Information about the pagesize and read-only-status may also come from
the devicetree. Parse this data, too, and act accordingly. While we are
here, change the initialization printout a bit. write_max is useful to
know to detect performance bottlenecks, the rest is superfluous.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
This patch adds support for linking device tree blob(s) into
vmlinux. Modifies asm-generic/vmlinux.lds.h to add linking
.dtb sections into vmlinux. To maintain compatiblity with the of/fdt
driver code platforms MUST copy the blob to a non-init memory location
before the kernel frees the .init.* sections in the image.
Modifies scripts/Makefile.lib to add a kbuild command to
compile DTS files to device tree blobs and a rule to create objects to
wrap the blobs for linking.
STRUCT_ALIGNMENT is defined in vmlinux.lds.h for use in the rule to
create wrapper objects for the dtb in Makefile.lib. The
STRUCT_ALIGN() macro in vmlinux.lds.h is modified to use the
STRUCT_ALIGNMENT definition.
The DTB's are placed on 32 byte boundries to allow parsing the blob
with driver/of/fdt.c during early boot without having to copy the blob
to get the structure alignment GCC expects.
A DTB is linked in by adding the DTB object to the list of objects to
be linked into vmlinux in the archtecture specific Makefile using
obj-y += foo.dtb.o
Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
Acked-by: Michal Marek <mmarek@suse.cz>
[grant.likely@secretlab.ca: cleaned up whitespace inconsistencies]
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
x86: avoid high BIOS area when allocating address space
x86: avoid E820 regions when allocating address space
x86: avoid low BIOS area when allocating address space
resources: add arch hook for preventing allocation in reserved areas
Revert "resources: support allocating space within a region from the top down"
Revert "PCI: allocate bus resources from the top down"
Revert "x86/PCI: allocate space from the end of a region, not the beginning"
Revert "x86: allocate space within a region top-down"
Revert "PCI: fix pci_bus_alloc_resource() hang, prefer positive decode"
PCI: Update MCP55 quirk to not affect non HyperTransport variants
This reverts commit e7f8567db9a7f6b3151b0b275e245c1cef0d9c70.
Acked-by: H. Peter Anvin <hpa@zytor.com>
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
There are some situations (e.g. in __pm_generic_call()), where
pm_runtime_suspended() is used to decide whether or not to execute
a device's (system) ->suspend() callback. The callback is not
executed if pm_runtime_suspended() returns true, but it does so
for devices that don't even support runtime PM, because the
power.disable_depth device field is ignored by it. This leads to
problems (i.e. devices are not suspened when they should), so rework
pm_runtime_suspended() so that it returns false if the device's
power.disable_depth field is different from zero.
Cc: stable@kernel.org
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6:
NFS: Fix panic after nfs_umount()
nfs: remove extraneous and problematic calls to nfs_clear_request
nfs: kernel should return EPROTONOSUPPORT when not support NFSv4
NFS: Fix fcntl F_GETLK not reporting some conflicts
nfs: Discard ACL cache on mode update
NFS: Readdir cleanups
NFS: nfs_readdir_search_for_cookie() don't mark as eof if cookie not found
NFS: Fix a memory leak in nfs_readdir
Call the filesystem back whenever a page is removed from the page cache
NFS: Ensure we use the correct cookie in nfs_readdir_xdr_filler
git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86:
wmi: use memcmp instead of strncmp to compare GUIDs
ACPI, hp-wmi: Fix memory leak in acpi query
msi-wmi: fix semantically incorrect use of keycode instead of scancode
msi-wmi: Add mute key support
asus-laptop: add wimax and wwan support
eeepc-wmi: fix compiler warning
ibm_rtl: _RTL_ is not available in UEFI mode
ibm_rtl: Loosen the DMI criteria to all IBM machines
drivers/platform/x86/thinkpad_acpi.c: delete double assignment
eeepc-wmi: add cpufv sysfs documentation
toshiba_acpi.c: Add key_entry for a lone FN keypress
ibm_rtl: fix printk format warning
->releasepage() does not remove the page from the mapping.
