commit 5ac7eace2d00eab5ae0e9fdee63e38aee6001f7c upstream
Add a facility whereby proposed new links to be added to a keyring can be
vetted, permitting them to be rejected if necessary. This can be used to
block public keys from which the signature cannot be verified or for which
the signature verification fails. It could also be used to provide
blacklisting.
This affects operations like add_key(), KEYCTL_LINK and KEYCTL_INSTANTIATE.
To this end:
(1) A function pointer is added to the key struct that, if set, points to
the vetting function. This is called as:
int (*restrict_link)(struct key *keyring,
const struct key_type *key_type,
unsigned long key_flags,
const union key_payload *key_payload),
where 'keyring' will be the keyring being added to, key_type and
key_payload will describe the key being added and key_flags[*] can be
AND'ed with KEY_FLAG_TRUSTED.
[*] This parameter will be removed in a later patch when
KEY_FLAG_TRUSTED is removed.
The function should return 0 to allow the link to take place or an
error (typically -ENOKEY, -ENOPKG or -EKEYREJECTED) to reject the
link.
The pointer should not be set directly, but rather should be set
through keyring_alloc().
Note that if called during add_key(), preparse is called before this
method, but a key isn't actually allocated until after this function
is called.
(2) KEY_ALLOC_BYPASS_RESTRICTION is added. This can be passed to
key_create_or_update() or key_instantiate_and_link() to bypass the
restriction check.
(3) KEY_FLAG_TRUSTED_ONLY is removed. The entire contents of a keyring
with this restriction emplaced can be considered 'trustworthy' by
virtue of being in the keyring when that keyring is consulted.
(4) key_alloc() and keyring_alloc() take an extra argument that will be
used to set restrict_link in the new key. This ensures that the
pointer is set before the key is published, thus preventing a window
of unrestrictedness. Normally this argument will be NULL.
(5) As a temporary affair, keyring_restrict_trusted_only() is added. It
should be passed to keyring_alloc() as the extra argument instead of
setting KEY_FLAG_TRUSTED_ONLY on a keyring. This will be replaced in
a later patch with functions that look in the appropriate places for
authoritative keys.
Tuned for toradex_vf_4.4-next
include/linux/key.h
security/keys/process_keys.c
Reviewed-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
This is the 4.4.220 stable release
commit 4054ab64e29bb05b3dfe758fff3c38a74ba753bb upstream.
A recent change to the netlink code: 6e237d099fac ("netlink: Relax attr
validation for fixed length types") logs a warning when programs send
messages with invalid attributes (e.g., wrong length for a u32). Yafang
reported this error message for tools/accounting/getdelays.c.
send_cmd() is wrongly adding 1 to the attribute length. As noted in
include/uapi/linux/netlink.h nla_len should be NLA_HDRLEN + payload
length, so drop the +1.
Fixes: 9e06d3f9f6b1 ("per task delay accounting taskstats interface: documentation fix")
Reported-by: Yafang Shao <laoar.shao@gmail.com>
Signed-off-by: David Ahern <dsahern@kernel.org>
Tested-by: Yafang Shao <laoar.shao@gmail.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Shailabh Nagar <nagar@watson.ibm.com>
Cc: <stable@vger.kernel.org>
Link: http://lkml.kernel.org/r/20200327173111.63922-1-dsahern@kernel.org
[ Upstream commit 26d5bb9e4c4b541c475751e015072eb2cbf70d15 ]
FMAN DMA read or writes under heavy traffic load may cause FMAN
internal resource leak; thus stopping further packet processing.
The FMAN internal queue can overflow when FMAN splits single
read or write transactions into multiple smaller transactions
such that more than 17 AXI transactions are in flight from FMAN
to interconnect. When the FMAN internal queue overflows, it can
stall further packet processing. The issue can occur with any one
of the following three conditions:
1. FMAN AXI transaction crosses 4K address boundary (Errata
A010022)
2. FMAN DMA address for an AXI transaction is not 16 byte
aligned, i.e. the last 4 bits of an address are non-zero
3. Scatter Gather (SG) frames have more than one SG buffer in
the SG list and any one of the buffers, except the last
buffer in the SG list has data size that is not a multiple
of 16 bytes, i.e., other than 16, 32, 48, 64, etc.
With any one of the above three conditions present, there is
likelihood of stalled FMAN packet processing, especially under
stress with multiple ports injecting line-rate traffic.
To avoid situations that stall FMAN packet processing, all of the
above three conditions must be avoided; therefore, configure the
system with the following rules:
1. Frame buffers must not span a 4KB address boundary, unless
the frame start address is 256 byte aligned
2. All FMAN DMA start addresses (for example, BMAN buffer
address, FD[address] + FD[offset]) are 16B aligned
3. SG table and buffer addresses are 16B aligned and the size
of SG buffers are multiple of 16 bytes, except for the last
SG buffer that can be of any size.
Additional workaround notes:
- Address alignment of 64 bytes is recommended for maximally
efficient system bus transactions (although 16 byte alignment is
sufficient to avoid the stall condition)
- To support frame sizes that are larger than 4K bytes, there are
two options:
1. Large single buffer frames that span a 4KB page boundary can
be converted into SG frames to avoid transaction splits at
the 4KB boundary,
2. Align the large single buffer to 256B address boundaries,
ensure that the frame address plus offset is 256B aligned.
- If software generated SG frames have buffers that are unaligned
and with random non-multiple of 16 byte lengths, before
transmitting such frames via FMAN, frames will need to be copied
into a new single buffer or multiple buffer SG frame that is
compliant with the three rules listed above.
