path: root/Documentation/usb
2013-08-12proc_usb_info.txt: Correct documentation about endianness of config descriptorsHans de Goede
The config descriptors as read from /proc/bus/usb/BBB/DDD are in *bus* endian format. Correct proc_usb_info.txt to correctly reflect that. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-12USB: URB documentation: claim complete() will be run with IRQs enabledMing Lei
There is no good reason to run complete() in hard interrupt disabled context. After switch to run complete() in tasklet, we will enable local IRQs when calling complete() since we can do it at that time. Even though we still disable IRQs now when calling complete() in tasklet, the URB documentation is updated to claim complete() will be run in tasklet context and local IRQs will be enabled, so that USB drivers can know the change and avoid one deadlock caused by: assume IRQs disabled in complete() and call spin_lock() to hold lock which might be acquired in interrupt context. Current spin_lock() usages in drivers' complete() will be cleaned up at the same time, and once the cleanup is finished, local IRQs will be enabled when calling complete() in tasklet. Also fix description about type of usb_complete_t, and remove the advice of running completion handler in tasklet for decreasing system latency. Cc: Oliver Neukum <oliver@neukum.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-02Merge tag 'driver-core-3.11-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg KH: "Here's the big driver core merge for 3.11-rc1 Lots of little things, and larger firmware subsystem updates, all described in the shortlog. Nice thing here is that we finally get rid of CONFIG_HOTPLUG, after 10+ years, thanks to Stephen Rohtwell (it had been always on for a number of kernel releases, now it's just removed)" * tag 'driver-core-3.11-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (27 commits) driver core: device.h: fix doc compilation warnings firmware loader: fix another compile warning with PM_SLEEP unset build some drivers only when compile-testing firmware loader: fix compile warning with PM_SLEEP set kobject: sanitize argument for format string sysfs_notify is only possible on file attributes firmware loader: simplify holding module for request_firmware firmware loader: don't export cache_firmware and uncache_firmware drivers/base: Use attribute groups to create sysfs memory files firmware loader: fix compile warning firmware loader: fix build failure with !CONFIG_FW_LOADER_USER_HELPER Documentation: Updated broken link in HOWTO Finally eradicate CONFIG_HOTPLUG driver core: firmware loader: kill FW_ACTION_NOHOTPLUG requests before suspend driver core: firmware loader: don't cache FW_ACTION_NOHOTPLUG firmware Documentation: Tidy up some drivers/base/core.c kerneldoc content. platform_device: use a macro instead of platform_driver_register firmware: move EXPORT_SYMBOL annotations firmware: Avoid deadlock of usermodehelper lock at shutdown dell_rbu: Select CONFIG_FW_LOADER_USER_HELPER explicitly ...
2013-06-17Documentation/usb: gadget_configfsAndrzej Pietrasiewicz
Add documentation for configfs-based usb gadget. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-03Finally eradicate CONFIG_HOTPLUGStephen Rothwell
Ever since commit 45f035ab9b8f ("CONFIG_HOTPLUG should be always on"), it has been basically impossible to build a kernel with CONFIG_HOTPLUG turned off. Remove all the remaining references to it. Cc: Russell King <linux@arm.linux.org.uk> Cc: Doug Thompson <dougthompson@xmission.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28USB: remove CONFIG_USB_SUSPEND from DocumentationAlan Stern
An earlier patch removed the CONFIG_USB_SUSPEND symbol but forgot to update the Documentation files. This patch (as1676) rectifies that omission. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-11USB: report submission of active URBsAlan Stern
This patch (as1633) changes slightly the way usbcore handled submissions of URBs that are already active. It will now return -EBUSY rather than -EINVAL, and it will call WARN_ONCE to draw people's attention to the bug. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-11Merge tag 'gadget-for-v3.8' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next USB gadget patches from Felipe: "usb: gadget: patches for v3.8 renesas_usbhs implements ->pullup() method, switches over to devm_request_irq(), adds support for DMA Engine and got a few miscelaneous cleanups. The NCM gadget got an endianness fix and the Ethernet gadget a frame size fix. We're finally removing the g_file_storage gadget and sticking to g_mass_storage and the new tcm_usb_gadget gadgets since that was a huge duplicaton of effort anyway. While removing g_file_storage, we also had to fix a bunch of defconfigs which were still pointing to the old gadget. There's a big series getting us closer to being able to introduce our configfs interface. The series converts functions into loadable modules which will, eventually, be registered to the configfs interface. Other than that there's the usual typo fixes and miscelaneous cleanups all over the place."
