path: root/Documentation/video4linux/CARDLIST.cx88
2008-06-05V4L/DVB (7990): Fix entry for PowerColor RA 330 and make it run with ↵Daniel Gimpelevich
firmware version 2.7 Signed-off-by: Daniel Gimpelevich <daniel@gimpelevich.san-francisco.ca.us> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7448): Add support for Kworld ATSC 120Mauro Carvalho Chehab
This board has a s5h1409 demod, plus a xc30x8 tuner (probably, xc3018). This patch adds proper support for radio, video, s-video, composite and ATSC. However, support for radio and video depends on having s5h1409 i2c gate open, otherwise, xc30x8 chip won't be visible. For a better support, some rework is needed on cx88 driver, to allow adding xc30x8 to i2c bus without sending i2c 0 byte reading to 0xc2 address. Thanks to Vanessa Ezekowitz <vanessaezekowitz@gmail.com> for helping to figure out the proper parameters for s5h1409 and the GPIO pins used by each configuration. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7370): Add basic support for Prolink Pixelview MPEG 8000GTMauro Carvalho Chehab
TV reception ok. S-video and Composite not tested. Audio not tested. IR not implemented yet. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7288): cx88: fix GPIO for FusionHDTV 7 Gold input selectionMichael Krufky
Fix GPIO for FusionHDTV 7 Gold tv / s-video / composite input selection. Fix card textual name to match other FusionHDTV device names. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7287): cx88: add analog support for DVICO FusionHDTV7 GoldSteven Toth
Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7258): Support DVB-T tuning on the DViCO FusionHDTV DVB-T ProChris Pascoe
Add support for tuning DVB-T channels on DViCO's FusionHDTV DVB-T Pro board. The IR remote and analog tuner are not supported at this time. Some changes made by Mauro Chehab to allow merging it with some other xc3028 patches. Signed-off-by: Chris Pascoe <c.pascoe@itee.uq.edu.au> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7257): cx88: Add xc2028/3028 boardsMauro Carvalho Chehab
This patch ports a patch from Markus Rechberger to work with tuner-xc2028. It adds entries for several cx88 boards with xc2038/3028 tuners. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7254): cx88: fix FusionHDTV 5 PCI nano name and enable IR supportMichael Krufky
load ir-kbd-i2c for IR remote control support on DViCO FusionHDTV 5 PCI nano Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7252): cx88: Add support for the Dvico PCI NanoSteven Toth
ATSC is known to work. SVideo / Composite should work (I have no cable to test). Analog tuner support does not work. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (7043): New card supported(partially): Pinnacle 800iSteven Toth
From Zhang: This patch continues the support for the Pinnacle HD 800i. Patch committed as-is, cleanups to follow ... Steve Signed-off-by: Chaogui Zhang <czhang1974@gmail.com> Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5685): Cx88: add support for ADS Tech Instant Video PCIDaniel Gimpelevich
Signed-off-by: Daniel Gimpelevich <daniel@gimpelevich.san-francisco.ca.us> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5431): Cx88: autodetect ADS Tech InstantTV DVB-SMichael Krufky
The ADS Tech InstantTV DVB-S is a clone of the KWorld DVB-S 100. This patch adds autodetection support for this card based on pci subsystem id. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4841): Added a newer PCI ID to CARDLIST.cx88Mauro Carvalho Chehab
2006-10-14V4L/DVB (4692): Add WinTV-HVR3000 DVB-T supportSteven Toth
The WinTV-HVR3000 is currently defined for analog support only. This patch adds full DVB-T support. (DVB-S support will be added soon) Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-03V4L/DVB (4689): Adding support for Nova-T-PCI PCI ID 0070:9000Steven Toth
Adding support for Nova-T-PCI PCI ID 0070:9000 Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-03V4L/DVB (4669): Cx88: autodetect Club3D Zap TV2100 by subsystem id 12ab:2300Michael Krufky
The Club3D Zap TV2100 has been reported to be a clone of the Yuan PG300 and KWorld/VStream XPert DVB-T with cx22702 Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4641): Trivial: use lowercase letters in hex subsystem idsMichael Krufky
2006-09-26V4L/DVB (4639): Cx88: add autodetection for alternate revision of Leadtek PVRMichael Krufky
