path: root/Documentation
2013-09-03fix execute permissionsTroy Kisky
2012-07-20ENGR00178933-2 [MX6] USB DOC: Add USB auto remote wake up docmake shi
Add USB auto remote wake up unit test method to udc doc. Signed-off-by: make shi <b15407@freescale.com>
2012-07-20ENGR00170819-2 usb-gadget: add test document for usb audioPeter Chen
Add test document Signed-off-by: Peter Chen <peter.chen@freescale.com>
2012-07-20ENGR00170548-2 [IMX6Q] USB-HOST:Add Doc for USB video and audio testmake shi
Add USB video and audio unit test method to host doc Signed-off-by: make shi <b15407@freescale.com>
2012-07-20ENGR00169885-2 usb-udc: Add Doc for udcPeter Chen
Add remote wakeup test method to udc doc Signed-off-by: Peter Chen <peter.chen@freescale.com>
2012-06-01docs: update HOWTO for 2.6.x -> 3.x versioningKees Cook
commit 591bfc6bf9e5e25e464fd4c87d64afd5135667c4 upstream. The HOWTO document needed updating for the new kernel versioning. The git URI for -next was updated as well. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21tcp: change tcp_adv_win_scale and tcp_rmem[2]Eric Dumazet
[ Upstream commit b49960a05e32121d29316cfdf653894b88ac9190 ] tcp_adv_win_scale default value is 2, meaning we expect a good citizen skb to have skb->len / skb->truesize ratio of 75% (3/4) In 2.6 kernels we (mis)accounted for typical MSS=1460 frame : 1536 + 64 + 256 = 1856 'estimated truesize', and 1856 * 3/4 = 1392. So these skbs were considered as not bloated. With recent truesize fixes, a typical MSS=1460 frame truesize is now the more precise : 2048 + 256 = 2304. But 2304 * 3/4 = 1728. So these skb are not good citizen anymore, because 1460 < 1728 (GRO can escape this problem because it build skbs with a too low truesize.) This also means tcp advertises a too optimistic window for a given allocated rcvspace : When receiving frames, sk_rmem_alloc can hit sk_rcvbuf limit and we call tcp_prune_queue()/tcp_collapse() too often, especially when application is slow to drain its receive queue or in case of losses (netperf is fast, scp is slow). This is a major latency source. We should adjust the len/truesize ratio to 50% instead of 75% This patch : 1) changes tcp_adv_win_scale default to 1 instead of 2 2) increase tcp_rmem[2] limit from 4MB to 6MB to take into account better truesize tracking and to allow autotuning tcp receive window to reach same value than before. Note that same amount of kernel memory is consumed compared to 2.6 kernels. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Tom Herbert <therbert@google.com> Cc: Yuchung Cheng <ycheng@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12hwmon: (jc42) Add support for AT30TS00, TS3000GB2, TSE2002GB2, and MCP9804Guenter Roeck
commit 1bd612a25855f4cc9345052b53d7da697dba6358 upstream. Also update IDT datasheet locations. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12hwmon: (jc42) Add support for ST Microelectronics STTS2002 and STTS3000Jean Delvare
commit 4de86126a712ba83fa038d277c8282f7ed466a4b upstream. These are fully compatible with Jedec JC 42.4 as far as I can see. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-12USB: update documentation for usbmonAlan Stern
commit d8cae98cddd286e38db1724dda1b0e7b467f9237 upstream. The documentation for usbmon is out of date; the usbfs "devices" file now exists in /sys/kernel/debug/usb rather than /proc/bus/usb. This patch (as1505) updates the documentation accordingly, and also mentions that the necessary information can be found by running lsusb. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12Documentation: Update stable addressJoe Perches
commit 2eb7f204db51969ea558802a6601d79c2fb273b9 upstream. The Japanese/Korean/Chinese versions still need updating. Also, the stable kernel 2.6.x.y descriptions are out of date and should be updated as well. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11PM / Runtime: Automatically retry failed autosuspendsAlan Stern
