path: root/Documentation/x86_64
2006-12-07[PATCH] Calgary: allow compiling Calgary in but not using it by defaultMuli Ben-Yehuda
This patch makes it possible to compile Calgary in but not use it by default. In this mode, use 'iommu=calgary' to activate it. Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Jon Mason <jdmason@kudzu.us> Signed-off-by: Andi Kleen <ak@suse.de>
2006-12-07[PATCH] x86-64: Try multiple timer variants in check_timerAndi Kleen
Instead of adding all kinds of more quirks try various timer routing variants in check_timer. In particular this tries to handle quirks from: - Nvidia NF2-4 reference BIOS: wrong timer override - Asus: Wrong timer override but no HPET table - ATI: require timer disabled in 8259 - Some boards: require timer enabled in 8259 We just try many of the the known variants in the hopefully right order in check_timer. Trying pin 0/2 on Nvidia suggested by Tim Hockin. TBD Experimental. Needs a lot of testing Signed-off-by: Andi Kleen <ak@suse.de>
2006-10-03Fix typos in Documentation/: 'Q'-'R'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'Q'-'R'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-30[PATCH] Document iommu=panicAndi Kleen
2006-09-30[PATCH] Allow disabling DAC using command line optionsAndi Kleen
Might or might not work around some reported bugs on VIA systems. Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-26[PATCH] Add stack documentation document from Keith OwensAndi Kleen
Describes the stack organization on x86-64. I changed it a bit and removed some obsolete information and the questions. Cc: kaos@sgi.com Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-26[PATCH] Document backtracer selection optionsAndi Kleen
2006-07-28[PATCH] x86_64: Document backtracer selection optionsAndi Kleen
Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] x86_64: Calgary IOMMU - Calgary specific bitsJon Mason
This patch hooks Calgary into the build, the x86-64 IOMMU initialization paths, and introduces the Calgary specific bits. The implementation draws inspiration from both PPC (which has support for the same chip but requires firmware support which we don't have on x86-64) and gart. Calgary is different from gart in that it support a translation table per PHB, as opposed to the single gart aperture. Changes from previous version: * Addition of boot-time disablement for bus-level translation/isolation (e.g, enable userspace DMA for things like X) * Usage of newer IOMMU abstraction functions Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-09[PATCH] x86_64: Reserve SRAT hotadd memory on x86-64Andi Kleen
From: Keith Mannthey, Andi Kleen Implement memory hotadd without sparsemem. The memory in the SRAT hotadd area is just preserved instead and can be activated later. There are a few restrictions: - Only one continuous hotadd area allowed per node The main problem is dealing with the many buggy SRAT tables that are out there. The strategy here is to reject anything suspicious. Originally from Keith Mannthey, with several hacks and changes by AK and also contributions from Andrew Morton [ TBD: Problems pointed out by KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>: 1) Goto's rebuild_zonelist patch will not work if CONFIG_MEMORY_HOTPLUG=n. Rebuilding zonelist is necessary when the system has just memory < 4G at boot, and hot add memory > 4G. because x86_64 has DMA32, ZONE_NORAML is not included into zonelist at boot time if system doesn't have memory >4G at boot. [AK: should just force the higher zones at boot time when SRAT tells us] 2) zone and node's spanned_pages and present_pages are not incremented. They should be. For example, our server (ia64/Fujitsu PrimeQuest) can equip memory from 4G to 1T(maybe 2T in future), and SRAT will *always* say we have possible 1T +memory. (Microsoft requires "write all possible memory in SRAT") When we reserve memmap for possible 1T memory, Linux will not work well in +minimum 4G configuraion ;) [AK: needs limiting to 5-10% of max memory] ] Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-26[PATCH] x86_64: Better ATI timer fixAndi Kleen
The previous experiment for using apicmaintimer on ATI systems didn't work out very well. In particular laptops with C2/C3 support often don't let it tick during idle, which makes it useless. There were also some other bugs that made the apicmaintimer often not used at all. I tried some other experiments - running timer over RTC and some other things but they didn't really work well neither. I rechecked the specs now and it turns out this simple change is actually enough to avoid the double ticks on the ATI systems. We just turn off IRQ 0 in the 8254 and only route it directly using the IO-APIC. I tested it on a few ATI systems and it worked there. In fact it worked on all chipsets (NVidia, Intel, AMD, ATI) I tried it on. According to the ACPI spec routing should always work through the IO-APIC so I think it's the correct thing to do anyways (and most of the old gunk in check_timer should be thrown away for x86-64). But for 2.6.16 it's best to do a fairly minimal change: - Use the known to be working everywhere-but-ATI IRQ0 both over 8254 and IO-APIC setup everywhere - Except on ATI disable IRQ0 in the 8254 - Remove the code to select apicmaintimer on ATI chipsets - Add some boot options to allow to override this (just paranoia) In 2.6.17 I hope to switch the default over to this for everybody. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-04[PATCH] x86_64: Calibrate APIC timer using PM timerAndi Kleen
