path: root/Documentation
2014-05-30Merge tag 'firewire-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394 Pull firewire fix from Stefan Richter: "A regression fix for the IEEE 1394 subsystem: re-enable IRQ-based asynchronous request reception at addresses below 128 TB" * tag 'firewire-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394: firewire: revert to 4 GB RDMA, fix protocols using Memory Space
2014-05-30Merge tag 'dm-3.15-fixes-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm Pull device-mapper fixes from Mike Snitzer: "A dm-cache stable fix to split discards on cache block boundaries because dm-cache cannot yet handle discards that span cache blocks. Really fix a dm-mpath LOCKDEP warning that was introduced in -rc1. Add a 'no_space_timeout' control to dm-thinp to restore the ability to queue IO indefinitely when no data space is available. This fixes a change in behavior that was introduced in -rc6 where the timeout couldn't be disabled" * tag 'dm-3.15-fixes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm: dm mpath: really fix lockdep warning dm cache: always split discards on cache block boundaries dm thin: add 'no_space_timeout' dm-thin-pool module param
2014-05-29firewire: revert to 4 GB RDMA, fix protocols using Memory SpaceStefan Richter
Undo a feature introduced in v3.14 by commit fcd46b34425d "firewire: Enable remote DMA above 4 GB". That change raised the minimum address at which protocol drivers and user programs can register for request reception from 0x0001'0000'0000 to 0x8000'0000'0000. It turned out that at least one vendor-specific protocol exists which uses lower addresses: https://bugzilla.kernel.org/show_bug.cgi?id=76921 For the time being, revert most of commit fcd46b34425d so that affected protocols work like with kernel v3.13 and before. Just keep the valid documentation parts from the regressing commit, and the ability to identify controllers which could be programmed to accept >32 bit physical DMA addresses. The rest of fcd46b34425d should probably be brought back as an optional instead of default feature. Reported-by: Fabien Spindler <fabien.spindler@inria.fr> Cc: <stable@vger.kernel.org> # 3.14+ Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2014-05-28Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm fixes from Paolo Bonzini: "Small fixes for x86, slightly larger fixes for PPC, and a forgotten s390 patch. The PPC fixes are important because they fix breakage that is new in 3.15" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: s390: announce irqfd capability KVM: x86: disable master clock if TSC is reset during suspend KVM: vmx: disable APIC virtualization in nested guests KVM guest: Make pv trampoline code executable KVM: PPC: Book3S: ifdef on CONFIG_KVM_BOOK3S_32_HANDLER for 32bit KVM: PPC: Book3S HV: Add missing code for transaction reclaim on guest exit KVM: PPC: Book3S: HV: make _PAGE_NUMA take effect
2014-05-25Merge branch 'rdunlap' (patches from Randy Dunlap)Linus Torvalds
Merge documentation fixes from Randy Dunlap. * emailed patches from Randy Dunlap <rdunlap@infradead.org>: Documentation: update /proc/stat "intr" count summary Documentation: update java sample wrapper for java 7 Documentation: update thunderbird email client settings Documentation: fix typos in drm docbook
2014-05-25Documentation: update /proc/stat "intr" count summaryJan Moskyto Matejka
The sum at the beginning of line "intr" includes also unnumbered interrupts. It implies that the sum at the beginning isn't the sum of the remainder of the line, not even an estimation. Fixed the documentation to mention that. This behaviour was added to /proc/stat in commit a2eddfa95919 ("x86: make /proc/stat account for all interrupts") Signed-off-by: Jan Moskyto Matejka <mq@suse.cz> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-25Documentation: update java sample wrapper for java 7Jonathan Callen
The sample wrapper currently fails on some Java 7 .class files. This updates the wrapper to properly handle those files. Signed-off-by: Jonathan Callen <jcallen@gentoo.org> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-25Documentation: update thunderbird email client settingsPaul McQuade
Added setting to email-clients that is easier to read and is easier to setup thunderbird. Removed config settings and added GUI settings. Signed-off-by: Paul McQuade <paulmcquad@gmail.com> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-25Documentation: fix typos in drm docbookMasanari Iida
Fix spelling typo in DocBook/drm.tmpl Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-25Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging Pull hwmon subsystem fixes from Jean Delvare. * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: (ntc_thermistor) Fix OF device ID mapping hwmon: (ntc_thermistor) Fix dependencies hwmon: Document temp[1-*]_min_hyst sysfs attribute
2014-05-25hwmon: Document temp[1-*]_min_hyst sysfs attributeJean Delvare
