path: root/Documentation/vm
2009-11-17Merge branch 'hostprogs-wmissing-prototypes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc * 'hostprogs-wmissing-prototypes' of git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc: Makefile: Add -Wmising-prototypes to HOSTCFLAGS oss: Mark loadhex static in hex2hex.c dtc: Mark various internal functions static dtc: Set "noinput" in the lexer to avoid an unused function drm: radeon: Mark several functions static in mkregtable arch/sparc/boot/*.c: Mark various internal functions static arch/powerpc/boot/addRamDisk.c: Mark several internal functions static arch/alpha/boot/tools/objstrip.c: Mark "usage" static Documentation/vm/page-types.c: Declare checked_open static genksyms: Mark is_reserved_word static kconfig: Mark various internal functions static kconfig: Make zconf.y work with current bison
2009-11-15Documentation/vm/page-types.c: Declare checked_open staticJosh Triplett
Nothing outside of Documentation/vm/page-types.c references checked_open. Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-10-29Merge branch 'hwpoison-2.6.32' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison-2.6.32' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: HWPOISON: fix invalid page count in printk output HWPOISON: Allow schedule_on_each_cpu() from keventd HWPOISON: fix/proc/meminfo alignment HWPOISON: fix oops on ksm pages HWPOISON: Fix page count leak in hwpoison late kill in do_swap_page HWPOISON: return early on non-LRU pages HWPOISON: Add brief hwpoison description to Documentation HWPOISON: Clean up PR_MCE_KILL interface
2009-10-08page-types: add hwpoison/unpoison featureWu Fengguang
For hwpoison stress testing. The debugfs mount point is assumed to be /debug/. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-08page-types: introduce kpageflags_flags()Wu Fengguang
2009-10-08page-types: make voffset local variablesWu Fengguang
2009-10-08page-types: make standalone pagemap/kpageflags read routinesWu Fengguang
Refactor the code to be more modular and easier to reuse. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-08page-types: introduce checked_open()Wu Fengguang
This helps merge duplicate code (now and future) and outstand the main logic. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-08page-types: add GPL noteWu Fengguang
2009-10-08pagemap: document KPF_KSM and show it in page-typesWu Fengguang
It indicates to the system admin that processes mapping such pages may be eating less physical memory than the reported numbers by legacy tools. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Acked-by: Chris Wright <chrisw@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-08pagemap: export KPF_HWPOISONWu Fengguang
This flag indicates a hardware detected memory corruption on the page. Any future access of the page data may bring down the machine. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-08ksm: more on default valuesHugh Dickins
Adjust the max_kernel_pages default to a quarter of totalram_pages, instead of nr_free_buffer_pages() / 4: the KSM pages themselves come from highmem, and even on a 16GB PAE machine, 4GB of KSM pages would only be pinning 32MB of lowmem with their rmap_items, so no need for the more obscure calculation (nor for its own special init function). There is no way for the user to switch KSM on if CONFIG_SYSFS is not enabled, so in that case default run to KSM_RUN_MERGE. Update KSM Documentation and Kconfig to reflect the new defaults. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-04HWPOISON: Add brief hwpoison description to DocumentationAndi Kleen
2009-09-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: truncate: use new helpers truncate: new helpers fs: fix overflow in sys_mount() for in-kernel calls fs: Make unload_nls() NULL pointer safe freeze_bdev: grab active reference to frozen superblocks freeze_bdev: kill bd_mount_sem exofs: remove BKL from super operations fs/romfs: correct error-handling code vfs: seq_file: add helpers for data filling vfs: remove redundant position check in do_sendfile vfs: change sb->s_maxbytes to a loff_t vfs: explicitly cast s_maxbytes in fiemap_check_ranges libfs: return error code on failed attr set seq_file: return a negative error code when seq_path_root() fails. vfs: optimize touch_time() too vfs: optimization for touch_atime() vfs: split generic_forget_inode() so that hugetlbfs does not have to copy it fs/inode.c: add dev-id and inode number for debugging in init_special_inode() libfs: make simple_read_from_buffer conventional
2009-09-24page-types: add feature for walking process address spaceWu Fengguang
