path: root/Documentation
2013-02-27Documentation/cgroups/blkio-controller.txt: fix typoWarren Turkal
Signed-off-by: Warren Turkal <wt@ooyala.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27Documentation/DMA-API-HOWTO.txt: minor grammar correctionsShuah Khan
Signed-off-by: Shuah Khan <shuah.khan@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-26Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c updates from Wolfram Sang: "Highlights: - new drivers for Intel ismt & Broadcom bcm2835 - a number of drivers got support for more variants and mostly got cleaned up on the way (sis630, i801, at91, tegra, designware) - i2c got rid of all *_set_drvdata(..., NULL) on remove/probe failure - removed the i2c_smbus_process_call from the core since there are no users - mxs can now switch between PIO and DMA depending on the message size and the bus speed can now be arbitrary In addition, there is the usual bunch of fixes, cleanups, devm_* conversions, etc" Fixed conflict (and buggy devm_* conversion) in i2c-s3c2410.c * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (39 commits) i2c: Remove unneeded xxx_set_drvdata(..., NULL) calls i2c: pxa: remove incorrect __exit annotations i2c: ocores: Fix pointer to integer cast warning i2c: tegra: remove warning dump if timeout happen in transfer i2c: fix i2c-ismt.c printk format warning i2c: i801: Add Device IDs for Intel Wellsburg PCH i2c: add bcm2835 driver i2c: ismt: Add Seth and Myself as maintainers i2c: sis630: checkpatch cleanup i2c: sis630: display unsigned hex i2c: sis630: use hex to constants for SMBus commands i2c: sis630: fix behavior after collision i2c: sis630: clear sticky bits i2c: sis630: Add SIS964 support i2c: isch: Add module parameter for backbone clock rate if divider is unset i2c: at91: fix unsed variable warning when building with !CONFIG_OF i2c: Adding support for Intel iSMT SMBus 2.0 host controller i2c: sh_mobile: don't send a stop condition by default inside transfers i2c: sh_mobile: eliminate an open-coded "goto" loop i2c: sh_mobile: fix timeout error handling ...
2013-02-26Merge tag 'for-3.9-rc1' of git://gitorious.org/linux-pwm/linux-pwmLinus Torvalds
Pull PWM changes from Thierry Reding: "A new driver has been added to support the PWM mode of the timer counter blocks found on Atmel AT91 SoCs. The VT8500 driver now supports changing the PWM signal polarity and the TI drivers (EHRPWM and ECAP) gained suspend and resume functionality. User drivers can now query the core for whether access to a PWM device will sleep (if the PWM chip is on a slow bus such as I2C or SPI). The pwm-backlight driver now handles the backlight BL_CORE_FBBLANK state in addition to the FB layer's blanking states. To round things off, a few fixes and cleanups are also included" * tag 'for-3.9-rc1' of git://gitorious.org/linux-pwm/linux-pwm: pwm: twl: Use to_twl() instead of container_of() pwm: tegra: assume CONFIG_OF pwm_backlight: Validate dft_brightness in main probe function pwm: Export pwm_{set,get}_chip_data() pwm: Make Kconfig entries more consistent pwm: Add can_sleep property to drivers pwm: Add pwm_can_sleep() as exported API to users pwm-backlight: handle BL_CORE_FBBLANK state pwm: pwm-tiecap: Low power sleep support pwm: pwm-tiehrpwm: Low power sleep support pwm: pwm-tiehrpwm: Update the clock handling of pwm-tiehrpwm driver pwm: vt8500: Add polarity support pwm: vt8500: Register write busy test performed incorrectly pwm: atmel: add Timer Counter Block PWM driver
2013-02-26Merge tag 'mmc-updates-for-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc Pull MMC update from Chris Ball: "MMC highlights for 3.9: Core: - Support for packed commands in eMMC 4.5. (This requires a host capability to be turned on. It increases write throughput by 20%+, but may also increase average write latency; more testing needed.) - Add DT bindings for capability flags. - Add mmc_of_parse() for shared DT parsing between drivers. Drivers: - android-goldfish: New MMC driver for the Android Goldfish emulator. - mvsdio: Add DT bindings, pinctrl, use slot-gpio for card detection. - omap_hsmmc: Fix boot hangs with RPMB partitions. - sdhci-bcm2835: New driver for controller used by Raspberry Pi. - sdhci-esdhc-imx: Add 8-bit data, auto CMD23 support, use slot-gpio. - sh_mmcif: Add support for eMMC DDR, bundled MMCIF IRQs. - tmio_mmc: Add DT bindings, support for vccq regulator" * tag 'mmc-updates-for-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (92 commits) mmc: tegra: assume CONFIG_OF, remove platform data mmc: add DT bindings for more MMC capability flags mmc: tmio: add support for the VccQ regulator mmc: tmio: remove unused and deprecated symbols mmc: sh_mobile_sdhi: use managed resource allocations mmc: sh_mobile_sdhi: remove unused .pdata field mmc: tmio-mmc: parse device-tree bindings mmc: tmio-mmc: define device-tree bindings mmc: sh_mmcif: use mmc_of_parse() to parse standard MMC DT bindings mmc: (cosmetic) remove "extern" from function declarations mmc: provide a standard MMC device-tree binding parser centrally mmc: detailed definition of CD and WP MMC line polarities in DT mmc: sdhi, tmio: only check flags in tmio-mmc driver proper mmc: sdhci: Fix parameter of sdhci_do_start_signal_voltage_switch() mmc: sdhci: check voltage range only on regulators aware of voltage value mmc: bcm2835: set SDHCI_QUIRK_DATA_TIMEOUT_USES_SDCLK mmc: support packed write command for eMMC4.5 devices mmc: add packed command feature of eMMC4.5 mmc: rtsx: remove driving adjustment mmc: use regulator_can_change_voltage() instead of regulator_count_voltages ...
2013-02-26Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds Pull LED subsystem update from Bryan Wu. * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: (61 commits) leds: leds-sunfire: use dev_err()/pr_err() instead of printk() leds: 88pm860x: Add missing of_node_put() leds: tca6507: Use of_get_child_count() leds: leds-pwm: make it depend on PWM and not HAVE_PWM Documentation: leds: update LP55xx family devices leds-lp55xx: fix problem on removing LED attributes leds-lp5521/5523: add author and copyright description leds-lp5521/5523: use new lp55xx common header leds-lp55xx: clean up headers leds-lp55xx: clean up definitions leds-lp55xx: clean up unused data and functions leds-lp55xx: clean up _remove() leds-lp55xx: add new function for removing device attribtues leds-lp55xx: code refactoring on selftest function leds-lp55xx: use common device attribute driver function leds-lp55xx: support device specific attributes leds-lp5523: use generic firmware interface leds-lp5521: use generic firmware interface leds-lp55xx: support firmware interface leds-lp55xx: add new lp55xx_register_sysfs() for the firmware interface ...
2013-02-26Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine updates from Vinod Koul: "This is fairly big pull by my standards as I had missed last merge window. So we have the support for device tree for slave-dmaengine, large updates to dw_dmac driver from Andy for reusing on different architectures. Along with this we have fixes on bunch of the drivers" Fix up trivial conflicts, usually due to #include line movement next to each other. * 'next' of git://git.infradead.org/users/vkoul/slave-dma: (111 commits) Revert "ARM: SPEAr13xx: Pass DW DMAC platform data from DT" ARM: dts: pl330: Add #dma-cells for generic dma binding support DMA: PL330: Register the DMA controller with the generic DMA helpers DMA: PL330: Add xlate function DMA: PL330: Add new pl330 filter for DT case. dma: tegra20-apb-dma: remove unnecessary assignment edma: do not waste memory for dma_mask dma: coh901318: set residue only if dma is in progress dma: coh901318: avoid unbalanced locking dmaengine.h: remove redundant else keyword dma: of-dma: protect list write operation by spin_lock dmaengine: ste_dma40: do not remove descriptors for cyclic transfers dma: of-dma.c: fix memory leakage dw_dmac: apply default dma_mask if needed dmaengine: ioat - fix spare sparse complain dmaengine: move drivers/of/dma.c -> drivers/dma/of-dma.c ioatdma: fix race between updating ioat->head and IOAT_COMPLETION_PENDING dw_dmac: add support for Lynxpoint DMA controllers dw_dmac: return proper residue value dw_dmac: fill individual length of descriptor ...
