Now, "snapshot" file returns success on a reset of snapshot buffer
even if the buffer wasn't allocated, instead of returning EINVAL.
This patch updates snapshot desctiption according to the change.
Link: http://lkml.kernel.org/r/51399409.4090207@hitachi.com
Signed-off-by: Hiraku Toyooka <hiraku.toyooka.gu@hitachi.com>
Pull ACPI and power management updates from Rafael Wysocki:
- Rework of the ACPI namespace scanning code from Rafael J. Wysocki
with contributions from Bjorn Helgaas, Jiang Liu, Mika Westerberg,
Toshi Kani, and Yinghai Lu.
- ACPI power resources handling and ACPI device PM update from Rafael
J Wysocki.
- ACPICA update to version 20130117 from Bob Moore and Lv Zheng with
contributions from Aaron Lu, Chao Guan, Jesper Juhl, and Tim Gardner.
- Support for Intel Lynxpoint LPSS from Mika Westerberg.
- cpuidle update from Len Brown including Intel Haswell support, C1
state for intel_idle, removal of global pm_idle.
- cpuidle fixes and cleanups from Daniel Lezcano.
- cpufreq fixes and cleanups from Viresh Kumar and Fabio Baltieri with
contributions from Stratos Karafotis and Rickard Andersson.
- Intel P-states driver for Sandy Bridge processors from Dirk
Brandewie.
- cpufreq driver for Marvell Kirkwood SoCs from Andrew Lunn.
- cpufreq fixes related to ordering issues between acpi-cpufreq and
powernow-k8 from Borislav Petkov and Matthew Garrett.
- cpufreq support for Calxeda Highbank processors from Mark Langsdorf
and Rob Herring.
- cpufreq driver for the Freescale i.MX6Q SoC and cpufreq-cpu0 update
from Shawn Guo.
- cpufreq Exynos fixes and cleanups from Jonghwan Choi, Sachin Kamat,
and Inderpal Singh.
- Support for "lightweight suspend" from Zhang Rui.
- Removal of the deprecated power trace API from Paul Gortmaker.
- Assorted updates from Andreas Fleig, Colin Ian King, Davidlohr Bueso,
Joseph Salisbury, Kees Cook, Li Fei, Nishanth Menon, ShuoX Liu,
Srinivas Pandruvada, Tejun Heo, Thomas Renninger, and Yasuaki
Ishimatsu.
* tag 'pm+acpi-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (267 commits)
PM idle: remove global declaration of pm_idle
unicore32 idle: delete stray pm_idle comment
openrisc idle: delete pm_idle
mn10300 idle: delete pm_idle
microblaze idle: delete pm_idle
m32r idle: delete pm_idle, and other dead idle code
ia64 idle: delete pm_idle
cris idle: delete idle and pm_idle
ARM64 idle: delete pm_idle
ARM idle: delete pm_idle
blackfin idle: delete pm_idle
sparc idle: rename pm_idle to sparc_idle
sh idle: rename global pm_idle to static sh_idle
x86 idle: rename global pm_idle to static x86_idle
APM idle: register apm_cpu_idle via cpuidle
cpufreq / intel_pstate: Add kernel command line option disable intel_pstate.
cpufreq / intel_pstate: Change to disallow module build
tools/power turbostat: display SMI count by default
intel_idle: export both C1 and C1E
ACPI / hotplug: Fix concurrency issues and memory leaks
This patch adds snapshot description in ftrace documentation.
This description includes what the snapshot is and how to use it.
Link: http://lkml.kernel.org/r/20121226025309.3252.150.stgit@liselsia
Cc: Rob Landley <rob@landley.net>
The text in Documentation said it would be removed in 2.6.41;
the text in the Kconfig said removal in the 3.1 release. Either
way you look at it, we are well past both, so push it off a cliff.
Note that the POWER_CSTATE and the POWER_PSTATE are part of the
legacy tracing API. Remove all tracepoints which use these flags.
As can be seen from context, most already have a trace entry via
trace_cpu_idle anyways.
Also, the cpufreq/cpufreq.c PSTATE one is actually unpaired, as
compared to the CSTATE ones which all have a clear start/stop.
As part of this, the trace_power_frequency also becomes orphaned,
so it too is deleted.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
KPROBE_TRACING has been replaced by KPROBE_EVENT.
Signed-off-by: Liu Bo <liub.liubo@gmail.com>
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Commit f3f096cfe ("tracing: Provide trace events interface for
uprobes") throws a warning about unmet dependencies.
The exact warning message is:
warning: (UPROBE_EVENT) selects UPROBES which has unmet direct dependencies (UPROBE_EVENTS && PERF_EVENTS)
This is due to a typo in arch/Kconfig file. Fix similar typos in
the uprobetracer documentation.
Also add sample format of a uprobe event in the uprobetracer
documentation as suggested by Masami Hiramatsu.
Reported-by: Stephen Boyd <sboyd@codeaurora.org>
Reported-by: Ingo Molnar <mingo@kernel.org>
Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Anton Arapov <anton@redhat.com>
Link: http://lkml.kernel.org/r/20120508111126.21004.38285.sendpatchset@srdronam.in.ibm.com
Implements trace_event support for uprobes. In its current form
it can be used to put probes at a specified offset in a file and
dump the required registers when the code flow reaches the
probed address.
The following example shows how to dump the instruction pointer
and %ax a register at the probed text address. Here we are
trying to probe zfree in /bin/zsh:
# cd /sys/kernel/debug/tracing/
# cat /proc/`pgrep zsh`/maps | grep /bin/zsh | grep r-xp
00400000-0048a000 r-xp 00000000 08:03 130904 /bin/zsh
# objdump -T /bin/zsh | grep -w zfree
0000000000446420 g DF .text 0000000000000012 Base
zfree # echo 'p /bin/zsh:0x46420 %ip %ax' > uprobe_events
# cat uprobe_events
p:uprobes/p_zsh_0x46420 /bin/zsh:0x0000000000046420
# echo 1 > events/uprobes/enable
# sleep 20
# echo 0 > events/uprobes/enable
# cat trace
# tracer: nop
# TASK-PID CPU# TIMESTAMP FUNCTION
zsh-24842 [006] 258544.995456: p_zsh_0x46420: (0x446420) arg1=446421 arg2=79
zsh-24842 [007] 258545.000270: p_zsh_0x46420: (0x446420) arg1=446421 arg2=79
zsh-24842 [002] 258545.043929: p_zsh_0x46420: (0x446420) arg1=446421 arg2=79
zsh-24842 [004] 258547.046129: p_zsh_0x46420: (0x446420) arg1=446421 arg2=79
Cc: Jim Keniston <jkenisto@linux.vnet.ibm.com>
Cc: Linux-mm <linux-mm@kvack.org>
Link: http://lkml.kernel.org/r/20120411103043.GB29437@linux.vnet.ibm.com
Pull trivial tree from Jiri Kosina:
"It's indeed trivial -- mostly documentation updates and a bunch of
typo fixes from Masanari.
