There's one missing USB ID at the card list. Add it.
This is an hybrid board. However, for analog, it requires
a new driver for saa7136. So, for now, let's just add
support for Digital TV.
Add the new DRX-K based devices there.
As reported by Andreas Oberritter <obi@linuxtv.org>, changeset
33ba28eebc3e1758e6adc1fcec9e1e3151bac453 did the wrong thing.
Fix it to properly reflect the entries for Terratec H5 revs 1 and 2,
and restore Terratec XS entry.
Re-run the cardlist script, in order to update the cardlists
for a few drivers, to sync with the driver changes.
Several cardlist entries are missed. Fix them by running some
script magic (about the same scripts we used to have at -hg tree).
Given how PCTV has multiple products with the same model name, include the
model number in the description and #define to make it a little more clear.
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
PS.: The cardlists are auto-generated via scripts.
This device uses an em2874B + Sharp 921 One Seg frontend.
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
This patch allows this device successfully to show video, at least from
its composite input.
I have no information about the true hardware contents of this device and so
this patch is based solely on fiddling with things until it worked. The
chip appears to be em2860, and the closest device with equivalent inputs
is the Typhoon DVD Maker. Copying the settings for that device appears
to do the trick. That's what this patch does.
[mchehab@redhat.com: update CARDLIST.em28xx accordingly, via script]
Signed-off-by: Adrian Taylor <adrian.taylor@realvnc.com>
Reviewed-by: Jarod Wilson <jarod@redhat.com>
This adds support for the KWorld PlusTV 340U and KWorld UB345-Q ATSC
sticks, which are really the same device. The sticks have an eMPIA
em2870 usb bridge chipset, an LG Electronics LGDT3304 ATSC/QAM
demodulator and an NXP TDA18271HD tuner -- early versions of the 340U
have a a TDA18271HD/C1, later models and the UB435-Q have a C2.
The stick has been tested succesfully with both VSB_8 and QAM_256 signals.
Its using lgdt3304 support added to the lgdt3305 driver by a prior patch,
rather than the current lgdt3304 driver, as its severely lacking in
functionality by comparison (see said patch for details).
Signed-off-by: Jarod Wilson <jarod@redhat.com>
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com>
Add support for design which has an em2863/tvp5150 and uses the standard
empia USB ID. In Sander's case, it was branded as an "Eminent model EM3705"
Thanks to Sander Van Ginkel for testing and help debugging the support.
[mchehab@redhat.com: move it to a vague card number slot (card=29)]
There are some missing entries there
Adds support to VC211A em2800 card. As this board doesn't have eeprom,
and uses a common set of i2c address, it has no way to add any
autodetection for it.
The patch were tested by me and by Raimundo on his board. Thanks to
those tests, several bugs related to em2800 support were corrected.
for producing the usbsnoop dump, used to get the gpio's and allowing me
to remotelly access his machine and to the needed tests.
Thanks-to: Raimundo Eduvirgnes de Oliveira <eduvirgens@yahoo.com.br>
Seems that the reference design used for the KWorld 2800d switched from the
em2860 to em2862, so we need to add the new USB id (and the i2c hash remains
so all we need is the default em2862 id.
Thanks to Ian Young for reporting the issue and testing the fix.
Cc: Ian Young <ian@duffrecords.com>
Support for Reddo DVB-C USB TV Box device. Remote is not working yet.
Thanks to Benjamin Larsson <banan@ludd.ltu.se>
Cc: Benjamin Larsson <banan@ludd.ltu.se>
Signed-off-by: Antti Palosaari <crope@iki.fi>
Added Kworld DVD Maker 2
Thanks to C Western <l@c-m-w.me.uk> for reporting this board.
[mchehab@redhat.com: Fix a few wrong IR keymaps]
Signed-off-by: Shine Liu <shinel@foxmail.com>
em28xx: Add support for Gadmei UTV330+
Signed-off-by: Zhenyu Wang <zhen78@gmail.com>
Thanks to hermann pitton <hermann-pitton@arcor.de> for pointing this new
variation.
Tested-by: hermann pitton <hermann-pitton@arcor.de>
Webcams in general don't have eeprom. So, the sensor hint code should be
called to properly detect what sensor is inside.
This webcam uses a em2710 chipset, that identifies itself as em2820,
plus a mt9v011 sensor, and a DY-301P lens.
It needs a few different initializations than a normal em28xx device.
Thanks to Hans de Goede <hdegoede@redhat.com> and Douglas Landgraf
<dougsland@redhat.com> for providing the acces for the webcam during
this weekend, I could make a patch for it while returning back from
FISL/Fudcom LATAM 2009.
Add support for the EVGA inDtube. Both ATSC and analog side validated as
fully functional.
Thanks to Jake Crimmins from EVGA for providing the correct GPIO info.
Thanks to Alan Hagge for doing all the device testing.
Thanks to Greg Williamson for providing hardware for testing.