2012-11-08usb: gadget: Remove File-backed Storage Gadget (g_file_storage).Michal Nazarewicz
The File-backed Storage Gadget (g_file_storage) gadget has been replaced with Mass Storage Gadget (g_mass_storage) which uses the composite framework. This commit removes g_file_storage (and most references to it). Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-10-22USB: update documentation for URB_ISO_ASAPAlan Stern
This patch (as1611) updates the USB documentation and kerneldoc to give a more precise meaning for the URB_ISO_ASAP flag and to explain more of the details of scheduling for isochronous URBs. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10usb: add decriptor of persist fail for some morph usb devicesLan Tianyu
Some morph devices will morph after being reset and cause persist to fail. This patch is to add descriptor about this in the Document/usb/persist.txt Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-15usb: gadget: mass_storage: add documentationMichal Nazarewicz
This commit adds Documentation/usb/mass-storage.txt file. It contains description of how to use the mass storage gadget from user space. It elaborates on madule parameters and sysfs interface more then it was written in the comments in the source code. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-05-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial updates from Jiri Kosina: "As usual, it's mostly typo fixes, redundant code elimination and some documentation updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits) edac, mips: don't change code that has been removed in edac/mips tree xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer lib: Change mail address of Oskar Schirmer net: Change mail address of Oskar Schirmer arm/m68k: Change mail address of Sebastian Hess i2c: Change mail address of Oskar Schirmer net: Fix tcp_build_and_update_options comment in struct tcp_sock atomic64_32.h: fix parameter naming mismatch Kconfig: replace "--- help ---" with "---help---" c2port: fix bogus Kconfig "default no" edac: Fix spelling errors. qla1280: Remove redundant NULL check before release_firmware() call remoteproc: remove redundant NULL check before release_firmware() qla2xxx: Remove redundant NULL check before release_firmware() call. aic94xx: Get rid of redundant NULL check before release_firmware() call tehuti: delete redundant NULL check before release_firmware() qlogic: get rid of a redundant test for NULL before call to release_firmware() bna: remove redundant NULL test before release_firmware() tg3: remove redundant NULL test before release_firmware() call typhoon: get rid of redundant conditional before all to release_firmware() ...
