path: root/Documentation
2014-02-13mm, oom: base root bonus on current usageDavid Rientjes
commit 778c14affaf94a9e4953179d3e13a544ccce7707 upstream. A 3% of system memory bonus is sometimes too excessive in comparison to other processes. With commit a63d83f427fb ("oom: badness heuristic rewrite"), the OOM killer tries to avoid killing privileged tasks by subtracting 3% of overall memory (system or cgroup) from their per-task consumption. But as a result, all root tasks that consume less than 3% of overall memory are considered equal, and so it only takes 33+ privileged tasks pushing the system out of memory for the OOM killer to do something stupid and kill dhclient or other root-owned processes. For example, on a 32G machine it can't tell the difference between the 1M agetty and the 10G fork bomb member. The changelog describes this 3% boost as the equivalent to the global overcommit limit being 3% higher for privileged tasks, but this is not the same as discounting 3% of overall memory from _every privileged task individually_ during OOM selection. Replace the 3% of system memory bonus with a 3% of current memory usage bonus. By giving root tasks a bonus that is proportional to their actual size, they remain comparable even when relatively small. In the example above, the OOM killer will discount the 1M agetty's 256 badness points down to 179, and the 10G fork bomb's 262144 points down to 183500 points and make the right choice, instead of discounting both to 0 and killing agetty because it's first in the task list. Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-06i2c: piix4: Add support for AMD ML and CZ SMBus changesShane Huang
commit 032f708bc4f6da868ec49dac48ddf3670d8035d3 upstream. The locations of SMBus register base address and enablement bit are changed from AMD ML, which need this patch to be supported. Signed-off-by: Shane Huang <shane.huang@amd.com> Reviewed-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-06i2c: mv64xxx: Document the newly introduced Armada XP A0 compatibleGregory CLEMENT
commit f8b94beb7e6a374cb0de531b72377c49857b35ca upstream. The first variants of Armada XP SoCs (A0 stepping) have issues related to the i2c controller which prevent to use the offload mechanism and lead to a kernel hang during boot. The commit introduces a new the compatible string marvell,mv78230-a0-i2c for the i2c controller. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> cc: devicetree@vger.kernel.org Fixes: 930ab3d403ae (i2c: mv64xxx: Add I2C Transaction Generator support) Signed-off-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-06ata: sata_mv: introduce compatible string "marvell, armada-370-sata"Simon Guinot
commit b1f5c73bd5a4752efb7d7af019034044b08aafe9 upstream. The sata_mv driver supports the SATA IP found in several Marvell SoCs. As some new SATA registers have been introduced with the Armada 370/XP SoCs, a way to identify them is needed. This patch introduces a new compatible string for the SATA IP found in Armada 370/XP SoCs. Signed-off-by: Simon Guinot <simon.guinot@sequanux.org> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Gregory Clement <gregory.clement@free-electrons.com> Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Cc: Lior Amsalem <alior@marvell.com> Acked-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-15clk: samsung: exynos5250: Add MDMA0 clocksAbhilash Kesavan
commit 8fb9aeb7a71ef4f3e0613d459a2e1366a7a90469 upstream. Adds gate clock for MDMA0 on Exynos5250 SoC. This is needed to ensure that the clock is enabled when MDMA0 is used on systems on which firmware gates the clockby default. Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Acked-by: Mike Turquette <mturquette@linaro.org> [t.figa: Updated patch description.] Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-15packet: fix send path when running with proto == 0Daniel Borkmann
[ Upstream commit 66e56cd46b93ef407c60adcac62cf33b06119d50 ] Commit e40526cb20b5 introduced a cached dev pointer, that gets hooked into register_prot_hook(), __unregister_prot_hook() to update the device used for the send path. We need to fix this up, as otherwise this will not work with sockets created with protocol = 0, plus with sll_protocol = 0 passed via sockaddr_ll when doing the bind. So instead, assign the pointer directly. The compiler can inline these helper functions automagically. While at it, also assume the cached dev fast-path as likely(), and document this variant of socket creation as it seems it is not widely used (seems not even the author of TX_RING was aware of that in his reference example [1]). Tested with reproducer from e40526cb20b5. [1] http://wiki.ipxwarzone.com/index.php5?title=Linux_packet_mmap#Example Fixes: e40526cb20b5 ("packet: fix use after free race in send path when dev is released") Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Tested-by: Salam Noureddine <noureddine@aristanetworks.com> Tested-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09libata: disable a disk via libata.force paramsRobin H. Johnson
commit b8bd6dc36186fe99afa7b73e9e2d9a98ad5c4865 upstream. A user on StackExchange had a failing SSD that's soldered directly onto the motherboard of his system. The BIOS does not give any option to disable it at all, so he can't just hide it from the OS via the BIOS. The old IDE layer had hdX=noprobe override for situations like this, but that was never ported to the libata layer. This patch implements a disable flag for libata.force. Example use: libata.force=2.0:disable [v2 of the patch, removed the nodisable flag per Tejun Heo] Signed-off-by: Robin H. Johnson <robbat2@gentoo.org> Signed-off-by: Tejun Heo <tj@kernel.org> Link: http://unix.stackexchange.com/questions/102648/how-to-tell-linux-kernel-3-0-to-completely-ignore-a-failing-disk Link: http://askubuntu.com/questions/352836/how-can-i-tell-linux-kernel-to-completely-ignore-a-disk-as-if-it-was-not-even-co Link: http://superuser.com/questions/599333/how-to-disable-kernel-probing-for-drive Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08tcp: tsq: restore minimal amount of queueingEric Dumazet
