path: root/Documentation/video4linux
2014-05-06media: media: gspca: sn9c20x: add ID for Genius Look 1320 V2Wolfram Sang
commit 61f0319193c44adbbada920162d880b1fdb3aeb3 upstream. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-18[media] v4l2: Add a V4L2 driver for SI476X MFDAndrey Smirnov
This commit adds a driver that exposes all the radio related functionality of the Si476x series of chips via the V4L2 subsystem. [mchehab@redhat.com: change it to depends on MFD_SI476X_CORE instead of selecting it; vidioc_s_register now uses const struct] Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Andrey Smirnov <andrew.smirnov@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-04-17Revert "[media] v4l2: Add a V4L2 driver for SI476X MFD"Mauro Carvalho Chehab
As requested by Andrey Smirnov <andrew.smirnov@gmail.com>, revert this patch. This reverts commit 30bac9110455402fa8888740c6819dd3daa2666f. Conflicts: drivers/media/radio/Kconfig drivers/media/radio/radio-si476x.c Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-29[media] v4l2: Add a V4L2 driver for SI476X MFDAndrey Smirnov
This commit adds a driver that exposes all the radio related functionality of the Si476x series of chips via the V4L2 subsystem. Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Andrey Smirnov <andrew.smirnov@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-24[media] tuner: add Sony BTF tunersHans Verkuil
This adds support for three Sony BTF tuners: TUNER_SONY_BTF_PG472Z: PAL+SECAM TUNER_SONY_BTF_PK467Z: NTSC-M-JP TUNER_SONY_BTF_PB463Z: NTSC-M These come from the go7007 staging driver where they were implemented in the wis-sony-tuner i2c driver. Adding support for these tuners to tuner-types.c is the first step towards removing the wis-sony-tuner driver. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-19[media] em28xx: update cardlistMauro Carvalho Chehab
There's one missing USB ID at the card list. Add it. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-19[media] em28xx: Add ISDB support for c3tech Digital duoMauro Carvalho Chehab
This is an hybrid board. However, for analog, it requires a new driver for saa7136. So, for now, let's just add support for Digital TV. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-02-13[media] radio-si470x doc: add info about v4l2-ctl and sox+alsaAlexey Klimov
Patch adds information about using v4l2-ctl utility to tune the si470x radio and example how to use sox+alsa to redirect sound from radio sound device to another sound device. Signed-off-by: Alexey Klimov <klimov.linux@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-02-08[media] Documentation: update V4L cardlistsMauro Carvalho Chehab
2013-02-08[media] saa7134: Add capture card Hawell HW-9004V1Vadim Frolov
This patch adds new capture board Hawell HW-9004V1. This card has 4 SAA71300 chips. In order to work it is needed to initialize its registers (gpio mask and value). The value of these registers were dumped under Windows using flytest. Signed-off-by: Vadim Frolov <fralik@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-01-24Merge branch 'v4l_for_linus' into staging/for_v3.9Mauro Carvalho Chehab
* v4l_for_linus: (464 commits) [media] uvcvideo: Set error_idx properly for S_EXT_CTRLS failures [media] uvcvideo: Cleanup leftovers of partial revert [media] uvcvideo: Return -EACCES when trying to set a read-only control Linux 3.8-rc3 mm: reinstante dropped pmd_trans_splitting() check cred: Remove tgcred pointer from struct cred drm/ttm: fix fence locking in ttm_buffer_object_transfer ARM: clps711x: Fix bad merge of clockevents setup ARM: highbank: save and restore L2 cache and GIC on suspend ARM: highbank: add a power request clear ARM: highbank: fix secondary boot and hotplug ARM: highbank: fix typos with hignbank in power request functions ARM: dts: fix highbank cpu mpidr values ARM: dts: add device_type prop to cpu nodes on Calxeda platforms drm/prime: drop reference on imported dma-buf come from gem xen/netfront: improve truesize tracking ARM: mx5: Fix MX53 flexcan2 clock ARM: OMAP2+: am33xx-hwmod: Fix wrongly terminated am33xx_usbss_mpu_irqs array sctp: fix Kconfig bug in default cookie hmac selection EDAC: Cleanup device deregistering path ... Conflicts: drivers/media/pci/dm1105/dm1105.c drivers/media/platform/soc_camera/mx2_camera.c
