 000000001de38000 CR4: 00000000000006e0 [ 49.952195] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 49.952195] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 49.952195] Process dd (pid: 3064, threadinfo ffff88001de02000, task ffff88001ddda250) [ 49.952195] Stack: [ 49.952195] ffff88001fa0de00 ffff88001f2dbd70 ffff88001f9fe800 000080b900000000 [ 49.952195] 00000000000000c0 ffff8800027a6100 0000000000000400 ffff88001fbc8218 [ 49.952195] 0000000000000000 0000000000000600 ffff88001de03bb8 ffffffff802d3ed7 [ 49.952195] Call Trace: [ 49.952195] [<ffffffff802d3ed7>] balance_dirty_pages_ratelimited_nr+0x1d7/0x3f0 [ 49.952195] [<ffffffff80368f8e>] ? ext3_writeback_write_end+0x9e/0x120 [ 49.952195] [<ffffffff802cc7df>] generic_file_buffered_write+0x12f/0x330 [ 49.952195] [<ffffffff802cce8d>] __generic_file_aio_write_nolock+0x26d/0x460 [ 49.952195] [<ffffffff802cda32>] ? generic_file_aio_write+0x52/0xd0 [ 49.952195] [<ffffffff802cda49>] generic_file_aio_write+0x69/0xd0 [ 49.952195] [<ffffffff80365fa6>] ext3_file_write+0x26/0xc0 [ 49.952195] [<ffffffff803034d1>] do_sync_write+0xf1/0x140 [ 49.952195] [<ffffffff80290d1a>] ? get_lock_stats+0x2a/0x60 [ 49.952195] [<ffffffff80280730>] ? autoremove_wake_function+0x0/0x40 [ 49.952195] [<ffffffff8030411b>] vfs_write+0xcb/0x190 [ 49.952195] [<ffffffff803042d0>] sys_write+0x50/0x90 [ 49.952195] [<ffffffff8022ff6b>] system_call_fastpath+0x16/0x1b [ 49.952195] Code: 00 00 00 2b 05 09 1c 17 01 48 89 c6 49 0f af f4 48 c1 ee 02 48 89 f0 48 f7 e1 48 89 d6 31 d2 48 c1 ee 02 48 0f af 75 d0 48 89 f0 <48> f7 f7 41 8b 95 ac 01 00 00 48 89 c7 49 0f af d4 48 c1 ea 02 [ 49.952195] RIP [<ffffffff802d39a9>] get_dirty_limits+0xe9/0x2c0 [ 49.952195] RSP <ffff88001de03a98> [ 50.096523] ---[ end trace 008d7aa02f244d7b ]--- Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: David Rientjes <rientjes@google.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13Documentation/sysctl/net.txt: fix a typoLi Zefan
s/spicified/specified Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07mm: add /proc controls for pdflush threadsPeter W Morreale
Add /proc entries to give the admin the ability to control the minimum and maximum number of pdflush threads. This allows finer control of pdflush on both large and small machines. The rationale is simply one size does not fit all. Admins on large and/or small systems may want to tune the min/max pdflush thread count to best suit their needs. Right now the min/max is hardcoded to 2/8. While probably a fair estimate for smaller machines, large machines with large numbers of CPUs and large numbers of filesystems/block devices may benefit from larger numbers of threads working on different block devices. Even if the background flushing algorithm is radically changed, it is still likely that multiple threads will be involved and admins would still desire finer control on the min/max other than to have to recompile the kernel. The patch adds '/proc/sys/vm/nr_pdflush_threads_min' and '/proc/sys/vm/nr_pdflush_threads_max' with r/w permissions. The minimum value for nr_pdflush_threads_min is 1 and the maximum value is the current value of nr_pdflush_threads_max. This minimum is required since additional thread creation is performed in a pdflush thread itself. The minimum value for nr_pdflush_threads_max is the current value of nr_pdflush_threads_min and the maximum value can be 1000. Documentation/sysctl/vm.txt is also updated. [akpm@linux-foundation.org: fix comment, fix whitespace, use __read_mostly] Signed-off-by: Peter W Morreale <pmorreale@novell.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02documentation: fix unix_dgram_qlen descriptionLi Xiaodong
Previous description about system parameter in /proc/sys/net/unix/ is wrong (or missed). Simply add a new description about unix_dgram_qlen according to latest kernel. Signed-off-by: Li Xiaodong <lixd@cn.fujitsu.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02documentation: update Documentation/filesystem/proc.txt and ↵Shen Feng