[ Upstream commit 98e09386c0ef4dfd48af7ba60ff908f0d525cdee ] After commit c9eeec26e32e ("tcp: TSQ can use a dynamic limit"), several users reported throughput regressions, notably on mvneta and wifi adapters. 802.11 AMPDU requires a fair amount of queueing to be effective. This patch partially reverts the change done in tcp_write_xmit() so that the minimal amount is sysctl_tcp_limit_output_bytes. It also remove the use of this sysctl while building skb stored in write queue, as TSO autosizing does the right thing anyway. Users with well behaving NICS and correct qdisc (like sch_fq), can then lower the default sysctl_tcp_limit_output_bytes value from 128KB to 8KB. This new usage of sysctl_tcp_limit_output_bytes permits each driver authors to check how their driver performs when/if the value is set to a minimum of 4KB. Normally, line rate for a single TCP flow should be possible, but some drivers rely on timers to perform TX completion and too long TX completion delays prevent reaching full throughput. Fixes: c9eeec26e32e ("tcp: TSQ can use a dynamic limit") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Sujith Manoharan <sujith@msujith.org> Reported-by: Arnaud Ebalard <arno@natisbad.org> Tested-by: Sujith Manoharan <sujith@msujith.org> Cc: Felix Fietkau <nbd@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04vsprintf: check real user/group id for %pKRyan Mallon
commit 312b4e226951f707e120b95b118cbc14f3d162b2 upstream. Some setuid binaries will allow reading of files which have read permission by the real user id. This is problematic with files which use %pK because the file access permission is checked at open() time, but the kptr_restrict setting is checked at read() time. If a setuid binary opens a %pK file as an unprivileged user, and then elevates permissions before reading the file, then kernel pointer values may be leaked. This happens for example with the setuid pppd application on Ubuntu 12.04: $ head -1 /proc/kallsyms 00000000 T startup_32 $ pppd file /proc/kallsyms pppd: In file /proc/kallsyms: unrecognized option 'c1000000' This will only leak the pointer value from the first line, but other setuid binaries may leak more information. Fix this by adding a check that in addition to the current process having CAP_SYSLOG, that effective user and group ids are equal to the real ids. If a setuid binary reads the contents of a file which uses %pK then the pointer values will be printed as NULL if the real user is unprivileged. Update the sysctl documentation to reflect the changes, and also correct the documentation to state the kptr_restrict=0 is the default. This is a only temporary solution to the issue. The correct solution is to do the permission check at open() time on files, and to replace %pK with a function which checks the open() time permission. %pK uses in printk should be removed since no sane permission check can be done, and instead protected by using dmesg_restrict. Signed-off-by: Ryan Mallon <rmallon@gmail.com> Cc: Kees Cook <keescook@chromium.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Joe Perches <joe@perches.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Sorry I let so much accumulate, I was in Buffalo and wanted a few things to cook in my tree for a while before sending to you. Anyways, it's a lot of little things as usual at this stage in the game" 1) Make bonding MAINTAINERS entry reflect reality, from Andy Gospodarek. 2) Fix accidental sock_put() on timewait mini sockets, from Eric Dumazet. 3) Fix crashes in l2tp due to mis-handling of ipv4 mapped ipv6 addresses, from François CACHEREUL. 4) Fix heap overflow in __audit_sockaddr(), from the eagle eyed Dan Carpenter. 5) tcp_shifted_skb() doesn't take handle FINs properly, from Eric Dumazet. 6) SFC driver bug fixes from Ben Hutchings. 7) Fix TX packet scheduling wedge after channel change in ath9k driver, from Felix Fietkau. 8) Fix user after free in BPF JIT code, from Alexei Starovoitov. 9) Source address selection test is reversed in __ip_route_output_key(), fix from Jiri Benc. 10) VLAN and CAN layer mis-size netlink attributes, from Marc Kleine-Budde. 11) Fix permission checks in sysctls to use current_euid() instead of current_uid(). From Eric W Biederman. 12) IPSEC policies can go away while a timer is still pending for them, add appropriate ref-counting to fix, from Steffen Klassert. 13) Fix mis-programming of FDR and RMCR registers on R8A7740 sh_eth chips, from Nguyen Hong Ky and Simon Horman. 14) MLX4 forgets to DMA unmap pages on RX, fix from Amir Vadai. 15) IPV6 GRE tunnel MTU upper limit is miscalculated, from Oussama Ghorbel. 16) Fix typo in fq_change(), we were assigning "initial quantum" to "quantum". From Eric Dumazet. 17) Set a more appropriate sk_pacing_rate for non-TCP sockets, otherwise FQ packet scheduler does not pace those flows properly. Also from Eric Dumazet. 18) rtlwifi miscalculates packet pointers, from Mark Cave-Ayland. 19) l2tp_xmit_skb() can be called from process context, not just softirq context, so we must always make sure to BH disable around it. From Eric Dumazet. 20) On qdisc reset, we forget to purge the RB tree of SKBs in netem packet scheduler. From Stephen Hemminger. 21) Fix info leak in farsync WAN driver ioctl() handler, from Dan Carpenter and Salva Peiró. 22) Fix PHY reset and other issues in dm9000 driver, from Nikita Kiryanov and Michael Abbott. 23) When hardware can do SCTP crc32 checksums, we accidently don't disable the csum offload when IPSEC transformations have been applied. From Fan Du and Vlad Yasevich. 24) Tail loss probing in TCP leaves the socket in the wrong congestion avoidance state. From Yuchung Cheng. 25) In CPSW driver, enable NAPI before interrupts are turned on, from Markus Pargmann. 26) Integer underflow and dual-assignment in YAM hamradio driver, from Dan Carpenter. 27) If we are going to mangle a packet in tcp_set_skb_tso_segs() we must unclone it. This fixes various hard to track down crashes in drivers where the SKBs ->gso_segs was changing right from underneath the driver during TX queueing. From Eric Dumazet. 28) Fix the handling of VLAN IDs, and in particular the special IDs 0 and 4095, in the bridging layer. From Toshiaki Makita. 29) Another info leak, this time in wanxl WAN driver, from Salva Peiró. 30) Fix race in socket credential passing, from Daniel Borkmann. 