path: root/Documentation/video4linux/CARDLIST.usbvision
2008-01-25V4L/DVB (6994): usbvision: add Pinnacle Studio PCTV USB (NTSC) FM V3Thierry MERLE
Add the "Pinnacle Studio PCTV USB (NTSC) FM" device. This is the third occurrence of the same device designation... Signed-off-by: Thierry MERLE <thierry.merle@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5530): Usbvision: remove CustomDevice facilityThierry MERLE
usbvision has a module parameter that ables the user to add a new USB entry at driver load. This functionality is useless by experience (adding statically the entry is easy). Furthermore, the USB_DEVICE(0xfff0, 0xfff0) USB entry caused usbvision_probe to be called for all unclaimed devices. Signed-off-by: Thierry MERLE <thierry.merle@free.fr> Acked-by: Dwaine Garden <DwaineGarden@rogers.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5515): Use a better format to represent usbvision supported boardsMauro Carvalho Chehab
Changed usbvision cards table to allow: 1) Not repeat USB ID on two structs; 2) Not need to specify both usb and card description tables at the same order, removing some magic; Some cards had duplicated names. Fixed. A test for an specific board were doing by using a string comparation. The comparation were wrong. Also, it is not a good practice to recognize a board based on his string name. Acked-by: Thierry MERLE <thierry.merle@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5500): Add a CARDLIST for the supported devices by usbvision driverMauro Carvalho Chehab
