(cherry picked from commit 602505a35f2bf10963bb1f97adeaeb66e610de24)
This driver observes the USB ID pin connected over a GPIO and
updates the USB cable extcon states accordingly.
The existing GPIO extcon driver is not suitable for this purpose
as it needs to be taught to understand USB cable states and it
can't handle more than one cable per instance.
For the USB case we need to handle 2 cable states.
1) USB (attach/detach)
2) USB-HOST (attach/detach)
This driver can be easily updated in the future to handle VBUS
events in case it happens to be available on GPIO for any platform.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Reviewed-by: Felipe Balbi <balbi@ti.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
(cherry picked from commit e52817faae359ce95c93c2b6eb88b16d4b430181)
Device tree nodes are already treated as objects, and we already want to
expose them to userspace which is done using the /proc filesystem today.
Right now the kernel has to do a lot of work to keep the /proc view in
sync with the in-kernel representation. If device_nodes are switched to
be kobjects then the device tree code can be a whole lot simpler. It
also turns out that switching to using /sysfs from /proc results in
smaller code and data size, and the userspace ABI won't change if
/proc/device-tree symlinks to /sys/firmware/devicetree/base.
v7: Add missing sysfs_bin_attr_init()
v6: Add __of_add_property() early init fixes from Pantelis
v5: Rename firmware/ofw to firmware/devicetree
Fix updating property values in sysfs
v4: Fixed build error on Powerpc
Fixed handling of dynamic nodes on powerpc
v3: Fixed handling of duplicate attribute and child node names
v2: switch to using sysfs bin_attributes which solve the problem of
reporting incorrect property size.
Tested-by: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Nathan Fontenot <nfont@linux.vnet.ibm.com>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
(cherry picked from commit 75b57ecf9d1d1e17d099ab13b8f48e6e038676be)
With release of ACPI 5.1 and _DSD method we can finally name GPIOs (and
other things as well) returned by _CRS. Previously we were only able to
use integer index to find the corresponding GPIO, which is pretty error
prone if the order changes.
With _DSD we can now query GPIOs using name instead of an integer index,
like the below example shows:
// Bluetooth device with reset and shutdown GPIOs
Device (BTH)
Name (_HID, ...)
Name (_CRS, ResourceTemplate ()
GpioIo (Exclusive, PullUp, 0, 0, IoRestrictionInputOnly,
"\\_SB.GPO0", 0, ResourceConsumer) {15}
"\\_SB.GPO0", 0, ResourceConsumer) {27, 31}
Name (_DSD, Package ()
ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"),
Package ()
Package () {"reset-gpio", Package() {^BTH, 1, 1, 0 }},
Package () {"shutdown-gpio", Package() {^BTH, 0, 0, 0 }},
The format of the supported GPIO property is:
Package () { "name", Package () { ref, index, pin, active_low }}
ref - The device that has _CRS containing GpioIo()/GpioInt() resources,
typically this is the device itself (BTH in our case).
index - Index of the GpioIo()/GpioInt() resource in _CRS starting from zero.
pin - Pin in the GpioIo()/GpioInt() resource. Typically this is zero.
active_low - If 1 the GPIO is marked as active_low.
Since ACPI GpioIo() resource does not have field saying whether it is
active low or high, the "active_low" argument can be used here. Setting
it to 1 marks the GPIO as active low.
In our Bluetooth example the "reset-gpio" refers to the second GpioIo()
resource, second pin in that resource with the GPIO number of 31.
This patch implements necessary support to gpiolib for extracting GPIOs
using _DSD device properties.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Grant Likely <grant.likely@linaro.org>
(cherry picked from commit 0d9a693cc8619b28f0eeb689a554647d42848fde)
The huge majority of GPIOs have their direction and initial value set
right after being obtained by one of the gpiod_get() functions. The
integer GPIO API had gpio_request_one() that took a convenience flags
parameter allowing to specify an direction and value applied to the
returned GPIO. This feature greatly simplifies client code and ensures
errors are always handled properly.
A similar feature has been requested for the gpiod API. Since setting
the direction of a GPIO is so often the very next action done after
obtaining its descriptor, we prefer to extend the existing functions
instead of introducing new functions that would raise the
number of gpiod getters to 16 (!).
