path: root/Documentation
2008-09-09update Documentation/filesystems/Locking for 2.6.27 changesChristoph Hellwig
In the 2.6.27 circle ->fasync lost the BKL, and the last remaining ->open variant that takes the BKL is also gone. ->get_sb and ->kill_sb didn't have BKL forever, so updated the entries while we're at that. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-05Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (98 commits) V4L/DVB (8881): gspca: After 'while (retry--) {...}', retry will be -1 but not 0. V4L/DVB (8880): PATCH: Fix parents on some webcam drivers V4L/DVB (8877): b2c2 and bt8xx: udelay to mdelay V4L/DVB (8876): budget: udelay changed to mdelay V4L/DVB (8874): gspca: Adjust hstart for sn9c103/ov7630 and update usb-id's. V4L/DVB (8873): gspca: Bad image offset with rev012a of spca561 and adjust exposure. V4L/DVB (8872): gspca: Bad image format and offset with rev072a of spca561. V4L/DVB (8870): gspca: Fix dark room problem with sonixb. V4L/DVB (8869): gspca: Move the Sonix webcams with TAS5110C1B from sn9c102 to gspca. V4L/DVB (8868): gspca: Support for vga modes with sif sensors in sonixb. V4L/DVB (8844): dabusb_fpga_download(): fix a memory leak V4L/DVB (8843): tda10048_firmware_upload(): fix a memory leak V4L/DVB (8842): vivi_release(): fix use-after-free V4L/DVB (8840): dib0700: add basic support for Hauppauge Nova-TD-500 (84xxx) V4L/DVB (8839): dib0700: add comment to identify 35th USB id pair V4L/DVB (8837): dvb: fix I2C adapters name size V4L/DVB (8835): gspca: Same pixfmt as the sn9c102 driver and raw Bayer added in sonixb. V4L/DVB (8834): gspca: Have a bigger buffer for sn9c10x compressed images. V4L/DVB (8833): gspca: Cleanup the sonixb code. V4L/DVB (8832): gspca: Bad pixelformat of vc0321 webcams. ...
2008-09-05Merge branch 'release-2.6.27' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-acpi-2.6 * 'release-2.6.27' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-acpi-2.6: acer-wmi: remove debugfs entries upon unloading ACPI: Avoid bogus timeout about SMbus check fujitsu-laptop: fix regression for P8010 in 2.6.27-rc ACPI: Make Len Brown the ACPI maintainer again ACPI: thinkpad-acpi: wan radio control is not experimental PNPACPI: ignore the producer/consumer bit for extended IRQ descriptors acpi: add checking for NULL early param ACPI: Fix typo in "Disable MWAIT via DMI on broken Compal board" ACPI: Fix now signed module parameter. ACPI: Change package length error to warning ACPI: Fix now signed module parameter.
2008-09-04Merge branch 'fixes_stg' of ../git_old into fixesMauro Carvalho Chehab
2008-09-03V4L/DVB (8826): gspca: Webcam Labtec 2200 (093a:2626) added in pac7311.Jean-Francois Moine
Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-09-03V4L/DVB (8825): gspca: More controls for pac73xx and new webcam 093a:2624.Hans de Goede
-Add usb id for 093a:2624 (pac7302) -Report some controls to userspace with 7302 only, as they are 7302 only -Add gain and exposure controls -Add autogain -Fix 7302 imaged being mirrored by default Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-09-03V4L/DVB (8715): gspca: Change the name of some webcam in the gspca doc.Jean-Francois Moine
2008-09-03V4L/DVB (8663): gspca: Webcam 0c45:6128 added in sonixj.Jean-Francois Moine
Patch adapted from a patch to gspcav1 made by the google microdia group. Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-09-03V4L/DVB (8556): au0828: add support for Hauppauge WoodburyMichael Krufky
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-09-02sysfs: document files in /sys/firmware/sgi_uv/Russ Anderson
Document files in /sys/firmware/sgi_uv/. Signed-off-by: Russ Anderson <rja@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-02ipc: document the new auto_msgmni proc fileNadia Derbey
Update Documentation/filesystems/proc.txt: it describes the file auto_msgmni intoduced to enable/disable msgmni automatic recomputing upon memory add/remove (see thread http://lkml.org/lkml/2008/7/4/27). Also added a description for msgmni (this filex is only listed in Documentation/sysctl/kernel.txt). Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-02NTFS: update homepageAdrian Bunk
Update the location of the NTFS homepage in several files. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-02don't diff generated firmware filesArjan van de Ven
With the new firmware infrastructure in 2.6.27, some files are generated and shouldn't be diffed; add these 2 to the "dontdiff" file Signed-off-by: Arjan van de Ven <arjan@Linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-28Merge branch 'wan' into release-2.6.27Andi Kleen
