path: root/Documentation/video4linux
2007-09-14V4L/DVB (6095): ivtv: fix VIDIOC_G_ENC_INDEX flag handlingHans Verkuil
Due to a documentation bug (the type mask is 3 bits long, not 2) the wrong frame types were filled in: the B and P frame types were swapped. This bug also hid a second bug: when a capture is stopped a last entry is written into the pgm index buffer with internal type 0, denoting the end of the program. This entry wasn't ignored, instead it was accidentally returned to the caller as a P frame. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5803): Bttv: add support for DViCO FusionHDTV 2Michael Krufky
add analog video support for DViCO FusionHDTV 2 Thanks to Todd Ignasiak for donating the card. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5800): Tuner: correct description of Philips FCV1236D tunerMichael Krufky
The old description was "Philips 1236D ATSC/NTSC dual in", which can be confused with other Philips tuner models. This patch corrects the name to "Philips FCV1236D ATSC/NTSC dual in", and updates the range and params array names to match the description. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5792): Zr364xx: add support for Trust Powerc@m 970ZAntoine Jacquet
Add Trust Powerc@m 970Z (0x06d6:0x003b) to the list of supported devices. Signed-off-by: Antoine Jacquet <royale@zerezo.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5789): Fix 3dfx Voodoo entries on CardlistMauro Carvalho Chehab
2007-07-18V4L/DVB (5765): SN9C1xx driver updatesLuca Risolia
- Add support for pair OV7630+SN9C120 - Better and safe locking mechanism of the device structure on open(), close() and disconnect() - Use kref for handling device deallocation - Generic cleanups Signed-off-by: Luca Risolia <luca.risolia@studio.unibo.it> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5685): Cx88: add support for ADS Tech Instant Video PCIDaniel Gimpelevich
Signed-off-by: Daniel Gimpelevich <daniel@gimpelevich.san-francisco.ca.us> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5646): V4l: saa7134: add support for 10moons TM300 cardTony Wan
Support the 10moons TM300 TV card (so called TV Master 3), which is a 10moons saa7130 based board. Here not include features for the IR-remote. It has been tested using TVTIME. The card was auto-detected and all the input sources worked correct with sound. Signed-off-by: Tony Wan <wankai@sjtu.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5563a): Add experimental support for tea5761 tunerMauro Carvalho Chehab
This driver were made based on tea5761 specs. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-11Merge branch 'master' of ↵Linus Torvalds
ssh://master.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb * 'master' of ssh://master.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (44 commits) V4L/DVB (5571): V4l1-compat: Make VIDIOCSPICT return errors in a useful way V4L/DVB (5624): Radio-maestro.c cleanup V4L/DVB (5623): Dsbr100.c Replace usb_dsbr100_do_ioctl to use video_ioctl2 V4L/DVB (5622): Radio-zoltrix.c cleanup V4L/DVB (5621): Radio-cadet.c Replace cadet_do_ioctl to use video_ioctl2 V4L/DVB (5619): Dvb-usb: fix typo V4L/DVB (5618): Cx88: Drop the generic i2c client from cx88-vp3054-i2c V4L/DVB (5617): V4L2: videodev, allow debugging V4L/DVB (5614): M920x: Disable second adapter on LifeView TV Walker Twin V4L/DVB (5613): M920x: loosen up 80-col limit V4L/DVB (5612): M920x: rename function prefixes from m9206_foo to m920x_foo V4L/DVB (5611): M920x: replace deb_rc with deb V4L/DVB (5610): M920x: remove duplicated code V4L/DVB (5609): M920x: group like functions together V4L/DVB (5608): M920x: various whitespace cleanups V4L/DVB (5607): M920x: Initial support for devices likely manufactured by Dposh V4L/DVB (5606): M920x: add "c-basic-offset: 8" to help emacs to enforce tabbing V4L/DVB (5605): M920x: Add support for LifeView TV Walker Twin V4L/DVB (5603): V4L: Prevent queueing queued buffers. V4L/DVB (5602): Enable DiSEqC in Starbox II (vp7021a) ...