Acked-by: Neil Brown <neilb@suse.de>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6
* 'driver-core-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6:
uio: Change mail address of Hans J. Koch
driver core: prune docs about device_interface
driver core: the development tree has switched to git
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'rbd-sysfs' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
rbd: replace the rbd sysfs interface
NFS needs to be able to release objects that are stored in the page
cache once the page itself is no longer visible from the page cache.
This patch adds a callback to the address space operations that allows
filesystems to perform page cleanups once the page has been removed
Original patch by: Linus Torvalds <torvalds@linux-foundation.org>
[trondmy: cover the cases of invalidate_inode_pages2() and
truncate_inode_pages()]
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
The new interface creates directories per mapped image
and under each it creates a subdir per available snapshot.
This allows keeping a cleaner interface within the sysfs
guidelines. The ABI documentation was updated too.
Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net>
Signed-off-by: Sage Weil <sage@newdream.net>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits)
af_unix: limit recursion level
pch_gbe driver: The wrong of initializer entry
pch_gbe dreiver: chang author
ucc_geth: fix ucc halt problem in half duplex mode
inet: Fix __inet_inherit_port() to correctly increment bsockets and num_owners
ehea: Add some info messages and fix an issue
hso: fix disable_net
NET: wan/x25_asy, move lapb_unregister to x25_asy_close_tty
cxgb4vf: fix setting unicast/multicast addresses ...
net, ppp: Report correct error code if unit allocation failed
DECnet: don't leak uninitialized stack byte
au1000_eth: fix invalid address accessing the MAC enable register
dccp: fix error in updating the GAR
tcp: restrict net.ipv4.tcp_adv_win_scale (#20312)
netns: Don't leak others' openreq-s in proc
Net: ceph: Makefile: Remove unnessary code
vhost/net: fix rcu check usage
econet: fix CVE-2010-3848
econet: fix CVE-2010-3850
econet: disallow NULL remote addr for sendmsg(), fixes CVE-2010-3849
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp:
EDAC: Fix typos in Documentation/edac.txt
EDAC, MCE: Fix edac_init_mce_inject error handling
EDAC: Remove deprecated kbuild goal definitions
tcp_win_from_space() does the following:
if (sysctl_tcp_adv_win_scale <= 0)
return space >> (-sysctl_tcp_adv_win_scale);
else
return space - (space >> sysctl_tcp_adv_win_scale);
"space" is int.
As per C99 6.5.7 (3) shifting int for 32 or more bits is
undefined behaviour.
Indeed, if sysctl_tcp_adv_win_scale is exactly 32,
space >> 32 equals space and function returns 0.
Which means we busyloop in tcp_fixup_rcvbuf().
Restrict net.ipv4.tcp_adv_win_scale to [-31, 31].
Fix https://bugzilla.kernel.org/show_bug.cgi?id=20312
Steps to reproduce:
echo 32 >/proc/sys/net/ipv4/tcp_adv_win_scale
wget www.kernel.org
[softlockup]
Fix trivial typos in edac.txt
Signed-off-by: Raoul Bhatia <r.bhatia@ipax.at>
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6
* 'fbdev-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6:
sisfb: delete osdef.h
sisfb: move the CONFIG warning to sis_main.c
sisfb: replace SiS_SetMemory with memset_io
sisfb: remove InPort/OutPort wrappers
sisfb: use CONFIG_FB_SIS_301/315 instead of SIS301/315H
sisfb: delete redudant #define SIS_LINUX_KERNEL
sisfb: delete dead SIS_XORG_XF86 code
sisfb: delete fallback code for pci_map_rom()
sisfb: delete obsolete PCI ROM bug workaround
fbdev: Update documentation index file.
lxfb: Program panel v/h sync output polarity correctly
fbcmap: integer overflow bug
fbcmap: cleanup white space in fb_alloc_cmap()
MAINTAINERS: Add fbdev patchwork entry, tidy up file patterns.
fbdev: da8xx: punt duplicated FBIO_WAITFORVSYNC define
fbdev: sh_mobile_lcdcfb: fix bug in reconfig()
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6
* 'sh-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6:
sh: clkfwk: Build fix for non-legacy CPG changes.
sh: Use GCC __builtin_prefetch() to implement prefetch().
sh: fix vsyscall compilation due to .eh_frame issue
sh: avoid to flush all cache in sys_cacheflush
sh: clkfwk: Disable init clk op for non-legacy clocks.
sh: clkfwk: Kill off now unused algo_id in set_rate op.
sh: clkfwk: Kill off unused clk_set_rate_ex().