Signed-off-by: Madalin Bucur <madalin.bucur@nxp.com>
This is the 4.4.214 stable release
commit 73668309215285366c433489de70d31362987be9 upstream.
mei client bus added the client protocol version to the device alias,
but ABI documentation was not updated.
Fixes: b26864cad1c9 (mei: bus: add client protocol version to the device alias)
Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
Link: https://lore.kernel.org/r/20191008005735.12707-1-tomas.winkler@intel.com
[ Upstream commit 73852e56827f5cb5db9d6e8dd8191fc2f2e8f424 ]
The abracon,tc-resistor property value is in kOhm.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
[ Upstream commit 46b14eef59a8157138dc02f916a7f97c73b3ec53 ]
Signed-off-by: Peter Hutterer <peter.hutterer@who-t.net>
commit 64870ed1b12e235cfca3f6c6da75b542c973ff78 upstream.
For MDS vulnerable processors with TSX support, enabling either MDS or
TAA mitigations will enable the use of VERW to flush internal processor
buffers at the right code path. IOW, they are either both mitigated
or both not. However, if the command line options are inconsistent,
the vulnerabilites sysfs files may not report the mitigation status
correctly.
For example, with only the "mds=off" option:
vulnerabilities/mds:Vulnerable; SMT vulnerable
vulnerabilities/tsx_async_abort:Mitigation: Clear CPU buffers; SMT vulnerable
The mds vulnerabilities file has wrong status in this case. Similarly,
the taa vulnerability file will be wrong with mds mitigation on, but
taa off.
Change taa_select_mitigation() to sync up the two mitigation status
and have them turned off if both "mds=off" and "tsx_async_abort=off"
are present.
Update documentation to emphasize the fact that both "mds=off" and
"tsx_async_abort=off" have to be specified together for processors that
are affected by both TAA and MDS to be effective.
[ bp: Massage and add kernel-parameters.txt change too. ]
Fixes: 1b42f017415b ("x86/speculation/taa: Add mitigation for TSX Async Abort")
Signed-off-by: Waiman Long <longman@redhat.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: linux-doc@vger.kernel.org
Cc: Mark Gross <mgross@linux.intel.com>
Cc: Pawan Gupta <pawan.kumar.gupta@linux.intel.com>
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Tyler Hicks <tyhicks@canonical.com>
Cc: x86-ml <x86@kernel.org>
Link: https://lkml.kernel.org/r/20191115161445.30809-2-longman@redhat.com
[ Upstream commit 185647813cac080453cb73a2e034a8821049f2a7 ]
"out_buf_sz" needs to be signed for the error handling to work.
commit db4d30fbb71b47e4ecb11c4efa5d8aad4b03dfae upstream.
Some processors may incur a machine check error possibly resulting in an
unrecoverable CPU lockup when an instruction fetch encounters a TLB
multi-hit in the instruction TLB. This can occur when the page size is
changed along with either the physical address or cache type. The relevant
erratum can be found here:
https://bugzilla.kernel.org/show_bug.cgi?id=205195
There are other processors affected for which the erratum does not fully
disclose the impact.
This issue affects both bare-metal x86 page tables and EPT.
It can be mitigated by either eliminating the use of large pages or by
using careful TLB invalidations when changing the page size in the page
tables.
Just like Spectre, Meltdown, L1TF and MDS, a new bit has been allocated in
MSR_IA32_ARCH_CAPABILITIES (PSCHANGE_MC_NO) and will be set on CPUs which
are mitigated against this issue.
Signed-off-by: Vineela Tummalapalli <vineela.tummalapalli@intel.com>
Co-developed-by: Pawan Gupta <pawan.kumar.gupta@linux.intel.com>
Signed-off-by: Pawan Gupta <pawan.kumar.gupta@linux.intel.com>
[bwh: Backported to 4.4:
- No support for X86_VENDOR_HYGON, ATOM_AIRMONT_NP
- Adjust context, indentation]
commit a7a248c593e4fd7a67c50b5f5318fe42a0db335e upstream.
Add the documenation for TSX Async Abort. Include the description of
the issue, how to check the mitigation state, control the mitigation,
guidance for system administrators.
[ bp: Add proper SPDX tags, touch ups by Josh and me. ]
Co-developed-by: Antonio Gomez Iglesias <antonio.gomez.iglesias@intel.com>
Signed-off-by: Antonio Gomez Iglesias <antonio.gomez.iglesias@intel.com>
Reviewed-by: Mark Gross <mgross@linux.intel.com>
Reviewed-by: Tony Luck <tony.luck@intel.com>
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
- Drop changes to ReST index files
- Drop "nosmt" documentation
- Adjust filenames, context]
commit 7531a3596e3272d1f6841e0d601a614555dc6b65 upstream.
Platforms which are not affected by X86_BUG_TAA may want the TSX feature
enabled. Add "auto" option to the TSX cmdline parameter. When tsx=auto
disable TSX when X86_BUG_TAA is present, otherwise enable TSX.
More details on X86_BUG_TAA can be found here:
https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/tsx_async_abort.html
[ bp: Extend the arg buffer to accommodate "auto\0". ]
[bwh: Backported to 4.4: adjust filename]
commit 95c5824f75f3ba4c9e8e5a4b1a623c95390ac266 upstream.
Add a kernel cmdline parameter "tsx" to control the Transactional
Synchronization Extensions (TSX) feature. On CPUs that support TSX
control, use "tsx=on|off" to enable or disable TSX. Not specifying this
option is equivalent to "tsx=off". This is because on certain processors
TSX may be used as a part of a speculative side channel attack.
Carve out the TSX controlling functionality into a separate compilation
unit because TSX is a CPU feature while the TSX async abort control
machinery will go to cpu/bugs.c.
