Allow clk API users to simplify their cleanup paths by providing a
managed version of clk_get() and clk_put().
Cherry-picked from mainline
a8a97db984bdc5e89d42e41891543d2daaf314cb
Change-Id: Ib36c0c82063928937166b6014fca92025bc83878
Reviewed-on: http://git-master/r/102860
Bug 939292
Change-Id: Ib0c849418c6c426518948785082fcceb180f3d64
Reviewed-on: http://git-master/r/96250
Tested-by: Liang Cheng (SW) <licheng@nvidia.com>
Reviewed-by: Antti Miettinen <amiettinen@nvidia.com>
Reviewed-by: Mark Peters <mpeters@nvidia.com>
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Almost every platform_driver does the three steps get_resource,
request_mem_region, ioremap. This does not only lead to a lot of code
duplication, but also a huge number of similar error strings and
inconsistent error codes on failure. So, introduce a helper function
which simplifies remapping a resource and make it hard to do something
wrong and add documentation for it.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Acked-by: Tejun Heo <tj@kernel.org>
(cherry picked from mainline commit
72f8c0bfa0de64c68ee59f40eb9b2683bffffbb0)
Change-Id: I600c5200104e234d42ca396e50853133b3ab4b1f
Reviewed-on: http://git-master/r/94533
Bug 894311
Change-Id: I376a03adc2088a9b1b0b19168f72dbcb770e6ad2
Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com>
Reviewed-on: http://git-master/r/83497
android-tegra-nv-3.1
Change-Id: I9001bb291779f107bbcb593d48f9f0f734074d0e
Linux 3.1.10
Change-Id: I465d184c492e8041dd0cd90f2cb70fde17ba7118
If the device starts to use IOMMUv2 features the dma handles
need to stay valid. The only sane way to do this is to use a
identity mapping for the device and not translate it by the
iommu. This is implemented with this patch. Since this lifts
the device-isolation there is also a new kernel parameter
which allows to disable that feature.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
The option iommu=group_mf indicates the that the iommu driver should
expose all functions of a multi-function PCI device as the same
iommu_device_group. This is useful for disallowing individual functions
being exposed as independent devices to userspace as there are often
hidden dependencies. Virtual functions are not affected by this option.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
On the platforms which are x2apic and interrupt-remapping
capable, Linux kernel is enabling x2apic even if the BIOS
doesn't. This is to take advantage of the features that x2apic
brings in.
Some of the OEM platforms are running into issues because of
this, as their bios is not x2apic aware. For example, this was
resulting in interrupt migration issues on one of the platforms.
Also if the BIOS SMI handling uses APIC interface to send SMI's,
then the BIOS need to be aware of x2apic mode that OS has
enabled.
On some of these platforms, BIOS doesn't have a HW mechanism to
turnoff the x2apic feature to prevent OS from enabling it.
To resolve this mess, recent changes to the VT-d2 specification:
http://download.intel.com/technology/computing/vptech/Intel(r)_VT_for_Direct_IO.pdf
includes a mechanism that provides BIOS a way to request system
software to opt out of enabling x2apic mode.
Look at the x2apic optout flag in the DMAR tables before
enabling the x2apic mode in the platform. Also print a warning
that we have disabled x2apic based on the BIOS request.
Kernel boot parameter "intremap=no_x2apic_optout" can be used to
override the BIOS x2apic optout request.
Signed-off-by: Youquan Song <youquan.song@intel.com>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: yinghai@kernel.org
Cc: joerg.roedel@amd.com
Cc: tony.luck@intel.com
Cc: dwmw2@infradead.org
Link: http://lkml.kernel.org/r/20110824001456.171766616@sbsiddha-desk.sc.intel.com
(cherry picked from commit 3d27e23b17010c668db311140b17bbbb70c78fb9)
Only allow KVM device assignment to attach to devices which:
- Are not bridges
- Have BAR resources (assume others are special devices)
- The user has permissions to use
Assigning a bridge is a configuration error, it's not supported, and
typically doesn't result in the behavior the user is expecting anyway.
