git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio updates from Rusty Russell:
"OK, this has the big virtio 1.0 implementation, as specified by OASIS.
On top of tht is the major rework of lguest, to use PCI and virtio
1.0, to double-check the implementation.
Then comes the inevitable fixes and cleanups from that work"
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (80 commits)
virtio: don't set VIRTIO_CONFIG_S_DRIVER_OK twice.
virtio_net: unconditionally define struct virtio_net_hdr_v1.
tools/lguest: don't use legacy definitions for net device in example launcher.
virtio: Don't expose legacy net features when VIRTIO_NET_NO_LEGACY defined.
tools/lguest: use common error macros in the example launcher.
tools/lguest: give virtqueues names for better error messages
tools/lguest: more documentation and checking of virtio 1.0 compliance.
lguest: don't look in console features to find emerg_wr.
tools/lguest: don't start devices until DRIVER_OK status set.
tools/lguest: handle indirect partway through chain.
tools/lguest: insert driver references from the 1.0 spec (4.1 Virtio Over PCI)
tools/lguest: insert device references from the 1.0 spec (4.1 Virtio Over PCI)
tools/lguest: rename virtio_pci_cfg_cap field to match spec.
tools/lguest: fix features_accepted logic in example launcher.
tools/lguest: handle device reset correctly in example launcher.
virtual: Documentation: simplify and generalize paravirt_ops.txt
lguest: remove NOTIFY call and eventfd facility.
lguest: remove NOTIFY facility from demonstration launcher.
lguest: use the PCI console device's emerg_wr for early boot messages.
lguest: always put console in PCI slot #1.
The general documentation we have for pv_ops is currenty present
on the IA64 docs, but since this documentation covers IA64 xen
enablement and IA64 Xen support got ripped out a while ago
through commit d52eefb47 present since v3.14-rc1 lets just
simplify, generalize and move the pv_ops documentation to a
shared place.
Cc: Isaku Yamahata <yamahata@valinux.co.jp>
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: Alok Kataria <akataria@vmware.com>
Cc: virtualization@lists.linux-foundation.org
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: xen-devel@lists.xenproject.org
Cc: kvm@vger.kernel.org
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
This patch enables cpu model support in kvm/s390 via the vm attribute
interface.
During KVM initialization, the host properties cpuid, IBC value and the
facility list are stored in the architecture specific cpu model structure.
During vcpu setup, these properties are taken to initialize the related SIE
state. This mechanism allows to adjust the properties from user space and thus
to implement different selectable cpu models.
This patch uses the IBC functionality to block instructions that have not
been implemented at the requested CPU type and GA level compared to the
full host capability.
Userspace has to initialize the cpu model before vcpu creation. A cpu model
change of running vcpus is not possible.
Signed-off-by: Michael Mueller <mimu@linux.vnet.ibm.com>
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Reviewed-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvms390/linux into kvm-next
KVM: s390: fixes and features for kvm/next (3.20)
1. Generic
- sparse warning (make function static)
- optimize locking
- bugfixes for interrupt injection
- fix MVPG addressing modes
2. hrtimer/wakeup fun
A recent change can cause KVM hangs if adjtime is used in the host.
The hrtimer might wake up too early or too late. Too early is fatal
as vcpu_block will see that the wakeup condition is not met and
sleep again. This CPU might never wake up again.
This series addresses this problem. adjclock slowing down the host
clock will result in too late wakeups. This will require more work.
In addition to that we also change the hrtimer from REALTIME to
MONOTONIC to avoid similar problems with timedatectl set-time.
3. sigp rework
We will move all "slow" sigps to QEMU (protected with a capability that
can be enabled) to avoid several races between concurrent SIGP orders.
4. Optimize the shadow page table
Provide an interface to announce the maximum guest size. The kernel
will use that to make the pagetable 2,3,4 (or theoretically) 5 levels.
5. Provide an interface to set the guest TOD
We now use two vm attributes instead of two oneregs, as oneregs are
vcpu ioctl and we don't want to call them from other threads.
6. Protected key functions
The real HMC allows to enable/disable protected key CPACF functions.
Lets provide an implementation + an interface for QEMU to activate
this the protected key instructions.
