git://git.kernel.org/pub/scm/linux/kernel/git/will/linux into kvm-arm/timer
User space defines the model to emulate to a guest and should therefore
decide which addresses are used for both the virtual CPU interface
directly mapped in the guest physical address space and for the emulated
distributor interface, which is mapped in software by the in-kernel VGIC
support.
Reviewed-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Christoffer Dall <c.dall@virtualopensystems.com>
On ARM some bits are specific to the model being emulated for the guest and
user space needs a way to tell the kernel about those bits. An example is mmio
device base addresses, where KVM must know the base address for a given device
to properly emulate mmio accesses within a certain address range or directly
map a device with virtualiation extensions into the guest address space.
We make this API ARM-specific as we haven't yet reached a consensus for a
generic API for all KVM architectures that will allow us to do something like
this.
git://linux-arm.org/linux-mr into for-arm-soc/arch-timers
Currently the documentation for the arch_timer devicetree binding only
lists "arm,armv7-timer".
Add "arm,armv8-timer" to the list of compatible strings.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Pull x86 EFI fixes from Peter Anvin:
"This is a collection of fixes for the EFI support. The controversial
bit here is a set of patches which bumps the boot protocol version as
part of fixing some serious problems with the EFI handover protocol,
used when booting under EFI using a bootloader as opposed to directly
from EFI. These changes should also make it a lot saner to support
cross-mode 32/64-bit EFI booting in the future. Getting these changes
into 3.8 means we avoid presenting an inconsistent ABI to bootloaders.
Other changes are display detection and fixing efivarfs."
* 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, efi: remove attribute check from setup_efi_pci
x86, build: Dynamically find entry points in compressed startup code
x86, efi: Fix PCI ROM handing in EFI boot stub, in 32-bit mode
x86, efi: Fix 32-bit EFI handover protocol entry point
x86, efi: Fix display detection in EFI boot stub
x86, boot: Define the 2.12 bzImage boot protocol
x86/boot: Fix minor fd leakage in tools/relocs.c
x86, efi: Set runtime_version to the EFI spec revision
x86, efi: fix 32-bit warnings in setup_efi_pci()
efivarfs: Delete dentry from dcache in efivarfs_file_write()
efivarfs: Never return ENOENT from firmware
efi, x86: Pass a proper identity mapping in efi_call_phys_prelog
efivarfs: Drop link count of the right inode
Pull dmraid fix from NeilBrown:
"Just one fix for md in 3.8
dmraid assess redundancy and replacements slightly inaccurately which
could lead to some degraded arrays failing to assemble."
* tag 'md-3.8-fixes' of git://neil.brown.name/md:
DM-RAID: Fix RAID10's check for sufficient redundancy
Define the 2.12 bzImage boot protocol: add xloadflags and additional
fields to allow the command line, initramfs and struct boot_params to
live above the 4 GiB mark.
The xloadflags now communicates if this is a 64-bit kernel with the
legacy 64-bit entry point and which of the EFI handover entry points
are supported.
Avoid adding new read flags to loadflags because of claimed
bootloaders testing the whole byte for == 1 to determine bzImageness
at least until the issue can be researched further.
This is based on patches by Yinghai Lu and David Woodhouse.
Originally-by: Yinghai Lu <yinghai@kernel.org>
Originally-by: David Woodhouse <dwmw2@infradead.org>
Acked-by: Yinghai Lu <yinghai@kernel.org>
Acked-by: David Woodhouse <dwmw2@infradead.org>
Acked-by: Matt Fleming <matt.fleming@intel.com>
Link: http://lkml.kernel.org/r/1359058816-7615-26-git-send-email-yinghai@kernel.org
Cc: Rob Landley <rob@landley.net>
Cc: Gokul Caushik <caushik1@gmail.com>
Cc: Josh Triplett <josh@joshtriplett.org>
Cc: Joe Millenbach <jmillenbach@gmail.com>
Pull ARM SoC fixes from Olof Johansson:
"Here's a long-pending fixes pull request for arm-soc (I didn't send
one in the -rc4 cycle).
The larger deltas are from:
- A fixup of error paths in the mvsdio driver
- Header file move for a driver that hadn't been properly converted
to multiplatform on i.MX, which was causing build failures when
included
- Device tree updates for at91 dealing mostly with their new pinctrl
setup merged in 3.8 and mistakes in those initial configs
The rest are the normal mix of small fixes all over the place; sunxi,
omap, imx, mvebu, etc, etc."
* tag 'fixes-for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits)
mfd: vexpress-sysreg: Don't skip initialization on probe
ARM: vexpress: Enable A7 cores in V2P-CA15_A7's Device Tree
ARM: vexpress: extend the MPIDR range used for pen release check
ARM: at91/dts: correct comment in at91sam9x5.dtsi for mii
ARM: at91/at91_dt_defconfig: add at91sam9n12 SoC to DT defconfig
ARM: at91/at91_dt_defconfig: remove memory specification to cmdline
ARM: at91/dts: add macb mii pinctrl config for kizbox
ARM: at91: rm9200: remake the BGA as default version
ARM: at91: fix gpios on i2c-gpio for RM9200 DT
ARM: at91/at91sam9x5 DTS: add SCK USART pins
ARM: at91/at91sam9x5 DTS: correct wrong PIO BANK values on u(s)arts
ARM: at91/at91-pinctrl documentation: fix typo and add some details
ARM: kirkwood: fix missing #interrupt-cells property
mmc: mvsdio: use devm_ API to simplify/correct error paths.