Devices without BAR resources are typically chipset components that
also don't have host drivers. We don't want users to hold such devices
captive or cause system problems by fencing them off into an iommu
domain. We determine "permission to use" by testing whether the user
has access to the PCI sysfs resource files. By default a normal user
will not have access to these files, so it provides a good indication
that an administration agent has granted the user access to the device.
[Yang Bai: add missing #include]
[avi: fix comment style]
Signed-off-by: Yang Bai <hamo.by@gmail.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
(cherry picked from commit 423873736b78f549fbfa2f715f2e4de7e6c5e1e9)
This option has no users and it exposes a security hole that we
can allow devices to be assigned without iommu protection. Make
KVM_DEV_ASSIGN_ENABLE_IOMMU a mandatory option.
Linux 3.1.9
Makefile
Change-Id: I22227ab33ba7ddaba8e6fe049393c58a83d73648
commit d8cae98cddd286e38db1724dda1b0e7b467f9237 upstream.
The documentation for usbmon is out of date; the usbfs "devices" file
now exists in /sys/kernel/debug/usb rather than /proc/bus/usb. This
patch (as1505) updates the documentation accordingly, and also
mentions that the necessary information can be found by running lsusb.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: Pete Zaitcev <zaitcev@redhat.com>
commit 2eb7f204db51969ea558802a6601d79c2fb273b9 upstream.
The Japanese/Korean/Chinese versions still need updating.
Also, the stable kernel 2.6.x.y descriptions are out of date
and should be updated as well.
This reverts commit d1f9642381847e2b94caa34c3533211cf36ffcf4.
Change-Id: If1879b331c1f0e3dea7433c5de53ac653743d9c2
Reviewed-on: http://git-master/r/72234
Reviewed-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Tested-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Tested-by: Ahung Cheng <ahcheng@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Add a new module that will dump the contents of the ftrace ring buffer.
Data is compressed and can be in ascii or binary form. Data will
automatically dump on kernel panic to console. Data can be dumped by
reading /proc/tracedump. See tracedump.h for details.
Change-Id: I7b7afc3def0b88629dd120d17e43858306a8f357
Signed-off-by: Liang Cheng <licheng@nvidia.com>
Reviewed-on: http://git-master/r/69494
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
arch/arm/mach-tegra/Kconfig
arch/arm/mach-tegra/board-ventana.c
drivers/misc/Kconfig
drivers/video/tegra/dc/hdmi.c
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
This module lets subsystem authors prioritize ftrace events
by calling tracelevel_register(...). High priority traces
will be automatically enabled on boot. See tracelevel.h
for more details
Original-Change-Id: If03699e96c598bdcf93b9a9f73918ce7b0c750cb
Reviewed-on: http://git-master/r/40290
Reviewed-by: Alon Farchy <afarchy@nvidia.com>
Tested-by: Alon Farchy <afarchy@nvidia.com>
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Tested-by: Daniel Solomon <daniels@nvidia.com>
Rebase-Id: R49f59f81d61907f66fdf892130a1b4dc6575d40e
tegra_dc_ext is the extended interface that exposes unique features for
the NVIDIA Tegra display controller.
Original-Change-Id: Ic18087a8fd8a60a6bc1b244361c15a1ed44cced4
Signed-off-by: Robert Morell <rmorell@nvidia.com>
Reviewed-on: http://git-master/r/41348
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: Red37e229b1606096c47f6ff0dfb3106ea43b2d69
The list of functions that can be called in atomic context is
non-intuitive (pm_runtime_put_sync can not, but
pm_runtime_put_sync_suspend can, if pm_runtime_irq_safe has
been called?). The code is actively misleading - the entry
points all start with spin_lock_irqsave, suggesting they
are safe to call in atomic context, but may later
enable interrupts.