Introduce "-p|--pid <pid>" for walking the process address space. The default action is to walk raw memory PFNs. Both the virtual address and physical address of each present pages will be listed: # ./tools/vm/page-types -lp $$ | head -3 voffset offset len flags 400 11bebe 1 __RU_lA____M______________________ 402 11bebc 1 __RU_lA____M______________________ Note that voffset/offset/len are now showed as hex numbers. [akpm@linux-foundation.org: coding-style fixes] Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24Documentation/vm/.gitignore: add page-typesJosh Triplett
Signed-off-by: Josh Triplett <josh@joshtriplett.org> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24truncate: new helpersnpiggin@suse.de
Introduce new truncate helpers truncate_pagecache and inode_newsize_ok. vmtruncate is also consolidated from mm/memory.c and mm/nommu.c and into mm/truncate.c. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-23Documentation/: fix warnings from -Wmissing-prototypes in HOSTCFLAGSLadinu Chandrasinghe
Fix up -Wmissing-prototypes in compileable userspace code, mainly under Documentation/. Signed-off-by: Ladinu Chandrasinghe <ladinu.pub@gmail.com> Signed-off-by: Trevor Keith <tsrk@tsrk.net> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22hugetlb: add MAP_HUGETLB exampleEric B Munson
Add an example of how to use the MAP_HUGETLB flag to the vm documentation directory and a reference to the example in hugetlbpage.txt. Signed-off-by: Eric B Munson <ebmunson@us.ibm.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Adam Litke <agl@us.ibm.com> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22ksm: add some documentationHugh Dickins
Add Documentation/vm/ksm.txt: how to use the Kernel Samepage Merging feature Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22hugetlb: clean up and update huge pages documentationLee Schermerhorn
Attempt to clarify huge page administration and usage, and updates the doucmentation to mention the balancing of huge pages across nodes when allocating and freeing. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Nishanth Aravamudan <nacc@us.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: Adam Litke <agl@us.ibm.com> Cc: Andy Whitcroft <apw@canonical.com> Cc: Eric Whitney <eric.whitney@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-10slub: add option to disable higher order debugging slabsDavid Rientjes
When debugging is enabled, slub requires that additional metadata be stored in slabs for certain options: SLAB_RED_ZONE, SLAB_POISON, and SLAB_STORE_USER. Consequently, it may require that the minimum possible slab order needed to allocate a single object be greater when using these options. The most notable example is for objects that are PAGE_SIZE bytes in size. Higher minimum slab orders may cause page allocation failures when oom or under heavy fragmentation. This patch adds a new slub_debug option, which disables debugging by default for caches that would have resulted in higher minimum orders: slub_debug=O When this option is used on systems with 4K pages, kmalloc-4096, for example, will not have debugging enabled by default even if CONFIG_SLUB_DEBUG_ON is defined because it would have resulted in a order-1 minimum slab order. Reported-by: Larry Finger <Larry.Finger@lwfinger.net> Tested-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-06-17Documentation/vm/Makefile: don't try to build slqbinfoAndrew Morton
For it is only in linux-next at this stage. Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16pagemap: add page-types toolWu Fengguang
Add page-types, a handy tool for querying page flags. It will expand some of the overloaded flags: PG_slob_free = PG_private PG_slub_frozen = PG_active PG_slub_debug = PG_error PG_readahead = PG_reclaim and mask out obscure flags except in -raw mode: PG_reserved PG_mlocked PG_mappedtodisk PG_private PG_private_2 PG_owner_priv_1 PG_arch_1 PG_uncached PG_compound* for non hugeTLB pages [akpm@linux-foundation.org: fix warning] Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16pagemap: document 9 more exported page flagsWu Fengguang
Also add short descriptions for all of the 20 exported page flags. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16pagemap: document clarificationsWu Fengguang
Some bit ranges were inclusive and some not. Fix them to be consistently inclusive. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16page allocator: use allocation flags as an index to the zone watermarkMel Gorman