2013-01-11[media] extract_xc3028.pl: fix permissionsMauro Carvalho Chehab
This is an executable file. Change permissions to reflect it. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-01-06[media] s5p-fimc: Fix typo of URL pointing to Media Controller API'sPrabhakar Lad
Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-01-05[media] v4l2-ctrls: add a notify callbackHans Verkuil
Sometimes platform/bridge drivers need to be notified when a control from a sub-device changes value. In order to support this a notify callback was added. [dheitmueller@kernellabs.com: fix merge conflict in v4l2-ctrls.c] Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-01-03Documentation: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from the kernel documentation. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-27Merge tag 'v3.8-rc1' into staging/for_v3.9Mauro Carvalho Chehab
Linux 3.8-rc1 * tag 'v3.8-rc1': (10696 commits) Linux 3.8-rc1 Revert "nfsd: warn on odd reply state in nfsd_vfs_read" ARM: dts: fix duplicated build target and alphabetical sort out for exynos dm stripe: add WRITE SAME support dm: remove map_info dm snapshot: do not use map_context dm thin: dont use map_context dm raid1: dont use map_context dm flakey: dont use map_context dm raid1: rename read_record to bio_record dm: move target request nr to dm_target_io dm snapshot: use per_bio_data dm verity: use per_bio_data dm raid1: use per_bio_data dm: introduce per_bio_data dm kcopyd: add WRITE SAME support to dm_kcopyd_zero dm linear: add WRITE SAME support dm: add WRITE SAME support dm: prepare to support WRITE SAME dm ioctl: use kmalloc if possible ... Conflicts: MAINTAINERS
2012-12-21[media] Documentation/media: Remove docs for obsoleted and removed v4l1 driversHans de Goede
When the v4l1 drivers were removed, there docs were forgotten. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-12-20[media] media: soc-camera: update documentationGuennadi Liakhovetski
Update soc-camera documentation to reflect the current camera host API and the use of the common V4L2 subdev API. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-12-18[media] Documentation: fix outdated statement re. v4l2Nicolas THERY
Fix tense used for describing struct v4l2_fh as it has been added a while ago. Signed-off-by: Nicolas Thery <nicolas.thery@st.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-11-19doc: fix quite a few typos within DocumentationMasanari Iida
Correct spelling typo in Documentations Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-11-19treewide: fix typo of "suport" in various comments and KconfigMasanari Iida
Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-10-05[media] media: v4l2-ctrl: add a helper function to add standard control with ↵Lad, Prabhakar
driver specific menu Add helper function v4l2_ctrl_new_std_menu_items(), which adds a standard menu control, with driver specific menu. Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com> Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-10-01[media] v4l2-ctrls: add a filter function to v4l2_ctrl_add_handlerHans Verkuil
With a filter function you can control more precisely which controls are added. This is useful in particular for radio device nodes for combined TV/Radio cards where you want to show just the radio-specific controls and not controls like brightness. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-26[media] Add vfl_dir field documentationHans Verkuil
2012-09-25[media] v4l: Documentation: change path of video driversLad, Prabhakar