Add might_sleep_if to all the __pm_runtime_* entry points
to enforce correct usage.
Also add pm_runtime_put_sync_autosuspend to the list of
functions that can be called in atomic context.
Change-Id: Icac17a10d77c64d44bd2761a91a588dfd1d0c6f0
Signed-off-by: Colin Cross <ccross@android.com>
Add description of timer_rate tunable and clean up some
typos.
Change-Id: I4b96a36aad51eed3bef0ee5f571dc6e0a94c8dd9
Signed-off-by: Allen Martin <amartin@nvidia.com>
Fixes a checkpatch warning
Change-Id: I2962b7c32f336188de0d2fe4f0f13f1199cb68e2
Rather than using explicit euid == 0 checks when trying to move
tasks into a cgroup via CFS, move permission checks into each
specific cgroup subsystem. If a subsystem does not specify a
'allow_attach' handler, then we fall back to doing our checks
the old way.
Use the 'allow_attach' handler for the 'cpu' cgroup to allow
non-root processes to add arbitrary processes to a 'cpu' cgroup
if it has the CAP_SYS_NICE capability set.
This version of the patch adds a 'allow_attach' handler instead
of reusing the 'can_attach' handler. If the 'can_attach' handler
is reused, a new cgroup that implements 'can_attach' but not
the permission checks could end up with no permission checks
at all.
Change-Id: Icfa950aa9321d1ceba362061d32dc7dfa2c64f0c
Original-Author: San Mehat <san@google.com>
This governor is designed for latency-sensitive workloads, such as
interactive user interfaces. The interactive governor aims to be
significantly more responsive to ramp CPU quickly up when CPU-intensive
activity begins.
Existing governors sample CPU load at a particular rate, typically
every X ms. This can lead to under-powering UI threads for the period of
time during which the user begins interacting with a previously-idle system
until the next sample period happens.
The 'interactive' governor uses a different approach. Instead of sampling
the CPU at a specified rate, the governor will check whether to scale the
CPU frequency up soon after coming out of idle. When the CPU comes out of
idle, a timer is configured to fire within 1-2 ticks. If the CPU is very
busy from exiting idle to when the timer fires then we assume the CPU is
underpowered and ramp to MAX speed.
If the CPU was not sufficiently busy to immediately ramp to MAX speed, then
the governor evaluates the CPU load since the last speed adjustment,
choosing the highest value between that longer-term load or the short-term
load since idle exit to determine the CPU speed to ramp to.
A realtime thread is used for scaling up, giving the remaining tasks the
CPU performance benefit, unlike existing governors which are more likely to
schedule rampup work to occur after your performance starved tasks have
completed.
The tuneables for this governor are:
/sys/devices/system/cpu/cpufreq/interactive/min_sample_time:
The minimum amount of time to spend at the current frequency before
ramping down. This is to ensure that the governor has seen enough
historic CPU load data to determine the appropriate workload.
Default is 80000 uS.
/sys/devices/system/cpu/cpufreq/interactive/go_maxspeed_load
The CPU load at which to ramp to max speed. Default is 85.
Change-Id: Ib2b362607c62f7c56d35f44a9ef3280f98c17585
Signed-off-by: Mike Chan <mike@android.com>
Signed-off-by: Todd Poynor <toddpoynor@google.com>
Bug: 3152864
Platform must register cpu power function that return power in
milliWatt seconds.
Change-Id: I1caa0335e316c352eee3b1ddf326fcd4942bcbe8
Introduce new platform callback hooks for cpuacct for tracking CPU frequencies
Not all platforms / architectures have a set CPU_FREQ_TABLE defined
for CPU transition speeds. In order to track time spent in at various
CPU frequencies, we enable platform callbacks from cpuacct for this accounting.
Architectures that support overclock boosting, or don't have pre-defined
frequency tables can implement their own bucketing system that makes sense
given their cpufreq scaling abilities.