[ bp: - Massage, shorten and clear the arg buffer.
- Clarifications of the tsx= possible options - Josh.
- Expand on TSX_CTRL availability - Pawan. ]
- Drop __ro_after_init attribute
commit 015664d15270a112c2371d812f03f7c579b35a73 upstream.
The Rio500 kernel driver has not been used by Rio500 owners since 2001
not long after the rio500 project added support for a user-space USB stack
through the very first versions of usbdevfs and then libusb.
Support for the kernel driver was removed from the upstream utilities
in 2008:
https://gitlab.freedesktop.org/hadess/rio500/commit/943f624ab721eb8281c287650fcc9e2026f6f5db
Cc: Cesar Miquel <miquel@df.uba.ar>
Signed-off-by: Bastien Nocera <hadess@hadess.net>
Cc: stable <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/6251c17584d220472ce882a3d9c199c401a51a71.camel@hadess.net
[ Upstream commit c49a0a80137c7ca7d6ced4c812c9e07a949f6f24 ]
There have been reports of RDRAND issues after resuming from suspend on
some AMD family 15h and family 16h systems. This issue stems from a BIOS
not performing the proper steps during resume to ensure RDRAND continues
to function properly.
RDRAND support is indicated by CPUID Fn00000001_ECX[30]. This bit can be
reset by clearing MSR C001_1004[62]. Any software that checks for RDRAND
support using CPUID, including the kernel, will believe that RDRAND is
not supported.
Update the CPU initialization to clear the RDRAND CPUID bit for any family
15h and 16h processor that supports RDRAND. If it is known that the family
15h or family 16h system does not have an RDRAND resume issue or that the
system will not be placed in suspend, the "rdrand=force" kernel parameter
can be used to stop the clearing of the RDRAND CPUID bit.
Additionally, update the suspend and resume path to save and restore the
MSR C001_1004 value to ensure that the RDRAND CPUID setting remains in
place after resuming from suspend.
Note, that clearing the RDRAND CPUID bit does not prevent a processor
that normally supports the RDRAND instruction from executing it. So any
code that determined the support based on family and model won't #UD.
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
Cc: Andrew Cooper <andrew.cooper3@citrix.com>
Cc: Chen Yu <yu.c.chen@intel.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: "linux-doc@vger.kernel.org" <linux-doc@vger.kernel.org>
Cc: "linux-pm@vger.kernel.org" <linux-pm@vger.kernel.org>
Cc: Nathan Chancellor <natechancellor@gmail.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Cc: "x86@kernel.org" <x86@kernel.org>
Link: https://lkml.kernel.org/r/7543af91666f491547bd86cebb1e17c66824ab9f.1566229943.git.thomas.lendacky@amd.com
[sl: adjust context in docs]
commit 1ae2324f732c9c4e2fa4ebd885fa1001b70d52e1 upstream.
HalfSipHash, or hsiphash, is a shortened version of SipHash, which
generates 32-bit outputs using a weaker 64-bit key. It has *much* lower
security margins, and shouldn't be used for anything too sensitive, but
it could be used as a hashtable key function replacement, if the output
is never exposed, and if the security requirement is not too high.
The goal is to make this something that performance-critical jhash users
would be willing to use.
On 64-bit machines, HalfSipHash1-3 is slower than SipHash1-3, so we alias
SipHash1-3 to HalfSipHash1-3 on those systems.
64-bit x86_64:
[ 0.509409] test_siphash: SipHash2-4 cycles: 4049181
[ 0.510650] test_siphash: SipHash1-3 cycles: 2512884
[ 0.512205] test_siphash: HalfSipHash1-3 cycles: 3429920
[ 0.512904] test_siphash: JenkinsHash cycles: 978267
So, we map hsiphash() -> SipHash1-3
32-bit x86:
[ 0.509868] test_siphash: SipHash2-4 cycles: 14812892
[ 0.513601] test_siphash: SipHash1-3 cycles: 9510710
[ 0.515263] test_siphash: HalfSipHash1-3 cycles: 3856157
[ 0.515952] test_siphash: JenkinsHash cycles: 1148567
So, we map hsiphash() -> HalfSipHash1-3
hsiphash() is roughly 3 times slower than jhash(), but comes with a
considerable security improvement.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
Reviewed-by: Jean-Philippe Aumasson <jeanphilippe.aumasson@gmail.com>
[bwh: Backported to 4.4 to avoid regression for WireGuard with only half
the siphash API present]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 2c956a60778cbb6a27e0c7a8a52a91378c90e1d1 upstream.
SipHash is a 64-bit keyed hash function that is actually a
cryptographically secure PRF, like HMAC. Except SipHash is super fast,
and is meant to be used as a hashtable keyed lookup function, or as a
general PRF for short input use cases, such as sequence numbers or RNG
chaining.
For the first usage:
There are a variety of attacks known as "hashtable poisoning" in which an
attacker forms some data such that the hash of that data will be the
same, and then preceeds to fill up all entries of a hashbucket. This is
a realistic and well-known denial-of-service vector. Currently
hashtables use jhash, which is fast but not secure, and some kind of
rotating key scheme (or none at all, which isn't good). SipHash is meant
as a replacement for jhash in these cases.
There are a modicum of places in the kernel that are vulnerable to
hashtable poisoning attacks, either via userspace vectors or network
vectors, and there's not a reliable mechanism inside the kernel at the
moment to fix it. The first step toward fixing these issues is actually
getting a secure primitive into the kernel for developers to use. Then
we can, bit by bit, port things over to it as deemed appropriate.