Documentation/sysctls Now /proc/sys is described in many places and much information is redundant. This patch updates the proc.txt and move the /proc/sys desciption out to the files in Documentation/sysctls. Details are: merge - 2.1 /proc/sys/fs - File system data - 2.11 /proc/sys/fs/mqueue - POSIX message queues filesystem - 2.17 /proc/sys/fs/epoll - Configuration options for the epoll interface with Documentation/sysctls/fs.txt. remove - 2.2 /proc/sys/fs/binfmt_misc - Miscellaneous binary formats since it's not better then the Documentation/binfmt_misc.txt. merge - 2.3 /proc/sys/kernel - general kernel parameters with Documentation/sysctls/kernel.txt remove - 2.5 /proc/sys/dev - Device specific parameters since it's obsolete the sysfs is used now. remove - 2.6 /proc/sys/sunrpc - Remote procedure calls since it's not better then the Documentation/sysctls/sunrpc.txt move - 2.7 /proc/sys/net - Networking stuff - 2.9 Appletalk - 2.10 IPX to newly created Documentation/sysctls/net.txt. remove - 2.8 /proc/sys/net/ipv4 - IPV4 settings since it's not better then the Documentation/networking/ip-sysctl.txt. add - Chapter 3 Per-Process Parameters to descibe /proc/<pid>/xxx parameters. Signed-off-by: Shen Feng <shen@cn.fujitsu.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-03modules: sysctl to block module loadingKees Cook
Implement a sysctl file that disables module-loading system-wide since there is no longer a viable way to remove CAP_SYS_MODULE after the system bounding capability set was removed in 2.6.25. Value can only be set to "1", and is tested only if standard capability checks allow CAP_SYS_MODULE. Given existing /dev/mem protections, this should allow administrators a one-way method to block module loading after initial boot-time module loading has finished. Signed-off-by: Kees Cook <kees.cook@canonical.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-01-15Update of Documentation: vm.txt and proc.txtPeter W Morreale
Update Documentation/sysctl/vm.txt and Documentation/filesystems/proc.txt. More specifically, the section on /proc/sys/vm in Documentation/filesystems/proc.txt was removed and a link to Documentation/sysctl/vm.txt added. Most of the verbiage from proc.txt was simply moved in vm.txt, with new addtional text for "swappiness" and "stat_interval". Signed-off-by: Peter W Morreale <pmorreale@novell.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08NOMMU: Make mmap allocation page trimming behaviour configurable.Paul Mundt
NOMMU mmap allocates a piece of memory for an mmap that's rounded up in size to the nearest power-of-2 number of pages. Currently it then discards the excess pages back to the page allocator, making that memory available for use by other things. This can, however, cause greater amount of fragmentation. To counter this, a sysctl is added in order to fine-tune the trimming behaviour. The default behaviour remains to trim pages aggressively, while this can either be disabled completely or set to a higher page-granular watermark in order to have finer-grained control. vm region vm_top bits taken from an earlier patch by David Howells. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Mike Frysinger <vapier.adi@gmail.com>
2009-01-06mm: add dirty_background_bytes and dirty_bytes sysctlsDavid Rientjes
This change introduces two new sysctls to /proc/sys/vm: dirty_background_bytes and dirty_bytes. dirty_background_bytes is the counterpart to dirty_background_ratio and dirty_bytes is the counterpart to dirty_ratio. With growing memory capacities of individual machines, it's no longer sufficient to specify dirty thresholds as a percentage of the amount of dirtyable memory over the entire system. dirty_background_bytes and dirty_bytes specify quantities of memory, in bytes, that represent the dirty limits for the entire system. If either of these values is set, its value represents the amount of dirty memory that is needed to commence either background or direct writeback. When a `bytes' or `ratio' file is written, its counterpart becomes a function of the written value. For example, if dirty_bytes is written to be 8096, 8K of memory is required to commence direct writeback. dirty_ratio is then functionally equivalent to 8K / the amount of dirtyable memory: dirtyable_memory = free pages + mapped pages + file cache dirty_background_bytes = dirty_background_ratio * dirtyable_memory -or- dirty_background_ratio = dirty_background_bytes / dirtyable_memory AND dirty_bytes = dirty_ratio * dirtyable_memory -or- dirty_ratio = dirty_bytes / dirtyable_memory Only one