2007-05-09V4L/DVB (5585): SN9C1xx driver updatesLuca Risolia
* Default color improvements to the OV7660 @ Fix sn9c102_write_reg() @ Fix sn9c102_i2c_try_raw_read() @ Fix MI-0343 + Add support for pair MI0360+SN9C120 + Add more USB ids Signed-off-by: Luca Risolia <luca.risolia@studio.unibo.it> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-09V4L/DVB (5582): Added support for Sabrent TV-PCB05 card.James T Klaas
Maintainer's notice: I needed to re-number the board, since the board number conflicted with a patch committed previously. Signed-off-by: James T Klaas <jklaas@appalachian.dyndns.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-09V4L/DVB (5580): Add support for three cards to saa7134 driverSimon Farnsworth
Add support for the "Elitegroup ECS TVP3XP FM1246", the "KWorld DVB-T 210", and the Animation Technologies LR214 Rev F onwards (SAA7131) to the saa7134 driver. Also rename the LR214WF to the LR214 Rev E or ealier (SAA7135), to match what we've seen on boards in the field. Changed the comment on the Lifeview cards to indicate Rev E and earlier versus Rev F and later, together with a chip indicator, following feedback from Peter Missel <peter.missel@onlinehome.de>. Signed-off-by: Simon Farnsworth <simon.farnsworth@onelan.co.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-09documentation: convert the Documentation directory to UTF-8John Anthony Kazos Jr
Convert files within the Documentation directory to UTF-8. Adrian Bunk: small additional fixes Signed-off-by: John Anthony Kazos Jr. <jakj@j-a-k-j.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-29Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (105 commits) sonypi: use mutex instead of semaphore sony-laptop: remove user visible camera controls as platform attributes meye: make meye use sony-laptop instead of sonypi sony-laptop: add a meye-usable include file for camera ops sony-laptop: complete the motion eye camera support in sony-laptop sonypi: try to detect if sony-laptop has already taken one of the known ioports sonypi: suggest sonypi users to try sony-laptop instead sony-laptop: add edge modem support (also called WWAN) sony-laptop: add locking on accesses to the ioport and global vars sony-laptop: add camera enable/disable parameter, better handle possible infinite loop thinkpad-acpi: make drivers/misc/thinkpad_acpi:fan_mutex static ACPI: thinkpad-acpi: add sysfs support to wan and bluetooth subdrivers ACPI: thinkpad-acpi: add sysfs support to hotkey subdriver ACPI: thinkpad-acpi: improve dock subdriver initialization ACPI: thinkpad-acpi: improve debugging for acpi helpers ACPI: thinkpad-acpi: improve fan control documentation ACPI: thinkpad-acpi: map ENXIO to EINVAL for fan sysfs ACPI: thinkpad-acpi: fix a fan watchdog invocation ACPI: thinkpad-acpi: do not arm fan watchdog if it would not work ACPI: thinkpad-acpi: add a fan-control feature master toggle ...
