path: root/Documentation
2017-06-17Merge remote-tracking branch 'fslc/4.1-2.0.x-imx' into ↵Marcel Ziswiler
toradex_4.1-2.0.x-imx-next Conflicts: arch/arm/boot/dts/imx7d.dtsi arch/arm/mach-imx/busfreq-imx.c arch/arm/mach-imx/imx_rpmsg.c drivers/mmc/host/sdhci-esdhc-imx.c Parts moved to: arch/arm/boot/dts/imx7s.dtsi Note: This also includes NXP's latest rel_imx_4.1.15_2.1.0_ga.
2017-06-17Merge tag 'v4.1.41' into 4.1-2.0.x-imxOtavio Salvador
Linux 4.1.41 * tag 'v4.1.41': (473 commits) Linux 4.1.41 mm/huge_memory.c: respect FOLL_FORCE/FOLL_COW for thp xc2028: Fix use-after-free bug properly iio: proximity: as3935: fix as3935_write ipx: call ipxitf_put() in ioctl error path sched/fair: Initialize throttle_count for new task-groups lazily sched/fair: Do not announce throttled next buddy in dequeue_task_fair() iio: dac: ad7303: fix channel description mwifiex: pcie: fix cmd_buf use-after-free in remove/reset rtlwifi: rtl8821ae: setup 8812ae RFE according to device type ARM: tegra: paz00: Mark panel regulator as enabled on boot fs/xattr.c: zero out memory copied to userspace in getxattr vfio/type1: Remove locked page accounting workqueue crypto: algif_aead - Require setkey before accept(2) staging: gdm724x: gdm_mux: fix use-after-free on module unload drm/ttm: fix use-after-free races in vm fault handling f2fs: sanity check segment count ipv6: reorder ip6_route_dev_notifier after ipv6_dev_notf ipv6: initialize route null entry in addrconf_init() rtnetlink: NUL-terminate IFLA_PHYS_PORT_NAME string ... Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2017-06-17Merge remote-tracking branch 'imx/imx_4.1.15_2.0.0_ga' into 4.1-2.0.x-imxOtavio Salvador
* imx/imx_4.1.15_2.0.0_ga: (157 commits) MLK-14762 ARM: dts: imx6sll-evk: correct gpio pin for lcd power control MLK-14285-3 usb: phy: mxs: optimize disconnect line condition MLK-14285-2 usb: chipidea: set mode for usb phy driver MLK-14285-1 usb: phy: add usb mode for usb_phy MLK-14747 driver: cpufreq: Correct dc regulator voltage on imx6ull MLK-14720 epdc: correct WFE setting when bypass legacy process MLK-13801-02 ARM: dts: Correct the gpt timer clock source on imx6ul/ull/sll MLK-13801-01 ARM: imx: add gpt_3m clock on imx6sll MLK-14680 pxp/epdc: add LUT cancellation feature MLK-14518-2 pxp: set data path for pxp after reset MLK-14518-1 pxp: initialize pxp according to recommended flow MLK-14516 epdc: bypass pxp legacy process when there's no transformation MLK-14369 epdc: sync LUT status to PXP before enable collision detection MLK-13198 pxp: imx7d: fix error histogram status report issue MLK-13917 pxp: fix build error for pxp library in user space MLK-13862-2 epdc/pxp: imx6ull/imx6sll: enhance the LUT cleanup flow to avoid stalling display MLK-13862-1 epdc/pxp: imx7d: enhance the LUT cleanup flow to avoid stalling display MLK-14697 ARM: dts: imx: update the setpoint data of imx6sll MXSCM-266 arm: dts: increase lpddr2 voltage to 1.25V MXSCM-265: dts: place imx6sxscm dtb files under CONFIG_SOC_IMX6SX ...
2017-05-30ASoC: sgtl5000: Allow LRCLK pad drive strength to be changedFabio Estevam
Introduce the "lrclk-strength" property to allow LRCLK pad drive strength to be changed via device tree. When running a stress playback loop test on a mx6dl wandboard channel swap can be noticed on about 10% of the times. While debugging this issue I noticed that when probing the SGTL5000 LRCLK pin with the scope the swap did not happen. After removing the probe the swap started to happen again. After changing the LRCLK pad drive strength to the maximum value the issue is gone. Same fix works on a mx6dl Colibri board as well. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Tested-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Mark Brown <broonie@kernel.org> (cherry picked from commit 570c70a60f53ca737ead4e5966c446bf0d39fac9) Conflicts: Documentation/devicetree/bindings/sound/sgtl5000.txt
2017-05-30Revert "ASoC: sgtl5000: Allow LRCLK pad drive strength to be changed"Max Krummenacher
This reverts commit 56b32850e08f94d5a5db28454ffce7aeb4ca6be9. revert this to get be able to cherry-pick the mainlined patch Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-05-28arm64: documentation: document tagged pointer stack constraintsKristina Martsenko
[ Upstream commit f0e421b1bf7af97f026e1bb8bfe4c5a7a8c08f42 ] Some kernel features don't currently work if a task puts a non-zero address tag in its stack pointer, frame pointer, or frame record entries (FP, LR). For example, with a tagged stack pointer, the kernel can't deliver signals to the process, and the task is killed instead. As another example, with a tagged frame pointer or frame records, perf fails to generate call graphs or resolve symbols. For now, just document these limitations, instead of finding and fixing everything that doesn't work, as it's not known if anyone needs to use tags in these places anyway. In addition, as requested by Dave Martin, generalize the limitations into a general kernel address tag policy, and refactor tagged-pointers.txt to include it. Fixes: d50240a5f6ce ("arm64: mm: permit use of tagged pointers at EL0") Cc: <stable@vger.kernel.org> # 3.12.x- Reviewed-by: Dave Martin <Dave.Martin@arm.com> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Kristina Martsenko <kristina.martsenko@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-05-17x86/platform/goldfish: Prevent unconditional loadingThomas Gleixner