2013-02-26vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry opJeff Layton
The following set of operations on a NFS client and server will cause server# mkdir a client# cd a server# mv a a.bak client# sleep 30 # (or whatever the dir attrcache timeout is) client# stat . stat: cannot stat `.': Stale NFS file handle Obviously, we should not be getting an ESTALE error back there since the inode still exists on the server. The problem is that the lookup code will call d_revalidate on the dentry that "." refers to, because NFS has FS_REVAL_DOT set. nfs_lookup_revalidate will see that the parent directory has changed and will try to reverify the dentry by redoing a LOOKUP. That of course fails, so the lookup code returns ESTALE. The problem here is that d_revalidate is really a bad fit for this case. What we really want to know at this point is whether the inode is still good or not, but we don't really care what name it goes by or whether the dcache is still valid. Add a new d_op->d_weak_revalidate operation and have complete_walk call that instead of d_revalidate. The intent there is to allow for a "weaker" d_revalidate that just checks to see whether the inode is still good. This is also gives us an opportunity to kill off the FS_REVAL_DOT special casing. [AV: changed method name, added note in porting, fixed confusion re having it possibly called from RCU mode (it won't be)] Cc: NeilBrown <neilb@suse.de> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-25Merge tag 'pci-v3.9-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI changes from Bjorn Helgaas: "Host bridge hotplug - Major overhaul of ACPI host bridge add/start (Rafael Wysocki, Yinghai Lu) - Major overhaul of PCI/ACPI binding (Rafael Wysocki, Yinghai Lu) - Split out ACPI host bridge and ACPI PCI device hotplug (Yinghai Lu) - Stop caching _PRT and make independent of bus numbers (Yinghai Lu) PCI device hotplug - Clean up cpqphp dead code (Sasha Levin) - Disable ARI unless device and upstream bridge support it (Yijing Wang) - Initialize all hot-added devices (not functions 0-7) (Yijing Wang) Power management - Don't touch ASPM if disabled (Joe Lawrence) - Fix ASPM link state management (Myron Stowe) Miscellaneous - Fix PCI_EXP_FLAGS accessor (Alex Williamson) - Disable Bus Master in pci_device_shutdown (Konstantin Khlebnikov) - Document hotplug resource and MPS parameters (Yijing Wang) - Add accessor for PCIe capabilities (Myron Stowe) - Drop pciehp suspend/resume messages (Paul Bolle) - Make pci_slot built-in only (not a module) (Jiang Liu) - Remove unused PCI/ACPI bind ops (Jiang Liu) - Removed used pci_root_bus (Bjorn Helgaas)" * tag 'pci-v3.9-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (51 commits) PCI/ACPI: Don't cache _PRT, and don't associate them with bus numbers PCI: Fix PCI Express Capability accessors for PCI_EXP_FLAGS ACPI / PCI: Make pci_slot built-in only, not a module PCI/PM: Clear state_saved during suspend PCI: Use atomic_inc_return() rather than atomic_add_return() PCI: Catch attempts to disable already-disabled devices PCI: Disable Bus Master unconditionally in pci_device_shutdown() PCI: acpiphp: Remove dead code for PCI host bridge hotplug PCI: acpiphp: Create companion ACPI devices before creating PCI devices PCI: Remove unused "rc" in virtfn_add_bus() PCI: pciehp: Drop suspend/resume ENTRY messages PCI/ASPM: Don't touch ASPM if forcibly disabled PCI/ASPM: Deallocate upstream link state even if device is not PCIe PCI: Document MPS parameters pci=pcie_bus_safe, pci=pcie_bus_perf, etc PCI: Document hpiosize= and hpmemsize= resource reservation parameters PCI: Use PCI Express Capability accessor PCI: Introduce accessor to retrieve PCIe Capabilities Register PCI: Put pci_dev in device tree as early as possible PCI: Skip attaching driver in device_add() PCI: acpiphp: Keep driver loaded even if no slots found ...
2013-02-25Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm merge from Dave Airlie: "Highlights: - TI LCD controller KMS driver - TI OMAP KMS driver merged from staging - drop gma500 stub driver - the fbcon locking fixes - the vgacon dirty like zebra fix. - open firmware videomode and hdmi common code helpers - major locking rework for kms object handling - pageflip/cursor won't block on polling anymore! - fbcon helper and prime helper cleanups - i915: all over the map, haswell power well enhancements, valleyview macro horrors cleaned up, killing lots of legacy GTT code, - radeon: CS ioctl unification, deprecated UMS support, gpu reset rework, VM fixes - nouveau: reworked thermal code, external dp/tmds encoder support (anx9805), fences sleep instead of polling, - exynos: all over the driver fixes." Lovely conflict in radeon/evergreen_cs.c between commit de0babd60d8d ("drm/radeon: enforce use of radeon_get_ib_value when reading user cmd") and the new changes that modified that evergreen_dma_cs_parse() function. * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (508 commits) drm/tilcdc: only build on arm drm/i915: Revert hdmi HDP pin checks drm/tegra: Add list of framebuffers to debugfs drm/tegra: Fix color expansion drm/tegra: Split DC_CMD_STATE_CONTROL register write drm/tegra: Implement page-flipping support drm/tegra: Implement VBLANK support drm/tegra: Implement .mode_set_base() drm/tegra: Add plane support drm/tegra: Remove bogus tegra_framebuffer structure drm: Add consistency check for page-flipping drm/radeon: Use generic HDMI infoframe helpers drm/tegra: Use generic HDMI infoframe helpers drm: Add EDID helper documentation drm: Add HDMI infoframe helpers video: Add generic HDMI infoframe helpers drm: Add some missing forward declarations drm: Move mode tables to drm_edid.c drm: Remove duplicate drm_mode_cea_vic() gma500: Fix n, m1 and m2 clock limits for sdvo and lvds ...
2013-02-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace and namespace infrastructure changes from Eric W Biederman: "This set of changes starts with a few small enhnacements to the user namespace. reboot support, allowing more arbitrary mappings, and support for mounting devpts, ramfs, tmpfs, and mqueuefs as just the user namespace root. I do my best to document that if you care about limiting your unprivileged users that when you have the user namespace support enabled you will need to enable memory control groups. There is a minor bug fix to prevent overflowing the stack if someone creates way too many user namespaces. The bulk of the changes are a continuation of the kuid/kgid push down work through the filesystems. These changes make using uids and gids typesafe which ensures that these filesystems are safe to use when multiple user namespaces are in use. The filesystems converted for 3.9 are ceph, 9p, afs, ocfs2, gfs2, ncpfs, nfs, nfsd, and cifs. The changes for these filesystems were a little more involved so I split the changes into smaller hopefully obviously correct changes. XFS is the only filesystem that remains. I was hoping I could get that in this release so that user namespace support would be enabled with an allyesconfig or an allmodconfig but it looks like the xfs changes need another couple of days before it they are ready." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (93 commits) cifs: Enable building with user namespaces enabled. cifs: Convert struct cifs_ses to use a kuid_t and a kgid_t cifs: Convert struct cifs_sb_info to use kuids and kgids cifs: Modify struct smb_vol to use kuids and kgids cifs: Convert struct cifsFileInfo to use a kuid cifs: Convert struct cifs_fattr to use kuid and kgids cifs: Convert struct tcon_link to use a kuid. cifs: Modify struct cifs_unix_set_info_args to hold a kuid_t and a kgid_t cifs: Convert from a kuid before printing current_fsuid cifs: Use kuids and kgids SID to uid/gid mapping cifs: Pass GLOBAL_ROOT_UID and GLOBAL_ROOT_GID to keyring_alloc cifs: Use BUILD_BUG_ON to validate uids and gids are the same size cifs: Override unmappable incoming uids and gids nfsd: Enable building with user namespaces enabled. nfsd: Properly compare and initialize kuids and kgids nfsd: Store ex_anon_uid and ex_anon_gid as kuids and kgids nfsd: Modify nfsd4_cb_sec to use kuids and kgids nfsd: Handle kuids and kgids in the nfs4acl to posix_acl conversion nfsd: Convert nfsxdr to use kuids and kgids nfsd: Convert nfs3xdr to use kuids and kgids ...
