This reverts commit fcf5e5198b447969ed2a56ec335dae3c695a6b46 which is
548acf19234dbda5a52d5a8e7e205af46e9da840 upstream.
Cc: Borislav Petkov <bp@suse.de>
commit 548acf19234dbda5a52d5a8e7e205af46e9da840 upstream.
Huge amounts of help from Andy Lutomirski and Borislav Petkov to
produce this. Andy provided the inspiration to add classes to the
exception table with a clever bit-squeezing trick, Boris pointed
out how much cleaner it would all be if we just had a new field.
Linus Torvalds blessed the expansion with:
' I'd rather not be clever in order to save just a tiny amount of space
in the exception table, which isn't really criticial for anybody. '
The third field is another relative function pointer, this one to a
handler that executes the actions.
We start out with three handlers:
1: Legacy - just jumps the to fixup IP
2: Fault - provide the trap number in %ax to the fixup code
3: Cleaned up legacy for the uaccess error hack
Signed-off-by: Tony Luck <tony.luck@intel.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/f6af78fcbd348cf4939875cfda9c19689b5e50b8.1455732970.git.tony.luck@intel.com
commit b6350c21cfe8aa9d65e189509a23c0ea4b8362c2 upstream.
Update PAT documentation to describe how PAT is initialized under
various configurations.
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Luis R. Rodriguez <mcgrof@suse.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: elliott@hpe.com
Cc: konrad.wilk@oracle.com
Cc: paul.gortmaker@windriver.com
Cc: xen-devel@lists.xenproject.org
Link: http://lkml.kernel.org/r/1458769323-24491-8-git-send-email-toshi.kani@hpe.com
Pull x86 mm updates from Ingo Molnar:
"The dominant change in this cycle was the continued work to isolate
kernel drivers from MTRR legacies: this tree gets rid of all kernel
internal driver interfaces to MTRRs (mostly by rewriting it to proper
PAT interfaces), the only access left is the /proc/mtrr ABI.
This work was done by Luis R Rodriguez.
There's also some related PCI interface additions for which I've
Cc:-ed Bjorn"
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits)
x86/mm/mtrr: Remove kernel internal MTRR interfaces: unexport mtrr_add() and mtrr_del()
s390/io: Add pci_iomap_wc() and pci_iomap_wc_range()
drivers/dma/iop-adma: Use dma_alloc_writecombine() kernel-style
drivers/video/fbdev/vt8623fb: Use arch_phys_wc_add() and pci_iomap_wc()
drivers/video/fbdev/s3fb: Use arch_phys_wc_add() and pci_iomap_wc()
drivers/video/fbdev/arkfb.c: Use arch_phys_wc_add() and pci_iomap_wc()
PCI: Add pci_iomap_wc() variants
drivers/video/fbdev/gxt4500: Use pci_ioremap_wc_bar() to map framebuffer
drivers/video/fbdev/kyrofb: Use arch_phys_wc_add() and pci_ioremap_wc_bar()
drivers/video/fbdev/i740fb: Use arch_phys_wc_add() and pci_ioremap_wc_bar()
PCI: Add pci_ioremap_wc_bar()
x86/mm: Make kernel/check.c explicitly non-modular
x86/mm/pat: Make mm/pageattr[-test].c explicitly non-modular
x86/mm/pat: Add comments to cachemode translation tables
arch/*/io.h: Add ioremap_uc() to all architectures
drivers/video/fbdev/atyfb: Use arch_phys_wc_add() and ioremap_wc()
drivers/video/fbdev/atyfb: Replace MTRR UC hole with strong UC
drivers/video/fbdev/atyfb: Clarify ioremap() base and length used
drivers/video/fbdev/atyfb: Carve out framebuffer length fudging into a helper
x86/mm, asm-generic: Add IOMMU ioremap_uc() variant default
Pull x86 boot updates from Ingo Molnar:
"The main x86 bootup related changes in this cycle were:
- more boot time optimizations. (Len Brown)
- implement hex output to allow the debugging of early bootup
parameters. (Kees Cook)
- remove obsolete MCA leftovers. (Paolo Pisati)"
* 'x86-boot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/smpboot: Remove APIC.wait_for_init_deassert and atomic init_deasserted
x86/smpboot: Remove SIPI delays from cpu_up()
x86/smpboot: Remove udelay(100) when polling cpu_callin_map
x86/smpboot: Remove udelay(100) when polling cpu_initialized_map
x86/boot: Obsolete the MCA sys_desc_table
x86/boot: Add hex output for debugging
mtrr_del()
The effort to replace mtrr_add() with architecture agnostic
arch_phys_wc_add() is complete, this will ensure write-combining
implementations (PAT on x86) is taken advantage instead of using
MTRR. With the effort done now, hide direct MTRR access for
drivers.
The legacy user-space /proc/mtrr ABI is not affected.
Update x86 documentation on MTRR to reflect the completion of
the phasing out of direct access to MTRR, also add a note on
platform firmware code use of MTRRs based on the obituary
discussion of MTRRs on Linux [0].