clk: mvebu/clk-cpu.c: fix memory leakage
ARM: OMAP2+: omap4-panda: add UART2 muxing for WiLink shared transport
ARM: OMAP2+: DT node Timer iteration fix
ARM: OMAP2+: Fix section warning for omap_init_ocp2scp()
ARM: OMAP2+: fix build break for omapdrm
ARM: OMAP2: Fix missing omap2xxx_clkt_vps_late_init function calls
Before attempting to activate a RAID array, it is checked for sufficient
redundancy. That is, we make sure that there are not too many failed
devices - or devices specified for rebuild - to undermine our ability to
activate the array. The current code performs this check twice - once to
ensure there were not too many devices specified for rebuild by the user
('validate_rebuild_devices') and again after possibly experiencing a failure
to read the superblock ('analyse_superblocks'). Neither of these checks are
sufficient. The first check is done properly but with insufficient
information about the possible failure state of the devices to make a good
determination if the array can be activated. The second check is simply
done wrong in the case of RAID10 because it doesn't account for the
independence of the stripes (i.e. mirror sets). The solution is to use the
properly written check ('validate_rebuild_devices'), but perform the check
after the superblocks have been read and we know which devices have failed.
This gives us one check instead of two and performs it in a location where
it can be done right.
Only RAID10 was affected and it was affected in the following ways:
- the code did not properly catch the condition where a user specified
a device for rebuild that already had a failed device in the same mirror
set. (This condition would, however, be caught at a deeper level in MD.)
- the code triggers a false positive and denies activation when devices in
independent mirror sets have failed - counting the failures as though they
were all in the same set.
The most likely place this error was introduced (or this patch should have
been included) is in commit 4ec1e369 - first introduced in v3.7-rc1.
Consequently this fix should also go in v3.7.y, however there is a
small conflict on the .version in raid_target, so I'll submit a
separate patch to -stable.
Cc: stable@vger.kernel.org
Signed-off-by: Jonathan Brassow <jbrassow@redhat.com>
Signed-off-by: NeilBrown <neilb@suse.de>
Implement the PSCI specification (ARM DEN 0022A) to control
virtual CPUs being "powered" on or off.
PSCI/KVM is detected using the KVM_CAP_ARM_PSCI capability.
A virtual CPU can now be initialized in a "powered off" state,
using the KVM_ARM_VCPU_POWER_OFF feature flag.
The guest can use either SMC or HVC to execute a PSCI function.
We use space #18 for floating point regs.
Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com>
The Cache Size Selection Register (CSSELR) selects the current Cache
Size ID Register (CCSIDR). You write which cache you are interested
in to CSSELR, and read the information out of CCSIDR.
Which cache numbers are valid is known by reading the Cache Level ID
Register (CLIDR).
To export this state to userspace, we add a KVM_REG_ARM_DEMUX
numberspace (17), which uses 8 bits to represent which register is
being demultiplexed (0 for CCSIDR), and the lower 8 bits to represent
this demultiplexing (in our case, the CSSELR value, which is 4 bits).
The following three ioctls are implemented:
- KVM_GET_REG_LIST
- KVM_GET_ONE_REG
- KVM_SET_ONE_REG
Now we have a table for all the cp15 registers, we can drive a generic
API.
The register IDs carry the following encoding:
ARM registers are mapped using the lower 32 bits. The upper 16 of that
is the register group type, or coprocessor number:
ARM 32-bit CP15 registers have the following id bit patterns:
0x4002 0000 000F <zero:1> <crn:4> <crm:4> <opc1:4> <opc2:3>
ARM 64-bit CP15 registers have the following id bit patterns:
0x4003 0000 000F <zero:1> <zero:4> <crm:4> <opc1:4> <zero:3>
For futureproofing, we need to tell QEMU about the CP15 registers the
host lets the guest access.
It will need this information to restore a current guest on a future
CPU or perhaps a future KVM which allow some of these to be changed.
We use a separate table for these, as they're only for the userspace API.
All interrupt injection is now based on the VM ioctl KVM_IRQ_LINE. This
works semantically well for the GIC as we in fact raise/lower a line on
a machine component (the gic). The IOCTL uses the follwing struct.
struct kvm_irq_level {
union {
__u32 irq; /* GSI */
__s32 status; /* not used for KVM_IRQ_LEVEL */
__u32 level; /* 0 or 1 */
ARM can signal an interrupt either at the CPU level, or at the in-kernel irqchip
(GIC), and for in-kernel irqchip can tell the GIC to use PPIs designated for
specific cpus. The irq field is interpreted like this:
bits: | 31 ... 24 | 23 ... 16 | 15 ... 0 |
field: | irq_type | vcpu_index | irq_number |
The irq_type field has the following values:
- irq_type[0]: out-of-kernel GIC: irq_number 0 is IRQ, irq_number 1 is FIQ
- irq_type[1]: in-kernel GIC: SPI, irq_number between 32 and 1019 (incl.)
(the vcpu_index field is ignored)
- irq_type[2]: in-kernel GIC: PPI, irq_number between 16 and 31 (incl.)
The irq_number thus corresponds to the irq ID in as in the GICv2 specs.
This is documented in Documentation/kvm/api.txt.
Targets KVM support for Cortex A-15 processors.
Contains all the framework components, make files, header files, some
tracing functionality, and basic user space API.
Only supported core is Cortex-A15 for now.
Most functionality is in arch/arm/kvm/* or arch/arm/include/asm/kvm_*.h.
The relation between PIN_BANK numbers and pio letters wasn't made very
clear.