The drawback of this approach is that all gpiod clients need to be
updated. To limit the pain, temporary macros are introduced that allow
gpiod_get*() to be called with or without the extra flags argument. They
will be removed once all consumer code has been updated.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Reviewed-by: Mark Brown <broonie@linaro.org>
(cherry picked from commit 39b2bbe3d715cf5013b5c48695ccdd25bd3bf120)
Introduce gpiod_get_optional() and gpiod_get_index_optional() helpers
that make it easier for drivers to handle optional GPIOs.
Currently in order to handle optional GPIOs, a driver needs to special
case error handling for -ENOENT, such as this:
gpio = gpiod_get(dev, "foo");
if (IS_ERR(gpio)) {
if (PTR_ERR(gpio) != -ENOENT)
return PTR_ERR(gpio);
gpio = NULL;
if (gpio) {
/* set up GPIO */
With these new helpers the above is reduced to:
gpio = gpiod_get_optional(dev, "foo");
if (IS_ERR(gpio))
if (gpio) {
/* set up GPIO */
While at it, device-managed variants of these functions are also
provided.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Reviewed-by: Alexandre Courbot <acourbot@nvidia.com>
(cherry picked from commit 29a1f2333e07bbbecb920cc78fd035fe8f53207a)
If the I2C is disturbed by other signals sometimes the i2c-imx bus gets stuck
with SDA being low.
This adds a recovery function to the bus driver.
When e.g. a device driver detects a stuck bus
int i2c_recover_bus(struct i2c_adapter *adap)
can be called to try to recover the bus.
(cherry picked from commit 88731dc0e8b6ba244e097b412b302acf3b9cc889)
arch/arm/boot/dts/imx6qdl-apalis.dtsi
drivers/i2c/busses/i2c-imx.c
pfuze3000
Some registers on pfuze3000 will lost after exit from LPSR, need restore them,
otherwise system may reboot with below command after system enter LPSR one time:
root@imx7d_all:~# echo enabled > /sys/class/tty/ttymxc0/power/wakeup
root@imx7d_all:~# echo mem > /sys/power/state
because LDOGCTL not recover as 1. Add 'fsl,lpsr-mode' property to this case,
please add this property if your board support LPSR mode as imx7d-12x12-lpddr3-arm2
board.
Signed-off-by: Robin Gong <b38343@freescale.com>
Add snvs HP/LP clock management for the driver.
Signed-off-by: Fugang Duan <B38611@freescale.com>
caam_snvs driver involves snvs HP registers access that needs to
enable snvs clock source. The patch add the clock management.
Rename imx6_usb_charger_detection to be imx_usb_charger_detection to cover
both imx6 and imx7.
Acked-by: Peter Chen <peter.chen@freescale.com>
Signed-off-by: Li Jun <jun.li@freescale.com>
After introduce otg features in dts, and remove hnp_enable, we should update
otg test document for how to enable HNP, SRP and ADP.
Add otg version, srp, hnp and adp support for usb OTG port, then those OTG
features don't have to be decided by usb gadget drivers.
If the property "fsl,dma-buffer-size" is present, using the specified buffer size.
Otherwise, using the default audio buffer size.
Signed-off-by: Zidan Wang <zidan.wang@freescale.com>
Add how to enable USB OTG ADP feature and test sequence.
Add adp-support property for USB OTG port.
Freescale i.MX6UL contains a internal touchscreen controller,
this patch add a driver to support this controller.
Signed-off-by: Haibo Chen <haibo.chen@freescale.com>
It's optional, for delay time between putting phy into low power mode
and turn off PHY clock.
The current driver support stop mode by calling machine api.
The patch add dts support to set gpr register for stop request.
After magic pattern comming during system suspend status, system will
be waked up, and irq handler will be running, there have enet register
access. Since all clocks are disabled in suspend, and clocks are enabled
after resume function. But irq handler run before resume function.
For imx7d chip, access register need some clocks enabled, otherwise system
hang. So the patch also disable wake up irq in the suspend, after resume
back enable the irq, which can avoid system hang issue.
Rename busfreq compatible string name from "fsl,imx6_busfreq
to "fsl,imx_busfreq".
Signed-off-by: Anson Huang <b20788@freescale.com>
add compatible string "fsl,imx6ul-usbphy"
Signed-off-by: Peter Chen <peter.chen@freescale.com>
"fsl,imx6ul-usbmisc"
Add compatible string "fsl,imx6ul-usbmisc"
Add i.MX6UL pinctrl driver support.