Most SIGP orders are handled partially in kernel and partially in
user space. In order to:
- Get a correct SIGP SET PREFIX handler that informs user space
- Avoid race conditions between concurrently executed SIGP orders
- Serialize SIGP orders per VCPU
We need to handle all "slow" SIGP orders in user space. The remaining
ones to be handled completely in kernel are:
- SENSE
- SENSE RUNNING
- EXTERNAL CALL
- EMERGENCY SIGNAL
- CONDITIONAL EMERGENCY SIGNAL
According to the PoP, they have to be fast. They can be executed
without conflicting to the actions of other pending/concurrently
executing orders (e.g. STOP vs. START).
This patch introduces a new capability that will - when enabled -
forward all but the mentioned SIGP orders to user space. The
instruction counters in the kernel are still updated.
Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
In order to get rid of the action_flags and to properly migrate pending SIGP
STOP irqs triggered e.g. by SIGP STOP AND STORE STATUS, we need to remember
whether to store the status when stopping.
For this reason, a new parameter (flags) for the SIGP STOP irq is introduced.
These flags further define details of the requested STOP and can be easily
migrated.
Reviewed-by: Thomas Huth <thuth@linux.vnet.ibm.com>
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
With commit c6c956b80bdf ("KVM: s390/mm: support gmap page tables with less
than 5 levels") we are able to define a limit for the guest memory size.
As we round up the guest size in respect to the levels of page tables
we get to guest limits of: 2048 MB, 4096 GB, 8192 TB and 16384 PB.
We currently limit the guest size to 16 TB, which means we end up
creating a page table structure supporting guest sizes up to 8192 TB.
This patch introduces an interface that allows userspace to tune
this limit. This may bring performance improvements for small guests.
Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
Although the GIC architecture requires us to map the MMIO regions
only at page aligned addresses, we currently do not enforce this from
the kernel side.
Restrict any vGICv2 regions to be 4K aligned and any GICv3 regions
to be 64K aligned. Document this requirement.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
With all of the GICv3 code in place now we allow userland to ask the
kernel for using a virtual GICv3 in the guest.
Also we provide the necessary support for guests setting the memory
addresses for the virtual distributor and redistributors.
This requires some userland code to make use of that feature and
explicitly ask for a virtual GICv3.
Document that KVM_CREATE_IRQCHIP only works for GICv2, but is
considered legacy and using KVM_CREATE_DEVICE is preferred.
Since the advent of VGIC dynamic initialization, this latter is
initialized quite late on the first vcpu run or "on-demand", when
injecting an IRQ or when the guest sets its registers.
This initialization could be initiated explicitly much earlier
by the users-space, as soon as it has provided the requested
dimensioning parameters.
This patch adds a new entry to the VGIC KVM device that allows
the user to manually request the VGIC init:
- a new KVM_DEV_ARM_VGIC_GRP_CTRL group is introduced.
- Its first attribute is KVM_DEV_ARM_VGIC_CTRL_INIT
The rationale behind introducing a group is to be able to add other
controls later on, if needed.
Signed-off-by: Eric Auger <eric.auger@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into HEAD
Second round of changes for KVM for arm/arm64 for v3.19; fixes reboot
problems, clarifies VCPU init, and fixes a regression concerning the
VGIC init flow.
arch/ia64/kvm/kvm-ia64.c [deleted in HEAD and modified in kvmarm]
When a vcpu calls SYSTEM_OFF or SYSTEM_RESET with PSCI v0.2, the vcpus
should really be turned off for the VM adhering to the suggestions in
the PSCI spec, and it's the sane thing to do.
Also, clarify the behavior and expectations for exits to user space with
the KVM_EXIT_SYSTEM_EVENT case.
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
It is not clear that this ioctl can be called multiple times for a given
vcpu. Userspace already does this, so clarify the ABI.
Also specify that userspace is expected to always make secondary and
subsequent calls to the ioctl with the same parameters for the VCPU as
the initial call (which userspace also already does).
Add code to check that userspace doesn't violate that ABI in the future,
and move the kvm_vcpu_set_target() function which is currently
duplicated between the 32-bit and 64-bit versions in guest.c to a common
static function in arm.c, shared between both architectures.
The implementation of KVM_ARM_VCPU_INIT is currently not doing what
userspace expects, namely making sure that a vcpu which may have been
turned off using PSCI is returned to its initial state, which would be
powered on if userspace does not set the KVM_ARM_VCPU_POWER_OFF flag.