2013-02-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: "Here is the crypto update for 3.9: - Added accelerated implementation of crc32 using pclmulqdq. - Added test vector for fcrypt. - Added support for OMAP4/AM33XX cipher and hash. - Fixed loose crypto_user input checks. - Misc fixes" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (43 commits) crypto: user - ensure user supplied strings are nul-terminated crypto: user - fix empty string test in report API crypto: user - fix info leaks in report API crypto: caam - Added property fsl,sec-era in SEC4.0 device tree binding. crypto: use ERR_CAST crypto: atmel-aes - adjust duplicate test crypto: crc32-pclmul - Kill warning on x86-32 crypto: x86/twofish - assembler clean-ups: use ENTRY/ENDPROC, localize jump labels crypto: x86/sha1 - assembler clean-ups: use ENTRY/ENDPROC crypto: x86/serpent - use ENTRY/ENDPROC for assember functions and localize jump targets crypto: x86/salsa20 - assembler cleanup, use ENTRY/ENDPROC for assember functions and rename ECRYPT_* to salsa20_* crypto: x86/ghash - assembler clean-up: use ENDPROC at end of assember functions crypto: x86/crc32c - assembler clean-up: use ENTRY/ENDPROC crypto: cast6-avx: use ENTRY()/ENDPROC() for assembler functions crypto: cast5-avx: use ENTRY()/ENDPROC() for assembler functions and localize jump targets crypto: camellia-x86_64/aes-ni: use ENTRY()/ENDPROC() for assembler functions and localize jump targets crypto: blowfish-x86_64: use ENTRY()/ENDPROC() for assembler functions and localize jump targets crypto: aesni-intel - add ENDPROC statements for assembler functions crypto: x86/aes - assembler clean-ups: use ENTRY/ENDPROC, localize jump targets crypto: testmgr - add test vector for fcrypt ...
2013-02-24Merge tag 'mfd-3.9-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFS updates from Samuel Ortiz: "This is the MFD pull request for the 3.9 merge window. No new drivers this time, but a bunch of fairly big cleanups: - Roger Quadros worked on a OMAP USBHS and TLL platform data consolidation, OMAP5 support and clock management code cleanup. - The first step of a major sync for the ab8500 driver from Lee Jones. In particular, the debugfs and the sysct interfaces got extended and improved. - Peter Ujfalusi sent a nice patchset for cleaning and fixing the twl-core driver, with a much needed module id lookup code improvement. - The regular wm5102 and arizona cleanups and fixes from Mark Brown. - Laxman Dewangan extended the palmas APIs in order to implement the palmas GPIO and rt drivers. - Laxman also added DT support for the tps65090 driver. - The Intel SCH and ICH drivers got a couple fixes from Aaron Sierra and Darren Hart. - Linus Walleij patchset for the ab8500 driver allowed ab8500 and ab9540 based devices to switch to the new abx500 pin-ctrl driver. - The max8925 now has device tree and irqdomain support thanks to Qing Xu. - The recently added rtsx driver got a few cleanups and fixes for a better card detection code path and now also supports the RTS5227 chipset, thanks to Wei Wang and Roger Tseng." * tag 'mfd-3.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (109 commits) mfd: lpc_ich: Use devres API to allocate private data mfd: lpc_ich: Add Device IDs for Intel Wellsburg PCH mfd: lpc_sch: Accomodate partial population of the MFD devices mfd: da9052-i2c: Staticize da9052_i2c_fix() mfd: syscon: Fix sparse warning mfd: twl-core: Fix kernel panic on boot mfd: rtsx: Fix issue that booting OS with SD card inserted mfd: ab8500: Fix compile error mfd: Add missing GENERIC_HARDIRQS dependecies Documentation: Add docs for max8925 dt mfd: max8925: Add dts mfd: max8925: Support dt for backlight mfd: max8925: Fix onkey driver irq base mfd: max8925: Fix mfd device register failure mfd: max8925: Add irqdomain for dt mfd: vexpress: Allow vexpress-sysreg to self-initialise mfd: rtsx: Support RTS5227 mfd: rtsx: Implement driving adjustment to device-dependent callbacks mfd: vexpress: Add pseudo-GPIO based LEDs mfd: ab8500: Rename ab8500 to abx500 for hwmon driver ...
2013-02-24Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - Some cleanups at V4L2 documentation - new drivers: ts2020 frontend, ov9650 sensor, s5c73m3 sensor, sh-mobile veu mem2mem driver, radio-ma901, davinci_vpfe staging driver - Lots of missing MAINTAINERS entries added - several em28xx driver improvements, including its conversion to videobuf2 - several fixups on drivers to make them to better comply with the API - DVB core: add support for DVBv5 stats, allowing the implementation of statistics for new standards like ISDB - mb86a20s: add statistics to the driver - lots of new board additions, cleanups, and driver improvements. * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (596 commits) [media] media: Add 0x3009 USB PID to ttusb2 driver (fixed diff) [media] rtl28xxu: Add USB IDs for Compro VideoMate U620F [media] em28xx: add usb id for terratec h5 rev. 3 [media] media: rc: gpio-ir-recv: add support for device tree parsing [media] mceusb: move check earlier to make smatch happy [media] radio-si470x doc: add info about v4l2-ctl and sox+alsa [media] staging: media: Remove unnecessary OOM messages [media] sh_vou: Use vou_dev instead of vou_file wherever possible [media] sh_vou: Use video_drvdata() [media] drivers/media/platform/soc_camera/pxa_camera.c: use devm_ functions [media] mt9t112: mt9t111 format set up differs from mt9t112 [media] sh-mobile-ceu-camera: fix SHARPNESS control default Revert "[media] fc0011: Return early, if the frequency is already tuned" [media] cx18/ivtv: fix regression: remove __init from a non-init function [media] em28xx: fix analog streaming with USB bulk transfers [media] stv0900: remove unnecessary null pointer check [media] fc0011: Return early, if the frequency is already tuned [media] fc0011: Add some sanity checks and cleanups [media] fc0011: Fix xin value clamping Revert "[media] [PATH,1/2] mxl5007 move reset to attach" ...
2013-02-24Merge tag 'kvm-3.9-1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Marcelo Tosatti: "KVM updates for the 3.9 merge window, including x86 real mode emulation fixes, stronger memory slot interface restrictions, mmu_lock spinlock hold time reduction, improved handling of large page faults on shadow, initial APICv HW acceleration support, s390 channel IO based virtio, amongst others" * tag 'kvm-3.9-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (143 commits) Revert "KVM: MMU: lazily drop large spte" x86: pvclock kvm: align allocation size to page size KVM: nVMX: Remove redundant get_vmcs12 from nested_vmx_exit_handled_msr x86 emulator: fix parity calculation for AAD instruction KVM: PPC: BookE: Handle alignment interrupts booke: Added DBCR4 SPR number KVM: PPC: booke: Allow multiple exception types KVM: PPC: booke: use vcpu reference from thread_struct KVM: Remove user_alloc from struct kvm_memory_slot KVM: VMX: disable apicv by default KVM: s390: Fix handling of iscs. KVM: MMU: cleanup __direct_map KVM: MMU: remove pt_access in mmu_set_spte KVM: MMU: cleanup mapping-level KVM: MMU: lazily drop large spte KVM: VMX: cleanup vmx_set_cr0(). KVM: VMX: add missing exit names to VMX_EXIT_REASONS array KVM: VMX: disable SMEP feature when guest is in non-paging mode KVM: Remove duplicate text in api.txt Revert "KVM: MMU: split kvm_mmu_free_page" ...