While SipHash is extremely fast for a cryptographically secure function,
it is likely a bit slower than the insecure jhash, and so replacements
will be evaluated on a case-by-case basis based on whether or not the
difference in speed is negligible and whether or not the current jhash usage
poses a real security risk.
For the second usage:
A few places in the kernel are using MD5 or SHA1 for creating secure
sequence numbers, syn cookies, port numbers, or fast random numbers.
SipHash is a faster and more fitting, and more secure replacement for MD5
in those situations. Replacing MD5 and SHA1 with SipHash for these uses is
obvious and straight-forward, and so is submitted along with this patch
series. There shouldn't be much of a debate over its efficacy.
Dozens of languages are already using this internally for their hash
tables and PRFs. Some of the BSDs already use this in their kernels.
SipHash is a widely known high-speed solution to a widely known set of
problems, and it's time we catch-up.
Cc: Eric Biggers <ebiggers3@gmail.com>
Cc: David Laight <David.Laight@aculab.com>
[bwh: Backported to 4.4 as dependency of commits df453700e8d8 "inet: switch
IP ID generator to siphash" and 3c79107631db "netfilter: ctnetlink: don't
use conntrack/expect object addresses as id":
- Adjust context]
commit a2059825986a1c8143fd6698774fa9d83733bb11 upstream.
The previous commit added macro calls in the entry code which mitigate the
Spectre v1 swapgs issue if the X86_FEATURE_FENCE_SWAPGS_* features are
enabled. Enable those features where applicable.
The mitigations may be disabled with "nospectre_v1" or "mitigations=off".
There are different features which can affect the risk of attack:
- When FSGSBASE is enabled, unprivileged users are able to place any
value in GS, using the wrgsbase instruction. This means they can
write a GS value which points to any value in kernel space, which can
be useful with the following gadget in an interrupt/exception/NMI
handler:
if (coming from user space)
swapgs
mov %gs:<percpu_offset>, %reg1
// dependent load or store based on the value of %reg
// for example: mov %(reg1), %reg2
If an interrupt is coming from user space, and the entry code
speculatively skips the swapgs (due to user branch mistraining), it
may speculatively execute the GS-based load and a subsequent dependent
load or store, exposing the kernel data to an L1 side channel leak.
Note that, on Intel, a similar attack exists in the above gadget when
coming from kernel space, if the swapgs gets speculatively executed to
switch back to the user GS. On AMD, this variant isn't possible
because swapgs is serializing with respect to future GS-based
accesses.
NOTE: The FSGSBASE patch set hasn't been merged yet, so the above case
doesn't exist quite yet.
- When FSGSBASE is disabled, the issue is mitigated somewhat because
unprivileged users must use prctl(ARCH_SET_GS) to set GS, which
restricts GS values to user space addresses only. That means the
gadget would need an additional step, since the target kernel address
needs to be read from user space first. Something like:
swapgs
mov (%reg1), %reg2
// dependent load or store based on the value of %reg2
// for example: mov %(reg2), %reg3
It's difficult to audit for this gadget in all the handlers, so while
there are no known instances of it, it's entirely possible that it
exists somewhere (or could be introduced in the future). Without
tooling to analyze all such code paths, consider it vulnerable.
Effects of SMAP on the !FSGSBASE case:
- If SMAP is enabled, and the CPU reports RDCL_NO (i.e., not
susceptible to Meltdown), the kernel is prevented from speculatively
reading user space memory, even L1 cached values. This effectively
disables the !FSGSBASE attack vector.
- If SMAP is enabled, but the CPU *is* susceptible to Meltdown, SMAP
still prevents the kernel from speculatively reading user space
memory. But it does *not* prevent the kernel from reading the
user value from L1, if it has already been cached. This is probably
only a small hurdle for an attacker to overcome.
Thanks to Dave Hansen for contributing the speculative_smap() function.
Thanks to Andrew Cooper for providing the inside scoop on whether swapgs
is serializing on AMD.
[ tglx: Fixed the USER fence decision and polished the comment as suggested
by Dave Hansen ]
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Reviewed-by: Dave Hansen <dave.hansen@intel.com>
- Check for X86_FEATURE_KAISER instead of X86_FEATURE_PTI
- mitigations= parameter is x86-only here
- Don't use __ro_after_init
- Adjust filename, context]
[ Upstream commit 0df82dcd55832a99363ab7f9fab954fcacdac3ae ]
Fully compatible with mcp2515, the mcp25625 have integrated transceiver.
This patch add the mcp25625 to the device tree bindings documentation.
Signed-off-by: Sean Nyekjaer <sean@geanix.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 5f3e2bf008c2221478101ee72f5cb4654b9fc363 upstream.
Some TCP peers announce a very small MSS option in their SYN and/or
SYN/ACK messages.
This forces the stack to send packets with a very high network/cpu
overhead.
Linux has enforced a minimal value of 48. Since this value includes
the size of TCP options, and that the options can consume up to 40
bytes, this means that each segment can include only 8 bytes of payload.
In some cases, it can be useful to increase the minimal value
to a saner value.
We still let the default to 48 (TCP_MIN_SND_MSS), for compatibility
reasons.
Note that TCP_MAXSEG socket option enforces a minimal value
of (TCP_MIN_MSS). David Miller increased this minimal value
in commit c39508d6f118 ("tcp: Make TCP_MAXSEG minimum more correct.")
from 64 to 88.
We might in the future merge TCP_MIN_SND_MSS and TCP_MIN_MSS.
CVE-2019-11479 -- tcp mss hardcoded to 48
Suggested-by: Jonathan Looney <jtl@netflix.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Bruce Curtis <brucec@netflix.com>
Cc: Jonathan Lemon <jonathan.lemon@gmail.com>
commit 9d8d0294e78a164d407133dea05caf4b84247d6a upstream.