The temp[1-*]_min_hyst sysfs attribute is already implemented by 3 hwmon drivers (adt7x10, lm77 and lm92) but was missing from the standard interface. Also add temp[1-*]_lcrit_hyst for consistency, even though no driver implement that one for the time being. Signed-off-by: Jean Delvare <jdelvare@suse.de> Reviewed-by: Guenter Roeck <linux@roeck-us.net>
2014-05-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "It looks like a sizeble collection but this is nearly 3 weeks of bug fixing while you were away. 1) Fix crashes over IPSEC tunnels with NAT, the latter can reroute the packet through a non-IPSEC protected path and the code has to be able to handle SKBs attached to routes lacking an attached xfrm state. From Steffen Klassert. 2) Fix OOPSs in ipv4 and ipv6 ipsec layers for unsupported sub-protocols, also from Steffen Klassert. 3) Set local_df on fragmented netfilter skbs otherwise we won't be able to forward successfully, from Florian Westphal. 4) cdc_mbim ipv6 neighbour code does __vlan_find_dev_deep without holding RCU lock, from Bjorn Mork. 5) local_df test in ip_may_fragment is inverted, from Florian Westphal. 6) jme driver doesn't check for DMA mapping failures, from Neil Horman. 7) qlogic driver doesn't calculate number of TX queues properly, from Shahed Shaikh. 8) fib_info_cnt can drift irreversibly positive if we fail to allocate the fi->fib_metrics array, from Sergey Popovich. 9) Fix use after free in ip6_route_me_harder(), also from Sergey Popovich. 10) When SYSCTL is disabled, we don't handle local_port_range and ping_group_range defaults properly at all, from Cong Wang. 11) Unaccelerated VLAN tagged frames improperly handled by cdc_mbim driver, fix from Bjorn Mork. 12) cassini driver needs nested lock annotations for TX locking, from Emil Goode. 13) On init error ipv6 VTI driver can unregister pernet ops twice, oops. Fix from Mahtias Krause. 14) If macvlan device is down, don't propagate IFF_ALLMULTI changes, from Peter Christensen. 15) Missing NULL pointer check while parsing netlink config options in ip6_tnl_validate(). From Susant Sahani. 16) Fix handling of neighbour entries during ipv6 router reachability probing, from Duan Jiong. 17) x86 and s390 JIT address randomization has some address calculation bugs leading to crashes, from Alexei Starovoitov and Heiko Carstens. 18) Clear up those uglies with nop patching and net_get_random_once(), from Hannes Frederic Sowa. 19) Option length miscalculated in ip6_append_data(), fix also from Hannes Frederic Sowa. 20) A while ago we fixed a race during device unregistry when a namespace went down, turns out there is a second place that needs similar protection. From Cong Wang. 21) In the new Altera TSE driver multicast filtering isn't working, disable it and just use promisc mode until the cause is found. From Vince Bridgers. 22) When we disable router enabling in ipv6 we have to flush the cached routes explicitly, from Duan Jiong. 23) NBMA tunnels should not cache routes on the tunnel object because the key is variable, from Timo Teräs. 24) With stacked devices GRO information in skb->cb[] can be not setup properly, make sure it is in all code paths. From Eric Dumazet. 25) Really fix stacked vlan locking, multiple levels of nesting with intervening non-vlan devices are possible. From Vlad Yasevich. 26) Fallback ipip tunnel device's mtu is not setup properly, from Steffen Klassert. 27) The packet scheduler's tcindex filter can crash because we structure copy objects with list_head's inside, oops. From Cong Wang. 28) Fix CHECKSUM_COMPLETE handling for ipv6 GRE tunnels, from Eric Dumazet. 29) In some configurations 'itag' in __mkroute_input() can end up being used uninitialized because of how fib_validate_source() works. Fix it by explitly initializing itag to zero like all the other fib_validate_source() callers do, from Li RongQing" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (116 commits) batman: fix a bogus warning from batadv_is_on_batman_iface() ipv4: initialise the itag variable in __mkroute_input bonding: Send ALB learning packets using the right source bonding: Don't assume 802.1Q when sending alb learning packets. net: doc: Update references to skb->rxhash stmmac: Remove unbalanced clk_disable call ipv6: gro: fix CHECKSUM_COMPLETE support net_sched: fix an oops in tcindex filter can: peak_pci: prevent use after free at netdev removal ip_tunnel: Initialize the fallback device properly vlan: Fix build error wth vlan_get_encap_level() can: c_can: remove obsolete STRICT_FRAME_ORDERING Kconfig option MAINTAINERS: Pravin Shelar is Open vSwitch maintainer. bnx2x: Convert return 0 to return rc bonding: Fix alb mode to only use first level vlans. bonding: Fix stacked device detection in arp monitoring macvlan: Fix lockdep warnings with stacked macvlan devices vlan: Fix lockdep warning with stacked vlan devices. net: Allow for more then a single subclass for netif_addr_lock net: Find the nesting level of a given device by type. ...