commit 886486b792e4f6f96d4fbe8ec5bf20811cab7d6a upstream. Originally, the runtime PM core would send an idle notification whenever a suspend attempt failed. The idle callback routine could then schedule a delayed suspend for some time later. However this behavior was changed by commit f71648d73c1650b8b4aceb3856bebbde6daa3b86 (PM / Runtime: Remove idle notification after failing suspend). No notifications were sent, and there was no clear mechanism to retry failed suspends. This caused problems for the usbhid driver, because it fails autosuspend attempts as long as a key is being held down. Therefore this patch (as1492) adds a mechanism for retrying failed autosuspends. If the callback routine updates the last_busy field so that the next autosuspend expiration time is in the future, the autosuspend will automatically be rescheduled. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11hwspinlock/core: use a mutex to protect the radix treeJuan Gutierrez
commit 93b465c2e186d96fb90012ba0f9372eb9952e732 upstream. Since we're using non-atomic radix tree allocations, we should be protecting the tree using a mutex and not a spinlock. Non-atomic allocations and process context locking is good enough, as the tree is manipulated only when locks are registered/ unregistered/requested/freed. The locks themselves are still protected by spinlocks of course, and mutexes are not involved in the locking/unlocking paths. Signed-off-by: Juan Gutierrez <jgutierrez@ti.com> [ohad@wizery.com: rewrite the commit log, #include mutex.h, add minor commentary] [ohad@wizery.com: update register/unregister parts in hwspinlock.txt] Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11Update email address for stable patch submissionJosh Boyer
commit 5fa224295f0e0358c8bc0e5390702338df889def upstream. The stable@kernel.org email address has been replaced with the stable@vger.kernel.org mailing list. Change the stable kernel rules to reference the new list instead of the semi-defunct email alias. Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-17lguest: allow booting guest with CONFIG_RELOCATABLE=yRusty Russell
commit e22a539824e8ddb82c87b4f415165ede82e6ab56 upstream. The CONFIG_RELOCATABLE code tries to align the unpack destination to the value of 'kernel_alignment' in the setup_hdr. If that's 0, it tries to unpack to address 0, which in fact causes the gunzip code to call 'error("Out of memory while allocating output buffer")'. The bootloader (ie. the lguest Launcher in this case) should be doing setting this field; the normal bzImage is 16M, we can use the same. Reported-by: Stefanos Geraggelos <sgerag@cslab.ece.ntua.gr> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-20Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86. reboot: Make Dell Latitude E6320 use reboot=pci x86, doc only: Correct real-mode kernel header offset for init_size x86: Disable AMD_NUMA for 32bit for now
2011-07-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2: nilfs2: remove resize from unsupported features list
2011-07-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (21 commits) slip: fix wrong SLIP6 ifdef-endif placing natsemi: fix another dma-debug report sctp: ABORT if receive, reassmbly, or reodering queue is not empty while closing socket net: Fix default in docs for tcp_orphan_retries. hso: fix a use after free condition net/natsemi: Fix module parameter permissions XFRM: Fix memory leak in xfrm_state_update sctp: Enforce retransmission limit during shutdown mac80211: fix TKIP replay vulnerability mac80211: fix ie memory allocation for scheduled scans ssb: fix init regression of hostmode PCI core rtlwifi: rtl8192cu: Add new USB ID for Netgear WNA1000M ath9k: Fix tx throughput drops for AR9003 chips with AES encryption carl9170: add NEC WL300NU-AG usbid cfg80211: fix deadlock with rfkill/sched_scan by adding new mutex ath5k: fix incorrect use of drvdata in PCI suspend/resume code ath5k: fix incorrect use of drvdata in sysfs code Bluetooth: Fix memory leak under page timeouts Bluetooth: Fix regression with incoming L2CAP connections Bluetooth: Fix hidp disconnect deadlocks and lost wakeup ...