[ Upstream commit 47512cfd0d7a8bd6ab71d01cd89fca19eb2093eb ] The goldfish platform code registers the platform device unconditionally which causes havoc in several ways if the goldfish_pdev_bus driver is enabled: - Access to the hardcoded physical memory region, which is either not available or contains stuff which is completely unrelated. - Prevents that the interrupt of the serial port can be requested - In case of a spurious interrupt it goes into a infinite loop in the interrupt handler of the pdev_bus driver (which needs to be fixed seperately). Add a 'goldfish' command line option to make the registration opt-in when the platform is compiled in. I'm seriously grumpy about this engineering trainwreck, which has seven SOBs from Intel developers for 50 lines of code. And none of them figured out that this is broken. Impressive fail! Fixes: ddd70cf93d78 ("goldfish: platform device for x86") Reported-by: Gabriel C <nix.or.die@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable@vger.kernel.org Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-04-05ASoC: sgtl5000: Allow LRCLK pad drive strength to be changedFabio Estevam
Introduce the "lrclk-strength" property to allow LRCLK pad drive strength to be changed via device tree. When running a stress playback loop test on a mx6dl wandboard channel swap can be noticed on about 10% of the times. While debugging this issue I noticed that when probing the SGTL5000 LRCLK pin with the scope the swap did not happen. After removing the probe the swap started to happen again. After changing the LRCLK pad drive strength to the maximum value the issue is gone. Same fix works on a mx6dl Colibri board as well. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Backport from http://mailman.alsa-project.org/pipermail/alsa-devel/2017-April/119525.html Conflicts: Documentation/devicetree/bindings/sound/sgtl5000.txt sound/soc/codecs/sgtl5000.c Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-03-24Merge remote-tracking branch 'fslc/4.1-2.0.x-imx' into toradex_4.1-2.0.x-imxMax Krummenacher
2017-01-23Merge tag 'v4.1.38' into 4.1-2.0.x-imxOtavio Salvador
Linux 4.1.38 * tag 'v4.1.38': (109 commits) Linux 4.1.38 gro: Allow tunnel stacking in the case of FOU/GUE tunnels: Don't apply GRO to multiple layers of encapsulation. net: ipv4: Convert IP network timestamps to be y2038 safe ipip: Properly mark ipip GRO packets as encapsulated. sg_write()/bsg_write() is not fit to be called under KERNEL_DS fs: exec: apply CLOEXEC before changing dumpable task flags IB/cma: Fix a race condition in iboe_addr_get_sgid() Revert "ALSA: usb-audio: Fix race at stopping the stream" kvm: nVMX: Allow L1 to intercept software exceptions (#BP and #OF) drivers/gpu/drm/ast: Fix infinite loop if read fails target/user: Fix use-after-free of tcmu_cmds if they are expired kernel/debug/debug_core.c: more properly delay for secondary CPUs scsi: avoid a permanent stop of the scsi device's request queue IB/multicast: Check ib_find_pkey() return value IPoIB: Avoid reading an uninitialized member variable block_dev: don't test bdev->bd_contains when it is not stable btrfs: limit async_work allocation and worker func duration mm/vmscan.c: set correct defer count for shrinker Input: drv260x - fix input device's parent assignment ...
2017-01-12KVM: PPC: Book3S HV: Save/restore XER in checkpointed register statePaul Mackerras
[ Upstream commit 0d808df06a44200f52262b6eb72bcb6042f5a7c5 ] When switching from/to a guest that has a transaction in progress, we need to save/restore the checkpointed register state. Although XER is part of the CPU state that gets checkpointed, the code that does this saving and restoring doesn't save/restore XER. This fixes it by saving and restoring the XER. To allow userspace to read/write the checkpointed XER value, we also add a new ONE_REG specifier. The visible effect of this bug is that the guest may see its XER value being corrupted when it uses transactions. Fixes: e4e38121507a ("KVM: PPC: Book3S HV: Add transactional memory support") Fixes: 0a8eccefcb34 ("KVM: PPC: Book3S HV: Add missing code for transaction reclaim on guest exit") Cc: stable@vger.kernel.org # v3.15+ Signed-off-by: Paul Mackerras <paulus@ozlabs.org> Reviewed-by: Thomas Huth <thuth@redhat.com> Signed-off-by: Paul Mackerras <paulus@ozlabs.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-01-10dtb, i2c-imx.txt: fix typosMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 602505a35f2bf10963bb1f97adeaeb66e610de24) (cherry picked from commit 51c231f901b541e95643259d2a36cb0bee54170d)
2017-01-10i2c-imx: add gpio recovery functionalityMax Krummenacher
If the I2C is disturbed by other signals sometimes the i2c-imx bus gets stuck with SDA being low. This adds a recovery function to the bus driver. When e.g. a device driver detects a stuck bus int i2c_recover_bus(struct i2c_adapter *adap) can be called to try to recover the bus. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 88731dc0e8b6ba244e097b412b302acf3b9cc889) (cherry picked from commit 478388b32ac83fc44a75d63ae819aadb220c83ec) Conflicts: arch/arm/boot/dts/imx6qdl-apalis.dtsi drivers/i2c/busses/i2c-imx.c
2017-01-10stmpe-adc: add device tree bindingsMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 16692ff50af0d7a216d71ff39b69d8971b08b690)
2017-01-10arm: dts: imx7: Add support for PWM polarity controlBhuvanchandra DV
Update #pwm-cells to 3 in order to support PWM signal polarity control. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com> (cherry picked from commit a97e7559fb82ddf9be12c5d31adbd35937f24ce7)
2017-01-10ENGR00305648-1 ASoC: imx-sgtl5000: Support non-ssi cpu-daiNicolin Chen