31) WHen NETLABEL is disabled, we don't validate CIPSO packets properly, from Seif Mazareeb. 32) Fix identification of fragmented frames in ipv4/ipv6 UDP Fragmentation Offload output paths, from Jiri Pirko. 33) Virtual Function fixes in bnx2x driver from Yuval Mintz and Ariel Elior. 34) When we removed the explicit neighbour pointer from ipv6 routes a slight regression was introduced for users such as IPVS, xt_TEE, and raw sockets. We mix up the users requested destination address with the routes assigned nexthop/gateway. From Julian Anastasov and Simon Horman. 35) Fix stack overruns in rt6_probe(), the issue is that can end up doing two full packet xmit paths at the same time when emitting neighbour discovery messages. From Hannes Frederic Sowa. 36) davinci_emac driver doesn't handle IFF_ALLMULTI correctly, from Mariusz Ceier. 37) Make sure to set TCP sk_pacing_rate after the first legitimate RTT sample, from Neal Cardwell. 38) Wrong netlink attribute passed to xfrm_replay_verify_len(), from Steffen Klassert. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (152 commits) ax88179_178a: Add VID:DID for Samsung USB Ethernet Adapter ax88179_178a: Correct the RX error definition in RX header Revert "bridge: only expire the mdb entry when query is received" tcp: initialize passive-side sk_pacing_rate after 3WHS davinci_emac.c: Fix IFF_ALLMULTI setup mac802154: correct a typo in ieee802154_alloc_device() prototype ipv6: probe routes asynchronous in rt6_probe netfilter: nf_conntrack: fix rt6i_gateway checks for H.323 helper ipv6: fill rt6i_gateway with nexthop address ipv6: always prefer rt6i_gateway if present bnx2x: Set NETIF_F_HIGHDMA unconditionally bnx2x: Don't pretend during register dump bnx2x: Lock DMAE when used by statistic flow bnx2x: Prevent null pointer dereference on error flow bnx2x: Fix config when SR-IOV and iSCSI are enabled bnx2x: Fix Coalescing configuration bnx2x: Unlock VF-PF channel on MAC/VLAN config error bnx2x: Prevent an illegal pointer dereference during panic bnx2x: Fix Maximum CoS estimation for VFs drivers: net: cpsw: fix kernel warn during iperf test with interrupt pacing ...
2013-10-15Merge tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull device tree fixes and reverts from Grant Likely: "One bug fix and three reverts. The reverts back out the slightly controversial feeding the entire device tree into the random pool and the reserved-memory binding which isn't fully baked yet. Expect the reserved-memory patches at least to resurface for v3.13. The bug fixes removes a scary but harmless warning on SPARC that was introduced in the v3.12 merge window. v3.13 will contain a proper fix that makes the new code work on SPARC. On the plus side, the diffstat looks *awesome*. I love removing lines of code" * tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux: Revert "drivers: of: add initialization code for dma reserved memory" Revert "ARM: init: add support for reserved memory defined by device tree" Revert "of: Feed entire flattened device tree into the random pool" of: fix unnecessary warning on missing /cpus node
2013-10-15Revert "drivers: of: add initialization code for dma reserved memory"Marek Szyprowski
This reverts commit 9d8eab7af79cb4ce2de5de39f82c455b1f796963. There is still no consensus on the bindings for the reserved memory and various drawbacks of the proposed solution has been shown, so the best now is to revert it completely and start again from scratch later. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-10-14Merge tag 'pm+acpi-3.12-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael Wysocki: "These fix two recent bugs in ACPIPHP (ACPI-based PCI hotplug) and update a bunch of web links and e-mail addresses in MAINTAINERS, docs and Kconfig that either are stale or will expire soon. Specifics: - The WARN_ON() in acpiphp_enumerate_slots() triggers as a false positive in some cases, so drop it. - Add a missing pci_dev_put() to an error code path in acpiphp_enumerate_slots(). - Replace my old e-mail address that's going to expire with a new one. - Update ACPI web links and git tree information in MAINTAINERS. - Update links to the Linux-ACPI project's page in MAINTAINERS. - Update some stale links and e-mail addresses under Documentation and in the ACPI Kconfig file" * tag 'pm+acpi-3.12-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / hotplug / PCI: Drop WARN_ON() from acpiphp_enumerate_slots() ACPI / hotplug / PCI: Fix error code path in acpiphp_enumerate_slots() ACPI / PM / Documentation: Replace outdated project links and addresses MAINTAINERS / ACPI: Update links to the Linux-ACPI project web page MAINTAINERS / ACPI: Update links and git tree information MAINTAINERS / Documentation: Update Rafael's e-mail address
2013-10-12Merge tag 'sound-3.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "All stable fixes except for a trivial headset mic fixup: the removal of bogus frame checks in snd-usb-usx2y driver that have regressed in the recent kernel versions, the HD-audio HDMI channel map fix, and a few HD-audio device-specific fixes" * tag 'sound-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Sony VAIO Pro 13 (haswell) now has a working headset jack ALSA: hda - Add a headset mic model for ALC269 and friends ALSA: hda - Fix microphone for Sony VAIO Pro 13 (Haswell model) ALSA: hda - Add fixup for ASUS N56VZ ALSA: hda - hdmi: Fix channel map switch not taking effect ALSA: hda - Fix mono speakers and headset mic on Dell Vostro 5470 ALSA: snd-usb-usx2y: remove bogus frame checks
2013-10-11ACPI / PM / Documentation: Replace outdated project links and addressesRafael J. Wysocki
Some links to projects web pages and e-mail addresses in ACPI/PM documentation and Kconfig are outdated, so update them. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-11ALSA: hda - Add a headset mic model for ALC269 and friendsDavid Henningsson
Using the headset mic model will cause the headset mic to be labeled "headset mic" instead of just "mic". Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-10-09MAINTAINERS / Documentation: Update Rafael's e-mail addressRafael J. Wysocki