There are also several linux/version.h include removals from Jesper."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (101 commits)
kcore: fix spelling in read_kcore() comment
constify struct pci_dev * in obvious cases
Revert "char: Fix typo in viotape.c"
init: fix wording error in mm_init comment
usb: gadget: Kconfig: fix typo for 'different'
Revert "power, max8998: Include linux/module.h just once in drivers/power/max8998_charger.c"
writeback: fix fn name in writeback_inodes_sb_nr_if_idle() comment header
writeback: fix typo in the writeback_control comment
Documentation: Fix multiple typo in Documentation
tpm_tis: fix tis_lock with respect to RCU
Revert "media: Fix typo in mixer_drv.c and hdmi_drv.c"
Doc: Update numastat.txt
qla4xxx: Add missing spaces to error messages
compiler.h: Fix typo
security: struct security_operations kerneldoc fix
Documentation: broken URL in libata.tmpl
Documentation: broken URL in filesystems.tmpl
mtd: simplify return logic in do_map_probe()
mm: fix comment typo of truncate_inode_pages_range
power: bq27x00: Fix typos in comment
Correct spelling "Fequency" to "Frequency" in
Documentation/trace/events-power.txt
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Append and update the description about wakeup/wakeup_rt usage.
Link: http://lkml.kernel.org/r/1328695537-15081-2-git-send-email-geunsik.lim@gmail.com
Cc: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: Geunsik Lim <geunsik.lim@samsung.com>
We renamed the page-free mm tracepoints.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Rename mm_page_free_direct into mm_page_free and mm_pagevec_free into
mm_page_free_batched
Since v2.6.33-5426-gc475dab the kernel triggers mm_page_free_direct for
all freed pages, not only for directly freed. So, let's name it properly.
For pages freed via page-list we also trigger mm_page_free_batched event.
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into perf/core
Preds is no longer stored in a fixed-size stack. The max preds now
is 2^14, and is way more than enough, so don't bother to document it.
Link: http://lkml.kernel.org/r/4EAA5E54.1080102@cn.fujitsu.com
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Change ISOLATE_XXX macro with bitwise isolate_mode_t type. Normally,
macro isn't recommended as it's type-unsafe and making debugging harder as
symbol cannot be passed throught to the debugger.
Quote from Johannes
" Hmm, it would probably be cleaner to fully convert the isolation mode
into independent flags. INACTIVE, ACTIVE, BOTH is currently a
tri-state among flags, which is a bit ugly."
This patch moves isolate mode from swap.h to mmzone.h by memcontrol.h
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
To support probing module init functions, kprobe-tracer allows
user to define a probe on non-existed function when it is given
with a module name. This also enables user to set a probe on
a function on a specific module, even if a same name (but different)
function is locally defined in another module.
The module name must be in the front of function name and separated
by a ':'. e.g. btrfs:btrfs_init_sysfs
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Link: http://lkml.kernel.org/r/20110627072656.6528.89970.stgit@fedora15
Neil Brown pointed out that lock_depth somehow escaped the BKL
removal work. Let's get rid of it now.
Note that the perf scripting utilities still have a bunch of
code for dealing with common_lock_depth in tracepoints; I have
left that in place in case anybody wants to use that code with
older kernels.
Suggested-by: Neil Brown <neilb@suse.de>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Link: http://lkml.kernel.org/r/20110422111910.456c0e84@bike.lwn.net
Add an "overwrite" trace_option for ftrace to control whether the buffer should
be overwritten on overflow or not. The default remains to overwrite old events
when the buffer is full. This patch adds the option to instead discard newest
events when the buffer is full. This is useful to get a snapshot of traces just
after enabling traces. Dropping the current event is also a simpler code path.
Signed-off-by: David Sharp <dhsharp@google.com>
LKML-Reference: <1291844807-15481-1-git-send-email-dhsharp@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/core
tracing_enabled should not be used, it is heavy weight and does not
do much in helping lower the overhead.
tracing_on should be used instead. Warn users to use tracing_on
when tracing_enabled is used as it will soon be removed from the
tracing directory.
The trace events sched_switch and sched_wakeup do the same thing
as the stand alone sched_switch tracer does. It is no longer needed.
Some architectures have unusual symbol names and the generic code to
match the symbol name with the function name for the syscall metadata
will fail. For example, symbols on PPC64 start with a period and the
generic code will fail to match them.
This patch moves the match logic out into a separate function which an
arch can override by defining ARCH_HAS_SYSCALL_MATCH_SYM_NAME in
asm/ftrace.h and implementing arch_syscall_match_sym_name.
Signed-off-by: Ian Munsie <imunsie@au1.ibm.com>
LKML-Reference: <1296703645-18718-5-git-send-email-imunsie@au1.ibm.com>
Some architectures use non-trivial system call tables and will not work
with the generic arch_syscall_addr code. For example, PowerPC64 uses a
table of twin long longs.
This patch makes the generic arch_syscall_addr weak to allow
architectures with non-trivial system call tables to override it.
LKML-Reference: <1296703645-18718-4-git-send-email-imunsie@au1.ibm.com>
Add bitfield type for tracing arguments on kprobe-tracer. The syntax of
a bitfield type is:
b<bit-size>@<bit-offset>/<container-size>
e.g.
Accessing 2 bits-width field with 4 bits-offset in 32 bits-width data at
4 bytes offseted from the address pointed by AX register:
+4(%ax):b2@4/32
Since the width of container data depends on the arch, so I just added
the container-size at the end.
Cc: 2nddept-manager@sdl.hitachi.co.jp
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
LKML-Reference: <20110204125205.9507.11363.stgit@ltc236.sdl.hitachi.co.jp>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
'sched_signal_send' doesn't exist in the kernel now. Replace it
with 'signal_generate' so that the example in events.txt can be
executed successfully.
I also change some /debug to /sys/kernel/debug which is debugfs'
default mount directory now(similar to commit 52ad51e).
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Signed-off-by: Tao Ma <boyu.mt@taobao.com>
Provides documentation for the following:
- the new power trace API,
- the old (legacy) power trace API,
- the DEPRECATED Kconfig option usage.
Signed-off-by: Jean Pihet <j-pihet@ti.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: trenn@suse.de
Cc: Len Brown <len.brown@intel.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: linux-pm@lists.linux-foundation.org
LKML-Reference: <1294253342-29056-3-git-send-email-j-pihet@ti.com>
and vmstat
When correlating ftrace results with /proc/vmstat, I noticed that the
reporting scripts value for "pages scanned" differed significantly. Both
values were "right" depending on how you look at it.
The difference is due to vmstat only counting scanning of the inactive
list towards pages scanned. The analysis script for the tracepoint counts
active and inactive list yielding a far higher value than vmstat. The
resulting scanning/reclaim ratio looks much worse. The tracepoint is ok
but this patch updates the reporting script so that the report values for
scanned are similar to vmstat.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
There have been numerous reports of stalls that pointed at the problem
being somewhere in the VM. There are multiple roots to the problems which
means dealing with any of the root problems in isolation is tricky to
justify on their own and they would still need integration testing. This
patch series puts together two different patch sets which in combination
should tackle some of the root causes of latency problems being reported.