[0] http://lkml.kernel.org/r/1438991330.3109.196.camel@hp.com
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
Cc: <syrjala@sci.fi>
Cc: Andy Walls <awalls@md.metrocast.net>
Cc: Antonino Daplas <adaplas@gmail.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Dave Airlie <airlied@redhat.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Davidlohr Bueso <dbueso@suse.de>
Cc: Doug Ledford <dledford@redhat.com>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Cc: Suresh Siddha <sbsiddha@gmail.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: Ville Syrjälä <syrjala@sci.fi>
Cc: airlied@linux.ie
Cc: benh@kernel.crashing.org
Cc: bhelgaas@google.com
Cc: dan.j.williams@intel.com
Cc: linux-fbdev@vger.kernel.org
Cc: linux-media@vger.kernel.org
Cc: mst@redhat.com
Cc: netdev@vger.kernel.org
Cc: vinod.koul@intel.com
Cc: xen-devel@lists.xensource.com
Link: http://lkml.kernel.org/r/1440443613-13696-12-git-send-email-mcgrof@do-not-panic.com
The IRQSTACKSIZE was renamed to the IRQ_STACK_SIZE in the
(26f80bd6a9 x86-64: Convert irqstacks to per-cpu) commit,
but it still named IRQSTACKSIZE in the documentation. This
patch fixes this.
Signed-off-by: Alexander Kuleshov <kuleshovmail@gmail.com>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
The kernel does not support the MCA bus anymroe, so mark sys_desc_table
as obsolete: remove any reference from the code together with the remaining
of MCA logic.
bloat-o-meter output:
add/remove: 0/0 grow/shrink: 0/2 up/down: 0/-55 (-55)
function old new delta
i386_start_kernel 128 119 -9
setup_arch 1421 1375 -46
Signed-off-by: Paolo Pisati <p.pisati@gmail.com>
Cc: Josh Triplett <josh@joshtriplett.org>
Link: http://lkml.kernel.org/r/1437409430-8491-1-git-send-email-p.pisati@gmail.com
The paths mentioned in this file weren't updated through some file
rename commits. Fix them to refer to the correct path.
Signed-off-by: James C Boyd <jcboyd.dev@gmail.com>
Cc: corbet@lwn.net
Cc: trivial@kernel.org
Link: http://lkml.kernel.org/r/1435781606-3037-1-git-send-email-jcboyd.dev@gmail.com
Merge branch that got ready.
Pull x86 core updates from Ingo Molnar:
"There were so many changes in the x86/asm, x86/apic and x86/mm topics
in this cycle that the topical separation of -tip broke down somewhat -
so the result is a more traditional architecture pull request,
collected into the 'x86/core' topic.
The topics were still maintained separately as far as possible, so
bisectability and conceptual separation should still be pretty good -
but there were a handful of merge points to avoid excessive
dependencies (and conflicts) that would have been poorly tested in the
end.
The next cycle will hopefully be much more quiet (or at least will
have fewer dependencies).
The main changes in this cycle were:
* x86/apic changes, with related IRQ core changes: (Jiang Liu, Thomas
Gleixner)
- This is the second and most intrusive part of changes to the x86
interrupt handling - full conversion to hierarchical interrupt
domains:
[IOAPIC domain] -----
[MSI domain] --------[Remapping domain] ----- [ Vector domain ]
| (optional) |
[HPET MSI domain] ----- |
[DMAR domain] -----------------------------
[Legacy domain] -----------------------------
This now reflects the actual hardware and allowed us to distangle
the domain specific code from the underlying parent domain, which
can be optional in the case of interrupt remapping. It's a clear
separation of functionality and removes quite some duct tape
constructs which plugged the remap code between ioapic/msi/hpet
and the vector management.
- Intel IOMMU IRQ remapping enhancements, to allow direct interrupt
injection into guests (Feng Wu)
* x86/asm changes:
- Tons of cleanups and small speedups, micro-optimizations. This
is in preparation to move a good chunk of the low level entry
code from assembly to C code (Denys Vlasenko, Andy Lutomirski,
Brian Gerst)
- Moved all system entry related code to a new home under
arch/x86/entry/ (Ingo Molnar)
- Removal of the fragile and ugly CFI dwarf debuginfo annotations.
Conversion to C will reintroduce many of them - but meanwhile
they are only getting in the way, and the upstream kernel does
not rely on them (Ingo Molnar)
- NOP handling refinements. (Borislav Petkov)
* x86/mm changes:
- Big PAT and MTRR rework: making the code more robust and
preparing to phase out exposing direct MTRR interfaces to drivers -
in favor of using PAT driven interfaces (Toshi Kani, Luis R
Rodriguez, Borislav Petkov)
- New ioremap_wt()/set_memory_wt() interfaces to support
Write-Through cached memory mappings. This is especially
important for good performance on NVDIMM hardware (Toshi Kani)
* x86/ras changes:
- Add support for deferred errors on AMD (Aravind Gopalakrishnan)
This is an important RAS feature which adds hardware support for
poisoned data. That means roughly that the hardware marks data
which it has detected as corrupted but wasn't able to correct, as
poisoned data and raises an APIC interrupt to signal that in the
form of a deferred error. It is the OS's responsibility then to
take proper recovery action and thus prolonge system lifetime as
far as possible.