2008-08-28ACPI: thinkpad-acpi: wan radio control is not experimentalJeremy Fitzhardinge
The WWAN radio control has been working well for over three years, and is no longer experimental. Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-08-26lguest: update commentryRusty Russell
2008-08-22Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: Update documentation to remind users to update mke2fs.conf ext4: Fix small file fragmentation ext4: Initialize writeback_index to 0 when allocating a new inode ext4: make sure ext4_has_free_blocks returns 0 for ENOSPC ext4: journal credit fix for the delayed allocation's writepages() function ext4: Rework the ext4_da_writepages() function ext4: journal credits reservation fixes for DIO, fallocate ext4: journal credits reservation fixes for extent file writepage ext4: journal credits calulation cleanup and fix for non-extent writepage ext4: Fix bug where we return ENOSPC even though we have plenty of inodes ext4: don't try to resize if there are no reserved gdt blocks left ext4: Use ext4_discard_reservations instead of mballoc-specific call ext4: Fix ext4_dx_readdir hash collision handling ext4: Fix delalloc release block reservation for truncate ext4: Fix potential truncate BUG due to i_prealloc_list being non-empty ext4: Handle unwritten extent properly with delayed allocation
2008-08-22Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: [libata] pata_it821x: fix warning libata: Fix a large collection of DMA mode mismatches ahci: sis controllers actually can do PMP pata_via: clean up recent tf_load changes libata: restore SControl on detach libata: use ata_link_printk() when printing SError libata: always do follow-up SRST if hardreset returned -EAGAIN libata: fix EH action overwriting in ata_eh_reset() sata_mv: add the Gen IIE flag to the SoC devices. ata_piix: IDE Mode SATA patch for Intel Ibex Peak DeviceIDs ahci: RAID mode SATA patch for Intel Ibex Peak DeviceIDs sata_mv: don't issue two DMA commands concurrently libata: implement no[hs]rst force params
2008-08-22libata: implement no[hs]rst force paramsTejun Heo
Implement force params nohrst, nosrst and norst. This is to work around reset related problems and ease debugging. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-21Documentation: HOWTO-ja_JP-sync patchTsugikazu Shibata
Here is a patch for Documentation/ja_JP/HOWTO sync with latest Documentation/HOWTO. It includes translation of changes done by Jon Corbet,Jiri Pirko and me: http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=history;f=Documentation/HOWTO;h=c2371c5a98f99b5eaa785bd0affd6c40187e84e3;hb=HEAD Singed-off-by: Tsugikazu Shibata <tshibata@ab.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-21Japanese translation of Documentation/SubmitChecklistTakenori Nagano
Hi, This patch adds SubmitChecklist translated into Japanese to Documentation/ja_JP directory. The translated SubmitChecklist has already been reviewed by JF project. SubmitChecklist is one of the important policy documents. So, I would like to merge into 2.6.27. Signed-off-by: Takenori Nagano <t-nagano@ah.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-20documentation: describe bootmem_debug kernel parameterAndreas Herrmann
"bootmem_debug" is not mentioned in kernel-parameters.txt. Recently I had to use that kernel option and I think it should be documented. Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Johannes Weiner <hannes@saeurebad.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: (22 commits) [SCSI] ibmvfc: Driver version 1.0.2 [SCSI] ibmvfc: Add details to async event log [SCSI] ibmvfc: Sanitize response lengths [SCSI] ibmvfc: Fix for lost async events [SCSI] ibmvfc: Fixup host state during reinit [SCSI] ibmvfc: Fix another hang on module removal [SCSI] ibmvscsi: Fixup desired DMA value for shared memory partitions [SCSI] megaraid_sas: remove sysfs dbg_lvl world writeable permissions [SCSI] qla2xxx: Update version number to 8.02.01-k7. [SCSI] qla2xxx: Explicitly tear-down vports during PCI remove_one(). [SCSI] qla2xxx: Reference proper ha during SBR handling. [SCSI] qla2xxx: Set npiv_supported flag for FCoE HBAs. [SCSI] qla2xxx: Don't leak SG-DMA mappings while aborting commands. [SCSI] qla2xxx: Correct vport-state management issues during ISP-ABORT. [SCSI] qla2xxx: Correct synchronization of software/firmware fcport states. [SCSI] scsi_dh: Initialize lun_state in check_ownership() [SCSI] scsi_dh: Do not use scsilun in rdac hardware handler [SCSI] megaraid_sas: version and Documentation Update [SCSI] megaraid_sas: add new controllers (0x78 0x79) [SCSI] megaraid_sas: add the shutdown DCMD cmd to driver shutdown routine ...