2011-07-13nilfs2: remove resize from unsupported features listRyusuke Konishi
Resize feature was supported by the commit 4e33f9eab07e but it was not reflected to the list of unsupported features in nilfs2.txt file. This updates the list to fix discrepancy. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2011-07-12x86, doc only: Correct real-mode kernel header offset for init_sizeDarren Hart
The real-mode kernel header init_size field is located at 0x260 per the field listing in th e"REAL-MODE KERNEL HEADER" section. It is listed as 0x25c in the "DETAILS OF HEADER FIELDS" section, which overlaps with pref_address. Correct the details listing to 0x260. Signed-off-by: Darren Hart <dvhart@linux.intel.com> Link: http://lkml.kernel.org/r/541cf88e2dfe5b8186d8b96b136d892e769a68c1.1310441260.git.dvhart@linux.intel.com CC: H. Peter Anvin <hpa@zytor.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-07-11Documentation/Changes: remove some really obsolete textLinus Torvalds
That file harkens back to the days of the big 2.4 -> 2.6 version jump, and was based even then on older versions. Some of it is just obsolete, and Jesper Juhl points out that it talks about kernel versions 2.6 and should be updated to 3.0. Remove some obsolete text, and re-phrase some other to not be 2.6-specific. Reported-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-11Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: [media] msp3400: fill in v4l2_tuner based on vt->type field [media] tuner-core.c: don't change type field in g_tuner or g_frequency [media] cx18/ivtv: fix g_tuner support [media] tuner-core: power up tuner when called with s_power(1) [media] v4l2-ioctl.c: check for valid tuner type in S_HW_FREQ_SEEK [media] tuner-core: simplify the standard fixup [media] tuner-core/v4l2-subdev: document that the type field has to be filled in [media] v4l2-subdev.h: remove unused s_mode tuner op [media] feature-removal-schedule: change in how radio device nodes are handled [media] bttv: fix s_tuner for radio [media] pvrusb2: fix g/s_tuner support [media] v4l2-ioctl.c: prefill tuner type for g_frequency and g/s_tuner [media] tuner-core: fix tuner_resume: use t->mode instead of t->type [media] tuner-core: fix s_std and s_tuner
2011-07-11Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86: hp-wmi: fix use after free dell-laptop - using buffer without mutex_lock Revert: "dell-laptop: Toggle the unsupported hardware killswitch" platform-drivers-x86: set backlight type to BACKLIGHT_PLATFORM thinkpad-acpi: handle HKEY 0x4010, 0x4011 events drivers/platform/x86: Fix memory leak thinkpad-acpi: handle some new HKEY 0x60xx events acer-wmi: fix bitwise bug when set device state acer-wmi: Only update rfkill status for associated hotkey events
2011-07-11Documentation/spinlocks.txt: Remove reference to sti()/cli()Muthu Kumar
Since we removed sti()/cli() and related, how about removing it from Documentation/spinlocks.txt? Signed-off-by: Muthukumar R <muthur@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: conditional resource-reallocation through kernel parameter pci=realloc
2011-07-08PCI: conditional resource-reallocation through kernel parameter pci=reallocRam Pai
Multiple attempts to dynamically reallocate pci resources have unfortunately lead to regressions. Though we continue to fix the regressions and fine tune the dynamic-reallocation behavior, we have not reached a acceptable state yet. This patch provides a interim solution. It disables dynamic reallocation by default, but adds the ability to enable it through pci=realloc kernel command line parameter. Tested-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-07-08net: Fix default in docs for tcp_orphan_retries.David S. Miller
Default should be listed at 8 instead of 7. Reported-by: Denys Fedoryshchenko <denys@visp.net.lb> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-07FS-Cache: Add a helper to bulk uncache pages on an inodeDavid Howells