Swap accounting can be configured by CONFIG_CGROUP_MEM_RES_CTLR_SWAP
configuration option and then it is turned on by default. There is a boot
option (noswapaccount) which can disable this feature.
This makes it hard for distributors to enable the configuration option as
this feature leads to a bigger memory consumption and this is a no-go for
general purpose distribution kernel. On the other hand swap accounting
may be very usuful for some workloads.
This patch adds a new configuration option which controls the default
behavior (CGROUP_MEM_RES_CTLR_SWAP_ENABLED). If the option is selected
then the feature is turned on by default.
It also adds a new boot parameter swapaccount[=1|0] which enhances the
original noswapaccount parameter semantic by means of enable/disable logic
(defaults to 1 if no value is provided to be still consistent with
noswapaccount).
The default behavior is unchanged (if CONFIG_CGROUP_MEM_RES_CTLR_SWAP is
enabled then CONFIG_CGROUP_MEM_RES_CTLR_SWAP_ENABLED is enabled as well)
Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
Asus UL30A has a 3G chip, but the radio is disabled by default.
The DSDT also reference a WIMAX device, which is not present on this model.
This patch adds two new files: wwan and wimax to control WWAN and
WIMAX devices. It does not use rfkill, because like WLED and BLED,
we don't know yet that the two ACPI functions will always control the
radio, they may control only the leds on some hardware.
We may add rfkill switchs later.
Signed-off-by: Corentin Chary <corentincj@iksaif.net>
Based on cpufv text from sysfs-platform-eeepc-laptop that
has almost same behavior.
Signed-off-by: Chris Bagwell <chris@cnpbagwell.com>
Acked-by: Corentin Chary <corentincj@iksaif.net>
Document things that I would've liked to have known when submitting a driver
to gregkh for staging.
Signed-off-by: Andres Salomon <dilinger@queued.net>
This is confusing, as we have "staging" trees for drivers/staging. Call
them -next trees.
My old mail address doesn't exist anymore. This changes all occurrences
to my new address.
Signed-off-by: Hans J. Koch <hjk@hansjkoch.de>
Add a bit more information how to use poll(2) on GPIO value files
correctly. For me it was not clear that I need to poll(2) for
POLLPRI|POLLERR or select(2) for exceptfds.
Signed-off-by: Bernhard Walle <walle@corscience.de>
If "p" is NULL then it will cause an oops when we pass it to
simple_strtoul(). In this case "p" can not be NULL so I removed the
check. I also changed the check a little to make it more explicit that
we are testing whether p points to the NUL char.
Acked-by: Joel Becker <joel.becker@oracle.com>
This is a simple update of the file Documentation/fb/00-INDEX based on
the directory content.
Signed-off-by: Vicente Jimenez Aguilar <googuy@gmail.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
PM / PM QoS: Fix reversed min and max
PM / OPP: Hide OPP configuration when SoCs do not provide an implementation
PM: Allow devices to be removed during late suspend and early resume
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
i2c: Sanity checks on adapter registration
i2c: Mark i2c_adapter.id as deprecated
i2c: Drivers shouldn't include <linux/i2c-id.h>
i2c: Delete unused adapter IDs
i2c: Remove obsolete cleanup for clientdata
It's about time to make it clear that i2c_adapter.id is deprecated.
Hopefully this will remind the last user to move over to a different
strategy.
Acked-by: Jarod Wilson <jarod@redhat.com>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Hans Verkuil <hverkuil@xs4all.nl>
fsl-diu-fb: drop dead ioctl define
MAINTAINERS: Add an fbdev git tree entry.