2013-02-24mmc: add DT bindings for more MMC capability flagsGuennadi Liakhovetski
Many MMC capability flags are platform-dependent and are traditionally set in platform data. With DT often each such capability requires a special binding. Add bindings for MMC_CAP_SD_HIGHSPEED, MMC_CAP_MMC_HIGHSPEED, MMC_CAP_POWER_OFF_CARD and MMC_CAP_SDIO_IRQ capabilities. Also add code to DT parser to look up "keep-power-in-suspend" and "enable-sdio-wakeup" bindings and set MMC_PM_KEEP_POWER and MMC_PM_WAKE_SDIO_IRQ respectively, if found. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-02-24mmc: tmio-mmc: define device-tree bindingsGuennadi Liakhovetski
Define device-tree bindings for the tmio-mmc driver to be able to specify parameters, currently provided in platform data. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-02-24mmc: detailed definition of CD and WP MMC line polarities in DTGuennadi Liakhovetski
Clarify ways to specify write-protect and card-detect MMC lines in FDT. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-02-24mmc: dt: bus-width can be an optional propertyShawn Guo
None of mmc drivers implements bus-width as a required device tree property. Instead, some drivers like atmel-mci, dw_mmc, sdhci-s3c implement it as an optional one, and will force bus width to be 1 when the property is absent. Let's change the common binding to reflect what the drivers are usually doing. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-02-24mmc: fix DT binding documentation SDHCI left-overGuennadi Liakhovetski
The file Documentation/devicetree/bindings/mmc/mmc.txt is common for all MMC host drivers. Use a generic MMC host reference instead of an SDHCI left-over. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-02-24mmc: dw_mmc: Add "disable-wp" device tree propertyDoug Anderson
The "disable-wp" property is used to specify that a given SD card slot doesn't have a concept of write protect. This eliminates the need for special case code for SD slots that should never be write protected (like a micro SD slot or a dev board). The dw_mmc driver is special in needing to specify "disable-wp" because the lack of a "wp-gpios" property means to use the special purpose write protect line. On some other mmc devices the lack of "wp-gpios" means that write protect should be disabled. Signed-off-by: Doug Anderson <dianders@chromium.org> Acked-by: Seungwon Jeon <tgih.jun@samsung.com> Acked-by: Will Newton <will.newton@imgtec.com> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-02-24Merge branch 'drm/hdmi-for-3.9' of git://anongit.freedesktop.org/tegra/linux ↵Dave Airlie
into drm-next Thierry writes: "Remove a duplicate implementation of the CEA VIC lookup and move the CEA and other mode tables to drm_edid.c to make it more difficult to create duplicates of the tables. Add some helpers to pack CEA-861/HDMI AVI, audio and SPD infoframes into binary buffers that can easily be written into hardware registers. A new helper function makes it easy construct an AVI infoframe from a DRM display mode. Convert the Tegra and Radeon drivers to use the new HDMI helpers." * 'drm/hdmi-for-3.9' of git://anongit.freedesktop.org/tegra/linux: drm/radeon: Use generic HDMI infoframe helpers drm/tegra: Use generic HDMI infoframe helpers drm: Add EDID helper documentation drm: Add HDMI infoframe helpers video: Add generic HDMI infoframe helpers drm: Add some missing forward declarations drm: Move mode tables to drm_edid.c drm: Remove duplicate drm_mode_cea_vic()
2013-02-23Merge branch 'akpm' (more incoming from Andrew)Linus Torvalds
Merge second patch-bomb from Andrew Morton: - A little DM fix - the MM queue * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (154 commits) ksm: allocate roots when needed mm: cleanup "swapcache" in do_swap_page mm,ksm: swapoff might need to copy mm,ksm: FOLL_MIGRATION do migration_entry_wait ksm: shrink 32-bit rmap_item back to 32 bytes ksm: treat unstable nid like in stable tree ksm: add some comments tmpfs: fix mempolicy object leaks tmpfs: fix use-after-free of mempolicy object mm/fadvise.c: drain all pagevecs if POSIX_FADV_DONTNEED fails to discard all pages mm: export mmu notifier invalidates mm: accelerate mm_populate() treatment of THP pages mm: use long type for page counts in mm_populate() and get_user_pages() mm: accurately document nr_free_*_pages functions with code comments HWPOISON: change order of error_states[]'s elements HWPOISON: fix misjudgement of page_action() for errors on mlocked pages memcg: stop warning on memcg_propagate_kmem net: change type of virtio_chan->p9_max_pages vmscan: change type of vm_total_pages to unsigned long fs/nfsd: change type of max_delegations, nfsd_drc_max_mem and nfsd_drc_mem_used ...
2013-02-23ksm: add some commentsHugh Dickins
Added slightly more detail to the Documentation of merge_across_nodes, a few comments in areas indicated by review, and renamed get_ksm_page()'s argument from "locked" to "lock_it". No functional change. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Petr Holasek <pholasek@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Izik Eidus <izik.eidus@ravellosystems.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23ksm: add sysfs ABI DocumentationPetr Holasek
Add sysfs documentation for Kernel Samepage Merging (KSM) including new merge_across_nodes knob. Signed-off-by: Petr Holasek <pholasek@redhat.com> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Izik Eidus <izik.eidus@ravellosystems.com> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23ksm: allow trees per NUMA nodePetr Holasek
Here's a KSM series, based on mmotm 2013-01-23-17-04: starting with Petr's v7 "KSM: numa awareness sysfs knob"; then fixing the two issues we had with that, fully enabling KSM page migration on the way. (A different kind of KSM/NUMA issue which I've certainly not begun to address here: when KSM pages are unmerged, there's usually no sense in preferring to allocate the new pages local to the caller's node.) This patch: Introduces new sysfs boolean knob /sys/kernel/mm/ksm/merge_across_nodes which control merging pages across different numa nodes. When it is set to zero only pages from the same node are merged, otherwise pages from all nodes can be merged together (default behavior). Typical use-case could be a lot of KVM guests on NUMA machine and cpus from more distant nodes would have significant increase of access latency to the merged ksm page. Sysfs knob was choosen for higher variability when some users still prefers higher amount of saved physical memory regardless of access latency. Every numa node has its own stable & unstable trees because of faster searching and inserting. Changing of merge_across_nodes value is possible only when there are not any ksm shared pages in system. I've tested this patch on numa machines with 2, 4 and 8 nodes and measured speed of memory access inside of KVM guests with memory pinned to one of nodes with this benchmark: http://pholasek.fedorapeople.org/alloc_pg.c Population standard deviations of access times in percentage of average were following: merge_across_nodes=1 2 nodes 1.4% 4 nodes 1.6% 8 nodes 1.7% merge_across_nodes=0 2 nodes 1% 4 nodes 0.32% 8 nodes 0.018% RFC: https://lkml.org/lkml/2011/11/30/91 v1: https://lkml.org/lkml/2012/1/23/46 v2: https://lkml.org/lkml/2012/6/29/105 v3: https://lkml.org/lkml/2012/9/14/550 v4: https://lkml.org/lkml/2012/9/23/137 v5: https://lkml.org/lkml/2012/12/10/540 v6: https://lkml.org/lkml/2012/12/23/154 v7: https://lkml.org/lkml/2012/12/27/225 Hugh notes that this patch brings two problems, whose solution needs further support in mm/ksm.c, which follows in subsequent patches: 1) switching merge_across_nodes after running KSM is liable to oops on stale nodes still left over from the previous stable tree; 2) memory hotremove may migrate KSM pages, but there is no provision here for !merge_across_nodes to migrate nodes to the proper tree. Signed-off-by: Petr Holasek <pholasek@redhat.com> Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Izik Eidus <izik.eidus@ravellosystems.com> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23acpi, memory-hotplug: support getting hotplug info from SRATTang Chen
We now provide an option for users who don't want to specify physical memory address in kernel commandline. /* * For movablemem_map=acpi: * * SRAT: |_____| |_____| |_________| |_________| ...... * node id: 0 1 1 2 * hotpluggable: n y y n * movablemem_map: |_____| |_________| * * Using movablemem_map, we can prevent memblock from allocating memory * on ZONE_MOVABLE at boot time. */ So user just specify movablemem_map=acpi, and the kernel will use hotpluggable info in SRAT to determine which memory ranges should be set as ZONE_MOVABLE. If all the memory ranges in SRAT is hotpluggable, then no memory can be used by kernel. But before parsing SRAT, memblock has already reserve some memory ranges for other purposes, such as for kernel image, and so on. We cannot prevent kernel from using these memory. So we need to exclude these ranges even if these memory is hotpluggable. Furthermore, there could be several memory ranges in the single node which the kernel resides in. We may skip one range that have memory reserved by memblock, but if the rest of memory is too small, then the kernel will fail to boot. So, make the whole node which the kernel resides in un-hotpluggable. Then the kernel has enough memory to use. NOTE: Using this way will cause NUMA performance down because the whole node will be set as ZONE_MOVABLE, and kernel cannot use memory on it. If users don't want to lose NUMA performance, just don't use it. [akpm@linux-foundation.org: fix warning] [akpm@linux-foundation.org: use strcmp()] Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Wu Jianguo <wujianguo@huawei.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Len Brown <lenb@kernel.org> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23page_alloc: add movable_memmap kernel parameterTang Chen