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs
Pull f2fs fixes from Jaegeuk Kim:
o Support swap file and link generic_file_remap_pages
o Enhance the bio streaming flow and free section control
o Major bug fix on recovery routine
o Minor bug/warning fixes and code cleanups
* tag 'f2fs-for-3.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (22 commits)
f2fs: use _safe() version of list_for_each
f2fs: add comments of start_bidx_of_node
f2fs: avoid issuing small bios due to several dirty node pages
f2fs: support swapfile
f2fs: add remap_pages as generic_file_remap_pages
f2fs: add __init to functions in init_f2fs_fs
f2fs: fix the debugfs entry creation path
f2fs: add global mutex_lock to protect f2fs_stat_list
f2fs: remove the blk_plug usage in f2fs_write_data_pages
f2fs: avoid redundant time update for parent directory in f2fs_delete_entry
f2fs: remove redundant call to set_blocksize in f2fs_fill_super
f2fs: move f2fs_balance_fs to punch_hole
f2fs: add f2fs_balance_fs in several interfaces
f2fs: revisit the f2fs_gc flow
f2fs: check return value during recovery
f2fs: avoid null dereference in f2fs_acl_from_disk
f2fs: initialize newly allocated dnode structure
f2fs: update f2fs partition info about SIT/NAT layout
f2fs: update f2fs document to reflect SIT/NAT layout correctly
f2fs: remove unneeded INIT_LIST_HEAD at few places
"People are back from the holiday breaks, and it shows. Here are a
bunch of fixes for a number of platforms:
- A couple of small fixes for Nomadik
- A larger set of changes for kirkwood/mvebu
- uart driver selection, dt clocks, gpio-poweroff fixups, a few
__init annotation fixes and some error handling improvement in
their xor dma driver.
- i.MX had a couple of minor fixes (and a critical one for flexcan2
clock setup)
- MXS has a small board fix and a framebuffer bugfix
- A set of fixes for Samsung Exynos, fixing default bootargs and some
Exynos5440 clock issues
- A set of OMAP changes including PM fixes and a few sparse warning
fixups
All in all a bit more positive code delta than we'd ideally want to
see here, mostly from the OMAP PM changes, but nothing overly crazy."
* tag 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (44 commits)
ARM: clps711x: Fix bad merge of clockevents setup
ARM: highbank: save and restore L2 cache and GIC on suspend
ARM: highbank: add a power request clear
ARM: highbank: fix secondary boot and hotplug
ARM: highbank: fix typos with hignbank in power request functions
ARM: dts: fix highbank cpu mpidr values
ARM: dts: add device_type prop to cpu nodes on Calxeda platforms
ARM: mx5: Fix MX53 flexcan2 clock
ARM: OMAP2+: am33xx-hwmod: Fix wrongly terminated am33xx_usbss_mpu_irqs array
pinctrl: mvebu: make pdma clock on dove mandatory
ARM: Dove: Add pinctrl clock to DT
dma: mv_xor: fix error handling for clocks
dma: mv_xor: fix error handling of mv_xor_channel_add()
arm: mvebu: Add missing ; for cpu node.
arm: mvebu: Armada XP MV78230 has only three Ethernet interfaces
arm: mvebu: Armada XP MV78230 has two cores, not one
clk: mvebu: Remove inappropriate __init tagging
ARM: Kirkwood: Use fixed-regulator instead of board gpio call
ARM: Kirkwood: Fix missing sdio clock
ARM: Kirkwood: Switch TWSI1 of 88f6282 to DT clock providers
into fixes
From Shawn Guo:
It includes one critical fix - wrong flexcan2 clock will hang system
when the port gets brought up. The other two are non-critical fixes,
which are sent together here, since it's still early -rc stage.
* tag 'imx-fixes-3.8' of git://git.linaro.org/people/shawnguo/linux-2.6:
ARM: dts: imx31-bug: Fix manufacturer compatible string
clk: imx: Remove 'clock-output-names' from the examples
Pull networking fixes from David Miller:
1) New sysctl ndisc_notify needs some documentation, from Hanns
Frederic Sowa.
2) Netfilter REJECT target doesn't set transport header of SKB
correctly, from Mukund Jampala.
3) Forcedeth driver needs to check for DMA mapping failures, from Larry
Finger.
4) brcmsmac driver can't use usleep_range while holding locks, use
udelay instead. From Niels Ole Salscheider.
5) Fix unregister of netlink bridge multicast database handlers, from
Vlad Yasevich and Rami Rosen.
6) Fix checksum calculations in netfilter's ipv6 network prefix
translation module.
7) Fix high order page allocation failures in netfilter xt_recent, from
Eric Dumazet.
8) mac802154 needs to use netif_rx_ni() instead of netif_rx() because
mac802154_process_data() can execute in process rather than
interrupt context. From Alexander Aring.
9) Fix splice handling of MSG_SENDPAGE_NOTLAST, otherwise we elide one
tcp_push() too many. From Eric Dumazet and Willy Tarreau.
10) Fix skb->truesize tracking in XEN netfront driver, from Ian
Campbell.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (46 commits)
xen/netfront: improve truesize tracking
ipv4: fix NULL checking in devinet_ioctl()
tcp: fix MSG_SENDPAGE_NOTLAST logic
net/ipv4/ipconfig: really display the BOOTP/DHCP server's address.
ip-sysctl: fix spelling errors
mac802154: fix NOHZ local_softirq_pending 08 warning
ipv6: document ndisc_notify in networking/ip-sysctl.txt
ath9k: Fix Kconfig for ATH9K_HTC
netfilter: xt_recent: avoid high order page allocations
netfilter: fix missing dependencies for the NOTRACK target
netfilter: ip6t_NPT: fix IPv6 NTP checksum calculation
bridge: add empty br_mdb_init() and br_mdb_uninit() definitions.
vxlan: allow live mac address change
bridge: Correctly unregister MDB rtnetlink handlers
brcmfmac: fix parsing rsn ie for ap mode.
brcmsmac: add copyright information for Canonical
rtlwifi: rtl8723ae: Fix warning for unchecked pci_map_single() call
rtlwifi: rtl8192se: Fix warning for unchecked pci_map_single() call
rtlwifi: rtl8192de: Fix warning for unchecked pci_map_single() call
rtlwifi: rtl8192ce: Fix warning for unchecked pci_map_single() call
Pull ACPI and power management fixes from Rafael Wysocki:
- Removal of some ACPICA code that the kernel will never use from Lv
Zheng.