OMAP: DSS: Fix documentation regarding 'vram' kernel parameter
OMAP: VRAM: Fix boot-time memory allocation
OMAP: VRAM: improve VRAM error prints
sisfb: limit POST memory test according to PCI resource length
fbdev: sh_mobile_lcdc: use correct number of modes, when using the default
fbdev: sh_mobile_lcdc: use the standard CEA-861 720p timing
fbdev: sh_mobile_hdmi: properly clean up modedb on monitor unplug
With the refactoring of the SH7722 clock framework some time ago this
abstraction has become unecessary. Kill it off before anyone else gets
the bright idea to start using it.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (66 commits)
can-bcm: fix minor heap overflow
gianfar: Do not call device_set_wakeup_enable() under a spinlock
ipv6: Warn users if maximum number of routes is reached.
docs: Add neigh/gc_thresh3 and route/max_size documentation.
axnet_cs: fix resume problem for some Ax88790 chip
ipv6: addrconf: don't remove address state on ifdown if the address is being kept
tcp: Don't change unlocked socket state in tcp_v4_err().
x25: Prevent crashing when parsing bad X.25 facilities
cxgb4vf: add call to Firmware to reset VF State.
cxgb4vf: Fail open if link_start() fails.
cxgb4vf: flesh out PCI Device ID Table ...
cxgb4vf: fix some errors in Gather List to skb conversion
cxgb4vf: fix bug in Generic Receive Offload
cxgb4vf: don't implement trivial (and incorrect) ndo_select_queue()
ixgbe: Look inside vlan when determining offload protocol.
bnx2x: Look inside vlan when determining checksum proto.
vlan: Add function to retrieve EtherType from vlan packets.
virtio-net: init link state correctly
ucc_geth: Fix deadlock
ucc_geth: Do not bring the whole IF down when TX failure.
Signed-off-by: Ben Greear <greearb@candelatech.com>
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: (27 commits)
block: remove unused copy_io_context()
Documentation: remove anticipatory scheduler info
block: remove REQ_HARDBARRIER
ioprio: rcu_read_lock/unlock protect find_task_by_vpid call (V2)
ioprio: fix RCU locking around task dereference
block: ioctl: fix information leak to userland
block: read i_size with i_size_read()
cciss: fix proc warning on attempt to remove non-existant directory
bio: take care not overflow page count when mapping/copying user data
block: limit vec count in bio_kmalloc() and bio_alloc_map_data()
block: take care not to overflow when calculating total iov length
block: check for proper length of iov entries in blk_rq_map_user_iov()
cciss: remove controllers supported by hpsa
cciss: use usleep_range not msleep for small sleeps
cciss: limit commands allocated on reset_devices
cciss: Use kernel provided PCI state save and restore functions
cciss: fix board status waiting code
drbd: Removed checks for REQ_HARDBARRIER on incomming BIOs
drbd: REQ_HARDBARRIER -> REQ_FUA transition for meta data accesses
drbd: Removed the BIO_RW_BARRIER support form the receiver/epoch code
* 'for-linus' of git://oss.sgi.com/xfs/xfs:
xfs: remove incorrect assert in xfs_vm_writepage
xfs: use hlist_add_fake
xfs: fix a few compiler warnings with CONFIG_XFS_QUOTA=n
xfs: tell lockdep about parent iolock usage in filestreams
xfs: move delayed write buffer trace
xfs: fix per-ag reference counting in inode reclaim tree walking
xfs: xfs_ioctl: fix information leak to userland
xfs: remove experimental tag from the delaylog option
Create sub directory Documentation/leds and add short documentation for
LP5521 and LP5523 drivers.
Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Jean Delvare <khali@linux-fr.org>
Currently, blinking LEDs can be awkward because it is not guaranteed that
all LEDs implement blinking. The trigger that wants it to blink then
needs to implement its own timer solution.
Rather than require that, add led_blink_set() API that triggers can use.
This function will attempt to use hw blinking, but if that fails
implements a timer for it. To stop blinking again, brightness_set() also
needs to be wrapped into API that will stop the software blink.
