path: root/Documentation/usb
2016-01-31usb: core: lpm: fix usb3_hardware_lpm sysfs nodeLu Baolu
commit bf5ce5bf3cc7136fd7fe5e8999a580bc93a9c8f6 upstream. Commit 655fe4effe0f ("usbcore: add sysfs support to xHCI usb3 hardware LPM") introduced usb3_hardware_lpm sysfs node. This doesn't show the correct status of USB3 U1 and U2 LPM status. This patch fixes this by replacing usb3_hardware_lpm with two nodes, usb3_hardware_lpm_u1 (for U1) and usb3_hardware_lpm_u2 (for U2), and recording the U1/U2 LPM status in right places. This patch should be back-ported to kernels as old as 4.3, that contains Commit 655fe4effe0f ("usbcore: add sysfs support to xHCI usb3 hardware LPM"). Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-22usb: interface authorization: Documentation partStefan Koch
This part adds the documentation for the interface authorization. Signed-off-by: Stefan Koch <stefan.koch10@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-18Revert "usb: interface authorization: Documentation part"Greg Kroah-Hartman
This reverts commit 6ef2bf71764708f7c58ee9300acd8df05dbaa06f as the signed-off-by address is invalid. Cc: Stefan Koch <stefan.koch10@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-14usb: interface authorization: Documentation partStefan Koch
This part adds the documentation for the interface authorization. Signed-off-by: Stefan Koch <skoch@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-14Merge tag 'usb-for-v4.3' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next Felipe writes: usb: patches for v4.3 merge window New support for Allwinne SoC on the MUSB driver has been added to the list of glue layers. MUSB also got support for building all DMA engines in one binary; this will be great for distros. DWC3 now has no trace of dev_dbg()/dev_vdbg() usage. We will rely solely on tracing to debug DWC3. There was also a fix for memory corruption with EP0 when maxpacket size transfers are > 512 bytes. Robert's EP capabilities flags is making EP selection a lot simpler. UDCs are now required to set these flags up when adding endpoints to the framework. Other than these, we have the usual set of miscelaneous cleanups and minor fixes. Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-07-31doc: usb: gadget-testing: using the updated testusb.cPeter Chen
testusb.c at http://www.linux-usb.org/usbtest/ is out of date, using the one at the kernel source folder. Cc: <stable@vger.kernel.org> Signed-off-by: Peter Chen <peter.chen@freescale.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-07-22usbcore: add sysfs support to xHCI usb3 hardware LPMKevin Strasser
Add a sysfs node to make it easier to verify if LPM is supported and being enabled for USB 3.0 devices. Signed-off-by: Kevin Strasser <kevin.strasser@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-26Merge tag 'usb-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB updates from Greg KH: "Here's the big USB patchset for 4.2-rc1. As is normal these days, the majority of changes are in the gadget drivers, with a bunch of other small driver changes. All of these have been in linux-next with no reported issues" * tag 'usb-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (175 commits) usb: dwc3: Use ASCII space in Kconfig usb: chipidea: add work-around for Marvell HSIC PHY startup usb: chipidea: allow multiple instances to use default ci_default_pdata dt-bindings: Consolidate ChipIdea USB ci13xxx bindings phy: add Marvell HSIC 28nm PHY phy: Add Marvell USB 2.0 OTG 28nm PHY dt-bindings: Add Marvell PXA1928 USB and HSIC PHY bindings USB: ssb: use devm_kzalloc USB: ssb: fix error handling in ssb_hcd_create_pdev() usb: isp1760: check for null return from kzalloc cdc-acm: Add support of ATOL FPrint fiscal printers usb: chipidea: usbmisc_imx: Remove unneeded semicolon USB: usbtmc: add device quirk for Rigol DS6104 USB: serial: mos7840: Use setup_timer phy: twl4030-usb: add ABI documentation phy: twl4030-usb: remove incorrect pm_runtime_get_sync() in probe function. phy: twl4030-usb: remove pointless 'suspended' test in 'suspend' callback. phy: twl4030-usb: make runtime pm more reliable. drivers:usb:fsl: Fix compilation error for fsl ehci drv usb: renesas_usbhs: Don't disable the pipe if Control write status stage ...