New file:
cpuacct.cpufreq reports the CPU time (in nanoseconds) spent at each CPU
frequency.
Change-Id: I10a80b3162e6fff3a8a2f74dd6bb37e88b12ba96
commit f7f9bdfadfda07afb904a9767468e38c2d1a6033 upstream.
Fix the not working internal mic on Dell Vostro 3500 laptop by introducing the
new model dell-vostro-3500.
Signed-off-by: Julian Wollrath <jwollrath@web.de>
commit 886486b792e4f6f96d4fbe8ec5bf20811cab7d6a upstream.
Originally, the runtime PM core would send an idle notification
whenever a suspend attempt failed. The idle callback routine could
then schedule a delayed suspend for some time later.
However this behavior was changed by commit
f71648d73c1650b8b4aceb3856bebbde6daa3b86 (PM / Runtime: Remove idle
notification after failing suspend). No notifications were sent, and
there was no clear mechanism to retry failed suspends.
This caused problems for the usbhid driver, because it fails
autosuspend attempts as long as a key is being held down. Therefore
this patch (as1492) adds a mechanism for retrying failed
autosuspends. If the callback routine updates the last_busy field so
that the next autosuspend expiration time is in the future, the
autosuspend will automatically be rescheduled.
Tested-by: Henrik Rydberg <rydberg@euromail.se>
commit 93b465c2e186d96fb90012ba0f9372eb9952e732 upstream.
Since we're using non-atomic radix tree allocations, we
should be protecting the tree using a mutex and not a
spinlock.
Non-atomic allocations and process context locking is good enough,
as the tree is manipulated only when locks are registered/
unregistered/requested/freed.
The locks themselves are still protected by spinlocks of course,
and mutexes are not involved in the locking/unlocking paths.
Signed-off-by: Juan Gutierrez <jgutierrez@ti.com>
[ohad@wizery.com: rewrite the commit log, #include mutex.h, add minor
commentary]
[ohad@wizery.com: update register/unregister parts in hwspinlock.txt]
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
commit 5fa224295f0e0358c8bc0e5390702338df889def upstream.
The stable@kernel.org email address has been replaced with the
stable@vger.kernel.org mailing list. Change the stable kernel rules to
reference the new list instead of the semi-defunct email alias.
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
This UML breakage:
linux-2.6.30.1[3800] vsyscall fault (exploit attempt?) ip:ffffffffff600000 cs:33 sp:7fbfb9c498 ax:ffffffffff600000 si:0 di:606790
linux-2.6.30.1[3856] vsyscall fault (exploit attempt?) ip:ffffffffff600000 cs:33 sp:7fbfb13168 ax:ffffffffff600000 si:0 di:606790
Is caused by commit 3ae36655 ("x86-64: Rework vsyscall emulation and add
vsyscall= parameter") - the vsyscall emulation code is not fully cooked
yet as UML relies on some rather fragile SIGSEGV semantics.
Linus suggested in https://lkml.org/lkml/2011/8/9/376 to default
to vsyscall=native for now, this patch implements that.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: Andrew Lutomirski <luto@mit.edu>
Cc: H. Peter Anvin <hpa@linux.intel.com>
Link: http://lkml.kernel.org/r/20111005214047.GE14406@localhost.pp.htv.fi
The second hunk fixes rps_sock_flow_table but has to re-wrap the paragraph.
