path: root/Documentation/thermal/exynos_thermal_emulation
2013-05-28doc: fix misspellings with 'codespell' toolAnatol Pomozov
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-04-02thermal: exynos: Adapt to temperature emulation core thermal frameworkAmit Daniel Kachhap
This removes the driver specific sysfs support of the temperature emulation and uses the newly added core thermal framework for thermal emulation. An exynos platform specific handler is added to support this. In this patch, the exynos senor(tmu) related code and exynos framework related (thermal zone, cooling devices) code are intentionally kept separate. So an emulated function pointer is passed from sensor to framework. This is beneficial in adding more sensor support using the same framework code which is an ongoing work. The goal is to finally split them totally. Even the existing read_temperature also follows the same execution method. Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Amit Daniel Kachhap <amit.daniel@samsung.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2013-01-04Thermal: exynos: Add sysfs node supporting exynos's emulation mode.Jonghwa Lee
This patch supports exynos's emulation mode with newly created sysfs node. Exynos 4x12 (4212, 4412) and 5 series provide emulation mode for thermal management unit. Thermal emulation mode supports software debug for TMU's operation. User can set temperature manually with software code and TMU will read current temperature from user value not from sensor's value. This patch includes also documentary placed under Documentation/thermal/. Signed-off-by: Jonghwa Lee <jonghwa3.lee@samsung.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