WiFi driver could call wifi_card_detect function to re-detect card,
this is required by some special WiFi cards like broadcom WiFi.
To use this function, a new property is introduced to indicate a wifi host.
Signed-off-by: Dong Aisheng <b29396@freescale.com>
Add new property registers-default to gpio-74x164.
Signed-off-by: Sandor Yu <R01008@freescale.com>
Add documentation for how to use hnp_enable input file to enable or disable
full OTG HNP function in runtime.
(cherry picked from commit cd7a4868a63297e11a699b5f96f118df2bc9f437)
tuning-step is the delay cell steps in tuning procedure. This patch
add the tuning-step setting in driver, so that user can set the
tuning-step value in dts.
e.g.
tuning-step = <2>;
this example set the tuning-step as value 2.
This patch also set the tuning-step of i.MX7D as 2, so that the tuning
procedure can execute successfully.
Add imx7d to usbmisc-imx binding doc
Add pfuze3000 chip support.
(cherry picked from commit e874ae660887ea364d332b84eda45eb7c73da323)
This patch introduces generic code to perform PM domain look-up using
device tree and automatically bind devices to their PM domains.
Generic device tree bindings are introduced to specify PM domains of
devices in their device tree nodes.
Backwards compatibility with legacy Samsung-specific PM domain bindings
is provided, but for now the new code is not compiled when
CONFIG_ARCH_EXYNOS is selected to avoid collision with legacy code.
This will change as soon as the Exynos PM domain code gets converted to
use the generic framework in further patch.
This patch was originally submitted by Tomasz Figa when he was employed
by Samsung.
Link: http://marc.info/?l=linux-pm&m=139955349702152&w=2
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Acked-by: Rob Herring <robh@kernel.org>
Tested-by: Philipp Zabel <p.zabel@pengutronix.de>
Reviewed-by: Kevin Hilman <khilman@linaro.org>
(cherry picked from commit aa42240ab2544a8bcb2efb400193826f57f3175e)
Keep all power-domains already enabled by bootloader on, even if no
driver has claimed them. This is useful for debug and development, but
should not be needed on a platform with proper driver support.
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
(cherry picked from commit 39ac5ba51b69a77a30d2e783aed02ec73c9f6d70)
This reverts commit 4aa055cb0634bc8d0389070104fe6aa7cfa99b8c.
Add tx-d-cal property
timer registers
Some 32-bit (ARMv7) systems are architected like this:
* The firmware doesn't know and doesn't care about hypervisor mode and
we don't want to add the complexity of hypervisor there.
* The firmware isn't involved in SMP bringup or resume.
* The ARCH timer come up with an uninitialized offset (CNTVOFF)
between the virtual and physical counters. Each core gets a
different random offset.
* The device boots in "Secure SVC" mode.
* Nothing has touched the reset value of CNTHCTL.PL1PCEN or
CNTHCTL.PL1PCTEN (both default to 1 at reset)
On systems like the above, it doesn't make sense to use the virtual
counter. There's nobody managing the offset and each time a core goes
down and comes back up it will get reinitialized to some other random
value.
This adds an optional property which can inform the kernel of this
situation, and firmware is free to remove the property if it is going
to initialize the CNTVOFF registers when each CPU comes out of reset.
Currently, the best course of action in this case is to use the
physical timer, which is why it is important that CNTHCTL hasn't been
changed from its reset value and it's a reasonable assumption given
that the firmware has never entered HYP mode.
Note that it's been said that on ARMv8 systems the firmware and
kernel really can't be architected as described above. That means
using the physical timer like this really only makes sense for ARMv7
systems.
Signed-off-by: Doug Anderson <dianders@chromium.org>
Signed-off-by: Sonny Rao <sonnyrao@chromium.org>
Reviewed-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
ARM arch timers are tightly coupled with the CPU logic and lose context
on platform implementing HW power management when cores are powered
down at run-time. Marking the arch timers as C3STOP regardless of power
management capabilities causes issues on platforms with no power management,
since in that case the arch timers cannot possibly enter states where the
timer loses context at runtime and therefore can always be used as a high
resolution clockevent device.
In order to fix the C3STOP issue in a way compliant with how real HW
works, this patch adds a boolean property to the arch timer bindings
to define if the arch timer is managed by an always-on power domain.
