path: root/Documentation/video4linux
2009-12-09Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (345 commits) V4L/DVB (13542): ir-keytable: Allow dynamic table change V4L/DVB (13541): atbm8830: replace 64-bit division and floating point usage V4L/DVB (13540): ir-common: Cleanup get key evdev code V4L/DVB (13539): ir-common: add __func__ for debug messages V4L/DVB (13538): ir-common: Use a dynamic keycode table V4L/DVB (13537): ir: Prepare the code for dynamic keycode table allocation V4L/DVB (13536): em28xx: Use the full RC5 code on HVR-950 Remote Controller V4L/DVB (13535): ir-common: Add a hauppauge new table with the complete RC5 code V4L/DVB (13534): ir-common: Remove some unused fields/structs V4L/DVB (13533): ir: use dynamic tables, instead of static ones V4L/DVB (13532): ir-common: Add infrastructure to use a dynamic keycode table V4L/DVB (13531): ir-common: rename the debug routine to allow exporting it V4L/DVB (13458): go7007: subdev conversion V4L/DVB (13457): s2250: subdev conversion V4L/DVB (13456): s2250: Change module structure V4L/DVB (13528): em28xx: add support for em2800 VC211A card em28xx: don't reduce scale to half size for em2800 em28xx: don't load audio modules when AC97 is mis-detected em28xx: em2800 chips support max width of 640 V4L/DVB (13523): dvb-bt8xx: fix compile warning ... Fix up trivial conflicts due to spelling fixes from the trivial tree in Documentation/video4linux/gspca.txt drivers/media/video/cx18/cx18-mailbox.h
2009-12-05V4L/DVB (13528): em28xx: add support for em2800 VC211A cardMauro Carvalho Chehab
Adds support to VC211A em2800 card. As this board doesn't have eeprom, and uses a common set of i2c address, it has no way to add any autodetection for it. The patch were tested by me and by Raimundo on his board. Thanks to those tests, several bugs related to em2800 support were corrected. for producing the usbsnoop dump, used to get the gpio's and allowing me to remotelly access his machine and to the needed tests. Thanks-to: Raimundo Eduvirgnes de Oliveira <eduvirgens@yahoo.com.br> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13476): spec: remove old dvb-spec and v4l2-spec directoriesHans Verkuil
It was really confusing to have media-specs, v4l2-spec and dvb-spec. So this patch removes v4l2-spec and dvb-spec. The docs in dvb-spec and the V4L1_API.html file were moved to media-specs/old-docs. Removed all references to v4l2-spec and dvb-spec. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13438): zr364xx: add support for Trust Powerc@m 910ZAntoine Jacquet
Tested-by: Enrique Dominguez <enrique.pinos@gmail.com> Signed-off-by: Antoine Jacquet <royale@zerezo.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13420): gspca - doc: Change the name of some webcams.Jean-Francois Moine
Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13407): Add Prof 7301 PCI DVB-S2 cardIgor M. Liplianin
Add Prof 7301 PCI DVB-S2 card The card based on stv0903 demod, stb6100 tuner. Signed-off-by: Igor M. Liplianin <liplianin@me.by> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13375): cx23885: Add support for Mygica X8558Pro DMB-THDavid T. L. Wong
Adds support for cx23885 card Mygica X8558 Pro DMB-TH Signed-off-by: David T. L. Wong <davidtlwong@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13347): cx23885: add digital television support for Hauppauge ↵Michael Krufky
WinTV-HVR1290 Signed-off-by: Michael Krufky <mkrufky@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13249): gspca - pac7311: Webcam 093a:2628 added.Jean-Francois Moine
2009-12-05V4L/DVB (13243): gscpa_mr97310a: Add Trust Spyc@m 100 USB IDAurelien Jacobs
gscpa_mr97310a: Add Trust Spyc@m 100 USB ID Signed-off-by: Aurelien Jacobs <aurel@gnuage.org> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13204): saa7134: add support for the Leadtek DTV1000SMichael Krufky
Thanks to Terry Wu for finding the GPIOs required for svideo / composite input Cc: Terry Wu <terrywu2009@gmail.com> Signed-off-by: Michael Krufky <mkrufky@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13168): Add support for Asus Europa Hybrid DVB-T card (SAA7134 ↵Danny Wood
SubVendor ID: 0x1043 Device ID: 0x4847) Adds the device IDs and driver linking to allow the Asus Europa DVB-T card to operate with these drivers. The device has a SAA7134 chipset with a TD1316 Hybrid Tuner. All inputs work on the card including switching between DVB-T and Analogue TV, there is also no IR with this card. [mchehab@redhat.com: CodingStyle fixes] Signed-off-by: Danny Wood <danwood76@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13116): gspca - ov519: Webcam 041e:4067 added.Rafal Milecki
Signed-off-by: Rafal Milecki <zajec5@gmail.com> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13077): em28xx: Add support for new variant of KWorld 2800dDevin Heitmueller