- Add support for Intel "Local MCE"s: upcoming CPUs will support
CPU-local MCE interrupts, as opposed to the traditional system-
wide broadcasted MCE interrupts (Ashok Raj)
- Misc cleanups (Borislav Petkov)
* x86/platform changes:
- Intel Atom SoC updates
... and lots of other cleanups, fixlets and other changes - see the
shortlog and the Git log for details"
* 'x86-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (222 commits)
x86/hpet: Use proper hpet device number for MSI allocation
x86/hpet: Check for irq==0 when allocating hpet MSI interrupts
x86/mm/pat, drivers/infiniband/ipath: Use arch_phys_wc_add() and require PAT disabled
x86/mm/pat, drivers/media/ivtv: Use arch_phys_wc_add() and require PAT disabled
x86/platform/intel/baytrail: Add comments about why we disabled HPET on Baytrail
genirq: Prevent crash in irq_move_irq()
genirq: Enhance irq_data_to_desc() to support hierarchy irqdomain
iommu, x86: Properly handle posted interrupts for IOMMU hotplug
iommu, x86: Provide irq_remapping_cap() interface
iommu, x86: Setup Posted-Interrupts capability for Intel iommu
iommu, x86: Add cap_pi_support() to detect VT-d PI capability
iommu, x86: Avoid migrating VT-d posted interrupts
iommu, x86: Save the mode (posted or remapped) of an IRTE
iommu, x86: Implement irq_set_vcpu_affinity for intel_ir_chip
iommu: dmar: Provide helper to copy shared irte fields
iommu: dmar: Extend struct irte for VT-d Posted-Interrupts
iommu: Add new member capability to struct irq_remap_ops
x86/asm/entry/64: Disentangle error_entry/exit gsbase/ebx/usermode code
x86/asm/entry/32: Shorten __audit_syscall_entry() args preparation
x86/asm/entry/32: Explain reloading of registers after __audit_syscall_entry()
Pull x86 EFI updates from Ingo Molnar:
"EFI changes:
- Use idiomatic negative error values in efivar_create_sysfs_entry()
instead of returning '1' to indicate error (Dan Carpenter)
- Implement new support to expose the EFI System Resource Tables in
sysfs, which provides information for performing firmware updates
(Peter Jones)
- Documentation cleanup in the EFI handover protocol section which
falsely claimed that 'cmdline_size' needed to be filled out by the
boot loader (Alex Smith)
- Align the order of SMBIOS tables in /sys/firmware/efi/systab to
match the way that we do things for ACPI and add documentation to
Documentation/ABI (Jean Delvare)"
* 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
efi: Work around ia64 build problem with ESRT driver
efi: Add 'systab' information to Documentation/ABI
efi: dmi: List SMBIOS3 table before SMBIOS table
efi/esrt: Fix some compiler warnings
x86, doc: Remove cmdline_size from list of fields to be filled in for EFI handover
efi: Add esrt support
efi: efivar_create_sysfs_entry() should return negative error codes
x86/core, to merge last updates
Collect all changes to arch/x86/entry/entry_64.S, before applying
patch that changes most of the file.
Rename the following system call entry points:
ia32_cstar_target -> entry_SYSCALL_compat
ia32_syscall -> entry_INT80_compat
The generic naming scheme for x86 system call entry points is:
entry_MNEMONIC_qualifier
where 'qualifier' is one of _32, _64 or _compat.
arch/x86/include/asm/irq_vectors.h
Initialize and prepare for handling LMCEs. Add a boot-time
option to disable LMCEs.
Signed-off-by: Ashok Raj <ashok.raj@intel.com>
[ Simplify stuff, align statements for better readability, reflow comments; kill
unused lmce_clear(); save us an MSR write if LMCE is already enabled. ]
Cc: linux-edac <linux-edac@vger.kernel.org>
Link: http://lkml.kernel.org/r/1433436928-31903-16-git-send-email-bp@alien8.de
Now that reserve_ram_pages_type() accepts the WT type, add
set_memory_wt(), set_memory_array_wt() and set_pages_array_wt()
in order to be able to set memory to Write-Through page cache
mode.
Also, extend ioremap_change_attr() to accept the WT type.
Signed-off-by: Toshi Kani <toshi.kani@hp.com>
Cc: Elliott@hp.com
Cc: arnd@arndb.de
Cc: hch@lst.de
Cc: hmh@hmh.eng.br
Cc: jgross@suse.com
Cc: linux-mm <linux-mm@kvack.org>
Cc: linux-nvdimm@lists.01.org
Cc: stefan.bader@canonical.com
Cc: yigal@plexistor.com
Link: http://lkml.kernel.org/r/1433436928-31903-13-git-send-email-bp@alien8.de
Add ioremap_wt() for creating Write-Through mappings on x86. It
follows the same model as ioremap_wc() for multi-arch support.
Define ARCH_HAS_IOREMAP_WT in the x86 version of io.h to
indicate that ioremap_wt() is implemented on x86.
Also update the PAT documentation file to cover ioremap_wt().
Cc: Elliott@hp.com
Cc: arnd@arndb.de
Cc: hch@lst.de
Cc: hmh@hmh.eng.br
Cc: jgross@suse.com
Link: http://lkml.kernel.org/r/1433436928-31903-8-git-send-email-bp@alien8.de
non-PAT pages
As part of the effort to phase out MTRR use document
write-combining MTRR effects on pages with different non-PAT
page attributes flags and different PAT entry values. Extend
arch_phys_wc_add() documentation to clarify power of two sizes /
boundary requirements as we phase out mtrr_add() use.
Lastly hint towards ioremap_uc() for corner cases on device
drivers working with devices with mixed regions where MTRR size
requirements would otherwise not enable write-combining
effective memory types.