On x86_64, all returns to usermode go through
prepare_exit_to_usermode(), with the sole exception of do_nmi().
This even includes machine checks -- this was added several years
ago to support MCE recovery. Update the documentation.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Borislav Petkov <bp@suse.de>
Cc: Frederic Weisbecker <frederic@kernel.org>
Cc: Jon Masters <jcm@redhat.com>
Cc: stable@vger.kernel.org
Fixes: 04dcbdb80578 ("x86/speculation/mds: Clear CPU buffers on exit to user")
Link: http://lkml.kernel.org/r/999fa9e126ba6a48e9d214d2f18dbde5c62ac55c.1557865329.git.luto@kernel.org
commit 88640e1dcd089879530a49a8d212d1814678dfe7 upstream.
The double fault ESPFIX path doesn't return to user mode at all --
it returns back to the kernel by simulating a #GP fault.
prepare_exit_to_usermode() will run on the way out of
general_protection before running user code.
Link: http://lkml.kernel.org/r/ac97612445c0a44ee10374f6ea79c222fe22a5c4.1557865329.git.luto@kernel.org
commit 95310e348a321b45fb746c176961d4da72344282 upstream.
Fix a minor typo in the MDS documentation: "eanbled" -> "enabled".
Reported-by: Jeff Bastian <jbastian@redhat.com>
commit ea01668f9f43021b28b3f4d5ffad50106a1e1301 upstream.
Adjust the last two rows in the table that display possible values when
MDS mitigation is enabled. They both were slightly innacurate.
In addition, convert the table of possible values and their descriptions
to a list-table. The simple table format uses the top border of equals
signs to determine cell width which resulted in the first column being
far too wide in comparison to the second column that contained the
majority of the text.
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
commit e672f8bf71c66253197e503f75c771dd28ada4a0 upstream.
Updated the documentation for a new CVE-2019-11091 Microarchitectural Data
Sampling Uncacheable Memory (MDSUM) which is a variant of
Microarchitectural Data Sampling (MDS). MDS is a family of side channel
attacks on internal buffers in Intel CPUs.
MDSUM is a special case of MSBDS, MFBDS and MLPDS. An uncacheable load from
memory that takes a fault or assist can leave data in a microarchitectural
structure that may later be observed using one of the same methods used by
MSBDS, MFBDS or MLPDS. There are no new code changes expected for MDSUM.
The existing mitigation for MDS applies to MDSUM as well.
Reviewed-by: Tyler Hicks <tyhicks@canonical.com>
Reviewed-by: Jon Masters <jcm@redhat.com>
commit 5c14068f87d04adc73ba3f41c2a303d3c3d1fa12 upstream.
Add MDS to the new 'mitigations=' cmdline option.
- Drop the auto,nosmt option, which we can't support
commit d68be4c4d31295ff6ae34a8ddfaa4c1a8ff42812 upstream.
Configure x86 runtime CPU speculation bug mitigations in accordance with
the 'mitigations=' cmdline option. This affects Meltdown, Spectre v2,
Speculative Store Bypass, and L1TF.
The default behavior is unchanged.
Tested-by: Jiri Kosina <jkosina@suse.cz> (on x86)
Reviewed-by: Jiri Kosina <jkosina@suse.cz>
Cc: "H . Peter Anvin" <hpa@zytor.com>
Cc: Jiri Kosina <jikos@kernel.org>
Cc: Waiman Long <longman@redhat.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: linuxppc-dev@lists.ozlabs.org
Cc: linux-s390@vger.kernel.org
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Steven Price <steven.price@arm.com>
Cc: Phil Auld <pauld@redhat.com>
Link: https://lkml.kernel.org/r/6616d0ae169308516cfdf5216bedd169f8a8291b.1555085500.git.jpoimboe@redhat.com
- Drop the auto,nosmt option and the l1tf mitigation selection, which we can't
support
commit 98af8452945c55652de68536afdde3b520fec429 upstream.
Keeping track of the number of mitigations for all the CPU speculation
bugs has become overwhelming for many users. It's getting more and more
complicated to decide which mitigations are needed for a given
architecture. Complicating matters is the fact that each arch tends to
have its own custom way to mitigate the same vulnerability.
Most users fall into a few basic categories:
a) they want all mitigations off;
b) they want all reasonable mitigations on, with SMT enabled even if
it's vulnerable; or
c) they want all reasonable mitigations on, with SMT disabled if
vulnerable.
Define a set of curated, arch-independent options, each of which is an
aggregation of existing options:
- mitigations=off: Disable all mitigations.
- mitigations=auto: [default] Enable all the default mitigations, but
leave SMT enabled, even if it's vulnerable.
- mitigations=auto,nosmt: Enable all the default mitigations, disabling
SMT if needed by a mitigation.
Currently, these options are placeholders which don't actually do
anything. They will be fleshed out in upcoming patches.
Link: https://lkml.kernel.org/r/b07a8ef9b7c5055c3a4637c87d07c296d5016fe0.1555085500.git.jpoimboe@redhat.com
- Drop the auto,nosmt option which we can't support
- Adjust filename]
commit 5999bbe7a6ea3c62029532ec84dc06003a1fa258 upstream.
Add the initial MDS vulnerability documentation.
- Drop the index updates
- Adjust filename]
commit 22dd8365088b6403630b82423cf906491859b65e upstream.
In virtualized environments it can happen that the host has the microcode
update which utilizes the VERW instruction to clear CPU buffers, but the
hypervisor is not yet updated to expose the X86_FEATURE_MD_CLEAR CPUID bit
to guests.