- APEI fix from Adrian Huang.
- Removal of unnecessary ACPI memory hotplug driver code from Liu
Jinsong.
- Minor ACPI power management fixes.
- ACPI debug code fix from Joe Perches.
- ACPI fix to make system bus device nodes get the right names.
- PNP resources handling fixes from Witold Szczeponik.
- cpuidle fix for a recent regression stalling boot on systems with
great numbers of CPUs from Daniel Lezcano.
- cpuidle fixes from Sivaram Nair.
- intel_idle debug message fix from Youquan Song.
- cpufreq build regression fix from Larry Finger.
- cpufreq fix for an obscure initialization race related to statistics
from Konstantin Khlebnikov.
- cpufreq change disabling the Longhaul driver by default from Rafał
Bilski.
- PM core fix preventing device suspend errors from happening during
system suspend due to obscure race conditions.
- PM QoS local variable name cleanup.
* tag 'pm+acpi-for-3.8-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
PM: Move disabling/enabling runtime PM to late suspend/early resume
PM / QoS: Rename local variable in dev_pm_qos_add_ancestor_request()
ACPI / scan: Do not use dummy HID for system bus ACPI nodes
cpufreq / governor: Fix problem with cpufreq_ondemand or cpufreq_conservative
cpufreq / Longhaul: Disable driver by default
cpufreq / stats: fix race between stats allocation and first usage
cpuidle: fix lock contention in the idle path
intel_idle: pr_debug information need separated
cpuidle / coupled: fix ready counter decrement
cpuidle: Fix finding state with min power_usage
PNP: Handle IORESOURCE_BITS in resource allocation
PNP: Simplify setting of resources
ACPI / power: Remove useless message from device registering routine
ACPI / glue: Update DBG macro to include KERN_DEBUG
ACPI / PM: Do not apply ACPI_SUCCESS() to acpi_bus_get_device() result
ACPI / memhotplug: remove redundant logic of acpi memory hotadd
ACPI / APEI: Fix the returned value in erst_dbg_read
ACPICA: Remove useless mini-C library.
Improve the documentation to clarify level vs edge triggered power off.
Improve the comments for level vs edge triggered power off.
Make use of gpio_is_valid().
Reported-by: Stephen Warren <swarren@wwwdotorg.org>
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Currently, the PM core disables runtime PM for all devices right
after executing subsystem/driver .suspend() callbacks for them
and re-enables it right before executing subsystem/driver .resume()
callbacks for them. This may lead to problems when there are
two devices such that the .suspend() callback executed for one of
them depends on runtime PM working for the other. In that case,
if runtime PM has already been disabled for the second device,
the first one's .suspend() won't work correctly (and analogously
for resume).
To make those issues go away, make the PM core disable runtime PM
for devices right before executing subsystem/driver .suspend_late()
callbacks for them and enable runtime PM for them right after
executing subsystem/driver .resume_early() callbacks for them. This
way the potential conflitcs between .suspend_late()/.resume_early()
and their runtime PM counterparts are still prevented from happening,
but the subtle ordering issues related to disabling/enabling runtime
PM for devices during system suspend/resume are much easier to avoid.
Reported-and-tested-by: Jan-Matthias Braun <jan_braun@gmx.net>
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com>
Cc: 3.4+ <stable@vger.kernel.org>
Signed-off-by: Carlos Alberto Lopez Perez <clopez@igalia.com>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: Neil Horman <nhorman@tuxdriver.com>
Cc: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com>
Cc: Tejun Heo <tj@kernel.org>
Add 3 new variables and sysctls to tune them (by one "next_id" variable
for messages, semaphores and shared memory respectively). This variable
can be used to set desired id for next allocated IPC object. By default
it's equal to -1 and old behaviour is preserved. If this variable is
non-negative, then desired idr will be extracted from it and used as a
start value to search for free IDR slot.
Notes:
1) this patch doesn't guarantee that the new object will have desired
id. So it's up to user space how to handle new object with wrong id.
2) After a sucessful id allocation attempt, "next_id" will be set back
to -1 (if it was non-negative).
[akpm@linux-foundation.org: checkpatch fixes]
Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com>
Cc: Serge Hallyn <serge.hallyn@canonical.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
I slipped in a new sysctl without proper documentation. I would like to
make up for this now.
'clock-output-names' is not used in any of the dts/dtsi files for i.mx.
Remove it from the examples, so that the example and the real usage in the
dtsi files can match.
Acked-by: Rob Herring <rob.herring@calxeda.com>
document to reflect the layout generated by mkfs.f2fs .
Signed-off-by: Huajun Li <huajun.li.lee@gmail.com>
Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core __dev* removal patches - take 3 - from Greg Kroah-Hartman:
"Here are the remaining __dev* removal patches against the 3.8-rc2
tree. All of these patches were previously sent to the subsystem
maintainers, most of them were picked up and pushed to you, but there
were a number that fell through the cracks, and new drivers were added
during the merge window, so this series cleans up the rest of the
instances of these markings.
Third time's the charm...
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
Fixed up trivial conflict with the pinctrl pull in pinctrl-sirf.c.
* tag 'driver-core-3.8-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (54 commits)
misc: remove __dev* attributes.
include: remove __dev* attributes.
Documentation: remove __dev* attributes.