Patch 1 adds a tracepoint for shrink_inactive_list. For this series, the
most important results is being able to calculate the scanning/reclaim
ratio as a measure of the amount of work being done by page reclaim.
Patch 2 accounts for time spent in congestion_wait.
Patches 3-6 were originally developed by Kosaki Motohiro but reworked for
this series. It has been noted that lumpy reclaim is far too aggressive
and trashes the system somewhat. As SLUB uses high-order allocations, a
large cost incurred by lumpy reclaim will be noticeable. It was also
reported during transparent hugepage support testing that lumpy reclaim
was trashing the system and these patches should mitigate that problem
without disabling lumpy reclaim.
Patch 7 adds wait_iff_congested() and replaces some callers of
congestion_wait(). wait_iff_congested() only sleeps if there is a BDI
that is currently congested. Patch 8 notes that any BDI being congested
is not necessarily a problem because there could be multiple BDIs of
varying speeds and numberous zones. It attempts to track when a zone
being reclaimed contains many pages backed by a congested BDI and if so,
reclaimers wait on the congestion queue.
I ran a number of tests with monitoring on X86, X86-64 and PPC64. Each
machine had 3G of RAM and the CPUs were
X86: Intel P4 2-core
X86-64: AMD Phenom 4-core
PPC64: PPC970MP
Each used a single disk and the onboard IO controller. Dirty ratio was
left at 20. I'm just going to report for X86-64 and PPC64 in a vague
attempt to keep this report short. Four kernels were tested each based on
v2.6.36-rc4
traceonly-v2r2: Patches 1 and 2 to instrument vmscan reclaims and congestion_wait
lowlumpy-v2r3: Patches 1-6 to test if lumpy reclaim is better
waitcongest-v2r3: Patches 1-7 to only wait on congestion
waitwriteback-v2r4: Patches 1-8 to detect when a zone is congested
nocongest-v1r5: Patches 1-3 for testing wait_iff_congestion
nodirect-v1r5: Patches 1-10 to disable filesystem writeback for better IO
The tests run were as follows
kernbench
compile-based benchmark. Smoke test performance
sysbench
OLTP read-only benchmark. Will be re-run in the future as read-write
micro-mapped-file-stream
This is a micro-benchmark from Johannes Weiner that accesses a
large sparse-file through mmap(). It was configured to run in only
single-CPU mode but can be indicative of how well page reclaim
identifies suitable pages.
stress-highalloc
Tries to allocate huge pages under heavy load.
kernbench, iozone and sysbench did not report any performance regression
on any machine. sysbench did pressure the system lightly and there was
reclaim activity but there were no difference of major interest between
the kernels.
X86-64 micro-mapped-file-stream
traceonly-v2r2 lowlumpy-v2r3 waitcongest-v2r3 waitwriteback-v2r4
pgalloc_dma 1639.00 ( 0.00%) 667.00 (-145.73%) 1167.00 ( -40.45%) 578.00 (-183.56%)
pgalloc_dma32 2842410.00 ( 0.00%) 2842626.00 ( 0.01%) 2843043.00 ( 0.02%) 2843014.00 ( 0.02%)
pgalloc_normal 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%)
pgsteal_dma 729.00 ( 0.00%) 85.00 (-757.65%) 609.00 ( -19.70%) 125.00 (-483.20%)
pgsteal_dma32 2338721.00 ( 0.00%) 2447354.00 ( 4.44%) 2429536.00 ( 3.74%) 2436772.00 ( 4.02%)
pgsteal_normal 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%)
pgscan_kswapd_dma 1469.00 ( 0.00%) 532.00 (-176.13%) 1078.00 ( -36.27%) 220.00 (-567.73%)
pgscan_kswapd_dma32 4597713.00 ( 0.00%) 4503597.00 ( -2.09%) 4295673.00 ( -7.03%) 3891686.00 ( -18.14%)
pgscan_kswapd_normal 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%)
pgscan_direct_dma 71.00 ( 0.00%) 134.00 ( 47.01%) 243.00 ( 70.78%) 352.00 ( 79.83%)
pgscan_direct_dma32 305820.00 ( 0.00%) 280204.00 ( -9.14%) 600518.00 ( 49.07%) 957485.00 ( 68.06%)
pgscan_direct_normal 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%)
pageoutrun 16296.00 ( 0.00%) 21254.00 ( 23.33%) 18447.00 ( 11.66%) 20067.00 ( 18.79%)
allocstall 443.00 ( 0.00%) 273.00 ( -62.27%) 513.00 ( 13.65%) 1568.00 ( 71.75%)
These are based on the raw figures taken from /proc/vmstat. It's a rough
measure of reclaim activity. Note that allocstall counts are higher
because we are entering direct reclaim more often as a result of not
sleeping in congestion. In itself, it's not necessarily a bad thing.
It's easier to get a view of what happened from the vmscan tracepoint
report.
FTrace Reclaim Statistics: vmscan
Direct reclaims 443 273 513 1568
Direct reclaim pages scanned 305968 280402 600825 957933
Direct reclaim pages reclaimed 43503 19005 30327 117191
Direct reclaim write file async I/O 0 0 0 0
Direct reclaim write anon async I/O 0 3 4 12
Direct reclaim write file sync I/O 0 0 0 0
Direct reclaim write anon sync I/O 0 0 0 0
Wake kswapd requests 187649 132338 191695 267701
Kswapd wakeups 3 1 4 1
Kswapd pages scanned 4599269 4454162 4296815 3891906
Kswapd pages reclaimed 2295947 2428434 2399818 2319706
Kswapd reclaim write file async I/O 1 0 1 1
Kswapd reclaim write anon async I/O 59 187 41 222
Kswapd reclaim write file sync I/O 0 0 0 0
Kswapd reclaim write anon sync I/O 0 0 0 0
Time stalled direct reclaim (seconds) 4.34 2.52 6.63 2.96
Time kswapd awake (seconds) 11.15 10.25 11.01 10.19
Total pages scanned 4905237 4734564 4897640 4849839
Total pages reclaimed 2339450 2447439 2430145 2436897
%age total pages scanned/reclaimed 47.69% 51.69% 49.62% 50.25%
%age total pages scanned/written 0.00% 0.00% 0.00% 0.00%
%age file pages scanned/written 0.00% 0.00% 0.00% 0.00%
Percentage Time Spent Direct Reclaim 29.23% 19.02% 38.48% 20.25%
Percentage Time kswapd Awake 78.58% 78.85% 76.83% 79.86%
What is interesting here for nocongest in particular is that while direct
reclaim scans more pages, the overall number of pages scanned remains the
same and the ratio of pages scanned to pages reclaimed is more or less the
same. In other words, while we are sleeping less, reclaim is not doing
more work and as direct reclaim and kswapd is awake for less time, it
would appear to be doing less work.