Add an FS-Cache helper to bulk uncache pages on an inode. This will only work for the circumstance where the pages in the cache correspond 1:1 with the pages attached to an inode's page cache. This is required for CIFS and NFS: When disabling inode cookie, we were returning the cookie and setting cifsi->fscache to NULL but failed to invalidate any previously mapped pages. This resulted in "Bad page state" errors and manifested in other kind of errors when running fsstress. Fix it by uncaching mapped pages when we disable the inode cookie. This patch should fix the following oops and "Bad page state" errors seen during fsstress testing. ------------[ cut here ]------------ kernel BUG at fs/cachefiles/namei.c:201! invalid opcode: 0000 [#1] SMP Pid: 5, comm: kworker/u:0 Not tainted 2.6.38.7-30.fc15.x86_64 #1 Bochs Bochs RIP: 0010: cachefiles_walk_to_object+0x436/0x745 [cachefiles] RSP: 0018:ffff88002ce6dd00 EFLAGS: 00010282 RAX: ffff88002ef165f0 RBX: ffff88001811f500 RCX: 0000000000000000 RDX: 0000000000000000 RSI: 0000000000000100 RDI: 0000000000000282 RBP: ffff88002ce6dda0 R08: 0000000000000100 R09: ffffffff81b3a300 R10: 0000ffff00066c0a R11: 0000000000000003 R12: ffff88002ae54840 R13: ffff88002ae54840 R14: ffff880029c29c00 R15: ffff88001811f4b0 FS: 00007f394dd32720(0000) GS:ffff88002ef00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00007fffcb62ddf8 CR3: 000000001825f000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process kworker/u:0 (pid: 5, threadinfo ffff88002ce6c000, task ffff88002ce55cc0) Stack: 0000000000000246 ffff88002ce55cc0 ffff88002ce6dd58 ffff88001815dc00 ffff8800185246c0 ffff88001811f618 ffff880029c29d18 ffff88001811f380 ffff88002ce6dd50 ffffffff814757e4 ffff88002ce6dda0 ffffffff8106ac56 Call Trace: cachefiles_lookup_object+0x78/0xd4 [cachefiles] fscache_lookup_object+0x131/0x16d [fscache] fscache_object_work_func+0x1bc/0x669 [fscache] process_one_work+0x186/0x298 worker_thread+0xda/0x15d kthread+0x84/0x8c kernel_thread_helper+0x4/0x10 RIP cachefiles_walk_to_object+0x436/0x745 [cachefiles] ---[ end trace 1d481c9af1804caa ]--- I tested the uncaching by the following means: (1) Create a big file on my NFS server (104857600 bytes). (2) Read the file into the cache with md5sum on the NFS client. Look in /proc/fs/fscache/stats: Pages : mrk=25601 unc=0 (3) Open the file for read/write ("bash 5<>/warthog/bigfile"). Look in proc again: Pages : mrk=25601 unc=25601 Reported-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-and-Tested-by: Suresh Jayaraman <sjayaraman@suse.de> cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-07[media] feature-removal-schedule: change in how radio device nodes are handledHans Verkuil
Radio devices have weird side-effects when used with combined TV/radio tuners and the V4L2 spec is ambiguous on how it should work. This results in inconsistent driver behavior which makes life hard for everyone. Be more strict in when and how the switch between radio and tv mode takes place and make sure all drivers behave the same. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-07thinkpad-acpi: handle HKEY 0x4010, 0x4011 eventsHenrique de Moraes Holschuh
Handle events 0x4010 and 0x4011 so that we do not pester users about them. These events report when the thinkpad is docked/undocked to a native hotplug dock (i.e. one that does not need ACPI handling, nor is represented in the ACPI device tree). Such docks are based on USB 2.0/3.0, and also work as port replicators. We really want a proper dock class to report these, or at least new input EV_SW events. Since it is not clear which one to use yet, keep reporting them as vendor-specific ThinkPad events. WARNING: As defined by the thinkpad-acpi sysfs ABI rules of engagement, the vendor-specific events will be REMOVED as soon as generic events are made available (duplicate events are a big problem), with an appropriate update to the thinkpad-acpi sysfs/event ABI versioning. Userspace is already prepared to provide easy backwards compatibility for such changes when convenient to the distro (see acpi-fakekey). * Event 0x4010: docking to hotplug dock/port replicator * Event 0x4011: undocking from hotplug dock/port replicator Typical usecase would be to trigger display reconfiguration. Reports mention T410, T510, and series 3 docks/port replicators. Special thanks to Robert de Rooy for his extensive report and analysis of the situation. http://www.thinkwiki.org/wiki/ThinkPad_Port_Replicator_Series_3 http://www.thinkwiki.org/wiki/ThinkPad_Mini_Dock_Series_3 http://www.thinkwiki.org/wiki/ThinkPad_Mini_Dock_Plus_Series_3 http://www.thinkwiki.org/wiki/ThinkPad_Mini_Dock_Plus_Series_3_for_Mobile_Workstations http://lenovoblogs.com/insidethebox/?p=290 Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Reported-by: Claudius Hubig <claudiushubig@chubig.net> Reported-by: Doctor Bill <docbill@gmail.com> Reported-by: Korte Noack <gbk.noack@gmx.de> Reported-by: Robert de Rooy <robert.de.rooy@gmail.com> Reported-by: Sebastian Will <swill@csail.mit.edu> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-07-07thinkpad-acpi: handle some new HKEY 0x60xx eventsHenrique de Moraes Holschuh