The e-mail address rjw@sisk.pl that I have been using for quite some time is going to expire at one point, so replace it with a new one, rjw@rjwysocki.net, everywhere in MAINTAINERS and Documentation/ABI. Signed-off-by: Rafael J. Wysocki <rjw@rjwysocki.net>
2013-10-02Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "We have a fairly large batch of fixes this time around, mostly just due to various platforms all having a fix or two more than usual. Worth pointing out are: - A fix for EDMA on Davinci/OMAP where channel allocation broke with the DT conversion. Due to some miscommunication we didn't understand the impact of the breakage, so we were pushing back on it for 3.12, but it sounds like it's actually breaking quite a few people out there. - A bunch of fixes for Marvell platforms, some straggling fixes for merge window fallout and some fixes for a couple of the platforms (Netgear RN102 in particular). - A fix for a race between multi-cluster power management and cpu hotplug on Versatile Express. And a bunch of other smaller fixes that all add up. We'll be switching over into stricter regressions-only mode from here on out" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (31 commits) ARM: multi_v7_defconfig: add SDHCI for i.MX bus: mvebu-mbus: Fix optional pcie-mem/io-aperture properties ARM: mvebu: add missing DT Mbus ranges and relocate PCIe DT nodes for RN102 ARM: at91: sam9g45: shutdown ddr1 too when rebooting MAINTAINERS: ARM: SIRF: use kernel.org mail box MAINTAINERS: ARM: SIRF: add missed drivers into maintain list ARM: edma: Fix clearing of unused list for DT DMA resources ARM: vexpress: tc2: fix hotplug/idle/kexec race on cluster power down ARM: dts: sirf: fix interrupt and dma prop of VIP for prima2 and atlas6 ARM: dts: sirf: fix the ranges of peri-iobrg of prima2 ARM: dts: makefile: build atlas6-evb.dtb for ARCH_ATLAS6 ARM: dts: sirf: fix fifosize, clks, dma channels for UART ARM: mvebu: Add DT entry for ReadyNAS 102 to use gpio-poweroff driver ARM: mvebu: fix ReadyNAS 102 Power button GPIO to make it active high ARM: mach-integrator: Add stub for pci_v3_early_init() for !CONFIG_PCI ARM: shmobile: Remove #gpio-ranges-cells DT property gpio: rcar: Remove #gpio-range-cells DT property usage ARM: shmobile: armadillo: fixup ether pinctrl naming ARM: shmobile: Lager: add Micrel KSZ8041 PHY fixup ARM: shmobile: update SDHI DT compatibility string to the <unit>-<soc> format ...
2013-10-02connector - documentation: simplify netlink message length assignmentMathias Krause
Use the precalculated size instead of obfuscating the message length calculation by first subtracting the netlink header length from size and then use the NLMSG_LENGTH() macro to add it back again. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking changes from David Miller: 1) Multiply in netfilter IPVS can overflow when calculating destination weight. From Simon Kirby. 2) Use after free fixes in IPVS from Julian Anastasov. 3) SFC driver bug fixes from Daniel Pieczko. 4) Memory leak in pcan_usb_core failure paths, from Alexey Khoroshilov. 5) Locking and encapsulation fixes to serial line CAN driver, from Andrew Naujoks. 6) Duplex and VF handling fixes to bnx2x driver from Yaniv Rosner, Eilon Greenstein, and Ariel Elior. 7) In lapb, if no other packets are outstanding, T1 timeouts actually stall things and no packet gets sent. Fix from Josselin Costanzi. 8) ICMP redirects should not make it to the socket error queues, from Duan Jiong. 9) Fix bugs in skge DMA mapping error handling, from Nikulas Patocka. 10) Fix setting of VLAN priority field on via-rhine driver, from Roget Luethi. 11) Fix TX stalls and VLAN promisc programming in be2net driver from Ajit Khaparde. 12) Packet padding doesn't get handled correctly in new usbnet SG support code, from Ming Lei. 13) Fix races in netdevice teardown wrt. network namespace closing. From Eric W. Biederman. 14) Fix potential missed initialization of net_secret if not TCP connections are openned. From Eric Dumazet. 15) Cinterion PLXX product ID in qmi_wwan driver is wrong, from Aleksander Morgado. 16) skb_cow_head() can change skb->data and thus packet header pointers, don't use stale ip_hdr reference in ip_tunnel code. 17) Backend state transition handling fixes in xen-netback, from Paul Durrant. 18) Packet offset for AH protocol is handled wrong in flow dissector, from Eric Dumazet. 19) Taking down an fq packet scheduler instance can leave stale packets in the queues, fix from Eric Dumazet. 20) Fix performance regressions introduced by TCP Small Queues. From Eric Dumazet. 21) IPV6 GRE tunneling code calculates max_headroom incorrectly, from Hannes Frederic Sowa. 22) Multicast timer handlers in ipv4 and ipv6 can be the last and final reference to the ipv4/ipv6 specific network device state, so use the reference put that will check and release the object if the reference hits zero. From Salam Noureddine. 23) Fix memory corruption in ip_tunnel driver, and use skb_push() instead of __skb_push() so that similar bugs are less hard to find. From Steffen Klassert. 24) Add forgotten hookup of rtnl_ops in SIT and ip6tnl drivers, from Nicolas Dichtel. 25) fq scheduler doesn't accurately rate limit in certain circumstances, from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (103 commits) pkt_sched: fq: rate limiting improvements ip6tnl: allow to use rtnl ops on fb tunnel sit: allow to use rtnl ops on fb tunnel ip_tunnel: Remove double unregister of the fallback device ip_tunnel_core: Change __skb_push back to skb_push ip_tunnel: Add fallback tunnels to the hash lists ip_tunnel: Fix a memory corruption in ip_tunnel_xmit qlcnic: Fix SR-IOV configuration ll_temac: Reset dma descriptors indexes on ndo_open skbuff: size of hole is wrong in a comment ipv6 mcast: use in6_dev_put in timer handlers instead of __in6_dev_put ipv4 igmp: use in_dev_put in timer handlers instead of __in_dev_put ethernet: moxa: fix incorrect placement of __initdata tag ipv6: gre: correct calculation of max_headroom powerpc/83xx: gianfar_ptp: select 1588 clock source through dts file Revert "powerpc/83xx: gianfar_ptp: select 1588 clock source through dts file" bonding: Fix broken promiscuity reference counting issue tcp: TSQ can use a dynamic limit dm9601: fix IFF_ALLMULTI handling pkt_sched: fq: qdisc dismantle fixes ...