The current imx-sgtl5000 driver always attaches the cpu-dai to ssi while in fact it could be attached to other cpu-dais like SAI. Thus this patch use a general code to support another cpu-dai. And meanwhile update the devicetree for i.MX6 Series. Acked-by: Wang Shengjiu <b02247@freescale.com> Signed-off-by: Nicolin Chen <Guangyu.Chen@freescale.com> (cherry picked from commit f9302eb42ad8f597b46e681b5ad402af3fb7dd9d)
2017-01-10Input: ad7879 - add device tree supportStefan Agner
Add device tree support for the I2C and SPI variant of AD7879(-1). This allows to specify the touchscreen controller as a I2C client node or SPI slave device. Most of the options available in platform data are also available as device tree properties, the only exception being GPIO capabilities, which can not be activated through device tree currently. Signed-off-by: Stefan Agner <stefan@agner.ch> Acked-by: Rob Herring <robh@kernel.org> Acked-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> [revert back to touchscreen_parse_of_params] (cherry picked from commit fa6e3ca274429b66e12d06abc5a6c013cef66471) (cherry picked from commit 7d717b69cc43ee4ba307f9ccaf2f41039f724af1)
2016-12-23mnt: Add a per mount namespace limit on the number of mountsEric W. Biederman
[ Upstream commit d29216842a85c7970c536108e093963f02714498 ] CAI Qian <caiqian@redhat.com> pointed out that the semantics of shared subtrees make it possible to create an exponentially increasing number of mounts in a mount namespace. mkdir /tmp/1 /tmp/2 mount --make-rshared / for i in $(seq 1 20) ; do mount --bind /tmp/1 /tmp/2 ; done Will create create 2^20 or 1048576 mounts, which is a practical problem as some people have managed to hit this by accident. As such CVE-2016-6213 was assigned. Ian Kent <raven@themaw.net> described the situation for autofs users as follows: > The number of mounts for direct mount maps is usually not very large because of > the way they are implemented, large direct mount maps can have performance > problems. There can be anywhere from a few (likely case a few hundred) to less > than 10000, plus mounts that have been triggered and not yet expired. > > Indirect mounts have one autofs mount at the root plus the number of mounts that > have been triggered and not yet expired. > > The number of autofs indirect map entries can range from a few to the common > case of several thousand and in rare cases up to between 30000 and 50000. I've > not heard of people with maps larger than 50000 entries. > > The larger the number of map entries the greater the possibility for a large > number of active mounts so it's not hard to expect cases of a 1000 or somewhat > more active mounts. So I am setting the default number of mounts allowed per mount namespace at 100,000. This is more than enough for any use case I know of, but small enough to quickly stop an exponential increase in mounts. Which should be perfect to catch misconfigurations and malfunctioning programs. For anyone who needs a higher limit this can be changed by writing to the new /proc/sys/fs/mount-max sysctl. Tested-by: CAI Qian <caiqian@redhat.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Conflicts: fs/namespace.c kernel/sysctl.c Signed-off-by: Philipp Hahn <hahn@univention.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-12-23fs: Give dentry to inode_change_ok() instead of inodeJan Kara
[ Upstream commit 31051c85b5e2aaaf6315f74c72a732673632a905 ] inode_change_ok() will be resposible for clearing capabilities and IMA extended attributes and as such will need dentry. Give it as an argument to inode_change_ok() instead of an inode. Also rename inode_change_ok() to setattr_prepare() to better relect that it does also some modifications in addition to checks. References: CVE-2015-1350 Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Philipp Hahn <hahn@univention.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-12-21bus: arm-ccn: Provide required event argumentsPawel Moll
[ Upstream commit 8f06c51fac1ca4104b8b64872f310e28186aea42 ] Since 688d4dfcdd624192cbf03c08402e444d1d11f294 "perf tools: Support parsing parameterized events" the perf userspace tools understands "argument=?" syntax in the events file, making sure that required arguments are provided by the user and not defaulting to 0, causing confusion. This patch adds the required arguments lists for CCN events. Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-12-17Merge tag 'v4.1.36' into 4.1-2.0.x-imxOtavio Salvador
Linux 4.1.36 * tag 'v4.1.36': (72 commits) Linux 4.1.36 kbuild: add -fno-PIE firewire: net: fix fragmented datagram_size off-by-one firewire: net: guard against rx buffer overflows parisc: Ensure consistent state when switching to kernel stack at syscall entry ovl: fsync after copy-up virtio: console: Unlock vqs while freeing buffers md: be careful not lot leak internal curr_resync value into metadata. -- (all) md: sync sync_completed has correct value as recovery finishes. scsi: arcmsr: Send SYNCHRONIZE_CACHE command to firmware scsi: scsi_debug: Fix memory leak if LBP enabled and module is unloaded drm/radeon/si_dpm: workaround for SI kickers drm/dp/mst: Check peer device type before attempting EDID read drm/dp/mst: add some defines for logical/physical ports drm/dp/mst: Clear port->pdt when tearing down the i2c adapter KVM: MIPS: Precalculate MMIO load resume PC KVM: MIPS: Make ERET handle ERL before EXL drm/radeon: drop register readback in cayman_cp_int_cntl_setup scsi: megaraid_sas: Fix data integrity failure for JBOD (passthrough) devices Revert "drm/radeon: fix DP link training issue with second 4K monitor" ...