2014-05-23Documentation: fix DOCBOOKS=... buildingJohannes Berg
Prior to commit 4266129964b8 ("[media] DocBook: Move all media docbook stuff into its own directory") it was possible to build only a single (or more) book(s) by calling, for example make htmldocs DOCBOOKS=80211.xml This now fails: cp: target `.../Documentation/DocBook//media_api' is not a directory Ignore errors from that copy to make this possible again. Fixes: 4266129964b8 ("[media] DocBook: Move all media docbook stuff into its own directory") Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-22net: doc: Update references to skb->rxhashTobias Klauser
In commit 61b905da33 ("net: Rename skb->rxhash to skb->hash"), skb->rxhash was renamed to skb->hash. Update references in Documentation accordingly. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-21Merge tag 'pci-v3.15-fixes-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI fixes from Bjorn Helgaas: "These are fixes for an SHPCHP hotplug regression, a "wait for pending transaction" problem (used in device reset paths), and an email address update. PCI device hotplug: - Fix SHPCHP bus speed mismatch issue (Marcel Apfelbaum) Miscellaneous: - Fix pci_wait_for_pending_transaction() (Gavin Shan) - Update email address (Ben Hutchings)" * tag 'pci-v3.15-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: PCI: Wrong register used to check pending traffic PCI: shpchp: Check bridge's secondary (not primary) bus speed PCI: Update my email address
2014-05-21Merge tag 'clk-fixes-for-linus' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull clock framework fixes from Mike Turquette: "Clock framework and driver fixes, all of which fix user-visible regressions. As usual most fixes are for platform-specific clock drivers, but there are also two fixes to the clk core after recent changes to the way that clock unregistration is handled" * tag 'clk-fixes-for-linus' of git://git.linaro.org/people/mike.turquette/linux: clk: tegra: Fix wrong value written to PLLE_AUX clk: shmobile: clk-mstp: change to using clock-indices clk: Fix slab corruption in clk_unregister() clk: Fix double free due to devm_clk_register() clk: socfpga: fix clock driver for 3.15 clk: divider: Fix best div calculation for power-of-two and table dividers clk: bcm281xx: don't use unnamed structs or unions
2014-05-20dm thin: add 'no_space_timeout' dm-thin-pool module paramMike Snitzer
Commit 85ad643b ("dm thin: add timeout to stop out-of-data-space mode holding IO forever") introduced a fixed 60 second timeout. Users may want to either disable or modify this timeout. Allow the out-of-data-space timeout to be configured using the 'no_space_timeout' dm-thin-pool module param. Setting it to 0 will disable the timeout, resulting in IO being queued until more data space is added to the thin-pool. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Cc: stable@vger.kernel.org # 3.14+
2014-05-20Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Peter Anvin. * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86-64, modify_ldt: Make support for 16-bit segments a runtime option x86, mm, hugetlb: Add missing TLB page invalidation for hugetlb_cow() x86, rdrand: When nordrand is specified, disable RDSEED as well
2014-05-15KVM: s390: announce irqfd capabilityCornelia Huck
s390 has acquired irqfd support with commit "KVM: s390: irq routing for adapter interrupts" (84223598778ba08041f4297fda485df83414d57e) but failed to announce it. Let's fix that. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Acked-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
2014-05-13Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Seems like we've had more fixes than usual this release cycle, but there's nothing in particular that we're doing differently. Perhaps it's just one of those cycles where more people are finding more regressions (and/or that the latency of when people actually test what's been in the tree for a while is catching up so that we get the bug reports now). The bigger changes here are are for TI and Marvell platforms: * Timing changes for GPMC (generic localbus) on OMAP causing some largeish DTS deltas. * Fixes to window allocation on PCI for mvebu touching drivers/ stuff. Patches have acks from subsystem maintainers where needed. * A fix from Thomas for a botched DT conversion in drivers/edma. There's a handful of other fixes for the above platforms as well as sunxi, at91, i.MX. I also included a MAINTAINER update for Broadcom, and a trivial move of a binding doc. I know you said you'd be offline this week, but I might as well post it for when you return. :)" I'm not quite offline yet. Doing a few pulls in the last hour before my internet goes away.. * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (31 commits) MAINTAINERS: update Broadcom ARM tree location and add an SoC family ARM: dts: i.MX53: Fix ipu register space size ARM: dts: kirkwood: fix mislocated pcie-controller nodes ARM: sunxi: Enable GMAC in sunxi_defconfig ARM: common: edma: Fix xbar mapping ARM: sun7i: Fix i2c4 base address ARM: Kirkwood: T5325: Fix double probe of Codec ARM: mvebu: enable the SATA interface on Armada 375 DB ARM: mvebu: specify I2C bus frequency on Armada 370 DB ARM: mvebu: use qsgmii phy-mode for Armada XP GP interfaces ARM: mvebu: fix NOR bus-width in Armada XP OpenBlocks AX3 Device Tree ARM: mvebu: fix NOR bus-width in Armada XP DB Device Tree ARM: mvebu: fix NOR bus-width in Armada XP GP Device Tree ARM: dts: AM3517: Disable absent IPs inherited from OMAP3 ARM: dts: OMAP2: Fix interrupts for OMAP2420 mailbox ARM: dts: OMAP5: Add mailbox dt node to fix boot warning ARM: OMAP5: Switch to THUMB mode if needed on secondary CPU ARM: dts: am437x-gp-evm: Do not reset gpio5 ARM: dts: omap3-igep0020: use SMSC9221 timings PCI: mvebu: split PCIe BARs into multiple MBus windows when needed ...