of dirty_background_bytes and dirty_background_ratio may be specified at a time, and only one of dirty_bytes and dirty_ratio may be specified. When one sysctl is written, the other appears as 0 when read. The `bytes' files operate on a page size granularity since dirty limits are compared with ZVC values, which are in page units. Prior to this change, the minimum dirty_ratio was 5 as implemented by get_dirty_limits() although /proc/sys/vm/dirty_ratio would show any user written value between 0 and 100. This restriction is maintained, but dirty_bytes has a lower limit of only one page. Also prior to this change, the dirty_background_ratio could not equal or exceed dirty_ratio. This restriction is maintained in addition to restricting dirty_background_bytes. If either background threshold equals or exceeds that of the dirty threshold, it is implicitly set to half the dirty threshold. Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Andrea Righi <righi.andrea@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-29Document kernel taint flags properlyGreg Kroah-Hartman
This fills in the documentation for all of the current kernel taint flags, and fixes the number for TAINT_CRAP, which was incorrectly described. Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-10Staging: add TAINT_CRAP for all drivers/staging codeGreg Kroah-Hartman
We need to add a flag for all code that is in the drivers/staging/ directory to prevent all other kernel developers from worrying about issues here, and to notify users that the drivers might not be as good as they are normally used to. Based on code from Andreas Gruenbacher and Jeff Mahoney to provide a TAINT flag for the support level of a kernel module in the Novell enterprise kernel release. This is the kernel portion of this feature, the ability for the flag to be set needs to be done in the build process and will happen in a follow-up patch. Cc: Andreas Gruenbacher <agruen@suse.de> Cc: Jeff Mahoney <jeffm@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23Documentation/sysctl/kernel.txt: fix softlockup_thresh descriptionAndrew Morton
- s/s/seconds/ - s/10 seconds/60 seconds/ - Mention the zero-disables-it feature. Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26Documentation cleanup: trivial misspelling, punctuation, and grammar ↵Matt LaPlante
corrections. Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13Documentation: sysctl/kernel.txt: fix documentation referenceMichael Opdenacker
This patch fixes a reference to Documentation/kmod.txt which was apparently renamed to Documentation/debugging-modules.txt Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-09brk: document randomize_va_space and CONFIG_COMPAT_BRK (was Re:Jiri Kosina
Document randomize_va_space and CONFIG_COMPAT_BRK. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-07oom: add sysctl to enable task memory dumpDavid Rientjes
Adds a new sysctl, 'oom_dump_tasks', that enables the kernel to produce a dump of all system tasks (excluding kernel threads) when performing an OOM-killing. Information includes pid, uid, tgid, vm size, rss, cpu, oom_adj score, and name. This is helpful for determining why there was an OOM condition and which rogue task caused it. It is configurable so that large systems, such as those with several thousand tasks, do not incur a performance penalty associated with dumping data they may not desire. If an OOM was triggered as a result of a memory controller, the tasklist shall be filtered to exclude tasks that are not a member of the same cgroup. Cc: Andrea Arcangeli <andrea@suse.de> Cc: Christoph Lameter <clameter@sgi.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06get rid of NR_OPEN and introduce a sysctl_nr_openEric Dumazet
NR_OPEN (historically set to 1024*1024) actually forbids processes to open more than 1024*1024 handles. Unfortunatly some production servers hit the not so 'ridiculously high value' of 1024*1024 file descriptors per process. Changing NR_OPEN is not considered safe because of vmalloc space potential exhaust. This patch introduces a new sysctl (/proc/sys/fs/nr_open) wich defaults to 1024*1024, so that admins can decide to change this limit if their workload needs it. [akpm@linux-foundation.org: export it for sparc64] Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05mm/page-writeback: highmem_is_dirtyable optionBron Gondwana
