path: root/Documentation/video4linux
2008-06-05V4L/DVB (7990): Fix entry for PowerColor RA 330 and make it run with ↵Daniel Gimpelevich
firmware version 2.7 Signed-off-by: Daniel Gimpelevich <daniel@gimpelevich.san-francisco.ca.us> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-06-05V4L/DVB (7932): cx18: mark Compro H900 as fully supported.Hans Verkuil
I always assumed that the Compro H900 could do digital as well, but it turned out that it is an analog-only card. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7827): cx23885: add missing subsystem ID for Hauppauge HVR-1200 OEMMichael Krufky
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7823): em28xx: add additional usb subids for Hauppauge HVR-950Michael Krufky
2008-04-29V4L/DVB (7786): cx18: new driver for the Conexant CX23418 MPEG encoder chipHans Verkuil
Many thanks to Steve Toth from Hauppauge and Nattu Dakshinamurthy from Conexant for their support. I am in particular thankful to Hauppauge since without their help this driver would not exist. It should also be noted that Steve did the work to get the DVB part up and running. Thank you! Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: G. Andrew Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29V4L/DVB (7766): saa7134: add another PCI ID for Beholder M6Igor Kuznetsov
Signed-off-by: Igor Kuznetsov <igk@igk.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29V4L/DVB (7765): Add support for Beholder BeholdTV H6Igor Kuznetsov
2008-04-24V4L/DVB (7677): saa7134: Add/fix Beholder entriesDmitry Belimov
Beholder TV/FM tuners: Changes: Add support Beholder Columbus PCMCIA card. Add key map for remote control of Beholder Columbus PCMCIA card. Fix gpiomask for all Beholder tuners. Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7673): cx23885: Add support for the Hauppauge HVR1400Steven Toth
DVB-T mode is now supported using the DiBcom dib7000p demodulator and the Xceive xc3028L silicon tuner. Analog mode is not supported. Signed-off-by: Steven Toth <stoth@hauppauge.com> Reviewed-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7651): tuner-xc2028: Several fixes to SCODEMauro Carvalho Chehab
This patch fixes several issues on SCODE: 1) The extracting tool weren't generating the proper tags for SCODE. This has almost no effect, since those tags shouldn't be used; 2) DIBCOM52 were using a wrong IF. It should be 5200, instead of 5700; 3) seek_firmware were wanting an exact match for firmware type. This is wrong. As result, no SCODE firmware were loaded; 4) A few files were including the wrong file for seeking demod firmwares; 5) XC3028_FE_DEFAULT can be used, if user doesn't want to load a firmware. However, this weren't documentated. This feature require more testing. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7647): Add support for the Hauppauge HVR-1700 digital modeSteven Toth
This adds support for DVB-T mode only, analog is not supported. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7645): Add support for the Hauppauge HVR-1200Steven Toth
This adds support for DVB-T mode only, analog mode is not supported. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7623): Scripts to maintain the CARDLIST fileSteven Toth
Scripts to maintain the CARDLIST file. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7507): saa7134: add analog support for Avermedia A700 cardsMatthias Schwarzott
Add support for composite and s-video inputs on Avermedia DVB-S Pro and DVB-S Hybrid+FM cards (both labled A700) to the saa7134 driver. XC2028 support for Hybrid+FM is still missing. Signed-off-by: Matthias Schwarzott <zzam@gentoo.org> Reviewed-by: Hermann Pitton <hermann.pitton@arcor.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7448): Add support for Kworld ATSC 120Mauro Carvalho Chehab
This board has a s5h1409 demod, plus a xc30x8 tuner (probably, xc3018). This patch adds proper support for radio, video, s-video, composite and ATSC. However, support for radio and video depends on having s5h1409 i2c gate open, otherwise, xc30x8 chip won't be visible. For a better support, some rework is needed on cx88 driver, to allow adding xc30x8 to i2c bus without sending i2c 0 byte reading to 0xc2 address. Thanks to Vanessa Ezekowitz <vanessaezekowitz@gmail.com> for helping to figure out the proper parameters for s5h1409 and the GPIO pins used by each configuration. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7370): Add basic support for Prolink Pixelview MPEG 8000GTMauro Carvalho Chehab
TV reception ok. S-video and Composite not tested. Audio not tested. IR not implemented yet. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7368): bttv: added support for Kozumi KTV-01C cardMauro Lacy