Cc: Jonathan Corbet <corbet@lwn.net>
Link: http://lkml.kernel.org/r/1430343851-967-3-git-send-email-mcgrof@do-not-panic.com
Link: http://lkml.kernel.org/r/1432628901-18044-10-git-send-email-bp@alien8.de
Hold it down for future reference, as the question about the
question mark in stack traces keeps popping up.
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Michal Marek <mmarek@suse.cz>
Cc: live-patching@vger.kernel.org
Link: http://lkml.kernel.org/r/1432628901-18044-18-git-send-email-bp@alien8.de
Link: http://lkml.kernel.org/r/20150521101614.GA10889@gmail.com
Update the documentation after
6f442be2fb22 ("x86_64, traps: Stop using IST for #SS").
Link: http://lkml.kernel.org/r/1432628901-18044-17-git-send-email-bp@alien8.de
... to Documentation/x86/ as it is going to collect more and not
only 64-bit specific info.
Link: http://lkml.kernel.org/r/1432628901-18044-16-git-send-email-bp@alien8.de
Documentation/x86/boot.txt labels the bit in
boot_params.hdr.loadflags as ALSR_FLAG while it should be
KASLR_FLAG.
Signed-off-by: Miroslav Benes <mbenes@suse.cz>
Cc: Jiri Kosina <jkosina@suse.cz>
Link: http://lkml.kernel.org/r/1429011324-7170-1-git-send-email-mbenes@suse.cz
Link: http://lkml.kernel.org/r/1431332153-18566-4-git-send-email-bp@alien8.de
handover
The cmdline_size field in setup_header is listed as read-only, and is
never read by the kernel. Therefore, there is no need for it to be set
by a boot loader implementing the EFI handover protocol, so remove it
from the list of fields required to be set by a boot loader.
Signed-off-by: Alex Smith <alex@alex-smith.me.uk>
Cc: H. Peter Anvin <hpa@linux.intel.com>
Cc: x86@kernel.org
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Commit:
e2b32e678513 ("x86, kaslr: randomize module base load address")
made module base address randomization unconditional and didn't regard
disabled KKASLR due to CONFIG_HIBERNATION and command line option
"nokaslr". For more info see (now reverted) commit:
f47233c2d34f ("x86/mm/ASLR: Propagate base load address calculation")
In order to propagate KASLR status to kernel proper, we need a single bit
in boot_params.hdr.loadflags and we've chosen bit 1 thus leaving the
top-down allocated bits for bits supposed to be used by the bootloader.
Originally-From: Jiri Kosina <jkosina@suse.cz>
Suggested-by: H. Peter Anvin <hpa@zytor.com>
Pull misc x86 fixes from Ingo Molnar:
"This contains:
- EFI fixes
- a boot printout fix
- ASLR/kASLR fixes
- intel microcode driver fixes
- other misc fixes
Most of the linecount comes from an EFI revert"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/mm/ASLR: Avoid PAGE_SIZE redefinition for UML subarch
x86/microcode/intel: Handle truncated microcode images more robustly
x86/microcode/intel: Guard against stack overflow in the loader
x86, mm/ASLR: Fix stack randomization on 64-bit systems
x86/mm/init: Fix incorrect page size in init_memory_mapping() printks
Documentation/x86: Fix path in zero-page.txt
x86/apic: Fix the devicetree build in certain configs
Revert "efi/libstub: Call get_memory_map() to obtain map and desc sizes"
x86/efi: Avoid triple faults during EFI mixed mode calls
Cc: Martin Mares <mj@ucw.cz>
Link: http://lkml.kernel.org/r/1422689004-13318-1-git-send-email-kuleshovmail@gmail.com
This patch adds arch specific code for kernel address sanitizer.
16TB of virtual addressed used for shadow memory. It's located in range
[ffffec0000000000 - fffffc0000000000] between vmemmap and %esp fixup
stacks.
At early stage we map whole shadow region with zero page. Latter, after
pages mapped to direct mapping address range we unmap zero pages from
corresponding shadow (see kasan_map_shadow()) and allocate and map a real
shadow memory reusing vmemmap_populate() function.
Also replace __pa with __pa_nodebug before shadow initialized. __pa with
CONFIG_DEBUG_VIRTUAL=y make external function call (__phys_addr)
__phys_addr is instrumented, so __asan_load could be called before shadow
area initialized.
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Konstantin Serebryany <kcc@google.com>
Cc: Dmitry Chernenkov <dmitryc@google.com>
Signed-off-by: Andrey Konovalov <adech.fo@gmail.com>
Cc: Yuri Gribov <tetra2005@gmail.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Jim Davis <jim.epost@gmail.com>
This causes all non-NMI, non-double-fault kernel entries from
userspace to run on the normal kernel stack. Double-fault is
exempt to minimize confusion if we double-fault directly from
userspace due to a bad kernel stack.
This is, suprisingly, simpler and shorter than the current code. It
removes the IMO rather frightening paranoid_userspace path, and it
make sync_regs much simpler.
There is no risk of stack overflow due to this change -- the kernel
stack that we switch to is empty.
This will also enable us to create non-atomic sections within
machine checks from userspace, which will simplify memory failure
handling. It will also allow the upcoming fsgsbase code to be
simplified, because it doesn't need to worry about usergs when
scheduling in paranoid_exit, as that code no longer exists.