Add vm.highmem_is_dirtyable toggle A 32 bit machine with HIGHMEM64 enabled running DCC has an MMAPed file of approximately 2Gb size which contains a hash format that is written randomly by the dbclean process. On 2.6.16 this process took a few minutes. With lowmem only accounting of dirty ratios, this takes about 12 hours of 100% disk IO, all random writes. Include a toggle in /proc/sys/vm/highmem_is_dirtyable which can be set to 1 to add the highmem back to the total available memory count. [akpm@linux-foundation.org: Fix the CONFIG_DETECT_SOFTLOCKUP=y build] Signed-off-by: Bron Gondwana <brong@fastmail.fm> Cc: Ethan Solomita <solo@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: WU Fengguang <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-17Documentation: update hugetlb informationNishanth Aravamudan
The hugetlb documentation has gotten a bit out of sync with the current code. Updated the sysctl file to refer to Documentation/vm/hugetlbpage.txt. Update that file to contain the current state of affairs (with the newer named sysctl in place). Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Acked-by: Adam Litke <agl@us.ibm.com> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17vm.txt: document min_free_pages as critical for correctnessPavel Machek
min_free_pages is critical for correctness, document it as such. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Add a 00-INDEX file to Documentation/sysctl/Jesper Juhl
Add a 00-INDEX file to Documentation/sysctl/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: Rob Landley <rob@landley.net> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17softlockup: add a /proc tuning parameterRavikiran G Thirumalai
Control the trigger limit for softlockup warnings. This is useful for debugging softlockups, by lowering the softlockup_thresh to identify possible softlockups earlier. This patch: 1. Adds a sysctl softlockup_thresh with valid values of 1-60s (Higher value to disable false positives) 2. Changes the softlockup printk to print the cpu softlockup time [akpm@linux-foundation.org: Fix various warnings and add definition of "two"] Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Shai Fultheim <shai@scalex86.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17oom: add oom_kill_allocating_task sysctlDavid Rientjes
Adds a new sysctl, 'oom_kill_allocating_task', which will automatically kill the OOM-triggering task instead of scanning through the tasklist to find a memory-hogging target. This is helpful for systems with an insanely large number of tasks where scanning the tasklist significantly degrades performance. Cc: Andrea Arcangeli <andrea@suse.de> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17handle kernelcore=: genericMel Gorman
This patch adds the kernelcore= parameter for x86. Once all patches are applied, a new command-line parameter exist and a new sysctl. This patch adds the necessary documentation. From: Yasunori Goto <y-goto@jp.fujitsu.com> When "kernelcore" boot option is specified, kernel can't boot up on ia64 because of an infinite loop. In addition, the parsing code can be handled in an architecture-independent manner. This patch uses common code to handle the kernelcore= parameter. It is only available to architectures that support arch-independent zone-sizing (i.e. define CONFIG_ARCH_POPULATES_NODE_MAP). Other architectures will ignore the boot parameter. [bunk@stusta.de: make cmdline_parse_kernelcore() static] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Acked-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Add Documentation/sysctl/ctl_unnumbered.txtAndrew Morton
Poeple keep on adding new numbered sysctls, when they're supposed not to. Add a documentation file which explain why new sysctls should use CTL_UNNUMBERED. The next patch will sprinkle pointers to this throughout sysctl.c. Eric provided the text (thanks) Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16change zonelist order: zonelist order selection logicKAMEZAWA Hiroyuki