Signed-off-by: Mauro Lacy <mauro@lacy.com.ar> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7366): Support for a 16-channel bt878 cardErnesto Hernández-Novich
I have what looks like a Geovision GV-600 (or 650) card. It has a large chip in the middle labeled CONEXANT FUSION 878A 25878-13 E345881.1 0312 TAIWAN It has an audio connector coming out from a chip labeled ATMEL 0242 AT89C2051-24PI It is identified as follows on my Debian GNU/Linux Etch (kernel 2.6.18) ... 01:0a.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11) 01:0a.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11) ... 01:0a.0 0400: 109e:036e (rev 11) Subsystem: 008a:763c Flags: bus master, medium devsel, latency 64, IRQ 58 Memory at dfffe000 (32-bit, prefetchable) [size=4K] Capabilities: [44] Vital Product Data Capabilities: [4c] Power Management version 2 01:0a.1 0480: 109e:0878 (rev 11) Subsystem: 008a:763c Flags: bus master, medium devsel, latency 64, IRQ 58 Memory at dffff000 (32-bit, prefetchable) [size=4K] Capabilities: [44] Vital Product Data Capabilities: [4c] Power Management version 2 It was being detected as a GENERIC UNKNOWN CARD both by the 2.6.18 kernel and the latest v4l-dvb drivers, but it did not work at all. The card has sixteen (16) BNC video inputs, four of them on the board itself and twelve on three daughter-cards. It has a single bt878 chip, no tuner and what looks like and audio input. After doing some research I managed to get only eight channels working by forcing card=125 and those DID NOT match channels 0-7 on the card, and no audio. Based on what was working for card=125, I added the card definition block, added a specific muxsel routine and got the card working fully with xawtv, where the sixteen channels show up as Composite0 to Composite15, matching the channel labels in the card and daughter-cards. I have made no efforts yet to get audio working, but would appreciate any pointers. Signed-off-by: Ernesto Hernández-Novich <emhn@usb.ve> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7288): cx88: fix GPIO for FusionHDTV 7 Gold input selectionMichael Krufky
Fix GPIO for FusionHDTV 7 Gold tv / s-video / composite input selection. Fix card textual name to match other FusionHDTV device names. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7287): cx88: add analog support for DVICO FusionHDTV7 GoldSteven Toth
Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7262): Add support for xc3028-based boardsMauro Carvalho Chehab
This patch adds support for the following saa7134 xc3028 based boards: 132 -> AVerMedia Cardbus TV/Radio (E506R) [1461:f436] 133 -> AVerMedia Hybrid TV/Radio (A16D) [1461:f936] 134 -> Avermedia M115 [1461:a836] 135 -> Compro VideoMate T750 [185b:c900] This is based on a original patch thanks to Markus Rechberger that added xc3028 gpio init code for the above boards. This patch moves saa7134_tuner_callback to saa7134-cards, originally used only by tda8290 DVB-S boards. The callback was made more generic to support other tuners. Currently, it supports both tda8290 and xc2028/xc3028 tuners. Added also the basis for xc5000 tuner callback. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7258): Support DVB-T tuning on the DViCO FusionHDTV DVB-T ProChris Pascoe
Add support for tuning DVB-T channels on DViCO's FusionHDTV DVB-T Pro board. The IR remote and analog tuner are not supported at this time. Some changes made by Mauro Chehab to allow merging it with some other xc3028 patches. Signed-off-by: Chris Pascoe <c.pascoe@itee.uq.edu.au> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7257): cx88: Add xc2028/3028 boardsMauro Carvalho Chehab
This patch ports a patch from Markus Rechberger to work with tuner-xc2028. It adds entries for several cx88 boards with xc2038/3028 tuners. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7254): cx88: fix FusionHDTV 5 PCI nano name and enable IR supportMichael Krufky
load ir-kbd-i2c for IR remote control support on DViCO FusionHDTV 5 PCI nano Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7252): cx88: Add support for the Dvico PCI NanoSteven Toth
ATSC is known to work. SVideo / Composite should work (I have no cable to test). Analog tuner support does not work. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7230): saa7134: add support for the MSI TV@nywhere A/D v1.1 cardRussell Kliese
Signed-off-by: Russell Kliese <russell@kliese.wattle.id.au> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7229): saa7134: add support for the Creatix CTX953_V.1.4.3 HybridHermann Pitton
Signed-off-by: Hermann Pitton <hermann-pitton@arcor.de> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7226): saa7134: add support for the NXP Snake DVB-S reference designHartmut Hackmann
2008-02-18V4L/DVB (7192): Adds support for Genius TVGo A11MCEAdrian Pardini