FTrace Reclaim Statistics: congestion_wait
Direct number congest waited 87 196 64 0
Direct time congest waited 4604ms 4732ms 5420ms 0ms
Direct full congest waited 72 145 53 0
Direct number conditional waited 0 0 324 1315
Direct time conditional waited 0ms 0ms 0ms 0ms
Direct full conditional waited 0 0 0 0
KSwapd number congest waited 20 10 15 7
KSwapd time congest waited 1264ms 536ms 884ms 284ms
KSwapd full congest waited 10 4 6 2
KSwapd number conditional waited 0 0 0 0
KSwapd time conditional waited 0ms 0ms 0ms 0ms
KSwapd full conditional waited 0 0 0 0
The vanilla kernel spent 8 seconds asleep in direct reclaim and no time at
all asleep with the patches.
MMTests Statistics: duration
User/Sys Time Running Test (seconds) 10.51 10.73 10.6 11.66
Total Elapsed Time (seconds) 14.19 13.00 14.33 12.76
Overall, the tests completed faster. It is interesting to note that backing off further
when a zone is congested and not just a BDI was more efficient overall.
PPC64 micro-mapped-file-stream
pgalloc_dma 3024660.00 ( 0.00%) 3027185.00 ( 0.08%) 3025845.00 ( 0.04%) 3026281.00 ( 0.05%)
pgsteal_dma 2508073.00 ( 0.00%) 2565351.00 ( 2.23%) 2463577.00 ( -1.81%) 2532263.00 ( 0.96%)
pgscan_kswapd_dma 4601307.00 ( 0.00%) 4128076.00 ( -11.46%) 3912317.00 ( -17.61%) 3377165.00 ( -36.25%)
pgscan_direct_dma 629825.00 ( 0.00%) 971622.00 ( 35.18%) 1063938.00 ( 40.80%) 1711935.00 ( 63.21%)
pageoutrun 27776.00 ( 0.00%) 20458.00 ( -35.77%) 18763.00 ( -48.04%) 18157.00 ( -52.98%)
allocstall 977.00 ( 0.00%) 2751.00 ( 64.49%) 2098.00 ( 53.43%) 5136.00 ( 80.98%)
Similar trends to x86-64. allocstalls are up but it's not necessarily bad.
Direct reclaims 977 2709 2098 5136
Direct reclaim pages scanned 629825 963814 1063938 1711935
Direct reclaim pages reclaimed 75550 242538 150904 387647
Direct reclaim write file async I/O 0 0 0 2
Direct reclaim write anon async I/O 0 10 0 4
Wake kswapd requests 392119 1201712 571935 571921
Kswapd wakeups 3 2 3 3
Kswapd pages scanned 4601307 4128076 3912317 3377165
Kswapd pages reclaimed 2432523 2318797 2312673 2144616
Kswapd reclaim write file async I/O 20 1 1 1
Kswapd reclaim write anon async I/O 57 132 11 121
Time stalled direct reclaim (seconds) 6.19 7.30 13.04 10.88
Time kswapd awake (seconds) 21.73 26.51 25.55 23.90
Total pages scanned 5231132 5091890 4976255 5089100
Total pages reclaimed 2508073 2561335 2463577 2532263
%age total pages scanned/reclaimed 47.95% 50.30% 49.51% 49.76%
Percentage Time Spent Direct Reclaim 18.89% 20.65% 32.65% 27.65%
Percentage Time kswapd Awake 72.39% 80.68% 78.21% 77.40%
Again, a similar trend that the congestion_wait changes mean that direct
reclaim scans more pages but the overall number of pages scanned while
slightly reduced, are very similar. The ratio of scanning/reclaimed
remains roughly similar. The downside is that kswapd and direct reclaim
was awake longer and for a larger percentage of the overall workload.
It's possible there were big differences in the amount of time spent
reclaiming slab pages between the different kernels which is plausible
considering that the micro tests runs after fsmark and sysbench.
Direct number congest waited 845 1312 104 0
Direct time congest waited 19416ms 26560ms 7544ms 0ms
Direct full congest waited 745 1105 72 0
Direct number conditional waited 0 0 1322 2935
Direct time conditional waited 0ms 0ms 12ms 312ms
Direct full conditional waited 0 0 0 3
KSwapd number congest waited 39 102 75 63
KSwapd time congest waited 2484ms 6760ms 5756ms 3716ms
KSwapd full congest waited 20 48 46 25
The vanilla kernel spent 20 seconds asleep in direct reclaim and only
312ms asleep with the patches. The time kswapd spent congest waited was
also reduced by a large factor.
ser/Sys Time Running Test (seconds) 26.58 28.05 26.9 28.47
Total Elapsed Time (seconds) 30.02 32.86 32.67 30.88
With all patches applies, the completion times are very similar.
X86-64 STRESS-HIGHALLOC
traceonly-v2r2 lowlumpy-v2r3 waitcongest-v2r3waitwriteback-v2r4
Pass 1 82.00 ( 0.00%) 84.00 ( 2.00%) 85.00 ( 3.00%) 85.00 ( 3.00%)
Pass 2 90.00 ( 0.00%) 87.00 (-3.00%) 88.00 (-2.00%) 89.00 (-1.00%)
At Rest 92.00 ( 0.00%) 90.00 (-2.00%) 90.00 (-2.00%) 91.00 (-1.00%)
Success figures across the board are broadly similar.
Direct reclaims 1045 944 886 887
Direct reclaim pages scanned 135091 119604 109382 101019
Direct reclaim pages reclaimed 88599 47535 47863 46671
Direct reclaim write file async I/O 494 283 465 280
Direct reclaim write anon async I/O 29357 13710 16656 13462
Direct reclaim write file sync I/O 154 2 2 3
Direct reclaim write anon sync I/O 14594 571 509 561
Wake kswapd requests 7491 933 872 892
Kswapd wakeups 814 778 731 780
Kswapd pages scanned 7290822 15341158 11916436 13703442
Kswapd pages reclaimed 3587336 3142496 3094392 3187151
Kswapd reclaim write file async I/O 91975 32317 28022 29628
Kswapd reclaim write anon async I/O 1992022 789307 829745 849769
Time stalled direct reclaim (seconds) 4588.93 2467.16 2495.41 2547.07
Time kswapd awake (seconds) 2497.66 1020.16 1098.06 1176.82
Total pages scanned 7425913 15460762 12025818 13804461
Total pages reclaimed 3675935 3190031 3142255 3233822
%age total pages scanned/reclaimed 49.50% 20.63% 26.13% 23.43%
%age total pages scanned/written 28.66% 5.41% 7.28% 6.47%
%age file pages scanned/written 1.25% 0.21% 0.24% 0.22%
Percentage Time Spent Direct Reclaim 57.33% 42.15% 42.41% 42.99%
Percentage Time kswapd Awake 43.56% 27.87% 29.76% 31.25%
Scanned/reclaimed ratios again look good with big improvements in
efficiency. The Scanned/written ratios also look much improved. With a
better scanned/written ration, there is an expectation that IO would be
more efficient and indeed, the time spent in direct reclaim is much
reduced by the full series and kswapd spends a little less time awake.
