path: root/Documentation/usb/persist.txt
2012-08-10usb: add decriptor of persist fail for some morph usb devicesLan Tianyu
Some morph devices will morph after being reset and cause persist to fail. This patch is to add descriptor about this in the Document/usb/persist.txt Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2008-07-21USB: use reset_resume when normal resume failsAlan Stern
This patch (as1109b) makes USB-Persist more resilient to errors. With the current code, if a normal resume fails, it's an unrecoverable error. With the patch, if a normal resume fails (and if the device is enabled for USB-Persist) then a reset-resume is tried. This fixes the problem reported in Bugzilla #10977. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: check serial-number string after device resetAlan Stern
This patch (as1048) extends the descriptor checking after a device is reset. Now the SerialNumber string descriptor is compared to its old value, in addition to the device and configuration descriptors. As a consequence, the kmalloc() call in usb_string() is now on the error-handling pathway for usb-storage. Hence its allocation type is changed to GFO_NOIO. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: remove CONFIG_USB_PERSIST settingAlan Stern
This patch (as1047) removes the USB_PERSIST Kconfig option, enabling it permanently. It also prevents the power/persist attribute from being created for hub devices; there's no point in having it since USB-PERSIST is always turned on for hubs. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: add power/persist device attributeAlan Stern
This patch (as920) adds an extra level of protection to the USB-Persist facility. Now it will apply by default only to hubs; for all other devices the user must enable it explicitly by setting the power/persist device attribute. The disconnect_all_children() routine in hub.c has been removed and its code placed inline. This is the way it was originally as part of hub_pre_reset(); the revised usage in hub_reset_resume() is sufficiently different that the code can no longer be shared. Likewise, mark_children_for_reset() is now inline as part of hub_reset_resume(). The end result looks much cleaner than before. The sysfs interface is updated to add the new attribute file, and there are corresponding documentation updates. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: add USB-Persist facilityAlan Stern
This patch (as886) adds the controversial USB-persist facility, allowing USB devices to persist across a power loss during system suspend. The facility is controlled by a new Kconfig option (with appropriate warnings about the potential dangers); when the option is off the behavior will remain the same as it is now. But when the option is on, people will be able to use suspend-to-disk and keep their USB filesystems intact -- something particularly valuable for small machines where the root filesystem is on a USB device! Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