Make zonelist creation policy selectable from sysctl/boot option v6. This patch makes NUMA's zonelist (of pgdat) order selectable. Available order are Default(automatic)/ Node-based / Zone-based. [Default Order] The kernel selects Node-based or Zone-based order automatically. [Node-based Order] This policy treats the locality of memory as the most important parameter. Zonelist order is created by each zone's locality. This means lower zones (ex. ZONE_DMA) can be used before higher zone (ex. ZONE_NORMAL) exhausion. IOW. ZONE_DMA will be in the middle of zonelist. current 2.6.21 kernel uses this. Pros. * A user can expect local memory as much as possible. Cons. * lower zone will be exhansted before higher zone. This may cause OOM_KILL. Maybe suitable if ZONE_DMA is relatively big and you never see OOM_KILL because of ZONE_DMA exhaution and you need the best locality. (example) assume 2 node NUMA. node(0) has ZONE_DMA/ZONE_NORMAL, node(1) has ZONE_NORMAL. *node(0)'s memory allocation order: node(0)'s NORMAL -> node(0)'s DMA -> node(1)'s NORMAL. *node(1)'s memory allocation order: node(1)'s NORMAL -> node(0)'s NORMAL -> node(0)'s DMA. [Zone-based order] This policy treats the zone type as the most important parameter. Zonelist order is created by zone-type order. This means lower zone never be used bofere higher zone exhaustion. IOW. ZONE_DMA will be always at the tail of zonelist. Pros. * OOM_KILL(bacause of lower zone) occurs only if the whole zones are exhausted. Cons. * memory locality may not be best. (example) assume 2 node NUMA. node(0) has ZONE_DMA/ZONE_NORMAL, node(1) has ZONE_NORMAL. *node(0)'s memory allocation order: node(0)'s NORMAL -> node(1)'s NORMAL -> node(0)'s DMA. *node(1)'s memory allocation order: node(1)'s NORMAL -> node(0)'s NORMAL -> node(0)'s DMA. bootoption "numa_zonelist_order=" and proc/sysctl is supporetd. command: %echo N > /proc/sys/vm/numa_zonelist_order Will rebuild zonelist in Node-based order. command: %echo Z > /proc/sys/vm/numa_zonelist_order Will rebuild zonelist in Zone-based order. Thanks to Lee Schermerhorn, he gives me much help and codes. [Lee.Schermerhorn@hp.com: add check_highest_zone to build_zonelists_in_zone_order] [akpm@linux-foundation.org: build fix] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: "jesse.barnes@intel.com" <jesse.barnes@intel.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-11security: Protection for exploiting null dereference using mmapEric Paris
Add a new security check on mmap operations to see if the user is attempting to mmap to low area of the address space. The amount of space protected is indicated by the new proc tunable /proc/sys/vm/mmap_min_addr and defaults to 0, preserving existing behavior. This patch uses a new SELinux security class "memprotect." Policy already contains a number of allow rules like a_t self:process * (unconfined_t being one of them) which mean that putting this check in the process class (its best current fit) would make it useless as all user processes, which we also want to protect against, would be allowed. By taking the memprotect name of the new class it will also make it possible for us to move some of the other memory protect permissions out of 'process' and into the new class next time we bump the policy version number (which I also think is a good future idea) Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2007-05-09misc doc and kconfig typosMatt LaPlante
Fix various typos in kernel docs and Kconfigs, 2.6.21-rc4. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09Fix misspellings collected by members of KJ list.Robert P. J. Day
Fix the misspellings of "propogate", "writting" and (oh, the shame :-) "kenrel" in the source tree. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-07mm: fix handling of panic_on_oom when cpusets are in useYasunori Goto
The current panic_on_oom may not work if there is a process using cpusets/mempolicy, because other nodes' memory may remain. But some people want failover by panic ASAP even if they are used. This patch makes new setting for its request. This is tested on my ia64 box which has 3 nodes. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Cc: Christoph Lameter <clameter@sgi.com> Cc: Paul Jackson <pj@sgi.com> Cc: Ethan Solomita <solo@google.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] x86: add sysctl for kstack_depth_to_printChuck Ebbert