2015-05-07usb: gadget: rndis: remove the limit of available rndis connectionsAndrzej Pietrasiewicz
RNDIS function has a limitation on the number of allowed instances. So far it has been RNDIS_MAX_CONFIGS, which happens to be one. In order to eliminate this kind of arbitrary limitation we should not preallocate a predefined (RNDIS_MAX_CONFIGS) array of struct rndis_params instances but instead allow allocating them on demand. This patch allocates struct rndis_params on demand in rndis_register(). Coversly, the structure is free()'d in rndis_deregister(). If CONFIG_USB_GADGET_DEBUG_FILES is set, the proc files are created which is the same behaviour as before, but the moment of creation is delayed until struct rndis_params is actually allocated. rnids_init() and rndis_exit() have nothing to do, so they are eliminated. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-05-07Documentation usb serial: fixed how to provide vendor and product idH. Nikolaus Schaller
While trying to test a Cinterion GSM/GPS/3G module I had reconfigured the USB interface by mistake and therefore needed to run a different USB driver than CDC-ACM. It turned out that I need the "usbserial" driver. This file is an official description how to use it: Documentation/usb/usb-serial.txt But it is outdated. The parameters vendor= and product= have been superseded by a /sys interface. Here was the solution: https://bbs.archlinux.org/viewtopic.php?id=175499 insmod usbserial vendor=0x#### product=0x#### becomes (first #### is vendor, second is product) modprobe usbserial echo #### #### >/sys/bus/usb-serial/drivers/generic/new_id This patch changes the documentation file to describe the modern variant. Please note that the old one still works (if compiled as module). Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com> Signed-off-by: Marek Belisko <marek@goldelico.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2015-04-27usb: Documentation: gadget-testing: fix parameter for capture channel maskPeter Chen
Fix the UAC2 parameter capture channel mask Signed-off-by: Peter Chen <peter.chen@freescale.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-03-24Merge tag 'usb-for-v4.1' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next Felipe writes: usb: patches for v4.1 merge window As usual, a big pile of commits. This time a total of 111 non-merge commits. Other than the usual set of cleanups and non-critical fixes, we have some interesting work for AM335x's MUSB babble recovery. Now that takes a lot less time and we don't have to Reset MUSB all the time. The printer gadget has been converted to configfs interface and the atmel udc has learned suspend/resume with wakeup. Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-03-18doc: usb: chipidea: add usb wakeup enable examplePeter Chen
Add the example for how to enable USB as system wakeup source. Signed-off-by: Peter Chen <peter.chen@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-10usb: gadget: printer: add configfs supportAndrzej Pietrasiewicz
Add support for configfs interface so that f_printer can be used as a component of usb gadgets composed with it. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-02-04Merge tag 'usb-for-v3.20' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next Felipe writes: usb: patches for v3.20 merge window Here's the big pull request for Gadgets and PHYs. It's a total of 217 non-merge commits with pretty much everything being touched. The most important bits are a ton of new documentation for almost all usb gadget functions, a new isp1760 UDC driver, several improvements to the old net2280 UDC driver, and some minor tracepoint improvements to dwc3. Other than that, a big list of minor cleanups, smaller bugfixes and new features all over the place. Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-12Documentation: usb: UVC function testingAndrzej Pietrasiewicz
Summary of how to test UVC function of USB gadget. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-12Documentation: usb: UAC2 function testingAndrzej Pietrasiewicz
Summary of how to test UAC2 function of USB gadget. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-12Documentation: usb: UAC1 function testingAndrzej Pietrasiewicz
Summary of how to test UAC1 function of USB gadget. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-12Documentation: usb: SOURCESINK function testingAndrzej Pietrasiewicz
Summary of how to test SOURCESINK function of USB gadget. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-12Documentation: usb: SERIAL function testingAndrzej Pietrasiewicz
Summary of how to test SERIAL function of USB gadget. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-12Documentation: usb: RNDIS function testingAndrzej Pietrasiewicz
Summary of how to test RNDIS function of USB gadget. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-12Documentation: usb: PHONET function testingAndrzej Pietrasiewicz
Summary of how to test PHONET function of USB gadget. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-12Documentation: usb: OBEX function testingAndrzej Pietrasiewicz