2014-05-12clk: shmobile: clk-mstp: change to using clock-indicesBen Dooks
With the addition of clock-indices, we need to change the renesas clock implementation to use these instead of the local definition of "renesas,clock-indices". Since this will break booting with older device trees, we add a simple auto-detection of which properties are present. Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Reviewed-by: Wolfram Sang <wsa+renesas@sang-engineering.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-05-11x86, rdrand: When nordrand is specified, disable RDSEED as wellH. Peter Anvin
One can logically expect that when the user has specified "nordrand", the user doesn't want any use of the CPU random number generator, neither RDRAND nor RDSEED, so disable both. Reported-by: Stephan Mueller <smueller@chronox.de> Cc: Theodore Ts'o <tytso@mit.edu> Link: http://lkml.kernel.org/r/21542339.0lFnPSyGRS@myon.chronox.de Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-05-10Merge tag 'davinci-fixes-for-v3.15-rc4' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci into fixes Pull "DaVinci fixes for v3.15" from Sekhar Nori: The patch fixes EDMA crossbar mapping to actually make it work. The patch has been tagged for stable. * tag 'davinci-fixes-for-v3.15-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci: ARM: common: edma: Fix xbar mapping Signed-off-by: Olof Johansson <olof@lixom.net>
2014-05-09net: mdio-gpio: fix device-tree binding documentationJohan Hovold
Fix aliases syntax in device-tree binding example to avoid copy-paste errors (the alias would be dropped silently). Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input subsystem fixes from Dmitry Torokhov: "Just a few fixups to various drivers" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: elantech - fix touchpad initialization on Gigabyte U2442 Input: tca8418 - fix loading this driver as a module from a device tree Input: bma150 - extend chip detection for bma180 Input: atkbd - fix keyboard not working on some LG laptops Input: synaptics - add min/max quirk for ThinkPad Edge E431
2014-05-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) e1000e computes header length incorrectly wrt vlans, fix from Vlad Yasevich. 2) ns_capable() check in sock_diag netlink code, from Andrew Lutomirski. 3) Fix invalid queue pairs handling in virtio_net, from Amos Kong. 4) Checksum offloading busted in sxgbe driver due to incorrect descriptor layout, fix from Byungho An. 5) Fix build failure with SMC_DEBUG set to 2 or larger, from Zi Shen Lim. 6) Fix uninitialized A and X registers in BPF interpreter, from Alexei Starovoitov. 7) Fix arch dependencies of candence driver. 8) Fix netlink capabilities checking tree-wide, from Eric W Biederman. 9) Don't dump IFLA_VF_PORTS if netlink request didn't ask for it in IFLA_EXT_MASK, from David Gibson. 10) IPV6 FIB dump restart doesn't handle table changes that happen meanwhile, causing the code to loop forever or emit dups, fix from Kumar Sandararajan. 11) Memory leak on VF removal in bnx2x, from Yuval Mintz. 12) Bug fixes for new Altera TSE driver from Vince Bridgers. 13) Fix route lookup key in SCTP, from Xugeng Zhang. 14) Use BH blocking spinlocks in SLIP, as per a similar fix to CAN/SLCAN driver. From Oliver Hartkopp. 15) TCP doesn't bump retransmit counters in some code paths, fix from Eric Dumazet. 16) Clamp delayed_ack in tcp_cubic to prevent theoretical divides by zero. Fix from Liu Yu. 17) Fix locking imbalance in error paths of HHF packet scheduler, from John Fastabend. 18) Properly reference the transport module when vsock_core_init() runs, from Andy King. 19) Fix buffer overflow in cdc_ncm driver, from Bjørn Mork. 20) IP_ECN_decapsulate() doesn't see a correct SKB network header in ip_tunnel_rcv(), fix from Ying Cai. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (132 commits) net: macb: Fix race between HW and driver net: macb: Remove 'unlikely' optimization net: macb: Re-enable RX interrupt only when RX is done net: macb: Clear interrupt flags net: macb: Pass same size to DMA_UNMAP as used for DMA_MAP ip_tunnel: Set network header properly for IP_ECN_decapsulate() e1000e: Restrict MDIO Slow Mode workaround to relevant parts e1000e: Fix issue with link flap on 82579 e1000e: Expand workaround for 10Mb HD throughput bug e1000e: Workaround for dropped packets in Gig/100 speeds on 82579 net/mlx4_core: Don't issue PCIe speed/width checks for VFs net/mlx4_core: Load the Eth driver first net/mlx4_core: Fix slave id computation for single port VF net/mlx4_core: Adjust port number in qp_attach wrapper when detaching net: cdc_ncm: fix buffer overflow Altera TSE: ALTERA_TSE should depend on HAS_DMA vsock: Make transport the proto owner net: sched: lock imbalance in hhf qdisc net: mvmdio: Check for a valid interrupt instead of an error net phy: Check for aneg completion before setting state to PHY_RUNNING ...