Introduce an internal mitigation mode VMWERV which enables the invocation
of the CPU buffer clearing even if X86_FEATURE_MD_CLEAR is not set. If the
system has no updated microcode this results in a pointless execution of
the VERW instruction wasting a few CPU cycles. If the microcode is updated,
but not exposed to a guest then the CPU buffers will be cleared.
That said: Virtual Machines Will Eventually Receive Vaccine
Reviewed-by: Borislav Petkov <bp@suse.de>
Tested-by: Jon Masters <jcm@redhat.com>
commit 8a4b06d391b0a42a373808979b5028f5c84d9c6a upstream.
Add the sysfs reporting file for MDS. It exposes the vulnerability and
mitigation state similar to the existing files for the other speculative
hardware vulnerabilities.
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
- Test x86_hyper instead of using hypervisor_is_type()
- Adjust context]
The vulnerabilties/l1tf attribute was added by commit 17dbca119312
"x86/speculation/l1tf: Add sysfs reporting for l1tf", which has
already been backported to 3.16, but only documented in commit
d90a7a0ec83f "x86/bugs, kvm: Introduce boot-time control of L1TF
mitigations", which has not and probbaly won't be.
Add just that line of documentation for now.
commit bc1241700acd82ec69fde98c5763ce51086269f8 upstream.
Now that the mitigations are in place, add a command line parameter to
control the mitigation, a mitigation selector function and a SMT update
mechanism.
This is the minimal straight forward initial implementation which just
provides an always on/off mode. The command line parameter is:
mds=[full|off]
This is consistent with the existing mitigations for other speculative
The idle invocation is dynamically updated according to the SMT state of
the system similar to the dynamic update of the STIBP mitigation. The idle
mitigation is limited to CPUs which are only affected by MSBDS and not any
other variant, because the other variants cannot be mitigated on SMT
enabled systems.
- Drop " __ro_after_init"
commit 07f07f55a29cb705e221eda7894dd67ab81ef343 upstream.
Add a static key which controls the invocation of the CPU buffer clear
mechanism on idle entry. This is independent of other MDS mitigations
because the idle entry invocation to mitigate the potential leakage due to
store buffer repartitioning is only necessary on SMT systems.
Add the actual invocations to the different halt/mwait variants which
covers all usage sites. mwaitx is not patched as it's not available on
Intel CPUs.
The buffer clear is only invoked before entering the C-State to prevent
that stale data from the idling CPU is spilled to the Hyper-Thread sibling
after the Store buffer got repartitioned and all entries are available to
the non idle sibling.
When coming out of idle the store buffer is partitioned again so each
sibling has half of it available. Now CPU which returned from idle could be
speculatively exposed to contents of the sibling, but the buffers are
flushed either on exit to user space or on VMENTER.
When later on conditional buffer clearing is implemented on top of this,
then there is no action required either because before returning to user
space the context switch will set the condition flag which causes a flush
on the return to user path.
Note, that the buffer clearing on idle is only sensible on CPUs which are
solely affected by MSBDS and not any other variant of MDS because the other
MDS variants cannot be mitigated when SMT is enabled, so the buffer
clearing on idle would be a window dressing exercise.
This intentionally does not handle the case in the acpi/processor_idle
driver which uses the legacy IO port interface for C-State transitions for
two reasons:
- The acpi/processor_idle driver was replaced by the intel_idle driver
almost a decade ago. Anything Nehalem upwards supports it and defaults
to that new driver.
- The legacy IO port interface is likely to be used on older and therefore
unaffected CPUs or on systems which do not receive microcode updates
anymore, so there is no point in adding that.
Reviewed-by: Frederic Weisbecker <frederic@kernel.org>
[bwh: Backported to 4.4: adjust context]
commit 04dcbdb8057827b043b3c71aa397c4c63e67d086 upstream.
mechanism on exit to user space and add the call into
prepare_exit_to_usermode() and do_nmi() right before actually returning.
Add documentation which kernel to user space transition this covers and
explain why some corner cases are not mitigated.
commit 6a9e529272517755904b7afa639f6db59ddb793e upstream.
The Microarchitectural Data Sampling (MDS) vulernabilities are mitigated by
clearing the affected CPU buffers. The mechanism for clearing the buffers
uses the unused and obsolete VERW instruction in combination with a
microcode update which triggers a CPU buffer clear when VERW is executed.
Provide a inline function with the assembly magic. The argument of the VERW
instruction must be a memory operand as documented:
"MD_CLEAR enumerates that the memory-operand variant of VERW (for
example, VERW m16) has been extended to also overwrite buffers affected
by MDS. This buffer overwriting functionality is not guaranteed for the
register operand variant of VERW."
Documentation also recommends to use a writable data segment selector:
"The buffer overwriting occurs regardless of the result of the VERW
permission check, as well as when the selector is null or causes a
descriptor load segment violation. However, for lowest latency we
recommend using a selector that indicates a valid writable data
segment."
Add x86 specific documentation about MDS and the internal workings of the
mitigation.
[bwh: Backported to 4.4: drop changes to doc index and configuration]
commit 55a974021ec952ee460dc31ca08722158639de72 upstream.
Provide the possibility to enable IBPB always in combination with 'prctl'
and 'seccomp'.
Add the extra command line options and rework the IBPB selection to
evaluate the command instead of the mode selected by the STIPB switch case.