ALLOC_WMARK_MIN, ALLOC_WMARK_LOW and ALLOC_WMARK_HIGH determin whether pages_min, pages_low or pages_high is used as the zone watermark when allocating the pages. Two branches in the allocator hotpath determine which watermark to use. This patch uses the flags as an array index into a watermark array that is indexed with WMARK_* defines accessed via helpers. All call sites that use zone->pages_* are updated to use the helpers for accessing the values and the array offsets for setting. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13mm: add documentation describing what tsk->active_mm means vs tsk->mmMichael Ellerman
I'm sure everyone knows this, but I didn't, so I googled it, and found a nice explanation from Linus. Might be worth sticking in Documentation. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13mm: reformat the Unevictable-LRU documentationDavid Howells
Do a bit of reformatting on the Unevictable-LRU documentation. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Rik van Riel <riel@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-09tracing: consolidate documentsLi Zefan
Move kmemtrace.txt, tracepoints.txt, ftrace.txt and mmiotrace.txt to the new trace/ directory. I didnt find any references to those documents in both source files and documents, so no extra work needs to be done. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Pekka Paalanen <pq@iki.fi> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> LKML-Reference: <49DD6E2B.6090200@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-05Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (413 commits) tracing, net: fix net tree and tracing tree merge interaction tracing, powerpc: fix powerpc tree and tracing tree interaction ring-buffer: do not remove reader page from list on ring buffer free function-graph: allow unregistering twice trace: make argument 'mem' of trace_seq_putmem() const tracing: add missing 'extern' keywords to trace_output.h tracing: provide trace_seq_reserve() blktrace: print out BLK_TN_MESSAGE properly blktrace: extract duplidate code blktrace: fix memory leak when freeing struct blk_io_trace blktrace: fix blk_probes_ref chaos blktrace: make classic output more classic blktrace: fix off-by-one bug blktrace: fix the original blktrace blktrace: fix a race when creating blk_tree_root in debugfs blktrace: fix timestamp in binary output tracing, Text Edit Lock: cleanup tracing: filter fix for TRACE_EVENT_FORMAT events ftrace: Using FTRACE_WARN_ON() to check "freed record" in ftrace_release() x86: kretprobe-booster interrupt emulation code fix ... Fix up trivial conflicts in arch/parisc/include/asm/ftrace.h include/linux/memory.h kernel/extable.c kernel/module.c
2009-03-30trivial: fix where cgroup documentation is not correctly referred toThadeu Lima de Souza Cascardo
cgroup documentation was moved to Documentation/cgroups/. There are some places that still refer to Documentation/controllers/, Documentation/cgroups.txt and Documentation/cpusets.txt. Fix those. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-11Merge commit 'v2.6.29-rc1' into tracing/urgentIngo Molnar
2009-01-06mm: remove try_to_munlock from vmscanHugh Dickins
An unfortunate feature of the Unevictable LRU work was that reclaiming an anonymous page involved an extra scan through the anon_vma: to check that the page is evictable before allocating swap, because the swap could not be freed reliably soon afterwards. Now try_to_free_swap() has replaced remove_exclusive_swap_page(), that's not an issue any more: remove try_to_munlock() call from shrink_page_list(), leaving it to try_to_munmap() to discover if the page is one to be culled to the unevictable list - in which case then try_to_free_swap(). Update unevictable-lru.txt to remove comments on the try_to_munlock() in shrink_page_list(), and shorten some lines over 80 columns. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-29kmemtrace: remove config option for enabling tracing at bootPekka Enberg
Users can pass kmemtrace.enabled=yes as a kernel parameter to enable kmemtrace at boot so remove the useless CONFIG_KMEMTRACE_DEFAULT_ENABLED config option. Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-12-29kmemtrace: Fix typos in documentation.Eduard - Gabriel Munteanu
Corrected the ABI description and the kmemtrace usage guide. Thanks to Randy Dunlap for noticing these errors. Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-12-29kmemtrace: Additional documentation.Eduard - Gabriel Munteanu
Documented kmemtrace's ABI, purpose and design. Also includes a short usage guide, FAQ, as well as a link to the userspace application's Git repository, which is currently hosted at repo.or.cz. Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-10-30.gitignore updatesAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20doc: unevictable LRU and mlocked pages documentationLee Schermerhorn
Documentation for unevictable lru list and its usage. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15Documentation/vm/page_migration: update reference to numa_maps + fix ↵Michael Kerrisk