2012-05-14FunctionFS: enable multiple functionsAndrzej Pietrasiewicz
Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Cc: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-08Merge branch 'master' into for-nextJiri Kosina
Merge with latest Linus' tree, as I have incoming patches that fix code that is newer than current HEAD of for-next. Conflicts: drivers/net/ethernet/realtek/r8169.c
2012-04-06USB documentation: explain lifetime rules for unlinking URBsAlan Stern
This patch (as1534c) updates the documentation for usb_unlink_urb and related functions. It explains that the caller must prevent the URB being unlinked from getting deallocated while the unlink is taking place. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-06usb/usbmon: correct the data interpretation of usbmon's outputSebastian Andrzej Siewior
The doc says that the data | 55534243 5e000000 00000000 00000600 00000000 00000000 00000000 000000 is the SCSI command 0x5e. According to the usbmon source, it dumps one byte after the other. The first 4 bytes are US_BULK_CB_SIGN which is correct. After that we see the TAG which is 0x5e. The cdb is 0x00 in this example. In order to correct this, I change the example to a READ_10 command which is 0x28 so it is not just a zero somewhere in the stream. Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-05doc: fix a few typosMasanari Iida
Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-03-30Documentation: remove references to /etc/modprobe.confLucas De Marchi
Usage of /etc/modprobe.conf file was deprecated by module-init-tools and is no longer parsed by new kmod tool. References to this file are replaced in Documentation, comments and Kconfig according to the context. There are also some references to the old /etc/modules.conf from 2.4 kernels that are being removed. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-21Documentation: Fix Broken URL "freshmeat"Masanari Iida
Fix broken URL in documents "freshmeat" to "freecode" in Documentation/filesystems/ramfs-rootfs-initramfs.txt, Documentation/scsi/scsi-generic.txt Documentation/usb/mtouchusb.txt Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-02-21Documentation: Fix typo in proc_usb_info.txtMasanari Iida
Correct typo "filsystem" to "filesystem" in Documentation/usb/proc_usb_info.txt Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-02-21Documentation: Fix typo in power-management.txtMasanari Iida
Correct spelling "diconnect()" to "disconnect()" in Documentation/usb/power-management.txt Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-01-04USB: update documentation for usbmonAlan Stern
The documentation for usbmon is out of date; the usbfs "devices" file now exists in /sys/kernel/debug/usb rather than /proc/bus/usb. This patch (as1505) updates the documentation accordingly, and also mentions that the necessary information can be found by running lsusb. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Pete Zaitcev <zaitcev@redhat.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-29USB: linux-cdc-acm.inf: add support for the acm_ms gadgetKlaus Schwarzkopf
Support for the acm_ms usb gadget on windows. Signed-off-by: Klaus Schwarzkopf <schwarzkopf@sensortherm.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-25Merge branch 'pm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm * 'pm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (63 commits) PM / Clocks: Remove redundant NULL checks before kfree() PM / Documentation: Update docs about suspend and CPU hotplug ACPI / PM: Add Sony VGN-FW21E to nonvs blacklist. ARM: mach-shmobile: sh7372 A4R support (v4) ARM: mach-shmobile: sh7372 A3SP support (v4) PM / Sleep: Mark devices involved in wakeup signaling during suspend PM / Hibernate: Improve performance of LZO/plain hibernation, checksum image PM / Hibernate: Do not initialize static and extern variables to 0 PM / Freezer: Make fake_signal_wake_up() wake TASK_KILLABLE tasks too PM / Hibernate: Add resumedelay kernel param in addition to resumewait MAINTAINERS: Update linux-pm list address PM / ACPI: Blacklist Vaio VGN-FW520F machine known to require acpi_sleep=nonvs PM / ACPI: Blacklist Sony Vaio known to require acpi_sleep=nonvs PM / Hibernate: Add resumewait param to support MMC-like devices as resume file PM / Hibernate: Fix typo in a kerneldoc comment PM / Hibernate: Freeze kernel threads after preallocating memory PM: Update the policy on default wakeup settings PM / VT: Cleanup #if defined uglyness and fix compile error PM / Suspend: Off by one in pm_suspend() PM / Hibernate: Include storage keys in hibernation image on s390 ...
2011-10-25Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (260 commits) usb: renesas_usbhs: fixup inconsistent return from usbhs_pkt_push() usb/isp1760: Allow to optionally trigger low-level chip reset via GPIOLIB. USB: gadget: midi: memory leak in f_midi_bind_config() USB: gadget: midi: fix range check in f_midi_out_open() QE/FHCI: fixed the CONTROL bug usb: renesas_usbhs: tidyup for smatch warnings USB: Fix USB Kconfig dependency problem on 85xx/QoirQ platforms EHCI: workaround for MosChip controller bug usb: gadget: file_storage: fix race on unloading USB: ftdi_sio.c: Use ftdi async_icount structure for TIOCMIWAIT, as in other drivers USB: ftdi_sio.c:Fill MSR fields of the ftdi async_icount structure USB: ftdi_sio.c: Fill LSR fields of the ftdi async_icount structure USB: ftdi_sio.c:Fill TX field of the ftdi async_icount structure USB: ftdi_sio.c: Fill the RX field of the ftdi async_icount structure USB: ftdi_sio.c: Basic icount infrastructure for ftdi_sio usb/isp1760: Let OF bindings depend on general CONFIG_OF instead of PPC_OF . USB: ftdi_sio: Support TI/Luminary Micro Stellaris BD-ICDI Board USB: Fix runtime wakeup on OHCI xHCI/USB: Make xHCI driver have a BOS descriptor. usb: gadget: add new usb gadget for ACM and mass storage ...