Drivers: misc: remove __dev* attributes.
Drivers: block: remove __dev* attributes.
Drivers: bcma: remove __dev* attributes.
Drivers: char: remove __dev* attributes.
Drivers: clocksource: remove __dev* attributes.
Drivers: ssb: remove __dev* attributes.
Drivers: dma: remove __dev* attributes.
Drivers: gpu: remove __dev* attributes.
Drivers: infinband: remove __dev* attributes.
Drivers: memory: remove __dev* attributes.
Drivers: mmc: remove __dev* attributes.
Drivers: iommu: remove __dev* attributes.
Drivers: power: remove __dev* attributes.
Drivers: message: remove __dev* attributes.
Drivers: macintosh: remove __dev* attributes.
Drivers: mfd: remove __dev* attributes.
pstore: remove __dev* attributes.
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from the kernel documentation.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pinctrl fixes from Linus Walleij:
"A first round of pinctrl fixes for v3.8:
- i.MX5 register configuration
- Swap a kfree to devm_kfree() to avoid memory corruption in the at91
driver
- Add the missing device tree binding doc for the SIRF pin controller
- Enable the SIRF GPIO pull up/down configuration from the device
tree, it was previously retired from the hard-coded approach.
- NULL check for the prcm_base in the Nomadik pin controller.
- Provide the prcm_base from the device tree in the DT boot path for
the Nomadik pin controller."
* tag 'pinctrl-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl:
ARM: ux500: add pinctrl address resources
pinctrl: nomadik: return if prcm_base is NULL
pinctrl: sirf: enable GPIO pullup/down configuration from dts
pinctrl: sirf: add missing DT-binding document
pinctrl: fix comment mistake
drivers/pinctrl/pinctrl-at91.c: convert kfree to devm_kfree
pinctrl: imx5: fix GPIO_8 pad CAN1_RXCAN configuration
Add DT support for twl4030_wdt. This is needed to get twl4030_wdt to
probe when booting with DT.
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
commit 7bec207427c2efb794 remove sirfsoc_gpio_set_pull function,
this patches takes the feature back by adding sirf,pullups and
sirf,pulldowns prop in dts, and the driver will set the GPIO
pull according to the dts.
Signed-off-by: Barry Song <Baohua.Song@csr.com>
While sending email to Linus for reviewing:
"pinctrl: sirf: add DT-binding pinmux mapping support"
https://patchwork.kernel.org/patch/1364361/
i have included the devicetree/bindings/pinctrl/pinctrl-sirf.txt
But while sending pull request with commit 056876f6c73406c,
i missed the document.
this patch takes the document back.
Pull watchdog updates from Wim Van Sebroeck:
"This includes some fixes and code improvements (like
clk_prepare_enable and clk_disable_unprepare), conversion from the
omap_wdt and twl4030_wdt drivers to the watchdog framework, addition
of the SB8x0 chipset support and the DA9055 Watchdog driver and some
OF support for the davinci_wdt driver."
* git://www.linux-watchdog.org/linux-watchdog: (22 commits)
watchdog: mei: avoid oops in watchdog unregister code path
watchdog: Orion: Fix possible null-deference in orion_wdt_probe
watchdog: sp5100_tco: Add SB8x0 chipset support
watchdog: davinci_wdt: add OF support
watchdog: da9052: Fix invalid free of devm_ allocated data
watchdog: twl4030_wdt: Change TWL4030_MODULE_PM_RECEIVER to TWL_MODULE_PM_RECEIVER
watchdog: remove depends on CONFIG_EXPERIMENTAL
watchdog: Convert dev_printk(KERN_<LEVEL> to dev_<level>(
watchdog: DA9055 Watchdog driver
watchdog: omap_wdt: eliminate goto
watchdog: omap_wdt: delete redundant platform_set_drvdata() calls
watchdog: omap_wdt: convert to devm_ functions
watchdog: omap_wdt: convert to new watchdog core
watchdog: WatchDog Timer Driver Core: fix comment
watchdog: s3c2410_wdt: use clk_prepare_enable and clk_disable_unprepare
watchdog: imx2_wdt: Select the driver via ARCH_MXC
watchdog: cpu5wdt.c: add missing del_timer call
watchdog: hpwdt.c: Increase version string
watchdog: Convert twl4030_wdt to watchdog core
davinci_wdt: preparation for switch to common clock framework
Merge the rest of Andrew's patches for -rc1:
"A bunch of fixes and misc missed-out-on things.
That'll do for -rc1. I still have a batch of IPC patches which still
have a possible bug report which I'm chasing down."
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (25 commits)
keys: use keyring_alloc() to create module signing keyring
keys: fix unreachable code
sendfile: allows bypassing of notifier events
SGI-XP: handle non-fatal traps
fat: fix incorrect function comment
Documentation: ABI: remove testing/sysfs-devices-node
proc: fix inconsistent lock state
linux/kernel.h: fix DIV_ROUND_CLOSEST with unsigned divisors
memcg: don't register hotcpu notifier from ->css_alloc()
checkpatch: warn on uapi #includes that #include <uapi/...