Acked-by: Borislav Petkov <bp@alien8.de>
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Pull x86 MPX fixes from Thomas Gleixner:
"Three updates for the new MPX infrastructure:
- Use the proper error check in the trap handler
- Add a proper config option for it
- Bring documentation up to date"
* 'x86-mpx-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, mpx: Give MPX a real config option prompt
x86, mpx: Update documentation
x86_64/traps: Fix always true condition
Give MPX a real config option. The CPUs that support it (referenced
here):
https://software.intel.com/en-us/forums/topic/402393
are not available publicly yet. Right now only the software emulator
provides MPX for the general public.
[ tglx: Make it default off. There is no point in having it on right
now as no hardware and no proper tooling support are available ]
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Dave Hansen <dave@sr71.net>
Link: http://lkml.kernel.org/r/20141212183836.2569D58D@viggo.jf.intel.com
I was writing some MPX test programs and realized that the
current design makes it tricky. I did something like:
bndcfgu |= bnd_dir | BNDCFGU_ENABLE;
xrstor();
printf("xrstor done");
// #BR bounds exception here
prctl(MPX_ENABLE_MANAGEMENT);
and then compiled the app with "-fcheck-pointer-bounds -mmpx"
to enable MPX instrumentation.
The problem is that there is MPX instrumentation inserted in
to the area of the printf(). The kernel gets a bounds exception
and since management isn't yet enabled, it SIGSEGV's.
Add a bit to the documentation to explain a way around this and
where apps need to be careful.
Link: http://lkml.kernel.org/r/20141212183835.8C581B3E@viggo.jf.intel.com
Pull x86 fixes from Ingo Molnar:
"Misc fixes (mainly Andy's TLS fixes), plus a cleanup"
x86/tls: Disallow unusual TLS segments
x86/tls: Validate TLS entries to protect espfix
MAINTAINERS: Add me as x86 VDSO submaintainer
x86/asm: Unify segment selector defines
x86/asm: Guard against building the 32/64-bit versions of the asm-offsets*.c file directly
x86_64, switch_to(): Load TLS descriptors before switching DS and ES
x86/mm: Use min() instead of min_t() in the e820 printout code
x86/mm: Fix zone ranges boot printout
x86/doc: Update documentation after file shuffling
While at it, also refer to the 32 bit entry file.
Cc: linux-doc@vger.kernel.org
Cc: bpoirier@suse.de
Link: http://lkml.kernel.org/r/1418165684-6226-1-git-send-email-mcgrof@do-not-panic.com
This patch adds the Documentation/x86/intel_mpx.txt file with some
information about Intel MPX.
Signed-off-by: Qiaowei Ren <qiaowei.ren@intel.com>
Cc: linux-mm@kvack.org
Cc: linux-mips@linux-mips.org
Link: http://lkml.kernel.org/r/20141114151832.7FDB1720@viggo.jf.intel.com
Peter Anvin says:
> 0xffff880000000000 is the lowest usable address because we have
> agreed to leave 0xffff800000000000-0xffff880000000000 for the
> hypervisor or other non-OS uses.
Let's call this out in the documentation.
This came up during the kernel address sanitizer discussions
where it was proposed to use this area for other kernel things.
Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com>
Link: http://lkml.kernel.org/r/20140918195606.841389D2@viggo.jf.intel.com
Fix the documented sysconfig location of 'tlb_single_page_flush_ceiling'
which is under /sys/kernel/debug/... not /sys/debug/kernel/...
Signed-off-by: Jeremiah Mahler <jmmahler@gmail.com>
Acked-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Link: http://lkml.kernel.org/r/1407484195-1441-1-git-send-email-jmmahler@gmail.com
Most of the logic here is in the documentation file. Please take
a look at it.
I know we've come full-circle here back to a tunable, but this
new one is *WAY* simpler. I challenge anyone to describe in one
sentence how the old one worked. Here's the way the new one
works:
If we are flushing more pages than the ceiling, we use
the full flush, otherwise we use per-page flushes.
Link: http://lkml.kernel.org/r/20140731154101.12B52CAF@viggo.jf.intel.com
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next
Pull x86-64 espfix changes from Peter Anvin:
"This is the espfix64 code, which fixes the IRET information leak as
well as the associated functionality problem. With this code applied,
16-bit stack segments finally work as intended even on a 64-bit
kernel.
Consequently, this patchset also removes the runtime option that we
added as an interim measure.
To help the people working on Linux kernels for very small systems,
this patchset also makes these compile-time configurable features"
* 'x86/espfix' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
Revert "x86-64, modify_ldt: Make support for 16-bit segments a runtime option"
x86, espfix: Make it possible to disable 16-bit support
x86, espfix: Make espfix64 a Kconfig option, fix UML
x86, espfix: Fix broken header guard
x86, espfix: Move espfix definitions into a separate header file
x86-32, espfix: Remove filter for espfix32 due to race
x86-64, espfix: Don't leak bits 31:16 of %esp returning to 16-bit stack
Fixed multiple spelling errors.
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Signed-off-by: Carlos E. Garcia <carlos@cgarcia.org>
The IRET instruction, when returning to a 16-bit segment, only
restores the bottom 16 bits of the user space stack pointer. This
causes some 16-bit software to break, but it also leaks kernel state
to user space. We have a software workaround for that ("espfix") for
the 32-bit kernel, but it relies on a nonzero stack segment base which
is not available in 64-bit mode.