2016-11-01MLK-13244 input: touchscreen: add support for vtl touchscreenAlejandro Lozano
Add the support for a CT36X based touchscreens using the CT36X controller and i2c touchscreen interface. Signed-off-by: Alejandro Lozano <alejandro.lozano@nxp.com> Signed-off-by: Juan Gutierrez <juan.gutierrez@nxp.com> Signed-off-by: Alejandro Sierra <alejandro.sierra@nxp.com>
2016-10-30x86/mm: Expand the exception table logic to allow new handling optionsTony Luck
[ Upstream commit 548acf19234dbda5a52d5a8e7e205af46e9da840 ] Huge amounts of help from Andy Lutomirski and Borislav Petkov to produce this. Andy provided the inspiration to add classes to the exception table with a clever bit-squeezing trick, Boris pointed out how much cleaner it would all be if we just had a new field. Linus Torvalds blessed the expansion with: ' I'd rather not be clever in order to save just a tiny amount of space in the exception table, which isn't really criticial for anybody. ' The third field is another relative function pointer, this one to a handler that executes the actions. We start out with three handlers: 1: Legacy - just jumps the to fixup IP 2: Fault - provide the trap number in %ax to the fixup code 3: Cleaned up legacy for the uaccess error hack Signed-off-by: Tony Luck <tony.luck@intel.com> Reviewed-by: Borislav Petkov <bp@suse.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/f6af78fcbd348cf4939875cfda9c19689b5e50b8.1455732970.git.tony.luck@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-10-05Merge tag 'v4.1.33' into 4.1-2.0.x-imxOtavio Salvador
Linux 4.1.33 * tag 'v4.1.33': (1760 commits) Linux 4.1.33 Revert "ARC: mm: don't loose PTE_SPECIAL in pte_modify()" x86/AMD: Apply erratum 665 on machines without a BIOS fix x86/paravirt: Do not trace _paravirt_ident_*() functions ovl: listxattr: use strnlen() ovl: remove posix_acl_default from workdir serial: 8250: added acces i/o products quad and octal serial cards sysfs: correctly handle read offset on PREALLOC attrs sysfs: correctly handle short reads on PREALLOC attrs. kernfs: don't depend on d_find_any_alias() when generating notifications dm crypt: fix free of bad values after tfm allocation failure dm crypt: fix error with too large bios dm log writes: fix check of kthread_run() return value dm log writes: fix bug with too large bios dm log writes: move IO accounting earlier to fix error path NFSv4.x: Fix a refcount leak in nfs_callback_up_net xfs: prevent dropping ioend completions during buftarg wait xfs: fix superblock inprogress check USB: serial: option: add WeTelecom 0x6802 and 0x6803 products USB: avoid left shift by -1 ... Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2016-09-14MLK-13206 dcp: mx6sl: add missing components in dtsQuan Zhang
After MX6ULL DCP issue is fixed in commit 7a1cc1f, it introduces a new issue, MX6SL will meet issue as no dcp clock is defined when initializing: [ 3.061344] mxs-dcp 20fc000.dcp: can't identify DCP clk: -2 On mx6sl, dcp clock is always on, so the patch use dummy as dcp clock directly. Signed-off-by: Quan Zhang <spring.zhang@nxp.com> (cherry picked from commit 17717049a2a0a2248e30c421a0e0559a45ca59f3)
2016-09-12MLK-13186-2 arm: imx6qp: add imx6qp standalone pcie dtbRichard Zhu
In order to pass the pcie gen2 compliance tests on imx6qp sd revb board, add one standalone imx6qp sd ldo pcie dtb - disalbe fec/sata, because that the fec/sata can't work when pll6 is in bypass mode. NOTE: Bypass mode of pll6 is mandatory required when external oscillator is used as pcie ref clk. Signed-off-by: Richard Zhu <hongxing.zhu@nxp.com> (cherry picked from commit 35cd4bdd4d8451a62475ecb922803d656f144bcf)
2016-08-19iio: proximity: as3935: correct IIO_CHAN_INFO_RAW outputMatt Ranostay
[ Upstream commit 5138806f16c74c7cb8ac3e408a859c79eb7c9567 ] IIO_CHAN_INFO_RAW was returning processed data which was incorrect. This also adds the IIO_CHAN_INFO_SCALE value to convert to a processed value. Signed-off-by: Matt Ranostay <mranostay@gmail.com> Cc: <Stable@vger.kernel.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-08-19Documentation/module-signing.txt: Note need for version info if reusing a keyBen Hutchings
[ Upstream commit b8612e517c3c9809e1200b72c474dbfd969e5a83 ] Signing a module should only make it trusted by the specific kernel it was built for, not anything else. If a module signing key is used for multiple ABI-incompatible kernels, the modules need to include enough version information to distinguish them. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: stable@vger.kernel.org Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-07-10pipe: limit the per-user amount of pages allocated in pipesWilly Tarreau
[ Upstream commit 759c01142a5d0f364a462346168a56de28a80f52 ] On no-so-small systems, it is possible for a single process to cause an OOM condition by filling large pipes with data that are never read. A typical process filling 4000 pipes with 1 MB of data will use 4 GB of memory. On small systems it may be tricky to set the pipe max size to prevent this from happening. This patch makes it possible to enforce a per-user soft limit above which new pipes will be limited to a single page, effectively limiting them to 4 kB each, as well as a hard limit above which no new pipes may be created for this user. This has the effect of protecting the system against memory abuse without hurting other users, and still allowing pipes to work correctly though with less data at once. The limit are controlled by two new sysctls : pipe-user-pages-soft, and pipe-user-pages-hard. Both may be disabled by setting them to zero. The default soft limit allows the default number of FDs per process (1024) to create pipes of the default size (64kB), thus reaching a limit of 64MB before starting to create only smaller pipes. With 256 processes limited to 1024 FDs each, this results in 1024*64kB + (256*1024 - 1024) * 4kB = 1084 MB of memory allocated for a user. The hard limit is disabled by default to avoid breaking existing applications that make intensive use of pipes (eg: for splicing). Reported-by: socketpair@gmail.com Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Mitigates: CVE-2013-4312 (Linux 2.0+) Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-07-10scsi: fix race between simultaneous decrements of ->host_failedWei Fang