Overall, indications here are that allocations were happening much faster
and this can be seen with a graph of the latency figures as the
allocations were taking place
http://www.csn.ul.ie/~mel/postings/vmscanreduce-20101509/highalloc-interlatency-hydra-mean.ps
Direct number congest waited 1333 204 169 4
Direct time congest waited 78896ms 8288ms 7260ms 200ms
Direct full congest waited 756 92 69 2
Direct number conditional waited 0 0 26 186
Direct time conditional waited 0ms 0ms 0ms 2504ms
Direct full conditional waited 0 0 0 25
KSwapd number congest waited 4 395 227 282
KSwapd time congest waited 384ms 25136ms 10508ms 18380ms
KSwapd full congest waited 3 232 98 176
KSwapd full conditional waited 318 0 312 9
Overall, the time spent speeping is reduced. kswapd is still hitting
congestion_wait() but that is because there are callers remaining where it
wasn't clear in advance if they should be changed to wait_iff_congested()
or not. Overall the sleep imes are reduced though - from 79ish seconds to
about 19.
User/Sys Time Running Test (seconds) 3415.43 3386.65 3388.39 3377.5
Total Elapsed Time (seconds) 5733.48 3660.33 3689.41 3765.39
With the full series, the time to complete the tests are reduced by 30%
PPC64 STRESS-HIGHALLOC
Pass 1 17.00 ( 0.00%) 34.00 (17.00%) 38.00 (21.00%) 43.00 (26.00%)
Pass 2 25.00 ( 0.00%) 37.00 (12.00%) 42.00 (17.00%) 46.00 (21.00%)
At Rest 49.00 ( 0.00%) 43.00 (-6.00%) 45.00 (-4.00%) 51.00 ( 2.00%)
Success rates there are *way* up particularly considering that the 16MB
huge pages on PPC64 mean that it's always much harder to allocate them.
stress-highalloc stress-highalloc stress-highalloc stress-highalloc
Direct reclaims 499 505 564 509
Direct reclaim pages scanned 223478 41898 51818 45605
Direct reclaim pages reclaimed 137730 21148 27161 23455
Direct reclaim write file async I/O 399 136 162 136
Direct reclaim write anon async I/O 46977 2865 4686 3998
Direct reclaim write file sync I/O 29 0 1 3
Direct reclaim write anon sync I/O 31023 159 237 239
Wake kswapd requests 420 351 360 326
Kswapd wakeups 185 294 249 277
Kswapd pages scanned 15703488 16392500 17821724 17598737
Kswapd pages reclaimed 5808466 2908858 3139386 3145435
Kswapd reclaim write file async I/O 159938 18400 18717 13473
Kswapd reclaim write anon async I/O 3467554 228957 322799 234278
Time stalled direct reclaim (seconds) 9665.35 1707.81 2374.32 1871.23
Time kswapd awake (seconds) 9401.21 1367.86 1951.75 1328.88
Total pages scanned 15926966 16434398 17873542 17644342
Total pages reclaimed 5946196 2930006 3166547 3168890
%age total pages scanned/reclaimed 37.33% 17.83% 17.72% 17.96%
%age total pages scanned/written 23.27% 1.52% 1.94% 1.43%
%age file pages scanned/written 1.01% 0.11% 0.11% 0.08%
Percentage Time Spent Direct Reclaim 44.55% 35.10% 41.42% 36.91%
Percentage Time kswapd Awake 86.71% 43.58% 52.67% 41.14%
While the scanning rates are slightly up, the scanned/reclaimed and
scanned/written figures are much improved. The time spent in direct
reclaim and with kswapd are massively reduced, mostly by the lowlumpy
patches.
Direct number congest waited 725 303 126 3
Direct time congest waited 45524ms 9180ms 5936ms 300ms
Direct full congest waited 487 190 52 3
Direct number conditional waited 0 0 200 301
Direct time conditional waited 0ms 0ms 0ms 1904ms
Direct full conditional waited 0 0 0 19
KSwapd number congest waited 0 2 23 4
KSwapd time congest waited 0ms 200ms 420ms 404ms
KSwapd full congest waited 0 2 2 4
Not as dramatic a story here but the time spent asleep is reduced and we
can still see what wait_iff_congested is going to sleep when necessary.
User/Sys Time Running Test (seconds) 12028.09 3157.17 3357.79 3199.16
Total Elapsed Time (seconds) 10842.07 3138.72 3705.54 3229.85
The time to complete this test goes way down. With the full series, we
are allocating over twice the number of huge pages in 30% of the time and
there is a corresponding impact on the allocation latency graph available
at.
http://www.csn.ul.ie/~mel/postings/vmscanreduce-20101509/highalloc-interlatency-powyah-mean.ps
This patch:
Add a trace event for shrink_inactive_list() and updates the sample
postprocessing script appropriately. It can be used to determine how many
pages were reclaimed and for non-lumpy reclaim where exactly the pages
were reclaimed from.
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Add a simple post-processing script for the reclaim-related trace events.
