path: root/Documentation/video4linux/cx2341x
2007-09-14V4L/DVB (6095): ivtv: fix VIDIOC_G_ENC_INDEX flag handlingHans Verkuil
Due to a documentation bug (the type mask is 3 bits long, not 2) the wrong frame types were filled in: the B and P frame types were swapped. This bug also hid a second bug: when a capture is stopped a last entry is written into the pgm index buffer with internal type 0, denoting the end of the program. This entry wasn't ignored, instead it was accidentally returned to the caller as a P frame. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5437): Update cx23415 documentationIan Armstrong
Adds more osd mode switching information. Corrects some information regarding mode selection & local alpha operation for 16 bit modes. Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5336): Cx23416 doc updates + rename CX2341X_ENC_UNKNOWNHans Verkuil
The documentation of Several miscellaneous commands was updated. As a result of which the CX2341X_ENC_UNKNOWN command was renamed to CX2341X_ENC_SET_VERT_CROP_LINE. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5184): Add cx23415 decoder register documentationIan Armstrong
Many thanks to Ian Armstrong for figuring out what all these registers do. Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5179): Cx2341x encoder documentation update.Hans Verkuil
2007-02-21V4L/DVB (5119): Various cx2341x documentation updates/fixes.Hans Verkuil
2007-02-21V4L/DVB (4987): Improve cx2341x documentationHans Verkuil
Document the program index table format, removed unused interrupt documentation and improve the documentation regarding the audio mode (stereo/joint/dual/mono). Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (4986): Removed unimplemented cx2341x API commandsHans Verkuil
The commands CX2341X_DEC_SET_AUDIO_OUTPUT, CX2341X_DEC_SET_AV_DELAY and CX2341X_ENC_SET_3_2_PULLDOWN are not implemented in the Conexant firmware. So these commands are removed. This also means that the V4L2_CID_MPEG_VIDEO_PULLDOWN control in cx2341x.c and pvrusb2-hdw.c is removed. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (4985): Update cx2341x documentation.Hans Verkuil
Removed a few unimplemented commands. Added a note for a few fields that are not implemented in the firmware, and clarified several issues around reverse playback. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (4981): Update cx2341x documentation.Hans Verkuil
2006-10-03Fix typos in Documentation/: 'N'-'P'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'N'-'P'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'H'-'M'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'H'-'M'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'B'-'C'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'B'-'C'. There are also a few grammar fixes thrown in for Randy. ;) Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-26V4L/DVB (4547): Add YUV HM12 and VBI IVTV format documentation.Hans Verkuil
README.hm12: documentation on the HM12 YUV format used by the cx23415/6 chip. README.vbi: documentation on the V4L2_MPEG_STREAM_VBI_FMT_IVTV VBI format used in MPEG streams. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4202): allow selecting CX2341x port modeHans Verkuil
CX2341X port was always set to 'memory', but 'streaming' is also possible ivtv uses the memory (DMA) interface with the CX2341X, while pvrusb2 and cx88-blackbird use the streaming interface. This setting is now selectable by the driver. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4193): Update cx2341x fw encoding API doc.Hans Verkuil
Based on recent tests it turned out that some features are not implemented. This has now been documented. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4118): Whitespace cleanupsTrent Piepho
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3809b): Added missing docs at kernel treeMauro Carvalho Chehab
Date: From: Mauro Carvalho Chehab <mchehab@infradead.org> There are some docs at V4L/DVB tree that were never included at kernel. This patch includes those docs. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