2013-09-30powerpc/83xx: gianfar_ptp: select 1588 clock source through dts fileAida Mynzhasova
Currently IEEE 1588 timer reference clock source is determined through hard-coded value in gianfar_ptp driver. This patch allows to select ptp clock source by means of device tree file node. For instance: fsl,cksel = <0>; for using external (TSEC_TMR_CLK input) high precision timer reference clock. Other acceptable values: <1> : eTSEC system clock <2> : eTSEC1 transmit clock <3> : RTC clock input When this attribute isn't used, eTSEC system clock will serve as IEEE 1588 timer reference clock. Signed-off-by: Aida Mynzhasova <aida.mynzhasova@skitlab.ru> Acked-by: Kumar Gala <galak@codeaurora.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-30Revert "powerpc/83xx: gianfar_ptp: select 1588 clock source through dts file"David S. Miller
This reverts commit 894116bd0e9b7749a0c4b6c62dec13c2a0ccef68. I applied the wrong version of this patch, correct version coming up. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-30block: change config option name for cmdline partition parsingPaul Gortmaker
Recently commit bab55417b10c ("block: support embedded device command line partition") introduced CONFIG_CMDLINE_PARSER. However, that name is too generic and sounds like it enables/disables generic kernel boot arg processing, when it really is block specific. Before this option becomes a part of a full/final release, add the BLK_ prefix to it so that it is clear in absence of any other context that it is block specific. In addition, fix up the following less critical items: - help text was not really at all helpful. - index file for Documentation was not updated - add the new arg to Documentation/kernel-parameters.txt - clarify wording in source comments Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Cai Zhiyong <caizhiyong@huawei.com> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-30Documentation/kernel-parameters.txt: replace kernelcore with MovableWeiping Pan
Han Pingtian found a typo in Documentation/kernel-parameters.txt about "kernelcore=", that "kernelcore" should be replaced with "Movable" here. Signed-off-by: Weiping Pan <wpan@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
Currently IEEE 1588 timer reference clock source is determined through hard-coded value in gianfar_ptp driver. This patch allows to select ptp clock source by means of device tree file node. For instance: fsl,cksel = <0>; for using external (TSEC_TMR_CLK input) high precision timer reference clock. Other acceptable values: <1> : eTSEC system clock <2> : eTSEC1 transmit clock <3> : RTC clock input When this attribute isn't used, eTSEC system clock will serve as IEEE 1588 timer reference clock. Signed-off-by: Aida Mynzhasova <aida.mynzhasova@skitlab.ru> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-30Merge tag 'asoc-v3.12-rc2' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Fixes for v3.12 Nothing too exciting here, all driver specific except for the fix from Liam for DPCM systems which have both front and back end DAIs which is not yet used by anything in mainline.
2013-09-29Merge tag 'tty-3.12-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial fixes from Greg KH: "Here are some serial at tty driver fixes for 3.12-rc3 The serial driver fixes some kref leaks, documentation is moved to the proper places, and the tty and n_tty fixes resolve some reported regressions. There is still one outstanding tty regression fix that isn't in here yet, as I want to test it out some more, it will be sent for 3.12-rc4 if it checks out" * tag 'tty-3.12-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: tty: ar933x_uart: move devicetree binding documentation tty: Fix SIGTTOU not sent with tcflush() n_tty: Fix EOF push index when termios changes serial: pch_uart: remove unnecessary tty_port_tty_get serial: pch_uart: fix tty-kref leak in dma-rx path serial: pch_uart: fix tty-kref leak in rx-error path serial: tegra: fix tty-kref leak
2013-09-28Merge tag 'devicetree-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull DeviceTree fixes from Rob Herring: "Clean-up to fix some warnings for !OF builds and spelling fixes in docs: - Clean-up openrisc prom.h - Fix warnings caused by of_irq.h ifdefs - Spelling fix for Synopsys" * tag 'devicetree-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: dts: Fix misspelling of Synopsys of: clean-up ifdefs in of_irq.h openrisc: clean-up prom.h
2013-09-27Merge tag 'sound-3.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Nothing too serious here: a couple of compress-offload core fixes, Haswell HDMI audio fix, a fixup for new MacBook Airs and a few COEF setups for ALC283 mic problems" * tag 'sound-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Enable internal mic on a Thinkpad machine with ALC283 ALSA: hda - Fix Internal Mic boost can't control with ALC283 ALSA: hda - Add documentation for CS4208 fixups ALSA: hda - Add fixup for MacBook Air 6,1 and 6,2 with CS4208 codec ALSA : hda - not use assigned converters for all unused pins ALSA: compress: Make sure we trigger STOP before closing the stream. ALSA: compress: Fix compress device unregister.