download URI With man-pages-3.07, the numa_maps documentation home is now proc(5), so the reference in Documentation/vm/page_migration needs updating. (Cliff/Lee are removing numa_maps.5 from the numactl package.) Also, the download location for the numactl package changed a while back. This patch fixes both things, as well as a typo (provided-->provides). Signed-off-by: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Cliff Wickman <cpw@sgi.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12docsrc: build Documentation/ sourcesRandy Dunlap
Currently source files in the Documentation/ sub-dir can easily bit-rot since they are not generally buildable, either because they are hidden in text files or because there are no Makefile rules for them. This needs to be fixed so that the source files remain usable and good examples of code instead of bad examples. Add the ability to build source files that are in the Documentation/ dir. Add to Kconfig as "BUILD_DOCSRC" config symbol. Use "CONFIG_BUILD_DOCSRC=1 make ..." to build objects from the Documentation/ sources. Or enable BUILD_DOCSRC in the *config system. However, this symbol depends on HEADERS_CHECK since the header files need to be installed (for userspace builds). Built (using cross-tools) for x86-64, i386, alpha, ia64, sparc32, sparc64, powerpc, sh, m68k, & mips. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26Documentation cleanup: trivial misspelling, punctuation, and grammar ↵Matt LaPlante
corrections. Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24hugetlb: new sysfs interfaceNishanth Aravamudan
Provide new hugepages user APIs that are more suited to multiple hstates in sysfs. There is a new directory, /sys/kernel/hugepages. Underneath that directory there will be a directory per-supported hugepage size, e.g.: /sys/kernel/hugepages/hugepages-64kB /sys/kernel/hugepages/hugepages-16384kB /sys/kernel/hugepages/hugepages-16777216kB corresponding to 64k, 16m and 16g respectively. Within each hugepages-size directory there are a number of files, corresponding to the tracked counters in the hstate, e.g.: /sys/kernel/hugepages/hugepages-64/nr_hugepages /sys/kernel/hugepages/hugepages-64/nr_overcommit_hugepages /sys/kernel/hugepages/hugepages-64/free_hugepages /sys/kernel/hugepages/hugepages-64/resv_hugepages /sys/kernel/hugepages/hugepages-64/surplus_hugepages Of these files, the first two are read-write and the latter three are read-only. The size of the hugepage being manipulated is trivially deducible from the enclosing directory and is always expressed in kB (to match meminfo). [dave@linux.vnet.ibm.com: fix build] [nacc@us.ibm.com: hugetlb: hang off of /sys/kernel/mm rather than /sys/kernel] [nacc@us.ibm.com: hugetlb: remove CONFIG_SYSFS dependency] Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-04Christoph has movedChristoph Lameter
Remove all clameter@sgi.com addresses from the kernel tree since they will become invalid on June 27th. Change my maintainer email address for the slab allocators to cl@linux-foundation.org (which will be the new email address for the future). Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06pagemap: add documentation for pagemapThomas Tuttle
Just a quick explanation of the pagemap interface from a userspace point of view, and an example of how to use it (in English, not code). Signed-off-by: Thomas Tuttle <ttuttle@google.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-02slabinfo: Support printout of the number of fallbacksChristoph Lameter
Add functionality to slabinfo to print out the number of fallbacks that have occurred for each slab cache when the -D option is specified. Also widen the allocation / free field since the numbers became too big after a week. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-04-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: slub: pack objects denser slub: Calculate min_objects based on number of processors. slub: Drop DEFAULT_MAX_ORDER / DEFAULT_MIN_OBJECTS slub: Simplify any_slab_object checks slub: Make the order configurable for each slab cache slub: Drop fallback to page allocator method slub: Fallback to minimal order during slab page allocation slub: Update statistics handling for variable order slabs slub: Add kmem_cache_order_objects struct slub: for_each_object must be passed the number of objects in a slab slub: Store max number of objects in the page struct. slub: Dump list of objects not freed on kmem_cache_close() slub: free_list() cleanup slub: improve kmem_cache_destroy() error message slob: fix bug - when slob allocates "struct kmem_cache", it does not force alignment.