due to structure change for video drivers, change the description with correct path. Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com> Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-23[media] Add support for Prof Revolution DVB-S2 8000 PCI-E cardMariusz Bia?o?czyk
The device is based on STV0903 demodulator, STB6100 tuner and CX23885 chipset; subsystem id: 8000:3034 This is a modified version of the official Prof Tuners Group patch: http://www.proftuners.com/sites/default/files/prof8000_0.patch [mchehab@redhat.com: trivial merge conflict fixup] Signed-off-by: Mariusz Bialonczyk <manio@skyboo.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-07-31Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull second set of media updates from Mauro Carvalho Chehab: - radio API: add support to work with radio frequency bands - new AM/FM radio drivers: radio-shark, radio-shark2 - new Remote Controller USB driver: iguanair - conversion of several drivers to the v4l2 core control framework - new board additions at existing drivers - the remaining (and vast majority of the patches) are due to drivers/DocBook fixes/cleanups. * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (154 commits) [media] radio-tea5777: use library for 64bits div [media] tlg2300: Declare MODULE_FIRMWARE usage [media] lgs8gxx: Declare MODULE_FIRMWARE usage [media] xc5000: Add MODULE_FIRMWARE statements [media] s2255drv: Add MODULE_FIRMWARE statement [media] dib8000: move dereference after check for NULL [media] Documentation: Update cardlists [media] bttv: add support for Aposonic W-DVR [media] cx25821: Remove bad strcpy to read-only char* [media] pms.c: remove duplicated include [media] smiapp-core.c: remove duplicated include [media] via-camera: pass correct format settings to sensor [media] rtl2832.c: minor cleanup [media] Add support for the IguanaWorks USB IR Transceiver [media] Minor cleanups for MCE USB [media] drivers/media/dvb/siano/smscoreapi.c: use list_for_each_entry [media] Use a named union in struct v4l2_ioctl_info [media] mceusb: Add Twisted Melon USB IDs [media] staging/media/solo6x10: use module_pci_driver macro [media] staging/media/dt3155v4l: use module_pci_driver macro ... Conflicts: Documentation/feature-removal-schedule.txt
2012-07-30[media] Documentation: Update cardlistsMauro Carvalho Chehab
2012-07-30[media] bttv: add support for Aposonic W-DVRTony Gentile
Forwarded-by: Gerd Hoffmann <kraxel@bytesex.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-07-30Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: "This is the first part of the media patches for v3.6. This patch series contain: - new DVB frontend: rtl2832 - new video drivers: adv7393 - some unused files got removed - a selection API cleanup between V4L2 and V4L2 subdev API's - a major redesign at v4l-ioctl2, in order to clean it up - several driver fixes and improvements." * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (174 commits) v4l: Export v4l2-common.h in include/linux/Kbuild media: Revert "[media] Terratec Cinergy S2 USB HD Rev.2" [media] media: Use pr_info not homegrown pr_reg macro [media] Terratec Cinergy S2 USB HD Rev.2 [media] v4l: Correct conflicting V4L2 subdev selection API documentation [media] Feature removal: V4L2 selections API target and flag definitions [media] v4l: Unify selection flags documentation [media] v4l: Unify selection flags [media] v4l: Common documentation for selection targets [media] v4l: Unify selection targets across V4L2 and V4L2 subdev interfaces [media] v4l: Remove "_ACTUAL" from subdev selection API target definition names [media] V4L: Remove "_ACTIVE" from the selection target name definitions [media] media: dvb-usb: print mac address via native %pM [media] s5p-tv: Use module_i2c_driver in sii9234_drv.c file [media] media: gpio-ir-recv: add allowed_protos for platform data [media] s5p-jpeg: Use module_platform_driver in jpeg-core.c file [media] saa7134: fix spelling of detach in label [media] cx88-blackbird: replace ioctl by unlocked_ioctl [media] cx88: don't use current_norm [media] cx88: fix a number of v4l2-compliance violations ...
