Several cardlist entries are missed. Fix them by running some
script magic (about the same scripts we used to have at -hg tree).
PS.: The cardlists are auto-generated via scripts.
Signed-off-by: Pavel Osnova <pvosnova@gmail.com>
Signed-off-by: Ramiro Morales <ramiro@rmorales.net>
Fix a few troubles at the card entries
This patch adds support for TechnoTrend TT-budget T-3000 DVB-T card.
Signed-off-by: Vadim Catana <vadim.catana@gmail.com>
This change adds support for Avermedia M733A. The original version for
linux 2.6.31 was sent to me from Avermedia, original author is unknown.
I ported it to current kernels, expanded and fixed key code handling for
RM-K6 remote control, and added an additional pci id also supported.
[mchehab@redhat.com: make checkpatch.pl happier]
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br>
[dougsland@redhat.com: Fixed cards numbers reject due changes in saa7134.h]
Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com>
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
Adds new capture boards Hawell HW-404M7 and HW-808M7. Those cards have 4
or 8 SAA7130 chips and for the work it only needs initialize registers.
The value of those registers were dumped under Windows using flytest.
But board haven't EEPROM.
For the first chip:
SAA7130 (0x7130, SubVenID:1131, SubDevID:0000, Rev: 01)
I2C slave devices found:
No devices
GPIO pins:
Mode : 0x00389C00
Value: 0x00016C00
Video input: 3
Audio input: Analog Line1
For other chips:
No devices
GPIO pins:
Mode : 0x00389200
Value: 0x00010000
Video input: 3
Signed-off-by: Vladimir Ermakov <vooon341@gmail.com>
Add lost configuration for our TV card.
Thanks to Terry Wu for finding the GPIOs required for svideo / composite input
Cc: Terry Wu <terrywu2009@gmail.com>
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com>
SubVendor ID: 0x1043 Device ID: 0x4847)
Adds the device IDs and driver linking to allow the Asus Europa DVB-T
card to operate with these drivers.
The device has a SAA7134 chipset with a TD1316 Hybrid Tuner.
All inputs work on the card including switching between DVB-T and
Analogue TV, there is also no IR with this card.
[mchehab@redhat.com: CodingStyle fixes]
Signed-off-by: Danny Wood <danwood76@gmail.com>
http://linuxtv.org/wiki/index.php/Zolid_Hybrid_TV_Tuner
test status analog (PAL-B):
- Sometimes picture is noisy, but it becomes crystal clear after
switching between channels. (happens for example at 687.25 Mhz)
- On a lower frequency (511.25 Mhz) the picture is always sharp, but
lacks colour.
- No sound problems.
- radio untested.
Digital:
- DVB-T/H stream reception works.
- Would expect to see some more channels in the higher frequency region.
Overall is the impression that sensitivity still needs improvement
both in analog and digital modes.
Signed-off-by: Henk Vergonet <Henk.Vergonet@gmail.com>
This patch add support for RoverMedia TV Link Pro FM (LR138 REV:I) card
based on saa7134.
Signed-off-by: Eugene Yudin <Eugene.Yudin@gmail.com>
Add support our new TV card based on xc5000 and saa7134.
Analog TV works well.
Added support to AverMedia Studio 505
[dougsland@redhat.com: fixed rejects and removed the change to add dk as default secam variant]
[mchehab@redhat.com: fix a few CodingStyle issues]
Signed-off-by: Vasiliy Temnikov <vaka@newmail.ru>
Patch solves problem of missed keystrokes on some remote controls,
as reported on http://bugzilla.kernel.org/show_bug.cgi?id=9637 .
Signed-off-by: Andrzej Hajda <andrzej.hajda@wp.pl>
WinTV-HVR1120 DVB-T/Hybrid
WinTV-HVR1150 ATSC/QAM-Hybrid
Add 1461:f736 to the list of identifiers corresponding to the
SAA7134_BOARD_AVERMEDIA_M103 board. This patch adds support for
a variant of the AVerMedia M103 MiniPCI DVB-T Hybrid card.
Signed-off-by: Barry Kitson <b.kitson@gmail.com>
WinTV-HVR1110r3
the model
Split Beholdr`s cards to correct models.
Here comes the full support for AVerMedia Cardbus Plus (E501R) - including
remote control. TV, Composite and FM radio tested, I don't have S-Video to
test. I've figured out that the radio works only with xtal frequency 13MHz.
Signed-off-by: Oldřich Jedlička <oldium.pro@seznam.cz>
[mchehab@redhat.com: Fix merge conflicts and CodingStyle issues]
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
replace occurances of "HVR1150" with "HVR1120" - this was a typo.
This patch adds support for Avermedia AVer TV GO 007 FM Plus (M15C) on
saa7134 driver (PCI ID 1461:f31d).
Signed-off-by: Pham Thanh Nam <phamthanhnam.ptn@gmail.com>
How to enable the mpeg encoder is not found yet.
The card comes up with gpio 0x0820000 for DVB-T.
Signed-off-by: Hermann Pitton <hermann-pitton@arcor.de>
Thanks to Sistema Fenix (http://www.sistemafenix.com.br/) for sponsoring
this
development.