Implement the expected functionality and clarify the ABI.
kvm/ia64 is gone, clean up Documentation too.
git://git.kernel.org/pub/scm/linux/kernel/git/kvms390/linux into HEAD
KVM: s390: Fixes for kvm/next (3.19) and stable
1. We should flush TLBs for load control instruction emulation (stable)
2. A workaround for a compiler bug that renders ACCESS_ONCE broken (stable)
3. Fix program check handling for load control
4. Documentation Fix
Documentation uses incorrect attribute names for some vm device
attributes: fix this.
No kernel ever reported KVM_CAP_DEVICE_MSIX, KVM_CAP_DEVICE_MSI,
KVM_CAP_DEVICE_ASSIGNMENT, KVM_CAP_DEVICE_DEASSIGNMENT.
This makes the documentation wrong, and no application ever
written to use these capabilities has a chance to work correctly.
The only way to detect support is to try, and test errno for ENOTTY.
That's unfortunate, but we can't fix the past.
Document the actual semantics, and drop the definitions from
the exported header to make it easier for application
developers to note and fix the bug.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
When commit 6adba5274206 (KVM: Let host know whether the guest can
handle async PF in non-userspace context.) is introduced, actually
bit 2 still is reserved and should be zero. Instead, bit 1 is 1 to
indicate if asynchronous page faults can be injected when vcpu is
in cpl == 0, and also please see this,
in the file kvm_para.h, #define KVM_ASYNC_PF_SEND_ALWAYS (1 << 1).
Signed-off-by: Tiejun Chen <tiejun.chen@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into kvm-next
Changes for KVM for arm/arm64 for 3.18
This includes a bunch of changes:
- Support read-only memory slots on arm/arm64
- Various changes to fix Sparse warnings
- Correctly detect write vs. read Stage-2 faults
- Various VGIC cleanups and fixes
- Dynamic VGIC data strcuture sizing
- Fix SGI set_clear_pend offset bug
- Fix VTTBR_BADDR Mask
- Correctly report the FSC on Stage-2 faults
virt/kvm/eventfd.c
[duplicate, different patch where the kvm-arm version broke x86.
The kvm tree instead has the right one]
This was missed in respective one_reg implementation patch.
Signed-off-by: Bharat Bhushan <Bharat.Bhushan@freescale.com>
In order to make the number of interrupts configurable, use the new
fancy device management API to add KVM_DEV_ARM_VGIC_GRP_NR_IRQS as
a VGIC configurable attribute.
Userspace can now specify the exact size of the GIC (by increments
of 32 interrupts).
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
It looks like when this was initially merged it got accidentally included
in the following section. I've just moved it back in the correct section
and re-numbered it as other ioctls have been added since.
Signed-off-by: Alex Bennée <alex.bennee@linaro.org>
Acked-by: Borislav Petkov <bp@suse.de>
In preparation for working on the ARM implementation I noticed the debug
interface was missing from the API document. I've pieced together the
expected behaviour from the code and commit messages written it up as
best I can.
vcpu exits and memslot mutations can run concurrently as long as the
vcpu does not aquire the slots mutex. Thus it is theoretically possible
for memslots to change underneath a vcpu that is handling an exit.
If we increment the memslot generation number again after
synchronize_srcu_expedited(), vcpus can safely cache memslot generation
without maintaining a single rcu_dereference through an entire vm exit.
And much of the x86/kvm code does not maintain a single rcu_dereference
of the current memslots during each exit.
We can prevent the following case:
vcpu (CPU 0) | thread (CPU 1)
1 vm exit |
2 srcu_read_unlock(&kvm->srcu) |
3 decide to cache something based on |
old memslots |
4 | change memslots
| (increments generation)
5 | synchronize_srcu(&kvm->srcu);
6 retrieve generation # from new memslots |
7 tag cache with new memslot generation |
8 srcu_read_unlock(&kvm->srcu) |
<action based on cache occurs even |
though the caching decision was based |
on the old memslots> |
<action *continues* to occur until next |
memslot generation change, which may |
be never> |
By incrementing the generation after synchronizing with kvm->srcu readers,
we ensure that the generation retrieved in (6) will become invalid soon
after (8).