2012-07-30[media] Documentation: Add newline at end-of-file to files lacking oneJesper Juhl
This patch simply adds a newline character at end-of-file to those files in Documentation/ that currently lack one. This is done for a few different reasons: A) It's rather annoying when you do "cat some_file.txt" that your prompt/cursor ends up at the end of the last line of output rather than on a new line. B) Some tools that process files line-by-line may get confused by the lack of a newline on the last line. C) The "\ No newline at end of file" line in diffs annoys me for some reason. So, let's just add the missing newline once and for all. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-07-20Documentation: Add newline at end-of-file to files lacking oneJesper Juhl
This patch simply adds a newline character at end-of-file to those files in Documentation/ that currently lack one. This is done for a few different reasons: A) It's rather annoying when you do "cat some_file.txt" that your prompt/cursor ends up at the end of the last line of output rather than on a new line. B) Some tools that process files line-by-line may get confused by the lack of a newline on the last line. C) The "\ No newline at end of file" line in diffs annoys me for some reason. So, let's just add the missing newline once and for all. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-07-06[media] v4l2-framework.txt: Update the locking documentationHans Verkuil
This documents the new queue->lock and how to use it. It also removes the documentation of v4l2_disable_ioctl_locking: this is only used in gspca and will be removed once gspca has been converted to vb2. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-24Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - some V4L2 API updates needed by embedded devices - DVB API extensions for ATSC-MH delivery system, used in US for mobile TV - new tuners for fc0011/0012/0013 and tua9001 - a new dvb driver for af9033/9035 - a new ATSC-MH frontend (lg2160) - new remote controller keymaps - Removal of a few legacy webcam driver that got replaced by gspca on several kernel versions ago - a new driver for Exynos 4/5 webcams(s5pp fimc-lite) - a new webcam sensor driver (smiapp) - a new video input driver for embedded (sta2x1xx) - several improvements, fixes, cleanups, etc inside the drivers. Manually fix up conflicts due to err() -> dev_err() conversion in drivers/staging/media/easycap/easycap_main.c * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (484 commits) [media] saa7134-cards: Remove a PCI entry added by mistake [media] radio-sf16fmi: add support for SF16-FMD [media] rc-loopback: remove duplicate line [media] patch for Asus My Cinema PS3-100 (1043:48cd) [media] au0828: Move the Kconfig knob under V4L_USB_DRIVERS [media] em28xx: simple comment fix [media] [resend] radio-sf16fmr2: add PnP support for SF16-FMD2 [media] smiapp: Use v4l2_ctrl_new_int_menu() instead of v4l2_ctrl_new_custom() [media] smiapp: Add support for 8-bit uncompressed formats [media] smiapp: Allow generic quirk registers [media] smiapp: Use non-binning limits if the binning limit is zero [media] smiapp: Initialise rval in smiapp_read_nvm() [media] smiapp: Round minimum pre_pll up rather than down in ip_clk_freq check [media] smiapp: Use 8-bit reads only before identifying the sensor [media] smiapp: Quirk for sensors that only do 8-bit reads [media] smiapp: Pass struct sensor to register writing commands instead of i2c_client [media] smiapp: Allow using external clock from the clock framework [media] zl10353: change .read_snr() to report SNR as a 0.1 dB [media] media: add support to gspca/pac7302.c for 093a:2627 (Genius FaceCam 300) [media] m88rs2000 - only flip bit 2 on reg 0x70 on 16th try ...
2012-05-20[media] media: add support to gspca/pac7302.c for 093a:2627 (Genius FaceCam 300)Jozsef Marton
gspca_pac7302 module supports the webcam with usb id: 093a:2627. It is a Genius FaceCam 300. The module does not need any changes but listing the usb id along with a vertical flip flag. The included patch adds this to the module source. Signed-off-by: Jozsef Marton <jmarton@users.sourceforge.net> Acked-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] v4l2-dev: rename two functionsHans Verkuil
Rename the function v4l2_dont_use_lock to v4l2_disable_ioctl_locking, and rename v4l2_dont_use_cmd to v4l2_disable_ioctl. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] v4l2-framework.txt: update the core lock documentationHans Verkuil
Thanks to Laurent Pinchart for pointing out that this information was missing. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] V4L: Add helper function for standard integer menu controlsSylwester Nawrocki
This patch adds v4l2_ctrl_new_int_menu() helper function which can be used in drivers for creating standard integer menu control with driver-specific menu item list. It is similar to v4l2_ctrl_new_std_menu(), except it doesn't have a mask parameter and an additional qmenu parameter allows passing an array of signed 64-bit integers as the menu item list. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Sakari Ailus <sakari.ailus@iki.fi> Tested-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] v4l2-framework.txt: document v4l2_dont_use_cmdHans Verkuil