Signed-off-by: Gilberto <gilberto@sistemafenix.com.br>
In opposite to the P7131 Dual this early OEM card has a male
radio antenna connector and also no remote.
We currently switch the DVB-T RF feed to the radio input, like
on the P7131 with female radio connector used also for DVB-T
and should improve this.
Add PCI ID and device specific tables for ADS Tech Instant HDTV.
[mchehab@redhat.com: make checkpatch happy and fix merge conflicts]
this development.
this development.
this development.
after looking it up, all rants about the 80 columns restriction seem to
be in vain. After changing the card's name it are now "only" seven new
lines in the tiny DVB-T/DVB-S switch function.
saa7130/34: v4l2 driver version 0.2.14 loaded
saa7133[0]: found at 0000:02:08.0, rev: 209, irq: 18, latency: 32, mmio: 0xfdef7000
saa7133[0]: subsystem: 1043:4878, board: Asus Tiger 3in1 [card=147,autodetected]
saa7133[0]: board init: gpio is 200000
tuner' 2-004b: chip found @ 0x96 (saa7133[0])
saa7133[0]: i2c eeprom 00: 43 10 78 48 54 20 1c 00 43 43 a9 1c 55 d2 b2 92
saa7133[0]: i2c eeprom 10: ff ff ff 0f ff 20 ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 20: 01 40 01 02 03 01 01 03 08 ff 00 d7 ff ff ff ff
saa7133[0]: i2c eeprom 30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 40: ff 28 00 c2 96 16 03 02 c0 1c ff ff ff ff ff ff
saa7133[0]: i2c eeprom 50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 60: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 70: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 80: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 90: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom a0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom b0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom c0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom d0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom e0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom f0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c scan: found device @ 0x10 [???]
saa7133[0]: i2c scan: found device @ 0x16 [???]
saa7133[0]: i2c scan: found device @ 0x1c [???]
saa7133[0]: i2c scan: found device @ 0x96 [???]
saa7133[0]: i2c scan: found device @ 0xa0 [eeprom]
tda829x 2-004b: setting tuner address to 61
tda829x 2-004b: type set to tda8290+75a
saa7133[0]: registered device video0 [v4l2]
saa7133[0]: registered device vbi0
saa7133[0]: registered device radio0
DVB: registering new adapter (saa7133[0])
DVB: registering frontend 0 (Philips TDA10086 DVB-S)...
The board init gpio is 0x0, 0x200000 is from previously unloading with
antenna_switch = 1.
It needs firmware for the tda10046 and analog sound needs saa7134-alsa.
I have support for one more board and need to fix the first revision of
the Asus Tiger DVB-T hybrid. DVB-T currently hangs on the male radio
antenna input, also some small other stuff.
Please report any issues with this patch, the next are depending on this
one.
saa7134: add support for the triple Asus Tiger 3in1
saa7134: add a separate entry for the ASUSTeK P7131 analog only
and do some eeprom detection to escape from the TVFM7135
with the same PCI subsystem on auto detection.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
The following patch updates saa7134 driver to add support for AVerMedia
Signed-off-by: Massimo Piccioni <alsa@piccio.org>
[mchehab@infradead.org: fixed merge conflicts and a small codingstyle]
Signed-off-by: Daniel Gimpelevich <daniel@gimpelevich.san-francisco.ca.us>
Split the Beholder M6 family to different models. Because M6 hasn`t RDS, M63
has chip with AC3 codec, M6 Extra has other type of HF module.
Add correct data for support MPEG encoder.
Signed-off-by: Igor Kuznetsov <igk@igk.ru>
Beholder TV/FM tuners:
Changes:
Add support Beholder Columbus PCMCIA card.
Add key map for remote control of Beholder Columbus PCMCIA card.
Fix gpiomask for all Beholder tuners.
Add support for composite and s-video inputs on
Avermedia DVB-S Pro and DVB-S Hybrid+FM cards
(both labled A700) to the saa7134 driver.
XC2028 support for Hybrid+FM is still missing.
Signed-off-by: Matthias Schwarzott <zzam@gentoo.org>
Reviewed-by: Hermann Pitton <hermann.pitton@arcor.de>
This patch adds support for the following saa7134 xc3028 based boards:
132 -> AVerMedia Cardbus TV/Radio (E506R) [1461:f436]
133 -> AVerMedia Hybrid TV/Radio (A16D) [1461:f936]
134 -> Avermedia M115 [1461:a836]
135 -> Compro VideoMate T750 [185b:c900]
This is based on a original patch thanks to Markus Rechberger that added xc3028
gpio init code for the above boards.
This patch moves saa7134_tuner_callback to saa7134-cards, originally used only
by tda8290 DVB-S boards. The callback was made more generic to support other
tuners.
Currently, it supports both tda8290 and xc2028/xc3028 tuners. Added also the
basis for xc5000 tuner callback.
Signed-off-by: Russell Kliese <russell@kliese.wattle.id.au>
Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de>
Signed-off-by: Adrian Pardini <pardo.bsso@gmail.com>
Thanks to Angelo Lisco for his initial patch we missed and to
Ahmet Dogan Ugurel confirming such a device functional.