It can be used to give an indication of how much traffic there is on the
LRU lists and how severe latencies due to reclaim are. Example output
looks like the following
Reclaim latencies expressed as order-latency_in_ms
uname-3942 9-200.179000000004 9-98.7900000000373 9-99.8330000001006
kswapd0-311 0-662.097999999998 0-2.79700000002049 \
0-149.100000000035 0-3295.73600000003 0-9806.31799999997 0-35528.833 \
0-10043.197 0-129740.979 0-3.50500000000466 0-3.54899999999907 \
0-9297.78999999992 0-3.48499999998603 0-3596.97999999998 0-3.92799999995623 \
0-3.35000000009313 0-16729.017 0-3.57799999997951 0-47435.0630000001 \
0-3.7819999998901 0-5864.06999999995 0-18635.334 0-10541.289 9-186011.565 \
9-3680.86300000001 9-1379.06499999994 9-958571.115 9-66215.474 \
9-6721.14699999988 9-1962.15299999993 9-1094806.125 9-2267.83199999994 \
9-47120.9029999999 9-427653.886 9-2.6359999999404 9-632.148999999976 \
9-476.753000000026 9-495.577000000048 9-8.45900000003166 9-6.6820000000298 \
9-1.30500000016764 9-251.746000000043 9-383.905000000028 9-80.1419999999925 \
9-281.160000000149 9-14.8780000000261 9-381.45299999998 9-512.07799999998 \
9-49.5519999999087 9-167.439000000013 9-183.820999999996 9-239.527999999933 \
9-19.9479999998584 9-148.747999999905 9-164.583000000101 9-16.9480000000913 \
9-192.376000000164 9-64.1010000000242 9-1.40800000005402 9-3.60800000000745 \
9-17.1359999999404 9-4.69500000006519 9-2.06400000001304 9-1582488.554 \
9-6244.19499999983 9-348153.812 9-2.0999999998603 9-0.987999999895692 \
0-32218.473 0-1.6140000000596 0-1.28100000019185 0-1.41300000017509 \
0-1.32299999985844 0-602.584000000032 0-1.34400000004098 0-1.6929999999702 \
1-22101.8190000001 9-174876.724 9-16.2420000000857 9-175.165999999736 \
9-15.8589999997057 9-0.604999999981374 9-3061.09000000032 9-479.277000000235 \
9-1.54499999992549 9-771.985000000335 9-4.88700000010431 9-15.0649999999441 \
9-0.879999999888241 9-252.01500000013 9-1381.03600000031 9-545.689999999944 \
9-3438.0129999998 9-3343.70099999988
bench-stresshig-3942 9-7063.33900000004 9-129960.482 9-2062.27500000002 \
9-3845.59399999992 9-171.82799999998 9-16493.821 9-7615.23900000006 \
9-10217.848 9-983.138000000035 9-2698.39999999991 9-4016.1540000001 \
9-5522.37700000009 9-21630.429 \
9-15061.048 9-10327.953 9-542.69700000016 9-317.652000000002 \
9-8554.71699999995 9-1786.61599999992 9-1899.31499999994 9-2093.41899999999 \
9-4992.62400000007 9-942.648999999976 9-1923.98300000001 9-3.7980000001844 \
9-5.99899999983609 9-0.912000000011176 9-1603.67700000014 9-1.98300000000745 \
9-3.96500000008382 9-0.902999999932945 9-2802.72199999983 9-1078.24799999991 \
9-2155.82900000014 9-10.058999999892 9-1984.723 9-1687.97999999998 \
9-1136.05300000007 9-3183.61699999985 9-458.731000000145 9-6.48600000003353 \
9-1013.25200000009 9-8415.22799999989 9-10065.584 9-2076.79600000009 \
9-3792.65699999989 9-71.2010000001173 9-2560.96999999997 9-2260.68400000012 \
9-2862.65799999982 9-1255.81500000018 9-15.7440000001807 9-4.33499999996275 \
9-1446.63800000004 9-238.635000000009 9-60.1790000000037 9-4.38800000003539 \
9-639.567000000039 9-306.698000000091 9-31.4070000001229 9-74.997999999905 \
9-632.725999999791 9-1625.93200000003 9-931.266000000061 9-98.7749999999069 \
9-984.606999999844 9-225.638999999966 9-421.316000000108 9-653.744999999879 \
9-572.804000000004 9-769.158999999985 9-603.918000000063 9-4.28499999991618 \
9-626.21399999992 9-1721.25 9-0.854999999981374 9-572.39599999995 \
9-681.881999999983 9-1345.12599999993 9-363.666999999899 9-3823.31099999999 \
9-2991.28200000012 9-4.27099999994971 9-309.76500000013 9-3068.35700000008 \
9-788.25 9-3515.73999999999 9-2065.96100000013 9-286.719999999972 \
9-316.076000000117 9-344.151000000071 9-2.51000000000931 9-306.688000000082 \
9-1515.00099999993 9-336.528999999864 9-793.491999999853 9-457.348999999929 \
9-13620.155 9-119.933999999892 9-35.0670000000391 9-918.266999999993 \
9-828.569000000134 9-4863.81099999999 9-105.222000000067 9-894.23900000006 \
9-110.964999999851 9-0.662999999942258 9-12753.3150000002 9-12.6129999998957 \
9-13368.0899999999 9-12.4199999999255 9-1.00300000002608 9-1.41100000008009 \
9-10300.5290000001 9-16.502000000095 9-30.7949999999255 9-6283.0140000002 \
9-4320.53799999994 9-6826.27300000004 9-3.07299999985844 9-1497.26799999992 \
9-13.4040000000969 9-3.12999999988824 9-3.86100000003353 9-11.3539999998175 \
9-0.10799999977462 9-21.780999999959 9-209.695999999996 9-299.647000000114 \
9-6.01699999999255 9-20.8349999999627 9-22.5470000000205 9-5470.16800000006 \
9-7.60499999998137 9-0.821000000229105 9-1.56600000010803 9-14.1669999998994 \
9-0.209000000031665 9-1.82300000009127 9-1.70000000018626 9-19.9429999999702 \
9-124.266999999993 9-0.0389999998733401 9-6.71400000015274 9-16.7710000001825 \
9-31.0409999999683 9-0.516999999992549 9-115.888000000035 9-5.19900000002235 \
9-222.389999999898 9-11.2739999999758 9-80.9050000000279 9-8.14500000001863 \
9-4.44599999999627 9-0.218999999808148 9-0.715000000083819 9-0.233000000007451
9-48.2630000000354 9-248.560999999987 9-374.96800000011 9-644.179000000004 \
9-0.835999999893829 9-79.0060000000522 9-128.447999999858 9-0.692000000039116 \
9-5.26500000013039 9-128.449000000022 9-2.04799999995157 9-12.0990000001621 \
9-8.39899999997579 9-10.3860000001732 9-11.9310000000987 9-53.4450000000652 \
9-0.46999999997206 9-2.96299999998882 9-17.9699999999721 9-0.776000000070781 \
9-25.2919999998994 9-33.1110000000335 9-0.434000000124797 9-0.641000000061467 \
9-0.505000000121072 9-1.12800000002608 9-149.222000000067 9-1.17599999997765 \