In checkin:
b3b42ac2cbae x86-64, modify_ldt: Ban 16-bit segments on 64-bit kernels
we "solved" this by forbidding 16-bit segments on 64-bit kernels, with
the logic that 16-bit support is crippled on 64-bit kernels anyway (no
V86 support), but it turns out that people are doing stuff like
running old Win16 binaries under Wine and expect it to work.
This works around this by creating percpu "ministacks", each of which
is mapped 2^16 times 64K apart. When we detect that the return SS is
on the LDT, we copy the IRET frame to the ministack and use the
relevant alias to return to userspace. The ministacks are mapped
readonly, so if IRET faults we promote #GP to #DF which is an IST
vector and thus has its own stack; we then do the fixup in the #DF
handler.
(Making #GP an IST exception would make the msr_safe functions unsafe
in NMI/MC context, and quite possibly have other effects.)
Special thanks to:
- Andy Lutomirski, for the suggestion of using very small stack slots
and copy (as opposed to map) the IRET frame there, and for the
suggestion to mark them readonly and let the fault promote to #DF.
- Konrad Wilk for paravirt fixup and testing.
- Borislav Petkov for testing help and useful comments.
Reported-by: Brian Gerst <brgerst@gmail.com>
Link: http://lkml.kernel.org/r/1398816946-3351-1-git-send-email-hpa@linux.intel.com
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Andrew Lutomriski <amluto@gmail.com>
Cc: Dirk Hohndel <dirk@hohndel.org>
Cc: Arjan van de Ven <arjan.van.de.ven@intel.com>
Cc: comex <comexk@gmail.com>
Cc: Alexander van Heukelum <heukelum@fastmail.fm>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: <stable@vger.kernel.org> # consider after upstream merge
The name in struct bootparam is ->initrd_addr_max and not ramdisk_max.
Fix that.
Link: http://lkml.kernel.org/r/1394633584-5509-2-git-send-email-bp@alien8.de
Some of the 00-INDEX files are somewhat outdated and some folders does
not contain 00-INDEX at all. Only outdated (with the notably exception
of spi) indexes are touched here, the 169 folders without 00-INDEX has
not been touched.
New 00-INDEX
- spi/* was added in a series of commits dating back to 2006
Added files (missing in (*/)00-INDEX)
- dmatest.txt was added by commit 851b7e16a07d ("dmatest: run test via
debugfs")
- this_cpu_ops.txt was added by commit a1b2a555d637 ("percpu: add
documentation on this_cpu operations")
- ww-mutex-design.txt was added by commit 040a0a371005 ("mutex: Add
support for wound/wait style locks")
- bcache.txt was added by commit cafe56359144 ("bcache: A block layer
cache")
- kernel-per-CPU-kthreads.txt was added by commit 49717cb40410
("kthread: Document ways of reducing OS jitter due to per-CPU
kthreads")
- phy.txt was added by commit ff764963479a ("drivers: phy: add generic
PHY framework")
- block/null_blk was added by commit 12f8f4fc0314 ("null_blk:
documentation")
- module-signing.txt was added by commit 3cafea307642 ("Add
Documentation/module-signing.txt file")
- assoc_array.txt was added by commit 3cb989501c26 ("Add a generic
associative array implementation.")
- arm/IXP4xx was part of the initial repo
- arm/cluster-pm-race-avoidance.txt was added by commit 7fe31d28e839
("ARM: mcpm: introduce helpers for platform coherency exit/setup")
- arm/firmware.txt was added by commit 7366b92a77fc ("ARM: Add
interface for registering and calling firmware-specific operations")
- arm/kernel_mode_neon.txt was added by commit 2afd0a05241d ("ARM:
7825/1: document the use of NEON in kernel mode")
- arm/tcm.txt was added by commit bc581770cfdd ("ARM: 5580/2: ARM TCM
(Tightly-Coupled Memory) support v3")
- arm/vlocks.txt was added by commit 9762f12d3e05 ("ARM: mcpm: Add
baremetal voting mutexes")
- blackfin/gptimers-example.c, Makefile was added by commit
4b60779d5ea7 ("Blackfin: add an example showing how to use the
gptimers API")
- devicetree/usage-model.txt was added by commit 31134efc681a ("dt:
Linux DT usage model documentation")
- fb/api.txt was added by commit fb21c2f42879 ("fbdev: Add FOURCC-based
format configuration API")
- fb/sm501.txt was added by commit e6a049807105 ("video, sm501: add
edid and commandline support")
- fb/udlfb.txt was added by commit 96f8d864afd6 ("fbdev: move udlfb out
of staging.")