2008-08-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (94 commits) pkt_sched: Prevent livelock in TX queue running. Revert "pkt_sched: Add BH protection for qdisc_stab_lock." Revert "pkt_sched: Protect gen estimators under est_lock." pkt_sched: remove bogus block (cleanup) nf_nat: use secure_ipv4_port_ephemeral() for NAT port randomization netfilter: ctnetlink: sleepable allocation with spin lock bh netfilter: ctnetlink: fix sleep in read-side lock section netfilter: ctnetlink: fix double helper assignation for NAT'ed conntracks netfilter: ipt_addrtype: Fix matching of inverted destination address type dccp: Fix panic caused by too early termination of retransmission mechanism pkt_sched: Don't hold qdisc lock over qdisc_destroy(). pkt_sched: Add lockdep annotation for qdisc locks pkt_sched: Never schedule non-root qdiscs. removed unused #include <version.h> rt2x00: Fix txdone_entry_desc_flags b43: Fix for another Bluetooth Coexistence SPROM Programming error for BCM4306 mac80211: remove kdoc references to IEEE80211_HW_HOST_GEN_BEACON_TEMPLATE p54u: reset skb's data/tail pointer on requeue p54: move p54_vdcf_init to the right place. iwlwifi: fix printk newlines ...
2008-08-18rfkill: protect suspended rfkill controllersHenrique de Moraes Holschuh
Guard rfkill controllers attached to a rfkill class against state changes after class suspend has been issued. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-16Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (38 commits) [ARM] 5191/1: ARM: remove CVS keywords [ARM] pxafb: fix the warning of incorrect lccr when lcd_conn is specified [ARM] pxafb: add flag to specify output format on LDD pins when base is RGBT16 [ARM] pxafb: fix the incorrect configuration of GPIO77 as ACBIAS for TFT LCD [ARM] 5198/1: PalmTX: PCMCIA fixes [ARM] Fix a pile of broken watchdog drivers [ARM] update mach-types [ARM] 5196/1: fix inline asm constraints for preload [ARM] 5194/1: update .gitignore [ARM] add proc-macros.S include to proc-arm940 and proc-arm946 [ARM] 5192/1: ARM TLB: add v7wbi_{possible,always}_flags to {possible,always}_tlb_flags [ARM] 5193/1: Wire up missing syscalls [ARM] traps: don't call undef hook functions with spinlock held [ARM] 5183/2: Provide Poodle LoCoMo GPIO names [ARM] dma-mapping: provide sync_range APIs [ARM] dma-mapping: improve type-safeness of DMA translations [ARM] Kirkwood: instantiate the orion_spi driver in the platform code [ARM] prevent crashing when too much RAM installed [ARM] Kirkwood: Instantiate mv_xor driver [ARM] Orion: Instantiate mv_xor driver for 5182 ...
2008-08-16[SCSI] megaraid_sas: version and Documentation UpdateYang, Bo
Signed-off-by: Bo Yang <bo.yang@lsi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-08-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: wm8990: Implement speaker volume PGA ALSA: wm8990: Fix routing of left DAC to speaker mixer ALSA: virtuoso: add Xonar D1 support
2008-08-15Merge branch 'linux-next' of git://git.infradead.org/~dedekind/ubifs-2.6Linus Torvalds
* 'linux-next' of git://git.infradead.org/~dedekind/ubifs-2.6: (29 commits) UBIFS: xattr bugfixes UBIFS: remove unneeded check UBIFS: few commentary fixes UBIFS: fix budgeting request alignment in xattr code UBIFS: improve arguments checking in debugging messages UBIFS: always set i_generation to 0 UBIFS: correct spelling of "thrice". UBIFS: support splice_write UBIFS: minor tweaks in commit UBIFS: reserve more space for index UBIFS: print pid in dump function UBIFS: align inode data to eight UBIFS: improve budgeting checks UBIFS: correct orphan deletion order UBIFS: fix typos in comments UBIFS: do not union creat_sqnum and del_cmtno UBIFS: optimize deletions UBIFS: increment commit number earlier UBIFS: remove another unneeded function parameter UBIFS: remove unneeded function parameter ...