9-3247.33100000001 9-10.7439999999478 9-153.523000000045 9-1.38300000014715 \
9-794.762000000104 9-3.36199999996461 9-128.765999999829 9-181.543999999994 \
9-78149.8229999999 9-176.496999999974 9-89.9940000001807 9-9.12700000009499 \
9-250.827000000048 9-0.224999999860302 9-0.388999999966472 9-1.16700000036508 \
9-32.1740000001155 9-12.6800000001676 9-0.0720000001601875 9-0.274999999906868
9-0.724000000394881 9-266.866000000387 9-45.5709999999963 9-4.54399999976158 \
9-8.27199999988079 9-4.38099999958649 9-0.512000000104308 9-0.0640000002458692
9-5.20000000018626 9-0.0839999997988343 9-12.816000000108 9-0.503000000026077 \
9-0.507999999914318 9-6.23999999975786 9-3.35100000025705 9-18.8530000001192 \
9-25.2220000000671 9-68.2309999996796 9-98.9939999999478 9-0.441000000108033 \
9-4.24599999981001 9-261.702000000048 9-3.01599999982864 9-0.0749999997206032 \
9-0.0370000000111759 9-4.375 9-3.21800000034273 9-11.3960000001825 \
9-0.0540000000037253 9-0.286000000312924 9-0.865999999921769 \
9-0.294999999925494 9-6.45999999996275 9-4.31099999975413 9-128.248999999836 \
9-0.282999999821186 9-102.155000000261 9-0.0860000001266599 \
9-0.0540000000037253 9-0.935000000055879 9-0.0670000002719462 \
9-5.8640000000596 9-19.9860000000335 9-4.18699999991804 9-0.566000000108033 \
9-2.55099999997765 9-0.702000000048429 9-131.653999999631 9-0.638999999966472 \
9-14.3229999998584 9-183.398000000045 9-178.095999999903 9-3.22899999981746 \
9-7.31399999978021 9-22.2400000002235 9-11.7979999999516 9-108.10599999968 \
9-99.0159999998286 9-102.640999999829 9-38.414000000339
Process Direct Wokeup Pages Pages Pages
details Rclms Kswapd Scanned Sync-IO ASync-IO
cc1-30800 0 1 0 0 0 wakeup-0=1
cc1-24260 0 1 0 0 0 wakeup-0=1
cc1-24152 0 12 0 0 0 wakeup-0=12
cc1-8139 0 1 0 0 0 wakeup-0=1
cc1-4390 0 1 0 0 0 wakeup-0=1
cc1-4648 0 7 0 0 0 wakeup-0=7
cc1-4552 0 3 0 0 0 wakeup-0=3
dd-4550 0 31 0 0 0 wakeup-0=31
date-4898 0 1 0 0 0 wakeup-0=1
cc1-6549 0 7 0 0 0 wakeup-0=7
as-22202 0 17 0 0 0 wakeup-0=17
cc1-6495 0 9 0 0 0 wakeup-0=9
cc1-8299 0 1 0 0 0 wakeup-0=1
cc1-6009 0 1 0 0 0 wakeup-0=1
cc1-2574 0 2 0 0 0 wakeup-0=2
cc1-30568 0 1 0 0 0 wakeup-0=1
cc1-2679 0 6 0 0 0 wakeup-0=6
sh-13747 0 12 0 0 0 wakeup-0=12
cc1-22193 0 18 0 0 0 wakeup-0=18
cc1-30725 0 2 0 0 0 wakeup-0=2
as-4392 0 2 0 0 0 wakeup-0=2
cc1-28180 0 14 0 0 0 wakeup-0=14
cc1-13697 0 2 0 0 0 wakeup-0=2
cc1-22207 0 8 0 0 0 wakeup-0=8
cc1-15270 0 179 0 0 0 wakeup-0=179
cc1-22011 0 82 0 0 0 wakeup-0=82
cp-14682 0 1 0 0 0 wakeup-0=1
as-11926 0 2 0 0 0 wakeup-0=2
cc1-6016 0 5 0 0 0 wakeup-0=5
make-18554 0 13 0 0 0 wakeup-0=13
cc1-8292 0 12 0 0 0 wakeup-0=12
make-24381 0 1 0 0 0 wakeup-1=1
date-18681 0 33 0 0 0 wakeup-0=33
cc1-32276 0 1 0 0 0 wakeup-0=1
timestamp-outpu-2809 0 253 0 0 0 wakeup-0=240 wakeup-1=13
date-18624 0 7 0 0 0 wakeup-0=7
cc1-30960 0 9 0 0 0 wakeup-0=9
cc1-4014 0 1 0 0 0 wakeup-0=1
cc1-30706 0 22 0 0 0 wakeup-0=22
uname-3942 4 1 306 0 17 direct-9=4 wakeup-9=1
cc1-28207 0 1 0 0 0 wakeup-0=1
cc1-30563 0 9 0 0 0 wakeup-0=9
cc1-22214 0 10 0 0 0 wakeup-0=10
cc1-28221 0 11 0 0 0 wakeup-0=11
cc1-28123 0 6 0 0 0 wakeup-0=6
kswapd0-311 0 7 357302 0 34233 wakeup-0=7
cc1-5988 0 7 0 0 0 wakeup-0=7
as-30734 0 161 0 0 0 wakeup-0=161
cc1-22004 0 45 0 0 0 wakeup-0=45
date-4590 0 4 0 0 0 wakeup-0=4
cc1-15279 0 213 0 0 0 wakeup-0=213
date-30735 0 1 0 0 0 wakeup-0=1
cc1-30583 0 4 0 0 0 wakeup-0=4
cc1-32324 0 2 0 0 0 wakeup-0=2
cc1-23933 0 3 0 0 0 wakeup-0=3
cc1-22001 0 36 0 0 0 wakeup-0=36
bench-stresshig-3942 287 287 80186 6295 12196 direct-9=287 wakeup-9=287
cc1-28170 0 7 0 0 0 wakeup-0=7
date-7932 0 92 0 0 0 wakeup-0=92
cc1-22222 0 6 0 0 0 wakeup-0=6
cc1-32334 0 16 0 0 0 wakeup-0=16
cc1-2690 0 6 0 0 0 wakeup-0=6
cc1-30733 0 9 0 0 0 wakeup-0=9
cc1-32298 0 2 0 0 0 wakeup-0=2
cc1-13743 0 18 0 0 0 wakeup-0=18
cc1-22186 0 4 0 0 0 wakeup-0=4
cc1-28214 0 11 0 0 0 wakeup-0=11
cc1-13735 0 1 0 0 0 wakeup-0=1
updatedb-8173 0 18 0 0 0 wakeup-0=18
cc1-13750 0 3 0 0 0 wakeup-0=3
cat-2808 0 2 0 0 0 wakeup-0=2
cc1-15277 0 169 0 0 0 wakeup-0=169
date-18317 0 1 0 0 0 wakeup-0=1
cc1-15274 0 197 0 0 0 wakeup-0=197
cc1-30732 0 1 0 0 0 wakeup-0=1
Kswapd Kswapd Order Pages Pages Pages
Instance Wakeups Re-wakeup Scanned Sync-IO ASync-IO
kswapd0-311 91 24 357302 0 34233 wake-0=31 wake-1=1 wake-9=59 rewake-0=10 rewake-1=1 rewake-9=13
Summary
Direct reclaims: 291
Direct reclaim pages scanned: 437794
Direct reclaim write sync I/O: 6295
Direct reclaim write async I/O: 46446
Wake kswapd requests: 2152
Time stalled direct reclaim: 519.163009000002 ms
Kswapd wakeups: 91
Kswapd pages scanned: 357302
Kswapd reclaim write sync I/O: 0
Kswapd reclaim write async I/O: 34233
Time kswapd awake: 5282.749757 ms
Acked-by: Larry Woodman <lwoodman@redhat.com>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Michael Rubin <mrubin@google.com>
Add more details to the dynamic function tracing design implementation.
LKML-Reference: <1279610015-10250-1-git-send-email-vapier@gentoo.org>
Support string type tracing and printing in kprobe-tracer.
This allows user to trace string data in kernel including __user data. Note
that sometimes __user data may not be accessed if it is paged-out (sorry, but
kprobes operation should be done in atomic, we can not wait for page-in).
Commiter note: Fixed up conflicts with b7e2ece.
LKML-Reference: <20100519195724.2885.18788.stgit@localhost6.localdomain6>
Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com>
We have been resisting new ftrace plugins and removing existing
ones, and kmemtrace has been superseded by kmem trace events
and perf-kmem, so we remove it.