Seems that the reference design used for the KWorld 2800d switched from the em2860 to em2862, so we need to add the new USB id (and the i2c hash remains so all we need is the default em2862 id. Thanks to Ian Young for reporting the issue and testing the fix. Cc: Ian Young <ian@duffrecords.com> Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-23Documentation/: fix warnings from -Wmissing-prototypes in HOSTCFLAGSLadinu Chandrasinghe
Fix up -Wmissing-prototypes in compileable userspace code, mainly under Documentation/. Signed-off-by: Ladinu Chandrasinghe <ladinu.pub@gmail.com> Signed-off-by: Trevor Keith <tsrk@tsrk.net> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-19V4L/DVB (13014): Add support for Compro VideoMate E800 (DVB-T part only)Vladimir Geroy
Adding Compro VideoMate E800 (DVB-T part only) Cc: Steven Toth <stoth@linuxtv.org> Signed-off-by: Vladimir Geroy <geroin22@yandex.ru> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (13002): Adds support for Zolid Hybrid PCI card:Henk Vergonet
http://linuxtv.org/wiki/index.php/Zolid_Hybrid_TV_Tuner test status analog (PAL-B): - Sometimes picture is noisy, but it becomes crystal clear after switching between channels. (happens for example at 687.25 Mhz) - On a lower frequency (511.25 Mhz) the picture is always sharp, but lacks colour. - No sound problems. - radio untested. Digital: - DVB-T/H stream reception works. - Would expect to see some more channels in the higher frequency region. Overall is the impression that sensitivity still needs improvement both in analog and digital modes. Signed-off-by: Henk Vergonet <Henk.Vergonet@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12725): v4l: warn when desired devnodenr is in use & add _no_warn ↵Hans Verkuil
function Warn when the desired device node number is already in use, except when the new video_register_device_no_warn function is called since in some use-cases that warning is not relevant. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12722): v4l2-dev: replace 'kernel number' by 'device node number'.Hans Verkuil
The term 'kernel number' is very vague, so replace it with the somewhat more descriptive term 'device node number'. In one place the local variable 'nr' was used to create the device node number of the new device name. This has been replaced with the vdev->num field to more clearly mark this as being the device node number and not the minor number. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12541): v4l: remove video_register_device_indexHans Verkuil
video_register_device_index is never actually called, instead the stream index number is always calculated automatically. This patch removes this function and simplifies the internal get_index function since that can now always just return the first free index. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12540): v4l: simplify v4l2_i2c_new_subdev and friendsHans Verkuil
Rewrite v4l2_i2c_new_subdev as a simplified version of v4l2_i2c_new_subdev_cfg and remove v4l2_i2c_new_probed_subdev and v4l2_i2c_new_probed_subdev_addr. This simplifies this API substantially. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12534): soc-camera: V4L2 API compliant scaling (S_FMT) and cropping ↵Guennadi Liakhovetski
(S_CROP) The initial soc-camera scaling and cropping implementation turned out to be incompliant with the V4L2 API, e.g., it expected the user to specify cropping in output window pixels, instead of input window pixels. This patch converts the soc-camera core and all drivers to comply with the standard. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12964): tuner-core: add support for NXP TDA18271 without TDA829X demodMichael Krufky
Add support for NXP TDA18271 as a standalone tuner, allowing the use of analog demodulators other than the Philips/NXP TDA829x. Signed-off-by: Michael Krufky <mkrufky@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12954): gspca - gl860: Addition of GL860 based webcamsOlivier Lorin
- add the Genesys Logic 05e3:0503 and 05e3:f191 webcam Signed-off-by: Olivier Lorin <o.lorin@laposte.net> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12951): em28xx: add Reddo DVB-C USB TV BoxAntti Palosaari
Support for Reddo DVB-C USB TV Box device. Remote is not working yet. Thanks to Benjamin Larsson <banan@ludd.ltu.se> Cc: Benjamin Larsson <banan@ludd.ltu.se> Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12950): tuner-simple: add Philips CU1216LAntti Palosaari
add Philips CU1216L NIM Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12946): SAA7164: Add support for a new HVR-2250 hardware revisionSteven Toth
SAA7164: Add support for a new HVR-2250 hardware revision Signed-off-by: Steven Toth <stoth@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12931): SAA7164: Fix the 88021 definition to work with production ↵Steven Toth
boards. Signed-off-by: Steven Toth <stoth@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12923): SAA7164: Add support for the NXP SAA7164 siliconSteven Toth