2013-09-27ALSA: hda - Add documentation for CS4208 fixupsTakashi Iwai
2013-09-26tty: ar933x_uart: move devicetree binding documentationGabor Juhos
Commit 'tty: ar933x_uart: add device tree support and binding documentation' introduced a new doc in bindins/tty/serial. According to a recent thread [1] on the linux-serial list, the binding documentation of serial drivers should be added into bindings/serial. Move the documentation of qca,ar9330-uart to the correct place. 1. http://marc.info/?l=linux-serial&m=137771295411517 Cc: devicetree@vger.kernel.org Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-25Merge tag 'stable/for-linus-3.12-rc2-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen fixes from Konrad Rzeszutek Wilk: "Bug-fixes and one update to the kernel-paramters.txt documentation. - Fix PV spinlocks triggering jump_label code bug - Remove extraneous code in the tpm front driver - Fix ballooning out of pages when non-preemptible - Fix deadlock when using a 32-bit initial domain with large amount of memory - Add xen_nopvpsin parameter to the documentation" * tag 'stable/for-linus-3.12-rc2-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/spinlock: Document the xen_nopvspin parameter. xen/p2m: check MFN is in range before using the m2p table xen/balloon: don't alloc page while non-preemptible xen: Do not enable spinlocks before jump_label_init() has executed tpm: xen-tpmfront: Remove the locality sysfs attribute tpm: xen-tpmfront: Fix default durations
2013-09-25xen/spinlock: Document the xen_nopvspin parameter.Konrad Rzeszutek Wilk
Which disables in the ticketlock slowpath the Xen PV optimization's. Useful for diagnosing issues and comparing benchmarks in over-commit CPU scenarios. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-09-24dts: Fix misspelling of Synopsysdevicetree-fixesDinh Nguyen
s/Synopsis/Synopsys s/synopsis/synopsys Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Cc: Pavel Machek <pavel@denx.de> CC: Arnd Bergmann <arnd@arndb.de> CC: Olof Johansson <olof@lixom.net> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Chris Ball <cjb@laptop.org> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Seungwon Jeon <tgih.jun@samsung.com> Cc: Tomasz Figa <tomasz.figa@gmail.com> Cc: devicetree@vger.kernel.org Cc: linux-mmc@vger.kernel.org CC: linux-arm-kernel@lists.infradead.org Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-09-21ARM: shmobile: update SDHI DT compatibility string to the <unit>-<soc> formatGuennadi Liakhovetski
Currently DT compatibility strings of both types can be found in the kernel sources: <unit>-<soc> and <soc>-<unit>, whereas a unique format should be followed and the former one is preferred. This patch converts the SDHI MMC driver and its users to the common standard. This is safe for now, since ATM no real products are using this driver with DT. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski+renesas@gmail.com> Acked-by: Chris Ball <cjb@laptop.org> [Removed r8a7740.dtsi portion as it is not applicable] Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2013-09-20Merge tag 'arm64-stable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64 Pull ARM64 fixes from Catalin Marinas: - Compat register fault reporting fix - Documentation clarification on tagged pointers - hwcap widened to 64-bit (user space already reading it as 64-bit) * tag 'arm64-stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64: arm64: Widen hwcap to be 64 bit arm64: Correctly report LR and SP for compat tasks arm64: documentation: tighten up tagged pointer documentation arm64: Make do_bad_area() function static
2013-09-20arm64: documentation: tighten up tagged pointer documentationWill Deacon
Commit d50240a5f6ce ("arm64: mm: permit use of tagged pointers at EL0") added support for tagged pointers in userspace, but the corresponding update to Documentation/ contained some imprecise statements. This patch fixes up some minor ambiguities in the text, hopefully making it more clear about exactly what the kernel expects from user virtual addresses. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2013-09-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) If the local_df boolean is set on an SKB we have to allocate a unique ID even if IP_DF is set in the ipv4 headers, from Ansis Atteka. 2) Some fixups for the new chipset support that went into the sfc driver, from Ben Hutchings. 3) Because SCTP bypasses a good chunk of, and actually duplicates, the logic of the ipv6 output path, some IPSEC things don't get done properly. Integrate SCTP better into the ipv6 output path so that these problems are fixed and such issues don't get missed in the future either. From Daniel Borkmann. 4) Fix skge regressions added by the DMA mapping error return checking added in v3.10, from Mikulas Patocka. 5) Kill some more IRQF_DISABLED references, from Michael Opdenacker. 6) Fix races and deadlocks in the bridging code, from Hong Zhiguo. 7) Fix error handling in tun_set_iff(), in particular don't leak resources. From Jason Wang. 8) Prevent format-string injection into xen-netback driver, from Kees Cook. 9) Fix regression added to netpoll ARP packet handling, in particular check for the right ETH_P_ARP protocol code. From Sonic Zhang. 10) Try to deal with AMD IOMMU errors when using r8169 chips, from Francois Romieu. 11) Cure freezes due to recent changes in the rt2x00 wireless driver, from Stanislaw Gruszka. 12) Don't do SPI transfers (which can sleep) in interrupt context in cw1200 driver, from Solomon Peachy. 13) Fix LEDs handling bug in 5720 tg3 chips already handled for 5719. From Nithin Sujir. 14) Make xen_netbk_count_skb_slots() count the actual number of slots that will be used, taking into consideration packing and other issues that the transmit path will run into. From David Vrabel. 15) Use the correct maximum age when calculating the bridge message_age_timer, from Chris Healy. 16) Get rid of memory leaks in mcs7780 IRDA driver, from Alexey Khoroshilov. 17) Netfilter conntrack extensions were converted to RCU but are not always freed properly using kfree_rcu(). Fix from Michal Kubecek. 18) VF reset recovery not being done correctly in qlcnic driver, from Manish Chopra. 19) Fix inverted test in ATM nicstar driver, from Andy Shevchenko. 20) Missing workqueue destroy in cxgb4 error handling, from Wei Yang. 21) Internal switch not initialized properly in bgmac driver, from Rafał Miłecki. 22) Netlink messages report wrong local and remote addresses in IPv6 tunneling, from Ding Zhi. 23) ICMP redirects should not generate socket errors in DCCP and SCTP. We're still working out how this should be handled for RAW and UDP sockets. From Daniel Borkmann and Duan Jiong. 24) We've had several bugs wherein the network namespace's loopback device gets accessed after it is free'd, NULL it out so that we can catch these problems more readily. From Eric W Biederman. 25) Fix regression in TCP RTO calculations, from Neal Cardwell. 26) Fix too early free of xen-netback network device when VIFs still exist. From Paul Durrant. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (87 commits) netconsole: fix a deadlock with rtnl and netconsole's mutex netpoll: fix NULL pointer dereference in netpoll_cleanup skge: fix broken driver ip: generate unique IP identificator if local fragmentation is allowed ip: use ip_hdr() in __ip_make_skb() to retrieve IP header xen-netback: Don't destroy the netdev until the vif is shut down net:dccp: do not report ICMP redirects to user space cnic: Fix crash in cnic_bnx2x_service_kcq() bnx2x, cnic, bnx2i, bnx2fc: Fix bnx2i and bnx2fc regressions. vxlan: Avoid creating fdb entry with NULL destination tcp: fix RTO calculated from cached RTT drivers: net: phy: cicada.c: clears warning Use #include <linux/io.h> instead of <asm/io.h> net loopback: Set loopback_dev to NULL when freed batman-adv: set the TAG flag for the vid passed to BLA netfilter: nfnetlink_queue: use network skb for sequence adjustment net: sctp: rfc4443: do not report ICMP redirects to user space net: usb: cdc_ether: use usb.h macros whenever possible net: usb: cdc_ether: fix checkpatch errors and warnings net: usb: cdc_ether: Use wwan interface for Telit modules ip6_tunnels: raddr and laddr are inverted in nl msg ...