revert "rtc: recycle id when unloading a rtc driver"
mm: clean up transparent hugepage sysfs error messages
hfsplus: add error message for the case of failure of sync fs in delayed_sync_fs() method
hfsplus: rework processing of hfs_btree_write() returned error
hfsplus: rework processing errors in hfsplus_free_extents()
hfsplus: avoid crash on failed block map free
kcmp: include linux/ptrace.h
drivers/rtc/rtc-imxdi.c: must include <linux/spinlock.h>
mm: cma: WARN if freed memory is still in use
exec: do not leave bprm->interp on stack
Pull VFS update from Al Viro:
"fscache fixes, ESTALE patchset, vmtruncate removal series, assorted
misc stuff."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (79 commits)
vfs: make lremovexattr retry once on ESTALE error
vfs: make removexattr retry once on ESTALE
vfs: make llistxattr retry once on ESTALE error
vfs: make listxattr retry once on ESTALE error
vfs: make lgetxattr retry once on ESTALE
vfs: make getxattr retry once on an ESTALE error
vfs: allow lsetxattr() to retry once on ESTALE errors
vfs: allow setxattr to retry once on ESTALE errors
vfs: allow utimensat() calls to retry once on an ESTALE error
vfs: fix user_statfs to retry once on ESTALE errors
vfs: make fchownat retry once on ESTALE errors
vfs: make fchmodat retry once on ESTALE errors
vfs: have chroot retry once on ESTALE error
vfs: have chdir retry lookup and call once on ESTALE error
vfs: have faccessat retry once on an ESTALE error
vfs: have do_sys_truncate retry once on an ESTALE error
vfs: fix renameat to retry on ESTALE errors
vfs: make do_unlinkat retry once on ESTALE errors
vfs: make do_rmdir retry once on ESTALE errors
vfs: add a flags argument to user_path_parent
This file is already documented in the stable ABI (see commit
5bbe1ec11fcf).
Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com>
Cc: Greg KH <greg@kroah.com>
Remove the documentation for capability.disable. The code supporting
this parameter was removed with commit 5915eb53861c ("security: remove
dummy module")
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Cc: Miklos Szeredi <mszeredi@suse.cz>
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs into for-linus
Removed vmtruncate
Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com>
Pull nfsd update from Bruce Fields:
"Included this time:
- more nfsd containerization work from Stanislav Kinsbursky: we're
not quite there yet, but should be by 3.9.
- NFSv4.1 progress: implementation of basic backchannel security
negotiation and the mandatory BACKCHANNEL_CTL operation. See
http://wiki.linux-nfs.org/wiki/index.php/Server_4.0_and_4.1_issues
for remaining TODO's
- Fixes for some bugs that could be triggered by unusual compounds.
Our xdr code wasn't designed with v4 compounds in mind, and it
shows. A more thorough rewrite is still a todo.
- If you've ever seen "RPC: multiple fragments per record not
supported" logged while using some sort of odd userland NFS client,
that should now be fixed.
- Further work from Jeff Layton on our mechanism for storing
information about NFSv4 clients across reboots.
- Further work from Bryan Schumaker on his fault-injection mechanism
(which allows us to discard selective NFSv4 state, to excercise
rarely-taken recovery code paths in the client.)
- The usual mix of miscellaneous bugs and cleanup.
Thanks to everyone who tested or contributed this cycle."
* 'for-3.8' of git://linux-nfs.org/~bfields/linux: (111 commits)
nfsd4: don't leave freed stateid hashed
nfsd4: free_stateid can use the current stateid
nfsd4: cleanup: replace rq_resused count by rq_next_page pointer
nfsd: warn on odd reply state in nfsd_vfs_read
nfsd4: fix oops on unusual readlike compound
nfsd4: disable zero-copy on non-final read ops
svcrpc: fix some printks
NFSD: Correct the size calculation in fault_inject_write
NFSD: Pass correct buffer size to rpc_ntop
nfsd: pass proper net to nfsd_destroy() from NFSd kthreads
nfsd: simplify service shutdown
nfsd: replace boolean nfsd_up flag by users counter
nfsd: simplify NFSv4 state init and shutdown
nfsd: introduce helpers for generic resources init and shutdown
nfsd: make NFSd service structure allocated per net
nfsd: make NFSd service boot time per-net
nfsd: per-net NFSd up flag introduced
nfsd: move per-net startup code to separated function
nfsd: pass net to __write_ports() and down
nfsd: pass net to nfsd_set_nrthreads()
Provide a proper invalidation method rather than relying on the netfs retiring
the cookie it has and getting a new one. The problem with this is that isn't
easy for the netfs to make sure that it has completed/cancelled all its
outstanding storage and retrieval operations on the cookie it is retiring.
Instead, have the cache provide an invalidation method that will cancel or wait
for all currently outstanding operations before invalidating the cache, and
will cause new operations to queue up behind that. Whilst invalidation is in
progress, some requests will be rejected until the cache can stack a barrier on
the operation queue to cause new operations to be deferred behind it.
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull Ceph update from Sage Weil:
"There are a few different groups of commits here. The largest is
Alex's ongoing work to enable the coming RBD features (cloning,
striping). There is some cleanup in libceph that goes along with it.
Cyril and David have fixed some problems with NFS reexport (leaking
dentries and page locks), and there is a batch of patches from Yan
fixing problems with the fs client when running against a clustered
MDS. There are a few bug fixes mixed in for good measure, many of
which will be going to the stable trees once they're upstream.
My apologies for the late pull. There is still a gremlin in the rbd
map/unmap code and I was hoping to include the fix for that as well,
but we haven't been able to confirm the fix is correct yet; I'll send
that in a separate pull once it's nailed down."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (68 commits)
rbd: get rid of rbd_{get,put}_dev()
libceph: register request before unregister linger
libceph: don't use rb_init_node() in ceph_osdc_alloc_request()
libceph: init event->node in ceph_osdc_create_event()
libceph: init osd->o_node in create_osd()
libceph: report connection fault with warning
libceph: socket can close in any connection state
rbd: don't use ENOTSUPP
rbd: remove linger unconditionally
rbd: get rid of RBD_MAX_SEG_NAME_LEN
libceph: avoid using freed osd in __kick_osd_requests()
ceph: don't reference req after put
rbd: do not allow remove of mounted-on image
libceph: Unlock unprocessed pages in start_read() error path
ceph: call handle_cap_grant() for cap import message
ceph: Fix __ceph_do_pending_vmtruncate
ceph: Don't add dirty inode to dirty list if caps is in migration
ceph: Fix infinite loop in __wake_requests
ceph: Don't update i_max_size when handling non-auth cap
bdi_register: add __printf verification, fix arg mismatch
Fix the state management of internal fscache operations and the accounting of
what operations are in what states.