On some broken motherboards (at least one NForce3 based AMD64 laptop) the PIT timer runs at a incorrect frequency. This patch adds a new option "apicpmtimer" that allows to use the APIC timer and calibrate it using the PMTimer. It requires the earlier patch that allows to run the main timer from the APIC. Specifying apicpmtimer implies apicmaintimer. The option defaults to off for now. I tested it on a few systems and the resulting APIC timer frequencies were usually a bit off, but always <1%, which should be tolerable. TBD figure out heuristic to enable this automatically on the affected systems TBD perhaps do it on all NForce3s or using DMI? Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-04[PATCH] x86_64: Allow to run main time keeping from the local APIC interruptAndi Kleen
Another piece from the no-idle-tick patch. This can be enabled with the "apicmaintimer" option. This is mainly useful when the PIT/HPET interrupt is unreliable. Note there are some systems that are known to stop the APIC timer in C3. For those it will never work, but this case should be automatically detected. It also only works with PM timer right now. When HPET is used the way the main timer handler computes the delay doesn't work. It should be a bit more efficient because there is one less regular interrupt to process on the boot processor. Requires earlier bugfix from Venkatesh Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-15spelling: s/appropiate/appropriate/Adrian Bunk
2006-01-11[PATCH] x86_64: Add documentation for CPU hotplug ACPI extensionAndi Kleen
Cc: len.brown@intel.com, ashok.ray@intel.com Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] x86_64: Don't reserve hotplug CPUs by defaultAndi Kleen
Most users don't need it so no need to waste memory. This means an user has to specify the appropiate number of hotplug CPUs on the command line with additional_cpus=... or fix their BIOS to follow the convention in Documentation/x86-64/cpu-hotplug-spec Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-14[PATCH] x86_64: Remove CONFIG_CHECKING and add command line option for ↵Andi Kleen
pagefault tracing CONFIG_CHECKING covered some debugging code used in the early times of the port. But it wasn't even SMP safe for quite some time and the bugs it checked for seem to be gone. This patch removes all the code to verify GS at kernel entry. There haven't been any new bugs in this area for a long time. Previously it also covered the sysctl for the page fault tracing. That didn't make much sense because that code was unconditionally compiled in. I made that a boot option now because it is typically only useful at boot. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-14[PATCH] x86_64: Log machine checks from boot on Intel systemsAndi Kleen
The logging for boot errors was turned off because it was broken on some AMD systems. But give Intel EM64T systems a chance because they are supposed to be correct there. The advantage is that there is a chance to actually log uncorrected machine checks after the reset. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-14[PATCH] x86_64: New heuristics to find out hotpluggable CPUs.Andi Kleen
With a NR_CPUS==128 kernel with CPU hotplug enabled we would waste 4MB on per CPU data of all possible CPUs. The reason was that HOTPLUG always set up possible map to NR_CPUS cpus and then we need to allocate that much (each per CPU data is roughly ~32k now) The underlying problem is that ACPI didn't tell us how many hotplug CPUs the platform supports. So the old code just assumed all, which would lead to this memory wastage. This implements some new heuristics: - If the BIOS specified disabled CPUs in the ACPI/mptables assume they can be enabled later (this is bending the ACPI specification a bit, but seems like a obvious extension) - The user can overwrite it with a new additionals_cpus=NUM option - Otherwise use half of the available CPUs or 2, whatever is more. Cc: ashok.raj@intel.com Cc: len.brown@intel.com Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-14[PATCH] x86_64: Some clarifications for Documention/x86_64/mm.txtAndi Kleen
I got some questions on this, so just fix up the documentation. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-12[PATCH] x86-64: Add command line option to set machine check tolerance levelAndi Kleen
2005-08-07[PATCH] x86_64: ignore machine checks from boot timeAndi Kleen
Don't log machine check events left over from boot. Too many BIOSes leave bogus events in there. This unfortunately also makes it impossible to log events that caused a reboot. For people with non broken BIOS there is mce=bootlog Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] x86_64: Some updates for boot-options.txtAndi Kleen
2005-05-20[PATCH] x86_64: Add option to disable timer checkAndi Kleen
This works around the too fast timer seen on some ATI boards. I don't feel confident enough about it yet to enable it by default, but give users the option. Patch and debugging from Christopher Allen Wing <wingc@engin.umich.edu>, with minor tweaks (renamed the option and documented it) Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