2011-10-04usb: dwc3: gadget: implement streams supportFelipe Balbi
The following patch adds support for streams to dwc3 driver. While at that, also fix one small issue on endpoint disable where we should clear all flags not only ENABLED. Reviewied-by: Paul Zimmerman <paulz@synopsys.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-09-27doc: fix broken referencesPaul Bolle
There are numerous broken references to Documentation files (in other Documentation files, in comments, etc.). These broken references are caused by typo's in the references, and by renames or removals of the Documentation files. Some broken references are simply odd. Fix these broken references, sometimes by dropping the irrelevant text they were part of. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-09-26usbcore: add sysfs support to xHCI usb2 hardware LPMAndiry Xu
This patch adds sysfs support to xHCI usb2 hardware LPM, so developer can enable and disable usb2 hardware LPM manually for test purpose. Signed-off-by: Andiry Xu <andiry.xu@amd.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22usb: Introduce DesignWare USB3 DRD DriverFelipe Balbi
The DesignWare USB3 is a highly configurable IP Core which can be instantiated as Dual-Role Device (DRD), Peripheral Only and Host Only (XHCI) configurations. Several other parameters can be configured like amount of FIFO space, amount of TX and RX endpoints, amount of Host Interrupters, etc. The current driver has been validated with a virtual model of version 1.73a of that core and with an FPGA burned with version 1.83a of the DRD core. We have support for PCIe bus, which is used on FPGA prototyping, and for the OMAP5, more adaptation (or glue) layers can be easily added and the driver is half prepared to handle any possible configuration the HW engineer has chosen considering we have the information on one of the GHWPARAMS registers to do runtime checking of certain features. More runtime checks can, and should, be added in order to make this driver even more flexible with regards to number of endpoints, FIFO sizes, transfer types, etc. While this supports only the device side, for now, we will add support for Host side (xHCI - see the updated series Sebastian has sent [1]) and OTG after we have it all stabilized. [1] http://marc.info/?l=linux-usb&m=131341992020339&w=2 Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-19PM / Runtime: Add macro to test for runtime PM eventsAlan Stern
This patch (as1482) adds a macro for testing whether or not a pm_message value represents an autosuspend or autoresume (i.e., a runtime PM) event. Encapsulating this notion seems preferable to open-coding the test all over the place. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-07-25Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (115 commits) EHCI: fix direction handling for interrupt data toggles USB: serial: add IDs for WinChipHead USB->RS232 adapter USB: OHCI: fix another regression for NVIDIA controllers usb: gadget: m66592-udc: add pullup function usb: gadget: m66592-udc: add function for external controller usb: gadget: r8a66597-udc: add pullup function usb: renesas_usbhs: support multi driver usb: renesas_usbhs: inaccessible pipe is not an error usb: renesas_usbhs: care buff alignment when dma handler USB: PL2303: correctly handle baudrates above 115200 usb: r8a66597-hcd: fixup USB_PORT_STAT_C_SUSPEND shift usb: renesas_usbhs: compile/config are rescued usb: renesas_usbhs: fixup comment-out usb: update email address in ohci-sh and r8a66597-hcd usb: r8a66597-hcd: add function for external controller EHCI: only power off port if over-current is active USB: mon: Allow to use usbmon without debugfs USB: EHCI: go back to using the system clock for QH unlinks ehci: add pci quirk for Ordissimo and RM Slate 100 too ehci: refactor pci quirk to use standard dmi_check_system method ... Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
2011-07-08USB: EHCI: Allow users to override 80% max periodic bandwidthKirill Smelkov