Add functions to parse movablemem_map boot option. Since the option could be specified more then once, all the maps will be stored in the global variable movablemem_map.map array. And also, we keep the array in monotonic increasing order by start_pfn. And merge all overlapped ranges. [akpm@linux-foundation.org: improve comment] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: remove unneeded parens] Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Reviewed-by: Wen Congyang <wency@cn.fujitsu.com> Tested-by: Lin Feng <linfeng@cn.fujitsu.com> Cc: Wu Jianguo <wujianguo@huawei.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Benjamin Herrenschmidt: "So from the depth of frozen Minnesota, here's the powerpc pull request for 3.9. It has a few interesting highlights, in addition to the usual bunch of bug fixes, minor updates, embedded device tree updates and new boards: - Hand tuned asm implementation of SHA1 (by Paulus & Michael Ellerman) - Support for Doorbell interrupts on Power8 (kind of fast thread-thread IPIs) by Ian Munsie - Long overdue cleanup of the way we handle relocation of our open firmware trampoline (prom_init.c) on 64-bit by Anton Blanchard - Support for saving/restoring & context switching the PPR (Processor Priority Register) on server processors that support it. This allows the kernel to preserve thread priorities established by userspace. By Haren Myneni. - DAWR (new watchpoint facility) support on Power8 by Michael Neuling - Ability to change the DSCR (Data Stream Control Register) which controls cache prefetching on a running process via ptrace by Alexey Kardashevskiy - Support for context switching the TAR register on Power8 (new branch target register meant to be used by some new specific userspace perf event interrupt facility which is yet to be enabled) by Ian Munsie. - Improve preservation of the CFAR register (which captures the origin of a branch) on various exception conditions by Paulus. - Move the Bestcomm DMA driver from arch powerpc to drivers/dma where it belongs by Philippe De Muyter - Support for Transactional Memory on Power8 by Michael Neuling (based on original work by Matt Evans). For those curious about the feature, the patch contains a pretty good description." (See commit db8ff907027b: "powerpc: Documentation for transactional memory on powerpc" for the mentioned description added to the file Documentation/powerpc/transactional_memory.txt) * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (140 commits) powerpc/kexec: Disable hard IRQ before kexec powerpc/85xx: l2sram - Add compatible string for BSC9131 platform powerpc/85xx: bsc9131 - Correct typo in SDHC device node powerpc/e500/qemu-e500: enable coreint powerpc/mpic: allow coreint to be determined by MPIC version powerpc/fsl_pci: Store the pci ctlr device ptr in the pci ctlr struct powerpc/85xx: Board support for ppa8548 powerpc/fsl: remove extraneous DIU platform functions arch/powerpc/platforms/85xx/p1022_ds.c: adjust duplicate test powerpc: Documentation for transactional memory on powerpc powerpc: Add transactional memory to pseries and ppc64 defconfigs powerpc: Add config option for transactional memory powerpc: Add transactional memory to POWER8 cpu features powerpc: Add new transactional memory state to the signal context powerpc: Hook in new transactional memory code powerpc: Routines for FP/VSX/VMX unavailable during a transaction powerpc: Add transactional memory unavaliable execption handler powerpc: Add reclaim and recheckpoint functions for context switching transactional memory processes powerpc: Add FP/VSX and VMX register load functions for transactional memory powerpc: Add helper functions for transactional memory context switching ...
2013-02-22Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core locking changes from Ingo Molnar: "The biggest change is the rwsem lock-steal improvements, both to the assembly optimized and the spinlock based variants. The other notable change is the clean up of the seqlock implementation to be based on the seqcount infrastructure. The rest is assorted smaller debuggability, cleanup and continued -rt locking changes." * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: rwsem-spinlock: Implement writer lock-stealing for better scalability futex: Revert "futex: Mark get_robust_list as deprecated" generic: Use raw local irq variant for generic cmpxchg lockdep: Selftest: convert spinlock to raw spinlock seqlock: Use seqcount infrastructure seqlock: Remove unused functions ntp: Make ntp_lock raw intel_idle: Convert i7300_idle_lock to raw_spinlock locking: Various static lock initializer fixes lockdep: Print more info when MAX_LOCK_DEPTH is exceeded rwsem: Implement writer lock-stealing for better scalability lockdep: Silence warning if CONFIG_LOCKDEP isn't set watchdog: Use local_clock for get_timestamp() lockdep: Rename print_unlock_inbalance_bug() to print_unlock_imbalance_bug() locking/stat: Fix a typo
2013-02-22Merge branch 'x86/microcode' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 microcode loading update from Peter Anvin: "This patchset lets us update the CPU microcode very, very early in initialization if the BIOS fails to do so (never happens, right?) This is handy for dealing with things like the Atom erratum where we have to run without PSE because microcode loading happens too late. As I mentioned in the x86/mm push request it depends on that infrastructure but it is otherwise a standalone feature." * 'x86/microcode' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/Kconfig: Make early microcode loading a configuration feature x86/mm/init.c: Copy ucode from initrd image to kernel memory x86/head64.c: Early update ucode in 64-bit x86/head_32.S: Early update ucode in 32-bit x86/microcode_intel_early.c: Early update ucode on Intel's CPU x86/tlbflush.h: Define __native_flush_tlb_global_irq_disabled() x86/microcode_intel_lib.c: Early update ucode on Intel's CPU x86/microcode_core_early.c: Define interfaces for early loading ucode x86/common.c: load ucode in 64 bit or show loading ucode info in 32 bit on AP x86/common.c: Make have_cpuid_p() a global function x86/microcode_intel.h: Define functions and macros for early loading ucode x86, doc: Documentation for early microcode loading
2013-02-22drm: Add consistency check for page-flippingThierry Reding
Driver implementations of the drm_crtc's .page_flip() function are required to update the crtc->fb field on success to reflect that the new framebuffer is now in use. This is important to keep reference counting on the framebuffers balanced. While at it, document this requirement to keep others from falling into the same trap. Suggested-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-02-22drm: Add EDID helper documentationThierry Reding
Add a reference section about the EDID helper functions to the DRM documentation. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
2013-02-21Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm changes from Peter Anvin: "This is a huge set of several partly interrelated (and concurrently developed) changes, which is why the branch history is messier than one would like. The *really* big items are two humonguous patchsets mostly developed by Yinghai Lu at my request, which completely revamps the way we create initial page tables. In particular, rather than estimating how much memory we will need for page tables and then build them into that memory -- a calculation that has shown to be incredibly fragile -- we now build them (on 64 bits) with the aid of a "pseudo-linear mode" -- a #PF handler which creates temporary page tables on demand. This has several advantages: 1. It makes it much easier to support things that need access to data very early (a followon patchset uses this to load microcode way early in the kernel startup). 2. It allows the kernel and all the kernel data objects to be invoked from above the 4 GB limit. This allows kdump to work on very large systems. 3. It greatly reduces the difference between Xen and native (Xen's equivalent of the #PF handler are the temporary page tables created by the domain builder), eliminating a bunch of fragile hooks. The patch series also gets us a bit closer to W^X. Additional work in this pull is the 64-bit get_user() work which you were also involved with, and a bunch of cleanups/speedups to __phys_addr()/__pa()." * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (105 commits) x86, mm: Move reserving low memory later in initialization x86, doc: Clarify the use of asm("%edx") in uaccess.h x86, mm: Redesign get_user with a __builtin_choose_expr hack x86: Be consistent with data size in getuser.S x86, mm: Use a bitfield to mask nuisance get_user() warnings x86/kvm: Fix compile warning in kvm_register_steal_time() x86-32: Add support for 64bit get_user() x86-32, mm: Remove reference to alloc_remap() x86-32, mm: Remove reference to resume_map_numa_kva() x86-32, mm: Rip out x86_32 NUMA remapping code x86/numa: Use __pa_nodebug() instead x86: Don't panic if can not alloc buffer for swiotlb mm: Add alloc_bootmem_low_pages_nopanic() x86, 64bit, mm: hibernate use generic mapping_init x86, 64bit, mm: Mark data/bss/brk to nx x86: Merge early kernel reserve for 32bit and 64bit x86: Add Crash kernel low reservation x86, kdump: Remove crashkernel range find limit for 64bit memblock: Add memblock_mem_size() x86, boot: Not need to check setup_header version for setup_data ...