- filesystems/Makefile was added by commit 1e0051ae48a2
("Documentation/fs/: split txt and source files")
- filesystems/nfs/nfsd-admin-interfaces.txt was added by commit
8a4c6e19cfed ("nfsd: document kernel interfaces for nfsd
configuration")
- ide/warm-plug-howto.txt was added by commit f74c91413ec6 ("ide: add
warm-plug support for IDE devices (take 2)")
- laptops/Makefile was added by commit d49129accc21
("Documentation/laptop/: split txt and source files")
- leds/leds-blinkm.txt was added by commit b54cf35a7f65 ("LEDS: add
BlinkM RGB LED driver, documentation and update MAINTAINERS")
- leds/ledtrig-oneshot.txt was added by commit 5e417281cde2 ("leds: add
oneshot trigger")
- leds/ledtrig-transient.txt was added by commit 44e1e9f8e705 ("leds:
add new transient trigger for one shot timer activation")
- m68k/README.buddha was part of the initial repo
- networking/LICENSE.(qla3xxx|qlcnic|qlge) was added by commits
40839129f779, c4e84bde1d59, 5a4faa873782
- networking/Makefile was added by commit 3794f3e812ef ("docsrc: build
Documentation/ sources")
- networking/i40evf.txt was added by commit 105bf2fe6b32 ("i40evf: add
driver to kernel build system")
- networking/ipsec.txt was added by commit b3c6efbc36e2 ("xfrm: Add
file to document IPsec corner case")
- networking/mac80211-auth-assoc-deauth.txt was added by commit
3cd7920a2be8 ("mac80211: add auth/assoc/deauth flow diagram")
- networking/netlink_mmap.txt was added by commit 5683264c3981
("netlink: add documentation for memory mapped I/O")
- networking/nf_conntrack-sysctl.txt was added by commit c9f9e0e1597f
("netfilter: doc: add nf_conntrack sysctl api documentation") lan)
- networking/team.txt was added by commit 3d249d4ca7d0 ("net: introduce
ethernet teaming device")
- networking/vxlan.txt was added by commit d342894c5d2f ("vxlan:
virtual extensible lan")
- power/runtime_pm.txt was added by commit 5e928f77a09a ("PM: Introduce
core framework for run-time PM of I/O devices (rev. 17)")
- power/charger-manager.txt was added by commit 3bb3dbbd56ea
("power_supply: Add initial Charger-Manager driver")
- RCU/lockdep-splat.txt was added by commit d7bd2d68aa2e ("rcu:
Document interpretation of RCU-lockdep splats")
- s390/kvm.txt was added by 5ecee4b (KVM: s390: API documentation)
- s390/qeth.txt was added by commit b4d72c08b358 ("qeth: bridgeport
support - basic control")
- scheduler/sched-bwc.txt was added by commit 88ebc08ea9f7 ("sched: Add
documentation for bandwidth control")
- scsi/advansys.txt was added by commit 4bd6d7f35661 ("[SCSI] advansys:
Move documentation to Documentation/scsi")
- scsi/bfa.txt was added by commit 1ec90174bdb4 ("[SCSI] bfa: add
readme file")
- scsi/bnx2fc.txt was added by commit 12b8fc10eaf4 ("[SCSI] bnx2fc: Add
driver documentation")
- scsi/cxgb3i.txt was added by commit c3673464ebc0 ("[SCSI] cxgb3i: Add
cxgb3i iSCSI driver.")
- scsi/hpsa.txt was added by commit 992ebcf14f3c ("[SCSI] hpsa: Add
hpsa.txt to Documentation/scsi")
- scsi/link_power_management_policy.txt was added by commit
ca77329fb713 ("[libata] Link power management infrastructure")
- scsi/osd.txt was added by commit 78e0c621deca ("[SCSI] osd:
Documentation for OSD library")
- scsi/scsi-parameter.txt was created/moved by commit 163475fb111c
("Documentation: move SCSI parameters to their own text file")
- serial/driver was part of the initial repo
- serial/n_gsm.txt was added by commit 323e84122ec6 ("n_gsm: add a
documentation")
- timers/Makefile was added by commit 3794f3e812ef ("docsrc: build
- virt/kvm/s390.txt was added by commit d9101fca3d57 ("KVM: s390:
diagnose call documentation")
- vm/split_page_table_lock was added by commit 49076ec2ccaf ("mm:
dynamically allocate page->ptl if it cannot be embedded to struct
page")
- w1/slaves/w1_ds28e04 was added by commit fbf7f7b4e2ae ("w1: Add
1-wire slave device driver for DS28E04-100")
- w1/masters/omap-hdq was added by commit e0a29382c6f5 ("hdq:
documentation for OMAP HDQ")
- x86/early-microcode.txt was added by commit 0d91ea86a895 ("x86, doc:
Documentation for early microcode loading")
- x86/earlyprintk.txt was added by commit a1aade478862 ("x86/doc:
mini-howto for using earlyprintk=dbgp")
- x86/entry_64.txt was added by commit 8b4777a4b50c ("x86-64: Document
some of entry_64.S")
- x86/pat.txt was added by commit d27554d874c7 ("x86: PAT
documentation")
Moved files
- arm/kernel_user_helpers.txt was moved out of arch/arm/kernel by
commit 37b8304642c7 ("ARM: kuser: move interface documentation out of
the source code")
- efi-stub.txt was moved out of x86/ and down into Documentation/ in
commit 4172fe2f8a47 ("EFI stub documentation updates")
- laptops/hpfall.c was moved out of hwmon/ and into laptops/ in commit
efcfed9bad88 ("Move hp_accel to drivers/platform/x86")
- commit 5616c23ad9cd ("x86: doc: move x86-generic documentation from
Doc/x86/i386"):
* x86/usb-legacy-support.txt
* x86/boot.txt
* x86/zero_page.txt
- power/video_extension.txt was moved to acpi in commit 70e66e4df191
("ACPI / video: move video_extension.txt to Documentation/acpi")
Removed files (left in 00-INDEX)
- memory.txt was removed by commit 00ea8990aadf ("memory.txt: remove
stray information")
- gpio.txt was moved to gpio/ in commit fd8e198cfcaa ("Documentation:
gpiolib: document new interface")
- networking/DLINK.txt was removed by commit 168e06ae26dd
("drivers/net: delete old parallel port de600/de620 drivers")
- serial/hayes-esp.txt was removed by commit f53a2ade0bb9 ("tty: esp:
remove broken driver")
- s390/TAPE was removed by commit 9e280f669308 ("[S390] remove tape
block docu")
- vm/locking was removed by commit 57ea8171d2bc ("mm: documentation:
remove hopelessly out-of-date locking doc")
- laptops/acer-wmi.txt was remvoed by commit 020036678e81 ("acer-wmi:
Delete out-of-date documentation")
Typos/misc issues
- rpc-server-gss.txt was added as knfsd-rpcgss.txt in commit
030d794bf498 ("SUNRPC: Use gssproxy upcall for server RPCGSS
authentication.")
