path: root/Documentation/w1
2006-06-22[PATCH] w1: Userspace communication protocol over connector.Evgeniy Polyakov
There are three types of messages between w1 core and userspace: 1. Events. They are generated each time new master or slave device found either due to automatic or requested search. 2. Userspace commands. Includes read/write and search/alarm search comamnds. 3. Replies to userspace commands. From: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] w1: Replace dscore and ds_w1_bridge with ds2490 driver.Evgeniy Polyakov
2006-06-22[PATCH] w1: Added default generic read/write operations.Evgeniy Polyakov
Special file in each w1 slave device's directory called "rw" is created each time new slave and no appropriate w1 family is registered. "rw" file supports read and write operations, which allows to perform almost any kind of operations. Each logical operation is a transaction in nature, which can contain several (two or one) low-level operations. Let's see how one can read EEPROM context: 1. one must write control buffer, i.e. buffer containing command byte and two byte address. At this step bus is reset and appropriate device is selected using either W1_SKIP_ROM or W1_MATCH_ROM command. Then provided control buffer is being written to the wire. 2. reading. This will issue reading eeprom response. It is possible that between 1. and 2. w1 master thread will reset bus for searching and slave device will be even removed, but in this case 0xff will be read, since no device was selected. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] W1: Add the DS2482 I2C-to-w1 bridge driver.Evgeniy Polyakov
Signed-off-by: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-21[PATCH] w1: Updates the w1 documentation (w1.generic)Evgeniy Polyakov
Updates the w1 documentation (w1.generic) Signed-off-by: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