2008-04-28mempolicy: use MPOL_F_LOCAL to Indicate Preferred Local PolicyLee Schermerhorn
Now that we're using "preferred local" policy for system default, we need to make this as fast as possible. Because of the variable size of the mempolicy structure [based on size of nodemasks], the preferred_node may be in a different cacheline from the mode. This can result in accessing an extra cacheline in the normal case of system default policy. Suspect this is the cause of an observed 2-3% slowdown in page fault testing relative to kernel without this patch series. To alleviate this, use an internal mode flag, MPOL_F_LOCAL in the mempolicy flags member which is guaranteed [?] to be in the same cacheline as the mode itself. Verified that reworked mempolicy now performs slightly better on 25-rc8-mm1 for both anon and shmem segments with system default and vma [preferred local] policy. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: use MPOL_PREFERRED for system-wide default policyLee Schermerhorn
Currently, when one specifies MPOL_DEFAULT via a NUMA memory policy API [set_mempolicy(), mbind() and internal versions], the kernel simply installs a NULL struct mempolicy pointer in the appropriate context: task policy, vma policy, or shared policy. This causes any use of that policy to "fall back" to the next most specific policy scope. The only use of MPOL_DEFAULT to mean "local allocation" is in the system default policy. This requires extra checks/cases for MPOL_DEFAULT in many mempolicy.c functions. There is another, "preferred" way to specify local allocation via the APIs. That is using the MPOL_PREFERRED policy mode with an empty nodemask. Internally, the empty nodemask gets converted to a preferred_node id of '-1'. All internal usage of MPOL_PREFERRED will convert the '-1' to the id of the node local to the cpu where the allocation occurs. System default policy, except during boot, is hard-coded to "local allocation". By using the MPOL_PREFERRED mode with a negative value of preferred node for system default policy, MPOL_DEFAULT will never occur in the 'policy' member of a struct mempolicy. Thus, we can remove all checks for MPOL_DEFAULT when converting policy to a node id/zonelist in the allocation paths. In slab_node() return local node id when policy pointer is NULL. No need to set a pol value to take the switch default. Replace switch default with BUG()--i.e., shouldn't happen. With this patch MPOL_DEFAULT is only used in the APIs, including internal calls to do_set_mempolicy() and in the display of policy in /proc/<pid>/numa_maps. It always means "fall back" to the the next most specific policy scope. This simplifies the description of memory policies quite a bit, with no visible change in behavior. get_mempolicy() continues to return MPOL_DEFAULT and an empty nodemask when the requested policy [task or vma/shared] is NULL. These are the values one would supply via set_mempolicy() or mbind() to achieve that condition--default behavior. This patch updates Documentation to reflect this change. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: rework mempolicy Reference Counting [yet again]Lee Schermerhorn
After further discussion with Christoph Lameter, it has become clear that my earlier attempts to clean up the mempolicy reference counting were a bit of overkill in some areas, resulting in superflous ref/unref in what are usually fast paths. In other areas, further inspection reveals that I botched the unref for interleave policies. A separate patch, suitable for upstream/stable trees, fixes up the known errors in the previous attempt to fix reference counting. This patch reworks the memory policy referencing counting and, one hopes, simplifies the code. Maybe I'll get it right this time. See the update to the numa_memory_policy.txt document for a discussion of memory policy reference counting that motivates this patch. Summary: Lookup of mempolicy, based on (vma, address) need only add a reference for shared policy, and we need only unref the policy when finished for shared policies. So, this patch backs out all of the unneeded extra reference counting added by my previous attempt. It then unrefs only shared policies when we're finished with them, using the mpol_cond_put() [conditional put] helper function introduced by this patch. Note that shmem_swapin() calls read_swap_cache_async() with a dummy vma containing just the policy. read_swap_cache_async() can call alloc_page_vma() multiple times, so we can't let alloc_page_vma() unref the shared policy in this case. To avoid this, we make a copy of any non-null shared policy and remove the MPOL_F_SHARED flag from the copy. This copy occurs before reading a page [or multiple pages] from swap, so the overhead should not be an issue here. I introduced a new static inline function "mpol_cond_copy()" to copy the shared policy to an on-stack policy and remove the flags that would require a conditional free. The current implementation of mpol_cond_copy() assumes that the struct mempolicy contains no pointers to dynamically allocated structures that must be duplicated or reference counted during copy. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