2013-02-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID subsystem updates from Jiri Kosina: "HID subsystem and drivers update. Highlights: - new support of a group of Win7/Win8 multitouch devices, from Benjamin Tissoires - fix for compat interface brokenness in uhid, from Dmitry Torokhov - conversion of drivers to use hid_driver helper, by H Hartley Sweeten - HID over I2C transport received ACPI enumeration support, written by Mika Westerberg - there is an ongoing effort to make HID sensor hubs independent of USB transport. The first self-contained part of this work is provided here, done by Mika Westerberg - a few smaller fixes here and there, support for a couple new devices added" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (43 commits) HID: Correct Logitech order in hid-ids.h HID: LG4FF: Remove unnecessary deadzone code HID: LG: Prevent the Logitech Gaming Wheels deadzone HID: LG: Fix detection of Logitech Speed Force Wireless (WiiWheel) HID: LG: Add support for Logitech Momo Force (Red) Wheel HID: hidraw: print message when succesfully initialized HID: logitech: split accel, brake for Driving Force wheel HID: logitech: add report descriptor for Driving Force wheel HID: add ThingM blink(1) USB RGB LED support HID: uhid: make creating devices work on 64/32 systems HID: wiimote: fix nunchuck button parser HID: blacklist Velleman data acquisition boards HID: sensor-hub: don't limit the driver only to USB bus HID: sensor-hub: get rid of unused sensor_hub_grabbed_usages[] table HID: extend autodetect to handle I2C sensors as well HID: ntrig: use input_configured() callback to set the name HID: multitouch: do not use pointers towards hid-core HID: add missing GENERIC_HARDIRQ dependency HID: multitouch: make MT_CLS_ALWAYS_TRUE the new default class HID: multitouch: fix protocol for Elo panels ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Assorted tiny fixes queued in trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (22 commits) DocBook: update EXPORT_SYMBOL entry to point at export.h Documentation: update top level 00-INDEX file with new additions ARM: at91/ide: remove unsused at91-ide Kconfig entry percpu_counter.h: comment code for better readability x86, efi: fix comment typo in head_32.S IB: cxgb3: delay freeing mem untill entirely done with it net: mvneta: remove unneeded version.h include time: x86: report_lost_ticks doesn't exist any more pcmcia: avoid static analysis complaint about use-after-free fs/jfs: Fix typo in comment : 'how may' -> 'how many' of: add missing documentation for of_platform_populate() btrfs: remove unnecessary cur_trans set before goto loop in join_transaction sound: soc: Fix typo in sound/codecs treewide: Fix typo in various drivers btrfs: fix comment typos Update ibmvscsi module name in Kconfig. powerpc: fix typo (utilties -> utilities) of: fix spelling mistake in comment h8300: Fix home page URL in h8300/README xtensa: Fix home page URL in Kconfig ...
2013-02-21Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge misc patches from Andrew Morton: - Florian has vanished so I appear to have become fbdev maintainer again :( - Joel and Mark are distracted to welcome to the new OCFS2 maintainer - The backlight queue - Small core kernel changes - lib/ updates - The rtc queue - Various random bits * akpm: (164 commits) rtc: rtc-davinci: use devm_*() functions rtc: rtc-max8997: use devm_request_threaded_irq() rtc: rtc-max8907: use devm_request_threaded_irq() rtc: rtc-da9052: use devm_request_threaded_irq() rtc: rtc-wm831x: use devm_request_threaded_irq() rtc: rtc-tps80031: use devm_request_threaded_irq() rtc: rtc-lp8788: use devm_request_threaded_irq() rtc: rtc-coh901331: use devm_clk_get() rtc: rtc-vt8500: use devm_*() functions rtc: rtc-tps6586x: use devm_request_threaded_irq() rtc: rtc-imxdi: use devm_clk_get() rtc: rtc-cmos: use dev_warn()/dev_dbg() instead of printk()/pr_debug() rtc: rtc-pcf8583: use dev_warn() instead of printk() rtc: rtc-sun4v: use pr_warn() instead of printk() rtc: rtc-vr41xx: use dev_info() instead of printk() rtc: rtc-rs5c313: use pr_err() instead of printk() rtc: rtc-at91rm9200: use dev_dbg()/dev_err() instead of printk()/pr_debug() rtc: rtc-rs5c372: use dev_dbg()/dev_warn() instead of printk()/pr_debug() rtc: rtc-ds2404: use dev_err() instead of printk() rtc: rtc-efi: use dev_err()/dev_warn()/pr_err() instead of printk() ...
2013-02-21backlight: lp855x_bl: support new LP8557 deviceKim, Milo
LP8557 is one of LP855x family device, but it has different register map and initialization process. To support this device, device specific configuration is done through the lp855x_device_config structure. Few register definitions are fixed for better readability. BRIGHTNESS_CTRL -> LP855X_BRIGHTNESS_CTRL DEVICE_CTRL -> LP855X_DEVICE_CTRL EEPROM_START -> LP855X_EEPROM_START EEPROM_END -> LP855X_EEPROM_END EPROM_START -> LP8556_EPROM_START EPROM_END -> LP8556_EPROM_END And LP8557 register definitions are added. New register function, lp855x_update_bit() is added. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Acked-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21lib/vsprintf.c: add %pa format specifier for phys_addr_t typesStepan Moskovchenko
Add the %pa format specifier for printing a phys_addr_t type and its derivative types (such as resource_size_t), since the physical address size on some platforms can vary based on build options, regardless of the native integer type. Signed-off-by: Stepan Moskovchenko <stepanm@codeaurora.org> Cc: Rob Landley <rob@landley.net> Cc: George Spelvin <linux@horizon.com> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Stephen Boyd <sboyd@codeaurora.org> Cc: Andrei Emeltchenko <andrei.emeltchenko@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21sun.com documentation fixesChristian Kujau
After I came across a help text for SUNGEM mentioning a broken sun.com URL, I felt like fixing those up, as they are now pointing to oracle.com URLs. Signed-off-by: Christian Kujau <lists@nerdbynature.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21bdi: allow block devices to say that they require stable page writesDarrick J. Wong
This patchset ("stable page writes, part 2") makes some key modifications to the original 'stable page writes' patchset. First, it provides creators (devices and filesystems) of a backing_dev_info a flag that declares whether or not it is necessary to ensure that page contents cannot change during writeout. It is no longer assumed that this is true of all devices (which was never true anyway). Second, the flag is used to relaxed the wait_on_page_writeback calls so that wait only occurs if the device needs it. Third, it fixes up the remaining disk-backed filesystems to use this improved conditional-wait logic to provide stable page writes on those filesystems. It is hoped that (for people not using checksumming devices, anyway) this patchset will give back unnecessary performance decreases since the original stable page write patchset went into 3.0. Sorry about not fixing it sooner. Complaints were registered by several people about the long write latencies introduced by the original stable page write patchset. Generally speaking, the kernel ought to allocate as little extra memory as possible to facilitate writeout, but for people who simply cannot wait, a second page stability strategy is (re)introduced: snapshotting page contents. The waiting behavior is still the default strategy; to enable page snapshotting, a superblock flag (MS_SNAP_STABLE) must be set. This flag is used to bandaid^Henable stable page writeback on ext3[1], and is not used anywhere else. Given that there are already a few storage devices and network FSes that have rolled their own page stability wait/page snapshot code, it would be nice to move towards consolidating all of these. It seems possible that iscsi and raid5 may wish to use the new stable page write support to enable zero-copy writeout. Thank you to Jan Kara for helping fix a couple more filesystems. Per Andrew Morton's request, here are the result of using dbench to measure latencies on ext2: 3.8.0-rc3: Operation Count AvgLat MaxLat ---------------------------------------- WriteX 109347 0.028 59.817 ReadX 347180 0.004 3.391 Flush 15514 29.828 287.283 Throughput 57.429 MB/sec 4 clients 4 procs max_latency=287.290 ms 3.8.0-rc3 + patches: WriteX 105556 0.029 4.273 ReadX 335004 0.005 