Keeping the existing increment is not strictly necessary, but we
do keep it and just move it for consistency from update_memslots to
install_new_memslots. It invalidates old cached MMIOs immediately,
instead of having to wait for the end of synchronize_srcu_expedited,
which makes the code more clearly correct in case CPU 1 is preempted
right after synchronize_srcu() returns.
To avoid halving the generation space in SPTEs, always presume that the
low bit of the generation is zero when reconstructing a generation number
out of an SPTE. This effectively disables MMIO caching in SPTEs during
the call to synchronize_srcu_expedited. Using the low bit this way is
somewhat like a seqcount---where the protected thing is a cache, and
instead of retrying we can simply punt if we observe the low bit to be 1.
Cc: stable@vger.kernel.org
Signed-off-by: David Matlack <dmatlack@google.com>
Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Reviewed-by: David Matlack <dmatlack@google.com>
This patch clarifies that kvm_dirty_regs are just a hint to the kernel and
that the kernel might just ignore some flags and sync the values (like done for
acrs and gprs now).
Patch queue for ppc - 2014-08-01
Highlights in this release include:
- BookE: Rework instruction fetch, not racy anymore now
- BookE HV: Fix ONE_REG accessors for some in-hardware registers
- Book3S: Good number of LE host fixes, enable HV on LE
- Book3S: Some misc bug fixes
- Book3S HV: Add in-guest debug support
- Book3S HV: Preload cache lines on context switch
- Remove 440 support
Alexander Graf (31):
KVM: PPC: Book3s PR: Disable AIL mode with OPAL
KVM: PPC: Book3s HV: Fix tlbie compile error
KVM: PPC: Book3S PR: Handle hyp doorbell exits
KVM: PPC: Book3S PR: Fix ABIv2 on LE
KVM: PPC: Book3S PR: Fix sparse endian checks
PPC: Add asm helpers for BE 32bit load/store
KVM: PPC: Book3S HV: Make HTAB code LE host aware
KVM: PPC: Book3S HV: Access guest VPA in BE
KVM: PPC: Book3S HV: Access host lppaca and shadow slb in BE
KVM: PPC: Book3S HV: Access XICS in BE
KVM: PPC: Book3S HV: Fix ABIv2 on LE
KVM: PPC: Book3S HV: Enable for little endian hosts
KVM: PPC: Book3S: Move vcore definition to end of kvm_arch struct
KVM: PPC: Deflect page write faults properly in kvmppc_st
KVM: PPC: Book3S: Stop PTE lookup on write errors
KVM: PPC: Book3S: Add hack for split real mode
KVM: PPC: Book3S: Make magic page properly 4k mappable
KVM: PPC: Remove 440 support
KVM: Rename and add argument to check_extension
KVM: Allow KVM_CHECK_EXTENSION on the vm fd
KVM: PPC: Book3S: Provide different CAPs based on HV or PR mode
KVM: PPC: Implement kvmppc_xlate for all targets
KVM: PPC: Move kvmppc_ld/st to common code
KVM: PPC: Remove kvmppc_bad_hva()
KVM: PPC: Use kvm_read_guest in kvmppc_ld
KVM: PPC: Handle magic page in kvmppc_ld/st
KVM: PPC: Separate loadstore emulation from priv emulation
KVM: PPC: Expose helper functions for data/inst faults
KVM: PPC: Remove DCR handling
KVM: PPC: HV: Remove generic instruction emulation
KVM: PPC: PR: Handle FSCR feature deselects
Alexey Kardashevskiy (1):
KVM: PPC: Book3S: Fix LPCR one_reg interface
Aneesh Kumar K.V (4):
KVM: PPC: BOOK3S: PR: Fix PURR and SPURR emulation
KVM: PPC: BOOK3S: PR: Emulate virtual timebase register
KVM: PPC: BOOK3S: PR: Emulate instruction counter
KVM: PPC: BOOK3S: HV: Update compute_tlbie_rb to handle 16MB base page
Anton Blanchard (2):
KVM: PPC: Book3S HV: Fix ABIv2 indirect branch issue
KVM: PPC: Assembly functions exported to modules need _GLOBAL_TOC()
Bharat Bhushan (10):
kvm: ppc: bookehv: Added wrapper macros for shadow registers
kvm: ppc: booke: Use the shared struct helpers of SRR0 and SRR1
kvm: ppc: booke: Use the shared struct helpers of SPRN_DEAR
kvm: ppc: booke: Add shared struct helpers of SPRN_ESR
kvm: ppc: booke: Use the shared struct helpers for SPRN_SPRG0-7