Handle some user interface events from the newer Lenovo models. We are likely to do something smart with these events in the future, for now, hide the ones we are already certain about from the user and userspace both. * Events 0x6000 and 0x6005 are key-related. 0x6005 is not properly identified yet. Ignore these events, and do not report them. * Event 0x6040 has not been properly identified yet, and we don't know if it is important (looks like it isn't, but still...). Keep reporting it. * Change the message the driver outputs on unknown 0x6xxx events, as all recent events are not related to thermal alarms. Degrade log level from ALERT to WARNING. Thanks to all users who reported these events or asked about them in a number of mailing lists. Your help is highly appreciated, even if I did took a lot of time to act on them. For that I apologise. I will list those that identified the reasons for the events as "reported-by", and I apologise in advance if I leave anyone out: it was not done on purpose, I made the mistake of not properly tagging all event report emails separately, and might have missed some. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Reported-by: Markus Malkusch <markus@malkusch.de> Reported-by: Peter Giles <g1l3sp@gmail.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-07-06Documentation: fix cgroup blkio throttle filenamesAndrea Righi
All the blkio.throttle.* file names are incorrectly reported without ".throttle" in the documentation. Fix it. Signed-off-by: Andrea Righi <andrea@betterlinux.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-06Documentation: update CodingStyle memory allocatorsJesper Juhl
The list of available general purpose memory allocators in Documentation/CodingStyle chapter 14 is incomplete. This patch adds the missing vzalloc() to the list. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-03Merge branch 'pm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM / Runtime: Update documentation regarding driver removal PM: Documentation: fix typo: pm_runtime_idle_sync() doesn't exist.
2011-07-03Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: (k10temp) Update documentation for Fam12h hwmon-vid: Fix typo in VIA CPU name hwmon: (f71882fg) Add support for the F71869A hwmon: Use <> rather than () around my e-mail address hwmon: (emc6w201) Properly handle all errors
2011-07-03hwmon: (k10temp) Update documentation for Fam12hClemens Ladisch
Add some CPU series IDs and links to the Fam12h datasheets. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-07-03hwmon: (f71882fg) Add support for the F71869AHans de Goede
The F71869A is almost the same as the F71869F/E, except that it has the normal number of temp and pwm zones for a F71882FG derived chip, rather then the limited number of the F71869F/E. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Tested-by: Max Baldwin <archerseven@gmail.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-07-02PM / Runtime: Update documentation regarding driver removalRafael J. Wysocki
Commit e1866b33b1e89f077b7132daae3dfd9a594e9a1a (PM / Runtime: Rework runtime PM handling during driver removal) forgot to update the documentation in Documentation/power/runtime_pm.txt to match the new code in drivers/base/dd.c. Update that documentation to match the code it describes. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-07-02PM: Documentation: fix typo: pm_runtime_idle_sync() doesn't exist.Kevin Hilman