This patch adds support for all of the known shipping Hauppauge HVR-2200 and HVR-2250 boards. Digital TV ATSC/QAM and DVB-T is enabled at this time. Both tuners are supported. Volatiles and typedefs need rework, the rest is coding style compliant. Signed-off-by: Steven Toth <stoth@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-14V4L/DVB (12720): em28xx-cards: Add vendor/product id for Kworld DVD Maker 2Douglas Schilling Landgraf
Added Kworld DVD Maker 2 Thanks to C Western <l@c-m-w.me.uk> for reporting this board. Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12690): gspca - pac7311: Webcam 06f8:3009 added.Stephane Marguet (Stemp)
Signed-off-by: Stephane Marguet (Stemp) <smarguet@gmail.com> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12591): em28xx: Add entry for GADMEI UTV330+ and related IR keymapMauro Carvalho Chehab
[mchehab@redhat.com: Fix a few wrong IR keymaps] Signed-off-by: Shine Liu <shinel@foxmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12589): Add support for RoverMedia TV Link Pro FMEugene Yudin
This patch add support for RoverMedia TV Link Pro FM (LR138 REV:I) card based on saa7134. Signed-off-by: Eugene Yudin <Eugene.Yudin@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12587): Add support BeholdTV X7 cardDmitri Belimov
Add support our new TV card based on xc5000 and saa7134. Analog TV works well. Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12574): support AverMedia Studio 505Vasiliy Temnikov
Added support to AverMedia Studio 505 [dougsland@redhat.com: fixed rejects and removed the change to add dk as default secam variant] [mchehab@redhat.com: fix a few CodingStyle issues] Signed-off-by: Vasiliy Temnikov <vaka@newmail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12554): FM TX: si4713: Add document fileEduardo Valentin
This patch adds a document file for si4713 device driver. It describes the driver interfaces and organization. Signed-off-by: Eduardo Valentin <eduardo.valentin@nokia.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12465): cx88: High resolution timer for Remote ControlsAndrzej Hajda
Patch solves problem of missed keystrokes on some remote controls, as reported on http://bugzilla.kernel.org/show_bug.cgi?id=9637 . Signed-off-by: Andrzej Hajda <andrzej.hajda@wp.pl> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12459): gspca - jeilinj: New subdriver for Jeilin chip.Theodore Kilgore
Signed-off-by: Theodore Kilgore <kilgota@auburn.edu> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12439): cx88: add support for WinFast DTV2000H rev. JVlastimil Labsky
I updated and simplyfied patch from Zbynek Hrabovsky for recent kernel. It enables autodetection of card, sound in analog TV , sound in FM radio and switching between antenna and cable RF input. Radio tuner still doesn't work, I don't even know how it works. Some guys wrote me that FM radio works with TV tuner used instead of radio part (symlink video0 -> radio0). Cc: Gerd Knorr <kraxel@bytesex.org> Signed-off-by: Vlastimil Labsky <vlasta.labsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12370): v4l doc: fix cqcam source code pathMhayk Whandson
Fixed the c-qcam source code path in the linux kernel tree. Signed-off-by: Mhayk Whandson <eu@mhayk.com.br> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12356): gspca - sonixj: Webcam 0c45:6148 addedDenis Loginov
Signed-off-by: Denis Loginov <dinvlad@gmail.com> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12334): tuner-simple: Add an entry for the Partsnic PTI-5NF05 NTSC ↵Andy Walls
tuner Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12306): cx23885: Add support for ATSC/QAM on Hauppauge HVR-1850Steven Toth
cx23885: Add support for ATSC/QAM on Hauppauge HVR-1850 Signed-off-by: Steven Toth <stoth@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12281): gspca - sunplus: Webcam 052b:1803 added.Johannes Goerner
Signed-off-by: Johannes Goerner <johannes-goerner@gmx.de> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12272): cx23885: add card Magic-Pro ProHDTV Extreme 2David Wong
cx23885: add card Magic-Pro ProHDTV Extreme 2 PCI-E. Signed-off-by: David T.L. Wong <davidtlwong@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12228): gspca - vc032x: Webcam 0ac8:c301 added.Jean-Francois Moine
Only the back sensor (mi1320_soc) is usable. Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12227): gspca - pac7311: Webcam 093a:2629 added.Jean-Francois Moine
2009-09-12V4L/DVB (12190): em28xx: Add support for Gadmei UTV330+Zhenyu Wang
em28xx: Add support for Gadmei UTV330+ Signed-off-by: Zhenyu Wang <zhen78@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-08-13V4L/DVB (12402): em28xx: fix: some em2710 chips use a different vendor IDMauro Carvalho Chehab
Thanks to hermann pitton <hermann-pitton@arcor.de> for pointing this new variation. Tested-by: hermann pitton <hermann-pitton@arcor.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