Add sysctl for kstack_depth_to_print. This lets users change the amount of raw stack data printed in dump_stack() without having to reboot. Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-11-30Fix typos in /Documentation : MiscMatt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some misc words. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-11[PATCH] document the core-dump-to-a-pipe patchMatthias Urlichs
The pipe-a-coredump-to-a-program feature was undocumented. *Grumble*. NB: a good enhancement to that patch would be: save all the stuff that a core file can get from the %x expansions in the environment. Signed-off-by: Matthias Urlichs <matthias@urlichs.de> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] zone_reclaim: dynamic slab reclaimChristoph Lameter
Currently one can enable slab reclaim by setting an explicit option in /proc/sys/vm/zone_reclaim_mode. Slab reclaim is then used as a final option if the freeing of unmapped file backed pages is not enough to free enough pages to allow a local allocation. However, that means that the slab can grow excessively and that most memory of a node may be used by slabs. We have had a case where a machine with 46GB of memory was using 40-42GB for slab. Zone reclaim was effective in dealing with pagecache pages. However, slab reclaim was only done during global reclaim (which is a bit rare on NUMA systems). This patch implements slab reclaim during zone reclaim. Zone reclaim occurs if there is a danger of an off node allocation. At that point we 1. Shrink the per node page cache if the number of pagecache pages is more than min_unmapped_ratio percent of pages in a zone. 2. Shrink the slab cache if the number of the nodes reclaimable slab pages (patch depends on earlier one that implements that counter) are more than min_slab_ratio (a new /proc/sys/vm tunable). The shrinking of the slab cache is a bit problematic since it is not node specific. So we simply calculate what point in the slab we want to reach (current per node slab use minus the number of pages that neeed to be allocated) and then repeately run the global reclaim until that is unsuccessful or we have reached the limit. I hope we will have zone based slab reclaim at some point which will make that easier. The default for the min_slab_ratio is 5% Also remove the slab option from /proc/sys/vm/zone_reclaim_mode. [akpm@osdl.org: cleanups] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-27[PATCH] Fix docs for fs.suid_dumpableAlexey Dobriyan
Sergey Vlasov noticed that there is not kernel.suid_dumpable, but fs.suid_dumpable. How KERN_SETUID_DUMPABLE ended up in fs_table[]? Hell knows... Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] doc: update panic_on_oops documentationMaxime Bizon
Signed-off-by: Maxime Bizon <mbizon@freebox.fr> Acked-by: Simon Horman <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] ZVC/zone_reclaim: Leave 1% of unmapped pagecache pages for file I/OChristoph Lameter
It turns out that it is advantageous to leave a small portion of unmapped file backed pages if all of a zone's pages (or almost all pages) are allocated and so the page allocator has to go off-node. This allows recently used file I/O buffers to stay on the node and reduces the times that zone reclaim is invoked if file I/O occurs when we run out of memory in a zone. The problem is that zone reclaim runs too frequently when the page cache is used for file I/O (read write and therefore unmapped pages!) alone and we have almost all pages of the zone allocated. Zone reclaim may remove 32 unmapped pages. File I/O will use these pages for the next read/write requests and the unmapped pages increase. After the zone has filled up again zone reclaim will remove it again after only 32 pages. This cycle is too inefficient and there are potentially too many zone reclaim cycles. With the 1% boundary we may still remove all unmapped pages for file I/O in zone reclaim pass. However. it will take a large number of read and writes to get back to 1% again where we trigger zone reclaim again. The zone reclaim 2.6.16/17 does not show this behavior because we have a 30 second timeout. [akpm@osdl.org: rename the /proc file and the variable] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] zoned vm counters: zone_reclaim: remove ↵Christoph Lameter