2007-04-28meye: make meye use sony-laptop instead of sonypimalattia@linux.it
Change sonypi_camera_command() calls to sony_pic_camera_command() and use the renamed macros. Signed-off-by: Mattia Dongili <malattia@linux.it> Signed-off-by: Len Brown <len.brown@intel.com>
2007-04-27V4L/DVB (5530): Usbvision: remove CustomDevice facilityThierry MERLE
usbvision has a module parameter that ables the user to add a new USB entry at driver load. This functionality is useless by experience (adding statically the entry is easy). Furthermore, the USB_DEVICE(0xfff0, 0xfff0) USB entry caused usbvision_probe to be called for all unclaimed devices. Signed-off-by: Thierry MERLE <thierry.merle@free.fr> Acked-by: Dwaine Garden <DwaineGarden@rogers.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5515): Use a better format to represent usbvision supported boardsMauro Carvalho Chehab
Changed usbvision cards table to allow: 1) Not repeat USB ID on two structs; 2) Not need to specify both usb and card description tables at the same order, removing some magic; Some cards had duplicated names. Fixed. A test for an specific board were doing by using a string comparation. The comparation were wrong. Also, it is not a good practice to recognize a board based on his string name. Acked-by: Thierry MERLE <thierry.merle@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5500): Add a CARDLIST for the supported devices by usbvision driverMauro Carvalho Chehab
2007-04-27V4L/DVB (5497): Additional card support for bttv driverScott Alfter
SSAI (www.ssai.us) makes several Bt878-based capture cards that get used in our surveillance, conferencing, and medical imaging systems. The attached relatively small patch adds support for these cards, which fall into two broad * boards with one or more Bt878s, one or more composite inputs, and no S-video or tuner inputs * boards with one Bt878, one composite input, one S-video input, and no tuner input Signed-off-by: Scott Alfter <salfter@ssai.us> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5474): SN9C1xx driver updatesLuca Risolia
@ Don't assume that SOF headers can't cross packets boundaries @ Fix compression quality selection + Add support for MI-0360 image sensor * Documentation updates @ Fix sysfs @ MI0343 rewritten * HV7131R color fixes and add new ABLC control * Rename the archive from "sn9c102" to "sn9c1xx" * fix typos * better support for TAS5110D @ fix OV7630 wrong colors @ Don't return an error if no input buffers are enqueued yet on VIDIOC_STREAMON * Add informations about colorspaces * More appropriate error codes in case of failure of some system calls * More precise hardware detection * Add more informations about supported hardware in the documentation + More supported devices + Add support for HV7131R image sensor Signed-off-by: Luca Risolia <luca.risolia@studio.unibo.it> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5446): Renamed ASUStek P7131 card [1043:4876]Hartmut Hackmann
The new name fits to what it is and what is on the box. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5445): Added / corrected support for some ASUS hybrid boardsHartmut Hackmann
There are 2 new entries for p7131 boards and one correction for a board with LNA. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5437): Update cx23415 documentationIan Armstrong
Adds more osd mode switching information. Corrects some information regarding mode selection & local alpha operation for 16 bit modes. Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5431): Cx88: autodetect ADS Tech InstantTV DVB-SMichael Krufky
The ADS Tech InstantTV DVB-S is a clone of the KWorld DVB-S 100. This patch adds autodetection support for this card based on pci subsystem id. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5409): Add CARDLIST.ivtv and README.ivtvHans Verkuil
2007-04-27V4L/DVB (5336): Cx23416 doc updates + rename CX2341X_ENC_UNKNOWNHans Verkuil
The documentation of Several miscellaneous commands was updated. As a result of which the CX2341X_ENC_UNKNOWN command was renamed to CX2341X_ENC_SET_VERT_CROP_LINE. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5331): Identify MSI TV@nywhere DuoPeter Missel
It is a Lifeview Duo with a different ID Signed-off-by: Peter Missel <peter.missel@onlinehome.de> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5330): Added card definition for AverMedia M102 miniPCIMarkus Rechberger
Signed-off-by: Markus Rechberger <mrechberger@gmail.com> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5314): Added support for tda827x tuners with preamlifiersHartmut Hackmann