2013-09-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "atomic_open-related fixes (Miklos' series, with EEXIST-related parts replaced with fix in fs/namei.c:atomic_open() instead of messing with the instances) + race fix in autofs + leak on failure exit in 9p" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: 9p: don't forget to destroy inode cache if fscache registration fails atomic_open: take care of EEXIST in no-open case with O_CREAT|O_EXCL in fs/namei.c vfs: don't set FILE_CREATED before calling ->atomic_open() nfs: set FILE_CREATED gfs2: set FILE_CREATED cifs: fix filp leak in cifs_atomic_open() vfs: improve i_op->atomic_open() documentation autofs4: close the races around autofs4_notify_daemon()
2013-09-18Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Misc fixes" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched: Fix comment for sched_info_depart sched/Documentation: Update sched-design-CFS.txt documentation sched/debug: Take PID namespace into account sched/fair: Fix small race where child->se.parent,cfs_rq might point to invalid ones
2013-09-16vfs: improve i_op->atomic_open() documentationMiklos Szeredi
Fix documentation of ->atomic_open() and related functions: finish_open() and finish_no_open(). Also add details that seem to be unclear and a source of bugs (some of which are fixed in the following series). Cc-ing maintainers of all filesystems implementing ->atomic_open(). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Sage Weil <sage@inktank.com> Cc: Steve French <sfrench@samba.org> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-09-16Merge branch 'timers/core' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer code update from Thomas Gleixner: - armada SoC clocksource overhaul with a trivial merge conflict - Minor improvements to various SoC clocksource drivers * 'timers/core' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: clocksource: armada-370-xp: Add detailed clock requirements in devicetree binding clocksource: armada-370-xp: Get reference fixed-clock by name clocksource: armada-370-xp: Replace WARN_ON with BUG_ON clocksource: armada-370-xp: Fix device-tree binding clocksource: armada-370-xp: Introduce new compatibles clocksource: armada-370-xp: Use CLOCKSOURCE_OF_DECLARE clocksource: armada-370-xp: Simplify TIMER_CTRL register access clocksource: armada-370-xp: Use BIT() ARM: timer-sp: Set dynamic irq affinity ARM: nomadik: add dynamic irq flag to the timer clocksource: sh_cmt: 32-bit control register support clocksource: em_sti: Convert to devm_* managed helpers
2013-09-16Merge branch 'for-next' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fixes from Steve French: "Two minor cifs fixes and a minor documentation cleanup for cifs.txt" * 'for-next' of git://git.samba.org/sfrench/cifs-2.6: cifs: update cifs.txt and remove some outdated infos cifs: Avoid calling unlock_page() twice in cifs_readpage() when using fscache cifs: Do not take a reference to the page in cifs_readpage_worker()
2013-09-15bonding: Make alb learning packet interval configurableNeil Horman
running bonding in ALB mode requires that learning packets be sent periodically, so that the switch knows where to send responding traffic. However, depending on switch configuration, there may not be any need to send traffic at the default rate of 3 packets per second, which represents little more than wasted data. Allow the ALB learning packet interval to be made configurable via sysfs Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Acked-by: Veaceslav Falico <vfalico@redhat.com> CC: Jay Vosburgh <fubar@us.ibm.com> CC: Andy Gospodarek <andy@greyhouse.net> CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-15Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull misc SCSI driver updates from James Bottomley: "This patch set is a set of driver updates (megaraid_sas, fnic, lpfc, ufs, hpsa) we also have a couple of bug fixes (sd out of bounds and ibmvfc error handling) and the first round of esas2r checker fixes and finally the much anticipated big endian additions for megaraid_sas" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (47 commits) [SCSI] fnic: fnic Driver Tuneables Exposed through CLI [SCSI] fnic: Kernel panic while running sh/nosh with max lun cfg [SCSI] fnic: Hitting BUG_ON(io_req->abts_done) in fnic_rport_exch_reset [SCSI] fnic: Remove QUEUE_FULL handling code [SCSI] fnic: On system with >1.1TB RAM, VIC fails multipath after boot up [SCSI] fnic: FC stat param seconds_since_last_reset not getting updated [SCSI] sd: Fix potential out-of-bounds access [SCSI] lpfc 8.3.42: Update lpfc version to driver version 8.3.42 [SCSI] lpfc 8.3.42: Fixed issue of task management commands having a fixed timeout [SCSI] lpfc 8.3.42: Fixed inconsistent spin lock usage. [SCSI] lpfc 8.3.42: Fix driver's abort loop functionality to skip IOs already getting aborted [SCSI] lpfc 8.3.42: Fixed failure to allocate SCSI buffer on PPC64 platform for SLI4 devices [SCSI] lpfc 8.3.42: Fix WARN_ON when driver unloads [SCSI] lpfc 8.3.42: Avoided making pci bar ioremap call during dual-chute WQ/RQ pci bar selection [SCSI] lpfc 8.3.42: Fixed driver iocbq structure's iocb_flag field running out of space [SCSI] lpfc 8.3.42: Fix crash on driver load due to cpu affinity logic [SCSI] lpfc 8.3.42: Fixed logging format of setting driver sysfs attributes hard to interpret [SCSI] lpfc 8.3.42: Fixed back to back RSCNs discovery failure. [SCSI] lpfc 8.3.42: Fixed race condition between BSG I/O dispatch and timeout handling [SCSI] lpfc 8.3.42: Fixed function mode field defined too small for not recognizing dual-chute mode ...