/proc/sys/vm/zone_reclaim_interval The zone_reclaim_interval was necessary because we were not able to determine how many unmapped pages exist in a zone. Therefore we had to scan in intervals to figure out if any pages were unmapped. With the zoned counters and NR_ANON_PAGES we now know the number of pagecache pages and the number of mapped pages in a zone. So we can simply skip the reclaim if there is an insufficient number of unmapped pages. We use SWAP_CLUSTER_MAX as the boundary. Drop all support for /proc/sys/vm/zone_reclaim_interval. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] support for panic at OOMKAMEZAWA Hiroyuki
This patch adds panic_on_oom sysctl under sys.vm. When sysctl vm.panic_on_oom = 1, the kernel panics intead of killing rogue processes. And if vm.panic_on_oom is 0 the kernel will do oom_kill() in the same way as it does today. Of course, the default value is 0 and only root can modifies it. In general, oom_killer works well and kill rogue processes. So the whole system can survive. But there are environments where panic is preferable rather than kill some processes. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-20[PATCH] suspend-to-ram: allow video options to be set at runtimePavel Machek
Currently, acpi video options can only be set on kernel command line. That's little inflexible; I'd like userland s2ram application that just works, and modifying kernel command line according to whitelist is not fun. It is better to just allow s2ram application to set video options just before suspend (according to the whitelist). This implements sysctl to allow setting suspend video options without reboot. (akpm: Documentation updates for this new sysctl are pending..) Signed-off-by: Pavel Machek <pavel@suse.cz> Cc: "Brown, Len" <len.brown@intel.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] Reclaim slab during zone reclaimChristoph Lameter
If large amounts of zone memory are used by empty slabs then zone_reclaim becomes uneffective. This patch shakes the slab a bit. The problem with this patch is that the slab reclaim is not containable to a zone. Thus slab reclaim may affect the whole system and be extremely slow. This also means that we cannot determine how many pages were freed in this zone. Thus we need to go off node for at least one allocation. The functionality is disabled by default. We could modify the shrinkers to take a zone parameter but that would be quite invasive. Better ideas are welcome. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] Zone reclaim: Allow modification of zone reclaim behaviorChristoph Lameter
In some situations one may want zone_reclaim to behave differently. For example a process writing large amounts of memory will spew unto other nodes to cache the writes if many pages in a zone become dirty. This may impact the performance of processes running on other nodes. Allowing writes during reclaim puts a stop to that behavior and throttles the process by restricting the pages to the local zone. Similarly one may want to contain processes to local memory by enabling regular swap behavior during zone_reclaim. Off node memory allocation can then be controlled through memory policies and cpusets. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] zone_reclaim: configurable off node allocation period.Christoph Lameter
Currently the zone_reclaim code has a fixed window of 30 seconds of off node allocations should a local zone have no unused pagecache pages left. Reclaim will be attempted again after this timeout period to avoid repeated useless scans for memory. This is also useful to established sufficiently large off node allocation chunks to relieve the local node. It may be beneficial to adjust that time period for some special situations. For example if memory use was exceeding node capacity one may want to give up for longer periods of time. If memory spikes intermittendly then one may want to shorten the time period to reduce the number of off node allocations. This patch allows just that.... Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] Zone reclaim: proc overrideChristoph Lameter
proc support for zone reclaim This patch creates a proc entry /proc/sys/vm/zone_reclaim_mode that may be used to override the automatic determination of the zone reclaim made on bootup. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