kvm: ppc: Add SPRN_EPR get helper function
kvm: ppc: bookehv: Save restore SPRN_SPRG9 on guest entry exit
KVM: PPC: Booke-hv: Add one reg interface for SPRG9
KVM: PPC: Remove comment saying SPRG1 is used for vcpu pointer
KVM: PPC: BOOKEHV: rename e500hv_spr to bookehv_spr
Michael Neuling (1):
KVM: PPC: Book3S HV: Add H_SET_MODE hcall handling
Mihai Caraman (8):
KVM: PPC: e500mc: Enhance tlb invalidation condition on vcpu schedule
KVM: PPC: e500: Fix default tlb for victim hint
KVM: PPC: e500: Emulate power management control SPR
KVM: PPC: e500mc: Revert "add load inst fixup"
KVM: PPC: Book3e: Add TLBSEL/TSIZE defines for MAS0/1
KVM: PPC: Book3s: Remove kvmppc_read_inst() function
KVM: PPC: Allow kvmppc_get_last_inst() to fail
KVM: PPC: Bookehv: Get vcpu's last instruction for emulation
Paul Mackerras (4):
KVM: PPC: Book3S: Controls for in-kernel sPAPR hypercall handling
KVM: PPC: Book3S: Allow only implemented hcalls to be enabled or disabled
KVM: PPC: Book3S PR: Take SRCU read lock around RTAS kvm_read_guest() call
KVM: PPC: Book3S: Make kvmppc_ld return a more accurate error indication
Stewart Smith (2):
Split out struct kvmppc_vcore creation to separate function
Use the POWER8 Micro Partition Prefetch Engine in KVM HV on POWER8
Documentation/virtual/kvm/api.txt
DCR handling was only needed for 440 KVM. Since we removed it, we can also
remove handling of DCR accesses.
The KVM_CHECK_EXTENSION is only available on the kvm fd today. Unfortunately
on PPC some of the capabilities change depending on the way a VM was created.
So instead we need a way to expose capabilities as VM ioctl, so that we can
see which VM type we're using (HV or PR). To enable this, add the
KVM_CHECK_EXTENSION ioctl to our vm ioctl portfolio.
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
Unfortunately, the LPCR got defined as a 32-bit register in the
one_reg interface. This is unfortunate because KVM allows userspace
to control the DPFD (default prefetch depth) field, which is in the
upper 32 bits. The result is that DPFD always get set to 0, which
reduces performance in the guest.
We can't just change KVM_REG_PPC_LPCR to be a 64-bit register ID,
since that would break existing userspace binaries. Instead we define
a new KVM_REG_PPC_LPCR_64 id which is 64-bit. Userspace can still use
the old KVM_REG_PPC_LPCR id, but it now only modifies those fields in
the bottom 32 bits that userspace can modify (ILE, TC and AIL).
If userspace uses the new KVM_REG_PPC_LPCR_64 id, it can modify DPFD
as well.
Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru>
This adds code to check that when the KVM_CAP_PPC_ENABLE_HCALL
capability is used to enable or disable in-kernel handling of an
hcall, that the hcall is actually implemented by the kernel.
If not an EINVAL error is returned.
This also checks the default-enabled list of hcalls and prints a
warning if any hcall there is not actually implemented.
This provides a way for userspace controls which sPAPR hcalls get
handled in the kernel. Each hcall can be individually enabled or
disabled for in-kernel handling, except for H_RTAS. The exception
for H_RTAS is because userspace can already control whether
individual RTAS functions are handled in-kernel or not via the
KVM_PPC_RTAS_DEFINE_TOKEN ioctl, and because the numeric value for
H_RTAS is out of the normal sequence of hcall numbers.
Hcalls are enabled or disabled using the KVM_ENABLE_CAP ioctl for the
KVM_CAP_PPC_ENABLE_HCALL capability on the file descriptor for the VM.
The args field of the struct kvm_enable_cap specifies the hcall number
in args[0] and the enable/disable flag in args[1]; 0 means disable
in-kernel handling (so that the hcall will always cause an exit to
userspace) and 1 means enable. Enabling or disabling in-kernel
handling of an hcall is effective across the whole VM.