2008-08-15ibmaem: update the documentation to reflect the current nameDarrick J. Wong
Minor documentation update to reflect the current full name of the power management hardware interface and reflows the text a bit. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15Documentation/vm/page_migration: update reference to numa_maps + fix ↵Michael Kerrisk
download URI With man-pages-3.07, the numa_maps documentation home is now proc(5), so the reference in Documentation/vm/page_migration needs updating. (Cliff/Lee are removing numa_maps.5 from the numactl package.) Also, the download location for the numactl package changed a while back. This patch fixes both things, as well as a typo (provided-->provides). Signed-off-by: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Cliff Wickman <cpw@sgi.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-14ALSA: virtuoso: add Xonar D1 supportClemens Ladisch
Add support for the Asus Xonar D1. It is the same as the DX, but without the external power detection. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-13USB: update to DocumentationOliver Neukum
this mentions a new deadlock due to advanced power management. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-13usb: auerswald: remove driver (obsolete)Wolfgang Mües
This patch removes the auerswald USB driver from the linux kernel 2.6.26. This driver was included into the kernel mainly to connect to the ISDN framework. This was done in linux 2.4.x. For 2.6.x, due to the fragile and moving ISDN support, this connection was never realized, and the only use of this driver was for device configuration. In the age of DSL, the demand of ISDN support is getting very low. Meanwhile, with the advent of libusb, an userspace driver was done for the device configuration which works fine for linux and mac. (Thanks to the libusb developers!). The userspace driver is downloadable from the auerswald web site. So this driver is obsolete now and has to be removed. Many thanks to all developers which helped me to bring this driver up and working. Signed-off-by: Wolfgang Muees <wolfgang@iksw-muees.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-13Documentation: fix typo in ubifs.txtSebastian Siewior
Signed-off-by: Sebastian Siewior <bigeasy@linutronix.de> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-12docsrc: fix getdelays printk formatsRandy Dunlap
Fix printf format type warnings (seen on alpha & ia64): Documentation/accounting/getdelays.c:206: warning: format '%15llu' expects type 'long long unsigned int', but argument 6 has type '__u64' Documentation/accounting/getdelays.c:206: warning: format '%15llu' expects type 'long long unsigned int', but argument 7 has type '__u64' Documentation/accounting/getdelays.c:206: warning: format '%15llu' expects type 'long long unsigned int', but argument 8 has type '__u64' Documentation/accounting/getdelays.c:206: warning: format '%15llu' expects type 'long long unsigned int', but argument 9 has type '__u64' Documentation/accounting/getdelays.c:206: warning: format '%15llu' expects type 'long long unsigned int', but argument 12 has type '__u64' Documentation/accounting/getdelays.c:206: warning: format '%15llu' expects type 'long long unsigned int', but argument 13 has type '__u64' Documentation/accounting/getdelays.c:206: warning: format '%15llu' expects type 'long long unsigned int', but argument 16 has type '__u64' Documentation/accounting/getdelays.c:206: warning: format '%15llu' expects type 'long long unsigned int', but argument 17 has type '__u64' Documentation/accounting/getdelays.c:214: warning: format '%15llu' expects type 'long long unsigned int', but argument 4 has type '__u64' Documentation/accounting/getdelays.c:214: warning: format '%15llu' expects type 'long long unsigned int', but argument 5 has type '__u64' Documentation/accounting/getdelays.c:221: warning: format '%llu' expects type 'long long unsigned int', but argument 2 has type '__u64' Documentation/accounting/getdelays.c:221: warning: format '%llu' expects type 'long long unsigned int', but argument 3 has type '__u64' Documentation/accounting/getdelays.c:221: warning: format '%llu' expects type 'long long unsigned int', but argument 4 has type '__u64' Documentation/accounting/getdelays.c:221: warning: format '%llu' expects type 'long long unsigned int', but argument 5 has type '__u64' Documentation/accounting/getdelays.c:221: warning: format '%llu' expects type 'long long unsigned int', but argument 6 has type '__u64' Documentation/accounting/getdelays.c:236: warning: 'cmd_type' may be used uninitialized in this function Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12docsrc: fix crc32hash typeRandy Dunlap