This is done by:
(1) Give struct fscache_operation a enum variable that directly represents the
state it's currently in, rather than spreading this knowledge over a bunch
of flags, who's processing the operation at the moment and whether it is
queued or not.
This makes it easier to write assertions to check the state at various
points and to prevent invalid state transitions.
(2) Add an 'operation complete' state and supply a function to indicate the
completion of an operation (fscache_op_complete()) and make things call
it. The final call to fscache_put_operation() can then check that an op
in the appropriate state (complete or cancelled).
(3) Adjust the use of object->n_ops, ->n_in_progress, ->n_exclusive to better
govern the state of an object:
(a) The ->n_ops is now the number of extant operations on the object
and is now decremented by fscache_put_operation() only.
(b) The ->n_in_progress is simply the number of objects that have been
taken off of the object's pending queue for the purposes of being
run. This is decremented by fscache_op_complete() only.
(c) The ->n_exclusive is the number of exclusive ops that have been
submitted and queued or are in progress. It is decremented by
fscache_op_complete() and by fscache_cancel_op().
fscache_put_operation() and fscache_operation_gc() now no longer try to
clean up ->n_exclusive and ->n_in_progress. That was leading to double
decrements against fscache_cancel_op().
fscache_cancel_op() now no longer decrements ->n_ops. That was leading to
double decrements against fscache_put_operation().
fscache_submit_exclusive_op() now decides whether it has to queue an op
based on ->n_in_progress being > 0 rather than ->n_ops > 0 as the latter
will persist in being true even after all preceding operations have been
cancelled or completed. Furthermore, if an object is active and there are
runnable ops against it, there must be at least one op running.
(4) Add a remaining-pages counter (n_pages) to struct fscache_retrieval and
provide a function to record completion of the pages as they complete.
When n_pages reaches 0, the operation is deemed to be complete and
fscache_op_complete() is called.
Add calls to fscache_retrieval_complete() anywhere we've finished with a
page we've been given to read or allocate for. This includes places where
we just return pages to the netfs for reading from the server and where
accessing the cache fails and we discard the proposed netfs page.
The bugs in the unfixed state management manifest themselves as oopses like the
following where the operation completion gets out of sync with return of the
cookie by the netfs. This is possible because the cache unlocks and returns
all the netfs pages before recording its completion - which means that there's
nothing to stop the netfs discarding them and returning the cookie.
FS-Cache: Cookie 'NFS.fh' still has outstanding reads
kernel BUG at fs/fscache/cookie.c:519!
invalid opcode: 0000 [#1] SMP
CPU 1
Modules linked in: cachefiles nfs fscache auth_rpcgss nfs_acl lockd sunrpc
Pid: 400, comm: kswapd0 Not tainted 3.1.0-rc7-fsdevel+ #1090 /DG965RY
RIP: 0010:[<ffffffffa007050a>] [<ffffffffa007050a>] __fscache_relinquish_cookie+0x170/0x343 [fscache]
RSP: 0018:ffff8800368cfb00 EFLAGS: 00010282
RAX: 000000000000003c RBX: ffff880023cc8790 RCX: 0000000000000000
RDX: 0000000000002f2e RSI: 0000000000000001 RDI: ffffffff813ab86c
RBP: ffff8800368cfb50 R08: 0000000000000002 R09: 0000000000000000
R10: ffff88003a1b7890 R11: ffff88001df6e488 R12: ffff880023d8ed98
R13: ffff880023cc8798 R14: 0000000000000004 R15: ffff88003b8bf370
FS: 0000000000000000(0000) GS:ffff88003bd00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00000000008ba008 CR3: 0000000023d93000 CR4: 00000000000006e0
Process kswapd0 (pid: 400, threadinfo ffff8800368ce000, task ffff88003b8bf040)
Stack:
ffff88003b8bf040 ffff88001df6e528 ffff88001df6e528 ffffffffa00b46b0
ffff88003b8bf040 ffff88001df6e488 ffff88001df6e620 ffffffffa00b46b0
ffff88001ebd04c8 0000000000000004 ffff8800368cfb70 ffffffffa00b2c91
Call Trace:
[<ffffffffa00b2c91>] nfs_fscache_release_inode_cookie+0x3b/0x47 [nfs]
[<ffffffffa008f25f>] nfs_clear_inode+0x3c/0x41 [nfs]
[<ffffffffa0090df1>] nfs4_evict_inode+0x2f/0x33 [nfs]
[<ffffffff810d8d47>] evict+0xa1/0x15c
[<ffffffff810d8e2e>] dispose_list+0x2c/0x38
[<ffffffff810d9ebd>] prune_icache_sb+0x28c/0x29b
[<ffffffff810c56b7>] prune_super+0xd5/0x140
[<ffffffff8109b615>] shrink_slab+0x102/0x1ab
[<ffffffff8109d690>] balance_pgdat+0x2f2/0x595
[<ffffffff8103e009>] ? process_timeout+0xb/0xb
[<ffffffff8109dba3>] kswapd+0x270/0x289
[<ffffffff8104c5ea>] ? __init_waitqueue_head+0x46/0x46
[<ffffffff8109d933>] ? balance_pgdat+0x595/0x595
[<ffffffff8104bf7a>] kthread+0x7f/0x87
[<ffffffff813ad6b4>] kernel_thread_helper+0x4/0x10
[<ffffffff81026b98>] ? finish_task_switch+0x45/0xc0
[<ffffffff813abcdd>] ? retint_restore_args+0xe/0xe
[<ffffffff8104befb>] ? __init_kthread_worker+0x53/0x53
[<ffffffff813ad6b0>] ? gs_change+0xb/0xb
Pull new F2FS filesystem from Jaegeuk Kim:
"Introduce a new file system, Flash-Friendly File System (F2FS), to
Linux 3.8.