Signed-off-by: Benjamin Poirier <benjamin.poirier@gmail.com>
Signed-off-by: Roy.Li <rongqing.li@windriver.com>
* git://github.com/davem330/net:
ipv6-multicast: Fix memory leak in IPv6 multicast.
ipv6: check return value for dst_alloc
net: check return value for dst_alloc
ipv6-multicast: Fix memory leak in input path.
bnx2x: add missing break in bnx2x_dcbnl_get_cap
bnx2x: fix WOL by enablement PME in config space
bnx2x: fix hw attention handling
net: fix a typo in Documentation/networking/scaling.txt
ath9k: Fix a dma warning/memory leak
rtlwifi: rtl8192cu: Fix unitialized struct
iwlagn: fix dangling scan request
batman-adv: do_bcast has to be true for broadcast packets only
cfg80211: Fix validation of AKM suites
iwlegacy: do not use interruptible waits
iwlegacy: fix command queue timeout
ath9k_hw: Fix Rx DMA stuck for AR9003 chips
Signed-off-by: Jason Wang <jasowang@redhat.com>
* 'hwmon-for-linus' of git://github.com/groeck/linux:
hwmon: (coretemp) remove struct platform_data * parameter from create_core_data()
hwmon: (coretemp) constify static data
hwmon: (coretemp) don't use kernel assigned CPU number as platform device ID
hwmon: (ds620) Fix handling of negative temperatures
hwmon: (w83791d) rename prototype parameter from 'register' to 'reg'
hwmon: (coretemp) Don't use threshold registers for tempX_max
hwmon: (coretemp) Let the user force TjMax
hwmon: (coretemp) Drop duplicate function get_pkg_tjmax
Commit e27e6151b154 ("mm/thp: use conventional format for boolean
attributes") changed
/sys/kernel/mm/transparent_hugepage/khugepaged/defrag
to be tuned by using 1 (enabled) or 0 (disabled) instead of "yes" and
"no", respectively.
Update the documentation.
Signed-off-by: David Rientjes <rientjes@google.com>
With commit c814a4c7c4aad795835583344353963a0a673eb0, the meaning of tempX_max
was changed. It no longer returns the value of bits 8:15 of
MSR_IA32_TEMPERATURE_TARGET, but instead returns the value of CPU threshold
register T1. tempX_max_hyst was added to reflect the value of temperature
threshold register T0.
As it turns out, T0 and T1 are used on some systems, presumably by the BIOS.
Also, T0 and T1 don't have a well defined meaning. The thresholds may be used
as upper or lower limits, and it is not guaranteed that T0 <= T1. Thus, the new
attribute mapping does not reflect the actual usage of the threshold registers.
Also, register contents are changed during runtime by an entity other than the
hwmon driver, meaning the values cached by the driver do not reflect actual
register contents.
Revert most of c814a4c7c4aad795835583344353963a0a673eb0 to address the problem.
Support for T0 and T1 will be added back in with a separate commit, using new
attribute names.
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
Cc: Durgadoss R <durgadoss.r@intel.com>
Acked-by: Jean Delvare <khali@linux-fr.org>
On old CPUs (and even some recent Atom CPUs) TjMax can't be read from
the CPU registers, so it is guessed by the driver using a complex
heuristic which isn't reliable. So let users who know their CPU's
TjMax pass it as a module parameter.
Cc: "R, Durgadoss" <durgadoss.r@intel.com>
Cc: Guenter Roeck <guenter.roeck@ericsson.com>
Cc: Alexander Stein <alexander.stein@systec-electronic.com>
Acked-by: Fenghua Yu <fenghua.yu@intel.com>
* git://github.com/davem330/net: (62 commits)
ipv6: don't use inetpeer to store metrics for routes.
can: ti_hecc: include linux/io.h
IRDA: Fix global type conflicts in net/irda/irsysctl.c v2
net: Handle different key sizes between address families in flow cache
net: Align AF-specific flowi structs to long
ipv4: Fix fib_info->fib_metrics leak
caif: fix a potential NULL dereference
sctp: deal with multiple COOKIE_ECHO chunks
ibmveth: Fix checksum offload failure handling
ibmveth: Checksum offload is always disabled
ibmveth: Fix issue with DMA mapping failure
ibmveth: Fix DMA unmap error
pch_gbe: support ML7831 IOH
pch_gbe: added the process of FIFO over run error
pch_gbe: fixed the issue which receives an unnecessary packet.
sfc: Use 64-bit writes for TX push where possible
Revert "sfc: Use write-combining to reduce TX latency" and follow-ups
bnx2x: Fix ethtool advertisement
bnx2x: Fix 578xx link LED
bnx2x: Fix XMAC loopback test
networking driver
The dmfe module is a orphan driver, and with this was removed the maintainer
of the documentation.