[ Upstream commit 72d8c36ec364c82bf1bf0c64dfa1041cfaf139f7 ] sas_ata_strategy_handler() adds the works of the ata error handler to system_unbound_wq. This workqueue asynchronously runs work items, so the ata error handler will be performed concurrently on different CPUs. In this case, ->host_failed will be decreased simultaneously in scsi_eh_finish_cmd() on different CPUs, and become abnormal. It will lead to permanently inequality between ->host_failed and ->host_busy, and scsi error handler thread won't start running. IO errors after that won't be handled. Since all scmds must have been handled in the strategy handler, just remove the decrement in scsi_eh_finish_cmd() and zero ->host_busy after the strategy handler to fix this race. Fixes: 50824d6c5657 ("[SCSI] libsas: async ata-eh") Cc: stable@vger.kernel.org Signed-off-by: Wei Fang <fangwei1@huawei.com> Reviewed-by: James Bottomley <jejb@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-06-03Fix OpenSSH pty regression on closeBrian Bloniarz
[ Upstream commit 0f40fbbcc34e093255a2b2d70b6b0fb48c3f39aa ] OpenSSH expects the (non-blocking) read() of pty master to return EAGAIN only if it has received all of the slave-side output after it has received SIGCHLD. This used to work on pre-3.12 kernels. This fix effectively forces non-blocking read() and poll() to block for parallel i/o to complete for all ttys. It also unwinds these changes: 1) f8747d4a466ab2cafe56112c51b3379f9fdb7a12 tty: Fix pty master read() after slave closes 2) 52bce7f8d4fc633c9a9d0646eef58ba6ae9a3b73 pty, n_tty: Simplify input processing on final close 3) 1a48632ffed61352a7810ce089dc5a8bcd505a60 pty: Fix input race when closing Inspired by analysis and patch from Marc Aurele La France <tsi@tuyoix.net> Reported-by: Volth <openssh@volth.com> Reported-by: Marc Aurele La France <tsi@tuyoix.net> BugLink: https://bugzilla.mindrot.org/show_bug.cgi?id=52 BugLink: https://bugzilla.mindrot.org/show_bug.cgi?id=2492 Signed-off-by: Brian Bloniarz <brian.bloniarz@gmail.com> Reviewed-by: Peter Hurley <peter@hurleysoftware.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-06-03crypto: s5p-sss - Remove useless hash interrupt handlerKrzysztof Kozlowski
[ Upstream commit 5512442553bbe8d4fcdba3e17b30f187706384a7 ] Beside regular feed control interrupt, the driver requires also hash interrupt for older SoCs (samsung,s5pv210-secss). However after requesting it, the interrupt handler isn't doing anything with it, not even clearing the hash interrupt bit. Driver does not provide hash functions so it is safe to remove the hash interrupt related code and to not require the interrupt in Device Tree. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-05-17ata: ahci-platform: Add ports-implemented DT bindings.Srinivas Kandagatla
[ Upstream commit 17dcc37e3e847bc0e67a5b1ec52471fcc6c18682 ] On some SOCs PORTS_IMPL register value is never programmed by the firmware and left at zero value. Which means that no sata ports are available for software. AHCI driver used to cope up with this by fabricating the port_map if the PORTS_IMPL register is read zero, but recent patch broke this workaround as zero value was valid for NVMe disks. This patch adds ports-implemented DT bindings as workaround for this issue in a way that DT can can override the PORTS_IMPL register in cases where the firmware did not program it already. Fixes: 566d1827df2e ("libata: disable forced PORTS_IMPL for >= AHCI 1.3") Cc: stable@vger.kernel.org # v4.5+ Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Acked-by: Tejun Heo <tj@kernel.org> Reviewed-by: Andy Gross <andy.gross@linaro.org> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-20USB: uas: Add a new NO_REPORT_LUNS quirkHans de Goede
[ Upstream commit 1363074667a6b7d0507527742ccd7bbed5e3ceaa ] Add a new NO_REPORT_LUNS quirk and set it for Seagate drives with an usb-id of: 0bc2:331a, as these will fail to respond to a REPORT_LUNS command. Cc: stable@vger.kernel.org Reported-and-tested-by: David Webb <djw@noc.ac.uk> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-19MLK-12684-3: Documentation: gpmi-nand: document the gpmi-nand compatibilityHan Xu
Document the gpmi-nand compatibility for i.MX6ULL Signed-off-by: Han Xu <han.xu@nxp.com>
2016-04-11efi: Make efivarfs entries immutable by defaultPeter Jones
[ Upstream commit ed8b0de5a33d2a2557dce7f9429dca8cb5bc5879 ] "rm -rf" is bricking some peoples' laptops because of variables being used to store non-reinitializable firmware driver data that's required to POST the hardware. These are 100% bugs, and they need to be fixed, but in the mean time it shouldn't be easy to *accidentally* brick machines. We have to have delete working, and picking which variables do and don't work for deletion is quite intractable, so instead make everything immutable by default (except for a whitelist), and make tools that aren't quite so broad-spectrum unset the immutable flag. Signed-off-by: Peter Jones <pjones@redhat.com> Tested-by: Lee, Chun-Yi <jlee@suse.com> Acked-by: Matthew Garrett <mjg59@coreos.com> Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-06MLK-12602: Documentation: gpmi-nand: legacy bch geometry option for NANDHan Xu