Summary of how to test OBEX function of USB gadget. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-12Documentation: usb: NCM function testingAndrzej Pietrasiewicz
Summary of how to test NCM function of USB gadget. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-12Documentation: usb: MIDI function testingAndrzej Pietrasiewicz
Summary of how to test MIDI function of USB gadget. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-12Documentation: usb: MASS STORAGE function testingAndrzej Pietrasiewicz
Summary of how to test MASS STORAGE function of USB gadget. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-12Documentation: usb: LOOPBACK function testingAndrzej Pietrasiewicz
Summary of how to test LOOPBACK function of USB gadget. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-12Documentation: usb: HID function testingAndrzej Pietrasiewicz
Summary of how to test HID function of USB gadget. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-12Documentation: usb: FFS function testingAndrzej Pietrasiewicz
Summary of how to test FFS (FunctionFS) function of USB gadget. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-12Documentation: usb: EEM function testingAndrzej Pietrasiewicz
Summary of how to test EEM function of USB gadget. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-12Documentation: usb: ECM subset function testingAndrzej Pietrasiewicz
Summary of how to test ECM subset function of USB gadget. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-12Documentation: usb: ECM function testingAndrzej Pietrasiewicz
Summary of how to test ECM function of USB gadget. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-12Documentation: usb: ACM function testingAndrzej Pietrasiewicz
The newly added file will be used to provide descriptions of how to test the functions of USB gadgets. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-12Documentation: usb: gadget_serial: update generic serial setup instructionAndrzej Pietrasiewicz
Using module parameters to specify accepted Vendor ID, Product ID is considered legacy now. Update the documentation to reflect it. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-01-09doc: usbmon: fix spelling s/unpriviledged/unprivileged/Jeremiah Mahler
Signed-off-by: Jeremiah Mahler <jmmahler@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09doc: usbmon: fix wording "be reading until"Jeremiah Mahler
The usbmon documentation uses "be reading until" which is an unusual wording. Change it to "read until it" which is more clear. Signed-off-by: Jeremiah Mahler <jmmahler@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-14Merge tag 'usb-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB updates from Greg KH: "Here's the big set of USB and PHY patches for 3.19-rc1. The normal churn in the USB gadget area is in here, as well as xhci and other individual USB driver updates. The PHY tree is also in here, as there were dependancies on the USB tree. All of these have been in linux-next" * tag 'usb-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (351 commits) arm: omap3: twl: remove usb phy init data usbip: fix error handling in stub_probe() usb: gadget: udc: missing curly braces USB: mos7720: delete some unneeded code wusb: replace memset by memzero_explicit usbip: remove unneeded structure usb: xhci: fix comment for PORT_DEV_REMOVE xhci: don't use the same variable for stopped and halted rings current TD xhci: clear extra bits from slot context when setting max exit latency xhci: cleanup finish_td function USB: adutux: NULL dereferences on disconnect usb: chipidea: fix platform_no_drv_owner.cocci warnings usb: chipidea: Fixed a few typos in comments Documentation: bindings: add doc for the USB2 ChipIdea USB driver usb: chipidea: add a usb2 driver for ci13xxx usb: chipidea: fix phy handling usb: chipidea: remove duplicate dev_set_drvdata for host_start usb: chipidea: parameter 'mode' isn't needed for hw_device_reset usb: chipidea: add controller reset API usb: chipidea: remove flag CI_HDRC_REQUIRE_TRANSCEIVER ...
2014-12-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree update from Jiri Kosina: "Usual stuff: documentation updates, printk() fixes, etc" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (24 commits) intel_ips: fix a type in error message cpufreq: cpufreq-dt: Move newline to end of error message ps3rom: fix error return code treewide: fix typo in printk and Kconfig ARM: dts: bcm63138: change "interupts" to "interrupts" Replace mentions of "list_struct" to "list_head" kernel: trace: fix printk message scsi: mpt2sas: fix ioctl in comment zbud, zswap: change module author email clocksource: Fix 'clcoksource' typo in comment arm: fix wording of "Crotex" in CONFIG_ARCH_EXYNOS3 help gpio: msm-v1: make boolean argument more obvious usb: Fix typo in usb-serial-simple.c PCI: Fix comment typo 'COMFIG_PM_OPS' powerpc: Fix comment typo 'CONIFG_8xx' powerpc: Fix comment typos 'CONFiG_ALTIVEC' clk: st: Spelling s/stucture/structure/ isci: Spelling s/stucture/structure/ usb: gadget: zero: Spelling s/infrastucture/infrastructure/ treewide: Fix company name in module descriptions ...