There are cases, when 80% max isochronous bandwidth is too limiting. For example I have two USB video capture cards which stream uncompressed video, and to stream full NTSC + PAL videos we'd need NTSC 640x480 YUV422 @30fps ~17.6 MB/s PAL 720x576 YUV422 @25fps ~19.7 MB/s isoc bandwidth. Now, due to limited alt settings in capture devices NTSC one ends up streaming with max_pkt_size=2688 and PAL with max_pkt_size=2892, both with interval=1. In terms of microframe time allocation this gives NTSC ~53us PAL ~57us and together ~110us > 100us == 80% of 125us uframe time. So those two devices can't work together simultaneously because the'd over allocate isochronous bandwidth. 80% seemed a bit arbitrary to me, and I've tried to raise it to 90% and both devices started to work together, so I though sometimes it would be a good idea for users to override hardcoded default of max 80% isoc bandwidth. After all, isn't it a user who should decide how to load the bus? If I can live with 10% or even 5% bulk bandwidth that should be ok. I'm a USB newcomer, but that 80% set in stone by USB 2.0 specification seems to be chosen pretty arbitrary to me, just to serve as a reasonable default. NOTE 1 ~~~~~~ for two streams with max_pkt_size=3072 (worst case) both time allocation would be 60us+60us=120us which is 96% periodic bandwidth leaving 4% for bulk and control. Alan Stern suggested that bulk then would be problematic (less than 300*8 bittimes left per microframe), but I think that is still enough for control traffic. NOTE 2 ~~~~~~ Sarah Sharp expressed concern that maxing out periodic bandwidth could lead to vendor-specific hardware bugs on host controllers, because > It's entirely possible that you'll run into > vendor-specific bugs if you try to pack the schedule with isochronous > transfers. I don't think any hardware designer would seriously test or > validate their hardware with a schedule that is basically a violation of > the USB bus spec (more than 80% for periodic transfers). So far I've only tested this patch on my HP Mini 5103 with N10 chipset kirr@mini:~$ lspci 00:00.0 Host bridge: Intel Corporation N10 Family DMI Bridge 00:02.0 VGA compatible controller: Intel Corporation N10 Family Integrated Graphics Controller 00:02.1 Display controller: Intel Corporation N10 Family Integrated Graphics Controller 00:1b.0 Audio device: Intel Corporation N10/ICH 7 Family High Definition Audio Controller (rev 02) 00:1c.0 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 1 (rev 02) 00:1c.3 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 4 (rev 02) 00:1d.0 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #1 (rev 02) 00:1d.1 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #2 (rev 02) 00:1d.2 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #3 (rev 02) 00:1d.3 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #4 (rev 02) 00:1d.7 USB Controller: Intel Corporation N10/ICH 7 Family USB2 EHCI Controller (rev 02) 00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2) 00:1f.0 ISA bridge: Intel Corporation NM10 Family LPC Controller (rev 02) 00:1f.2 SATA controller: Intel Corporation N10/ICH7 Family SATA AHCI Controller (rev 02) 01:00.0 Network controller: Broadcom Corporation BCM4313 802.11b/g/n Wireless LAN Controller (rev 01) 02:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8059 PCI-E Gigabit Ethernet Controller (rev 11) and the system works stable with 110us/uframe (~88%) isoc bandwith allocated for above-mentioned isochronous transfers. NOTE 3 ~~~~~~ This feature is off by default. I mean max periodic bandwidth is set to 100us/uframe by default exactly as it was before the patch. So only those of us who need the extreme settings are taking the risk - normal users who do not alter uframe_periodic_max sysfs attribute should not see any change at all. NOTE 4 ~~~~~~ I've tried to update documentation in Documentation/ABI/ thoroughly, but only "TBD" was put into Documentation/usb/ehci.txt -- the text there seems to be outdated and much needing refreshing, before it could be amended. Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Kirill Smelkov <kirr@mns.spb.ru> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-01USB: Documentation: Use correct character in gadget_hid.txtTobias Klauser