4.112 Flush 14982 30.540 298.634 Throughput 55.4496 MB/sec 4 clients 4 procs max_latency=298.650 ms As you can see, for ext2 the maximum write latency decreases from ~60ms on a laptop hard disk to ~4ms. I'm not sure why the flush latencies increase, though I suspect that being able to dirty pages faster gives the flusher more work to do. On ext4, the average write latency decreases as well as all the maximum latencies: 3.8.0-rc3: WriteX 85624 0.152 33.078 ReadX 272090 0.010 61.210 Flush 12129 36.219 168.260 Throughput 44.8618 MB/sec 4 clients 4 procs max_latency=168.276 ms 3.8.0-rc3 + patches: WriteX 86082 0.141 30.928 ReadX 273358 0.010 36.124 Flush 12214 34.800 165.689 Throughput 44.9941 MB/sec 4 clients 4 procs max_latency=165.722 ms XFS seems to exhibit similar latency improvements as ext2: 3.8.0-rc3: WriteX 125739 0.028 104.343 ReadX 399070 0.005 4.115 Flush 17851 25.004 131.390 Throughput 66.0024 MB/sec 4 clients 4 procs max_latency=131.406 ms 3.8.0-rc3 + patches: WriteX 123529 0.028 6.299 ReadX 392434 0.005 4.287 Flush 17549 25.120 188.687 Throughput 64.9113 MB/sec 4 clients 4 procs max_latency=188.704 ms ...and btrfs, just to round things out, also shows some latency decreases: 3.8.0-rc3: WriteX 67122 0.083 82.355 ReadX 212719 0.005 2.828 Flush 9547 47.561 147.418 Throughput 35.3391 MB/sec 4 clients 4 procs max_latency=147.433 ms 3.8.0-rc3 + patches: WriteX 64898 0.101 71.631 ReadX 206673 0.005 7.123 Flush 9190 47.963 219.034 Throughput 34.0795 MB/sec 4 clients 4 procs max_latency=219.044 ms Before this patchset, all filesystems would block, regardless of whether or not it was necessary. ext3 would wait, but still generate occasional checksum errors. The network filesystems were left to do their own thing, so they'd wait too. After this patchset, all the disk filesystems except ext3 and btrfs will wait only if the hardware requires it. ext3 (if necessary) snapshots pages instead of blocking, and btrfs provides its own bdi so the mm will never wait. Network filesystems haven't been touched, so either they provide their own wait code, or they don't block at all. The blocking behavior is back to what it was before 3.0 if you don't have a disk requiring stable page writes. This patchset has been tested on 3.8.0-rc3 on x64 with ext3, ext4, and xfs. I've spot-checked 3.8.0-rc4 and seem to be getting the same results as -rc3. [1] The alternative fixes to ext3 include fixing the locking order and page bit handling like we did for ext4 (but then why not just use ext4?), or setting PG_writeback so early that ext3 becomes extremely slow. I tried that, but the number of write()s I could initiate dropped by nearly an order of magnitude. That was a bit much even for the author of the stable page series! :) This patch: Creates a per-backing-device flag that tracks whether or not pages must be held immutable during writeout. Eventually it will be used to waive wait_for_page_writeback() if nothing requires stable pages. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21Merge tag 'virt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM virtualization changes: "This contains parts of the ARM KVM support that have dependencies on other patches merged through the arm-soc tree. In combination with patches coming through Russell's tree, this will finally add full support for the kernel based virtual machine on ARM, which has been awaited for some time now. Further, we now have a separate platform for virtual machines and qemu booting that is used by both Xen and KVM, separating these from the Versatile Express reference implementation. Obviously, this new platform is multiplatform capable so it can be combined with existing machines in the same kernel." * tag 'virt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (38 commits) ARM: arch_timer: include linux/errno.h arm: arch_timer: add missing inline in stub function ARM: KVM: arch_timers: Wire the init code and config option ARM: KVM: arch_timers: Add timer world switch ARM: KVM: arch_timers: Add guest timer core support ARM: KVM: Add VGIC configuration option ARM: KVM: VGIC initialisation code ARM: KVM: VGIC control interface world switch ARM: KVM: VGIC interrupt injection ARM: KVM: vgic: retire queued, disabled interrupts ARM: KVM: VGIC virtual CPU interface management ARM: KVM: VGIC distributor handling ARM: KVM: VGIC accept vcpu and dist base addresses from user space ARM: KVM: Initial VGIC infrastructure code ARM: KVM: Keep track of currently running vcpus KVM: ARM: Introduce KVM_ARM_SET_DEVICE_ADDR ioctl ARM: gic: add __ASSEMBLY__ guard to C definitions ARM: gic: define GICH offsets for VGIC support ARM: gic: add missing distributor defintions ARM: mach-virt: fixup machine descriptor after removal of sys_timer ...
2013-02-21Merge tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC device tree conversions from Arnd Bergmann: "These are device tree conversions for a number of platforms, with the intention of turning code from board files into device tree descriptions. Notable changes are: - davinci bindings for pinctrl, MTD, RTC, watchdog and i2c - nomadik bindings for all devices, removing the board files - bcm2835 bindings for mmc and i2c - tegra bindings for hdmi, keyboard, audio, as well as some updates - at91 bindings for hardware ecc and for devices on RM9200 - mxs bindings for cfa100xx - sunxi support for Miniand Hackberry board" * tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (72 commits) Revert "sunxi: a10-cubieboard: Add user LEDs to the device tree" Revert "sunxi: a13-olinuxino: Add user LED to the device tree" clk: tegra: initialise parent of uart clocks ARM: tegra: remove clock-frequency properties from serial nodes clk: tegra: fix driver to match DT binding clk: tegra: local arrays should be static clk: tegra: Add missing spinlock for hclk and pclk clk: tegra: Implement locking for super clock clk: tegra: fix wrong clock index between se to sata_cold sunxi: a13-olinuxino: Add user LED to the device tree ARM: davinci: da850 DT: add support for machine reboot ARM: davinci: da850: add wdt DT node ARM: davinci: da850: add DT node for I2C0 ARM: at91: at91sam9n12: add DT parameters to enable PMECC ARM: at91: at91sam9x5: add DT parameters to enable PMECC ARM: at91: add EMAC bindings to RM9200 DT ARM: at91: add SSC bindings to RM9200 DT ARM: at91: add MMC bindings to RM9200 DT ARM: at91: Animeo IP: enable watchdog support ARM: nomadik: fix OF compilation regression ...
2013-02-21Merge tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC-specific updates from Arnd Bergmann: "This is a larger set of new functionality for the existing SoC families, including: - vt8500 gains support for new CPU cores, notably the Cortex-A9 based wm8850 - prima2 gains support for the "marco" SoC family, its SMP based cousin - tegra gains support for the new Tegra4 (Tegra114) family - socfpga now supports a newer version of the hardware including SMP - i.mx31 and bcm2835 are now using DT probing for their clocks - lots of updates for sh-mobile - OMAP updates for clocks, power management and USB - i.mx6q and tegra now support cpuidle - kirkwood now supports PCIe hot plugging - tegra clock support is updated - tegra USB PHY probing gets implemented diffently" * tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (148 commits) ARM: prima2: remove duplicate v7_invalidate_l1 ARM: shmobile: r8a7779: Correct TMU clock support again ARM: prima2: fix __init section for cpu hotplug ARM: OMAP: Consolidate OMAP USB-HS platform data (part 3/3) ARM: OMAP: Consolidate OMAP USB-HS platform data (part 1/3) arm: socfpga: Add SMP support for actual socfpga harware arm: Add v7_invalidate_l1 to cache-v7.S arm: socfpga: Add entries to enable make dtbs socfpga arm: socfpga: Add new device tree source for actual socfpga HW ARM: tegra: sort Kconfig selects for Tegra114 ARM: tegra: enable ARCH_REQUIRE_GPIOLIB for Tegra114 ARM: tegra: Fix build error w/ ARCH_TEGRA_114_SOC w/o ARCH_TEGRA_3x_SOC ARM: tegra: Fix build error for gic update ARM: tegra: remove empty tegra_smp_init_cpus() ARM: shmobile: Register ARM architected timer ARM: MARCO: fix the build issue due to gic-vic-to-irqchip move ARM: shmobile: r8a7779: Correct TMU clock support ARM: mxs_defconfig: Select CONFIG_DEVTMPFS_MOUNT ARM: mxs: decrease mxs_clockevent_device.min_delta_ns to 2 clock cycles ARM: mxs: use apbx bus clock to drive the timers on timrotv2 ...