2014-05-05Input: elantech - fix touchpad initialization on Gigabyte U2442Hans de Goede
The hw_version 3 Elantech touchpad on the Gigabyte U2442 does not accept 0x0b as initialization value for r10, this stand-alone version of the driver: http://planet76.com/drivers/elantech/psmouse-elantech-v6.tar.bz2 Uses 0x03 which does work, so this means not setting bit 3 of r10 which sets: "Enable Real H/W Resolution In Absolute mode" Which will result in half the x and y resolution we get with that bit set, so simply not setting it everywhere is not a solution. We've been unable to find a way to identify touchpads where setting the bit will fail, so this patch uses a dmi based blacklist for this. https://bugzilla.kernel.org/show_bug.cgi?id=61151 Cc: stable@vger.kernel.org Reported-by: Philipp Wolfer <ph.wolfer@gmail.com> Tested-by: Philipp Wolfer <ph.wolfer@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-05-04Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 fixes from Catalin Marinas: "These are mostly arm64 fixes with an additional arm(64) platform fix for the initialisation of vexpress clocks (the latter only affecting arm64; the arch/arm64 code is SoC agnostic and does not rely on early SoC-specific calls) - vexpress platform clocks initialisation moved earlier following the arm64 move of of_clk_init() call in a previous commit - Default DMA ops changed to non-coherent to preserve compatibility with 32-bit ARM DT files. The "dma-coherent" property can be used to explicitly mark a device coherent. The Applied Micro DT file has been updated to avoid DMA cache maintenance for the X-Gene SATA controller (the only arm64 related driver with such assumption in -rc mainline) - Fixmap correction for earlyprintk - kern_addr_valid() fix for huge pages" * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: vexpress: Initialise the sysregs before setting up the clocks arm64: Mark the Applied Micro X-Gene SATA controller as DMA coherent arm64: Use bus notifiers to set per-device coherent DMA ops arm64: Make default dma_ops to be noncoherent arm64: fixmap: fix missing sub-page offset for earlyprintk arm64: Fix for the arm64 kern_addr_valid() function
2014-05-03arm64: Mark the Applied Micro X-Gene SATA controller as DMA coherentCatalin Marinas
Since the default DMA ops for arm64 are non-coherent, mark the X-Gene controller explicitly as dma-coherent to avoid additional cache maintenance. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Loc Ho <lho@apm.com>
2014-05-03Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Thomas Gleixner: "This update brings along: - Two fixes for long standing bugs in the hrtimer code, one which prevents remote enqueuing and the other preventing arbitrary delays after a interrupt hang was detected - A fix in the timer wheel which prevents math overflow - A fix for a long standing issue with the architected ARM timer related to the C3STOP mechanism. - A trivial compile fix for nspire SoC clocksource" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: timer: Prevent overflow in apply_slack hrtimer: Prevent remote enqueue of leftmost timers hrtimer: Prevent all reprogramming if hang detected clocksource: nspire: Fix compiler warning clocksource: arch_arm_timer: Fix age-old arch timer C3STOP detection issue
2014-04-30Merge tag 'sound-3.15-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "A few collections of small eggs that have been gathered during the Easter holidays. Mostly small ASoC fixes, with a HD-audio quirk and a workaround for Nvidia controller" * tag 'sound-3.15-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Suppress CORBRP clear on Nvidia controller chips ALSA: hda - add headset mic detect quirk for a Dell laptop ASoC: jz4740: Remove Makefile entry for removed file ASoC: Intel: Fix audio crash due to negative address offset ASoC: dapm: Fix widget double free with auto-disable DAPM kcontrol ASoC: Intel: Fix incorrect sizeof() in sst_hsw_stream_get_volume() ASoC: Intel: some incorrect sizeof() usages ASoC: cs42l73: Convert to use devm_gpio_request_one ASoC: cs42l52: Convert to use devm_gpio_request_one ASoC: tlv320aic31xx: document that the regulators are mandatory ASoC: fsl_spdif: Fix wrong OFFSET of STC_SYSCLK_DIV ASoC: alc5623: Fix regmap endianness ASoC: tlv320aic3x: fix shared reset pin for DT ASoC: rsnd: fix clock prepare/unprepare
2014-04-29Merge branch 'clockevents/3.15-fixes' of ↵Thomas Gleixner
git://git.linaro.org/people/daniel.lezcano/linux into timers/urgent clockevent fixes for 3.15 from Daniel Lezcano: * Lorenzo Pieralizi fixed an issue with the arch_arm_timer where the C3STOP flag for all the arch can cause some trouble by setting the flag only if the power domain is not always on * Alexander Shiyan fixed a compilation by changing the init function to the right prototype
2014-04-29ARM: common: edma: Fix xbar mappingThomas Gleixner
This is another great example of trainwreck engineering: commit 2646a0e529 (ARM: edma: Add EDMA crossbar event mux support) added support for using EDMA on peripherals which have no direct EDMA event mapping. The code compiles and does not explode in your face, but that's it. 1) Reading an u16 array from an u32 device tree array simply does not work. Even if the function is named "edma_of_read_u32_to_s16_array". It merily calls of_property_read_u16_array. So the resulting 16bit array will have every other entry = 0. 2) The DT entry for the xbar registers related to xbar has length 0x10 instead of the real length: 0xfd0 - 0xf90 = 0x40. Not a real problem as it does not cross a page boundary, but wrong nevertheless. 3) But none of this matters as the mapping never happens: After reading nonsense edma_of_read_u32_to_s16_array() invalidates the first array entry pair, so nobody can ever notice the braindamage by immediate explosion. Seems the QA criteria for this code was solely not to explode when someone adds edma-xbar-event-map entries to the DT. Goal achieved, congratulations! Not really helpful if someone wants to use edma on a device which requires a xbar mapping. Fix the issues by: - annotating the device tree entry with "/bits/ 16" as documented in the of_property_read_u16_array kernel doc - make the size of the xbar register mapping correct - invalidating the end of the array and not the start This convoluted mess wants to be completely rewritten as there is no point to keep the xbar_chan array memory and the iomapping of the xbar regs around forever. Marking the xbar mapped channels as used should be done right there. But that's a different issue and this patch is small enough to make it work and allows a simple backport for stable. Cc: stable@vger.kernel.org # v3.12+ Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sekhar Nori <nsekhar@ti.com>