This patch contains - new tuning code for the tda827xa silicon tuner. - controls the preamplifier of some boards with this tuner. - support for the Philips Tiger S hybrid DVB-T reference design. - reworked the saa7134-dvb modulue to get rid of most of the small board specific functions. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5257): USB: add zr364xx V4L2 driverAntoine Jacquet
This patch adds a V4L2 driver giving support for USB webcams based on the zr364xx chipsets. Signed-off-by: Antoine Jacquet <royale@zerezo.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5184): Add cx23415 decoder register documentationIan Armstrong
Many thanks to Ian Armstrong for figuring out what all these registers do. Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5179): Cx2341x encoder documentation update.Hans Verkuil
2007-02-21V4L/DVB (5119): Various cx2341x documentation updates/fixes.Hans Verkuil
2007-02-21V4L/DVB (5111): Saa7134: add support for Terratec Cinergy HT PCIMichael Krufky
Add support for Terratec Cinergy HT PCI Signed-off-by: Giorgio Moscardi <software@sukkology.net> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5068): Fix authorship referencesMauro Carvalho Chehab
Bill Dirks asked me to update his entries at kernel files, since he change his e-mail. I've also updated a few web broken links or obsolete info to the curent sites where V4L drivers and API are being discussed currently. CC: Bill Dirks <bill@thedirks.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5064): ET61X251 driver updates.Luca Risolia
- Implement audio ioctl's and VIDIOC_ENUM_FRAMESIZES - Documentation updates - Generic improvements Signed-off-by: Luca Risolia <luca.risolia@studio.unibo.it> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5063): ZC0301 driver updates.Luca Risolia
2007-02-21V4L/DVB (5062): SN9C102 driver updatesLuca Risolia
- Add support for SN9C105 and SN9C120 - Add some more USB device identifiers - Add support for OV7660 - Implement audio ioctl's and VIDIOC_ENUM_FRAMESIZES - Add preliminary support for 0x0c45/0x6007 - Documentation updates - Generic improvements Signed-off-by: Luca Risolia <luca.risolia@studio.unibo.it> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5061): Bt8xx: add support for Ultraview DVB-T LiteMichael Krufky
Ultraview DVB-T Lite is a clone of DViCO FusionHDTV DVB-T Lite Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5015): Add support for more Encore TV cardsJuan Pablo Sormani
Signed-off-by: Juan Pablo Sormani <sorman@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (4993): Updated cardlist to reflect the newly added saa7134 boardMauro Carvalho Chehab
2007-02-21V4L/DVB (4987): Improve cx2341x documentationHans Verkuil
Document the program index table format, removed unused interrupt documentation and improve the documentation regarding the audio mode (stereo/joint/dual/mono). Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (4986): Removed unimplemented cx2341x API commandsHans Verkuil
The commands CX2341X_DEC_SET_AUDIO_OUTPUT, CX2341X_DEC_SET_AV_DELAY and CX2341X_ENC_SET_3_2_PULLDOWN are not implemented in the Conexant firmware. So these commands are removed. This also means that the V4L2_CID_MPEG_VIDEO_PULLDOWN control in cx2341x.c and pvrusb2-hdw.c is removed. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (4985): Update cx2341x documentation.Hans Verkuil
Removed a few unimplemented commands. Added a note for a few fields that are not implemented in the firmware, and clarified several issues around reverse playback. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (4981): Update cx2341x documentation.Hans Verkuil
2007-02-17Various typo fixes.Robert P. J. Day
Correct mis-spellings of "algorithm", "appear", "consistent" and (shame, shame) "kernel". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-10V4L/DVB (4887): Remove the broken VIDEO_ZR36120 driverAdrian Bunk
The VIDEO_ZR36120 driver has: - already been marked as BROKEN in 2.6.0 three years ago and - is still marked as BROKEN. Drivers that had been marked as BROKEN for such a long time seem to be unlikely to be revived in the forseeable future. But if anyone wants to ever revive this driver, the code is still present in the older kernel releases. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4841): Added a newer PCI ID to CARDLIST.cx88Mauro Carvalho Chehab
2006-12-10V4L/DVB (4835): Added support for the Terratec Cinergy HT PCMCIA moduleHartmut Hackmann
This is a hybrid cardbus module. Besides the card support, i modified the definition names for AGC and GPIO of the tda10046. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