document the new option for legacy bch geometry support. Conflicts: Documentation/devicetree/bindings/mtd/gpmi-nand.txt Signed-off-by: Han Xu <han.xu@nxp.com> (cherry picked from commit c1c24ecd24cb808e825eb13a3e3d016c283322cc)
2016-03-22KVM: MMU: fix ept=0/pte.u=1/pte.w=0/CR0.WP=0/CR4.SMEP=1/EFER.NX=0 comboPaolo Bonzini
[ Upstream commit 844a5fe219cf472060315971e15cbf97674a3324 ] Yes, all of these are needed. :) This is admittedly a bit odd, but kvm-unit-tests access.flat tests this if you run it with "-cpu host" and of course ept=0. KVM runs the guest with CR0.WP=1, so it must handle supervisor writes specially when pte.u=1/pte.w=0/CR0.WP=0. Such writes cause a fault when U=1 and W=0 in the SPTE, but they must succeed because CR0.WP=0. When KVM gets the fault, it sets U=0 and W=1 in the shadow PTE and restarts execution. This will still cause a user write to fault, while supervisor writes will succeed. User reads will fault spuriously now, and KVM will then flip U and W again in the SPTE (U=1, W=0). User reads will be enabled and supervisor writes disabled, going back to the originary situation where supervisor writes fault spuriously. When SMEP is in effect, however, U=0 will enable kernel execution of this page. To avoid this, KVM also sets NX=1 in the shadow PTE together with U=0. If the guest has not enabled NX, the result is a continuous stream of page faults due to the NX bit being reserved. The fix is to force EFER.NX=1 even if the CPU is taking care of the EFER switch. (All machines with SMEP have the CPU_LOAD_IA32_EFER vm-entry control, so they do not use user-return notifiers for EFER---if they did, EFER.NX would be forced to the same value as the host). There is another bug in the reserved bit check, which I've split to a separate patch for easier application to stable kernels. Cc: stable@vger.kernel.org Cc: Andy Lutomirski <luto@amacapital.net> Reviewed-by: Xiao Guangrong <guangrong.xiao@linux.intel.com> Fixes: f6577a5fa15d82217ca73c74cd2dcbc0f6c781dd Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-03-22ARM: OMAP2+: hwmod: Introduce ti,no-idle dt propertyLokesh Vutla
[ Upstream commit 6327a31a3f875c438ca13058bc4c73f1a752cd8a ] commit 2e18f5a1bc18e8af7031b3b26efde25307014837 upstream. Introduce a dt property, ti,no-idle, that prevents an IP to idle at any point. This is to handle Errata i877, which tells that GMAC clocks cannot be disabled. Acked-by: Roger Quadros <rogerq@ti.com> Tested-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Dave Gerlach <d-gerlach@ti.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-03-04net/ipv6: add sysctl option accept_ra_min_hop_limitHangbin Liu
[ Upstream commit 8013d1d7eafb0589ca766db6b74026f76b7f5cb4 ] Commit 6fd99094de2b ("ipv6: Don't reduce hop limit for an interface") disabled accept hop limit from RA if it is smaller than the current hop limit for security stuff. But this behavior kind of break the RFC definition. RFC 4861, 6.3.4. Processing Received Router Advertisements A Router Advertisement field (e.g., Cur Hop Limit, Reachable Time, and Retrans Timer) may contain a value denoting that it is unspecified. In such cases, the parameter should be ignored and the host should continue using whatever value it is already using. If the received Cur Hop Limit value is non-zero, the host SHOULD set its CurHopLimit variable to the received value. So add sysctl option accept_ra_min_hop_limit to let user choose the minimum hop limit value they can accept from RA. And set default to 1 to meet RFC standards. Signed-off-by: Hangbin Liu <liuhangbin@gmail.com> Acked-by: YOSHIFUJI Hideaki <hideaki.yoshifuji@miraclelinux.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-03-01MLK-12462-1 mmc: core: add MMC_PM_IGNORE_PM_NOTIFY featureDong Aisheng
With igore pm notify feature, MMC core will not re-detect card after system suspend/resume. This is needed for some special cards like Broadcom WiFi which can't work propertly on card re-detect after system resume. Signed-off-by: Dong Aisheng <aisheng.dong@nxp.com> (cherry picked from commit 3a4a074d2ead8044afe42cd0d060fe25564b274c)
2016-02-19doc: usb: ci-hdrc-usb2: add property non-zero-ttctrl-tthaPeter Chen
If this property is not set, the max packet size is 1023 bytes, and if the total of packet size for pervious transactions are more than 256 bytes, it can't accept any transactions within this frame. The use case is single transaction, but higher frame rate. If this property is set, the max packet size is 188 bytes, it can handle more transactions than above case, it can accept transactions until it considers the left room size within frame is less than 188 bytes, software needs to make sure it does not send more than 90% maximum_periodic_data_per_frame. The use case is multiple transactions, but less frame rate. Signed-off-by: Peter Chen <peter.chen@kernel.org> Signed-off-by: Peter Chen <peter.chen@nxp.com>
2016-02-16MLK-12360-3 bcmdhd: fix bcmdhd blocks system suspend issueDong Aisheng