Signed-off-by: Marcos Paulo de Souza <marcos.mage@gmail.com>
Revert the post-3.0 commit 82f9d486e59f5 ("memcg: add
memory.vmscan_stat").
The implementation of per-memcg reclaim statistics violates how memcg
hierarchies usually behave: hierarchically.
The reclaim statistics are accounted to child memcgs and the parent
hitting the limit, but not to hierarchy levels in between. Usually,
hierarchical statistics are perfectly recursive, with each level
representing the sum of itself and all its children.
Since this exports statistics to userspace, this may lead to confusion
and problems with changing things after the release, so revert it now,
we can try again later.
Signed-off-by: Johannes Weiner <jweiner@redhat.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Ying Han <yinghan@google.com>
Cc: Balbir Singh <bsingharora@gmail.com>
* git://bedivere.hansenpartnership.com/git/scsi-rc-fixes-2.6: (25 commits)
[SCSI] bnx2i: Fixed the endian on TTT for NOP out transmission
[SCSI] libfc: fix referencing to fc_fcp_pkt from the frame pointer via fr_fsp()
[SCSI] libfc: block SCSI eh thread for blocked rports
[SCSI] libfc: fix fc_eh_host_reset
[SCSI] fcoe: Fix deadlock between fip's recv_work and rtnl
[SCSI] qla2xxx: Update version number to 8.03.07.07-k.
[SCSI] qla2xxx: Set the task attributes after memsetting fcp cmnd.
[SCSI] qla2xxx: Correct inadvertent loop state transitions during port-update handling.
[SCSI] qla2xxx: Save and restore irq in the response queue interrupt handler.
[SCSI] qla2xxx: Double check for command completion if abort mailbox command fails.
[SCSI] qla2xxx: Acquire hardware lock while manipulating dsd list.
[SCSI] qla2xxx: Fix qla24xx revision check while enabling interrupts.
[SCSI] qla2xxx: T10 DIF - Fix incorrect error reporting.
[SCSI] qla2xxx: T10 DIF - Handle uninitalized sectors.
[SCSI] hpsa: fix physical device lun and target numbering problem
[SCSI] hpsa: fix problem that OBDR devices are not detected
[SCSI] isci: add version number
[SCSI] isci: fix event-get pointer increment
[SCSI] isci: dynamic interrupt coalescing
[SCSI] isci: Leave requests alone if already terminating.
The LTTng 2.0 kernel tracer (stand-alone module package, available at
http://lttng.org) uses the 0xF6 ioctl range for tracer control and
transport operations.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
* 'v4l_for_linus' of git://linuxtv.org/mchehab/for_linus:
[media] vp7045: fix buffer setup
[media] nuvoton-cir: simplify raw IR sample handling
[media] [Resend] viacam: Don't explode if pci_find_bus() returns NULL
[media] v4l2: Fix documentation of the codec device controls
[media] gspca - sonixj: Fix the darkness of sensor om6802 in 320x240
[media] gspca - sonixj: Fix wrong register mask for sensor om6802
[media] gspca - ov519: Fix LED inversion of some ov519 webcams
[media] pwc: precedence bug in pwc_init_controls()
Fixed missing ids of the codec controls description in the controls.xml file.
Signed-off-by: Kamil Debski <k.debski@samsung.com>
Reported-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
The chips supported by the max16065 driver should not be accessed using direct
i2ctools commands. Add warning to driver documentation to alert users.