2014-04-29clocksource: arch_arm_timer: Fix age-old arch timer C3STOP detection issueLorenzo Pieralisi
ARM arch timers are tightly coupled with the CPU logic and lose context on platform implementing HW power management when cores are powered down at run-time. Marking the arch timers as C3STOP regardless of power management capabilities causes issues on platforms with no power management, since in that case the arch timers cannot possibly enter states where the timer loses context at runtime and therefore can always be used as a high resolution clockevent device. In order to fix the C3STOP issue in a way compliant with how real HW works, this patch adds a boolean property to the arch timer bindings to define if the arch timer is managed by an always-on power domain. This power domain is present on all ARM platforms to date, and manages HW that must not be turned off, whatever the state of other HW components (eg power controller). On platforms with no power management capabilities, it is the only power domain present, which encompasses and manages power supply for all HW components in the system. If the timer is powered by the always-on power domain, the always-on property must be present in the bindings which means that the timer cannot be shutdown at runtime, so it is not a C3STOP clockevent device. If the timer binding does not contain the always-on property, the timer is assumed to be power-gateable, hence it must be defined as a C3STOP clockevent device. Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: Magnus Damm <damm@opensource.se> Cc: Marc Carino <marc.ceeeee@gmail.com> Cc: Mark Rutland <mark.rutland@arm.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2014-04-27arc_emac: add clock handlingHeiko Stübner
This adds ability for the arc_emac to really handle its supplying clock. To get the needed clock-frequency either a real clock or the previous clock-frequency property must be provided. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Tested-by: Max Schwarz <max.schwarz@online.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-26Merge tag 'at91-fixes' of git://github.com/at91linux/linux-at91 into fixesArnd Bergmann
3.15 fixes for AT91 - one little DT fix - the use of proper directory for clock in include/dt-bindings it allows to remove the now empty include/dt-bindings/clk * tag 'at91-fixes' of git://github.com/at91linux/linux-at91: dt-bindings: clock: Move at91.h to dt-bindigs/clock ARM: at91: fix spi cs on sama5d3 Xplained board Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-04-25PCI: Update my email addressBen Hutchings
Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-04-23net: Update my email addressBen Hutchings
Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-23dt: Fix binding typos in clock-names and interrupt-namesGeert Uytterhoeven
s/interrupts-names/interrupt-names/g s/clocks-names/clock-names/g Some of the binding files and device tree files get this wrong and the kernel won't be able to pick it up. Fix them up now so that they don't get widely used. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Acked-by : Patrice Chotard <patrice.chotard@st.com> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2014-04-22Merge remote-tracking branches 'asoc/fix/intel', 'asoc/fix/jz4740', ↵Mark Brown
'asoc/fix/rcar', 'asoc/fix/tlv320aic31xx' and 'asoc/fix/tlv320aic3x' into asoc-linus
2014-04-19Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Unfortunately this contains no easter eggs, its a bit larger than I'd like, but I included a patch that just moves code from one file to another and I'd like to avoid merge conflicts with that later, so it makes it seem worse than it is, Otherwise: - radeon: fixes to use new microcode to stabilise some cards, use some common displayport code, some runtime pm fixes, pll regression fixes - i915: fix for some context oopses, a warn in a used path, backlight fixes - nouveau: regression fix - omap: a bunch of fixes" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (51 commits) drm: bochs: drop unused struct fields drm: bochs: add power management support drm: cirrus: add power management support drm: Split out drm_probe_helper.c from drm_crtc_helper.c drm/plane-helper: Don't fake-implement primary plane disabling drm/ast: fix value check in cbr_scan2 drm/nouveau/bios: fix a bit shift error introduced by 457e77b drm/radeon/ci: make sure mc ucode is loaded before checking the size drm/radeon/si: make sure mc ucode is loaded before checking the size drm/radeon: improve PLL params if we don't match exactly v2 drm/radeon: memory leak on bo reservation failure. v2 drm/radeon: fix VCE fence command drm/radeon: re-enable mclk dpm on R7 260X asics drm/radeon: add support for newer mc ucode on CI (v2) drm/radeon: add support for newer mc ucode on SI (v2) drm/radeon: apply more strict limits for PLL params v2 drm/radeon: update CI DPM powertune settings drm/radeon: fix runpm handling on APUs (v4) drm/radeon: disable mclk dpm on R7 260X drm/tegra: Remove gratuitous pad field ...