Cc: Jake Crimmins <jcrimmins@evga.com>
Cc: Alan Hagge <ahagge@gmail.com>
Cc: Greg Williamson <cheeseboy16@gmail.com>
Added an entry for Kworld 315 (for while, dvb only)
Signed-off-by: Franklin Meng <fmeng2002@yahoo.com>
Make the KWorld 2800d work properly. In this case, that means making the
profile more generic so that it works for both the Pointnix Intra-Oral USB
camera and the KWorld device.
The device provides the audio through a pass-thru cable, so we don't need
an actual audio capture profile (neither the K-World device nor the Pointnix
have an onboard audio decoder).
Thanks to Paul Thomas for providing sample hardware.
Cc: Paul Thomas <pthomas8589@gmail.com>
videobuf_dma_map/unmap
Change kmalloc()/kfree() to vmalloc()/vfree() for sglist allocation
during videobuf_dma_map() and videobuf_dma_unmap()
High resolution sensors might require too many contiguous pages
to be allocated for sglist by kmalloc() during videobuf_dma_map()
(i.e. 256Kib for 8MP sensor).
In such situations, kmalloc() could face some problem to find the
required free memory. vmalloc() is a safer solution instead, as the
allocated memory does not need to be contiguous.
Signed-off-by: David Cohen <david.cohen@nokia.com>
Added EmpireTV entry.
Thanks to Xwang <xwang1976@email.it> to provide data for this board.
Added usb vendor/product id for Kaiser Baas Video to DVD maker.
Thanks to Trevor Campbell <tca42186@bigpond.net.au> for providing all data and tests needed to add this card to em28xx driver.
Added SIIG AVTuner-PVR to the right entry.
Removed EM2821_BOARD_PROLINK_PLAYTV_USB2 entry.
This entry has a incorrect tuner set.
description
Added board Pinnacle Dazzle Video Creator Plus DVC107 to name description field.
chipset
[dougsland@redhat.com: Fixed CodingStyle]
Signed-off-by: Indika Katugampala <indika_20012001@yahoo.co.jp>
Added DVC 101 model to Pinnacle Dazzle description
Thanks to Peter Senna Tschudin <peter.senna@gmail.com> for borrow me one
of those devices.
of those devices.
Added entry for GADMEI TVR200.
Thanks to Yohanes Nugroho <yohanes@gmail.com> for testing and data collection.
profile
The Pinnacle 80e cannot be supported since Micronas yanked their driver
support for the drx-j chipset at the last minute. Remove the device profile
since it cannot work without the drx driver and it being there is only likely
to confuse people into thinking the device is supported but not working.
Signed-off-by: Devin Heitmueller <dheitmueller@linuxtv.org>
The DVC 100 profile is redundant since we already have an existing identical
profile named "Pinnacle Dazzle DVC 90/DVC 100"
Added board PixelView PlayTV Box 4
Thanks to Vildenei Negrao Pereira <neodarkaman@brturbo.com.br> for testing and data collection.
Prolink PlayTV USB2
Don't operate under the assumption that every device that uses the em2820
default USB ID is a Prolink PlayTV USB. We have an eeprom hash, so use that,
since otherwise we cannot support other devices with the 2820 default USB ID
(such as the ADS Tech Instant TV USB USBAV-704)
Added specific entry for WinTV-HVR 850
Signed-off-by: Douglas Schilling Landgraf <dougsland@linuxtv.org>
Add registration for Pinnacle 80e ATSC tuner
Register the em2874 based Pinnacle 80e device. Note that support for this
device also requires the new drx-j driver (which is not available yet)
Thanks for Ray Lu from Empia for providing the em2874 datasheet.
Thanks to Joerg Schindler from Pinnacle for providing sample hardware.
Thanks to Rainer Miethling from Pinnacle for providing engineering support.
Signed-off-by: Devin Heitmueller <devin.heitmueller@gmail.com>
EM2820_BOARD_PROLINK_PLAYTV_USB2
Added vendor/product id for EM2820_BOARD_PROLINK_PLAYTV_USB2
Correct firmware type to MTS
Correct audio routing for composite/s-video
Add DVB-T detection.
This patch uses the eeprom hash method for detection as the vendor/product
ids are also used for the DIGIVOX_AD. This may be a clone of the same
product. Explanatory text has been added prior to the hask look-up in
anticipation that it may help others.
The following has been tested to work:
Analogue TV (PAL-I)
Composite In
DVB-T (UK Crystal Palace)
USB AUDIO
The following has not been tested but probably works:
S-Video In
Signed-off-by: Darron Broad <darron@kewl.org>
Thanks to "Devin Heitmueller" <devin.heitmueller@gmail.com> for pointing this
issue.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Added Compro VideoMate ForYou/Stereo model (analog only)
Signed-off-by: Vitaly Wool <vital@embeddedalley.com>
[dougsland@gmail.com: Solved conflicts with v4l-dvb devel tree]
Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com>
[mchehab@infradead.org: Need to fix some merge conflicts]
- New supported IDs for analog models
(Based on Markus Rechberger <mrechberger@gmail.com> version of em28xx driver)
- Validation field for new em28xx boards.