The ability for KVM_ENABLE_CAP to be used on a VM file descriptor
on PowerPC is new, added by this commit. The KVM_CAP_ENABLE_CAP_VM
capability advertises that this ability exists.
When a VM is created, an initial set of hcalls are enabled for
in-kernel handling. The set that is enabled is the set that have
an in-kernel implementation at this point. Any new hcall
implementations from this point onwards should not be added to the
default set without a good reason.
No distinction is made between real-mode and virtual-mode hcall
implementations; the one setting controls them both.
Bugfixes
- add IPTE to trace event decoder
- document and advertise KVM_CAP_S390_IRQCHIP
Cleanups
- Reuse kvm_vcpu_block for s390
- Get rid of tasklet for wakup processing
This series enables the "KVM_(S|G)ET_MP_STATE" ioctls on s390 to make
the cpu state settable by user space.
This is necessary to avoid races in s390 SIGP/reset handling which
happen because some SIGPs are handled in QEMU, while others are
handled in the kernel. Together with the busy conditions as return
value of SIGP races happen especially in areas like starting and
stopping of CPUs. (For example, there is a program 'cpuplugd', that
runs on several s390 distros which does automatic onlining and
offlining on cpus.)
As soon as the MPSTATE interface is used, user space takes complete
control of the cpu states. Otherwise the kernel will use the old way.
Therefore, the new kernel continues to work fine with old QEMUs.
Let's document that this is a capability that may be enabled per-vm.
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Capabilities can be enabled on a vcpu or (since recently) on a vm. Document
this and note for the existing capabilites whether they are per-vcpu or
per-vm.
This patch
- adds s390 specific MP states to linux headers and documents them
- implements the KVM_{SET,GET}_MP_STATE ioctls
- enables KVM_CAP_MP_STATE
- allows user space to control the VCPU state on s390.
If user space sets the VCPU state using the ioctl KVM_SET_MP_STATE, we can disable
manual changing of the VCPU state and trust user space to do the right thing.
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
Highlight the aspects of the ioctls that are actually specific to x86
and ia64. As defined restrictions (irqchip) and mp states may not apply
to other architectures, these parts are flagged to belong to x86 and ia64.
In preparation for the use of KVM_(S|G)ET_MP_STATE by s390.
Fix a spelling error (KVM_SET_MP_STATE vs. KVM_SET_MPSTATE) on the way.
Document the MIPS specific parts of the KVM API, including:
- The layout of the kvm_regs structure.
- The interrupt number passed to KVM_INTERRUPT.
- The registers supported by the KVM_{GET,SET}_ONE_REG interface, and
the encoding of those register ids.
- That KVM_INTERRUPT and KVM_GET_REG_LIST are supported on MIPS.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: linux-doc@vger.kernel.org
Some of the MIPS registers that can be accessed with the
KVM_{GET,SET}_ONE_REG interface have fairly long names, so widen the
Register column of the table in the KVM_SET_ONE_REG documentation to
allow them to fit.
Tabs in the table are replaced with spaces at the same time for
consistency.
KVM_SET_SIGNAL_MASK is implemented in generic code and isn't x86
specific, so document it as being applicable for all architectures.
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial into next
Pull trivial tree changes from Jiri Kosina:
"Usual pile of patches from trivial tree that make the world go round"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits)
staging: go7007: remove reference to CONFIG_KMOD
aic7xxx: Remove obsolete preprocessor define
of: dma: doc fixes
doc: fix incorrect formula to calculate CommitLimit value
doc: Note need of bc in the kernel build from 3.10 onwards
mm: Fix printk typo in dmapool.c
modpost: Fix comment typo "Modules.symvers"
Kconfig.debug: Grammar s/addition/additional/
wimax: Spelling s/than/that/, wording s/destinatary/recipient/
aic7xxx: Spelling s/termnation/termination/
arm64: mm: Remove superfluous "the" in comment
of: Spelling s/anonymouns/anonymous/
dma: imx-sdma: Spelling s/determnine/determine/
ath10k: Improve grammar in comments
ath6kl: Spelling s/determnine/determine/
of: Improve grammar for of_alias_get_id() documentation
drm/exynos: Spelling s/contro/control/
radio-bcm2048.c: fix wrong overflow check
doc: printk-formats: do not mention casts for u64/s64
doc: spelling error changes
Pull KVM updates from Paolo Bonzini:
"At over 200 commits, covering almost all supported architectures, this
was a pretty active cycle for KVM. Changes include:
- a lot of s390 changes: optimizations, support for migration, GDB
support and more
- ARM changes are pretty small: support for the PSCI 0.2 hypercall
interface on both the guest and the host (the latter acked by
Catalin)
- initial POWER8 and little-endian host support
- support for running u-boot on embedded POWER targets
- pretty large changes to MIPS too, completing the userspace
interface and improving the handling of virtualized timer hardware
- for x86, a larger set of changes is scheduled for 3.17. Still, we
have a few emulator bugfixes and support for running nested
fully-virtualized Xen guests (para-virtualized Xen guests have
always worked). And some optimizations too.