Add autodetection for PCI subsystem ID 107d:6632, to detect as a Leadtek PVR 2000 Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4638): Basic DVB-T and analog TV support for the HVR1300.Steven Toth
This is the first in a series of patches to add full WinTV-HVR1300 support to Linux. This first patch will enable analog TV support and DVB-T support. Later patches will add the hardware MPEG encoder support. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4362): Cx88: Shenzhen Tungsten Ages Tech TE-DTV-250 / Swann PCI TV ↵David Bussenschutt
Tuner card support Add support for Shenzhen Tungsten Ages Tech TE-DTV-250 OEM for Swann PCI TV Tuner Card Signed-off-by: David Bussenschutt <buzz@oska.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4361): Cx88: add support for Norwood PCI TV Tuner (non-pro)Peter Naulls
This patch adds support for Norwood PCI TV Tuner (non-pro) Signed-off-by: Peter Naulls <peter@chocky.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4360): Cx88: add autodetection support for AverMedia M150-DMichael Krufky
This patch adds autodetection support for the AverMedia M150-D blackbird MPEG encoder / analog video capture card. This board is known to work with the ASUS PVR 416 configuration. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4359): Cx88: add initial support for Hauppauge HVR3000 trimode cardEric Thomas
add initial support for Hauppauge WinTV-HVR3000 TriMode Analog/DVB-S/DVB-T only analog is working for now Signed-off-by: Eric Thomas <ethomas@claranet.fr> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-30V4L/DVB (4285): Cx88: add support for Geniatech Digistar / Digiwave 103gSaqeb Akhter
This patch adds support for the Geniatech Digistar, aka Digiwave 103g DVB-S card. Acked-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Saqeb Akhter <johoja@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4144): Cx88: add support for FusionHDTV 3 Gold (original revision)Michael Krufky
Add support for FusionHDTV 3 Gold (original revision), using the card definition for FusionHDTV3 Gold-Q Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4088): Fixes for card cx88 #50Ricardo Cerqueira
The description of the card has been updated to it's full name/model. The tuner has also been switched to a more compatible one (radio wasn't working, now it is) Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4056): Cx88: Add basic support for Leadtek Winfast DTV2000H cardMalcolm Valentine
Add DVB-T and PAL-G television support for Winfast DTV2000H Signed-off-by: Malcolm Valentine <farkit@iinet.net.au> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4038): New cx88 card #50: NPG Tech RealTVRicardo Cerqueira
Added support for a new cx88 card, including it's remote Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4016): Cx88-blackbird: add support for ProLink Pixelview Playtv@P7000Angelo Marconi
- Add support for ProLink Pixelview Playtv@P7000 Raw video and MPEG encoded video confirmed to work properly. SVideo, Composite and FM inputs are untested - disabled for now. Signed-off-by: Angelo Marconi <am@massalombarda.net> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3991): Cx88: add autodetection for another Twinhan VP-3054 board.Michael Krufky
Added autodetection for PCI subsystem id 1822:0019 to use the card definition for CX88_BOARD_DNTV_LIVE_DVB_T_PRO Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3800): Cx88: added support for KWorld MCE 200 DeluxeValentin Zagura
This patch adds support for KWorld MCE 200 Deluxe. Raw video is working perfectly, MPEG capture using cx88-blackbird is also working, but the quality could be improved. svideo and radio until they can be tested also. Signed-off-by: Valentin Zagura <puthre@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3735): Add support for pcHDTV HD5500 ATSC/QAMRusty Scott
Added card definitions for the pcHDTV HD5500 ATSC/QAM card Signed-off-by: Rusty Scott <rustys@ieee.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-08V4L/DVB (3408): DViCO FusionHDTV DVB-T Hybrid and ZL10353-based FusionHDTV ↵Chris Pascoe
DVB-T Plus support Add support for the FE6600 tuner used on the DVB-T Hybrid board. Add support for the Zarlink ZL10353 DVB-T demodulator, which supersedes the MT352, used on the DViCO FusionHDTV DVB-T Hybrid and later model Plus boards. Signed-off-by: Chris Pascoe <c.pascoe@itee.uq.edu.au> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-02-07V4L/DVB (3316): Add initial support for KWorld HardwareMpegTV XPertMichael Krufky