- commit b88cf73d9278 ("net: add missing entries to
Documentation/networking/00-INDEX")
* generic-hdlc.txt was added as generic_hdlc.txt
* spider_net.txt was added as spider-net.txt
- w1/master/mxc-w1 was added as mxc_w1 by commit a5fd9139f74c ("w1: add
1-wire master driver for i.MX27 / i.MX31")
- s390/zfcpdump.txt was added as zfcpdump by commit 6920c12a407e
("[S390] Add Documentation/s390/00-INDEX.")
Signed-off-by: Henrik Austad <henrik@austad.us>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> [rcu bits]
Acked-by: Rob Landley <rob@landley.net>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Mark Brown <broonie@kernel.org>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: Len Brown <len.brown@intel.com>
Cc: James Bottomley <JBottomley@parallels.com>
Pull trivial tree updates from Jiri Kosina:
"Usual rocket science stuff from trivial.git"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
neighbour.h: fix comment
sched: Fix warning on make htmldocs caused by wait.h
slab: struct kmem_cache is protected by slab_mutex
doc: Fix typo in USB Gadget Documentation
of/Kconfig: Spelling s/one/once/
mkregtable: Fix sscanf handling
lp5523, lp8501: comment improvements
thermal: rcar: comment spelling
treewide: fix comments and printk msgs
IXP4xx: remove '1 &&' from a condition check in ixp4xx_restart()
Documentation: update /proc/uptime field description
Documentation: Fix size parameter for snprintf
arm: fix comment header and macro name
asm-generic: uaccess: Spelling s/a ny/any/
mtd: onenand: fix comment header
doc: driver-model/platform.txt: fix a typo
drivers: fix typo in DEVTMPFS_MOUNT Kconfig help text
doc: Fix typo (acces_process_vm -> access_process_vm)
treewide: Fix typos in printk
drivers/gpu/drm/qxl/Kconfig: reformat the help text
Old kexec-tools can not load new kernels. The reason is kexec-tools does
not fill efi_info in x86 setup header previously, thus EFI failed to
initialize. In new kexec-tools it will by default to fill efi_info and
pass other EFI required infomation to 2nd kernel so kexec kernel EFI
initialization can succeed finally.
To prevent from breaking userspace, add a new xloadflags bit so
kexec-tools can check the flag and switch to old logic.
Signed-off-by: Dave Young <dyoung@redhat.com>
Acked-by: Borislav Petkov <bp@suse.de>
Tested-by: Toshi Kani <toshi.kani@hp.com>
Sync with Linus' tree to be able to apply fixes on top of newer things
in tree (efi-stub).
Removed obsolte parameters from boot-options.txt.
Verified by grepping around in arch/x86/.
Signed-off-by: Richard Weinberger <richard@nod.at>
git://git.kernel.org/pub/scm/linux/kernel/git/mfleming/efi into x86/efi
Pull EFI virtual mapping changes from Matt Fleming:
* New static EFI runtime services virtual mapping layout which is
groundwork for kexec support on EFI. (Borislav Petkov)
Pull x86 EFI changes from Ingo Molnar:
"Main changes:
- Add support for earlyprintk=efi which uses the EFI framebuffer.
Very useful for debugging boot problems.
- EFI stub support for large memory maps (more than 128 entries)
- EFI ARM support - this was mostly done by generalizing x86 <-> ARM
platform differences, such as by moving x86 EFI code into
drivers/firmware/efi/ and sharing it with ARM.
- Documentation updates
- misc fixes"
* 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (26 commits)
x86/efi: Add EFI framebuffer earlyprintk support
boot, efi: Remove redundant memset()
x86/efi: Fix config_table_type array termination
x86 efi: bugfix interrupt disabling sequence
x86: EFI stub support for large memory maps
efi: resolve warnings found on ARM compile
efi: Fix types in EFI calls to match EFI function definitions.
efi: Renames in handle_cmdline_files() to complete generalization.
efi: Generalize handle_ramdisks() and rename to handle_cmdline_files().
efi: Allow efi_free() to be called with size of 0
efi: use efi_get_memory_map() to get final map for x86
efi: generalize efi_get_memory_map()
efi: Rename __get_map() to efi_get_memory_map()
efi: Move unicode to ASCII conversion to shared function.
efi: Generalize relocate_kernel() for use by other architectures.
efi: Move relocate_kernel() to shared file.
efi: Enforce minimum alignment of 1 page on allocations.
efi: Rename memory allocation/free functions
efi: Add system table pointer argument to shared functions.
efi: Move common EFI stub code from x86 arch code to common location