Fix differing signedness warning: Documentation/pcmcia/crc32hash.c:29: warning: pointer targets in passing argument 1 of 'crc32' differ in signedness Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12docsrc: fix ifenslave typeRandy Dunlap
Documentation/networking/ifenslave.c:1084: warning: pointer targets in assignment differ in signedness >From include/linux/socket.h: * 1003.1g requires sa_family_t and that sa_data is char. and from SUSv3: (http://www.opengroup.org/onlinepubs/009695399/basedefs/sys/socket.h.html) The <sys/socket.h> header shall define the sockaddr structure that includes at least the following members: sa_family_t sa_family Address family. char sa_data[] Socket address (variable-length data). <end SUSv3> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12docsrc: fix procfs exampleRandy Dunlap
Add MODULE_LICENSE() to DocBook/procfs_example.c since modpost complained about a missing license there. Remove tty procfs removal since the creation was deleted long ago (http://git.kernel.org/?p=linux/kernel/git/tglx/history.git;a=commitdiff;h=5ad9cb65e9b15e5b83e2dd1c10a4bcaccc4ec644). Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: <J.A.K.Mouw@its.tudelft.nl> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12docsrc: build Documentation/ sourcesRandy Dunlap
Currently source files in the Documentation/ sub-dir can easily bit-rot since they are not generally buildable, either because they are hidden in text files or because there are no Makefile rules for them. This needs to be fixed so that the source files remain usable and good examples of code instead of bad examples. Add the ability to build source files that are in the Documentation/ dir. Add to Kconfig as "BUILD_DOCSRC" config symbol. Use "CONFIG_BUILD_DOCSRC=1 make ..." to build objects from the Documentation/ sources. Or enable BUILD_DOCSRC in the *config system. However, this symbol depends on HEADERS_CHECK since the header files need to be installed (for userspace builds). Built (using cross-tools) for x86-64, i386, alpha, ia64, sparc32, sparc64, powerpc, sh, m68k, & mips. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12cpu hotplug: s390 doesn't support additional_cpus anymore.Heiko Carstens
s390 doesn't support the additional_cpus kernel parameter anymore since a long time. So we better update the code and documentation to reflect that. Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12quota: documentation for sending "below quota" messages via netlink and tiny ↵Jan Kara
doc update Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12feature-removal-schedule.txt: remove the NCR53C9x entryAdrian Bunk
Now that the driver is removed we should also remove the entry in Documentation/feature-removal-schedule.txt Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Christoph Hellwig <hch@lst.de> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12lguest: don't set MAC address for guest unless specifiedRusty Russell
This shows up when trying to bridge: tap0: received packet with own address as source address As Max Krasnyansky points out, there's no reason to give the guest the same mac address as the TUN device. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Max Krasnyansky <maxk@qualcomm.com>
2008-08-11Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: powerpc: Remove include/linux/harrier_defs.h powerpc: Do not ignore arch/powerpc/include powerpc: Delete completed "ppc removal" task from feature removal file powerpc/mm: Fix attribute confusion with htab_bolt_mapping() powerpc/pci: Don't keep ISA memory hole resources in the tree powerpc: Zero fill the return values of rtas argument buffer powerpc/4xx: Update defconfig files for 2.6.27-rc1 powerpc/44x: Incorrect NOR offset in Warp DTS powerpc/44x: Warp DTS changes for board updates powerpc/4xx: Cleanup Warp for i2c driver changes. powerpc/44x: Adjust warp-nand resource end address
2008-08-11powerpc: Delete completed "ppc removal" task from feature removal fileRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-09Merge branch 'for-rmk' of git://aeryn.fluff.org.uk/bjdooks/linuxRussell King
2008-08-09[ARM] S3C24XX: Documentation: Update GPIO statusBen Dooks
Update the status of the S3C24XX GPIO now we have moved to supporting GPIOLIB Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-08-09[ARM] S3C24XX: Documentation: update SD/MMC statusBen Dooks
Update SD/MMC status now that the driver is merged. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-08-09[ARM] S3C24XX: Documentation: Update suported CPU listBen Dooks
Update supported and in-progress cpu list. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