Use ASCII minus sign instead of unicode EN DASH in gadget_hid.txt. Also remove two unecessary spaces in the same file. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-17USB: Fix up URB error codes to reflect implementation.Sarah Sharp
Documentation/usb/error-codes.txt mentions that urb->status can be set to -EXDEV, if the isochronous transfer was not fully completed. However, in practice, EHCI, UHCI, and OHCI all only set -EXDEV in the individual frame status, never in the URB status. Those host controller actually always pass in a zero status to usb_hcd_giveback_urb, and rely on the core to set the appropriate status value. The xHCI driver ran into issues with the uvcvideo driver when it tried to set -EXDEV in urb->status, because the driver refused to submit URBs, and the userspace camera application's video froze. Clean up the documentation to reflect the actual implementation. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Acked-by: Alan Stern <stern@rowland.harvard.edu>
2011-05-23Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (205 commits) USB: EHCI: Remove SPARC_LEON {read,write}_be definitions from ehci.h USB: UHCI: Support big endian GRUSBHC HC sparc: add {read,write}*_be routines USB: UHCI: Add support for big endian descriptors USB: UHCI: Use ACCESS_ONCE rather than using a full compiler barrier USB: UHCI: Add support for big endian mmio usb-storage: Correct adjust_quirks to include latest flags usb/isp1760: Fix possible unlink problems usb/isp1760: Move function isp1760_endpoint_disable() within file. USB: remove remaining usages of hcd->state from usbcore and fix regression usb: musb: ux500: add configuration and build options for ux500 dma usb: musb: ux500: add dma glue layer for ux500 usb: musb: ux500: add dma name for ux500 usb: musb: ux500: add ux500 specific code for gadget side usb: musb: fix compile error usb-storage: fix up the unusual_realtek device list USB: gadget: f_audio: Fix invalid dereference of initdata EHCI: don't rescan interrupt QHs needlessly OHCI: fix regression caused by nVidia shutdown workaround USB: OTG: msm: Free VCCCX regulator even if we can't set the voltage ...
2011-04-29USB: documentation update for the pre_reset methodAlan Stern
This patch (as1459) updates the documentation for the pre_reset method in struct usb_driver. When a driver is notified of an impending reset, it must cancel all outstanding I/O and not start any new I/O until it has been notified that the reset is complete. As far as I know, most existing drivers that implement pre_reset do this now. The major exceptions appear to be the SpeedTouch and CDC-WDM drivers. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-29USB: gadget: g_multi: fixed vendor and product ID in inf filesMichal Nazarewicz
Commit 1c6529e92b "USB: gadget: g_multi: fixed vendor and product ID" replaced g_multi's vendor and product ID with proper ID's from Linux Foundation. This commit now updates INF files in the Documentation/usb directory which were omitted in the original commit. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-22HID: Move hiddev.txt to the new Documentation/hid directoryAlan Ott
With the new Documentation/hid directory, it makes sense to have hiddev.txt here as well. Signed-off-by: Alan Ott <alan@signal11.us> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-02-04USB: usbmon: fix-up docs and text API for sparse ISOPete Zaitcev
This is based on a patch that Alan Stern wrote. It did the same simple thing in both text and binary cases. In the same time, Marton and I fixed the binary side properly, but this leaves the text to be fixed. It is not very important due to low maxium data size of text, but let's add it just for extra correctness. The pseudocode is too much to keep fixed up, and we have real code to be used as examples now, so let's drop it too. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-16USB: use the runtime-PM autosuspend implementationAlan Stern