2014-12-04USB / PM: Drop CONFIG_PM_RUNTIME from the USB coreRafael J. Wysocki
After commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if PM_SLEEP is selected) PM_RUNTIME is always set if PM is set, so quite a few depend on CONFIG_PM (or even dropped in some cases). Replace CONFIG_PM_RUNTIME with CONFIG_PM in the USB core code and documentation. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-26Merge tag 'usb-serial-3.19-rc1' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/johan/usb-serial into usb-next Johan writes: USB-serial updates for v3.19-rc1 These changes add a new "simple" driver for Google USB-serial devices and add support for Huawei Gobi modems to qcserial. Included are also some removals of unnecessary atomic allocations and a few spelling fixes. Signed-off-by: Johan Hovold <johan@kernel.org>
2014-11-20Merge Linus' tree to be be to apply submitted patches to newer code thanJiri Kosina
current trivial.git base
2014-11-06usb: gadget: hid: add configfs supportAndrzej Pietrasiewicz
Make the hid function available for gadgets composed with configfs. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2014-10-29gadget_configfs.txt: fix spelling of 'function'Frans Klaver
Signed-off-by: Frans Klaver <frans.klaver@xsens.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-10-22USB: serial: keyspan_pda: fix Entrega company name spellingMark Knibbs
Entrega is misspelled as Entregra or Entrgra, so fix that. Signed-off-by: Mark Knibbs <markk@clara.co.uk> Signed-off-by: Johan Hovold <johan@kernel.org>
2014-09-23usb: hub: rename khubd to hub_wq in documentation and commentsPetr Mladek
USB hub has started to use a workqueue instead of kthread. Let's update the documentation and comments here and there. This patch mostly just replaces "khubd" with "hub_wq". There are only few exceptions where the whole sentence was updated. These more complicated changes can be found in the following files: Documentation/usb/hotplug.txt drivers/net/usb/usbnet.c drivers/usb/core/hcd.c drivers/usb/host/ohci-hcd.c drivers/usb/host/xhci.c Signed-off-by: Petr Mladek <pmladek@suse.cz> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-23uwb: doc: bring uwb documentation up to dateThomas Pugliese
The existing UWB documentation states that UWB devices show up in /sys/class/uwb and /sys/bus/uwb/devices. Up until the most recent changes to add uwb devices to their own bus, neither of these statements were actually true. Now, UWB devices do show up in /sys/bus/uwb/devices so the documentation has been updated to reflect that and removed references to /sys/class/uwb. The existing documentation also states that local UWB radio controller (RC) devices also show up as UWB devices along with their wireless peer UWB devices under /sys/class/uwb. This is not true so that statement has been removed. Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09usb: doc: hotplug.txt code typosJeremiah Mahler
Fixed several typos in the code examples given in Documentation/usb/hotplug.txt. - missing [] with array of struct usb_device_id - checkpatch.pl warning: space between function name and parenthesis - missing terminating ';' Signed-off-by: Jeremiah Mahler <jmmahler@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09usb: documentation for usb port power off mechanismsLan Tianyu
describe the mechanisms for controlling port power policy and discovering the port power state. [oliver]: fixes, clarification of wakeup vs port-power-control [sarah]: wordsmithing [djbw]: updates for peer port changes [alan]: review and fixes Cc: Oliver Neukum <oneukum@suse.de> Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial into next Pull trivial tree changes from Jiri Kosina: "Usual pile of patches from trivial tree that make the world go round" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits) staging: go7007: remove reference to CONFIG_KMOD aic7xxx: Remove obsolete preprocessor define of: dma: doc fixes doc: fix incorrect formula to calculate CommitLimit value doc: Note need of bc in the kernel build from 3.10 onwards mm: Fix printk typo in dmapool.c modpost: Fix comment typo "Modules.symvers" Kconfig.debug: Grammar s/addition/additional/ wimax: Spelling s/than/that/, wording s/destinatary/recipient/ aic7xxx: Spelling s/termnation/termination/ arm64: mm: Remove superfluous "the" in comment of: Spelling s/anonymouns/anonymous/ dma: imx-sdma: Spelling s/determnine/determine/ ath10k: Improve grammar in comments ath6kl: Spelling s/determnine/determine/ of: Improve grammar for of_alias_get_id() documentation drm/exynos: Spelling s/contro/control/ radio-bcm2048.c: fix wrong overflow check doc: printk-formats: do not mention casts for u64/s64 doc: spelling error changes ...
2014-05-23Doc: usb: chipidea: need to build both kernel Image and modulesPeter Chen
When tried to enable OTG FSM, we need to rebuild both kernel Image and modules, since there are some codes at gadget modules which are controlled by related configurations. Signed-off-by: Peter Chen <peter.chen@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