When enable WIFi and connected with AP, the system is unable to suspend. root@imx6qdlsolo:~# echo standby > /sys/power/state PM: Syncing filesystems ... done. Freezing user space processes ... (elapsed 0.001 seconds) done. Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done. dhdsdio_isr: Enter dhdsdio_isr: Enter dhdsdio_isr: disable SDIO interrupts Calling dhdsdio_dpc() from dhdsdio_isr dhdsdio_dpc: Enter dhdsdio_bussleep: request WAKE (currently SLEEP) (Keypress still response here.... ) It's caused by Broadcom WiFi driver will keep handling SDIO irq even after the driver is already suspended. This weird behavior will block the MMC host suspend during its irq synchronize operation in free_irq(), then the system suspend is blocked too and hanged. Add SDHCI_QUIRK2_SDIO_IRQ_THREAD for BCM WiFi to use kernel thread to process sdio interrupts which won't block system suspend and process freeze operation. Signed-off-by: Dong Aisheng <aisheng.dong@nxp.com>
2016-02-16MLK-12077-3 bcmdhd: fix bcmdhd system resume crash issue.Dong Aisheng
bcmdhd can't support removing host during suspend and driver crash when detect card after resume due to no response to CMD7. It looks bcmdhd has a special requirement to enumerate card by itself which is incompatible with current MMC core. So implement post-cd feature to allow driver to detect card as it wants, then we add back non-removable capability to avoid MMC core to redetect card after resume. root@imx6qdlsolo:~# echo standby > /sys/power/state PM: Syncing filesystems ... done. PM: Preparing system for standby sleep Freezing user space processes ... (elapsed 0.001 seconds) done. Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done. PM: Entering standby sleep evbug: Event. Dev: input3, Type: 0, Code: 0, Value: 1 evbug: Event. Dev: input2, Type: 0, Code: 0, Value: 1 PM: suspend of devices complete after 652.363 msecs PM: suspend devices took 0.660 seconds PM: late suspend of devices complete after 1.148 msecs PM: noirq suspend of devices complete after 1.043 msecs Disabling non-boot CPUs ... CPU1: shutdown Enabling non-boot CPUs ... CPU1 is up PM: noirq resume of devices complete after 0.534 msecs PM: early resume of devices complete after 0.553 msecs evbug: Event. Dev: input2, Type: 1, Code: 116, Value: 1 evbug: Event. Dev: input2, Type: 0, Code: 0, Value: 0 evbug: Event. Dev: input2, Type: 1, Code: 116, Value: 0 evbug: Event. Dev: input2, Type: 0, Code: 0, Value: 0 mmc1: error -110 during resume (card was removed?) PM: resume of devices complete after 605.525 msecs PM: resume devices took 0.610 seconds PM: Finishing wakeup. Restarting tasks ... done. WARNING: driver bcmsdh_sdmmc did not remove its interrupt handler! root@imx6qdlsolo:~# Unable to handle kernel NULL pointer dereference at virtual address 0000022c pgd = 80004000 [0000022c] *pgd=00000000 Internal error: Oops: 17 [#1] PREEMPT SMP ARM Modules linked in: bcmdhd evbug ov5647_camera_mipi mxc_mipi_csi mx6s_capture CPU: 1 PID: 780 Comm: kworker/u4:4 Not tainted 4.1.15-01434-g70f4b36 #1310 Hardware name: Freescale i.MX7 Dual (Device Tree) Workqueue: kmmcd mmc_rescan task: a974af80 ti: a846e000 task.ti: a846e000 PC is at _raw_spin_lock_irqsave+0x1c/0x5c LR is at get_parent_ip+0x10/0x2c pc : [<8077b9d4>] lr : [<8005207c>] psr: 60050093 sp : a846fc20 ip : 0001001f fp : a800b000 r10: 00000000 r9 : 00000001 r8 : 0000022c r7 : 00000002 r6 : 0000022c r5 : a0050013 r4 : 0000022c r3 : a974af80 r2 : 00000001 r1 : a846fc44 r0 : 00000000 Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel Control: 10c53c7d Table: a951406a DAC: 00000015 Process kworker/u4:4 (pid: 780, stack limit = 0xa846e210) Stack: (0xa846fc20 to 0xa8470000) fc20: 00000000 a846fc50 a846fc44 80061808 00000000 000001dc 00000000 805037fc fc40: 8d89d5ec 00000000 a974af80 80053e88 00000000 00000000 ab7293c0 00000000 fc60: 7f09c828 000000c9 7f09c828 a916a804 00000001 0001001f a800b000 7f0698a4 fc80: a974afc8 00000001 00000000 00000000 00012ebc a974af80 00000001 80ad46c0 fca0: a974af80 00000000 a8eeccc0 00000001 0001001f a846fd04 00000000 7f099440 fcc0: a800b000 7f0699c4 a846fcdf 00000000 00000001 7f068834 a937c900 0105c688 fce0: a846fd04 a8e20000 00000000 00000001 00000000 7f071f08 a846fd04 a80a0000 fd00: ffffffff 00000000 ffffffff a8e20000 a8e20000 00000000 7f099440 00000000 fd20: 00000000 7f099440 a800b000 7f072f4c a974af80 00000000 00000000 80778564 fd40: a846fd54 a9346550 80330028 00000001 a846e000 a8e20000 7f099440 00000000 fd60: 18005000 a8eeccc0 00000000 7f099440 a800b000 7f073744 a846fd8c 80052130 fd80: a9273898 00000000 a800b000 a8e20000 7f099440 00000001 a8eec200 a9270000 fda0: 00000000 7f099440 a800b000 7f07cd3c 80b81100 8040003f a800b000 00000000 fdc0: 00000000 a8e20000 7f099440 a9270000 a9273000 a9270000 00000000 7f099440 fde0: a800b000 7f02df4c 00000001 a8e20000 7f099440 a8eec200 00000000 a916e008 fe00: 00000000 a90bfb00 a800b000 7f074cbc a9270000 7f099440 a8e20000 00000000 fe20: a8f81610 7f0765ec 7f0765b0 a8eeccc0 a855df40 7f069310 a916a800 a8eec200 fe40: 7f09b414 7f06a950 7f06a908 a8f81608 a8f81600 8050e8b8 a8f81608 7f09b414 fe60: 80b22c70 80379744 a974af80 a8f8163c a8f81608 803797d4 00000005 a81ce930 fe80: a8f81608 8037923c a8f81608 a8f81608 80b93cf4 80376504 a846fea0 800e0e3c fea0: 00000000 00000000 a8f81608 000000bd a833f000 00000000 00000000 8050ed04 fec0: 00000001 8050dd8c 400f8c0f a833f000 ffffff92 a833f000 a81ce600 8050de30 fee0: 8050ddbc a833f240 a833f1dc 80506048 a90bfb00 a833f240 a800b000 a81ce600 ff00: 00000000 800462f0 a81ce600 80043c94 00000000 a800b000 a90bfb18 a800b014 ff20: a846e000 00000088 80b39379 a90bfb00 a800b000 8004654c 80ad4100 a800b164 ff40: a90bfb00 00000000 a84856c0 a90bfb00 80046500 00000000 00000000 00000000 ff60: 00000000 8004b1e8 2df9acc7 00000000 b5f3ff89 a90bfb00 00000000 