path: root/Documentation/w1
2009-10-04ds2482: Discard obsolete detect methodJean Delvare
There is no point in implementing a detect callback for the DS2482, as this device can't be detected. It was there solely to handle "force" module parameters to instantiate devices, but now we have a better sysfs interface that can do the same. So we can get rid of the ugly module parameters and the detect callback. This shrinks the binary module size by 21%. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Ben Gardner <gardner.ben@gmail.com>
2009-01-08w1: send status messages after command processingEvgeniy Polyakov
Send completion status of the commands to the userspace. Message and protocol are described in the documentation. Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Cc: Paul Alfille <paul.alfille@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08w1: added w1 reset commandEvgeniy Polyakov
Command which allows to reset the bus. Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Cc: Paul Alfille <paul.alfille@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08w1: documentation updateEvgeniy Polyakov
Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08w1: add 1-wire master driver for i.MX27 / i.MX31Sascha Hauer
This patch adds support for the 1-wire master interface for i.MX27 and i.MX31. Signed-off-by: Luotao Fu <l.fu@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12hdq: documentation for OMAP HDQMadhusudhan Chikkature
Add a brief document about omap2430/3430 HDQ/1-wire driver. Signed-off-by: Madhusudhan Chikkature<madhu.cr@ti.com> Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16W1: Documentation/w1/masters/ds2490 updateDavid Fries
Provide some additional details about the status of the driver and the ds2490 hardware. Signed-off-by: David Fries <david@fries.net> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16W1: Document add, remove, search_count, and pullup.David Fries
Document w1_master_add, w1_master_remove, search_count, and pullup. Signed-off-by: David Fries <david@fries.net> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16W1: feature, w1_therm.c use strong pullup and documentationDavid Fries
Added strong pullup to thermal sensor driver and general documentation on the sensor. Signed-off-by: David Fries <david@fries.net> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06w1-gpio: add GPIO w1 bus master driverVille Syrjala
Add a GPIO 1-wire bus master driver. The driver used the GPIO API to control the wire and the GPIO pin can be specified using platform data similar to i2c-gpio. The driver was tested with AT91SAM9260 + DS2401. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Add Documentation/{w1,w1/masters}/00-INDEXRob Landley
Two 00-INDEX files under Documentation/w1 Signed-off-by: Rob Landley <rob@landley.net> Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-22[PATCH] w1: Userspace communication protocol over connector.Evgeniy Polyakov
There are three types of messages between w1 core and userspace: 1. Events. They are generated each time new master or slave device found either due to automatic or requested search. 2. Userspace commands. Includes read/write and search/alarm search comamnds. 3. Replies to userspace commands. From: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] w1: Replace dscore and ds_w1_bridge with ds2490 driver.Evgeniy Polyakov
2006-06-22[PATCH] w1: Added default generic read/write operations.Evgeniy Polyakov
Special file in each w1 slave device's directory called "rw" is created each time new slave and no appropriate w1 family is registered. "rw" file supports read and write operations, which allows to perform almost any kind of operations. Each logical operation is a transaction in nature, which can contain several (two or one) low-level operations. Let's see how one can read EEPROM context: 1. one must write control buffer, i.e. buffer containing command byte and two byte address. At this step bus is reset and appropriate device is selected using either W1_SKIP_ROM or W1_MATCH_ROM command. Then provided control buffer is being written to the wire. 2. reading. This will issue reading eeprom response. It is possible that between 1. and 2. w1 master thread will reset bus for searching and slave device will be even removed, but in this case 0xff will be read, since no device was selected. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] W1: Add the DS2482 I2C-to-w1 bridge driver.Evgeniy Polyakov
Signed-off-by: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-21[PATCH] w1: Updates the w1 documentation (w1.generic)Evgeniy Polyakov
Updates the w1 documentation (w1.generic) Signed-off-by: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