- Add initial support for KWorld HardwareMpegTV XPert. - uses silicon tuner: tda8290 + tda8275 - standard video using cx88 broadcast decoder is working. - blackbird mpeg encoder support (cx23416) not yet working. - FM radio untested. - audio is only working correctly in television mode, all other modes disabled. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-22V4L/DVB (3392): Add PCI ID for DigitalNow DVB-T Dual, rebranded DViCO ↵Michael Krufky
FusionHDTV DVB-T Dual. - Add PCI ID for DigitalNow DVB-T Dual, rebranded DViCO FusionHDTV DVB-T Dual. Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-12V4L/DVB (3349): Add PCI ID for UltraView DVB-T Plus, rebranded DViCO ↵Michael Krufky
FusionHDTV DVB-T Plus - Add PCI ID for UltraView DVB-T Plus,rebranded DViCO FusionHDTV DVB-T Plus Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09V4L/DVB (3311): DViCO FusionHDTV DVB-T Dual Digital PCI supportChris Pascoe
- Support for DVB reception on the PCI half of the DViCO DVB-T Dual Digital. Signed-off-by: Chris Pascoe <c.pascoe@itee.uq.edu.au> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3294): Add Kworld/Vstream Xpert DVB-T card with cx22702 tuner.Manenti Marco
- Add Kworld/Vstream Xpert DVB-T card with cx22702 tuner. Signed-off-by: Manenti Marco <marco_manenti@colman.it> Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3220): Add support for VP-3054 HDTV boardChris Pascoe
- Added support for VP-3054 (aka DigitalNow DNTV Live! DVB-T Pro!). - This board has a secondary I2C bus and remote control. - Added a new module to handle secondary I2C bus on this board. Signed-off-by: Chris Pascoe <c.pascoe@itee.uq.edu.au> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3092): Add support for another Nova-T-PCI PCI subdevice 0x9001Steven Toth
- Add support for another Nova-T-PCI PCI subdevice 0x9001 Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3089): Adding support for the Hauppauge HVR1100 and HVR1100-LP ↵Steven Toth
products. - Add support for the Hauppauge HVR1100 and HVR1100-LP products. - Add i2c_gate_ctrl callback function to dvb_frontend_ops struct. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L (1007): Add support for KWorld DVB-S 100Vadim Catana
- Add support for KWorld DVB-S 100, based on the same chips as Hauppauge Nova-S Plus (CX23883/CX24123/CX24109), without the Intersil ISL6421, which is used for LNB control. - LNB voltage and tone are controled by LNBDC and LNBTone bits from register 0x29 of the CX24123 demodulator. - The MO_GP0_IO register from CX23883 is used to turn LNB power on and off. Signed-off-by: Vadim Catana <skystar@moldova.cc> Acked-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L (0990): Enable IR support for the Nova-S-PlusSteven Toth
- Enable IR support for the Nova-S-Plus. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L (0979): Added V4L support for the Nova-S-Plus and Nova-SE2 DVB-S productsSteven Toth
- Added V4L support for the Nova-S-Plus and Nova-SE2 DVB-S products. - Basic DVB-S support is working, analog video inputs work. - It has one or two fixme comments, primarily analog GPIOs (audio) and eeprom parsing. - CX24123 code (in cx88-dvb.c) disabled until the - cx24123 module is added to dvb-kernel cvs. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-11-09[PATCH] v4l: 895: new avermedia 303 card without radioLubomir Bulej
- New Avermedia 303 card (without radio). Signed-off-by: Lubomir Bulej <bulej@nenya.ms.mff.cuni.cz> Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 766: add dvb card winfast dtv1000-tDavid Shirley
- Add DVB card WinFast DTV1000-T Signed-off-by: David Shirley <David.Shirley@team.telstra.com> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 712: added analog support for ati hdtv wonderKirk Lapray
- Added analog support for ATI HDTV Wonder Signed-off-by: Kirk Lapray <kirk.lapray@gmail.com> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 711: changed pll 1 to pll pll 28Michael Krufky
- Changed { .pll = 1, } to { .pll = PLL_28, } Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 689: cx88 cardlist updated now it also includes pci subsystem idsMauro Carvalho Chehab
- Cx88 cardlist updated. Now, it also includes PCI subsystem IDs. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 628: added new avermedia card 550Nickolay V. Shmyrev
- Added new Avermedia card 550 Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
