Change-Id: Ib3b69ffc5ac3e07c9cc44cc49e9142088eec477e
Update Documentation/sysrq.txt magic sysrq keys:
- 'g' is for kgdb (not arch-specific);
- add 2 new uses for 'v', remove the Voyager info;
- add 'y' info (SPARC-64 specific);
Cc: Jason Wessel <jason.wessel@windriver.com>
Cc: "James E.J. Bottomley" <James.Bottomley@suse.de>
Cc: David Airlie <airlied@linux.ie>
Acked-by: Alexander Shishkin <virtuoso@slind.org>
While setting up sysrq operation on the XO laptop (which lacks a SysRq
key), i realized that the documentation was quite out of date.
Change documentation of SysRq to reflect current KEY_SYSRQ value.
Signed-off-by: Paul Fox <pgf@laptop.org>
commit d6580a9f15238b87e618310c862231ae3f352d2d ("kexec: sysrq: simplify
sysrq-c handler") changed the behavior of sysrq-c to unconditional
dereference of NULL pointer. So in cases with CONFIG_KEXEC, where
crash_kexec() was directly called from sysrq-c before, now it can be said
that a step of "real oops" was inserted before starting kdump.
However, in contrast to oops via SysRq-c from keyboard which results in
panic due to in_interrupt(), oops via "echo c > /proc/sysrq-trigger" will
not become panic unless panic_on_oops=1. It means that even if dump is
properly configured to be taken on panic, the sysrq-c from proc interface
might not start crashdump while the sysrq-c from keyboard can start
crashdump. This confuses traditional users of kdump, i.e. people who
expect sysrq-c to do common behavior in both of the keyboard and proc
interface.
This patch brings the keyboard and proc interface behavior of sysrq-c in
line, by forcing panic_on_oops=1 before oops in sysrq-c handler.
And some updates in documentation are included, to clarify that there is
no longer dependency with CONFIG_KEXEC, and that now the system can just
crash by sysrq-c if no dump mechanism is configured.
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Ken'ichi Ohmichi <oomichi@mxs.nes.nec.co.jp>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Cc: Brayan Arraes <brayan@yack.com.br>
Cc: Eric W. Biederman <ebiederm@xmission.com>
include/linux/slub_def.h
lib/Kconfig.debug
mm/slob.c
mm/slub.c
Now that the filesystem freeze operation has been elevated to the VFS, and
is just an ioctl away, some sort of safety net for unintentionally frozen
root filesystems may be in order.
The timeout thaw originally proposed did not get merged, but perhaps
something like this would be useful in emergencies.
For example, freeze /path/to/mountpoint may freeze your root filesystem if
you forgot that you had that unmounted.
I chose 'j' as the last remaining character other than 'h' which is sort
of reserved for help (because help is generated on any unknown character).
I've tested this on a non-root fs with multiple (nested) freezers, as well
as on a system rendered unresponsive due to a frozen root fs.
[randy.dunlap@oracle.com: emergency thaw only if CONFIG_BLOCK enabled]
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Cc: Takashi Sato <t-sato@yk.jp.nec.com>
Document the interactions between loglevel and the sysrq output. Also
document how to work round it should output be required on the console.
Signed-off-by: Andy Whitcroft <apw@canonical.com>
Cc: Martin Mares <mj@ucw.cz>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
git is maintaining the last update time much more accuratly than the
internal update time. Remove it.
Impact: update documentation and help messages
We have a conventional method of explicitly stating the
sysrq action key in a sysrq help message, so change
dump-ftrace-buffer to use that method and add it to
Documentation/sysrq.txt.
* 'v28-timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (36 commits)
fix documentation of sysrq-q really
Fix documentation of sysrq-q
timer_list: add base address to clock base
timer_list: print cpu number of clockevents device
timer_list: print real timer address
NOHZ: restart tick device from irq_enter()
NOHZ: split tick_nohz_restart_sched_tick()
NOHZ: unify the nohz function calls in irq_enter()
timers: fix itimer/many thread hang, fix
timers: fix itimer/many thread hang, v3
ntp: improve adjtimex frequency rounding
timekeeping: fix rounding problem during clock update
ntp: let update_persistent_clock() sleep
hrtimer: reorder struct hrtimer to save 8 bytes on 64bit builds
posix-timers: lock_timer: make it readable
posix-timers: lock_timer: kill the bogus ->it_id check
posix-timers: kill ->it_sigev_signo and ->it_sigev_value
posix-timers: sys_timer_create: cleanup the error handling
posix-timers: move the initialization of timer->sigq from send to create path
posix-timers: sys_timer_create: simplify and s/tasklist/rcu/
Fix trivial conflicts due to sysrq-q description clahes in
Documentation/sysrq.txt and drivers/char/sysrq.c
I fell into the trap recently that it only dumps hrtimers instead of
all timers. Fix the documentation.
SysRq-Q also dumps information about the clockevent devices.
Cc: torvalds@linux-foundation.org
SysRQ-P is not always useful on SMP systems, since it usually ends up showing
the backtrace of a CPU that is doing just fine, instead of the backtrace of
the CPU that is having problems.
This patch adds SysRQ show-all-cpus(L), which shows the backtrace of every
active CPU in the system. It skips idle CPUs because some SMP systems are
just too large and we already know what the backtrace of the idle task looks
like.
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: <lwoodman@redhat.com>
Document sequence of keypresses that actually works. Yes, this changed
year-or-so ago.
Signed-off-by: Pavel Machek <pavel@suse.cz>
In Documentation/sysrq.txt, the description of 'h' says that any key not
listed *above* will generate help. That's obviously not true since all the
keys listed below 'h' will do what they are described to do, not display help.
So change the text so that it says that any key not listed in the table will
generate help, which is what really happens.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
sh uses the same sysrq trigger as ppc, update the documentation to
reflect that.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
I added the 'Q' to list. A short description in the `Ok, so what can I
use them for'-section, on when or why to use it would be nice!
Signed-off-by: Johannes Weiner <hannes-kernel@saeurebad.de>
Alphabetize the sysrq command keys list.
Change SysRq showBlockedTasks from sysrq-X to sysrq-W and show that in the
Help message.
It was previously done via X, but X is already used for Xmon on ppc & powerpc
platforms and this collision needs to be avoided.
All callers of register_sysrq_key() are now marked in the sysrq op/key table.
I didn't mark 'h' as Help because Help is just printed for any unknown key,
such as '?'.
Added some omitted sysrq key entries in the sysrq.txt file.
sysrq SAK is described as being something you should mistake for SAK from
c2 compliant systems - whoops. What's meant is that it should *not* be
mistaken as such.
This patch for 2.4.x updates the dead email address for 'Mydraal'
and since he no longer wishes to field questions concerning
SysRq or this document removes the statement stating otherwise.
This patch contains the most trivial from Rusty's trivial patches:
- spelling fixes
- remove duplicate includes
Add a sysrq-trigger mechanism for kexec based crashdumps. Alt-Sysrq-c
triggers a kexec based crashdump.
Signed-off-by: Hariprasad Nellitheertha <hari@in.ibm.com>
infrastructure for it.
Let it rip!