Highlights:
- Add initial f2fs source codes
- Fix an endian conversion bug
- Fix build failures on random configs
- Fix the power-off-recovery routine
- Minor cleanup, coding style, and typos patches"
From the Kconfig help text:
F2FS is based on Log-structured File System (LFS), which supports
versatile "flash-friendly" features. The design has been focused on
addressing the fundamental issues in LFS, which are snowball effect
of wandering tree and high cleaning overhead.
Since flash-based storages show different characteristics according to
the internal geometry or flash memory management schemes aka FTL, F2FS
and tools support various parameters not only for configuring on-disk
layout, but also for selecting allocation and cleaning algorithms.
and there's an article by Neil Brown about it on lwn.net:
http://lwn.net/Articles/518988/
* tag 'for-3.8-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (36 commits)
f2fs: fix tracking parent inode number
f2fs: cleanup the f2fs_bio_alloc routine
f2fs: introduce accessor to retrieve number of dentry slots
f2fs: remove redundant call to f2fs_put_page in delete entry
f2fs: make use of GFP_F2FS_ZERO for setting gfp_mask
f2fs: rewrite f2fs_bio_alloc to make it simpler
f2fs: fix a typo in f2fs documentation
f2fs: remove unused variable
f2fs: move error condition for mkdir at proper place
f2fs: remove unneeded initialization
f2fs: check read only condition before beginning write out
f2fs: remove unneeded memset from init_once
f2fs: show error in case of invalid mount arguments
f2fs: fix the compiler warning for uninitialized use of variable
f2fs: resolve build failures
f2fs: adjust kernel coding style
f2fs: fix endian conversion bugs reported by sparse
f2fs: remove unneeded version.h header file from f2fs.h
f2fs: update the f2fs document
f2fs: update Kconfig and Makefile
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU updates from Joerg Roedel:
"A few new features this merge-window. The most important one is
probably, that dma-debug now warns if a dma-handle is not checked with
dma_mapping_error by the device driver. This requires minor changes
to some architectures which make use of dma-debug. Most of these
changes have the respective Acks by the Arch-Maintainers.
Besides that there are updates to the AMD IOMMU driver for refactor
the IOMMU-Groups support and to make sure it does not trigger a
hardware erratum.
The OMAP changes (for which I pulled in a branch from Tony Lindgren's
tree) have a conflict in linux-next with the arm-soc tree. The
conflict is in the file arch/arm/mach-omap2/clock44xx_data.c which is
deleted in the arm-soc tree. It is safe to delete the file too so
solve the conflict. Similar changes are done in the arm-soc tree in
the common clock framework migration. A missing hunk from the patch
in the IOMMU tree will be submitted as a seperate patch when the
merge-window is closed."
* tag 'iommu-updates-v3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (29 commits)
ARM: dma-mapping: support debug_dma_mapping_error
ARM: OMAP4: hwmod data: ipu and dsp to use parent clocks instead of leaf clocks
iommu/omap: Adapt to runtime pm
iommu/omap: Migrate to hwmod framework
iommu/omap: Keep mmu enabled when requested
iommu/omap: Remove redundant clock handling on ISR
iommu/amd: Remove obsolete comment
iommu/amd: Don't use 512GB pages
iommu/tegra: smmu: Move bus_set_iommu after probe for multi arch
iommu/tegra: gart: Move bus_set_iommu after probe for multi arch
iommu/tegra: smmu: Remove unnecessary PTC/TLB flush all
tile: dma_debug: add debug_dma_mapping_error support
sh: dma_debug: add debug_dma_mapping_error support
powerpc: dma_debug: add debug_dma_mapping_error support
mips: dma_debug: add debug_dma_mapping_error support
microblaze: dma-mapping: support debug_dma_mapping_error
ia64: dma_debug: add debug_dma_mapping_error support
c6x: dma_debug: add debug_dma_mapping_error support
ARM64: dma_debug: add debug_dma_mapping_error support
intel-iommu: Prevent devices with RMRRs from being placed into SI Domain
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
Pull hwmon subsystem update from Jean Delvare:
"There are many improvements to the it87 driver, as well as suspend
support for the Winbond Super-I/O chips, and a few other fixes."
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
hwmon-vid: Add support for AMD family 11h to 15h processors
hwmon: (it87) Support PECI for additional chips
hwmon: (it87) Report thermal sensor type as Intel PECI if appropriate
hwmon: (it87) Manage device specific features with table
hwmon: (it87) Replace pwm group macro with direct attribute definitions
hwmon: (it87) Avoid quoted string splits across lines
hwmon: (it87) Save fan registers in 2-dimensional array
hwmon: (it87) Introduce support for tempX_offset sysfs attribute
hwmon: (it87) Replace macro defining tempX_type sensors with direct definitions
hwmon: (it87) Save voltage register values in 2-dimensional array
hwmon: (it87) Save temperature registers in 2-dimensional array
hwmon: (w83627ehf) Get rid of smatch warnings
hwmon: (w83627hf) Don't touch nonexistent I2C address registers
hwmon: (w83627ehf) Add support for suspend
hwmon: (w83627hf) Add support for suspend
hwmon: Fix PCI device reference leak in quirk
