commit 6e88559470f581741bcd0f2794f9054814ac9740 upstream.
Add documentation for Spectre vulnerability and the mitigation mechanisms:
- Explain the problem and risks
- Document the mitigation mechanisms
- Document the command line controls
- Document the sysfs files
Co-developed-by: Andi Kleen <ak@linux.intel.com>
Co-developed-by: Tim Chen <tim.c.chen@linux.intel.com>
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Reviewed-by: Randy Dunlap <rdunlap@infradead.org>
Cc: stable@vger.kernel.org
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
commit 9137bb27e60e554dab694eafa4cca241fa3a694f upstream
Add the PR_SPEC_INDIRECT_BRANCH option for the PR_GET_SPECULATION_CTRL and
PR_SET_SPECULATION_CTRL prctls to allow fine grained per task control of
indirect branch speculation via STIBP and IBPB.
Invocations:
Check indirect branch speculation status with
- prctl(PR_GET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, 0, 0, 0);
Enable indirect branch speculation with
- prctl(PR_SET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, PR_SPEC_ENABLE, 0, 0);
Disable indirect branch speculation with
- prctl(PR_SET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, PR_SPEC_DISABLE, 0, 0);
Force disable indirect branch speculation with
- prctl(PR_SET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, PR_SPEC_FORCE_DISABLE, 0, 0);
See Documentation/userspace-api/spec_ctrl.rst.
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: David Woodhouse <dwmw@amazon.co.uk>
Cc: Casey Schaufler <casey.schaufler@intel.com>
Cc: Asit Mallick <asit.k.mallick@intel.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Jon Masters <jcm@redhat.com>
Cc: Waiman Long <longman9394@gmail.com>
Cc: Greg KH <gregkh@linuxfoundation.org>
Cc: Dave Stewart <david.c.stewart@intel.com>
Link: https://lkml.kernel.org/r/20181125185005.866780996@linutronix.de
commit dd0792699c4058e63c0715d9a7c2d40226fcdddc upstream
Fix some typos, improve formulations, end sentences with a fullstop.
commit 356e4bfff2c5489e016fdb925adbf12a1e3950ee upstream
For certain use cases it is desired to enforce mitigations so they cannot
be undone afterwards. That's important for loader stubs which want to
prevent a child from disabling the mitigation again. Will also be used for
seccomp(). The extra state preserving of the prctl state for SSB is a
preparatory step for EBPF dymanic speculation control.
commit b617cfc858161140d69cc0b5cc211996b557a1c7 upstream
Add two new prctls to control aspects of speculation related vulnerabilites
and their mitigations to provide finer grained control over performance
impacting mitigations.
PR_GET_SPECULATION_CTRL returns the state of the speculation misfeature
which is selected with arg2 of prctl(2). The return value uses bit 0-2 with
the following meaning:
Bit Define Description
0 PR_SPEC_PRCTL Mitigation can be controlled per task by
1 PR_SPEC_ENABLE The speculation feature is enabled, mitigation is
disabled
2 PR_SPEC_DISABLE The speculation feature is disabled, mitigation is
enabled
If all bits are 0 the CPU is not affected by the speculation misfeature.
If PR_SPEC_PRCTL is set, then the per task control of the mitigation is
available. If not set, prctl(PR_SET_SPECULATION_CTRL) for the speculation
misfeature will fail.
PR_SET_SPECULATION_CTRL allows to control the speculation misfeature, which
is selected by arg2 of prctl(2) per task. arg3 is used to hand in the
control value, i.e. either PR_SPEC_ENABLE or PR_SPEC_DISABLE.
The common return values are:
EINVAL prctl is not implemented by the architecture or the unused prctl()
arguments are not 0
ENODEV arg2 is selecting a not supported speculation misfeature
PR_SET_SPECULATION_CTRL has these additional return values:
ERANGE arg3 is incorrect, i.e. it's not either PR_SPEC_ENABLE or PR_SPEC_DISABLE
ENXIO prctl control of the selected speculation misfeature is disabled
The first supported controlable speculation misfeature is
PR_SPEC_STORE_BYPASS. Add the define so this can be shared between
architectures.
Based on an initial patch from Tim Chen and mostly rewritten.
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Right now, SECCOMP_RET_KILL_THREAD (neƩ SECCOMP_RET_KILL) kills the
current thread. There have been a few requests for this to kill the entire
process (the thread group). This cannot be just changed (discovered when
adding coredump support since coredumping kills the entire process)
because there are userspace programs depending on the thread-kill
behavior.
Instead, implement SECCOMP_RET_KILL_PROCESS, which is 0x80000000, and can
be processed as "-1" by the kernel, below the existing RET_KILL that is
ABI-set to "0". For userspace, SECCOMP_RET_ACTION_FULL is added to expand
the mask to the signed bit. Old userspace using the SECCOMP_RET_ACTION
mask will see SECCOMP_RET_KILL_PROCESS as 0 still, but this would only
be visible when examining the siginfo in a core dump from a RET_KILL_*,
where it will think it was thread-killed instead of process-killed.
Attempts to introduce this behavior via other ways (filter flags,
seccomp struct flags, masked RET_DATA bits) all come with weird
side-effects and baggage. This change preserves the central behavioral
expectations of the seccomp filter engine without putting too great
a burden on changes needed in userspace to use the new action.