This patch (as1428) converts USB over to the new runtime-PM core autosuspend framework. One slightly awkward aspect of the conversion is that USB devices will now have two suspend-delay attributes: the old power/autosuspend file and the new power/autosuspend_delay_ms file. One expresses the delay time in seconds and the other in milliseconds, but otherwise they do the same thing. The old attribute can be deprecated and then removed eventually. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22USB: teach "devices" file about Wireless and SuperSpeed USBAlan Stern
The /sys/kernel/debug/usb/devices file doesn't know about Wireless or SuperSpeed USB. This patch (as1416b) teaches it, and updates the Documentation/usb/proc_sub_info.txt file accordingly. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Vrabel <david.vrabel@csr.com> CC: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: gadget: g_multi: added documentation and INF filesMichal Nazarewicz
A short documentation of the g_multi driver along with INF files for Windows XP SP3 are provided. Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: gadget: g_serial: INF file updatedMichal Nazarewicz
Updated the INF file for g_serial gadget. It should work with most recent Windows systems now. Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: gadget: g_ether: updated INF fileMichal Nazarewicz
Updated the INF file for the g_ether gadget. It should work with most recent Windows systems now. Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: Documentation/usb/linux.inf: Checkpatch cleanupAndrea Gelmini
Documentation/usb/linux.inf:66: ERROR: trailing whitespace Documentation/usb/linux.inf:67: ERROR: trailing whitespace Documentation/usb/linux.inf:98: ERROR: trailing whitespace Documentation/usb/linux.inf:99: ERROR: trailing whitespace Documentation/usb/linux.inf:115: ERROR: trailing whitespace Documentation/usb/linux.inf:116: ERROR: trailing whitespace Documentation/usb/linux.inf:120: ERROR: trailing whitespace Documentation/usb/linux.inf:121: ERROR: trailing whitespace Documentation/usb/linux.inf:122: ERROR: trailing whitespace Documentation/usb/linux.inf:123: ERROR: trailing whitespace Documentation/usb/linux.inf:144: ERROR: trailing whitespace Documentation/usb/linux.inf:145: ERROR: trailing whitespace Documentation/usb/linux.inf:146: ERROR: trailing whitespace Documentation/usb/linux.inf:147: ERROR: trailing whitespace Documentation/usb/linux.inf:158: ERROR: trailing whitespace Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: Documentation/usb/hotplug.txt: Checkpatch cleanupAndrea Gelmini
Documentation/usb/hotplug.txt:13: ERROR: trailing whitespace Documentation/usb/hotplug.txt:87: ERROR: trailing whitespace Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: Documentation/usb/ehci.txt: Checkpatch cleanupAndrea Gelmini
Documentation/usb/ehci.txt:12: ERROR: trailing whitespace Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (229 commits) USB: remove unused usb_buffer_alloc and usb_buffer_free macros usb: musb: update gfp/slab.h includes USB: ftdi_sio: fix legacy SIO-device header USB: kl5usb105: reimplement using generic framework USB: kl5usb105: minor clean ups USB: kl5usb105: fix memory leak USB: io_ti: use kfifo to implement write buffering USB: io_ti: remove unsused private counter USB: ti_usb: use kfifo to implement write buffering USB: ir-usb: fix incorrect write-buffer length USB: aircable: fix incorrect write-buffer length USB: safe_serial: straighten out read processing USB: safe_serial: reimplement read using generic framework USB: safe_serial: reimplement write using generic framework usb-storage: always print quirks USB: usb-storage: trivial debug improvements USB: oti6858: use port write fifo USB: oti6858: use kfifo to implement write buffering USB: cypress_m8: use kfifo to implement write buffering USB: cypress_m8: remove unused drain define ... Fix up conflicts (due to usb_buffer_alloc/free renaming) in drivers/input/tablet/acecad.c drivers/input/tablet/kbtab.c drivers/input/tablet/wacom_sys.c drivers/media/video/gspca/gspca.c sound/usb/usbaudio.c