This power domain is present on all ARM platforms to date, and manages
HW that must not be turned off, whatever the state of other HW
components (eg power controller). On platforms with no power management
capabilities, it is the only power domain present, which encompasses
and manages power supply for all HW components in the system.
If the timer is powered by the always-on power domain, the always-on
property must be present in the bindings which means that the timer cannot
be shutdown at runtime, so it is not a C3STOP clockevent device.
If the timer binding does not contain the always-on property, the timer is
assumed to be power-gateable, hence it must be defined as a C3STOP
clockevent device.
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Cc: Magnus Damm <damm@opensource.se>
Cc: Marc Carino <marc.ceeeee@gmail.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
It is optional, and only for 3p0, 2p5, and 1p1.
This patch adds guide for selecting available gadget drivers for otg and EH
compliance tests.
Signed-off-by: Li Jun <b47624@freescale.com>
(cherry picked from commit 520cac9e4fe938887dd45b5b4df6c8e35e125a59)
Update for HSIC controller
polling support
Update HNP test procedure as HNP polling is supported.
This property is used to wakeup transceiver if it's in
sleep mode.
(cherry picked from commit 9fa3b150ae0c4249ca1b6a7aba57d844540aa383)
(cherry picked from commit b492b7ca89bf8826a3cd5b2513b3235be63101d8)
The 'big-endian-data' property is originally used to indicate whether the
LSB firstly or MSB firstly will be transmitted to the CODEC or received
from the CODEC, and there has nothing relation to the memory data.
Generally, if the audio data in big endian format, which will be using the
bytes reversion, Here this can only be used to bits reversion.
So using the 'lsb-first' instead of 'big-endian-data' can make the code
to be readable easier and more easy to understand what this property is
used to do.
This property used for configuring whether the LSB or the MSB is transmitted
first for the fifo data.
Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com>
Acked-by: Nicolin Chen <nicoleotsuka@gmail.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
(cherry picked from commit eadb0019d206591e34e864b62059b292e157d8fc)
Signed-off-by: Mark Brown <broonie@linaro.org>
(cherry picked from commit 014fd22ef9c6a7e9536b7e16635714a1a34810a8)
It is used to indicate whether we use SoC's usb charger
detection or not. Besides, we add anatop phandle since
we need to use anatop register to do most of charger detect operations.
The new property "ddrsmp" was added into device tree. Update the doc
accordingly.
Signed-off-by: Ye.Li <B37916@freescale.com>
(cherry picked from commit 4239df12c5d6c3ac19a25e120ffe17df93c358a3)
Add compatible string for imx6sx-usbmisc.
Add the example for how to enable USB as system wakeup source.
Enable DMA support on i.mx6. The read speed can increase from 600KB/s
to 1.2MB/s on i.mx6q. You can disable or enable dma function in dts.
If not set "dma-names" in dts, spi will use PIO mode. This patch only
validate on i.mx6, not i.mx5, but encourage ones to apply this patch
on i.mx5 since they share the same IP.
Note:
Sometime, there is a weid data in rxfifo after one full tx/rx
transfer finish by DMA on i.mx6dl, so we disable dma functhion on
i.mx6dl.
Signed-off-by: Frank Li <Frank.Li@freescale.com>
(cherry picked from commit f62caccd12c17e4cb516d43a6e4dd8a3abc1f7e0)
(cherry picked from commit b87c98a8944c76840ed1375ed4792ef608de5c01)
add optional property devicetree for SPI slave nodes
into devicetree so that LSB mode can be enabled by devicetree.
Signed-off-by: Zhao Qiang <B45475@freescale.com>
(cherry picked from commit cd6339e6ced387ad67b5551dd2931cfd7e8b970b)
(cherry picked from commit 09623c20b3e6b11a914343d4b0f15b63e683f0d8)
Support for Wake-on-LAN using Magic Packet. ENET IP supports sleep mode
in low power status, when system enter suspend status, Magic packet can
wake up system even if all SOC clocks are gate. The patch doing below things:
- flagging the device as a wakeup source for the system, as well as
its Wake-on-LAN interrupt
- prepare the hardware for entering WoL mode
- add standard ethtool WOL interface
- enable the ENET interrupt to wake us
Tested on i.MX6q/dl sabresd, sabreauto boards, i.MX6SX arm2 boards.