Replace reference to pm_runtime_idle_sync() in the driver core with pm_runtime_put_sync() which is used in the code. Signed-off-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-06-28Merge branch 'usb-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: MAINTAINERS: add myself as maintainer of USB/IP usb: r8a66597-hcd: fix cannot detect low/full speed device USB: ehci-ath79: fix a NULL pointer dereference USB: Add new FT232H chip to drivers/usb/serial/ftdi_sio.c usb/isp1760: Fix bug preventing the unlinking of control urbs USB: Fix up URB error codes to reflect implementation. xhci: Always set urb->status to zero for isoc endpoints. xhci: Add reset on resume quirk for asrock p67 host xHCI 1.0: Incompatible Device Error USB: don't let errors prevent system sleep USB: don't let the hub driver prevent system sleep USB: change maintainership of ohci-hcd and ehci-hcd xHCI 1.0: Force Stopped Event(FSE) xhci: Don't warn about zeroed bMaxBurst descriptor field. USB: Free bandwidth when usb_disable_device is called. xhci: Reject double add of active endpoints. USB: TI 3410/5052 USB Serial Driver: Fix mem leak when firmware is too big. usb: musb: gadget: clear TXPKTRDY flag when set FLUSHFIFO usb: musb: host: compare status for negative error values
2011-06-21PM / Domains: Update documentationRafael J. Wysocki
Commit 4d27e9dcff00a6425d779b065ec8892e4f391661 (PM: Make power domain callbacks take precedence over subsystem ones) forgot to update the device power management documentation to take changes made by it into account. Correct that mistake. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-06-21PM: Update documentation regarding sysdevsRafael J. Wysocki
The part of Documentation/power/devices.txt regarding sysdevs is not valid any more after commit 2e711c04dbbf7a7732a3f7073b1fc285d12b369d (PM: Remove sysdev suspend, resume and shutdown operations), so remove it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-06-21PM / Runtime: Update doc: usage count no longer incremented across system PMKevin Hilman
Commit e8665002477f0278f84f898145b1f141ba26ee26 (PM: Allow pm_runtime_suspend() to succeed during system suspend) removed usage count increment across system PM. Update doc to reflect this. Signed-off-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-06-19Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: Move RCU_BOOST #ifdefs to header file rcu: use softirq instead of kthreads except when RCU_BOOST=y rcu: Use softirq to address performance regression rcu: Simplify curing of load woes
2011-06-17USB: Fix up URB error codes to reflect implementation.Sarah Sharp
Documentation/usb/error-codes.txt mentions that urb->status can be set to -EXDEV, if the isochronous transfer was not fully completed. However, in practice, EHCI, UHCI, and OHCI all only set -EXDEV in the individual frame status, never in the URB status. Those host controller actually always pass in a zero status to usb_hcd_giveback_urb, and rely on the core to set the appropriate status value. The xHCI driver ran into issues with the uvcvideo driver when it tried to set -EXDEV in urb->status, because the driver refused to submit URBs, and the userspace camera application's video froze. Clean up the documentation to reflect the actual implementation. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Acked-by: Alan Stern <stern@rowland.harvard.edu>
2011-06-15Documentation: fix cgroup typos and formattingJörg Sommer
Fix format and spelling. Signed-off-by: Jörg Sommer <joerg@alea.gnuu.de> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15Documentation: update cgroupfs mount pointJörg Sommer
According to commit 676db4af0430 ("cgroupfs: create /sys/fs/cgroup to mount cgroupfs on") the canonical mountpoint for the cgroup filesystem is /sys/fs/cgroup. Hence, this should be used in the documentation. Signed-off-by: Jörg Sommer <joerg@alea.gnuu.de> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15Documentation: update kmemleak supported archsMaxin B. John
Instead of listing the architectures that are supported by kmemleak in Documentation/kmemleak.txt, just refer people to the list of supported architecutures in lib/Kconfig.debug so that Documentation/kmemleak.txt does not need more updates for this. Signed-off-by: Maxin B. John <maxin.john@gmail.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15Documentation: update printk-formats.txtAndrew Murray
This patch updates the incomplete documentation concerning the printk extended format specifiers. Signed-off-by: Andrew Murray <amurray@mpc-data.co.uk> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15Documentation/feature-removal-schedule.txt: remove ns_cgroup from ↵akpm@linux-foundation.org
feature-removal-schedule.txt Commit a77aea92010acf ("cgroup: remove the ns_cgroup") removed the ns_cgroup but it forgot to remove the related doc in feature-removal-schedule.txt. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Cc: Serge E. Hallyn <serge.hallyn@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
