Signed-off-by: Alexander Goncharov <alexzandersss@gmail.com>
Signed-off-by: Jean-François Moine <moinejf@free.fr>
Tested-by: Simon Danner <simon@danner-urloffen.de>
Add Genius iSlim 310 webcam to the supported list of the PAC7302 driver.
For more information see http://linuxtv.org/wiki/index.php/PixArt_PAC7301/PAC7302 .
Signed-off-by: Márton Németh <nm127@freemail.hu>
Signed-off-by: Warren Bosworth Focke <wbfocke@gmail.com>
Adds the following models:
- 0c45:624c
- 0c45:628c
- 0458:704a
- 0458:704c
Signed-off-by: Brian Johnson <brijohn@gmail.com>
gscpa Documentation: add cpia1 cameras
sn9c2028 drivers
gspca.txt: add cams supported by mr97310a, sq905(c) and sn9c2028 drivers
Signed-off-by: Theodore Kilgore <kilgota@banach.math.auburn.edu>
The two sensors ov772x and ov965x have too much differences.
Signed-off-by: Jean-Francois Moine <moinejf@free.fr>
Tested-by: Francesco Lavra <francescolavra@interfree.it>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (345 commits)
V4L/DVB (13542): ir-keytable: Allow dynamic table change
V4L/DVB (13541): atbm8830: replace 64-bit division and floating point usage
V4L/DVB (13540): ir-common: Cleanup get key evdev code
V4L/DVB (13539): ir-common: add __func__ for debug messages
V4L/DVB (13538): ir-common: Use a dynamic keycode table
V4L/DVB (13537): ir: Prepare the code for dynamic keycode table allocation
V4L/DVB (13536): em28xx: Use the full RC5 code on HVR-950 Remote Controller
V4L/DVB (13535): ir-common: Add a hauppauge new table with the complete RC5 code
V4L/DVB (13534): ir-common: Remove some unused fields/structs
V4L/DVB (13533): ir: use dynamic tables, instead of static ones
V4L/DVB (13532): ir-common: Add infrastructure to use a dynamic keycode table
V4L/DVB (13531): ir-common: rename the debug routine to allow exporting it
V4L/DVB (13458): go7007: subdev conversion
V4L/DVB (13457): s2250: subdev conversion
V4L/DVB (13456): s2250: Change module structure
V4L/DVB (13528): em28xx: add support for em2800 VC211A card
em28xx: don't reduce scale to half size for em2800
em28xx: don't load audio modules when AC97 is mis-detected
em28xx: em2800 chips support max width of 640
V4L/DVB (13523): dvb-bt8xx: fix compile warning
Fix up trivial conflicts due to spelling fixes from the trivial tree in
Documentation/video4linux/gspca.txt
drivers/media/video/cx18/cx18-mailbox.h
gscpa_mr97310a: Add Trust Spyc@m 100 USB ID
Signed-off-by: Aurelien Jacobs <aurel@gnuage.org>
Signed-off-by: Rafal Milecki <zajec5@gmail.com>
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
- add the Genesys Logic 05e3:0503 and 05e3:f191 webcam
Signed-off-by: Olivier Lorin <o.lorin@laposte.net>
Signed-off-by: Stephane Marguet (Stemp) <smarguet@gmail.com>
Signed-off-by: Theodore Kilgore <kilgota@auburn.edu>
Signed-off-by: Denis Loginov <dinvlad@gmail.com>
Signed-off-by: Johannes Goerner <johannes-goerner@gmx.de>
Only the back sensor (mi1320_soc) is usable.
Signed-off-by: Jani Monoses <jani@ubuntu.com>
Signed-off-by: Lierdakil <root@livid.pp.ru>
This patch adds support for USB webcams based on the MR97310A chip. It was
tested with an Aiptek PenCam VGA+ webcam.
Signed-off-by: Kyle Guinn <elyk03@gmail.com>
Signed-off-by: Erik Andren <erik.andren@gmail.com>
Signed-off-by: Fabio Rossi <rossi.f@inwind.it>
