Adds support for cx23885 card Mygica X8558 Pro DMB-TH
Signed-off-by: David T. L. Wong <davidtlwong@gmail.com>
WinTV-HVR1290
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com>
Signed-off-by: Jean-Francois Moine <moinejf@free.fr>
gscpa_mr97310a: Add Trust Spyc@m 100 USB ID
Signed-off-by: Aurelien Jacobs <aurel@gnuage.org>
Thanks to Terry Wu for finding the GPIOs required for svideo / composite input
Cc: Terry Wu <terrywu2009@gmail.com>
SubVendor ID: 0x1043 Device ID: 0x4847)
Adds the device IDs and driver linking to allow the Asus Europa DVB-T
card to operate with these drivers.
The device has a SAA7134 chipset with a TD1316 Hybrid Tuner.
All inputs work on the card including switching between DVB-T and
Analogue TV, there is also no IR with this card.
[mchehab@redhat.com: CodingStyle fixes]
Signed-off-by: Danny Wood <danwood76@gmail.com>
Signed-off-by: Rafal Milecki <zajec5@gmail.com>
Seems that the reference design used for the KWorld 2800d switched from the
em2860 to em2862, so we need to add the new USB id (and the i2c hash remains
so all we need is the default em2862 id.
Thanks to Ian Young for reporting the issue and testing the fix.
Cc: Ian Young <ian@duffrecords.com>
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
Fix up -Wmissing-prototypes in compileable userspace code, mainly under
Documentation/.
Signed-off-by: Ladinu Chandrasinghe <ladinu.pub@gmail.com>
Signed-off-by: Trevor Keith <tsrk@tsrk.net>
Adding Compro VideoMate E800 (DVB-T part only)
Cc: Steven Toth <stoth@linuxtv.org>
Signed-off-by: Vladimir Geroy <geroin22@yandex.ru>
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
http://linuxtv.org/wiki/index.php/Zolid_Hybrid_TV_Tuner
test status analog (PAL-B):
- Sometimes picture is noisy, but it becomes crystal clear after
switching between channels. (happens for example at 687.25 Mhz)
- On a lower frequency (511.25 Mhz) the picture is always sharp, but
lacks colour.
- No sound problems.
- radio untested.
Digital:
- DVB-T/H stream reception works.
- Would expect to see some more channels in the higher frequency region.
Overall is the impression that sensitivity still needs improvement
both in analog and digital modes.
Signed-off-by: Henk Vergonet <Henk.Vergonet@gmail.com>
function
Warn when the desired device node number is already in use, except when
the new video_register_device_no_warn function is called since in some
use-cases that warning is not relevant.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
The term 'kernel number' is very vague, so replace it with the somewhat more
descriptive term 'device node number'.
In one place the local variable 'nr' was used to create the device node number
of the new device name. This has been replaced with the vdev->num field to
more clearly mark this as being the device node number and not the minor
number.
video_register_device_index is never actually called, instead the
stream index number is always calculated automatically.
This patch removes this function and simplifies the internal get_index
function since that can now always just return the first free index.
Rewrite v4l2_i2c_new_subdev as a simplified version of v4l2_i2c_new_subdev_cfg
and remove v4l2_i2c_new_probed_subdev and v4l2_i2c_new_probed_subdev_addr.
This simplifies this API substantially.
(S_CROP)
The initial soc-camera scaling and cropping implementation turned out to be
incompliant with the V4L2 API, e.g., it expected the user to specify cropping
in output window pixels, instead of input window pixels. This patch converts
the soc-camera core and all drivers to comply with the standard.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Add support for NXP TDA18271 as a standalone tuner, allowing the use of
analog demodulators other than the Philips/NXP TDA829x.
- add the Genesys Logic 05e3:0503 and 05e3:f191 webcam
Signed-off-by: Olivier Lorin <o.lorin@laposte.net>
Support for Reddo DVB-C USB TV Box device. Remote is not working yet.