2012-05-14[media] v4l2-dev: make it possible to skip locking for selected ioctlsHans Verkuil
Using the V4L2 core lock is a very robust method that is usually very good at doing the right thing. But some drivers, particularly USB drivers, may want to prevent the core from taking the lock for specific ioctls, particularly buffer queuing ioctls. The reason is that certain commands like S_CTRL can take a long time to process over USB and all the time the core has the lock, preventing VIDIOC_DQBUF from proceeding, even though a frame may be ready in the queue. This introduces unwanted latency. Since the buffer queuing commands often have their own internal lock it is often not necessary to take the core lock. Drivers can now say that they don't want the core to take the lock for specific ioctls. As it is a specific opt-out it makes it clear to the reviewer that those ioctls will need more care when reviewing. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] v4l: Implement v4l2_subdev_link_validate()Sakari Ailus
v4l2_subdev_link_validate() is the default op for validating a link. In V4L2 subdev context, it is used to call a pad op which performs the proper link check without much extra work. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] v4l: Improve sub-device documentation for pad opsSakari Ailus
Document that format related configuration is done through pad ops in case the driver does use the media framework. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] v4l: Document raw bayer 4CC codesSakari Ailus
Document guidelines how 4CC codes should be named. Only raw bayer is included currently. Other formats should be documented later on. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-07[media] v4l2-event: Add v4l2_subscribed_event_opsHans de Goede
Just like with ctrl events, drivers may want to get called back on listener add / remove for other event types too. Rather then special casing all of this in subscribe / unsubscribe event it is better to use ops for this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-19[media] V4L: fix incorrect refcountingHans Verkuil
Both radio-keene and dsbr100 did one v4l2_device_get too many. Thus the refcount never became 0 and that causes a memory leak. Also updated the V4L2 framework documentation accordingly. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-08Merge branch 'master' into for-nextJiri Kosina
Merge with latest Linus' tree, as I have incoming patches that fix code that is newer than current HEAD of for-next. Conflicts: drivers/net/ethernet/realtek/r8169.c
2012-04-05doc: fix a few typosMasanari Iida
2012-03-30Documentation: remove references to /etc/modprobe.confLucas De Marchi
Usage of /etc/modprobe.conf file was deprecated by module-init-tools and is no longer parsed by new kmod tool. References to this file are replaced in Documentation, comments and Kconfig according to the context. There are also some references to the old /etc/modules.conf from 2.4 kernels that are being removed. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - V4L2 API additions to better support JPEG compression control - media API additions to properly support MPEG decoders - V4L2 API additions for image crop/scaling - a few other V4L2 API DocBook fixes/improvements - two new DVB frontend drivers: m88rs2000 and rtl2830 - two new DVB drivers: az6007 and rtl28xxu - a framework for ISA drivers, that removed lots of common code found at the ISA radio drivers - a new FM transmitter driver (radio-keene) - a GPIO-based IR receiver driver - a new sensor driver: mt9m032 - some new video drivers: adv7183, blackfin, mx2_emmaprp, sii9234_drv, vs6624 - several new board additions, driver fixes, improvements and cleanups. * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (295 commits) [media] update CARDLIST.em28xx [media] partially reverts changeset fa5527c [media] stb0899: fix the limits for signal strength values [media] em28xx: support for 2304:0242 PCTV QuatroStick (510e) [media] em28xx: support for 2013:0251 PCTV QuatroStick nano (520e) [media] -EINVAL -> -ENOTTY [media] gspca - sn9c20x: Cleanup source [media] gspca - sn9c20x: Simplify register write for capture start/stop [media] gspca - sn9c20x: Add automatic JPEG compression mechanism [media] gspca - sn9c20x: Greater delay in case of sensor no response [media] gspca - sn9c20x: Optimize the code of write sequences [media] gspca - sn9c20x: Add the JPEG compression quality control [media] gspca - sn9c20x: Add a delay after Omnivision sensor reset [media] gspca - sn9c20x: Propagate USB errors to higher level [media] gspca - sn9c20x: Use the new video control mechanism [media] gspca - sn9c20x: Fix loss of frame start [media] gspca - zc3xx: Lack of register 08 value for sensor cs2102k [media] gspca - ov534_9: Add brightness to OmniVision 5621 sensor [media] gspca - zc3xx: Add V4L2_CID_JPEG_COMPRESSION_QUALITY control support [media] pvrusb2: fix 7MHz & 8MHz DVB-T tuner support for HVR1900 rev D1F5 ...
2012-03-19[media] update CARDLIST.em28xxMauro Carvalho Chehab
Add the new DRX-K based devices there. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
