path: root/Documentation/telephony
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-07-22remove mention of CONFIG_KMOD from documentationJohannes Berg
Also includes a few Kconfig files (xtensa, blackfin) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: linux-doc@vger.kernel.org Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Randy Dunlap <rdunlap@xenotime.net>
2007-10-17Add a 00-INDEX file to Documentation/telephony/Jesper Juhl
Add a 00-INDEX file to Documentation/telephony/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Rob Landley <rob@landley.net> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