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
Acked-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro>
[ remove kmemtrace from the makefile, handle slob too ]
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits)
vlynq: make whole Kconfig-menu dependant on architecture
add descriptive comment for TIF_MEMDIE task flag declaration.
EEPROM: max6875: Header file cleanup
EEPROM: 93cx6: Header file cleanup
EEPROM: Header file cleanup
agp: use NULL instead of 0 when pointer is needed
rtc-v3020: make bitfield unsigned
PCI: make bitfield unsigned
jbd2: use NULL instead of 0 when pointer is needed
cciss: fix shadows sparse warning
doc: inode uses a mutex instead of a semaphore.
uml: i386: Avoid redefinition of NR_syscalls
fix "seperate" typos in comments
cocbalt_lcdfb: correct sections
doc: Change urls for sparse
Powerpc: wii: Fix typo in comment
i2o: cleanup some exit paths
Documentation/: it's -> its where appropriate
UML: Fix compiler warning due to missing task_struct declaration
UML: add kernel.h include to signal.c
* 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
tracing: Fix "integer as NULL pointer" warning.
tracing: Fix tracepoint.h DECLARE_TRACE() to allow more than one header
tracing: Make the documentation clear on trace_event boot option
ring-buffer: Wrap open-coded WARN_ONCE
tracing: Convert nop macros to static inlines
tracing: Fix sleep time function profiling
tracing: Show sample std dev in function profiling
tracing: Add documentation for trace commands mod, traceon/traceoff
ring-buffer: Make benchmark handle missed events
ring-buffer: Make non-consuming read less expensive with lots of cpus.
tracing: Add graph output support for irqsoff tracer
tracing: Have graph flags passed in to ouput functions
tracing: Add ftrace events for graph tracer
tracing: Dump either the oops's cpu source or all cpus buffers
tracing: Fix uninitialized variable of tracing/trace output
Make it clear that event-list is a comma separated list of events.
Reported-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
LKML-Reference: <4B2F154C.2060503@cn.fujitsu.com>
The mod command went in as commit
64e7c440618998fd69eee6ab490b042d12248021
The traceon/traceoff commands went in as commit
23b4ff3aa479c9e3bb23cb6b2d0a97878399784a
Signed-off-by: Chase Douglas <chase.douglas@canonical.com>
LKML-Reference: <1272045759-32018-1-git-send-email-chase.douglas@canonical.com>
The ftrace_dump_on_oops kernel parameter, sysctl and sysrq let one
dump every cpu buffers when an oops or panic happens.
It's nice when you have few cpus but it may take ages if have many,
plus you miss the real origin of the problem in all the cpu traces.
Sometimes, all you need is to dump the cpu buffer that triggered the
opps, most of the time it is our main interest.
This patch modifies ftrace_dump_on_oops to handle this choice.
The ftrace_dump_on_oops kernel parameter, when it comes alone, has
the same behaviour than before. But ftrace_dump_on_oops=orig_cpu
will only dump the buffer of the cpu that oops'ed.
Similarly, sysctl kernel.ftrace_dump_on_oops=1 and
echo 1 > /proc/sys/kernel/ftrace_dump_on_oops keep their previous
behaviour. But setting 2 jumps into cpu origin dump mode.
v2: Fix double setup
v3: Fix spelling issues reported by Randy Dunlap
v4: Also update __ftrace_dump in the selftests
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Support basic types of integer (u8, u16, u32, u64, s8, s16, s32, s64) in
kprobe tracer. With this patch, users can specify above basic types on
each arguments after ':'. If omitted, the argument type is set as
unsigned long (u32 or u64, arch-dependent).
e.g.
echo 'p account_system_time+0 hardirq_offset=%si:s32' > kprobe_events
adds a probe recording hardirq_offset in signed-32bits value on the
entry of account_system_time.
LKML-Reference: <20100412171708.3790.18599.stgit@localhost6.localdomain6>
[Ss]ytem => [Ss]ystem
udpate => update
paramters => parameters
orginal => original
Signed-off-by: Thomas Weber <swirl@gmx.li>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (172 commits)
perf_event, amd: Fix spinlock initialization
perf_event: Fix preempt warning in perf_clock()
perf tools: Flush maps on COMM events
perf_events, x86: Split PMU definitions into separate files
perf annotate: Handle samples not at objdump output addr boundaries
perf_events, x86: Remove superflous MSR writes
perf_events: Simplify code by removing cpu argument to hw_perf_group_sched_in()
perf_events, x86: AMD event scheduling
perf_events: Add new start/stop PMU callbacks
perf_events: Report the MMAP pgoff value in bytes
perf annotate: Defer allocating sym_priv->hist array
perf symbols: Improve debugging information about symtab origins
perf top: Use a macro instead of a constant variable
perf symbols: Check the right return variable
perf/scripts: Tag syscall_name helper as not yet available
perf/scripts: Add perf-trace-python Documentation
perf/scripts: Remove unnecessary PyTuple resizes
perf/scripts: Add syscall tracing scripts
perf/scripts: Add Python scripting engine
perf/scripts: Remove check-perf-trace from listed scripts
Fix trivial conflict in tools/perf/util/probe-event.c
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into tracing/core
Most implementations of arch_syscall_addr() are the same, so create a
default version in common code and move the one piece that differs (the
syscall table) to asm/syscall.h. New arch ports don't have to waste
time copying & pasting this simple function.
The s390/sparc versions need to be different, so document why.
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
LKML-Reference: <1264498803-17278-1-git-send-email-vapier@gentoo.org>
In particular, several occurances of funny versions of 'success',
'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address',
'beginning', 'desirable', 'separate' and 'necessary' are fixed.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Joe Perches <joe@perches.com>
Cc: Junio C Hamano <gitster@pobox.com>
Update the graph tracer examples to cover the new frame pointer semantics
(in terms of passing it along). Move the HAVE_FUNCTION_GRAPH_FP_TEST docs
out of the Kconfig, into the right place, and expand on the details.
LKML-Reference: <1264165967-18938-1-git-send-email-vapier@gentoo.org>
'ftrace' is no longer the name of the function tracer, to activate
the function trace 'echo function > current_tracer' is to be used instead
of 'echo ftrace > current_tracer'. Update the documentation to reflect
the current implementation.
Signed-off-by: Yang Hongyang <yanghy@cn.fujitsu.com>
LKML-Reference: <4B5D0BA8.20106@cn.fujitsu.com>
Latest kprobetrace can remove probe points selectively, thus
the documentation should be updated too.
Cc: systemtap <systemtap@sources.redhat.com>
Cc: DLE <dle-develop@lists.sourceforge.net>
LKML-Reference: <20100119023512.31880.35535.stgit@localhost6.localdomain6>
Shell interprets $val as shell variable, thus we need quote if
we use the echo command.
LKML-Reference: <20100119023505.31880.17367.stgit@localhost6.localdomain6>
