commit 6e88559470f581741bcd0f2794f9054814ac9740 upstream.
Add documentation for Spectre vulnerability and the mitigation mechanisms:
- Explain the problem and risks
- Document the mitigation mechanisms
- Document the command line controls
- Document the sysfs files
Co-developed-by: Andi Kleen <ak@linux.intel.com>
Co-developed-by: Tim Chen <tim.c.chen@linux.intel.com>
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Reviewed-by: Randy Dunlap <rdunlap@infradead.org>
Cc: stable@vger.kernel.org
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
commit 9137bb27e60e554dab694eafa4cca241fa3a694f upstream
Add the PR_SPEC_INDIRECT_BRANCH option for the PR_GET_SPECULATION_CTRL and
PR_SET_SPECULATION_CTRL prctls to allow fine grained per task control of
indirect branch speculation via STIBP and IBPB.
Invocations:
Check indirect branch speculation status with
- prctl(PR_GET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, 0, 0, 0);
Enable indirect branch speculation with
- prctl(PR_SET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, PR_SPEC_ENABLE, 0, 0);
Disable indirect branch speculation with
- prctl(PR_SET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, PR_SPEC_DISABLE, 0, 0);
Force disable indirect branch speculation with
- prctl(PR_SET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, PR_SPEC_FORCE_DISABLE, 0, 0);
See Documentation/userspace-api/spec_ctrl.rst.
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: David Woodhouse <dwmw@amazon.co.uk>
Cc: Casey Schaufler <casey.schaufler@intel.com>
Cc: Asit Mallick <asit.k.mallick@intel.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Jon Masters <jcm@redhat.com>
Cc: Waiman Long <longman9394@gmail.com>
Cc: Greg KH <gregkh@linuxfoundation.org>
Cc: Dave Stewart <david.c.stewart@intel.com>
Link: https://lkml.kernel.org/r/20181125185005.866780996@linutronix.de
commit dd0792699c4058e63c0715d9a7c2d40226fcdddc upstream
Fix some typos, improve formulations, end sentences with a fullstop.
commit 356e4bfff2c5489e016fdb925adbf12a1e3950ee upstream
For certain use cases it is desired to enforce mitigations so they cannot
be undone afterwards. That's important for loader stubs which want to
prevent a child from disabling the mitigation again. Will also be used for
seccomp(). The extra state preserving of the prctl state for SSB is a
preparatory step for EBPF dymanic speculation control.
commit b617cfc858161140d69cc0b5cc211996b557a1c7 upstream
Add two new prctls to control aspects of speculation related vulnerabilites
and their mitigations to provide finer grained control over performance
impacting mitigations.
PR_GET_SPECULATION_CTRL returns the state of the speculation misfeature
which is selected with arg2 of prctl(2). The return value uses bit 0-2 with
the following meaning:
Bit Define Description
0 PR_SPEC_PRCTL Mitigation can be controlled per task by
1 PR_SPEC_ENABLE The speculation feature is enabled, mitigation is
disabled
2 PR_SPEC_DISABLE The speculation feature is disabled, mitigation is
enabled
If all bits are 0 the CPU is not affected by the speculation misfeature.
If PR_SPEC_PRCTL is set, then the per task control of the mitigation is
available. If not set, prctl(PR_SET_SPECULATION_CTRL) for the speculation
misfeature will fail.
PR_SET_SPECULATION_CTRL allows to control the speculation misfeature, which
is selected by arg2 of prctl(2) per task. arg3 is used to hand in the
control value, i.e. either PR_SPEC_ENABLE or PR_SPEC_DISABLE.
The common return values are:
EINVAL prctl is not implemented by the architecture or the unused prctl()
arguments are not 0
ENODEV arg2 is selecting a not supported speculation misfeature
PR_SET_SPECULATION_CTRL has these additional return values:
ERANGE arg3 is incorrect, i.e. it's not either PR_SPEC_ENABLE or PR_SPEC_DISABLE
ENXIO prctl control of the selected speculation misfeature is disabled
The first supported controlable speculation misfeature is
PR_SPEC_STORE_BYPASS. Add the define so this can be shared between
architectures.
Based on an initial patch from Tim Chen and mostly rewritten.
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