2014-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull more networking fixes from David Miller: 1) Fix mlx4_en_netpoll implementation, it needs to schedule a NAPI context, not synchronize it. From Chris Mason. 2) Ipv4 flow input interface should never be zero, it should be LOOPBACK_IFINDEX instead. From Cong Wang and Julian Anastasov. 3) Properly configure MAC to PHY connection in mvneta devices, from Thomas Petazzoni. 4) sys_recv should use SYSCALL_DEFINE. From Jan Glauber. 5) Tunnel driver ioctls do not use the correct namespace, fix from Nicolas Dichtel. 6) Fix memory leak on seccomp filter attach, from Kees Cook. 7) Fix lockdep warning for nested vlans, from Ding Tianhong. 8) Crashes can happen in SCTP due to how the auth_enable value is managed, fix from Vlad Yasevich. 9) Wireless fixes from John W Linville and co. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (45 commits) net: sctp: cache auth_enable per endpoint tg3: update rx_jumbo_pending ring param only when jumbo frames are enabled vlan: Fix lockdep warning when vlan dev handle notification seccomp: fix memory leak on filter attach isdn: icn: buffer overflow in icn_command() ip6_tunnel: use the right netns in ioctl handler sit: use the right netns in ioctl handler ip_tunnel: use the right netns in ioctl handler net: use SYSCALL_DEFINEx for sys_recv net: mdio-gpio: Add support for separate MDI and MDO gpio pins net: mdio-gpio: Add support for active low gpio pins net: mdio-gpio: Use devm_ functions where possible ipv4, route: pass 0 instead of LOOPBACK_IFINDEX to fib_validate_source() ipv4, fib: pass LOOPBACK_IFINDEX instead of 0 to flowi4_iif mlx4_en: don't use napi_synchronize inside mlx4_en_netpoll net: mvneta: properly configure the MAC <-> PHY connection in all situations net: phy: add minimal support for QSGMII PHY sfc:On MCDI timeout, issue an FLR (and mark MCDI to fail-fast) mwifiex: fix hung task on command timeout mwifiex: process event before command response ...
2014-04-18Merge tag 'driver-core-3.15-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core fixes from Greg KH: "Here are some driver core fixes for 3.15-rc2. Also in here are some documentation updates, as well as an API removal that had to wait for after -rc1 due to the cleanups coming into you from multiple developer trees (this one and the PPC tree.) All have been in linux next successfully" * tag 'driver-core-3.15-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: drivers/base/dd.c incorrect pr_debug() parameters Documentation: Update stable address in Chinese and Japanese translations topology: Fix compilation warning when not in SMP Chinese: add translation of io_ordering.txt stable_kernel_rules: spelling/word usage sysfs, driver-core: remove unused {sysfs|device}_schedule_callback_owner() kernfs: protect lazy kernfs_iattrs allocation with mutex fs: Don't return 0 from get_anon_bdev
2014-04-18Merge tag 'tty-3.15-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial driver fixes from Greg KH: "Here are a number of small tty/serial driver fixes for 3.15-rc2. Also in here are some Documentation file removals for drivers that we removed a long time ago, no need to keep it around any longer. All of these have been in linux-next for a bit" * tag 'tty-3.15-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: Revert "serial: 8250, disable "too much work" messages" serial: amba-pl011: fix regression, causing an Oops on rmmod tty: Fix help text of SYNCLINK_CS tty: fix memleak in alloc_pid ttyprintk: Allow built as a module ttyprintk: Fix wrong tty_unregister_driver() call in the error path serial: 8250, disable "too much work" messages Documentation/serial: Delete obsolete driver documentation serial: omap: Fix missing pm_runtime_resume handling by simplifying code serial_core: Fix pm imbalance on unbind serial: pl011: change Rx burst size to half of trigger level serial: timberdale: Depend on X86_32 serial: st-asc: Fix SysRq char handling Revert "serial: clps711x: Give a chance to perform useful tasks during wait loop" serial_core: Fix conditional start_tx on ring buffer not empty serial: efm32: use $vendor,$device scheme for compatible string serial: omap: free the wakeup settings in remove
2014-04-18Documentation/vm/numa_memory_policy.txt: fix wrong document in ↵Tang Chen