00000000 ff80: a846ff80 a846ff80 00000000 00000000 a846ff90 a846ff90 a846ffac a84856c0 ffa0: 8004b10c 00000000 00000000 8000f568 00000000 00000000 00000000 00000000 ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ffe0: 00000000 00000000 00000000 00000000 00000013 00000000 ecd61557 f82769f5 [<8077b9d4>] (_raw_spin_lock_irqsave) from [<80061808>] (add_wait_queue+0x20/0x48) [<80061808>] (add_wait_queue) from [<805037fc>] (__mmc_claim_host+0x58/0x1b0) [<805037fc>] (__mmc_claim_host) from [<7f0698a4>] (sdioh_request_byte+0x1cc/0x2a4 [bcmdhd]) [<7f0698a4>] (sdioh_request_byte [bcmdhd]) from [<7f0699c4>] (sdioh_cfg_write+0x20/0x28 [bcmdhd]) [<7f0699c4>] (sdioh_cfg_write [bcmdhd]) from [<7f068834>] (bcmsdh_cfg_write+0x90/0xdc [bcmdhd]) [<7f068834>] (bcmsdh_cfg_write [bcmdhd]) from [<7f071f08>] (dhdsdio_clk_kso_enab+0x38/0x168 [bcmdhd]) [<7f071f08>] (dhdsdio_clk_kso_enab [bcmdhd]) from [<7f072f4c>] (dhdsdio_clk_devsleep_iovar+0xf4/0x5f4 [bcmdhd]) [<7f072f4c>] (dhdsdio_clk_devsleep_iovar [bcmdhd]) from [<7f073744>] (dhdsdio_bussleep+0x2f8/0x4dc [bcmdhd]) [<7f073744>] (dhdsdio_bussleep [bcmdhd]) from [<7f07cd3c>] (dhd_bus_stop+0x2e8/0x3f0 [bcmdhd]) [<7f07cd3c>] (dhd_bus_stop [bcmdhd]) from [<7f02df4c>] (dhd_detach+0x2a4/0x438 [bcmdhd]) [<7f02df4c>] (dhd_detach [bcmdhd]) from [<7f074cbc>] (dhdsdio_release+0x4c/0x1dc [bcmdhd]) [<7f074cbc>] (dhdsdio_release [bcmdhd]) from [<7f0765ec>] (dhdsdio_disconnect+0x3c/0xa0 [bcmdhd]) [<7f0765ec>] (dhdsdio_disconnect [bcmdhd]) from [<7f069310>] (bcmsdh_remove+0x3c/0x60 [bcmdhd]) [<7f069310>] (bcmsdh_remove [bcmdhd]) from [<7f06a950>] (bcmsdh_sdmmc_remove+0x48/0x60 [bcmdhd]) [<7f06a950>] (bcmsdh_sdmmc_remove [bcmdhd]) from [<8050e8b8>] (sdio_bus_remove+0x30/0xf8) [<8050e8b8>] (sdio_bus_remove) from [<80379744>] (__device_release_driver+0x70/0xe4) [<80379744>] (__device_release_driver) from [<803797d4>] (device_release_driver+0x1c/0x28) [<803797d4>] (device_release_driver) from [<8037923c>] (bus_remove_device+0xd8/0x104) [<8037923c>] (bus_remove_device) from [<80376504>] (device_del+0x10c/0x210) [<80376504>] (device_del) from [<8050ed04>] (sdio_remove_func+0x1c/0x28) [<8050ed04>] (sdio_remove_func) from [<8050dd8c>] (mmc_sdio_remove+0x40/0x70) [<8050dd8c>] (mmc_sdio_remove) from [<8050de30>] (mmc_sdio_detect+0x74/0x100) [<8050de30>] (mmc_sdio_detect) from [<80506048>] (mmc_rescan+0xb8/0x314) [<80506048>] (mmc_rescan) from [<800462f0>] (process_one_work+0x120/0x330) [<800462f0>] (process_one_work) from [<8004654c>] (worker_thread+0x4c/0x480) [<8004654c>] (worker_thread) from [<8004b1e8>] (kthread+0xdc/0xf4) [<8004b1e8>] (kthread) from [<8000f568>] (ret_from_fork+0x14/0x2c) Code: f10c0080 e3a00001 ebe359b1 f594f000 (e1943f9f) Signed-off-by: Dong Aisheng <aisheng.dong@nxp.com>
2016-01-20MLK-11360-01 crypto: caam_snvs: add snvs clock managementFugang Duan
caam_snvs driver involves snvs HP registers access that needs to enable snvs clock source. The patch add the clock management. Signed-off-by: Fugang Duan <B38611@freescale.com> Signed-off-by: Dan Douglass <dan.douglass@freescale.com>
2016-01-19MLK-12170-1 mmc: sdhci-esdhc-imx: support setting tuning start pointDong Aisheng
The delay cells of some SoCs may have less delay value of one cell, for such SoCs, user could set a start delay cell point to skip a few meaningless tuning cells. Signed-off-by: Dong Aisheng <aisheng.dong@nxp.com>
2016-01-19MLK-12284-2 doc: syscon: add clocks as optional propertyDong Aisheng
User can specify clocks in devicetree which is used for accessing the registers in this regmap. Signed-off-by: Dong Aisheng <b29396@freescale.com> (cherry picked from commit 4a89ef5b579e6fb5640df099ee13939ca6d3a325)
2016-01-14cpufreq: interactive: allow arbitrary speed / delay mappingsMinsung Kim
Accept a string of delays and speeds at which to apply the delay before raising each step above hispeed. For example, "80000 1300000:200000 1500000:40000" means that the delay at or above 1GHz, until 1.3GHz is 80 msecs, the delay until 1.5GHz is 200 msecs and the delay at or above 1.5GHz is 40 msecs when hispeed_freq is 1GHz. [toddpoynor@google.com: add documentation] Change-Id: Ifeebede8b1acbdd0a53e5c6916bccbf764dc854f Signed-off-by: Minsung Kim <ms925.kim@samsung.com>
2016-01-14cpufreq: interactive: default go_hispeed_load 99%, doc updatesTodd Poynor
Update default go_hispeed_load from 85% to 99%. Recent changes to the governor now use a default target_load of 90%. go_hispeed_load should not be lower than the target load for hispeed_freq, which could lead to oscillating speed decisions. Other recent changes reduce the need to dampen speed jumps on load spikes, while input event boosts from userspace are the preferred method for anticipating load spikes with UI impacts. General update to the documentation to reflect recent changes. Change-Id: I1b92f3091f42c04b10503cd1169a943b5dfd6faf Signed-off-by: Todd Poynor <toddpoynor@google.com>
2016-01-14cpufreq: interactive: allow arbitrary speed / target load mappingsTodd Poynor
Accept a string of target loads and speeds at which to apply the target loads, per the documentation update in this patch. For example, "85 1000000:90 1700000:99" targets CPU load 85% below speed 1GHz, 90% at or above 1GHz, until 1.7GHz and above, at which load 99% is targeted. Attempt to avoid oscillations by evaluating the current speed weighted by current load against each new choice of speed, choosing a higher speed if the current load requires a higher speed. Change-Id: Ie3300206047c84eca5a26b0b63ea512e5207550e Signed-off-by: Todd Poynor <toddpoynor@google.com>