2013-02-21Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC driver specific changes from Arnd Bergmann: - Updates to the ux500 cpufreq code - Moving the u300 DMA controller driver to drivers/dma - Moving versatile express drivers out of arch/arm for sharing with arch/arm64 - Device tree bindings for the OMAP General Purpose Memory Controller * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (27 commits) ARM: OMAP2+: gpmc: Add device tree documentation for elm handle ARM: OMAP2+: gpmc: add DT bindings for OneNAND ARM: OMAP2+: gpmc-onenand: drop __init annotation mtd: omap-onenand: pass device_node in platform data ARM: OMAP2+: Prevent potential crash if GPMC probe fails ARM: OMAP2+: gpmc: Remove unneeded of_node_put() arm: Move sp810.h to include/linux/amba/ ARM: OMAP: gpmc: add DT bindings for GPMC timings and NAND ARM: OMAP: gpmc: enable hwecc for AM33xx SoCs ARM: OMAP: gpmc-nand: drop __init annotation mtd: omap-nand: pass device_node in platform data ARM: OMAP: gpmc: don't create devices from initcall on DT dma: coh901318: cut down on platform data abstraction dma: coh901318: merge header files dma: coh901318: push definitions into driver dma: coh901318: push header down into the DMA subsystem dma: coh901318: skip hard-coded addresses dma: coh901318: remove hardcoded target addresses dma: coh901318: push platform data into driver dma: coh901318: create a proper platform data file ...
2013-02-21Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC cleanups from Arnd Bergmann: "A large number of cleanups, all over the platforms. This is dominated largely by the Samsung platforms (s3c, s5p, exynos) and a few of the others moving code out of arch/arm into more appropriate subsystems. The clocksource and irqchip drivers are now abstracted to the point where platforms that are already cleaned up do not need to even specify the driver they use, it can all get configured from the device tree as we do for normal device drivers. The clocksource changes basically touch every single platform in the process. We further clean up the use of platform specific header files here, with the goal of turning more of the platforms over to being "multiplatform" enabled, which implies that they cannot expose their headers to architecture independent code any more. It is expected that no functional changes are part of the cleanup. The overall reduction in total code lines is mostly the result of removing broken and obsolete code." * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (133 commits) ARM: mvebu: correct gated clock documentation ARM: kirkwood: add missing include for nsa310 ARM: exynos: move exynos4210-combiner to drivers/irqchip mfd: db8500-prcmu: update resource passing drivers/db8500-cpufreq: delete dangling include ARM: at91: remove NEOCORE 926 board sunxi: Cleanup the reset code and add meaningful registers defines ARM: S3C24XX: header mach/regs-mem.h local ARM: S3C24XX: header mach/regs-power.h local ARM: S3C24XX: header mach/regs-s3c2412-mem.h local ARM: S3C24XX: Remove plat-s3c24xx directory in arch/arm/ ARM: S3C24XX: transform s3c2443 subirqs into new structure ARM: S3C24XX: modify s3c2443 irq init to initialize all irqs ARM: S3C24XX: move s3c2443 irq code to irq.c ARM: S3C24XX: transform s3c2416 irqs into new structure ARM: S3C24XX: modify s3c2416 irq init to initialize all irqs ARM: S3C24XX: move s3c2416 irq init to common irq code ARM: S3C24XX: Modify s3c_irq_wake to use the hwirq property ARM: S3C24XX: Move irq syscore-ops to irq-pm clocksource: always define CLOCKSOURCE_OF_DECLARE ...
2013-02-21Merge tag 'fixes-non-critical' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull non-critical ARM SoC bug fixes from Arnd Bergmann: "Bug fixes that did not make it into v3.8, mostly because they were not considered important enough, and in some cases because bugs only show up in combination with other patches destined for 3.9. This includes a few larger patches for GPIO on the Marvell PXA platform and a lot of Samsung specific bug fixes, as well as a series from Arnd to fix older build warnings." * tag 'fixes-non-critical' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits) ARM: SPEAr13xx: Enable CONFIG_ARCH_HAS_CPUFREQ ARM: imx: MACH_MX31ADS_WM1133_EV1 needs REGULATOR_WM8350 scripts/sortextable: silence script output ARM: s3c: i2c: add platform_device forward declaration ARM: mvebu: allow selecting mvebu without Armada XP ARM: pick Versatile by default for !MMU ARM: integrator: fix build with INTEGRATOR_AP off ARM: integrator/versatile: fix NOMMU warnings ARM: sa1100: don't warn about mach/ide.h ARM: shmobile: fix defconfig warning on CONFIG_USB ARM: w90x900: fix legacy assembly syntax ARM: samsung: fix assembly syntax for new gas ARM: disable virt_to_bus/virt_to_bus almost everywhere ARM: dts: Correct pin configuration of SD 4 for exynos4x12-pinctrl ARM: SAMSUNG: Silence empty switch warning in fimc-core.h ARM: SAMSUNG: Silence empty switch warning in sdhci.h ARM: msm: proc_comm_boot_wait should not be __init arm: vt8500: Update MAINTAINERS entry for arch-vt8500 ARM: integrator: ensure ap_syscon_base is initialised when !CONFIG_MMU ARM: S5PV210: Fix early uart output in fifo mode ...
2013-02-21Merge tag 'char-misc-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver patches from Greg Kroah-Hartman: "Here's the big char/misc driver patches for 3.9-rc1. Nothing major here, just lots of different driver updates (mei, hyperv, ipack, extcon, vmci, etc.). All of these have been in the linux-next tree for a while." * tag 'char-misc-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (209 commits) w1: w1_therm: Add force-pullup option for "broken" sensors w1: ds2482: Added 1-Wire pull-up support to the driver vme: add missing put_device() after device_register() fails extcon: max8997: Use workqueue to check cable state after completing boot of platform extcon: max8997: Set default UART/USB path on probe extcon: max8997: Consolidate duplicate code for checking ADC/CHG cable type extcon: max8997: Set default of ADC debounce time during initialization extcon: max8997: Remove duplicate code related to set H/W line path extcon: max8997: Move defined constant to header file extcon: max77693: Make max77693_extcon_cable static extcon: max8997: Remove unreachable code extcon: max8997: Make max8997_extcon_cable static extcon: max77693: Remove unnecessary goto statement to improve readability extcon: max77693: Convert to devm_input_allocate_device() extcon: gpio: Rename filename of extcon-gpio.c according to kernel naming style CREDITS: update email and address of Harald Hoyer extcon: arizona: Use MICDET for final microphone identification extcon: arizona: Always take the first HPDET reading as the final one extcon: arizona: Clear _trig_sts bits after jack detection extcon: arizona: Don't HPDET magic when headphones are enabled ...
2013-02-21Merge tag 'tty-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial patches from Greg Kroah-Hartman: "Here's the big tty/serial driver patches for 3.9-rc1. More tty port rework and fixes from Jiri here, as well as lots of individual serial driver updates and fixes. All of these have been in the linux-next tree for a while." * tag 'tty-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (140 commits) tty: mxser: improve error handling in mxser_probe() and mxser_module_init() serial: imx: fix uninitialized variable warning serial: tegra: assume CONFIG_OF TTY: do not update atime/mtime on read/write lguest: select CONFIG_TTY to build properly. ARM defconfigs: add missing inclusions of linux/platform_device.h fb/exynos: include platform_device.h ARM: sa1100/assabet: include platform_device.h directly serial: imx: Fix recursive locking bug pps: Fix build breakage from decoupling pps from tty tty: Remove ancient hardpps() pps: Additional cleanups in uart_handle_dcd_change pps: Move timestamp read into PPS code proper pps: Don't crash the machine when exiting will do pps: Fix a use-after free bug when unregistering a source. pps: Use pps_lookup_dev to reduce ldisc coupling pps: Add pps_lookup_dev() function tty: serial: uartlite: Support uartlite on big and little endian systems tty: serial: uartlite: Fix sparse and checkpatch warnings serial/arc-uart: Miscll DT related updates (Grant's review comments) ... Fix up trivial conflicts, mostly just due to the TTY config option clashing with the EXPERIMENTAL removal.