numa_memory_policy.txt In document numa_memory_policy.txt, the following examples for flag MPOL_F_RELATIVE_NODES are incorrect. For example, consider a task that is attached to a cpuset with mems 2-5 that sets an Interleave policy over the same set with MPOL_F_RELATIVE_NODES. If the cpuset's mems change to 3-7, the interleave now occurs over nodes 3,5-6. If the cpuset's mems then change to 0,2-3,5, then the interleave occurs over nodes 0,3,5. According to the comment of the patch adding flag MPOL_F_RELATIVE_NODES, the nodemasks the user specifies should be considered relative to the current task's mems_allowed. (https://lkml.org/lkml/2008/2/29/428) And according to numa_memory_policy.txt, if the user's nodemask includes nodes that are outside the range of the new set of allowed nodes, then the remap wraps around to the beginning of the nodemask and, if not already set, sets the node in the mempolicy nodemask. So in the example, if the user specifies 2-5, for a task whose mems_allowed is 3-7, the nodemasks should be remapped the third, fourth, fifth, sixth node in mems_allowed. like the following: mems_allowed: 3 4 5 6 7 relative index: 0 1 2 3 4 5 So the nodemasks should be remapped to 3,5-7, but not 3,5-6. And for a task whose mems_allowed is 0,2-3,5, the nodemasks should be remapped to 0,2-3,5, but not 0,3,5. mems_allowed: 0 2 3 5 relative index: 0 1 2 3 4 5 Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Cc: Randy Dunlap <rdunlap@infradead.org> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-18dt-bindings: clock: Move at91.h to dt-bindigs/clockTushar Behera
Most of the clock related dt-binding header files are located in dt-bindings/clock folder. It would be good to keep all the similar header files at a single location. Signed-off-by: Tushar Behera <tushar.behera@linaro.org> CC: Rob Landley <rob@landley.net> CC: Andrew Victor <linux@maxim.org.za> CC: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Acked-by: Boris BREZILLON <b.brezillon.dev@gmail.com> [nicolas.ferre@atmel.com: add new at91sam9261 & at91sam9rl] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-04-18Merge tag 'dt-fixes-for-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree fixes from Rob Herring: - fix error handling in of_update_property - fix section mismatch warnings in __reserved_mem_check_root - add empty of_find_node_by_path for !OF builds - add various missing binding documentation * tag 'dt-fixes-for-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: of: add empty of_find_node_by_path() for !OF of: Clean up of_update_property DT: add vendor prefix for EBV Elektronik of: Fix the section mismatch warnings. of: Add vendor prefix for Digi International Inc. DT: I2C: Add trivial bindings used by kirkwood boards DT: Vendor: Add prefixes used by Kirkwood devices DT: bindings: add missing Marvell Kirkwood SoC documentation dt-bindings: add vendor-prefix for Newhaven Display of: add vendor prefix for I2SE GmbH of: add vendor prefix for ISEE 2007 S.L.
2014-04-18ASoC: tlv320aic31xx: document that the regulators are mandatoryAlexandre Belloni
The driver will not probe if regulators are not provided. Move the regulator properties to the required section. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-04-18drm: Split out drm_probe_helper.c from drm_crtc_helper.cDaniel Vetter
This is leftover stuff from my previous doc round which I kinda wanted to do but didn't yet due to rebase hell. The modeset helpers and the probing helpers a independent and e.g. i915 uses the probing stuff but has its own modeset infrastructure. It hence makes to split this up. While at it add a DOC: comment for the probing libraray. It would be rather neat to pull some of the DocBook documenting these two helpers into in-line DOC: comments. But unfortunately kerneldoc doesn't support markdown or something similar to make nice-looking documentation, so the current state is better. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-04-17Merge tag 'fbdev-reorder-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux Pull fbdev renaming patches from Tomi Valkeinen: "Reorder drivers/video/ directory so that all fbdev drivers are now located in drivers/video/fbdev/ and the fbdev framework core files are located in drivers/video/fbdev/core/ The drivers/video/Kconfig is modified so that the DRM and the fbdev menu options are in separate submenus, instead of both being mixed in the same 'Graphics support' menu level" * tag 'fbdev-reorder-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: video: Kconfig: move drm and fb into separate menus fbdev: move fbdev core files to separate directory video: move fbdev to drivers/video/fbdev