The only missing architecture here is ia64. It's not a coincidence
that support for KVM on ia64 is scheduled for removal in 3.17"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (203 commits)
KVM: add missing cleanup_srcu_struct
KVM: PPC: Book3S PR: Rework SLB switching code
KVM: PPC: Book3S PR: Use SLB entry 0
KVM: PPC: Book3S HV: Fix machine check delivery to guest
KVM: PPC: Book3S HV: Work around POWER8 performance monitor bugs
KVM: PPC: Book3S HV: Make sure we don't miss dirty pages
KVM: PPC: Book3S HV: Fix dirty map for hugepages
KVM: PPC: Book3S HV: Put huge-page HPTEs in rmap chain for base address
KVM: PPC: Book3S HV: Fix check for running inside guest in global_invalidates()
KVM: PPC: Book3S: Move KVM_REG_PPC_WORT to an unused register number
KVM: PPC: Book3S: Add ONE_REG register names that were missed
KVM: PPC: Add CAP to indicate hcall fixes
KVM: PPC: MPIC: Reset IRQ source private members
KVM: PPC: Graciously fail broken LE hypercalls
PPC: ePAPR: Fix hypercall on LE guest
KVM: PPC: BOOK3S: Remove open coded make_dsisr in alignment handler
KVM: PPC: BOOK3S: Always use the saved DAR value
PPC: KVM: Make NX bit available with magic page
KVM: PPC: Disable NX for old magic page using guests
KVM: PPC: BOOK3S: HV: Add mixed page-size support for guest
kvm-next
Patch queue for ppc - 2014-05-30
In this round we have a few nice gems. PR KVM gains initial POWER8 support
as well as LE host awareness, ihe e500 targets can now properly run u-boot,
LE guests now work with PR KVM including KVM hypercalls and HV KVM guests
can now use huge pages.
On top of this there are some bug fixes.
include/uapi/linux/kvm.h
Commit b005255e12a3 ("KVM: PPC: Book3S HV: Context-switch new POWER8
SPRs") added a definition of KVM_REG_PPC_WORT with the same register
number as the existing KVM_REG_PPC_VRSAVE (though in fact the
definitions are not identical because of the different register sizes.)
For clarity, this moves KVM_REG_PPC_WORT to the next unused number,
and also adds it to api.txt.
Commit 3b7834743f9 ("KVM: PPC: Book3S HV: Reserve POWER8 space in get/set_one_reg") added definitions for several KVM_REG_PPC_* symbols
but missed adding some to api.txt. This adds them.
Old guests try to use the magic page, but map their trampoline code inside
of an NX region.
Since we can't fix those old kernels, try to detect whether the guest is sane
or not. If not, just disable NX functionality in KVM so that old guests at
least work at all. For newer guests, add a bit that we can set to keep NX
functionality available.
Changed for the 3.16 merge window.
This includes KVM support for PSCI v0.2 and also includes generic Linux
support for PSCI v0.2 (on hosts that advertise that feature via their
DT), since the latter depends on headers introduced by the former.
Finally there's a small patch from Marc that enables Cortex-A53 support.
s390 has acquired irqfd support with commit "KVM: s390: irq routing for
adapter interrupts" (84223598778ba08041f4297fda485df83414d57e) but
failed to announce it. Let's fix that.
Add an interface to inject clock comparator and CPU timer interrupts
into the guest. This is needed for handling the external interrupt
interception.
Signed-off-by: Thomas Huth <thuth@linux.vnet.ibm.com>