Signed-off-by: Adrian Pardini <pardo.bsso@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7132): Add USB ID for a newer variant of Hauppauge WinTV-HVR 900Luc Saillard
Device description: WinTV-HVR-900 M/R: 65018/B3C0 ##4207 Signed-off-by: Luc Saillard <luc@saillard.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7085): saa7134: detect the LifeView FlyDVB-T Hybrid Mini PCIHermann Pitton
Thanks to Angelo Lisco for his initial patch we missed and to Ahmet Dogan Ugurel confirming such a device functional. Signed-off-by: Hermann Pitton <hermann-pitton@arcor.de> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7084): saa7134: add support for the Medion / Creatix CTX948 cardHermann Pitton
This adds support for analog inputs and DVB-T. Good sensitivity for DVB-T currently needs to use analog TV first. DVB-S support is not yet completed, but is on the way. Signed-off-by: Hermann Pitton <hermann-pitton@arcor.de> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7082): support for Twinhan Hybrid DTV-DVB 3056 PCIHermann Pitton
S-Video is unconfirmed, but likely correct. The remote is not yet investigated. Thanks go to Sioux for providing code and asking to fix the auto detection. Signed-off-by: sioux <sioux_it@libero.it> Signed-off-by: Hermann Pitton <hermann-pitton@arcor.de> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7081): zr364xx: add support for Creative DiVi CAM 516Antoine Jacquet
Signed-off-by: Antoine Jacquet <royale@zerezo.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7080): zr364xx: add support for Pentax Optio 50Antoine Jacquet
2008-02-18V4L/DVB (7079): zr364xx: fix typo in documentationAntoine Jacquet
2008-01-25V4L/DVB (7043): New card supported(partially): Pinnacle 800iSteven Toth
From Zhang: This patch continues the support for the Pinnacle HD 800i. Patch committed as-is, cleanups to follow ... Steve Signed-off-by: Chaogui Zhang <czhang1974@gmail.com> Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (7042): xc5000: Tuner analog supportSteven Toth
From Zhang: This an updated patch that adds analog support for the xc5000 tuner driver. it was tested on a Pinnacle PCTV HD 800i card (patches to follow). Patch commited as-is, cleanup to follow ... Steve. Signed-off-by: Chaogui Zhang <czhang1974@gmail.com> Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (7020): Add USB ID for a newer variant of Hauppauge WinTV USB2Mauro Carvalho Chehab
Thanks to Jeroen Janssen <Jeroen.Janssen@vub.ac.be> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (7017): saa7134: add MSI TV@nywhere Plus with the older tda8275 tunerHermann Pitton
Thanks go to Mark Schultz for the initial contribution and to Dean Hilkewich for testing it again. Signed-off-by: Hermann Pitton <hermann-pitton@arcor.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6994): usbvision: add Pinnacle Studio PCTV USB (NTSC) FM V3Thierry MERLE
Add the "Pinnacle Studio PCTV USB (NTSC) FM" device. This is the third occurrence of the same device designation... Signed-off-by: Thierry MERLE <thierry.merle@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6993): Fix CARDLIST.saa7134Mauro Carvalho Chehab
2008-01-25V4L/DVB (6975): Add missing entry for Beholder BeholdTV 407Mauro Carvalho Chehab
Acked-by: Andrey J. Melnikov <temnota@kmv.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6973): Add Beholder TV 401/405/407/409/505/507/609/M6 supportAndrey J. Melnikoff (TEMHOTA)
This patch updates cardlist for Beholder TV tuners: old models (with GPIO ir) 401, 403, 405, 407, 409, 505, 507 and add support for 607, 609, M6 cards with new i2c-ir. Signed-off-by: Igor Kuznetsov <igk72@yandex.ru> Signed-off-by: Andrey J. Melnikov <temnota@kmv.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6938): Add a tool for extracting xc3028 version 2.7 firmwareMauro Carvalho Chehab
This tool allows the extraction of xc3028 v2.7 firmware from HVR 12x0 file. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6935): cx23885: add missing subsystem IDs for Hauppauge HVR1500 RetailMichael Krufky
2008-01-25V4L/DVB (6932): cx23885: add missing subsystem ID for Hauppauge HVR1800 RetailMichael Krufky
2008-01-25V4L/DVB (6898): cx23885: add support for Hauppauge WinTV HVR-1500Michael Krufky
2008-01-25V4L/DVB (6885): Add support for the Hauppauge HVR1500QSteven Toth
The express card ATSC/QAM tuner. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (em28xx): Add support for Pinnacle Dazzle DVC 100Aurelien Jarno
The patch below adds the "Pinnacle Dazzle DVC 100" to the list of cards supported by the em28xx driver. As the configuration is the same as the DVC 90 one, it simply adds a new USB ID to the list of devices supported by the DVC 90 configuration. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