Thanks to Benjamin Larsson <banan@ludd.ltu.se>
Cc: Benjamin Larsson <banan@ludd.ltu.se>
Signed-off-by: Antti Palosaari <crope@iki.fi>
add Philips CU1216L NIM
SAA7164: Add support for a new HVR-2250 hardware revision
Signed-off-by: Steven Toth <stoth@kernellabs.com>
boards.
This patch adds support for all of the known shipping Hauppauge HVR-2200
and HVR-2250 boards. Digital TV ATSC/QAM and DVB-T is enabled at this
time. Both tuners are supported.
Volatiles and typedefs need rework, the rest is coding style compliant.
Added Kworld DVD Maker 2
Thanks to C Western <l@c-m-w.me.uk> for reporting this board.
Signed-off-by: Stephane Marguet (Stemp) <smarguet@gmail.com>
[mchehab@redhat.com: Fix a few wrong IR keymaps]
Signed-off-by: Shine Liu <shinel@foxmail.com>
This patch add support for RoverMedia TV Link Pro FM (LR138 REV:I) card
based on saa7134.
Signed-off-by: Eugene Yudin <Eugene.Yudin@gmail.com>
Add support our new TV card based on xc5000 and saa7134.
Analog TV works well.
Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com>
Added support to AverMedia Studio 505
[dougsland@redhat.com: fixed rejects and removed the change to add dk as default secam variant]
[mchehab@redhat.com: fix a few CodingStyle issues]
Signed-off-by: Vasiliy Temnikov <vaka@newmail.ru>
This patch adds a document file for si4713 device driver.
It describes the driver interfaces and organization.
Signed-off-by: Eduardo Valentin <eduardo.valentin@nokia.com>
Patch solves problem of missed keystrokes on some remote controls,
as reported on http://bugzilla.kernel.org/show_bug.cgi?id=9637 .
Signed-off-by: Andrzej Hajda <andrzej.hajda@wp.pl>
Signed-off-by: Theodore Kilgore <kilgota@auburn.edu>
I updated and simplyfied patch from Zbynek Hrabovsky for recent kernel.
It enables autodetection of card, sound in analog TV , sound in FM radio
and switching between antenna and cable RF input. Radio tuner still
doesn't work, I don't even know how it works. Some guys wrote me that FM
radio works with TV tuner used instead of radio part (symlink video0 ->
radio0).
Cc: Gerd Knorr <kraxel@bytesex.org>
Signed-off-by: Vlastimil Labsky <vlasta.labsky@gmail.com>
Fixed the c-qcam source code path in the linux kernel tree.
Signed-off-by: Mhayk Whandson <eu@mhayk.com.br>
Signed-off-by: Denis Loginov <dinvlad@gmail.com>
tuner
Signed-off-by: Andy Walls <awalls@radix.net>
cx23885: Add support for ATSC/QAM on Hauppauge HVR-1850
Signed-off-by: Johannes Goerner <johannes-goerner@gmx.de>
cx23885: add card Magic-Pro ProHDTV Extreme 2 PCI-E.
Signed-off-by: David T.L. Wong <davidtlwong@gmail.com>
Only the back sensor (mi1320_soc) is usable.
em28xx: Add support for Gadmei UTV330+
Signed-off-by: Zhenyu Wang <zhen78@gmail.com>
Thanks to hermann pitton <hermann-pitton@arcor.de> for pointing this new
variation.
Tested-by: hermann pitton <hermann-pitton@arcor.de>
WinTV-HVR1120 DVB-T/Hybrid
WinTV-HVR1150 ATSC/QAM-Hybrid
Signed-off-by: Brian Johnson <brijohn@gmail.com>
Webcams in general don't have eeprom. So, the sensor hint code should be
called to properly detect what sensor is inside.
This webcam uses a em2710 chipset, that identifies itself as em2820,
plus a mt9v011 sensor, and a DY-301P lens.
It needs a few different initializations than a normal em28xx device.
Thanks to Hans de Goede <hdegoede@redhat.com> and Douglas Landgraf
<dougsland@redhat.com> for providing the acces for the webcam during
this weekend, I could make a patch for it while returning back from
FISL/Fudcom LATAM 2009.