The new action is discoverable by userspace through either the new
actions_avail sysctl or through the SECCOMP_GET_ACTION_AVAIL seccomp
operation. If used without checking for availability, old kernels
will treat RET_KILL_PROCESS as RET_KILL_THREAD (since the old mask
will produce RET_KILL_THREAD).
Cc: Paul Moore <paul@paul-moore.com>
Cc: Fabricio Voznika <fvoznika@google.com>
In preparation for adding SECCOMP_RET_KILL_PROCESS, rename SECCOMP_RET_KILL
to the more accurate SECCOMP_RET_KILL_THREAD.
The existing selftest values are intentionally left as SECCOMP_RET_KILL
just to be sure we're exercising the alias.
Add a new action, SECCOMP_RET_LOG, that logs a syscall before allowing
the syscall. At the implementation level, this action is identical to
the existing SECCOMP_RET_ALLOW action. However, it can be very useful when
initially developing a seccomp filter for an application. The developer
can set the default action to be SECCOMP_RET_LOG, maybe mark any
obviously needed syscalls with SECCOMP_RET_ALLOW, and then put the
application through its paces. A list of syscalls that triggered the
default action (SECCOMP_RET_LOG) can be easily gleaned from the logs and
that list can be used to build the syscall whitelist. Finally, the
developer can change the default action to the desired value.
This provides a more friendly experience than seeing the application get
killed, then updating the filter and rebuilding the app, seeing the
application get killed due to a different syscall, then updating the
filter and rebuilding the app, etc.
The functionality is similar to what's supported by the various LSMs.
SELinux has permissive mode, AppArmor has complain mode, SMACK has
bring-up mode, etc.
SECCOMP_RET_LOG is given a lower value than SECCOMP_RET_ALLOW as allow
while logging is slightly more restrictive than quietly allowing.
Unfortunately, the tests added for SECCOMP_RET_LOG are not capable of
inspecting the audit log to verify that the syscall was logged.
With this patch, the logic for deciding if an action will be logged is:
if action == RET_ALLOW:
do not log
else if action == RET_KILL && RET_KILL in actions_logged:
log
else if action == RET_LOG && RET_LOG in actions_logged:
log
else if filter-requests-logging && action in actions_logged:
log
else if audit_enabled && process-is-being-audited:
log
else:
do not log
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
Adminstrators can write to this sysctl to set the seccomp actions that
are allowed to be logged. Any actions not found in this sysctl will not
be logged.
For example, all SECCOMP_RET_KILL, SECCOMP_RET_TRAP, and
SECCOMP_RET_ERRNO actions would be loggable if "kill trap errno" were
written to the sysctl. SECCOMP_RET_TRACE actions would not be logged
since its string representation ("trace") wasn't present in the sysctl
value.
The path to the sysctl is:
/proc/sys/kernel/seccomp/actions_logged
The actions_avail sysctl can be read to discover the valid action names
that can be written to the actions_logged sysctl with the exception of
"allow". SECCOMP_RET_ALLOW actions cannot be configured for logging.
The default setting for the sysctl is to allow all actions to be logged
except SECCOMP_RET_ALLOW. While only SECCOMP_RET_KILL actions are
currently logged, an upcoming patch will allow applications to request
additional actions to be logged.
There's one important exception to this sysctl. If a task is
specifically being audited, meaning that an audit context has been
allocated for the task, seccomp will log all actions other than
SECCOMP_RET_ALLOW despite the value of actions_logged. This exception
preserves the existing auditing behavior of tasks with an allocated
audit context.
do not log
log
else if audit_enabled && task-is-being-audited:
log
else:
do not log
This patch creates a read-only sysctl containing an ordered list of
seccomp actions that the kernel supports. The ordering, from left to
right, is the lowest action value (kill) to the highest action value
(allow). Currently, a read of the sysctl file would return "kill trap
errno trace allow". The contents of this sysctl file can be useful for
userspace code as well as the system administrator.
/proc/sys/kernel/seccomp/actions_avail
libseccomp and other userspace code can easily determine which actions
the current kernel supports. The set of actions supported by the current
kernel may be different than the set of action macros found in kernel
headers that were installed where the userspace code was built.
In addition, this sysctl will allow system administrators to know which
actions are supported by the kernel and make it easier to configure
exactly what seccomp logs through the audit subsystem. Support for this
level of logging configuration will come in a future patch.
This updates no_new_privs documentation to ReST markup and adds it to
the user-space API documentation.
This updates seccomp_filter.txt for ReST markup, and moves it under the
user-space API index, since it describes how application author can use
seccomp.
The asterisk of the pointer is interpreted as a start tag for inline
emphasis. Asterisks which are not Sphinx markup need to be quoted in
rst-files. This fixes the Sphinx warning:
Documentation/userspace-api/unshare.rst:108: WARNING: Inline emphasis start-string without end-string.
Signed-off-by: Markus Heiser <markus.heiser@darmarit.de>
This is a straightforward conversion, without any real textual changes.
Since this document has seen no substantive changes since its addition in
2006, some such changes are probably warranted.
This is meant to be the place for documentation relevant to application
developers. It's empty for the moment, but at least we have a place now!