2013-09-13cifs: update cifs.txt and remove some outdated infosBjörn Jacke
Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Björn JACKE <bj@sernet.de> Signed-off-by: Steve French <smfrench@gmail.com>
2013-09-12Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This has been sitting in -next for a while with no objections and all MIPS defconfigs except one are building fine; that one platform got broken by another patch in your tree and I'm going to submit a patch separately. - a handful of fixes that didn't make 3.11 - a few bits of Octeon 3 support with more to come for a later release - platform enhancements for Octeon, ath79, Lantiq, Netlogic and Ralink SOCs - a GPIO driver for the Octeon - some dusting off of the DECstation code - the usual dose of cleanups" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (65 commits) MIPS: DMA: Fix BUG due to smp_processor_id() in preemptible code MIPS: kexec: Fix random crashes while loading crashkernel MIPS: kdump: Skip walking indirection page for crashkernels MIPS: DECstation HRT calibration bug fixes MIPS: Export copy_from_user_page() (needed by lustre) MIPS: Add driver for the built-in PCI controller of the RT3883 SoC MIPS: DMA: For BMIPS5000 cores flush region just like non-coherent R10000 MIPS: ralink: Add support for reset-controller API MIPS: ralink: mt7620: Add cpu-feature-override header MIPS: ralink: mt7620: Add spi clock definition MIPS: ralink: mt7620: Add wdt clock definition MIPS: ralink: mt7620: Improve clock frequency detection MIPS: ralink: mt7620: This SoC has EHCI and OHCI hosts MIPS: ralink: mt7620: Add verbose ram info MIPS: ralink: Probe clocksources from OF MIPS: ralink: Add support for systick timer found on newer ralink SoC MIPS: ralink: Add support for periodic timer irq MIPS: Netlogic: Built-in DTB for XLP2xx SoC boards MIPS: Netlogic: Add support for USB on XLP2xx MIPS: Netlogic: XLP2xx update for I2C controller ...
2013-09-12Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge more patches from Andrew Morton: "The rest of MM. Plus one misc cleanup" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (35 commits) mm/Kconfig: add MMU dependency for MIGRATION. kernel: replace strict_strto*() with kstrto*() mm, thp: count thp_fault_fallback anytime thp fault fails thp: consolidate code between handle_mm_fault() and do_huge_pmd_anonymous_page() thp: do_huge_pmd_anonymous_page() cleanup thp: move maybe_pmd_mkwrite() out of mk_huge_pmd() mm: cleanup add_to_page_cache_locked() thp: account anon transparent huge pages into NR_ANON_PAGES truncate: drop 'oldsize' truncate_pagecache() parameter mm: make lru_add_drain_all() selective memcg: document cgroup dirty/writeback memory statistics memcg: add per cgroup writeback pages accounting memcg: check for proper lock held in mem_cgroup_update_page_stat memcg: remove MEMCG_NR_FILE_MAPPED memcg: reduce function dereference memcg: avoid overflow caused by PAGE_ALIGN memcg: rename RESOURCE_MAX to RES_COUNTER_MAX memcg: correct RESOURCE_MAX to ULLONG_MAX mm: memcg: do not trap chargers with full callstack on OOM mm: memcg: rework and document OOM waiting and wakeup ...
2013-09-12memcg: document cgroup dirty/writeback memory statisticsSha Zhengju
Signed-off-by: Sha Zhengju <handai.szj@taobao.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Greg Thelen <gthelen@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 4 from Al Viro: "list_lru pile, mostly" This came out of Andrew's pile, Al ended up doing the merge work so that Andrew didn't have to. Additionally, a few fixes. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (42 commits) super: fix for destroy lrus list_lru: dynamically adjust node arrays shrinker: Kill old ->shrink API. shrinker: convert remaining shrinkers to count/scan API staging/lustre/libcfs: cleanup linux-mem.h staging/lustre/ptlrpc: convert to new shrinker API staging/lustre/obdclass: convert lu_object shrinker to count/scan API staging/lustre/ldlm: convert to shrinkers to count/scan API hugepage: convert huge zero page shrinker to new shrinker API i915: bail out earlier when shrinker cannot acquire mutex drivers: convert shrinkers to new count/scan API fs: convert fs shrinkers to new scan/count API xfs: fix dquot isolation hang xfs-convert-dquot-cache-lru-to-list_lru-fix xfs: convert dquot cache lru to list_lru xfs: rework buffer dispose list tracking xfs-convert-buftarg-lru-to-generic-code-fix xfs: convert buftarg LRU to generic code fs: convert inode and dentry shrinking to be node aware vmscan: per-node deferred work ...