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
Cc: David Woodhouse <dwmw@amazon.co.uk>
Cc: Casey Schaufler <casey.schaufler@intel.com>
Cc: Asit Mallick <asit.k.mallick@intel.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Waiman Long <longman9394@gmail.com>
Cc: Greg KH <gregkh@linuxfoundation.org>
Cc: Dave Stewart <david.c.stewart@intel.com>
Link: https://lkml.kernel.org/r/20181125185006.144047038@linutronix.de
commit 6b3e64c237c072797a9ec918654a60e3a46488e2 upstream.
If 'prctl' mode of user space protection from spectre v2 is selected
on the kernel command-line, STIBP and IBPB are applied on tasks which
restrict their indirect branch speculation via prctl.
SECCOMP enables the SSBD mitigation for sandboxed tasks already, so it
makes sense to prevent spectre v2 user space to user space attacks as
well.
The Intel mitigation guide documents how STIPB works:
Setting bit 1 (STIBP) of the IA32_SPEC_CTRL MSR on a logical processor
prevents the predicted targets of indirect branches on any logical
processor of that core from being controlled by software that executes
(or executed previously) on another logical processor of the same core.
Ergo setting STIBP protects the task itself from being attacked from a task
running on a different hyper-thread and protects the tasks running on
different hyper-threads from being attacked.
While the document suggests that the branch predictors are shielded between
the logical processors, the observed performance regressions suggest that
STIBP simply disables the branch predictor more or less completely. Of
course the document wording is vague, but the fact that there is also no
requirement for issuing IBPB when STIBP is used points clearly in that
direction. The kernel still issues IBPB even when STIBP is used until Intel
clarifies the whole mechanism.
IBPB is issued when the task switches out, so malicious sandbox code cannot
mistrain the branch predictor for the next user space task on the same
logical processor.
Link: https://lkml.kernel.org/r/20181125185006.051663132@linutronix.de
commit 7cc765a67d8e04ef7d772425ca5a2a1e2b894c15 upstream.
Now that all prerequisites are in place:
- Add the prctl command line option
- Default the 'auto' mode to 'prctl'
- When SMT state changes, update the static key which controls the
conditional STIBP evaluation on context switch.
- At init update the static key which controls the conditional IBPB
Link: https://lkml.kernel.org/r/20181125185005.958421388@linutronix.de
commit 9137bb27e60e554dab694eafa4cca241fa3a694f upstream.
Add the PR_SPEC_INDIRECT_BRANCH option for the PR_GET_SPECULATION_CTRL and
PR_SET_SPECULATION_CTRL prctls to allow fine grained per task control of
indirect branch speculation via STIBP and IBPB.
Invocations:
Check indirect branch speculation status with
- prctl(PR_GET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, 0, 0, 0);
Enable indirect branch speculation with
- prctl(PR_SET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, PR_SPEC_ENABLE, 0, 0);
Disable indirect branch speculation with
- prctl(PR_SET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, PR_SPEC_DISABLE, 0, 0);
Force disable indirect branch speculation with
- prctl(PR_SET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, PR_SPEC_FORCE_DISABLE, 0, 0);
See Documentation/userspace-api/spec_ctrl.rst.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Link: https://lkml.kernel.org/r/20181125185005.866780996@linutronix.de
- Renumber the PFA flags
- Drop changes in tools/include/uapi/linux/prctl.h
- Adjust filename]
commit fa1202ef224391b6f5b26cdd44cc50495e8fab54 upstream.
Add command line control for user space indirect branch speculation
mitigations. The new option is: spectre_v2_user=
The initial options are:
- on: Unconditionally enabled
- off: Unconditionally disabled
-auto: Kernel selects mitigation (default off for now)
When the spectre_v2= command line argument is either 'on' or 'off' this
implies that the application to application control follows that state even
if a contradicting spectre_v2_user= argument is supplied.
Originally-by: Tim Chen <tim.c.chen@linux.intel.com>
Link: https://lkml.kernel.org/r/20181125185005.082720373@linutronix.de
- Don't use __ro_after_init or cpu_smt_control
- Adjust filename]
commit c2b71462d294cf517a0bc6e4fd6424d7cee5596f upstream.
The syzkaller fuzzer reported a bug in the USB hub driver which turned
out to be caused by a negative runtime-PM usage counter. This allowed
a hub to be runtime suspended at a time when the driver did not expect
it. The symptom is a WARNING issued because the hub's status URB is
submitted while it is already active:
URB 0000000031fb463e submitted while active
WARNING: CPU: 0 PID: 2917 at drivers/usb/core/urb.c:363
The negative runtime-PM usage count was caused by an unfortunate
design decision made when runtime PM was first implemented for USB.
At that time, USB class drivers were allowed to unbind from their
interfaces without balancing the usage counter (i.e., leaving it with
a positive count). The core code would take care of setting the
counter back to 0 before allowing another driver to bind to the
interface.
Later on when runtime PM was implemented for the entire kernel, the
opposite decision was made: Drivers were required to balance their
runtime-PM get and put calls. In order to maintain backward
compatibility, however, the USB subsystem adapted to the new
implementation by keeping an independent usage counter for each
interface and using it to automatically adjust the normal usage
counter back to 0 whenever a driver was unbound.
This approach involves duplicating information, but what is worse, it
doesn't work properly in cases where a USB class driver delays
decrementing the usage counter until after the driver's disconnect()
routine has returned and the counter has been adjusted back to 0.
Doing so would cause the usage counter to become negative. There's
even a warning about this in the USB power management documentation!
As it happens, this is exactly what the hub driver does. The
kick_hub_wq() routine increments the runtime-PM usage counter, and the
corresponding decrement is carried out by hub_event() in the context
of the hub_wq work-queue thread. This work routine may sometimes run
after the driver has been unbound from its interface, and when it does
it causes the usage counter to go negative.