As a result of this, the timer trigger becomes a very trivial one, and
hopefully we can finally see triggers using blinking as well because it's
always easy to use.
Acked-by: Richard Purdie <rpurdie@linux.intel.com>
The kernel syslog contains debugging information that is often useful
during exploitation of other vulnerabilities, such as kernel heap
addresses. Rather than futilely attempt to sanitize hundreds (or
thousands) of printk statements and simultaneously cripple useful
debugging functionality, it is far simpler to create an option that
prevents unprivileged users from reading the syslog.
This patch, loosely based on grsecurity's GRKERNSEC_DMESG, creates the
dmesg_restrict sysctl. When set to "0", the default, no restrictions are
enforced. When set to "1", only users with CAP_SYS_ADMIN can read the
kernel syslog via dmesg(8) or other mechanisms.
[akpm@linux-foundation.org: explain the config option in kernel.txt]
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Acked-by: Eugene Teo <eugeneteo@kernel.org>
Acked-by: Kees Cook <kees.cook@canonical.com>
/proc/pid/oom_adj was deprecated in August 2010 with the introduction of
the new oom killer heuristic.
This patch copies the Documentation/feature-removal-schedule.txt entry for
this tunable to the Documentation/ABI/obsolete directory so nobody misses
it.
Signed-off-by: David Rientjes <rientjes@google.com>
Reported-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Remove anticipatory block I/O scheduler info from Documentation/
since the code has been deleted.
Reported-by: "Robert P. J. Day" <rpjday@crashcourse.ca>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
drivers/base/intf.c was removed before the beginning of (git) time but
its Documentation stuck around. Remove it.
Signed-off-by: Brandon Philips <brandon@ifup.org>
Since the OPP API is only useful with an appropraite SoC-specific
implementation there is no point in offering the ability to enable
the API on general systems. Provide an ARCH_HAS OPP Kconfig symbol
which masks out the option unless selected by an implementation.
Acked-by: Nishanth Menon <nm@ti.com>
Acked-by: Kevin Hilman <khilman@deeprootsystems.com>
We promised to do this for 2.6.37, and the code looks stable enough to
keep that promise.
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Alex Elder <aelder@sgi.com>
The DSS documentation didn't mention the option to give the VRAM start
address.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com>
i2c-i801: Add PCI idents for Patsburg 'IDF' SMBus controllers
i2c-i801: Handle multiple instances instead of keeping global state
i2c-i801: Add Intel Patsburg device ID
i2c: Drop unused I2C_CLASS_TV flags
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (70 commits)
[SCSI] pmcraid: add support for set timestamp command and other fixes
[SCSI] pmcraid: remove duplicate struct member
[SCSI] qla4xxx: Fix cmd check in qla4xxx_cmd_wait
[SCSI] megaraid_sas: Version and documentation update
[SCSI] megaraid_sas: Add three times Online controller reset
[SCSI] megaraid_sas: Add input parameter for max_sectors
[SCSI] megaraid_sas: support devices update flag
[SCSI] libosd: write/read_sg_kern API
[SCSI] libosd: Support for scatter gather write/read commands
[SCSI] libosd: Free resources in reverse order of allocation
[SCSI] libosd: Fix bug in attr_page handling
[SCSI] lpfc 8.3.18: Update lpfc driver version to 8.3.18
[SCSI] lpfc 8.3.18: Add new WQE support
[SCSI] lpfc 8.3.18: Fix critical errors
[SCSI] lpfc 8.3.18: Adapter Shutdown and Unregistration cleanup
[SCSI] lpfc 8.3.18: Add logic to detect last devloss timeout
[SCSI] lpfc 8.3.18: Add support of received ELS commands
[SCSI] lpfc 8.3.18: FC/FCoE Discovery fixes
[SCSI] ipr: add definitions for a new adapter
[SCSI] bfa: fix comments for c files
These are the extra 'Integrated Device Function' SMBus controllers found
on the Patsburg chipset. Mention the absence of slave mode support.
Add support for the Intel Patsburg PCH SMBus Controller.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