It is not possible for hub_disconnect() to wait for a pending
hub_event() call to finish, because hub_disconnect() is called with
the device lock held and hub_event() acquires that lock. The only
feasible fix is to reverse the original design decision: remove the
duplicate interface-specific usage counter and require USB drivers to
balance their runtime PM gets and puts. As far as I know, all
existing drivers currently do this.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-and-tested-by: syzbot+7634edaea4d0b341c625@syzkaller.appspotmail.com
CC: <stable@vger.kernel.org>
commit 26cb1f36c43ee6e89d2a9f48a5a7500d5248f836 upstream.
Currently only supported on powerpc.
Signed-off-by: Diana Craciun <diana.craciun@nxp.com>
commit e59f5bd759b7dee57593c5b6c0441609bda5d530 upstream.
[ Upstream commit 19fad20d15a6494f47f85d869f00b11343ee5c78 ]
There is a UBSAN report as below:
UBSAN: Undefined behaviour in net/ipv4/tcp_input.c:2877:56
signed integer overflow:
2147483647 * 1000 cannot be represented in type 'int'
CPU: 3 PID: 0 Comm: swapper/3 Not tainted 5.1.0-rc4-00058-g582549e #1
Call Trace:
<IRQ>
dump_stack+0x8c/0xba
ubsan_epilogue+0x11/0x60
handle_overflow+0x12d/0x170
? ttwu_do_wakeup+0x21/0x320
__ubsan_handle_mul_overflow+0x12/0x20
tcp_ack_update_rtt+0x76c/0x780
tcp_clean_rtx_queue+0x499/0x14d0
tcp_ack+0x69e/0x1240
? __wake_up_sync_key+0x2c/0x50
? update_group_capacity+0x50/0x680
tcp_rcv_established+0x4e2/0xe10
tcp_v4_do_rcv+0x22b/0x420
tcp_v4_rcv+0xfe8/0x1190
ip_protocol_deliver_rcu+0x36/0x180
ip_local_deliver+0x15b/0x1a0
ip_rcv+0xac/0xd0
__netif_receive_skb_one_core+0x7f/0xb0
__netif_receive_skb+0x33/0xc0
netif_receive_skb_internal+0x84/0x1c0
napi_gro_receive+0x2a0/0x300
receive_buf+0x3d4/0x2350
? detach_buf_split+0x159/0x390
virtnet_poll+0x198/0x840
? reweight_entity+0x243/0x4b0
net_rx_action+0x25c/0x770
__do_softirq+0x19b/0x66d
irq_exit+0x1eb/0x230
do_IRQ+0x7a/0x150
common_interrupt+0xf/0xf
</IRQ>
It can be reproduced by:
echo 2147483647 > /proc/sys/net/ipv4/tcp_min_rtt_wlen
Fixes: f672258391b42 ("tcp: track min RTT using windowed min-filter")
Signed-off-by: ZhangXiaoxu <zhangxiaoxu5@huawei.com>
[ Upstream commit de9c0d49d85dc563549972edc5589d195cd5e859 ]
While building arm32 allyesconfig, I ran into the following errors:
arch/arm/lib/xor-neon.c:17:2: error: You should compile this file with
'-mfloat-abi=softfp -mfpu=neon'
In file included from lib/raid6/neon1.c:27:
/home/nathan/cbl/prebuilt/lib/clang/8.0.0/include/arm_neon.h:28:2:
error: "NEON support not enabled"
Building V=1 showed NEON_FLAGS getting passed along to Clang but
__ARM_NEON__ was not getting defined. Ultimately, it boils down to Clang
only defining __ARM_NEON__ when targeting armv7, rather than armv6k,
which is the '-march' value for allyesconfig.
>From lib/Basic/Targets/ARM.cpp in the Clang source:
// This only gets set when Neon instructions are actually available, unlike
// the VFP define, hence the soft float and arch check. This is subtly
// different from gcc, we follow the intent which was that it should be set
// when Neon instructions are actually available.
if ((FPU & NeonFPU) && !SoftFloat && ArchVersion >= 7) {
Builder.defineMacro("__ARM_NEON", "1");
Builder.defineMacro("__ARM_NEON__");
// current AArch32 NEON implementations do not support double-precision
// floating-point even when it is present in VFP.
Builder.defineMacro("__ARM_NEON_FP",
"0x" + Twine::utohexstr(HW_FP & ~HW_FP_DP));
Ard Biesheuvel recommended explicitly adding '-march=armv7-a' at the
beginning of the NEON_FLAGS definitions so that __ARM_NEON__ always gets
definined by Clang. This doesn't functionally change anything because
that code will only run where NEON is supported, which is implicitly
armv7.
Link: https://github.com/ClangBuiltLinux/linux/issues/287
Suggested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Reviewed-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
commit ddba91801aeb5c160b660caed1800eb3aef403f8 upstream.
KVM's API requires thats ioctls must be issued from the same process
that created the VM. In other words, userspace can play games with a
VM's file descriptors, e.g. fork(), SCM_RIGHTS, etc..., but only the
creator can do anything useful. Explicitly reject device ioctls that
are issued by a process other than the VM's creator, and update KVM's
API documentation to extend its requirements to device ioctls.
Fixes: 852b6d57dc7f ("kvm: add device control API")
Signed-off-by: Sean Christopherson <sean.j.christopherson@intel.com>
This is the 4.4.177 stable release
It seemed odd to say "since 4.17" in a 4.4 kernel. Consider
rewording the reference to indicate where in the stable series
it was introduced as well as where it originated.
Signed-off-by: Mark Rustad <mrustad@gmail.com>
